Initializing a very long vector with some repetition
rafimiet
Member level 5
I have to initialize a very long vector in the pattern such as
x(0*64 TO 0*64+15) = '1';
x(1*64 TO 1*64+15) = '1';
x(2*64 TO 2*64+15) = '1';
x(15*64 TO 15*64+15) = '1';
What is the best way to do so? In some scenarios, it may b even bigger than this, but pattern remains similar.
Is this VHDL, as it has syntax errors?
Where is this initialisation done? Can you post the real code, or a complete example rather than just a snippet?
The vhdl code is as follows:
Code VHDL - [expand]
8
9
10
11
GENERIC(LLrow: INTEGER := 16);
SIGNAL b0 : STD_LOGIC_VECTOR(N*N/4 - 1 downto 0) := (OTHERS => '0') ;
variable row : INTEGER RANGE 1 TO N := 1;
variable addr2_2 : INTEGER RANGE 0 TO N*N-1 := 0;
                                        if row <= LLrow then
                                            b0(addr2_2 + LLrow-1 downto addr2_2) <= (OTHERS => '1');
                                            row := row + 1;
                                            addr2_2 := addr2_2 + N/2;
                                        end if;
As I try to synthesis this, it never comes out of running synthesis.
Please post the whole code, or complete example showing the problem.
row := row + 1;
end if;
This part gives me a headache...plz use signals!
Stop using variables in the synthesizable part of your design. You can do everything with signals.
Don't you know if you write VHDL using variables it behaves more like software ;-)
dpaul... This part gives me a headache...plz use signals!
I have a very long code using Finite State Machine. Here I attach the code. The code is sequential, so using signal provides output only on the next clock cycle. Also I sometimes need to update the value of an object within the same loop twice, which is not possible with signals, so I use variables.
Please check my code design strategy and suggest me how to make my code efficient
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
622
623
624
625
626
627
628
629
630
631
632
633
634
635
636
637
638
639
640
641
642
643
644
645
646
647
648
649
650
651
652
653
654
655
656
657
658
659
660
661
662
663
664
665
666
667
668
669
670
671
672
673
674
675
676
677
678
679
680
681
682
683
684
685
686
687
688
689
690
691
692
693
694
695
696
697
698
699
700
701
702
703
704
705
706
707
708
709
710
711
712
713
714
715
716
717
718
719
720
721
722
723
724
725
726
727
728
729
730
731
732
733
734
735
736
737
738
739
740
741
742
743
744
745
746
747
748
749
750
751
752
753
754
755
756
757
758
759
760
761
762
763
764
765
766
767
768
769
770
771
772
773
774
775
776
-- Company:
-- Engineer:
-- Create Date:    14:39:53 07/27/2017
-- Design Name:
-- Module Name:    FSM_all - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity FSM_all is
    GENERIC (L : INTEGER := 3;                  -- L is level of DWT
                N : integer := 256;             -- N x N is image size
                logN : INTEGER := 8;            -- log10(N)/log10(2) gives n bits that can address N
                LLrow : INTEGER := 16;          -- N/2^(L+1) Range (0 TO LLrow-1)
                word_length : integer := 11);
    Port ( rst,clk : in  STD_LOGIC;
           i : in  STD_LOGIC_VECTOR (7 downto 0);
              out_en : OUT std_logic;
           y : out  STD_LOGIC_VECTOR (word_length-1 downto 0));
end FSM_all;
architecture Behavioral of FSM_all is
                        -- SRA FUNCTION --
    function "sra" (l : signed; r : natural) return signed is
        alias l_a : signed(l'length-1 downto 0) is l;
    begin
        return resize(l_a, l_a'length + r)(l_a'length+r-1 downto r);
    end function "sra";
                        --- RAM SIGNALS ---
    TYPE ram_type IS ARRAY (N*N-1 DOWNTO 0) OF STD_LOGIC_VECTOR(word_length-1 DOWNTO 0);
   SIGNAL RAM1: ram_type;
    SIGNAL RAM2: ram_type;
    SIGNAL we1,en1,we2,en2 : STD_LOGIC :='0';
    SIGNAL addr1,addr2 : INTEGER RANGE 0 TO N*N-1 := 0;
    SIGNAL di1,do1,di2,do2 : STD_LOGIC_VECTOR(word_length-1 DOWNTO 0):= (OTHERS => '0');
                        --- FSM SIGNALS ---
    TYPE state IS (fill_ram,dwt1d,idwt1d,dwt2d,idwt2d,initialize_SPIHT,load_b0,load_coef,ref_bitstream,sorting,output);
    SIGNAL pr_state: state;
                        --- DWT SIGNALS ---
    SIGNAL s1,x2k,s2,s23,s3 : signed(word_length-1 downto 0);
                        --- DEBUGGING SIGNALS ---
    SIGNAL db_addr : INTEGER RANGE 0 TO N*N/4-1 := 0;
                        --- SPIHT SIGNALS ---
                        ---(N*N/(2**(2*L))-1) L=3,N=256 =>1023
    SIGNAL b0 : STD_LOGIC_VECTOR(N*N/4 - 1 downto 0) := (OTHERS => '0') ;--Current block significant
    SIGNAL b1, b2 : STD_LOGIC_VECTOR(N*N/16 - 1 downto 0);-- b1:if all des sig or not, b2: typeA or B
    SIGNAL threshold : INTEGER RANGE 0 TO word_length-1;
    SIGNAL init_thrsh : signed(word_length-1 downto 0) := (OTHERS => '0');
    SIGNAL b0_addr : INTEGER RANGE 0 TO N*N/4-1 := 0;
begin
                        --- RAM1 INITIALIZATION HERE ---
    ram1_init : PROCESS(clk)
                    BEGIN
                        if clk'event AND clk = '1' then
                            if en1 = '1' then
                                if we1 = '1' then
                                    RAM1(addr1) <= di1;
                                else
                                    do1 <= RAM1(addr1);
                                end if;
                            end if;
                        end if;
                    END PROCESS ram1_init;
                        --- RAM2 INITIALIZATION HERE ---
    ram2_init : PROCESS(clk)
                    BEGIN
                            if en2 = '1' then
                                if we2 = '1' then
                                    RAM2(addr2) <= di2;
                                else
                                    do2 <= RAM2(addr2);
                                end if;
                            end if;
                        end if;
                    END PROCESS ram2_init;
                        ----- FSM STARTS FROM HERE ----
