Adwaittronics
Junior Member level 3
Hi
I want to design a capacitive power supply , with i/p voltage as 90V to 270V and o/p voltage as 24V , how can I calculate maximum current of the circuit?
I calculated the capacitance of the X-rated capacitor by the formula X = 1/(2* pi*f*C) where f=50-60Hz.
Then calculated the current by the formula I = V/X , where V is the input voltage.
Is this the correct way to calculate maximum current of the circuit ?
In all the above calculation output voltage is not in picture , so am I right or wrong kindly explain.
NOTE : for all the i/p voltages from 90V to 270V ,I want the o/p voltage to be 24V.
