2 wire LCD interfacing
djc
Advanced Member level 1
India
Hello,
I wrote a code for 2 wire LCD interfacing using PIC16F72 and mikroC. Serial IC is 74HC595 . Both clock pins are shorted. LCD is operated in 4 bit mode. D4,D5,D6, D7 bit of LCD is connected to Q4,Q5,Q6 and Q7 bit of serial IC. Enable pin of LCD is connected to Q2 pin through data pin using resistor and diode combination. RS pin connected to Q3 pin of serial IC. Code is as follows,
#define Data_DS     PORTB.B1
#define Data_Clk    PORTB.B2
char i=0,m=0,j=0;
unsigned char binaryNumber[10],val=0,RS = 0,En = 0,En_On = 0x04, En_Off = 0x00,RS_On =0x08,RS_Off = 0x00;//,En_On[8]={0,0,1,0,0,0,0,0},En_Off={0,0,0,0,0,0,0,0};
unsigned int Temp;
void Data_Out(unsigned int Data)
           i=1;
                     for(m=0;m<8;m++){
                             binaryNumber[i++]= Data % 2;
                             Data = Data / 2;
                             //Data_DS = binaryNumber[i];
                             for(j = i-1;j> 0;j--){
                             Data_DS = binaryNumber[j];
                             Data_Clk = 1;
                             Delay_us(1);
                             Data_Clk = 0;
                             Delay_us(1);
                 Data_Clk = 1;
                 Delay_us(1);
                 Data_Clk = 0;
                 //Delay_ms(1000);
void Port_setting(){
TRISB = 0x00;        //Set port B as output
PORTB = 0;
void ADCnComparator(){
ADON_bit = 0;
void convert_cmd_upper_nibble(unsigned char value){
Temp = 0b00000100;                     //D3=RS,D2=Enable
    if(Value & 0x80) // D7
        Temp = Temp | 0x80;
    if(Value & 0x40) // D6
        Temp = Temp | 0x40;
    if(Value & 0x20) // D5
        Temp = Temp | 0x20;
    if(Value & 0x10) // D4
        Temp = Temp | 0x10;
    Temp = Temp & 0xF4;        //Preserved the data of RS and Enable pin=1
    Data_Out(Temp);
    Temp = Temp & 0xF8;        //Enable pin=0
    Delay_ms(1);
    Data_out(Temp);
void convert_cmd_lower_nibble(unsigned char Value){
    Value = val<<4;
        Temp = Temp | 0x80;
        Temp = Temp | 0x40;
        Temp = Temp | 0x20;
        Temp = Temp | 0x10;
    Data_Out(Temp);
    Delay_ms(1);
    Data_out(Temp);
void convert_data_upper_nibble(unsigned char Value){
Temp = 0b00001100;                     //D3=RS,D2=Enable
        Temp = Temp | 0x80;
        Temp = Temp | 0x40;
        Temp = Temp | 0x20;
        Temp = Temp | 0x10;
    Temp = Temp & 0xFC;                //Preserved the data of RS and Enable pin=1
    Data_Out(Temp);
    Delay_ms(1);
    Data_out(Temp);
void convert_data_lower_nibble(unsigned char Value){
    Value = val<<4;
        Temp = Temp | 0x80;
        Temp = Temp | 0x40;
        Temp = Temp | 0x20;
        Temp = Temp | 0x10;
    Data_Out(Temp);
    Delay_ms(1);
    Data_out(Temp);
void LCD_Cmd(unsigned char lcd_data){
    //RS = 0;                          //For LCD Command
    val = (lcd_data & 0xF0);
    val = val>>4;                    //Extra
    convert_cmd_upper_nibble(val);
    delay_us(10);
    //val = ((data<<4) & 0xF0);
    val = (lcd_data & 0x0F);
    convert_cmd_lower_nibble(val);
    delay_us(10);
void LCD_Dat(char lcd_data_1){
    //RS = 1;                          //For LCD Data
    val = (lcd_data_1 & 0xF0);
    val = val>>4;
    convert_data_upper_nibble(val);
    delay_us(100);
    //val_1 = ((data_1<<4) & 0xF0);
    val = (lcd_data_1 & 0x0F);
    convert_data_lower_nibble(val);
    delay_us(100);
void LCD_Init(){
    LCD_Cmd(0x38);                 //Special Sequence:Write Function Set.
    delay_ms(5);
    LCD_Cmd(0x01);                  //clear the screen
    delay_ms(5);
    LCD_Cmd(0x0A);                  //Display Off cursor On
    delay_ms(5);
    LCD_Cmd(0x28);                  //4bit,2ine,5*7matrix
    delay_ms(5);
    LCD_Cmd(0x02);                  //Return Home
    delay_ms(5);
    LCD_Cmd(0x80);                  //Cursor to top left character position
    delay_ms(5);
    LCD_Cmd(0x06);                  //Increment sursor to right
    delay_ms(5);
void Print_LCD(char *cptr){
    while(*cptr != '\0'){
        LCD_Dat(*cptr);
        delay_us(100);
        cptr++;
void main() {
Port_Setting();
ADCnComparator();
LCD_Init();
          while(1){
          Print_LCD("W");
However there is no O/P on LCD. What is wrong with the code? Plz can any one guide me??
Didn't review the code, but SPI interface requires at lest 3 wires - MSCK, MOSI and /CS. Can give you my library, but it will be complicated for beginers.
I mean to remember a weird HC595 LCD interface circuit driven by two processor pins. The strangeness starts with tying both shift clock and register clock together, a respective circuit hasn't much to do with SPI. A special means to hold E low during the shift process is mandatory.
You should absolutely show the exact circuit, otherwise the post is almost useless.
Here is my new code. I am unable to attach file of circuit. Reply box is giving no option to attach a file or to paste a code.