                        ----- Main Section of FSM -----
    Main:           PROCESS(clk,rst)
                        ----DWT VARIABLES----
                        variable di_temp,di_temp1 : STD_LOGIC_VECTOR(word_length-1 downto 0);
                        variable adr,ram_out,ram_out1,alt1,alt5 : STD_LOGIC := '0';
                        variable ram_out2 : STD_LOGIC_VECTOR(1 downto 0) := "00";
                        variable addr2_1,addr2_2,addr1_1,addr1_2,addr1_3,addr1_4,a_temp,b_temp : INTEGER RANGE 0 TO N*N-1 := 0;
                        variable v1,v3 : signed(word_length-1 downto 0) := (OTHERS => '0');
                        variable v2 : signed(word_length-1 downto 0);
                        variable count_1,count : INTEGER RANGE 0 TO 7 := 0;
                        variable row,col1,col2,c_col1,c_col2 : INTEGER RANGE 1 TO N := 1;
                        variable M : INTEGER RANGE 0 TO N := N;
                        variable level : INTEGER RANGE 0 TO 5 := 1;
                        variable thrsh : STD_LOGIC_VECTOR(word_length-2 downto 0);
                        ----SPIHT VARIABLES----
                    BEGIN
                        IF clk'EVENT AND clk = '1' THEN
                            IF rst = '0' THEN
                                CASE pr_state IS
                ------- DWT Stages -----------
                                    WHEN fill_ram => -- Take 1D DWT Directly and fill into RAM2
                                        out_en <= '0';
                                        di_temp(word_length-1 downto 8) := (OTHERS => '0');
                                --      di_temp(5 downto 0) := (OTHERS => '0');
                                        di_temp(7 downto 0) := i;
                                        if adr = '0' then
                                            adr := '1';
                                            addr1 <= 0;
                                            addr2 <= 0;
                                            addr2_1 := 0;
                                            addr2_2 := M*M/2;
                                            ram_out := '0';count := 0;
                                        end if;
                                        if count = 0 then
                                            count := count + 1;
                                        elsif alt5 = '1' then
                                            s1 <= signed(di_temp1);
                                            x2k <= signed(di_temp);
                                            v1 := s1 + x2k;
                                            s2 <= v1 sra 1;
                                            v2 := s1 - x2k;
                                            s23 <= v2 sra 1;
                                            alt5 := NOT alt5;
                                        else
                                            alt5 := NOT alt5;
                                            di_temp1 := di_temp;
                                        end if;
                                        s3 <= s23;
                                        if ram_out = '0' then
                                            if count_1 >= 6 then
                                                we2 <= '1'; en2 <= '1';
                                                di2 <= std_logic_vector(s2);
                                                addr2 <= addr2_1;
                                                addr2_1 := addr2_1 + 1;
                                                ram_out := '1';
                                            else
                                                count_1 := count_1 + 1;
                                            end if;
                                        else
                                            addr2 <= addr2_2;
                                            addr2_2 := addr2_2 + 1;
                                            di2 <= std_logic_vector(s3);
                                            ram_out := '0';
                                            if addr2_2 = M*M then
                                                pr_state <= dwt2d;
                                                alt5 := '0';
                                                count_1 := 0;
                                                adr := '0';
                                                s1 <= (OTHERS => 'Z');s2 <= (OTHERS => 'Z');
                                                s3 <= (OTHERS => 'Z');
                                                x2k <= (OTHERS => 'Z');
                                            end if;
                                        end if;
                                    WHEN dwt1d =>
                                        out_en <= '0';
                                        we1 <= '0';
                                        if adr = '1' then
                                            addr1 <= 0;
                                            count := 0;
                                            adr := '0';a_temp := 0;
                                            addr2_1 := 0;col1 := 1;
                                            addr2_2 := M*M/2;row := 1;
                                            ram_out := '0';alt5 := '0';
                                            di_temp1 := (OTHERS => 'Z');
                                        elsif col1 <= M then
                                            if row < M then
                                                if row = 1 then
                                                    a_temp := addr1;
                                                end if;
                                                addr1 <= addr1 + 1;
                                                row := row + 1;
                                            else
                                                row := 1;
                                                if col1 < M then
                                                    addr1 <= a_temp + N;
