Results 1 to 13 of 13
    Junior Member level 2
    Points: 1,171, Level: 7
    Jul 2012
    20
    1,171
    7
    Counter Preload by any given values
    How can preload the counter by known value......counter is either synchronous or asynchronous.
    if i want to start my counter from 5 then which type of coding is required in verilog....
    Points: 7,451, Level: 20
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germay
    1,094
    7,451
    20
    Blog Entries
    Re: Counter Preload by any given values
    Synchronous logic will be better. I won't give you codes, but hints.
    1st do you know how to write code for a simple synchronous up or down counter?
    If no, then 1st learn how a simple synchronous counter can be coded with Verilog (Google search will give you 100's of results).
    If yes, then you can modify that slightly to allow loading of values from an external port. Keep a single bit input port named such as counter_load_i. Depending on the counter start value to be loaded (for your case it is 5), keep provision for another multi-bit input port through which you can load this value.
    Now on the rising edge of your clock, check if your counter_load_i is HIGH (this signal should be high only when you want to load the particular start value, else low). So if it is high, load the value (5) from the external multi-bit input port to an internal register, on the clock rising edge. Next increment/decrement that internal register on the clk rising edge. There...your system is done!
    .....yes, I do this for fun!
    Points: 6,076, Level: 18
    Apr 2016
    6,076
    18
    Quote Originally Posted by sandy2811 View Post
    forget asynchronous. make it synchronous. add a reset signal or a load signal that can make the counter value assume e.g. 5
    Really, I am not Sam.
    •   Alt1st September 2017, 14:59
      advertising
    Points: 899, Level: 6
    Dec 2013
    36
    899
    use a synchronous counter with reset value 5
    •   Alt3rd September 2017, 22:34
      advertising
    Jul 2012
    20
    1,171
    7
    I have already done this things as you have told, but i want to reset it by using preset or clear logic but i am not getting it perfectly...............
    Points: 60,593, Level: 60
    Apr 2014
    12,371
    60,593
    60
    Show your code.
    Then it's more easy to see what (and how) you have done so far...and to give detailled code modifications.
    •   Alt4th September 2017, 07:09
      advertising
  7. #7
    Jul 2012
    20
    1,171
    7
    Show your code.
    My code is this
    Code Verilog - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    module preload_counter(q,
                           clk,
                           rst,
                           en,
                           load,
                           preload,
                           upd
    input clk,rst,load,upd,en;
    input [2:0] preload;
    integer c;
    output [2:0] q;
    reg [2:0] q;
    always @(posedge clk)
    begin
       if (rst)
         q <= 3'b000;
        else if (load)
            q <= preload;
           else if(upd)
           // else
          begin
             q <= q + 1;
             if( q == 3'b111)
               begin
               c = 1'b1;
               $display("Counter is full count = %b and c = %d",q,c);
               end
             end
           else
             begin
             q <= q - 1;
             if( q == 3'b000)
               begin
               c = 1'b0;
               $display("Counter is empty count = %b and c = %d",q,c);
               end
           end
    end
    endmodule
  8. #8
    Dec 2013
    36
    899
    I'm sorry what is exactly the problem in this code ?
  9. #9
    Jul 2012
    20
    1,171
    7
    Nothing problem in this code but my idea is to make a counter which is start by a given or known value( i assume 5).
    and i want to start counter by this (5) initial value by using preset or clear input.
  10. #10
    dpaul's Avatar
    Jan 2008
    Germay
    1,094
    7,451
    20
    Blog Entries
    In common terminology, a clear input drives a flop to a reset state (this would be similar to what your are doing with the rst signal).
    A preset input drives a flip-flop to a set state, and I guess you want the counter value to be 5 when a preset signal is asserted. So just add a sync check for another input signal 'preset' which, if high, will drive q to value 5.
    I recommend you to read and understand this:
    http://www.csit-sun.pub.ro/courses/M.../hdlcode6.html
  11. #11
    Member level 3
    Points: 2,406, Level: 11
    Nov 2006
    61
    2,406
    11
    Sandy2811, in the code you provided, you need to change the "always @(posedge clk)" to be "always @(posedge rst or posedge clk)" to see the effect of "rst" in simulation
    •   Alt6th September 2017, 16:00
      advertising
  12. #12
    dpaul's Avatar
    Jan 2008
    Germay
    1,094
    7,451
    20
    Blog Entries
    The OP might be modeling a sync reset, we don't know, so he maybe correct!
  13. #13
    Jul 2012
    20
    1,171
    7
    Quote Originally Posted by sherif123 View Post
    Thanks but i have design this for synchronous reset.....
