Results 1 to 3 of 3
    Member level 3
    Points: 449, Level: 4
    Mar 2016
    54
    449
    how to switch from one shell to another
    hello,
    I am in a problem of dealing with two shells, I have a some 10 lines of commands in a single file where the first 5 lines are only understood by tclsh and the next five lines are understood only by either my default bash or csh. if i source the file (containig tthese 10 commands), i want my job to be done in a single press of my enter key.
    the problem is , if i write "csh " command at the middle of the file (i.e at 6th line), it says invalid command. but if i enter myself csh in terminal then it will take and accept.
    Regards,
    Anil
    Points: 12,739, Level: 27
    Apr 2010
    1,935
    12,739
    27
    Re: how to switch from one shell to another
    post your script or example script which is trying to switch shells.
    Points: 8,605, Level: 22
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,284
    8,605
    22
    Blog Entries
    Can you not call the bash cmds from tclsh?
    http://stackoverflow.com/questions/4...rom-tcl-script
    FPGA enthusiast!