                                                end if;
                                                col1 := col1 + 1;
                                            end if;
                                        end if;
                                        if count <= 1 then
                                            count := count + 1;
                                            x2k <= signed(do1);
                                            v1 := s1 + x2k;
                                            s2 <= v1 sra 1;
                                            v2 := s1 - x2k;
                                            s23 <= v2 sra 1;
                                            alt5 := NOT alt5;
                                        else
                                            alt5 := NOT alt5;
                                            di_temp1 := do1;
                                        end if;
                                        s3 <= s23;
                                                addr2 <= addr2_1;
                                                ram_out := '1';
                                            else
                                            end if;
                                        else
                                            addr2 <= addr2_2;
                                            ram_out := '0';
                                                pr_state <= dwt2d;
                                                alt5 := '0';
                                                count_1 := 0;
                                            end if;
                                        end if;
                                    WHEN dwt2d =>
                                        out_en <= '0';
                                        we2 <= '0';
                                        if adr = '0' then
                                            addr2 <= 0;
                                            row := 1;
                                            col1 := 1;
                                            adr := '1';
                                            addr1_1 := 0;
                                            addr1_2 := M*N/2;
                                            addr1_3 := M/2;
                                            addr1_4 := M*(N+1)/2;
                                            ram_out := '0';
                                            count_1 := 0;count := 0;
                                        elsif row < M then
                                            row := row + 1;
                                            addr2 <= addr2 + M/2;
                                        elsif row = M then
                                            if col1 < M/2 then
                                                col1 := col1 + 1;
                                                addr2 <= col1 - 1;
                                                row := 1;
                                            elsif col1 = M/2 then
                                                col1 := col1 + 1;
                                                col2 := 1;
                                                addr2 <= M*M/2;
                                                row := 1;
                                            else
                                                if col2 < M/2 then
                                                    col2 := col2 + 1;
                                                    addr2 <= M*M/2 + col2-1;
                                                    row := 1;
                                                end if;
                                            end if;
                                        end if;
                                        if count <= 1 then
                                            count := count + 1;
                                            x2k <= signed(do2);
                                            v1 := s1 + x2k;
                                            s2 <= v1 sra 1;
                                            v2 := s1 - x2k;
                                            s23 <= v2 sra 1;
                                            alt5 := NOT alt5;
                                        else
                                            alt5 := NOT alt5;
                                            di_temp1 := do2;
                                        end if;
                                        s3 <= s23;
                                        if s23(word_length-1) = '0' then
                                            if s23 > v3 then
                                                v3 := s23;
                                            end if;
                                        end if;
                                        if s2(word_length-1) = '0' then
                                            if s2 > v3 then
                                                v3 := s2;
                                            end if;
                                        end if;
                                        init_thrsh <= v3;
                                        if ram_out2 = "00" then
                                                we1 <= '1'; en1 <= '1';
                                                di1 <= std_logic_vector(s2);
                                                if c_col1 = 1 then
                                                    addr1_1 := a_temp;
                                                    c_col1 := c_col1 + 1;
                                                elsif c_col1 = M/2 then
                                                    a_temp := a_temp + 1;
                                                    c_col1 := 1;
                                                    addr1_1 := addr1_1 + N;
                                                else
                                                end if;
                                                addr1 <= addr1_1;
