Results 1 to 9 of 9
    Points: 99, Level: 1
    Dec 2016
    7
    99
    [Moved]: to inspect & decap interior surface mounted capacitors
    I'm not an engineer sorry but I wanted to post a question about surface mounted capacitors. Can't figure out which group to put my question.
    Points: 54,851, Level: 57
    Apr 2011
    Minneapolis, Minnesota, USA
    13,361
    54,851
    57
    re: [Moved]: inspecting & recapping interior surface mounted capacitors
    Since you're asking about a physical capacitor package, the present section is suitable (Mechanical Engineering and Design).
    Description on the forum home page:
    "Mechanical engineering issues and different mechanical design techiques for your specific project ex. construction, metal works, cabinets, racks, crates, enclosures, front panels"
    Dec 2016
    7
    99
    Quote Originally Posted by BradtheRad View Post
    Thank you. My question is can the capacitors as seen in the following picture be decaped ? Why to inspect the interior or inside.
    Full Member level 6
    Points: 2,777, Level: 12
    SLK001's Avatar
    Aug 2015
    Coral Springs, Florida
    384
    2,777
    12
    No, they cannot be decapped. They are MLCC and their dielectric is ceramic.
    Why do you need to inspect the interior?
    Dec 2016
    7
    99
    Quote Originally Posted by SLK001 View Post
    Then how can the interior be inspected for anomalies ? Something that should not be there such as a transceiver, antenna and front end that sort of thing.
    SLK001 so they cannot be decapped can they be broken open with a sharp cutting tool like a utility knife ?
    Full Member level 6
    SLK001's Avatar
    Aug 2015
    384
    2,777
    12
    Re: [Moved]: inspecting & recapping interior surface mounted capacitors
    Quote Originally Posted by victor6799 View Post
    You can pot them in epoxy and then slowly grind them down to nothing (stopping every 5-10 thousandths of an inch to photograph). Your better approach would be to replace them one-by-one, then test for the anomalies.
    Are you saying that you suspect a miniature transceiver is being placed inside one of your capacitors?
  7. #7
    Dec 2016
    7
    99
    Not in just mine but at the factory.
  8. #8
    Full Member level 6
    SLK001's Avatar
    Aug 2015
    384
    2,777
    12
    That would take miniaturization to a new level. The largest of these caps is only 0.060" by 0.120".
  9. #9
    Points: 12,785, Level: 27
    Feb 2010
    UNITED KINGDOM
    1,996
    12,785
    27
    Re: [Moved]: to inspect & decap interior surface mounted capacitors
    Strange thread, are we talking paranoia here?
