Results 1 to 4 of 4
    Points: 228, Level: 2
    Apr 2016
    228
    Generate 40 Hz from 44MHz clock
    I am designing FPGA using VHDL. Please suggest a logic to generate exactly 40 Hz from 44MHz using FPGA alone.
    •   Alt21st April 2017, 05:33
      advertising
    Points: 60,582, Level: 60
    Apr 2014
    12,362
    60,582
    60
    Re: Generate 40 Hz from 44MHz clock
    44MHz ÷ 40Hz = 1 100 000
    --> you need 1 100 000 pulses of 44MHz for one 40Hz pulse
    Each pulse has two edges: thus 550 000 pulses of 44MHz from one 40Hz edge to the next.
    Now use a 20 bit binary counter running from 44MHz.
    Compare it with 549 999 (count from 0 to 549 999)
    On compare match: toggle the 40Hz signal and synchronously reset the 20 bit counter.
    •   Alt21st April 2017, 06:42
      advertising
    Full Member level 4
    Points: 1,828, Level: 9
    May 2014
    221
    1,828
    9
    What he said.
    Just remember things are in multiples of two.
    Therefore in order to make 1100000 you need to know what the x is in 2^x.
    On a side note, since I assume you're new to vhdl
    Code VHDL - [expand]
    8
    9
    -- allows addition
    signal s : unsigned(x-1 downto 0);
    s <= s+1;
    -- does not allow addition
    signal slv : std_logic_vector(x-1 downto 0);
    -- requires type conversion
    slv <= std_logic_vector(unsigned(slv)+ 1);
    -- using variables allows addition to happen instantaneous which will help you around the edges ;)
    [/syntax]
    •   Alt26th April 2017, 12:54
      advertising
    Points: 29,073, Level: 41
    ads-ee's Avatar
    Sep 2013
    USA
    6,687
    29,073
    41
    Quote Originally Posted by wesleytaylor View Post
    A variable will also synthesizes to an adder following a register, so if your clock frequency is high and you use the output of this add operation for say a huge mux, some other large combinational logic, or has a lot of loads, you may not meet timing. The s output, if defined as a variable with the following assignment s := s+1;, will be a combinational output.
    So yeah it might "help you around the edges" but there is a caveat.