                                                ram_out2 := "01";
                                            else
                                                a_temp := 0;
                                            end if;
                                        elsif ram_out2 = "01" then
                                            addr1 <= addr1_2;
                                            ram_out2 := "00";
                                                if c_col2 < M/2 then
                                                    if c_col2 = 1 then
                                                        b_temp := addr1_2;
                                                    end if;
                                                    c_col2 := c_col2 + 1;
                                                    addr1_2 := addr1_2 + N;
                                                else
                                                    if addr1_2 = N*(M-1) + M/2 -1 then
                                                        ram_out2 := "10";
                                                        count_1 := 0;
                                                        c_col1 := 1;
                                                        c_col2 := 1;
                                                        alt1 := '0';
                                                    else
                                                        addr1_2 := b_temp + 1;
                                                    end if;
                                                    c_col2 := 1;
                                                end if;
                                            di1 <= std_logic_vector(s3);
                                        elsif ram_out2 = "10" then
                                            addr1 <= addr1_3;
                                            if c_col1 < M/2 then
                                                if c_col1 = 1 then
                                                    a_temp := addr1_3;
                                                end if;
                                                addr1_3 := addr1_3 + N;
                                            else
                                                addr1_3 := a_temp + 1;
                                                c_col1 := 1;
                                            end if;
                                            ram_out2 := "11";
                                        else
                                            addr1 <= addr1_4;
                                            ram_out2 := "10";
                                                if c_col2 = 1 then
                                                    b_temp := addr1_4;
                                                end if;
                                                addr1_4 := addr1_4 + N;
                                            else
                                                if addr1_4 = N*(M-1) + M - 1 then
                                                    ram_out2 := "00";
                                                    count_1 := 0;
                                                    if level < L then
                                                        pr_state <= dwt1d;
                                                        level := level + 1;
                                                        alt5 := '0';
                                                        M := M/2;
                                                    else
                                                        pr_state <= initialize_SPIHT;
                                                        alt5 := '0';count_1 := 0;
                                                        level := 1;addr2_2 := 0;
                                                        addr2 <= 0;row := 1;
                                                        count := 0;addr2_1 := 0;
                                                    end if;
                                                end if;
                                                addr1_4 := b_temp + 1;
                                                c_col2 := 1;
                                            end if;
                                        end if;
                ------- SPIHT STAGES ----------------
                ------- REFINEMENT PASS -------------
                                    WHEN initialize_SPIHT =>
                                        if row <= 2*LLrow then
                                            b0(addr2_2 + 2*LLrow-1 downto addr2_2) <= (OTHERS => '1');
                                            row := row + 1;
                                            if count_1 <= word_length-1 then
                                                if init_thrsh(word_length-1-count_1) = '1' then
                                                    threshold <= word_length-1-count_1;
                                                else
                                                end if;
                                            end if;
                                        else
                                            pr_state <= load_b0;
                                        end if;
                                        addr1 <= 0;
                                    WHEN load_b0 =>
                                        we1 <= '0';we2 <= '0';
                                        if b0_addr < N*N/4 then
                                            if b0_addr <= N*N/4-9 then
                                                if b0(b0_addr+7 downto b0_addr) = "00000000" then
                                                    b0_addr <= b0_addr + 8;
                                                elsif b0(b0_addr) = '1' then
                                                    pr_state <= load_coef;
                                                else
                                                    b0_addr <= b0_addr + 1;
