Results 1 to 5 of 5
    Member level 3
    Points: 949, Level: 6
    abhishek.2138's Avatar
    Dec 2013
    55
    949
    Snubber / clamp capacitor
    which type of capacitor used for snubber in flyback smps of around 20watts ?
    •   Alt27th February 2017, 10:38
      advertising
    Points: 59,045, Level: 59
    Apr 2014
    12,038
    59,045
    59
    Re: Snubber / clamp capacitor
    no voltage, no current?
    No circuit?
    •   Alt27th February 2017, 19:45
      advertising
    Member level 3
    Dec 2013
    55
    949
    Input - 230Vac (15% tolerance), 50 Hz
    Output- 24V, 0.5A
    Device used- NCP1014AP06 (in built MOSFET of 700V & controller 65 KHz freq.)
    want to know ceramic or film capacitor to be used for clamp & for snubber.
    Here I am concerned with clamp now (for NCP1014AP06) but also want to know capacitor type for snubber.
    Flyback topology used with no auxilary winding...( No aux winding needed for NCP1014 upto 14W)
    Datasheet---
    NCP1010-D.PDF
    •   Alt28th February 2017, 02:56
      advertising
    Junior Member level 3
    Points: 473, Level: 4
    Aug 2016
    India
    30
    473
    You can use a ceramic capacitor which can tolerate upto few 100s of volts.
    Points: 28,763, Level: 41
    Sep 2008
    cambridge
    6,025
    28,763
    41
    ceramic yes, as in smd is less inductive than most film types.....and smaller......if you shovel your spec into power.com's free PI Expert software it will calculate the entire circuit and bom for you...and tell you the snubber cap part number etc
