Results 1 to 9 of 9
    Newbie level 3
    Points: 25, Level: 1
    Aug 2017
    25
    cQFP 176 pin .dxf or .dwg file
    I'm looking for a .dxf or .dwg file of a cQFP 176 pin package.
    I've done some googling but didn't find anything. Anyone on the forum knows where to get?
    Greetz,
    Egoe
    Full Member level 6
    Points: 2,649, Level: 11
    SLK001's Avatar
    Aug 2015
    Coral Springs, Florida
    372
    2,649
    11
    Re: cQFP 176 pin .dxf or .dwg file
    I've never seen any package in any format rather than a basic drawing with dimensions, so that your own footprint can be made for your PCB software package.
    •   Alt3rd August 2017, 23:08
      advertising
    Newbie level 3
    Aug 2017
    25
    Hi SLK001,
    Thanks for the reply.
    Well I am actually looking for a basic drawing with dimensions. I want to import this drawing into Visio and add some other things and use it for documentation purposes. So I don't really want to make a footprint for it.
    For another package type: QFN100 I've found on the web a .dxf file, which I could manipulate to my needs in LibreCad and Visio. A .dxf or .dwg QFP176 file I haven't found yet.
    Points: 244,846, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,531
    244,846
    100
    What is "cQFP176"? Unless a manufacturer refers to an industry standard (e.g. JEDEC) package definition, a valid dimension specification can be only obtained from the manufacturer.
    Same pin count packages can have dimension differences that aren't obvious at first sight. Thus it's important to use original manufacturer specifications.
    Sketching a QFP package is very easy once you have the correct dimensions.
    •   Alt4th August 2017, 10:15
      advertising
    Newbie level 3
    Aug 2017
    25
    Hi FvM,
    "cQFP176":
    c : Ceramic
    QFP: Quad Flat Package
    176 : 176pins
    Based on your comment it makes sense to request a .dwg or .dxf file from the manufacturer. As I don't seem to easily find a (JEDEC) package definition. Initially I wanted to avoid involving a manufacturer as I wanted to do some feasibility by myself and afterwards contact potential manufacturers.
    Points: 12,189, Level: 26
    Feb 2010
    UNITED KINGDOM
    1,929
    12,189
    26
    pin pitch, body size etc.
  7. #7
    Advanced Member level 3
    Points: 6,313, Level: 18
    Sep 2009
    Lancashire UK.
    932
    6,313
    18
    Get the free Library Expert Lite software from pcblibraries, enter the dimensions of your component to create the component then look at the dimensions tab, take a screenshot using the windows snipping program (or whatever you have) and paste that into visio.
    Before you ask - have you searched the forum? Have you searched Google? - Please do so.
    Please do not ask me in private - ask in public. Also please do not ask me to be a forum friend.
    If I have gone to the effort to help you etc then please have the decency to at least acknowledge it and do not just ask a question then never come back..
  8. #8
    Newbie level 3
    Aug 2017
    25
    Thanks for all the inputs. I'm following Mattylad proposal.
    Egoe
    •   Alt1st September 2017, 21:57
      advertising
  9. #9
    Feb 2010
    UNITED KINGDOM
    1,929
    12,189
    26
    That is not going to be dimensionaly 1:1 if that is what you are looking for...
    YOU ALSO NEED THE INFORMATION I MENTIONED IN #6