                                                end if;
                                            else
                                                else
                                                end if;
                                            end if;
                                        else
                                            pr_state <= sorting;
                                            b0_addr <= 0;
                                        end if;
                                        db_addr <= b0_addr;
                                    WHEN load_coef =>
                                        if count = 0 then
                                            addr1 <= to_integer(to_unsigned(b0_addr,2*logN) sll 1) + to_integer((to_unsigned(b0_addr,2*logN) srl logN-1) sll logN);
                                        elsif count = 2 then
                                            addr1 <= addr1 + N - 1;
                                        else
                                            addr1 <= addr1 + 1;
                                        end if;
                                        pr_state <= ref_bitstream;
                                    WHEN ref_bitstream =>
                                        if do1(word_length-1) = '1' then
                                            di_temp := std_logic_vector(-signed(do1));
                                        else
                                            di_temp := do1;
                                        end if;
                                        if di_temp(threshold) = '1' then ---SIGNIFICANT AT THIS THRESHOLD
                                            thrsh := (OTHERS => '0');
                                            thrsh(threshold) := '1';
                                            if di_temp(word_length-2 downto 0) > thrsh then
                                                a_temp := 1;
                                            else
                                                a_temp := 0;
                                            end if;
                                            if  a_temp = 0 then ---NOT ALREADY SIGNIFICANT COEFFICIENT
                                                if addr2_1 = word_length-1 then --- can hold only one more bit
                                                    di_temp1(addr2_1) := do1(word_length-1);
                                                    di2 <= di_temp1;
                                                    addr2 <= addr2 + 1;
                                                    we2 <= '1';
                                                    addr2_1 := 0;
                                                    di_temp1(addr2_1) := di_temp(threshold);
                                                    addr2_1 := 1;
                                                elsif addr2_1 = word_length-2 then
                                                    di2 <= di_temp1;
                                                    addr2 <= addr2 + 1;
                                                    we2 <= '1';
                                                    addr2_1 := 0;
                                                else
                                                    addr2 <= addr2 + 1;
                                                    we2 <= '0';
                                                end if;
                                            else ---- ALREADY SIGNIFICANT COEFFICIENT
                                                    di2 <= di_temp1;
                                                    addr2 <= addr2 + 1;
                                                    we2 <= '1';
                                                    addr2_1 := 0;
                                                else
                                                    we2 <= '0';
                                                end if;
                                            end if;
                                        else --- NOT SIGNIFICANT AT THIS THRESHOLD
                                                di2 <= di_temp1;
                                                addr2 <= addr2 + 1;
                                                we2 <= '1';
                                                addr2_1 := 0;
                                            else
                                                we2 <= '0';
                                            end if;
                                        end if;
                                        if count = 3 then
                                            b0_addr := b0_addr + 1;
                                            count := 0;
                                        else
                                            count := count + 1;
                                        end if;
                                    WHEN sorting =>
                                        pr_state <= idwt1d;
                -------- IDWT STAGES ----------------
                                    WHEN idwt1d =>
                                        we1 <= '0';en1 <= '1';
                                        out_en <= '0';
                                        if adr = '1' then
                                            ram_out2 := "00";
                                            adr := '0';
                                            ram_out1 := '0';
                                            addr1_1 := 0;
                                            addr1_2 := M*N/2;
                                            addr1_3 := M/2;
                                            addr2 <= 0;a_temp := 0;
                                            alt1 := '0';c_col2 := 1;
                                            c_col1 := 1; alt5 := '0';
                                    --      s1 <= (OTHERS => 'Z'); do1 <= (OTHERS => 'Z');do1 <= (OTHERS => 'Z');
                                        end if;
