importing folders & files to icfb
Alipoursaadaty
Member level 3
Hi guys
I did my project in my university's lab. After that I copied my folders & Files & my maked libraries from lab's PCs. In other words, I exported them. Now I wanna import these files to my laptop. But I don't know what I do. Who does know about importing & adding files to icfb (Cadence virtuoso)
Please help me
:thumbsdown: :oops: :-?
My cadence virtuoso software is on the linux OS & I perform it on the vmware.
How do I add .tar.gz files to linux from windows by vmware???
Launch linux on vmware.
Connect to machine where you create "*.tar.gz" by ftp.
Then transfer "*.tar.gz" to linux on vmware.
Are you kidding ?
ftp mean "File Transfer Protocol".
https://en.wikipedia.org/wiki/File_Transfer_Protocol
Ok. Now I transfer the .tar.gz archive file. But when I open the cadence virtuoso & perform in the linux, I can't find my built library. I think this is happening because of tech file destination.
Do I change tech file direction in my linux or change the tech file direction address in my cds.lib file?
You have technology library as local.
Copy it also from Lab.
I have technology library and I added it to my linux OS & cadence virtuoso. But In my linux, The technology library has different direction than lab's technology library. Also when I change the technology library folder to same direction as lab technology library, it doesn't work.:-:)-(
Edit cds.lib
Than you so much. It works properly
But the simulation states does not work. I can't load my saved state, but I have simulation folder and state folders in the simulation folder.
How do I load states?
Describe correctly.
State folder don't exist in the simulation folder.
Simulation states exist in test bench cell view or state directory.
Which one do you use ?
What value do you set for followings ?
"asimenv" "saveDir"
"asimenv.startup" "projectDir"
"asimenv" "saveAsCellview"
Show me ".cdsinit" and ".cdsenv" which you use at Univeristy Lab.
Show me ".cdsinit" and ".cdsenv" which you use at PC.
These files are located in both home_directory and work_directrory where you launch Cadence Virtuoso.
Re: importing folders & files to icfb
Describe correctly.
"asimenv" "saveDir"
I just find .cdsinit & .cdsenv files.
.cdsinit file for my work directory is:
filepath: <cds_install_dir>/samples/local/cdsinit
dfII version: 4.4
This file should be copied as <cds_install_dir>/local/.cdsinit
and customized as a site startup file. The site startup file is
read and executed when the Design Framework II software starts.
This file can load all the application configuration files and
application bind key files.
It also sets the library search path ( which may be overriden by the
user customization file.
Finally this file transfers control to the user by executing the
The user customization file may be
./.cdsinit - .cdsinit in the working directory
~/.cdsinit - .cdsinit in the user's home directory
This site file checks if a .cdsinit exists in the working directory
and executes it. If .cdsinit does not exist in the user's working
directory then ~/.cdsinit is executed if it exists.
Please read the entire file and the comments before you start
customizing the file. See the section below on File Installation
for a list of sample files supplied.
There are bind key definition files supplied for different
applications. The relevant bind key definitions files must
be loaded if you want bind keys defined for that application.
See section LOAD APPLICATION BIND KEY DEFINITIONS.
In order for any window placements to work correctly the following
X resource must be set in the .Xdefaults or .xresources file
pertaining to your hardware platform.
Mwm*clientAutoPlace: False
After setting the resource read in the resource file with the command
xrdb <resource_filename>
and restart the Motif window manager.
The function
prependInstallPath("string")
adds the installation path to the string argument
For this reason there should NOT be a space at the beginning of the
string.
There SHOULD be a space at the end of the string if more paths are to
follow.
This function is used to make path specification in this file
independant of the exact installation path.
The function let() creates local variables ( example: libPath ).
This makes sure that any global variables are not accidentally modified.
; File Installation
; CONFIGURATION FILES
; The following configuration files are delivered in the 4.4 release:
; <cds_install_dir>/samples/local
; aaConfig.il - analog
; dciConfig.il - Cadence to Synopsys Interface
; metConfig.il - Designing with Composer
; using metric measurements
; sysConfig.il - systems
; uiConfig.il - user interface
; The configuration files are used to initialize parameters and
; forms.
; ENVIRONMENT VARIABLES
; Schematic, Layout and Graphic environment variable defaults are now found in
; <cds_install_dir>/etc/tools/
; layout/.cdsenv
; schematic/.cdsenv
; graphic/.cdsenv
; These can be customized in the user's ./cdsenv and ~/.cdsenv files.
; A .cdsenv file can be created by using CIW->options->save defaults.
; BIND KEY DEFINITION FILES
; The following bind key definition files are delivered in the
; 4.3 release:
; leBindKeys.il - layout editor
; schBindKeys.il - schematic editor
; CUSTOMIZATION FILES
; The following customization files are delivered in the
; 4.3 release:
; <cds_install_dir>/samples/local/cdsinit - site customization
; <cds_install_dir>/cdsuser/.cdsinit - user customization
; ADMINISTRATION
; The site administrator should install the "site" files as follows: ;
; 1. Copy <cds_install_dir>/samples/local/cdsinit
; to <cds_install_dir>/local/.cdsinit
; and modify the file
; (If <cds_install_dir>/local does not exist create it)
; <cds_install_dir>/local is the site customization directory.
; This directory is not sent as part of the software. The site
; administrator must create this directory. Whenever software is
; upgraded the Cadence installation process retains the site
; administration directory if it exists.
; 2. If default configuration needs to be changed copy the
; relevant configuration file
; from: 4.3/samples/local
; to: 4.3/local
; and modify the file(s)
; 3. If default bind key definitions need to be changed copy the
; relevant bind key definition file
; to: 4.3/local
; 4. Copy 4.3/cdsuser/.cdsinit to the user's home or working
; directory - Do this step only if the user does not already
; have a .cdsinit file.
; If after site customization each user wants to customize
; portions of the configuration or bind keys definitions
; they should copy the relevant sections from the files in
; 4.3/samples/local
; into
; the user's customization file
; ./.cdsinit or ~/.cdsinit
; FILE LOADING ORDER
; 1. The configuration files are not automatically loaded.
; Remove the comment on the filename line to load the file.
; The search order for the configuration files is:
; 4.3/local
; 2. The bind key definition files are not automatically loaded.
; The search order for the bind key definition files is:
; 4.3/local
; 4.3/samples/local
; 3. Load user customization file
; ./.cdsinit - load .cdsinit in the working directory if it exists
; else
; ~/.cdsinit - load .cdsinit in the user's home directory
; This file does NOT load both user customization files even if both exist.
;# LOAD APPLICATION CONFIGURATION FILES
;Remove the comment ; if you want to load the specific configuration file
;If you do not load the configuration files the applications will use the
;default configurations.
let( (configFileList file path saveSkillPath)
configFileList = '(
; "aaConfig.il"
; "dciConfig.il"
; "leConfig.il"
; "metConfig.il"
; "schConfig.il"
; "sysConfig.il"
; "uiConfig.il"
; This is the path that is searched for the files
path = strcat(
; If you want to add another path add it here as a string
prependInstallPath("local ")
saveSkillPath=getSkillPath()
setSkillPath(path)
foreach(file configFileList
if(isFile(file) then
loadi(file)
setSkillPath(saveSkillPath)
hiiSetFont("text" "-adobe-courier-bold-r-*-*-12-*")
;# LOAD APPLICATION BIND KEY DEFINITIONS
;Add the comment ; if you do not want to load the specific
;bind key definition file.
;If you do not load the bind key definitions the applications will not
;have any bind keys defined.
;If you load the bind key definition file but the application is not
;registered ( product not licensed or checked out ) then you might get
;a warning that looks like
; *WARNING* "Schematics is not registered yet"
;This warning can be ignored if you know that the product is not
;licensed or checked out.
let( (bindKeyFileList file path saveSkillPath)
bindKeyFileList = '(
"leBindKeys.il"
"schBindKeys.il"
path = strcat(
prependInstallPath("samples/local")
setSkillPath(path)
foreach(file bindKeyFileList
if(isFile(file ) then
loadi(file)
; An individual user may wish to add some bindkeys of his/her own or
; over ride some default loaded bindkeys. For more information about
; bindkeys see the manual "SKILL Reference Manual, Language Fundamentals",
; Chapter 4.
; Here is an example of setting one bindkey on "F2" than prints
; "Hello world" to the CIW when pressed in the CIW.
;hiSetBindKey("Command Interpreter" "<Key>F2" "printf("Hello World")")
; Here is an example of setting keys for more than one application
;let( (app appList)
; appList = '(
; "Command Interpreter"
; "Schematics"
; "Symbol"
; Add other applications here
; foreach(app appList
; hiSetBindKey(app "<Key>F4" "printf("Hello ")")
; hiSetBindKey(app "<Key>F5" "printf("World")")
;# SETTINGS FOR SKILL PATH and SKILL PROGRAMMING
; The function sstatus() sets the status of variables
; The variable writeProtect controls if a SKILL function can be
; redefined or not;
; Any functions defined after writeProtect = t CANNOT be redefined
; Any functions defined after writeProtect = nil CAN be redefined
; If you are going to create SKILL programs and define functions set the
; status of writeProtect to nil at the beginning of your session.
; Set skill search path. The SKILL search path contains directories
; to be searched to locate SKILL programs when program names are
; specified without full path names.
; The operation could be reading, writing or loading a SKILL program.
; Source technology files are considered SKILL files and when loading
; or dumping the technology file SKILL search path will be used.
sstatus(writeProtect nil)
let((skillPath)
skillPath= strcat(
". ~ " ; Current & home directory
prependInstallPath("samples/techfile ") ; sample source technology files
setSkillPath(skillPath)
; VERIFICATION - DIVA/INQUERY/DRACULA ENCAPS #
; There are no configuration variables for these
; applications to be set in the .cdsinit. You may
; need to create a .simrc file, using the example
; in <cds_install_dir>/cdsuser/.simrc
;# PLACE AND ROUTE - CELL3, CE, BE, PREVIEW,GE #
; The geSetProbeNetStopLevel default is zero.
; To probe routing in channels, it must be >= 2.
; geSetProbeNetStopLevel(0) ; 20 is a good number.
;# LAS and COMPACTOR #
; applications to be set in the .cdsinit. You need
; to add information to your technology file. See
; the LAS and COMPACTOR reference manuals for
; details about technology file additions.
;# Customizing the 4.x environment with: #
;# SETTING AmPLD DEFAULTS (Data I/O Abel 4.x) #
; No Setup is required if using the default system shipped from Cadence.
; If you are using your own Abel or need to customize the system Please
; See Appendix A of the Programmable Logic Design System Users Guide.
;# DESIGN FLOWS #
; The design flows can be used with no customization, but customizing
; them for your personal preference can greatly enhance your
; productivity. Please See the Design Flow users guide for details.
; Bring up top flow ...
;amdfTopFlow()
;# MISCELLANEOUS
; Set your own prompt in the CIW. The first argument is the prompt.
; The second argument is not used yet.
; The variable editor defines the text editor to be used when any of
; the applications invoke an editor. For example technology dump and
; edit operation opens an editor window.
; The editor may also be set by
; unix environment variable EDITOR
; setenv EDITOR 'xedit'
; When Design Framework is invoked the SKILL variable editor is set
; to the value of the unix variable EDITOR.
; If EDITOR is not defined the SKILL variable
; editor is set to "vi"
; You may also set the variable to execute a UNIX command
; that invokes an xterm window of given size and location
; and starts an editor program.
; Example:
; editor = "xterm -geometry 80x40 -e emacs"
; Size of xterm in the above example is 80 characters by 40 lines.
; With some editors on certain platforms the variable editor must
; be defined as shown above.
; Some application which require a text editor may be using the UNIX
; variable EDITOR instead of the SKILL variable editor. It is a good
; idea to set the UNIX variable EDITOR to the text editor of your
; choice which will automatically set the SKILL variable editor.
