Results 1 to 5 of 5
    Full Member level 3
    Points: 1,202, Level: 7
    Oct 2015
    163
    1,202
    7
    How to work around with wrong PCB footprint?
    Hi! I have a PCB layout design which happens to have wrong footprints with few IC devices that were ordered. Like for example, TSOP-6 to SC88, SOT23 to SC-70, Can you please help me guys on how to work around on this error?
    •   Alt19th June 2017, 06:20
      advertising
    Full Member level 6
    Points: 2,649, Level: 11
    SLK001's Avatar
    Aug 2015
    Coral Springs, Florida
    372
    2,649
    11
    Re: How to work around with wrong PCB footprint?
    You can make PCB adapters that go from one package to another. A SC-70 might fit on a SOT23 footprint with a little help. Your other options are to order the parts in the correct footprint, or redo the board to reflect the different footprints.
    This is why it is so important to double and triple check your work, taking all these things into account.
    •   Alt19th June 2017, 06:57
      advertising
    Points: 26,878, Level: 39
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,059
    26,878
    39
    Blog Entries
    The PCB adapters are quite usefull for many cases, except if there are ICs dealing with high speed digital signals. or high resolution analog signals. Anyway, if you don't have a reasonable logistic/purchase support, whenever possible it is always a good measure to draw footprints in such a way that accepts more than just 1 package option.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   Alt19th June 2017, 13:17
      advertising
    Newbie level 5
    Points: 261, Level: 3
    Apr 2016
    9
    261
    just check the soldering feasibility with the PCB adapters as sometime they are difficult to solder on PCB with wrong footprint
    Member level 5
    Points: 759, Level: 6
    Sep 2016
    90
    759
    If the PCB is manufactured then the only way is to solve this problem is by soldering and by using adapters if available.