                                            we1 <= '0'; en1 <= '1';
                                            if c_col1 = 1 then
                                                addr1_1 := a_temp;
                                                c_col1 := 1;
                                            else
                                            end if;
                                            addr1 <= addr1_1;
                                            ram_out2 := "01";
                                            addr1 <= addr1_2;
                                            ram_out2 := "00";
                                                    if c_col2 = 1 then
                                                        b_temp := addr1_2;
                                                    end if;
                                                else
                                                        ram_out2 := "10";
                                                        c_col1 := 1;
                                                        c_col2 := 1;
                                                        alt1 := '0';
                                                    else
                                                    end if;
                                                    c_col2 := 1;
                                                end if;
                                            addr1 <= addr1_3;
                                                if c_col1 = 1 then
                                                    a_temp := addr1_3;
                                                end if;
                                            else
                                                c_col1 := 1;
                                            end if;
                                            ram_out2 := "11";
                                        else
                                            addr1 <= addr1_4;
                                            ram_out2 := "10";
                                                if c_col2 = 1 then
                                                    b_temp := addr1_4;
                                                end if;
                                            else
                                                    ram_out2 := "11";
                                                else
                                                    c_col2 := 1;
                                                end if;
                                            end if;
                                        end if;
                                        if count <= 1 then
                                            count := count + 1;
                                            x2k <= signed(do1);
                                            s2 <= s1 + x2k;
                                            s23 <= s1 - x2k;
                                            alt5 := NOT alt5;
                                        else
                                            alt5 := NOT alt5;
                                            di_temp1 := do1;
                                        end if;
                                        s3 <= s23;
                                            we2 <= '1';
                                                ram_out := '1';
                                            else
                                                ram_out := '0';
                                            end if;
                                            if count_1 <= 7 then
                                                addr2 <= 0;
                                            else
                                                if row < M then
                                                    row := row + 1;
                                                elsif row = M then
                                                    if col1 < M/2 then
                                                        col1 := col1 + 1;
                                                        addr2 <= col1 - 1;
                                                        row := 1;
                                                        col1 := col1 + 1;
                                                        col2 := 1;
                                                        addr2 <= M*M/2;
                                                        row := 1;
                                                    else
                                                        if col2 < M/2 then
                                                            col2 := col2 + 1;
                                                            row := 1;
                                                        elsif col2 = M/2 then
                                                            pr_state <= idwt2d;
                                                        end if;
                                                    end if;
                                                end if;
                                            end if;
                                        else
                                            count_1 := count_1 + 1;we2 <= '0';
                                            row := 1;col1 := 1;col2 := 1;ram_out := '0';
                                        end if;
                                    WHEN idwt2d =>
                                        out_en <= '0';
                                        we2 <= '0';
                                        if adr = '0' then
                                            adr := '1';
                                            addr1 <= 0;
                                            addr1_1 := 0;
                                            addr2 <= 0;
                                            count_1 := 0;
                                            count := 0;
                                            col1 := 1;
                                            addr2_1 := 0;alt5 := '0';