;setPrompts("Ready >" "")
;editor = "xterm -geometry 85x50 -e vi";
printf("END OF SITE CUSTOMIZATION\n")
;# LOAD USER CUSTOMIZATION FILE
;The site customization file is going to load the user
;customization file. In case you have copied this site
;customization file as your user customization file
;comment out or remove the next section to prevent
;recursive loading of ./.cdsinit
load(strcat(getShellEnvVar("SNPS_SIMIF") "/interfaces/simif/virtuoso/discoveryAMS.al"))
load(strcat(getShellEnvVar("MGC_HOME")
"/shared/pkgs/icv.ixl/tools/queryskl/calibre.skl"))
load("./leBindKeys.il")
;//# SONNET CADENCE VIRTUOSO INTERFACE SETUP
;END OF THE SITE CUSTOMIZATION FILE
Also .cdsenv file for my work directory is:
";This is a sample environment variable file containing the default
;values for environment variables in Design Framework II products.
;See the appropriate tool documentation regarding the use and
;choices for each variable.
;To customize your defaults, use this file as a template and place
;a modified version of this file in ../local/.cdsenv. This
;local version should typically reflect the values of your system
;defaults as set by your site coordinator. To specify more personal
;defaults, place a modified version of either this or the
;../local/.cdsenv file into your home directory as .cdsenv.
;Your ../local/.cdsenv file will be loaded first, followed
;by the .cdsenv in your home directory, so any values in ~/.cdsenv
;will override those previously loaded.
;UltraSim environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;UltraSim opts partition variables
UltraSim.opts UsimRAAgeDomain string "loglog"
UltraSim.opts rshort string "1e-6"
UltraSim.opts simSave boolean nil
UltraSim.opts abstoli string "1.00e-12"
UltraSim.opts UsimTAMaxPerTime string ""
UltraSim.opts UsimPAEnabled boolean nil
UltraSim.opts UsimNAOutputSort string "name"
UltraSim.opts simSaveFile string ""
UltraSim.opts UsimTASigNames string ""
UltraSim.opts dc string "Complete DC (1)"
UltraSim.opts TNOMDC string "27"
UltraSim.opts other string ""
UltraSim.opts UsimPADepth string "1"
UltraSim.opts simRestart boolean nil
UltraSim.opts otherSpice string ""
UltraSim.opts wf_tres string "1e-12"
UltraSim.opts UsimPATimeIntervals string ""
UltraSim.opts UsimRAMode string "HCI only"
UltraSim.opts rcr_fmax string "1e9"
UltraSim.opts simTimePoints string ""
UltraSim.opts UsimTASigEdgeType string "rise"
UltraSim.opts UsimRADeltaDToggle boolean t
UltraSim.opts tol string "0.01"
UltraSim.opts wf_reltol string ""
UltraSim.opts wf_abstoli string "1e-12"
UltraSim.opts UsimTARefSigEdgeType string "rise"
UltraSim.opts wf_format string "PSF"
UltraSim.opts UsimRAAgeMethod string "interp"
UltraSim.opts UsimTASigLowThreshold string ""
UltraSim.opts UsimTAEnabled boolean nil
UltraSim.opts UsimTAMinLowTime string ""
UltraSim.opts UsimNA toggle (nil)
UltraSim.opts postl string "No RCR (0)"
UltraSim.opts abstolv string "1.00e-06"
UltraSim.opts diode_method string "Analog Table (A)"
UltraSim.opts UsimRAAgeproc string ""
UltraSim.opts ParasiticRCFile string ""
UltraSim.opts UsimTAMinHighTime string ""
UltraSim.opts UsimOptMethod boolean nil
UltraSim.opts UsimPA toggle (nil)
UltraSim.opts UsimRAMinAge float 0.0
UltraSim.opts UsimTA toggle (nil)
UltraSim.opts UsimTAMaxHighTime string ""
UltraSim.opts wf_abstolv string "1e-6"
UltraSim.opts UsimRADeltaD float 0.1
UltraSim.opts simLoadFile string ""
UltraSim.opts UsimPALimit string ""
UltraSim.opts TEMPDC string "27"
UltraSim.opts UsimTARefSig string ""
UltraSim.opts mos_method string "Analog/MS Table (A)"
UltraSim.opts UsimRANBTIAgeproc string ""
UltraSim.opts wf_filter boolean t
UltraSim.opts UsimTARefSigHighThreshold string ""
UltraSim.opts UsimTANegWindow string ""
UltraSim.opts UsimTASigHighThreshold string ""
UltraSim.opts UsimTAMinPerTime string ""
UltraSim.opts UsimTAReportTitle string ""
UltraSim.opts dump_step string ""
UltraSim.opts speed string "Default (5)"
UltraSim.opts dcut boolean nil
UltraSim.opts UsimPAPort string ""
UltraSim.opts UsimTASubcktName string ""
UltraSim.opts UsimNALimit string ""
UltraSim.opts UsimRAAgingTime string "10y"
UltraSim.opts scale string "1.0"
UltraSim.opts rvshort string "1e-6"
UltraSim.opts UsimPAName string ""
UltraSim.opts analog string "Default (1)"
UltraSim.opts UsimTAMaxLowTime string ""
UltraSim.opts UsimPAOutputSort string "avg"
UltraSim.opts UsimPAPower boolean nil
UltraSim.opts UsimTASetupTime string ""
UltraSim.opts lshort string "0"
UltraSim.opts dcut_field string ""
UltraSim.opts UsimTATrigger string "both"
UltraSim.opts UsimOptMethodHier boolean nil
UltraSim.opts simRepeat string ""
UltraSim.opts sim_mode string "Mixed Signal (MS)"
UltraSim.opts cgndr string "0"
UltraSim.opts UsimTADisplaySetting string ""
UltraSim.opts cgnd string "1e-20"
UltraSim.opts UsimRA toggle (nil)
UltraSim.opts UsimTARefSigLowThreshold string ""
UltraSim.opts UsimTACheckType string "setup"
UltraSim.opts UsimNASortIs string "inc"
UltraSim.opts scalem string "1.0"
UltraSim.opts UsimTADepth string ""
UltraSim.opts UsimPADisplaySetting string ""
UltraSim.opts lvshort string "0"
;UltraSim outputs partition variables
UltraSim.outputs UsimOptionLogicSubckt3 string ""
UltraSim.outputs UsimOptionLogicDepth3 string "1"
UltraSim.outputs UsimOptionProbeAnalog boolean t
UltraSim.outputs UsimOptionAllLogicNV5 boolean nil
UltraSim.outputs UsimOptionLogicLowThreshold string ""
UltraSim.outputs UsimOptionLogicSubckt2 string ""
UltraSim.outputs UsimOptionLogicHighThreshold string ""
UltraSim.outputs UsimOptionLogicIncludeRC boolean nil
UltraSim.outputs UsimOptionLogicSubckt string ""
UltraSim.outputs UsimOptionLogicSubckt5 string ""
UltraSim.outputs UsimOptionLogicDepth4 string "1"
UltraSim.outputs UsimOptionAllAnalogTC boolean nil
UltraSim.outputs UsimOptionAllLogicNV boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC4 boolean nil
UltraSim.outputs UsimOptionLogicDepth string "1"
UltraSim.outputs UsimOptionLogicLowThreshold2 string ""
UltraSim.outputs UsimOptionAllLogicNV2 boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC2 boolean nil
UltraSim.outputs UsimOptionNumberVolThreshold string "1"
UltraSim.outputs UsimOptionLogicSubckt4 string ""
UltraSim.outputs UsimOptionLogicHighThreshold4 string ""
UltraSim.outputs UsimOptionAllAnalogNV boolean nil
UltraSim.outputs UsimOptionLogicLowThreshold5 string ""
UltraSim.outputs UsimOptionIncludeRC boolean nil
UltraSim.outputs UsimOptionDepth string "1"
UltraSim.outputs UsimOptionLogicHighThreshold2 string ""
UltraSim.outputs UsimOptionLogicIncludeRC5 boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC3 boolean nil
UltraSim.outputs UsimOptionLogicHighThreshold3 string ""
UltraSim.outputs UsimOptionLogicDepth5 string "1"
UltraSim.outputs UsimOptionLogicLowThreshold3 string ""
UltraSim.outputs UsimOptionLogicLowThreshold4 string ""
UltraSim.outputs UsimOptionProbeLogic boolean nil
UltraSim.outputs UsimOptionAllLogicNV3 boolean nil
UltraSim.outputs UsimOptionAllLogicNV4 boolean nil
UltraSim.outputs UsimOptionLogicHighThreshold5 string ""
UltraSim.outputs UsimOptionLogicDepth2 string "1"
;UltraSim envOpts partition variables
UltraSim.envOpts stopViewList string "spectre"
UltraSim.envOpts switchViewList string "spectre cmos_sch cmos.sch schematic veriloga"
UltraSim.envOpts netlistFormat string "spectre"
UltraSim.envOpts autoDisplay boolean t
UltraSim.envOpts printComments boolean nil
UltraSim.envOpts UltraSimVectorFile string ""
UltraSim.envOpts UltraSimVcdFile string ""
UltraSim.envOpts userCmdLineOption string ""
UltraSim.envOpts UltraSimVcdInfo string ""
;UltraSim init partition variables
UltraSim.init processPriority int 0
;UltraSim tran partition variables
UltraSim.tran enable toggle (nil)
UltraSim.tran stop string ""
;UltraSim tranOpts partition variables
UltraSim.tranOpts start string ""
UltraSim.tranOpts outputstart string ""
UltraSim.tranOpts step string "1e-9"
UltraSim.tranOpts readic string ""
UltraSim.tranOpts write string "UltraSim.ic"
UltraSim.tranOpts writefinal string "UltraSim.fc"
UltraSim.tranOpts method_new string ""
UltraSim.tranOpts infotimes string ""
UltraSim.tranOpts maxstep string ""
UltraSim.tranOpts max_start string ""
UltraSim.tranOpts max_stop string ""
UltraSim.tranOpts max_subckt string ""
;UltraSimVerilog environment variables
;UltraSimVerilog opts partition variables
UltraSimVerilog.opts rshort string "1e-6"
UltraSimVerilog.opts UsimRAAgeDomain string "loglog"
UltraSimVerilog.opts simSave boolean nil
UltraSimVerilog.opts UsimTAMaxPerTime string ""
UltraSimVerilog.opts abstoli string "1.00e-12"
UltraSimVerilog.opts UsimPAEnabled boolean nil
UltraSimVerilog.opts UsimNAOutputSort string "name"
UltraSimVerilog.opts simSaveFile string ""
UltraSimVerilog.opts UsimTASigNames string ""
UltraSimVerilog.opts TNOMDC string "27"
UltraSimVerilog.opts dc string "Complete DC (1)"
UltraSimVerilog.opts other string ""
UltraSimVerilog.opts otherSpice string ""
UltraSimVerilog.opts simRestart boolean nil
UltraSimVerilog.opts UsimPADepth string "1"
UltraSimVerilog.opts wf_tres string "1e-12"
UltraSimVerilog.opts UsimPATimeIntervals string ""
UltraSimVerilog.opts UsimRAMode string "HCI only"
UltraSimVerilog.opts rcr_fmax string "1e9"
UltraSimVerilog.opts simTimePoints string ""
UltraSimVerilog.opts UsimTASigEdgeType string "rise"
UltraSimVerilog.opts UsimRADeltaDToggle boolean t
UltraSimVerilog.opts tol string "0.01"
UltraSimVerilog.opts wf_reltol string ""
UltraSimVerilog.opts wf_abstoli string "1e-12"
UltraSimVerilog.opts UsimTARefSigEdgeType string "rise"
UltraSimVerilog.opts UsimRAAgeMethod string "interp"
UltraSimVerilog.opts UsimTASigLowThreshold string ""
UltraSimVerilog.opts UsimTAEnabled boolean nil
UltraSimVerilog.opts UsimTAMinLowTime string ""
UltraSimVerilog.opts UsimNA toggle (nil)
UltraSimVerilog.opts postl string "No RCR (0)"
UltraSimVerilog.opts abstolv string "1.00e-06"
UltraSimVerilog.opts diode_method string "Analog Table (A)"
UltraSimVerilog.opts UsimRAAgeproc string ""
UltraSimVerilog.opts ParasiticRCFile string ""
UltraSimVerilog.opts UsimTAMinHighTime string ""
UltraSimVerilog.opts UsimOptMethod boolean nil
UltraSimVerilog.opts UsimPA toggle (nil)
