There is a standard design in Ansoft's OTS website including an HFSS tutorial that explains the model. The model also includes the transition to a microstrip.
I am sure this is not a "real" connector, since these designs are propietary, but that should give you a good start.
If someone does, may I ask a big big favor:
Please ask them how do I start an analysis (analyze) only with unix command-line. Basically, I'd like to telnet to a unix box and write something like this: hfss -batchsolve my_antenna.hfss
(I've tried -batchsolve and -iconic with Unix hfss9.x and it doesn't work).
Also, since I cannot open a DISPLAY if I telnet into a unix-box, how do I forward the DISPLAY to null ? Thank you so much.
