Results 1 to 6 of 6
    Newbie level 3
    Points: 134, Level: 1
    Dec 2016
    134
    how generate prbs in hspice?
    hi
    how i can have "prbs" in hspice....but no use a lfsr beacuse it does not work!!
    can you help me?!
    hurry up :)
    Points: 260,224, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    Re: how generate prbs in hspice?
    Sure? What did you try yet?
    Points: 39,706, Level: 48
    Mar 2008
    USA
    6,413
    39,706
    48
    Your implemantation of a LFSR may have failed, but I
    am pretty sure that this does not prove it's not viable.
    A pwlfile type source can be populated (its state file)
    with any series of time/value pairs you like.
    A series string of vpulse voltage sources with varying
    delays / PWs can emulate a random bit stream.
    Newbie level 3
    Dec 2016
    134
    if we can produce a random bit generator in hspice?
    please write a code :)
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    pwlfile is probably unhandy for long prbs sequences. Thus a behavioral model of the lfsr feedback circuit may be preferable.
    Personally I don't use HSPICE and can't help with an example. I clearly imagine a solution in Pspice or Ltspice, I'm rather sure it exists in HSPICE as well.
    Mar 2008
    USA
    6,413
    39,706
    48
    A question is, just how "random" does this bit stream
    need to be? If all you are looking for is a NRZ pattern
    that exercises maximum and minimum transition
    density, for example, that might be easiest built with
    the stack of pulse sources (or, parallel rack of pulsed
    currents, terminated by a burden resistor) that make
    a few different patterns within the simulation interval.
    If HSPICE has a tnoise type capability maybe it has a
    noise source that acts in the time domain. Then all you
    might need is a clocked comparator behavioral model
    to clean it and make logic levels.