UltraSimVerilog.opts UsimRAMinAge float 0.0
UltraSimVerilog.opts UsimTA toggle (nil)
UltraSimVerilog.opts UsimTAMaxHighTime string ""
UltraSimVerilog.opts wf_abstolv string "1e-6"
UltraSimVerilog.opts UsimRADeltaD float 0.1
UltraSimVerilog.opts simLoadFile string ""
UltraSimVerilog.opts UsimPALimit string ""
UltraSimVerilog.opts TEMPDC string "27"
UltraSimVerilog.opts UsimTARefSig string ""
UltraSimVerilog.opts mos_method string "Analog/MS Table (A)"
UltraSimVerilog.opts UsimRANBTIAgeproc string ""
UltraSimVerilog.opts wf_filter boolean t
UltraSimVerilog.opts UsimTARefSigHighThreshold string ""
UltraSimVerilog.opts UsimTANegWindow string ""
UltraSimVerilog.opts UsimTASigHighThreshold string ""
UltraSimVerilog.opts UsimTAMinPerTime string ""
UltraSimVerilog.opts UsimTAReportTitle string ""
UltraSimVerilog.opts dump_step string ""
UltraSimVerilog.opts speed string "Default (5)"
UltraSimVerilog.opts dcut boolean nil
UltraSimVerilog.opts UsimPAPort string ""
UltraSimVerilog.opts UsimTASubcktName string ""
UltraSimVerilog.opts UsimNALimit string ""
UltraSimVerilog.opts UsimRAAgingTime string "10y"
UltraSimVerilog.opts scale string "1.0"
UltraSimVerilog.opts rvshort string "1e-6"
UltraSimVerilog.opts UsimPAName string ""
UltraSimVerilog.opts analog string "Default (1)"
UltraSimVerilog.opts UsimTAMaxLowTime string ""
UltraSimVerilog.opts UsimPAOutputSort string "avg"
UltraSimVerilog.opts UsimPAPower boolean nil
UltraSimVerilog.opts UsimTASetupTime string ""
UltraSimVerilog.opts lshort string "0"
UltraSimVerilog.opts dcut_field string ""
UltraSimVerilog.opts UsimTATrigger string "both"
UltraSimVerilog.opts UsimOptMethodHier boolean nil
UltraSimVerilog.opts simRepeat string ""
UltraSimVerilog.opts UsimTADisplaySetting string ""
UltraSimVerilog.opts cgndr string "0"
UltraSimVerilog.opts sim_mode string "Mixed Signal (MS)"
UltraSimVerilog.opts cgnd string "1e-20"
UltraSimVerilog.opts UsimRA toggle (nil)
UltraSimVerilog.opts UsimTARefSigLowThreshold string ""
UltraSimVerilog.opts UsimTACheckType string "setup"
UltraSimVerilog.opts UsimNASortIs string "inc"
UltraSimVerilog.opts scalem string "1.0"
UltraSimVerilog.opts UsimPADisplaySetting string ""
UltraSimVerilog.opts UsimTADepth string ""
UltraSimVerilog.opts lvshort string "0"
;UltraSimVerilog outputs partition variables
UltraSimVerilog.outputs UsimOptionLogicSubckt3 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth3 string "1"
UltraSimVerilog.outputs UsimOptionProbeAnalog boolean t
UltraSimVerilog.outputs UsimOptionAllLogicNV5 boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt2 string ""
UltraSimVerilog.outputs UsimOptionLogicHighThreshold string ""
UltraSimVerilog.outputs UsimOptionLogicIncludeRC boolean nil
UltraSimVerilog.outputs UsimOptionLogicSubckt string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt5 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth4 string "1"
UltraSimVerilog.outputs UsimOptionAllAnalogTC boolean nil
UltraSimVerilog.outputs UsimOptionAllLogicNV boolean nil
UltraSimVerilog.outputs UsimOptionLogicIncludeRC4 boolean nil
UltraSimVerilog.outputs UsimOptionLogicDepth string "1"
UltraSimVerilog.outputs UsimOptionLogicLowThreshold2 string ""
UltraSimVerilog.outputs UsimOptionAllLogicNV2 boolean nil
UltraSimVerilog.outputs UsimOptionNumberVolThreshold string "1"
UltraSimVerilog.outputs UsimOptionLogicIncludeRC2 boolean nil
UltraSimVerilog.outputs UsimOptionAllAnalogNV boolean nil
UltraSimVerilog.outputs UsimOptionLogicHighThreshold4 string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt4 string ""
UltraSimVerilog.outputs UsimOptionDepth string "1"
UltraSimVerilog.outputs UsimOptionIncludeRC boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold5 string ""
UltraSimVerilog.outputs allDigitalNV boolean t
UltraSimVerilog.outputs UsimOptionLogicHighThreshold2 string ""
UltraSimVerilog.outputs UsimOptionLogicHighThreshold3 string ""
UltraSimVerilog.outputs UsimOptionLogicIncludeRC3 boolean nil
UltraSimVerilog.outputs UsimOptionLogicIncludeRC5 boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold3 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth5 string "1"
UltraSimVerilog.outputs UsimOptionProbeLogic boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold4 string ""
UltraSimVerilog.outputs UsimOptionAllLogicNV3 boolean nil
UltraSimVerilog.outputs UsimOptionAllLogicNV4 boolean nil
UltraSimVerilog.outputs UsimOptionLogicDepth2 string "1"
UltraSimVerilog.outputs UsimOptionLogicHighThreshold5 string ""
;UltraSimVerilog verimixOpts partition variables
UltraSimVerilog.verimixOpts filename6 string ""
UltraSimVerilog.verimixOpts maxDCIter int 0
UltraSimVerilog.verimixOpts scope1 string ""
UltraSimVerilog.verimixOpts scope10 string ""
UltraSimVerilog.verimixOpts filename8 string ""
UltraSimVerilog.verimixOpts dcInterval float 0.0
UltraSimVerilog.verimixOpts scope3 string ""
UltraSimVerilog.verimixOpts scope8 string ""
UltraSimVerilog.verimixOpts scope7 string ""
UltraSimVerilog.verimixOpts filename7 string ""
UltraSimVerilog.verimixOpts scope string ""
UltraSimVerilog.verimixOpts filename4 string ""
UltraSimVerilog.verimixOpts filename string ""
UltraSimVerilog.verimixOpts filename1 string ""
UltraSimVerilog.verimixOpts scope9 string ""
UltraSimVerilog.verimixOpts importsdfswitch boolean nil
UltraSimVerilog.verimixOpts filename2 string ""
UltraSimVerilog.verimixOpts numberofsdffiles int 2
UltraSimVerilog.verimixOpts scope2 string ""
UltraSimVerilog.verimixOpts scope6 string ""
UltraSimVerilog.verimixOpts filename10 string ""
UltraSimVerilog.verimixOpts delaymodechoice string "Ignore"
UltraSimVerilog.verimixOpts sdfmixedswitch boolean t
UltraSimVerilog.verimixOpts filename9 string ""
UltraSimVerilog.verimixOpts scope5 string ""
UltraSimVerilog.verimixOpts filename5 string ""
UltraSimVerilog.verimixOpts filename3 string ""
UltraSimVerilog.verimixOpts scope4 string ""
;UltraSimVerilog verilogOpts partition variables
UltraSimVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
UltraSimVerilog.verilogOpts optionsFile string ""
UltraSimVerilog.verilogOpts twinTurbo boolean nil
UltraSimVerilog.verilogOpts suppressMessages boolean nil
UltraSimVerilog.verilogOpts libraryFile string ""
UltraSimVerilog.verilogOpts behaveProfile boolean nil
UltraSimVerilog.verilogOpts verimixLog string "verilog.log"
UltraSimVerilog.verilogOpts simVision boolean nil
UltraSimVerilog.verilogOpts pulseSpec boolean nil
UltraSimVerilog.verilogOpts commandFile string ""
UltraSimVerilog.verilogOpts pulseError int 100
UltraSimVerilog.verilogOpts stopCompile boolean nil
UltraSimVerilog.verilogOpts keepNodes string "Minimum"
UltraSimVerilog.verilogOpts accelerationCA boolean nil
UltraSimVerilog.verilogOpts turboRadio string "Default"
UltraSimVerilog.verilogOpts libraryDir string ""
UltraSimVerilog.verilogOpts suppressWarnings boolean nil
UltraSimVerilog.verilogOpts accelerationSwitches boolean nil
UltraSimVerilog.verilogOpts accelerationNormal boolean t
UltraSimVerilog.verilogOpts delayType string "Typical"
UltraSimVerilog.verilogOpts pulseReject int 100
UltraSimVerilog.verilogOpts delayMode string "Default"
UltraSimVerilog.verilogOpts vermixBinary string "verilog.vmx"
;UltraSimVerilog init partition variables
UltraSimVerilog.init processPriority int 0
;UltraSimVerilog envOpts partition variables
UltraSimVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
UltraSimVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
UltraSimVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
UltraSimVerilog.envOpts outputFormat string "AWD"
UltraSimVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
UltraSimVerilog.envOpts mspSetupNetlistEscapeName boolean nil
UltraSimVerilog.envOpts autoDisplay boolean t
UltraSimVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
UltraSimVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
UltraSimVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
UltraSimVerilog.envOpts mspSetupNetlistPinMap boolean nil
UltraSimVerilog.envOpts mspSetupNetlistBus boolean t
UltraSimVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
UltraSimVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
UltraSimVerilog.envOpts mspSetupNetlistExplicit boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
UltraSimVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
UltraSimVerilog.envOpts printComments boolean nil
UltraSimVerilog.envOpts UltraSimVectorFile string ""
UltraSimVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
UltraSimVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimTimeValue int 1
UltraSimVerilog.envOpts mspSetupNetlistUseLib boolean nil
UltraSimVerilog.envOpts UltraSimVcdFile string ""
UltraSimVerilog.envOpts mspSetupNetlistNullPort boolean nil
UltraSimVerilog.envOpts mspSetupNetlistDropPortRange boolean t
UltraSimVerilog.envOpts userCmdLineOption string ""
UltraSimVerilog.envOpts mspSetupNetlistUpCase boolean nil
UltraSimVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
UltraSimVerilog.envOpts UltraSimVcdInfo string ""
;UltraSimVerilog tran partition variables
UltraSimVerilog.tran enable toggle (nil)
UltraSimVerilog.tran stop string ""
;UltraSimVerilog tranOpts partition variables
UltraSimVerilog.tranOpts start string ""
UltraSimVerilog.tranOpts outputstart string ""
UltraSimVerilog.tranOpts step string "1e-9"
UltraSimVerilog.tranOpts readic string ""
UltraSimVerilog.tranOpts write string "UltraSim.ic"
UltraSimVerilog.tranOpts writefinal string "UltraSim.fc"
UltraSimVerilog.tranOpts method_new string ""
UltraSimVerilog.tranOpts infotimes string ""
UltraSimVerilog.tranOpts maxstep string ""
UltraSimVerilog.tranOpts max_start string ""
UltraSimVerilog.tranOpts max_stop string ""
UltraSimVerilog.tranOpts max_subckt string ""
;1*******************************************************
;2* DLE/DLR Environment Variables
;3*******************************************************
adle lxLocalAbutment boolean nil
;AMS-Direct Environment Defaults
;FORMAT: tool[.partition] varName type value private {choices, minmax} comment
amsDirect amsCompMode boolean nil
amsDirect amsLSB_MSB boolean nil
amsDirect amsScalarInstances boolean t
