Results 1 to 8 of 8
    Points: 46, Level: 1
    Jun 2017
    46
    [Moved]: How to remove noise from an eeg signal contaminated with noise?
    i need to remove noise from th eeg signal using a notch filter.Can anyone please help me with the coding?
    Points: 23,791, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,565
    23,791
    37
    Re: How to remove noise from an eeg signal contaminated with noise?
    Coding? Do you mean you want a DIGITAL filter? Your question is pretty vague. Frequency? Bandwidth? Order? Sampling frequency? Programming language? Other requirements?
    Points: 39,350, Level: 48
    Mar 2008
    USA
    6,358
    39,350
    48
    They were assigning this problem in sophomore circuits
    classes when I was an undergrad (30+ years ago). Nice
    to know universities are keeping up (by moving the
    problem to DSP... yeh.
    Jun 2017
    46
    yes sir,i agree with u..I questioned in a vague manner without mentioning any information.
    Sir firstly i initiated with a raw eeg data which i had taken from .mat file..Then i added noise to it..Now i want to filter that noise either by a filter that produces the best kind of results..The code for the above mentioned steps is given below:
    Code PHP - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    fs = 512
    T = 1/fs;
    N =length(EEGsig); ls = size(EEGsig);
    tx =[0:length(EEGsig)-1]/fs;
    fx = fs*(0:N/2-1)/N;
    ax=1;
    x=  EEGsig;
    fNoise = 50;
    aNoise = 0.25;
    noise= aNoise*x;
    signalNoise= x + noise;
    figure();
    subplot(3,1,1);
    plot(tx, x);
    xlabel('Time [s]');
    ylabel('Amplitude');
    title('Original signal');
    subplot(3,1,2);
    plot(tx, noise);
    xlabel('Time [s]');
    title('Noise');
    subplot(3,1,3);
    plot(tx, signalNoise);
    xlabel('Time [s]');
    title('Original signal + Noise');
    hence,in the above code i need to filter the added noise..Please help me with the code..N thanks for your reply sir.
    barry's Avatar
    Mar 2005
    California, USA
    4,565
    23,791
    37
    Re: [Moved]: How to remove noise from an eeg signal contaminated with noise?
    Matlab has a lot of tools for filtering. Try searching "matlab filters".
    Jun 2017
    46
    sir basically i want to use notch filter for removing noise.Can u help me with the syntax or the code itself?
  7. #7
    Points: 31,137, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,182
    31,137
    43
    Quote Originally Posted by Aparna24 View Post
    I think you need to practice your Google-Fu, it's very weak at the moment...
    e.g. first returned link https://www.mathworks.com/help/dsp/ref/iirnotch.html
    third link: https://www.mathworks.com/help/dsp/e....mathworks.com
    Though I have no idea how a notch filter will help you remove noise...unless that noise is at a fixed frequency, but then I wouldn't call that noise.
  8. #8
    Jun 2017
    46
    Thanks for your suggestion and also for your reply..I have recently joined here,and so m not well qualified as you are..Though i'll try to improve n work upon my Google-Fu..
