Results 1 to 2 of 2
    Member level 3
    Points: 417, Level: 4
    Jul 2017
    59
    417
    VHDL Equivalent of Verilog Code
    Please anyone tell me the VHDL equivalent for the below verilog code.
    Code Verilog - [expand]
    assign  ifc_cle = (cpu_rst_n & (~rst_hold_f) & ((req_md_r == 2'b11)? req_rst_r : 1'b1))? 1'bz : (boot_override_r? rcw_src_r[8] : 1'bz);
    •   AltAdvertisment
    Points: 36,169, Level: 46
    Jun 2010
    6,614
    36,169
    46
    Re: VHDL Equivalent of Verilog Code
    You are trying to translate some really badly written Verilog. I suggest you find a better source, or a Verilog tutorial/reference book. Or better still - understand what you're trying to do and write your own.
    Im going to give a direct translation, written in equally bad formatting (though I assume you'll just copy and paste anyway, rather than try and understand it):
    Code VHDL - [expand]
    ifc_cle <= 'Z' when cpu_rst_n = '1' and rst_hold_f = '0' and ( (req_md_r = "11" and req_rst_t = '1') or req_md_r /= "11" ) else rcw_src_r(8) when boot_override_r = '1' else 'Z';
    and here is the improved VHDL 2008 version:
    ifc_cle <= 'Z' when ??(cpu_rst_n  and not rst_hold_f) and ( (req_md_r = "11" and ??req_rst_t ) or req_md_r /= "11" ) ) else rcw_src_r(8) when ??boot_override_r else 'Z';