amsDirect includeInstCdfParams boolean nil
amsDirect amsVerbose boolean nil
amsDirect amsMaxErrors int 50
amsDirect amsExcludeParams string ""
amsDirect hdlVarFile string ""
amsDirect simRunDirLoc string ""
amsDirect logFileName string "ams_direct.log"
amsDirect initFile string ""
amsDirect amsDefinitionViews string ""
amsDirect amsExpScalingFactor cyclic "no"
amsDirect modifyParamScope cyclic "no"
amsDirect.prep allowUndefParams boolean t
amsDirect.prep detailedDisciplineRes boolean nil
amsDirect.prep forceGlobalSync boolean nil
amsDirect.prep ncsimGUI boolean t
amsDirect.prep ncsimTcl boolean nil
amsDirect.prep runNcelab boolean t
amsDirect.prep runNcsim boolean t
amsDirect.prep use5xForVHDL boolean t
amsDirect.prep ncelabAnnoSimtime boolean nil
amsDirect.prep ncelabCoverage boolean nil
amsDirect.prep ncelabEpulseNeg boolean nil
amsDirect.prep ncelabIeee1634 boolean nil
amsDirect.prep ncelabInterconnmultisrc boolean nil
amsDirect.prep ncelabLibverbose boolean nil
amsDirect.prep ncelabMessages boolean nil
amsDirect.prep ncelabNostdout boolean nil
amsDirect.prep ncelabNoTchkMsg boolean nil
amsDirect.prep ncelabNoTchkXgen boolean nil
amsDirect.prep ncelabNotimingchecks boolean nil
amsDirect.prep ncelabNovitalaccl boolean t
amsDirect.prep ncelabNoVpdmsg boolean nil
amsDirect.prep ncelabNoVpdXgen boolean nil
amsDirect.prep ncelabNtcWarn boolean nil
amsDirect.prep ncelabPathpulse boolean nil
amsDirect.prep ncelabPlinooptwarn boolean nil
amsDirect.prep ncelabPlinowarn boolean nil
amsDirect.prep ncelabPresrvResFn boolean nil
amsDirect.prep ncelabSdfNocheckCelltype boolean nil
amsDirect.prep ncelabSdfNoHeader boolean nil
amsDirect.prep ncelabSdfNoWarnings boolean nil
amsDirect.prep ncelabSdfWorstcaseRounding boolean nil
amsDirect.prep ncelabStatus boolean t
amsDirect.prep ncelabUpdate boolean t
amsDirect.prep ncelabV93 boolean nil
amsDirect.prep ncelabNosource boolean nil
amsDirect.prep ncelabUseAfile boolean nil
amsDirect.prep ncelabUseGenafile boolean nil
amsDirect.prep ncelabExpand boolean nil
amsDirect.prep ncelabRelax boolean nil
amsDirect.prep ncelabDisableenht boolean nil
amsDirect.prep ncelabNonegtchk boolean nil
amsDirect.prep ncelabNoipd boolean nil
amsDirect.prep ncelabSdfverbose boolean nil
amsDirect.prep ncelabNoautosdf boolean nil
amsDirect.prep ncelabNeverwarn boolean nil
amsDirect.prep ncelabNocopyright boolean nil
amsDirect.prep ncelabUseGeneric boolean nil
amsDirect.prep ncelabUsePulseR boolean nil
amsDirect.prep ncelabUsePulseE boolean nil
amsDirect.prep ncelabUsePulseIntR boolean nil
amsDirect.prep ncelabUsePulseIntE boolean nil
amsDirect.prep ncelabUseExtendtcheckdatalimit boolean nil
amsDirect.prep ncelabUseExtendtcheckreferencelimit boolean nil
amsDirect.prep ncelabNonotifier boolean nil
amsDirect.prep ncelabUseSdfprecision boolean nil
amsDirect.prep ncsimEpulseNoMsg boolean nil
amsDirect.prep ncsimExtassertmsg boolean nil
amsDirect.prep ncsimMessages boolean nil
amsDirect.prep ncsimNeverwarn boolean nil
amsDirect.prep ncsimNocifcheck boolean nil
amsDirect.prep ncsimNosource boolean nil
amsDirect.prep ncsimNostdout boolean nil
amsDirect.prep ncsimPlinooptwarn boolean nil
amsDirect.prep ncsimPlinowarn boolean nil
amsDirect.prep ncsimProfile boolean nil
amsDirect.prep ncsimProfthread boolean nil
amsDirect.prep ncsimRedmem boolean nil
amsDirect.prep ncsimStatus boolean nil
amsDirect.prep ncsimUnbuffered boolean nil
amsDirect.prep ncsimUpdate boolean t
amsDirect.prep ncelabUseAddArgs boolean nil
amsDirect.prep ncsimUseAddArgs boolean nil
amsDirect.prep ncelabMaxErrors int 50
amsDirect.prep ncelabPulseE int 100
amsDirect.prep ncelabPulseIntE int 100
amsDirect.prep ncelabPulseIntR int 100
amsDirect.prep ncelabPulseR int 100
amsDirect.prep ncelabExtendtcheckdatalimit int 0
amsDirect.prep ncelabExtendtcheckreferencelimit int 0
amsDirect.prep ncsimMaxErrors int 50
amsDirect.prep analogControlFile string ""
amsDirect.prep cdsGlobalsLib string ""
amsDirect.prep cdsGlobalsView string ""
amsDirect.prep compileExcludeLibs string ""
amsDirect.prep connectRulesCell string "mixedsignal"
amsDirect.prep connectRulesCell2 string "ConnRules_5V_full"
amsDirect.prep connectRulesLib string ""
amsDirect.prep connectRulesView string ""
amsDirect.prep discipline string "logic"
amsDirect.prep language string "verilog"
amsDirect.prep ncelabArguments string ""
amsDirect.prep ncsimArguments string ""
amsDirect.prep simVisScriptFile string ""
amsDirect.prep timescale string "1ns/1ns"
amsDirect.prep vlogGroundSigs string "gnd!"
amsDirect.prep vlogSupply0Sigs string ""
amsDirect.prep vlogSupply1Sigs string ""
amsDirect.prep ncelabAfile string ""
amsDirect.prep ncelabGenafile string ""
amsDirect.prep ncelabLoadpli1 string ""
amsDirect.prep ncelabLoadvpi string ""
amsDirect.prep ncelabSdfCmdFile string ""
amsDirect.prep ncelabTopLvlGeneric string ""
amsDirect.prep ncelabSdfprecision string ""
amsDirect.prep ncelabNowarn string ""
amsDirect.prep ncsimLoadvpi string ""
amsDirect.prep ncsimNowarn string ""
amsDirect.prep ncelabModelFilePaths string ""
amsDirect.prep compileMode cyclic "incremental"
amsDirect.prep netlistMode cyclic "incremental"
amsDirect.prep ncelabAccess cyclic "Read"
amsDirect.prep ncelabDelayMode cyclic "None"
amsDirect.prep ncelabDelayType cyclic "None"
amsDirect.prep ncelabEpulseFiltering cyclic "None"
amsDirect.prep ncelabLogFileAction cyclic "Overwrite log file"
amsDirect.prep ncelabOmichecklvl cyclic "Standard"
amsDirect.prep ncelabVipdelay cyclic "Typical"
amsDirect.prep ncsimLogFileAction cyclic "Overwrite log file"
amsDirect.prep ncsimOmichecklvl cyclic "None"
amsDirect.simcntl scapprox boolean nil
amsDirect.simcntl scdebug boolean nil
amsDirect.simcntl scdiagnose boolean nil
amsDirect.simcntl scerror boolean t
amsDirect.simcntl scignshorts boolean nil
amsDirect.simcntl scinfo boolean t
amsDirect.simcntl scmacromod boolean nil
amsDirect.simcntl scnarrate boolean t
amsDirect.simcntl scnote boolean t
amsDirect.simcntl scopptcheck boolean t
amsDirect.simcntl scpivotdc boolean nil
amsDirect.simcntl scscfusefileflag boolean nil
amsDirect.simcntl scspscflag boolean nil
amsDirect.simcntl scstats boolean nil
amsDirect.simcntl scwarn boolean t
amsDirect.simcntl scfastbreak boolean nil
amsDirect.simcntl scusemodeleval boolean nil
amsDirect.simcntl scdigits int 5
amsDirect.simcntl scmaxiters int 5
amsDirect.simcntl scmaxnotes int 5
amsDirect.simcntl scmaxwarn int 5
amsDirect.simcntl scscale int 1
amsDirect.simcntl scscalem int 1
amsDirect.simcntl scskipcount int 0
amsDirect.simcntl sccmin string "0.0"
amsDirect.simcntl scaddlglblopts string ""
amsDirect.simcntl scaddltranopts string ""
amsDirect.simcntl scgmin string "1e-12"
amsDirect.simcntl sciabstol string "1e-12"
amsDirect.simcntl scicstmt string ""
amsDirect.simcntl sclteratio string ""
amsDirect.simcntl scmaxstep string ""
amsDirect.simcntl scpivabs string "0.0"
amsDirect.simcntl scpivrel string "1e-3"
amsDirect.simcntl screadic string ""
amsDirect.simcntl screadns string ""
amsDirect.simcntl screltol string ""
amsDirect.simcntl scrforce string "1.0"
amsDirect.simcntl scalem string "1.0"
amsDirect.simcntl scale string "1.0"
amsDirect.simcntl scscfincfile string ""
amsDirect.simcntl scscftimestamp string ""
amsDirect.simcntl scskipstart string "0.0"
amsDirect.simcntl scskipstop string "0.0"
amsDirect.simcntl scstep string ""
amsDirect.simcntl scstop string "0.0"
amsDirect.simcntl scstrobedelay string "0.0"
amsDirect.simcntl scstrobeperiod string "0.0"
amsDirect.simcntl sctemp string "27.0"
amsDirect.simcntl sctitle string ""
amsDirect.simcntl sctnom string "27.0"
amsDirect.simcntl scvabstol string "1e-6"
amsDirect.simcntl scwrite string ""
amsDirect.simcntl scwritefinal string ""
amsDirect.simcntl scannotate cyclic "sweep"
amsDirect.simcntl scaudit cyclic "detailed"
amsDirect.simcntl sccheckstmt cyclic "all"
amsDirect.simcntl sccompatible cyclic "spectre"
amsDirect.simcntl scerrpreset cyclic "moderate"
amsDirect.simcntl scgmincheck cyclic "max_v_only"
amsDirect.simcntl schomotopy cyclic "all"
amsDirect.simcntl scic cyclic "all"
amsDirect.simcntl scinventory cyclic "detailed"
amsDirect.simcntl sclimit cyclic "dev"
amsDirect.simcntl scmethod cyclic "<Default value>"
amsDirect.simcntl scnotation cyclic "eng"
amsDirect.simcntl scquantities cyclic "no"
amsDirect.simcntl screlref cyclic "<Default value>"
amsDirect.simcntl scskipdc cyclic "no"
amsDirect.simcntl sctempeffects cyclic "all"
amsDirect.simcntl sctopcheck cyclic "full"
amsDirect.simcntl sctransave cyclic "allpub"
amsDirect.simcntl scmodelevaltype cyclic "s"
amsDirect.vhdl allowNoEntityUpdate boolean nil
amsDirect.vhdl checkAndNetlist boolean nil
amsDirect.vhdl checkOnly boolean nil
amsDirect.vhdl compileAsAMS boolean t
amsDirect.vhdl forceEntitySync boolean nil
amsDirect.vhdl forceInlineCompDecl boolean nil
amsDirect.vhdl netlistAfterCdfChange boolean nil
amsDirect.vhdl prohibitCompile boolean nil
amsDirect.vhdl useProcessViewNamesOnly boolean nil
amsDirect.vhdl lexpragma boolean nil
amsDirect.vhdl messages boolean nil
amsDirect.vhdl neverwarn boolean nil
amsDirect.vhdl nopragmawarn boolean nil
amsDirect.vhdl nostdout boolean nil
amsDirect.vhdl novitalcheck boolean nil
amsDirect.vhdl pragma boolean nil
amsDirect.vhdl relax boolean nil
amsDirect.vhdl status boolean nil
amsDirect.vhdl update boolean t
amsDirect.vhdl v93 boolean t
amsDirect.vhdl vhdllinedebug boolean nil
amsDirect.vhdl ncvhdlUseAddArgs boolean nil
amsDirect.vhdl maxErrors int 50
amsDirect.vhdl amsEligibleViewTypes string "schematic schematicSymbol"
amsDirect.vhdl defaultObject string "quantity"
amsDirect.vhdl defaultScalarNature string "real"
amsDirect.vhdl defaultScalarType string "quantity"
amsDirect.vhdl defaultVectorNature string "real_vector"
amsDirect.vhdl defaultVectorType string "quantity"
amsDirect.vhdl defPackageNames string ""
amsDirect.vhdl excludeViewNames string ""
amsDirect.vhdl ncvhdlArguments string ""
amsDirect.vhdl processViewNames string ""
amsDirect.vhdl templateFile string ""
amsDirect.vhdl templateScript string ""
amsDirect.vhdl logFileAction cyclic "Overwrite log file"
amsDirect.vhdl nowarn string ""
amsDirect.vhdl allowDeviantBuses cyclic "no"
