Results 1 to 6 of 6
    Points: 1,082, Level: 7
    Aug 2013
    45
    1,082
    7
    very strange typecast (VHDL)
    hello,
    I just noticed this port map in the project I am working on:
    Code VHDL - [expand]
    custom_fifo
            PORT map(
              clk                            => clk,
              std_logic_vector(q)            => q
    I have never seen such a thing. What's its purpose, how does it work, how is this called? If this was to convert from one signal type to another I'd rather do it this way:
    custom_fifo
            PORT map(
              clk                      => clk,
              q      => std_logic_vector(q)
    Is it perhaps equivalent?
    •   AltAdvertisment
    Points: 245,688, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,688
    245,688
    100
    Re: very strange typecast (VHDL)
    Read about named versus positional association in component instantiation.
    Both example codes have syntax error, missing delimiting ",".
    •   AltAdvertisment
    Points: 36,169, Level: 46
    Jun 2010
    6,614
    36,169
    46
    It was done like this because I assume the local version of q was a slv, while the q in the port map is signed/unsigned. You have to do the conversion on the LHS otherwise it is an illegal assignment.
    •   AltAdvertisment
    Aug 2013
    45
    1,082
    7
    I realised now I wasn't very clear in my question. The question was related to type conversion, not port assotiations, sorry
    The missing "," is not a syntax error, " . . . " is (it was on purpose).
    yes, the conversion is neccessary due to type difference in port / signal.
    LHS conversions are very rarely used, seems like I forgot about this feature.
    Thank you guys
    Aug 2013
    45
    1,082
    7
    guess I'd need the help of you guys once more on this topic:
    8
    9
    10
    11
    signal   DQ                        :   std_ulogic_vector( 7 downto 0);
    -- memory simulation model
    inst_name : entity_name
       Port map (
          E_b                     => CSN(0),
          W_b                     => WEN,
          G_b                     => OEN,
          A                       => std_logic_vector(Addr(16 downto 0)),
          std_ulogic_vector(DQ)   => std_logic_vector(DQ (7 downto 0))
    The component ports are of type std_logic, the signals connected to the instance are of type ulogic.
    That works fine for all ports of type IN or OUT, but port DQ is of type INOUT.
    So I converted the signal on both sides, once for input once for output.
    This compiles fine as long as the signal is 'floating' (not connected anywhere).
    As soon as I connect it with a port of another instance I get the error:
    I get the following error: "DQ(7)" has multiple drivers but is not a resolved signal.
    Can you help?
    many thanks
    •   AltAdvertisment
    Jun 2010
    6,614
    36,169
    46
    Because it is an inout, it implies DQ will be driving from multiple places. So here, DQ will need to be connected to a std_logic_vector, not a ulogic, as ulogic is not a resolved type (std_logic is)
