Emmanuel1992
Junior Member level 2
ADC and Comparators are not disabled.
Hi, how to do that sir?
hi
it is using your code only you just need to check carefully follow these steps
1) in void check_port_status() function mentioned all your port checking activities i.e. PORTB.F7 ==0 , PORTB.F7 == 1 etc. set different status 0,1 ,2 .. for them.
2) in while loop put relavent action codes which you have already written in if.. condition
3) set- reset the flags
structure is already ready.
hi
same you can impleament with all your conditions including (&&) conditions...
hi
pls refer this hope it will help
#define Light_Turn_on 1
#define Light_Turn_off 2
#define Light_fault_detected 3
//.... other status comes here
// take some flags keep initial values 0
char status_updated_for_status_1 = 0;
char status_updated_for_status_2 = 0;
char status_updated_for_status_3 = 0;
//.... other flags comes here (use bitfields for memory saving ... )
// make one function that checkes only stauts of ports
if(PORTB.F7==0)
if(status_updated_for_status_1 == 0)
Status = Light_Turn_on ;
if(PORTB.F7==1)
if(status_updated_for_status_2 == 0)
Status = Light_Turn_off;
if((PORTB.F0==1)&&(PORTD.F0=1))
if(status_updated_for_status_3 == 0)
Status =Light_fault_detected;
// .... other ports comes here
//in your while loop
while(1)
switch(status)
case Light_Turn_on :
status_updated_for_status_1 = 1;
// put your LCD code & uart code here. i.e. action to be taken
// this part taken from your code please modify this .... too bulky .. for time being taken from your code
PORTD=0b00111111;
Delay_ms(500);
Lcd_Cmd(_LCD_CLEAR);
Lcd_Out(1,1,"LIGHTS TURNED");
Lcd_Out(2,1,"ON SUCCESSFULLY");
Lcd_Out(4,-3,"SENDIND SMS.....");
Delay_ms(1500);
Lcd_Out(1,1,"AUTOMATIC STREET");
Lcd_Out(2,1,"LIGHTS AND FAULT");
Lcd_Out(3,-3,"DETECTION SYSTEM");
UART1_Write_Text("AT+CMGS=");
UART1_Write(0x22);
UART1_Write_Text("+255717677776");
UART1_Write(0x22);
UART1_Write(0x0d);
Delay_ms(200);
UART1_Write_Text("LIGHTS TURNDED ON SUCCESSFULLY");
UART1_Write(26);
Delay_ms(100);
Status = 0;
break ;
case Light_Turn_off :
status_updated_for_status_2 = 1;
Status = 0;
break ;
//.... other cases
Hi again, Thank you for your reply, let me check it then i will give you the feedback, GOD BLESS YOU..