amsDirect.vhdl allowIllegalIdentifiers cyclic "warn"
amsDirect.vhdl allowNameCollisions cyclic "warn"
amsDirect.vhdl allowPortNetMismatches cyclic "no"
amsDirect.vhdl allowSparseBuses cyclic "warn"
amsDirect.vhdl headerText cyclic "none"
amsDirect.vlog checkAndNetlist boolean nil
amsDirect.vlog checkOnly boolean nil
amsDirect.vlog compileAsAMS boolean t
amsDirect.vlog ifdefLanguageExtensions boolean nil
amsDirect.vlog netlistAfterCdfChange boolean nil
amsDirect.vlog prohibitCompile boolean nil
amsDirect.vlog useDefparam boolean nil
amsDirect.vlog useProcessViewNamesOnly boolean nil
amsDirect.vlog checktasks boolean nil
amsDirect.vlog ieee1364 boolean nil
amsDirect.vlog noline boolean nil
amsDirect.vlog lexpragma boolean nil
amsDirect.vlog markcelldefines boolean nil
amsDirect.vlog messages boolean nil
amsDirect.vlog neverwarn boolean nil
amsDirect.vlog nomempack boolean nil
amsDirect.vlog nopragmawarn boolean nil
amsDirect.vlog nostdout boolean nil
amsDirect.vlog pragma boolean nil
amsDirect.vlog status boolean nil
amsDirect.vlog update boolean t
amsDirect.vlog vloglinedebug boolean nil
amsDirect.vlog ncvlogUseAddArgs boolean nil
amsDirect.vlog netlistUDFAsMacro boolean nil
amsDirect.vlog bindCdsAliasLib boolean t
amsDirect.vlog bindCdsAliasView boolean t
amsDirect.vlog maxErrors int 50
amsDirect.vlog amsEligibleViewTypes string "schematic"
amsDirect.vlog excludeViewNames string ""
amsDirect.vlog includeFiles string "(disciplines.vams)"
amsDirect.vlog ncvlogArguments string ""
amsDirect.vlog paramDefVals string ""
amsDirect.vlog paramGlobalDefVal string "0"
amsDirect.vlog processViewNames string ""
amsDirect.vlog templateFile string ""
amsDirect.vlog templateScript string ""
amsDirect.vlog incdir string ""
amsDirect.vlog macro string ""
amsDirect.vlog nowarn string ""
amsDirect.vlog allowDeviantBuses cyclic "no"
amsDirect.vlog allowIllegalIdentifiers cyclic "warn"
amsDirect.vlog allowNameCollisions cyclic "warn"
amsDirect.vlog allowSparseBuses cyclic "warn"
amsDirect.vlog headerText cyclic "none"
amsDirect.vlog logFileAction cyclic "Overwrite log file"
amsDirect.vlog iterInstExpFormat string "%b_%i"
amsDirect.vlog netClashFormat string "%b_netclash"
amsDirect.vlog instClashFormat string "%b_instclash"
amsDirect.vlog aliasInstFormat string "ams_alias_inst_%i"
;Analog Artist Simulation Environment Defaults
;Session Options
asimenv windowBased boolean t
asimenv schematicBased boolean nil
asimenv saveDir string "~/.artist_states"
asimenv saveQuery boolean t
asimenv loadCorners boolean t
asimenv designEditMode boolean nil;edit/read open mode
asimenv showWhatsNew string "yes"
asimenv.startup simulator string "spectre"
asimenv.startup projectDir string "~/simulation"
asimenv.startup hostMode string "local"
asimenv.startup host string ""
asimenv.startup remoteDir string ""
asimenv.startup digitalHostMode string "local"
asimenv.startup digitalHost string ""
;Window Options
asimenv.window x int 1
asimenv.window y int 317
;Load State Dialog
asimenv.loadstate modelSetup boolean t
;when set to nil, loadstate form opens with Model Setup deselected by default
;Plotting Options
asimenv.plotting autoPlot boolean t
asimenv.plotting overlay boolean nil
asimenv.plotting immediatePlot boolean nil
asimenv.plotting designName boolean t
asimenv.plotting simulationDate boolean t
asimenv.plotting temperature boolean nil
asimenv.plotting variables boolean nil
asimenv.plotting scalarOutputs boolean nil
asimenv.plotting icons boolean t
asimenv.plotting fontSize int 11
asimenv.plotting width int 564
asimenv.plotting height int 428
asimenv.plotting x int 577
asimenv.plotting y int 373
asimenv.plotting displayMode cyclic "auto"
asimenv.plotting stripModeType cyclic "auto"
asimenv.plotting immediatePrint boolean t
asimenv.plotting printInlines boolean t
;Command-Type-In Window
asimenv.window width int 650
asimenv.window height int 275
;Miscellaneous
asimenv.misc saveDefaultsToOCEAN boolean nil
asimenv.misc numberOfSavedRuns int 0
asimenv.misc browserCenterMode boolean nil
asimenv.misc updateCDFtermOrder boolean nil
asimenv.misc queryCDFtermOrder boolean t
asimenv.misc oceanScriptFile string "./oceanScript.ocn"
asimenv.userPref printNotation cyclic "suffix"
asimenv.userPref printCommentChar string "#"
;Noise summary options
asimenv.noiseSummary digits int 6
asimenv.noiseSummary percentDecimals int 2
;obsolete simulator startup form variables
asimenv.startup sessionName string "schematic"
asimenv.startup libName string ""
asimenv.startup cellName string ""
asimenv.startup viewName string ""
asimenv.startup versionName string ""
asimenv.netlist obsoleteWarnings int 1
;Distributed Processing
;Please do not add any options other than for Artist Distributed
;below this point.
;asimenv.startup hostMode - value of 'distributed' enables distributed processing
asimenv.distributed externalServer boolean nil
;If set non-nil, the job server is started remotely.
asimenv.distributed autoJobSubmit boolean nil
;If set non-nil, job setup form is NOT presented to user at job submit time.
asimenv.distributed showMessages boolean t
;If set non-nil, a message is displayed in the CIW or OCEAN terminal
;when a job is completed.
asimenv.distributed queueName string ""
;Sets the default queue name. If unspecified, system default is used.
asimenv.distributed hostName string ""
;Sets the default host name. If unspecified, host is automatically selected.
asimenv.distributed startTime string ""
;Sets the default start time for a job (in 24 hr. format). If unspecified, job runs immediately.
asimenv.distributed startDay cyclic "today"
;Sets the default start day for a job. If `today', then job will always run on the same day it is submitted
asimenv.distributed expTime string ""
;Sets the default expiration time for a job (in 24 hr. format). If unspecified, expiration time
;is based on the value of the `timeLimit' variable.
asimenv.distributed expDay cyclic "today"
;Sets the default expiration day for a job. If `today', then job will always run on the same day it is submitted
asimenv.distributed timeLimit cyclic "none"
;Sets the default time limit for a job. If `none', then no time limit is imposed.
;If `unspecified', then expiration time is based on value of `expTime' and `expDay' variables.
asimenv.distributed emailNotify boolean t
;If set non-nil, email notification is provided following job termination.
asimenv.distributed mailTo string ""
;Sets the default list of users who will receive job termination notification email.
;If unspecified, and emailNotify is t, then default value is the user's id.
asimenv.distributed logsInEmail boolean t
;If set non-nil, stdout and stderr logs will be included in the termination email.
asimenv.distributed stateFile string "~/.adpState"
;Sets the filename containing the job server's state.
asimenv.distributed daysBeforeExpire int 3
;Specifies the number of days after which terminated jobs will be deleted from
;the job server.
asimenv.distributed block boolean nil
;If set non-nil, the process will be blocked until the job has completed.
asimenv.distributed copyMode boolean nil
;If set non-nil, the input data for the job is copied to /tmp on the execution host,
;the job is run there locally (i.e. no network read/write), and the output data is
;copied back to the submission host.
asimenv.distributed copyModeDir string "/tmp"
;The directory, relative to the execution host, that will be used for setting up the
;working directory of a copy mode job.
asimenv.distributed loginShell cyclic "none"
;Specifies login shell for the job. If `none', then the user's local environment
;is copied over to the execution host and used as the job's environment.
asimenv.distributed numOfTasks int 0
;Specifies the default number of tasks a job should be broken into.
;This is used by the Monte Carlo tool.
;If zero, then number of tasks is bases on queue and/or host settings
asimenv.distributed jobArgsInOceanScript boolean nil
;Indicates job arguments should be added to run commands when
;OCEAN script is generated.
asimenv.distributed puttogetherqueue string ""
;Used to specify the queue to be used for Put Together Job
asimenv.distributed copyNetlist boolean nil
;Used to specify whether netlist directory needs to be copied from execution
;host to submission host. This may be required if during simulation, some files
;are generated under netlist dir
;Used to specify whether to remove the job from DP database after job completion.
;So that, if set to t, the same job name is used repeatedly.
;Used to specify whether list option for specifying hosts needs to be displayed
;in Job Submit Form. If set to nil the list option will not be displayed.
;Used to specify the default value for Shell_Cmd_at_Finish as available in job
;submit form.
asimenv.distributed logsDir string "/tmp"
;Used to specify the directory where the log files would be generated
asimenv.distributed mailAllLogs boolean nil
;Used to specify whether to send the log files in mail for all the tasks
;If set to t, log files would be mailed for each task and a summary mail would be
;sent after completion of all the tasks. If set to nil just a summary mail would be
asimenv.distributed logFile string "~/cdsDPSetupChk.log"
asimenv.distributed clockSync boolean nil
asimenv.distributed lsfResourceString string ""
;Used to specify the Default LSF Resource String
asimenv.distributed donotCopyCore boolean t
;Used to specify whether DP need to filter the core files while copying the directories
;If set to t then all the files with name starting from core will be filtered out
;If set to nil then all the files will be copied
; Copyright (C) 1991
; Cadence Design Systems, Analog Division
; All Rights Reserved.
; $Source: /cvsrep/group/artist/src/auCdl/cdsenv,v $
; $Author: cvsadm $
; $Revision: 1.1 $
; $Date: 2003/10/06 04:16:43 $
; $State: Exp $
;auCdl Environment Variables
;For cell-view to cell-view:
auCdl.envOpts defaultSubcircuitCall string "ansCdlSubcktCall"
;auCore Environment Variables
;Note: The tool registration file should not be edited.
;Customization should be based on the file in <cdshier>/samples/.cdsenv.
