francis29
Member level 5
I created PWM signal in dsPIC30F3011 and i am getting these waveforms . There are spikes during off period of value around 1 volt. So is that a problem??
Because i am going to connect this to a buck converter. So if both high side and low side PWM turned on at the same time it will blow the devices. So i just want to confirm this spikes won't create a problem.
This is the DSO waveform
