Results 1 to 4 of 4
    Newbie level 1
    Points: 15, Level: 1
    Apr 2017
    15
    About Neon and LED lighting
    This is something related to illuminated channel letter signs. I was searching to know about the illuminations of channel letter signs. I got to know that Neon or LED lightings are used for this purpose. I found some images related to this from the site of a company who provide Channel letter signs in Toronto. From that, I guess Neon lighting is more attractive. What do you think?
    Can somebody tell me what are the main differences between LED and Neon channel letter lighting? I have heard that some Neon signs have the problem of toxic gas leaking. Do you have any idea about this?
    •   Alt18th April 2017, 05:17
      advertising
    Full Member level 1
    Points: 488, Level: 4
    Apr 2017
    98
    488
    Re: About Neon and LED lighting
    Quote Originally Posted by stevenc View Post
    I don't think neon or helium is toxic. They are generally (unless broken) under a vacuum. so any leaks would be sucking in air.
    •   Alt18th April 2017, 06:16
      advertising
    Advanced Member level 1
    Points: 2,589, Level: 11
    Mar 2015
    481
    2,589
    11
    I have gone through a document long back which states "Neon channels eventually lose all of the neon inside the glass tubes. So, that means you have to replace the gas by taking it to professional neon channels manufacturer or need to buy new one. Of course it takes around 10 years to happen but it is sure that it will happen. They are also not easier to clean because there are tubes to clean off as the tubes get hot."
    So Maintenance of LED is very easy as there are no gases, no glass tubes and it won't run out. It is small, very bright. LED signs are also high durable and last up approximately to 100,000 hrs, even if left to work for 24X7.
    --Hobbyckts--
    Nothing you will loose by pressing "Helped Me" button instead conveying thanks.... But press only when the post helped you....
    •   Alt18th April 2017, 07:46
      advertising
    Points: 71,531, Level: 65
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    11,705
    71,531
    65
    Agreed, glass is slightly permeable to Neon gas so there is a gradual contamination/diffusion from the atmosphere outside the tube.
    Glass tubes are easier to shape while keeping uniform light output but could be considerably more expensive than LED 'rope', especialy over prolonged usage but most Neon tube signs are good for 10 years or more. The gas is non-toxic, in fact it is classed as 'inert', meaning it is very difficult for it to chemically react with other substances.
    Also note that Neon tubes work from high voltages, sometimes more than 1KV so there could be an electrical safety issue in some circumstances.