;Tool Filter list of simulators
auCore.toolFilter toolList string "spectre spectreS cdsSpice auCdl auLvs hspiceS hspiceD UltraSim "
;Tool Filter list of simulators selected by default
auCore.toolFilter defaultTools string "spectre spectreS auCdl auLvs"
;Tool Filter variable to enable auto update
auCore.toolFilter autoUpdate boolean nil
;Logic Levels form variables
auCore.voltageLevels highlayer cyclic "y2"
auCore.voltageLevels midlayer cyclic "y4"
auCore.voltageLevels lowlayer cyclic "y6"
auCore.voltageLevels high float 2.0
auCore.voltageLevels low float 0.8
auCore.voltageLevels type string "DC"
auCore.voltageLevels time float 0.0
;The following variable indicates the release to which the Artist cdsenv
;variables are compliant. Set to the current release to disable
;automatic variable detection/conversion of user's .cdsenv file.
auCore artVarVer string ""
; $Source: /cvsrep/group/artist/src/auLvs/cdsenv,v $
; $Author: zhaag $
; $Revision: 1.1.12.1 $
; $Date: 2004/10/13 09:30:08 $
; $State: Exp $
auLvs.envOpts defaultSubcircuitCall string "ansLvsCompPrim"
;Calculator environment variables
;FORMAT: tool[.partition] varName varType default private {choices,min/max}
;calculator modes
calculator mode cyclic "RPN"
calculator uimode cyclic "standard"
calculator eval boolean nil
calculator dstack boolean nil
calculator oldexpr boolean t
calculator browserOldExpr boolean nil
;clip special function variables
calculator.clip from string ""
calculator.clip to string ""
;value special function variables
calculator.value at string ""
;x value at maximum special function variables
calculator.xmax nth string "1"
;x value at minimum special function variables
calculator.xmin nth string "1"
;ipn special function variables
calculator.ipn spurOrder string "3"
calculator.ipn refHarmonic string "1"
calculator.ipn spurHarmonic string "1"
calculator.ipn extPoint string "0"
calculator.ipn refOrder string "1"
;ipnVRI special function variables
calculator.ipnVRI spurHarmonic string ""
calculator.ipnVRI refHarmonic string ""
calculator.ipnVRI ordspur string ""
calculator.ipnVRI epoint string ""
calculator.ipnVRI rport string ""
calculator.ipnVRI measurePrompt cyclic "Input Referred IPN"
calculator.ipnVRI powerSwPrompt cyclic "Variable Sweep"
calculator.ipnVRI measure string ""
calculator.ipnVRI psweep string ""
;phaseNoise special function variables
calculator.phaseNoise nth string "0"
calculator.phaseNoise noiseResNam string "pnoise.pss"
;compression special function variables
calculator.compression nth string "0"
calculator.compression x string "0"
calculator.compression compress string "1"
calculator.compressionVRI harmonic string ""
calculator.compressionVRI epoint string ""
calculator.compressionVRI rport string ""
calculator.compressionVRI gcomp string ""
calculator.compressionVRI measurePrompt cyclic "Input Referred Compression"
calculator.compressionVRI measure string ""
;harmonic special function variable
calculator.harmonic nth string "0"
calculator.harmonic spurHarmonic string "1"
calculator.harmonic refHarmonic string "1"
;harmonicFreq special function variable
calculator.harmonicFreq nth string "1"
;tangent special function variables
calculator.tangent x string "0"
calculator.tangent y string "0"
calculator.tangent slope string "1.0"
;discrete fourier transform special function variables
calculator.dft from string ""
calculator.dft to string ""
calculator.dft samples string "64"
calculator.dft windowName cyclic "Rectangular"
calculator.dft smooth float 1.0
calculator.dft cgtype cyclic "(none)"
calculator.dft cohGain float 1.0
calculator.psd from string ""
calculator.psd to string ""
calculator.psd samples string "512"
calculator.psd windowName cyclic "Hanning"
calculator.psd smooth float 1.0
calculator.psd cgtype cyclic "(none)"
calculator.psd cohGain float 1.0
calculator.psd detrending cyclic "None"
calculator.psd windowSize string "256"
calculator.psdbb from string ""
calculator.psdbb to string ""
calculator.psdbb samples string "512"
calculator.psdbb windowName cyclic "Hanning"
calculator.psdbb smooth float 1.0
calculator.psdbb cgtype cyclic "(none)"
calculator.psdbb cohGain float 1.0
calculator.psdbb detrending cyclic "None"
calculator.psdbb windowSize string "256"
;total harmonic distortion special function variables
calculator.thd from string ""
calculator.thd to string ""
calculator.thd samples string "64"
calculator.thd fundamental string ""
;threshold crossing special function variables
calculator.cross value string "2.5"
calculator.cross nth string "1"
calculator.cross type cyclic "either"
;root value special function variables
calculator.root value string "2.5"
calculator.root nth string "1"
;fourier evaluation special function variables
calculator.fourEval from string ""
calculator.fourEval to string ""
calculator.fourEval by string ""
;convolution special function variables
calculator.convolve from string ""
calculator.convolve to string ""
calculator.convolve incr cyclic "linear"
calculator.convolve by string ""
;threshold delay special function variables
calculator.delay value_a string "2.5"
calculator.delay nth_a string "1"
calculator.delay type_a cyclic "either"
calculator.delay value_b string "2.5"
calculator.delay nth_b string "1"
calculator.delay type_b cyclic "either"
;bandwidth special function variables
calculator.bandwidth db string "3"
calculator.bandwidth type cyclic "low"
;rise time special function variables
calculator.riseTime initial string ""
calculator.riseTime itype cyclic "y at x"
calculator.riseTime final string ""
calculator.riseTime ftype cyclic "y at x"
calculator.riseTime theta_a string "10"
calculator.riseTime theta_b string "90"
;slew rate special function variables
calculator.slewRate initial string ""
calculator.slewRate itype cyclic "y at x"
calculator.slewRate final string ""
calculator.slewRate ftype cyclic "y at x"
calculator.slewRate theta_a string "10"
calculator.slewRate theta_b string "90"
;sample special function variables
calculator.sample from string ""
calculator.sample to string ""
calculator.sample incr cyclic "linear"
calculator.sample by string ""
;settling time special function variables
calculator.settlingTime initial string ""
calculator.settlingTime itype cyclic "y at x"
calculator.settlingTime final string ""
calculator.settlingTime ftype cyclic "y at x"
calculator.settlingTime theta string "5"
;overshoot special function variables
calculator.overshoot initial string ""
calculator.overshoot itype cyclic "y at x"
calculator.overshoot final string ""
calculator.overshoot ftype cyclic "y at x"
;table special function variables
calculator.table filename string ""
calculator.table name string ""
calculator.table xcolumn int 1
calculator.table ycolumn int 2
calculator.table xskip int 0
calculator.table yskip int 0
;left shift special function variables
calculator.lshift delta string "0"
;rms noise special function variables
calculator.rmsNoise from string ""
calculator.rmsNoise to string ""
;eyeDiagram special function variables
calculator.eyeDiagram start string "0"
calculator.eyeDiagram stop string "0"
calculator.eyeDiagram period string "0"
;defInteg special function variables
calculator.integ initial string ""
calculator.integ final string ""
; cdba Environment Variables
; This tool registration file should not be edited
; since customization is done via the file in
; <cdshier>/samples/.cdsenv
cdba dbInstNamingGlobalInc boolean nil
cdba dbNumCPU int 1
cdba dbStatCacheOn boolean nil
cdba.DBUPerUU behavioral int 160
cdba.DBUPerUU graphic int 1000
cdba.DBUPerUU logicModel int 160
cdba.DBUPerUU maskLayout int 1000
cdba.DBUPerUU netlist int 160
cdba.DBUPerUU package int 160
cdba.DBUPerUU PCB int 160
cdba.DBUPerUU schematic int 160
cdba.DBUPerUU schematicSymbol int 160
cdba.DBUPerUU stranger int 1000
cdba.DBUPerUU symbolic int 1000
cdba.DBUPerUU verilogMap int 160
cdba.userUnits behavioral cyclic "inch"
cdba.userUnits graphic cyclic "micron"
cdba.userUnits logicModel cyclic "inch"
cdba.userUnits maskLayout cyclic "micron"
cdba.userUnits netlist cyclic "inch"
cdba.userUnits package cyclic "inch"
cdba.userUnits PCB cyclic "inch"
cdba.userUnits schematic cyclic "inch"
cdba.userUnits schematicSymbol cyclic "inch"
cdba.userUnits stranger cyclic "micron"
cdba.userUnits symbolic cyclic "micron"
cdba.userUnits verilogMap cyclic "inch"
; this file is tools/dfII/etc/tools/cdsLibEditor/.cdsenv, format is:
; tool[.partition] varName varType default private {choices,min/max}
cdsLibEditor.main autoExclEdit boolean nil
cdsLibEditor.main warnExclLock boolean t
; this file is tools/dfII/etc/tools/cdsLibManager/.cdsenv, format is:
cdsLibManager.ckCancel useOptionText string ""
cdsLibManager.ckCancel useOptionsOn boolean nil
cdsLibManager.ckIn selectMatches toggle (t nil nil nil)
cdsLibManager.ckIn useOptionText string ""
cdsLibManager.ckIn useOptionsOn boolean nil
cdsLibManager.ckOut useOptionText string ""
cdsLibManager.ckOut useOptionsOn boolean nil
cdsLibManager.copy addToCategoryName string ""
cdsLibManager.copy addToCategoryOn boolean nil
cdsLibManager.copy addToCellsPattern string "*"
cdsLibManager.copy allViewsOn boolean t
cdsLibManager.copy exactHierOn boolean nil
cdsLibManager.copy extraViews string ""
cdsLibManager.copy hierOn boolean nil
cdsLibManager.copy skipLibsOn boolean t
cdsLibManager.copy skipLibsText string ""
cdsLibManager.copy skipLibsText1 string ""
cdsLibManager.copy skipLibsText10 string ""
cdsLibManager.copy skipLibsText11 string ""
cdsLibManager.copy skipLibsText12 string ""
cdsLibManager.copy skipLibsText13 string ""
cdsLibManager.copy skipLibsText14 string ""
cdsLibManager.copy skipLibsText15 string ""
cdsLibManager.copy skipLibsText2 string ""
cdsLibManager.copy skipLibsText3 string ""
cdsLibManager.copy skipLibsText4 string ""
cdsLibManager.copy skipLibsText5 string ""
cdsLibManager.copy skipLibsText6 string ""
cdsLibManager.copy skipLibsText7 string ""
cdsLibManager.copy skipLibsText8 string ""
cdsLibManager.copy skipLibsText9 string ""
cdsLibManager.copy updateChoice toggle (t nil)
cdsLibManager.copy updateOn boolean nil
cdsLibManager.copy viewsText string ""
cdsLibManager.copy addPropFiles boolean t
cdsLibManager.copyError overwriteAll boolean nil
cdsLibManager.copyGlobals expandRadio toggle (t nil)
cdsLibManager.copyGlobals mpsRadio toggle (t nil)
cdsLibManager.copyGlobals stopMutations boolean t
cdsLibManager.copyGlobals useMonitor boolean t
cdsLibManager.copyGlobals warnRenameDM boolean t
cdsLibManager.copyVersion openView boolean t
cdsLibManager.copyVersion toLibrary string ""
