Results 1 to 4 of 4
    Member level 3
    Points: 968, Level: 7
    Nov 2013
    iran
    60
    968
    7
    fpga programmed successfully but it doesn't work correctley
    Hi every one,
    I wanted to check the FPGA(spartan 6(xc6slx150)) on the board so I wrote a very simple code as below:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    entity test is
        Port ( out_put : out  STD_LOGIC_VECTOR (9 downto 0)	);
    end test;
    architecture Behavioral of test is
    begin
    out_put<="0101010101";
    end Behavioral;
    and ucf file is as below:
    NET "out_put[0]" IOSTANDARD = LVCMOS18;
    NET "out_put[1]" IOSTANDARD = LVCMOS18;
    NET "out_put[2]" IOSTANDARD = LVCMOS18;
    NET "out_put[3]" IOSTANDARD = LVCMOS18;
    NET "out_put[4]" IOSTANDARD = LVCMOS18;
    NET "out_put[5]" IOSTANDARD = LVCMOS18;
    NET "out_put[6]" IOSTANDARD = LVCMOS18;
    NET "out_put[7]" IOSTANDARD = LVCMOS18;
    NET "out_put[8]" IOSTANDARD = LVCMOS18;
    NET "out_put[9]" IOSTANDARD = LVCMOS18;
    NET "out_put[0]" LOC = W18;
    NET "out_put[1]" LOC = Y18;
    NET "out_put[2]" LOC = T16;
    NET "out_put[3]" LOC = T15;
    NET "out_put[4]" LOC = U17;
    NET "out_put[5]" LOC = U16;
    NET "out_put[6]" LOC = V19;
    NET "out_put[7]" LOC = V18;
    NET "out_put[9]" LOC = R15;
    NET "out_put[8]" LOC = R16;
    I programmed the fpga via JTAG and everything was ok it said in the ISE IMPACT that program succeeded but when I checked the IOs which I valued in the vhdl code the logic is incorrect I'm sure that the hardware and voltages on the board are correct what do you think? what is my problem?
    could it be possible that there is a problem in the programmer and it doesn't program the .bit file correctly?
    Matin
    •   AltAdvertisment
    Points: 21,066, Level: 35
    barry's Avatar
    Mar 2005
    California, USA
    4,056
    21,066
    35
    Re: fpga programmed successfully but it doesn't work correctley
    Are you sure you programmed the proper bitfile? How are verifying the outputs-this is a bga, isn't it?
    •   AltAdvertisment
    Member level 3
    Nov 2013
    iran
    60
    968
    7
    Hi
    I'm sure I load the correct file. it doesn't work yet, I checked all the things over and over again but I could not understand what is wrong :( it programmed successfully but when I want to check the GPIOs by voltmeter the outputs are not correct :(
    I attached my simple project please check it if you can and tell me what is my problem?
    Matin
    test_io.rar
    •   AltAdvertisment
    barry's Avatar
    Mar 2005
    California, USA
    4,056
    21,066
    35
    1) how are you looking at pins on a bga?
    2) are your power supply voltages correct?
    3) if you're going to be playing with FPGAs you're going to need more than a voltmeter.
    4) have you looked at your pinFile? Any messages from synthesis or PAR that might give you a clue?
