Results 1 to 6 of 6
    Member level 3
    Points: 873, Level: 6
    Oct 2014
    55
    873
    How to set program counter to illegal address while code is running ?
    I'm trying to create illegal instruction reset.
    I'm programming Infineon TC29x Aurix Tricore Microcontroller based embedded system in 'C' language.
    I need to set program counter to illegal address, i.e. 0x00FF FFFC. Can this be done with assembly language instructions?
    If yes, please instrument assembly language instruction that would set program counter to 0x00FF FFFC while code is running
    Points: 23,780, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,565
    23,780
    37
    Re: How to set program counter to illegal address while code is running ?
    I tried to look at the documentation for the uP, but they won't give it out freely. Not a way to win new customers, in my opinion.
    Regardless, my best solution if there's no way to directly load the PC would be maybe call a subroutine, which puts the program counter on the stack. Then have your subroutine modify that location in the stack so when you return from the subroutine, voila, bad PC!
    Full Member level 4
    Points: 2,317, Level: 11
    May 2012
    222
    2,317
    11
    I think you cannot write into a program counter register. It is read only register. If there is mistake in the code cpu will automatically generates illegal instruction. If you want to write data into a particular address define a pointer to that address and try writing some data into that address and cpu will generate illegal address interrupt.
    Points: 76,224, Level: 67
    Apr 2014
    15,458
    76,224
    67
    Writing into a PC register is the same as performing an unconditional absolute jump.
    But maybe the compiler/assembler detects an error when you jump to an illegal address.
    The modifed_stack_and_return method should work either way.
    Member level 4
    Points: 1,080, Level: 7
    Altaero's Avatar
    Dec 2013
    St-Petersburg, Russia
    78
    1,080
    7
    I didn't try it, but it should work. Try to use pointer to a function like this:
    Code C - [expand]
    int (*func)(void) = 0x00FFFFFC;
        func();
    Points: 9,079, Level: 22
    Easyrider83's Avatar
    Oct 2011
    Tallinn, Estonia
    1,592
    9,079
    22
    Small fix: int (*func)(void) = (void*)0x00FFFFFC;
    Love me or hate me. All infractions will be ignored.