cdsLibManager.copyVersion toView string ""
cdsLibManager.copyVersion useOptionText string ""
cdsLibManager.copyVersion useOptionsOn boolean nil
cdsLibManager.copyWizard addToCategoryName string ""
cdsLibManager.copyWizard addToCategoryOn boolean nil
cdsLibManager.copyWizard addToCellsPattern string "*"
cdsLibManager.copyWizard extraViews string ""
cdsLibManager.copyWizard skipLibsText string ""
cdsLibManager.copyWizard skipLibsText1 string ""
cdsLibManager.copyWizard skipLibsText10 string ""
cdsLibManager.copyWizard skipLibsText11 string ""
cdsLibManager.copyWizard skipLibsText12 string ""
cdsLibManager.copyWizard skipLibsText13 string ""
cdsLibManager.copyWizard skipLibsText14 string ""
cdsLibManager.copyWizard skipLibsText15 string ""
cdsLibManager.copyWizard skipLibsText2 string ""
cdsLibManager.copyWizard skipLibsText3 string ""
cdsLibManager.copyWizard skipLibsText4 string ""
cdsLibManager.copyWizard skipLibsText5 string ""
cdsLibManager.copyWizard skipLibsText6 string ""
cdsLibManager.copyWizard skipLibsText7 string ""
cdsLibManager.copyWizard skipLibsText8 string ""
cdsLibManager.copyWizard skipLibsText9 string ""
cdsLibManager.copyWizard updateChoice toggle (t nil)
cdsLibManager.copyWizard updateOn boolean t
cdsLibManager.customize mapTimeout float 5.0
cdsLibManager.customize showDFIIWarning boolean t
cdsLibManager.customize startupFile string "cdsLibMgr.il"
cdsLibManager.database addDb1 string ""
cdsLibManager.database addDb2 string ""
cdsLibManager.database addDb3 string ""
cdsLibManager.database addDb4 string ""
cdsLibManager.database addDb5 string ""
cdsLibManager.database addDb6 string ""
cdsLibManager.database addDb7 string ""
cdsLibManager.database addDb8 string ""
cdsLibManager.database addDb9 string ""
cdsLibManager.database ddDb string "com.cadence.interfaces.libAccess.cddLib5xDatabase"
cdsLibManager.database server string "com.cadence.interfaces.libAccess.ladLibraryServer"
cdsLibManager.defaults fileRadio toggle (nil t nil)
cdsLibManager.defaults saveAllOn boolean nil
cdsLibManager.defaults saveAsText string ".cdsenv"
cdsLibManager.delete libCheckOn boolean t
cdsLibManager.delete localRadio toggle (t nil)
cdsLibManager.deleteTag overrideRadio toggle (t nil nil nil)
cdsLibManager.deleteView localRadio toggle (t nil)
cdsLibManager.filter cellFilter string ""
cdsLibManager.filter viewFilter string ""
; The log file format is 'baseName[.UID][.host][.PID][.sequence].log'
cdsLibManager.log addHostID boolean nil
cdsLibManager.log addProcID boolean nil
cdsLibManager.log addSequence boolean nil
cdsLibManager.log addUserID boolean nil
cdsLibManager.log baseName string "libManager"
cdsLibManager.main categoryText string ""
cdsLibManager.main cellLevelText string ""
cdsLibManager.main dblClickEditCellView boolean t
cdsLibManager.main libraryText string ""
cdsLibManager.main showCategoriesOn boolean nil
cdsLibManager.main showFilesOn boolean nil
cdsLibManager.main viewLevelText string ""
cdsLibManager.newLib dmRadio toggle (t nil)
cdsLibManager.newLib pathText string ""
cdsLibManager.option forceEnv boolean nil
cdsLibManager.option useDMfilter boolean t
cdsLibManager.option useFastDM boolean t
cdsLibManager.rename updateOn boolean t
cdsLibManager.renameRefLib refreshSessionOn boolean t
cdsLibManager.submit useNameOn boolean nil
cdsLibManager.submit useNameText string ""
cdsLibManager.submit useOptionText string ""
cdsLibManager.submit useOptionsOn boolean nil
cdsLibManager.update useNameOn boolean nil
cdsLibManager.update useNameText string ""
cdsLibManager.update useOptionText string ""
cdsLibManager.update useOptionsOn boolean nil
;cdsSpice environment variables
;cdsSpice opts partition variables
cdsSpice.opts TEMPDC string "25"
cdsSpice.opts NSIG string "4"
cdsSpice.opts TIMSAT string "0"
cdsSpice.opts RELTOL string "1e-3"
cdsSpice.opts MKS string "1"
cdsSpice.opts ITL5 string "999999"
cdsSpice.opts ARTSTR string "0"
cdsSpice.opts GMINON string "2"
cdsSpice.opts LVLTIM string "2"
cdsSpice.opts VCESAT string "0.0"
cdsSpice.opts ITL3 string "4"
cdsSpice.opts SCALEM string "1"
cdsSpice.opts GO2OFF string "0"
cdsSpice.opts ITL4 string "25"
cdsSpice.opts AVSTEP string ".33"
cdsSpice.opts ITL1 string "100"
cdsSpice.opts ITL2 string "100"
cdsSpice.opts METHOD string "1"
cdsSpice.opts CHGTOL string "1e-14"
cdsSpice.opts TNOM string "25"
cdsSpice.opts MORBKP string ".1"
cdsSpice.opts ABSTOL string "1e-12"
cdsSpice.opts UIC string "0"
cdsSpice.opts SINWAV string "1e+6"
cdsSpice.opts GRTEXT string "1"
cdsSpice.opts PRNOTE string "1"
cdsSpice.opts VLIMAX string "50000"
cdsSpice.opts GMIN string "1e-12"
cdsSpice.opts GSAVE string "0"
cdsSpice.opts INTTIM string "0"
cdsSpice.opts CNVREV string "2.4"
cdsSpice.opts DCSAT string "0"
cdsSpice.opts TINIT string ""
cdsSpice.opts VBESAT string "0.6"
cdsSpice.opts QADLIN string "0"
cdsSpice.opts MFNOIS string "0"
cdsSpice.opts TRTOL string "7"
cdsSpice.opts SCALE string "1"
cdsSpice.opts PSFFLG string "1"
cdsSpice.opts SPICE2G string "0"
cdsSpice.opts WRFLAG string "0"
cdsSpice.opts SPTEMP string "1"
cdsSpice.opts RON string "1"
cdsSpice.opts NRAMP string "0"
cdsSpice.opts VNTOL string "1e-6"
cdsSpice.opts NOWARN string "0"
cdsSpice.opts VBCSAT string "0.15"
cdsSpice.opts DCOPPT string "1"
cdsSpice.opts MAXORD string "2"
cdsSpice.opts SPMESS string "1"
;cdsSpice outputs partition variables
cdsSpice.outputs allAnalogNV boolean t
cdsSpice.outputs allAnalogTC boolean nil
;cdsSpice envOpts partition variables
cdsSpice.envOpts updateFile string ""
cdsSpice.envOpts stimulusFile string ""
cdsSpice.envOpts instViewListTable string ""
cdsSpice.envOpts doInstBased boolean nil
cdsSpice.envOpts stopViewList string "cdsSpice spice"
cdsSpice.envOpts includeSyntax string "cdsSpice"
cdsSpice.envOpts initFile string ""
cdsSpice.envOpts printComments boolean nil
cdsSpice.envOpts netlistType string "hierarchical"
cdsSpice.envOpts generateMapFile boolean nil
cdsSpice.envOpts includeFile string ""
cdsSpice.envOpts instStopListTable string ""
cdsSpice.envOpts switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
;cdsSpice init partition variables
cdsSpice.init processPriority int 0
;cdsSpice dc partition variables
cdsSpice.dc enable toggle (nil)
cdsSpice.dc from string ""
cdsSpice.dc to string ""
cdsSpice.dc by string ""
cdsSpice.dc device string ""
;cdsSpice dcOpts partition variables
;cdsSpice noise partition variables
cdsSpice.noise enable toggle (nil)
cdsSpice.noise source string ""
cdsSpice.noise output string ""
cdsSpice.noise listEvery string "1"
;cdsSpice noiseOpts partition variables
;cdsSpice ac partition variables
cdsSpice.ac enable toggle (nil)
cdsSpice.ac from string ""
cdsSpice.ac to string ""
cdsSpice.ac incrType string "Logarithmic"
cdsSpice.ac lin string ""
cdsSpice.ac log string ""
;cdsSpice acOpts partition variables
;cdsSpice tran partition variables
cdsSpice.tran enable toggle (nil)
cdsSpice.tran from string ""
cdsSpice.tran to string ""
cdsSpice.tran by string ""
cdsSpice.tran delmax string ""
cdsSpice.tran continue boolean nil
cdsSpice.tran newParam boolean nil
;cdsSpice tranOpts partition variables
;cdsSpiceVerilog environment variables
;cdsSpiceVerilog opts partition variables
cdsSpiceVerilog.opts TEMPDC string "25"
cdsSpiceVerilog.opts NSIG string "4"
cdsSpiceVerilog.opts TIMSAT string "0"
cdsSpiceVerilog.opts RELTOL string "1e-3"
cdsSpiceVerilog.opts MKS string "1"
cdsSpiceVerilog.opts ITL5 string "999999"
cdsSpiceVerilog.opts ARTSTR string "0"
cdsSpiceVerilog.opts GMINON string "2"
cdsSpiceVerilog.opts LVLTIM string "2"
cdsSpiceVerilog.opts VCESAT string "0.0"
cdsSpiceVerilog.opts ITL3 string "4"
cdsSpiceVerilog.opts SCALEM string "1"
cdsSpiceVerilog.opts GO2OFF string "0"
cdsSpiceVerilog.opts ITL4 string "25"
cdsSpiceVerilog.opts AVSTEP string ".33"
cdsSpiceVerilog.opts ITL1 string "100"
cdsSpiceVerilog.opts ITL2 string "100"
cdsSpiceVerilog.opts METHOD string "1"
cdsSpiceVerilog.opts CHGTOL string "1e-14"
cdsSpiceVerilog.opts TNOM string "25"
cdsSpiceVerilog.opts MORBKP string ".1"
cdsSpiceVerilog.opts ABSTOL string "1e-12"
cdsSpiceVerilog.opts UIC string "0"
cdsSpiceVerilog.opts GRTEXT string "1"
cdsSpiceVerilog.opts SINWAV string "1e+6"
cdsSpiceVerilog.opts PRNOTE string "1"
cdsSpiceVerilog.opts VLIMAX string "50000"
cdsSpiceVerilog.opts INTTIM string "0"
cdsSpiceVerilog.opts GSAVE string "0"
cdsSpiceVerilog.opts GMIN string "1e-12"
cdsSpiceVerilog.opts DCSAT string "0"
cdsSpiceVerilog.opts CNVREV string "2.4"
cdsSpiceVerilog.opts TINIT string ""
cdsSpiceVerilog.opts MFNOIS string "0"
cdsSpiceVerilog.opts QADLIN string "0"
cdsSpiceVerilog.opts VBESAT string "0.6"
cdsSpiceVerilog.opts PSFFLG string "1"
cdsSpiceVerilog.opts SCALE string "1"
cdsSpiceVerilog.opts TRTOL string "7"
cdsSpiceVerilog.opts SPICE2G string "0"
cdsSpiceVerilog.opts SPTEMP string "1"
cdsSpiceVerilog.opts WRFLAG string "0"
cdsSpiceVerilog.opts RON string "1"
cdsSpiceVerilog.opts NRAMP string "0"
cdsSpiceVerilog.opts NOWARN string "0"
cdsSpiceVerilog.opts VNTOL string "1e-6"
cdsSpiceVerilog.opts MAXORD string "2"
cdsSpiceVerilog.opts DCOPPT string "1"
cdsSpiceVerilog.opts VBCSAT string "0.15"
cdsSpiceVerilog.opts SPMESS string "1"
;cdsSpiceVerilog outputs partition variables
cdsSpiceVerilog.outputs allDigitalNV boolean t
cdsSpiceVerilog.outputs allAnalogNV boolean t
cdsSpiceVerilog.outputs allAnalogTC boolean nil
;cdsSpiceVerilog verimixOpts partition variables
cdsSpiceVerilog.verimixOpts filename6 string ""
cdsSpiceVerilog.verimixOpts maxDCIter int 0
cdsSpiceVerilog.verimixOpts scope1 string ""
cdsSpiceVerilog.verimixOpts scope10 string ""
cdsSpiceVerilog.verimixOpts filename8 string ""
cdsSpiceVerilog.verimixOpts dcInterval float 0.0
cdsSpiceVerilog.verimixOpts scope3 string ""
cdsSpiceVerilog.verimixOpts scope8 string ""
cdsSpiceVerilog.verimixOpts scope7 string ""
cdsSpiceVerilog.verimixOpts filename7 string ""
cdsSpiceVerilog.verimixOpts scope string ""
cdsSpiceVerilog.verimixOpts filename4 string ""
cdsSpiceVerilog.verimixOpts filename string ""
cdsSpiceVerilog.verimixOpts filename1 string ""
cdsSpiceVerilog.verimixOpts scope9 string ""
cdsSpiceVerilog.verimixOpts importsdfswitch boolean nil
cdsSpiceVerilog.verimixOpts filename2 string ""
cdsSpiceVerilog.verimixOpts numberofsdffiles int 2
cdsSpiceVerilog.verimixOpts scope2 string ""
cdsSpiceVerilog.verimixOpts scope6 string ""
cdsSpiceVerilog.verimixOpts filename10 string ""
cdsSpiceVerilog.verimixOpts delaymodechoice string "Ignore"
cdsSpiceVerilog.verimixOpts sdfmixedswitch boolean t
cdsSpiceVerilog.verimixOpts filename9 string ""
cdsSpiceVerilog.verimixOpts scope5 string ""