                                            addr2_2 := M*M/2;alt5 := '0';
                                            ram_out := '0';col1 := 1;ram_out1 := '0';
                                        end if;
                                            addr2 <= addr2_1;
                                            ram_out := '1';
                                        else
                                            addr2 <= addr2_2;
                                            if addr2_2 = M*M-1 then
                                                ram_out := '1';
                                            else
                                                ram_out := '0';
                                            end if;
                                        end if;
                                        if count <= 1 then
                                            count := count + 1;
                                            x2k <= signed(do2);
                                            s2 <= s1 + x2k;
                                            s3 <= s1 - x2k;
                                            alt5 := NOT alt5;
                                        else
                                            alt5 := NOT alt5;
                                            di_temp1 := do2;
                                        end if;
                                            we1 <= '1';en1 <= '1';
                                            if ram_out1 = '0' then
                                                ram_out1 := '1';
                                            else
                                                ram_out1 := '0';
                                            end if;
                                            if count_1 <= 6 then
                                                addr1 <= 0;
                                                if row < M then
                                                    if row = 1 then
                                                        a_temp := addr1;
                                                    end if;
                                                    addr1 <= addr1 + 1;
                                                    row := row + 1;
                                                else
                                                    row := 1;
                                                    if col1 < M then
                                                    end if;
                                                    col1 := col1 + 1;
                                                end if;
                                            else
                                                if level = L then
                                                    pr_state <= output;
                                                else
                                                    pr_state <= idwt1d;
                                                    level := level + 1;
                                                    M := 2*M;
                                                end if;
                                            end if;
                                        else
                                            addr1 <= 0;a_temp := 0;row := 1;
                                            alt1 := '0'; col1 := 1;
                                        end if;
                ----- OUTPUT STAGES ------
                                    WHEN output =>
                                        out_en <= '1';
                                            y <= (OTHERS => '0');
                                        else
                                            y(word_length-1 downto 0) <= do1(word_length-1 downto 0);
                                        end if;
                                        if alt1 = '0' then
                                            addr1_1 := 0;
                                            alt1 := '1';
                                        else
                                            addr1_1 := addr1_1 + 1;
                                            if addr1_1 = N*N then
                                                pr_state <= fill_ram;
                                            end if;
                                        end if;
                                        addr1 <= addr1_1;
                                END CASE;
                            END IF;
                        END IF;
                    END PROCESS Main;
end Behavioral;
Without making things more complicated, lets come to your original problem....
Why don't you use a generate statement to achieve the above(assuming x is a signal of type std_logic_vector)?
array_gen : for i in 0 to 15 generate
x(i*64 TO i*64+15) <= (others => '1');
end generate array_gen;
As Tricky mentioned in #2, it would be interesting to know what x is is!
I can't go through your long code, but...
This is not good. Allow extra states (I am sure your design can live with 2 or 3 clks of extra latency), let the signals update on the next clk, and then check their values in a new state.
If you want FSM coding style from Xilinx- https://www.xilinx.com/support/docu...hing/HDL-Design/2015x/VHDL/docs-pdf/lab10.pdf
This post is all very confusing, as I dont understand how the original question relates to the huge code posted.
This wont work, as this is not an initialisation, but just driving all the bits of X to constant 1. Its not clear what the OP means by initialisation - do you mean power up initialisation or initialisation as part of your running design. ie something writes all the addresses of a ram?
Please clarify exactly what the problem is.
As for comments on your code:
1. Where are the comments?
2. With few comments, signal naming is just annoying.
3. Do you really need so many states?
4. From my brief look, it looks like an attempt to port some software. Could you not have re-architected to make it more pipeline friendly?