cdsSpiceVerilog.verimixOpts filename5 string ""
cdsSpiceVerilog.verimixOpts filename3 string ""
cdsSpiceVerilog.verimixOpts scope4 string ""
;cdsSpiceVerilog verilogOpts partition variables
cdsSpiceVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
cdsSpiceVerilog.verilogOpts optionsFile string ""
cdsSpiceVerilog.verilogOpts twinTurbo boolean nil
cdsSpiceVerilog.verilogOpts suppressMessages boolean nil
cdsSpiceVerilog.verilogOpts libraryFile string ""
cdsSpiceVerilog.verilogOpts behaveProfile boolean nil
cdsSpiceVerilog.verilogOpts verimixLog string "verilog.log"
cdsSpiceVerilog.verilogOpts simVision boolean nil
cdsSpiceVerilog.verilogOpts pulseSpec boolean nil
cdsSpiceVerilog.verilogOpts commandFile string ""
cdsSpiceVerilog.verilogOpts pulseError int 100
cdsSpiceVerilog.verilogOpts stopCompile boolean nil
cdsSpiceVerilog.verilogOpts keepNodes string "Minimum"
cdsSpiceVerilog.verilogOpts accelerationCA boolean nil
cdsSpiceVerilog.verilogOpts turboRadio string "Default"
cdsSpiceVerilog.verilogOpts libraryDir string ""
cdsSpiceVerilog.verilogOpts suppressWarnings boolean nil
cdsSpiceVerilog.verilogOpts accelerationSwitches boolean nil
cdsSpiceVerilog.verilogOpts accelerationNormal boolean t
cdsSpiceVerilog.verilogOpts delayType string "Typical"
cdsSpiceVerilog.verilogOpts pulseReject int 100
cdsSpiceVerilog.verilogOpts delayMode string "Default"
cdsSpiceVerilog.verilogOpts vermixBinary string "verilog.vmx"
;cdsSpiceVerilog init partition variables
cdsSpiceVerilog.init processPriority int 0
;cdsSpiceVerilog envOpts partition variables
cdsSpiceVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
cdsSpiceVerilog.envOpts mspNetlistMode string "Flat"
cdsSpiceVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistEscapeName boolean nil
cdsSpiceVerilog.envOpts updateFile string ""
cdsSpiceVerilog.envOpts stimulusFile string ""
cdsSpiceVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
cdsSpiceVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
cdsSpiceVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
cdsSpiceVerilog.envOpts includeSyntax string "cdsSpice"
cdsSpiceVerilog.envOpts mspSetupNetlistPinMap boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistBus boolean t
cdsSpiceVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
cdsSpiceVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
cdsSpiceVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
cdsSpiceVerilog.envOpts mspSetupNetlistExplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
cdsSpiceVerilog.envOpts initFile string ""
cdsSpiceVerilog.envOpts printComments boolean nil
cdsSpiceVerilog.envOpts includeFile string ""
cdsSpiceVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
cdsSpiceVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
cdsSpiceVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimTimeValue int 1
cdsSpiceVerilog.envOpts mspSetupNetlistUseLib boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistNullPort boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistDropPortRange boolean t
cdsSpiceVerilog.envOpts mspSetupNetlistUpCase boolean nil
cdsSpiceVerilog.envOpts generateMapFile boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;cdsSpiceVerilog dc partition variables
cdsSpiceVerilog.dc enable toggle (nil)
cdsSpiceVerilog.dc from string ""
cdsSpiceVerilog.dc to string ""
cdsSpiceVerilog.dc by string ""
cdsSpiceVerilog.dc device string ""
;cdsSpiceVerilog dcOpts partition variables
;cdsSpiceVerilog noise partition variables
cdsSpiceVerilog.noise enable toggle (nil)
cdsSpiceVerilog.noise source string ""
cdsSpiceVerilog.noise output string ""
cdsSpiceVerilog.noise listEvery string "1"
;cdsSpiceVerilog noiseOpts partition variables
;cdsSpiceVerilog ac partition variables
cdsSpiceVerilog.ac enable toggle (nil)
cdsSpiceVerilog.ac from string ""
cdsSpiceVerilog.ac to string ""
cdsSpiceVerilog.ac incrType string "Logarithmic"
cdsSpiceVerilog.ac lin string ""
cdsSpiceVerilog.ac log string ""
;cdsSpiceVerilog acOpts partition variables
;cdsSpiceVerilog tran partition variables
cdsSpiceVerilog.tran enable toggle (nil)
cdsSpiceVerilog.tran from string ""
cdsSpiceVerilog.tran to string ""
cdsSpiceVerilog.tran by string ""
cdsSpiceVerilog.tran delmax string ""
cdsSpiceVerilog.tran continue boolean nil
cdsSpiceVerilog.tran newParam boolean nil
;cdsSpiceVerilog tranOpts partition variables
; CMX CONSTRAINT MANAGER - ENVIRONMENT VARIABLES (FACTORY DEFAULTS)
; This tool registration file should not be edited since customization
; is done via the file in <cdshier>/samples/.cdsenv
;FACTORY DEFAULTS FOR NET-BASED SUPER CATEGORY (cmxNetBasedSuperCat)
;Net Class To Net Category (cmxClassToNetCat)
;default weight for constraints
cmx.cmxClassToNetCat defaultWeight int 200
;inter-layer clearance
cmx.cmxClassToNetCat defVal_ilc float 0.0
cmx.cmxClassToNetCat minVal_ilc float 0.0
cmx.cmxClassToNetCat maxVal_ilc float 0.0
;layer depth
cmx.cmxClassToNetCat defVal_depth int 0
cmx.cmxClassToNetCat minVal_depth int 0
cmx.cmxClassToNetCat maxVal_depth int 0
;Net-Class To Net-Class Category (cmxClassToClassCat)
cmx.cmxClassToClassCat defaultWeight int 200
cmx.cmxClassToClassCat defVal_ilc float 0.0
cmx.cmxClassToClassCat minVal_ilc float 0.0
cmx.cmxClassToClassCat maxVal_ilc float 0.0
;layer depth
cmx.cmxClassToClassCat defVal_depth int 0
cmx.cmxClassToClassCat minVal_depth int 0
cmx.cmxClassToClassCat maxVal_depth int 0
;Net To Net Category (cmxNetToNetCat)
cmx.cmxNetToNetCat defaultWeight int 200
cmx.cmxNetToNetCat defVal_ilc float 0.0
cmx.cmxNetToNetCat minVal_ilc float 0.0
cmx.cmxNetToNetCat maxVal_ilc float 0.0
;layer depth
cmx.cmxNetToNetCat defVal_depth int 0
cmx.cmxNetToNetCat minVal_depth int 0
cmx.cmxNetToNetCat maxVal_depth int 0
;differential pair gap
cmx.cmxNetToNetCat defVal_diffgap float 0.0
cmx.cmxNetToNetCat minVal_diffgap float 0.0
cmx.cmxNetToNetCat maxVal_diffgap float 0.0
;tandem shield overhang
cmx.cmxNetToNetCat defVal_tanhang float 0.0
cmx.cmxNetToNetCat minVal_tanhang float 0.0
cmx.cmxNetToNetCat maxVal_tanhang float 0.0
;parallel shield gap
cmx.cmxNetToNetCat defVal_pargap float 0.0
cmx.cmxNetToNetCat minVal_pargap float 0.0
cmx.cmxNetToNetCat maxVal_pargap float 0.0
;parallel shield width
cmx.cmxNetToNetCat defVal_parwidth float 0.0
cmx.cmxNetToNetCat minVal_parwidth float 0.0
cmx.cmxNetToNetCat maxVal_parwidth float 0.0
;Net/Net-Class Category (cmxNetCat)
cmx.cmxNetCat defaultWeight int 200
;net priority
cmx.cmxNetCat defVal_pri int 0
cmx.cmxNetCat minVal_pri int 0
cmx.cmxNetCat maxVal_pri int 255
;net width
cmx.cmxNetCat defVal_width float 0.0
cmx.cmxNetCat minVal_width float 0.0
cmx.cmxNetCat maxVal_width float 0.0
;minimum IR drop
cmx.cmxNetCat defVal_minird float 0.0
cmx.cmxNetCat minVal_minird float 0.0
cmx.cmxNetCat maxVal_minird float 0.0
;maximum IR drop
cmx.cmxNetCat defVal_maxird float 0.0
cmx.cmxNetCat minVal_maxird float 0.0
cmx.cmxNetCat maxVal_maxird float 0.0
;FACTORY DEFAULTS FOR GEOMETRIC SUPER CATEGORY (cmxGeometricSuperCat)
;Symmetry Category (cmxSymCat)
cmx.cmxSymCat defaultWeight int 200
;axis name
cmx.cmxSymCat defVal_axis string ""
;Grouping Category (cmxGroupingCat)
cmx.cmxGroupingCat defaultWeight int 200
;preserve relative position
cmx.cmxGroupingCat defVal_prPos boolean t
;no fence needed
cmx.cmxGroupingCat defVal_noFence boolean t
;fence shape name
cmx.cmxGroupingCat defVal_fence string ""
;exclude all
cmx.cmxGroupingCat defVal_exclAll boolean nil
;Alignment Category (cmxAlignCat)
cmx.cmxAlignCat defaultWeight int 200
;orientation
cmx.cmxAlignCat defVal_orient string "NO_CARE"
;alignment reference
cmx.cmxAlignCat defVal_alignRef string "NO_CARE"
;reference segment
cmx.cmxAlignCat defVal_segment int 0
;inner or outer edge
cmx.cmxAlignCat defVal_inner boolean t
;alignment layer
cmx.cmxAlignCat defVal_alignLayer string "bBox"
;check ordering
cmx.cmxAlignCat defVal_order boolean t
;compactor direction (for Compactor only)
cmx.cmxAlignCat defVal_compactDir boolean nil
;Fixed Category (cmxFixedCat)
cmx.cmxFixedCat defaultWeight int 200
;check x position
cmx.cmxFixedCat defVal_x boolean t
;default x value
cmx.cmxFixedCat defVal_xVal float 0.0
;check y position
cmx.cmxFixedCat defVal_y boolean t
;default y value
cmx.cmxFixedCat defVal_yVal float 0.0
;default orientation
cmx.cmxFixedCat defVal_orient string "AS_IS"
;default reference
cmx.cmxFixedCat defVal_refer string "CENTER"
;default user movable
cmx.cmxFixedCat defVal_userMovable boolean nil
;Distance Category (cmxDistCat)
cmx.cmxDistCat defaultWeight int 200
;check minimum manhattan x distance
cmx.cmxDistCat defVal_minX boolean t
;minimum manhattan x distance value
cmx.cmxDistCat defVal_minXVal float 0.0
;check maximum manhattan x distance
cmx.cmxDistCat defVal_maxX boolean t
;maximum manhattan x distance value
cmx.cmxDistCat defVal_maxXVal float 0.0
;check minimum manhattan y distance
cmx.cmxDistCat defVal_minY boolean t
;minimum manhattan y distance value
cmx.cmxDistCat defVal_minYVal float 0.0
;check maximum manhattan y distance
cmx.cmxDistCat defVal_maxY boolean t
;maximum manhattan y distance
cmx.cmxDistCat defVal_maxYVal float 0.0
;reference for measurement on x-axis
cmx.cmxDistCat defVal_referX string "CENTER"
;reference for measurement on y-axis
cmx.cmxDistCat defVal_referY string "CENTER"
;ROD Alignment Category (cmxRodAlignCat)
;default name for ROD object 1
;default handle name for ROD object 1
;default name for ROD object 2
;default handle name for ROD object 2
compactor hilite1LPP string "hilite drawing"
compactor hilite2LPP string "marker error"
compactor hilite3LPP string "hilite drawing1"
compactor hilite4LPP string "hilite drawing2"
compactor cpCpathLPP string "annotate drawing7"
compactor cpAuxLPP string "annotate drawing8"
compactor cpOutlineLPP string "annotate drawing9"
compactor useDBox boolean t
compactor arrowScale float 1.0
compactor zoomScale float 1.2
compactor checkSaved boolean t
conn2sch src_sch_lib string ""
conn2sch src_cell_name string ""
conn2sch src_view_name string ""
conn2sch dest_sch_lib string ""
conn2sch dest_view_name string "schematic"
conn2sch dest_cell_name string ""
conn2sch dest_symbol_view_name string "symbol"
conn2sch ref_lib_list string "analogLib basic sample"
conn2sch log_file_name string "./conn2sch.log"
conn2sch import_if_exists int 0
conn2sch sheet_symbol string "none "
conn2sch line_line_spacing float 0.2
conn2sch line_component_spacing float 0.5
conn2sch density_level int 0
conn2sch label_height int 10
conn2sch pin_placement string "left_and_right_sides"
conn2sch page_col_limit int 1024
conn2sch page_row_limit int 1024
conn2sch full_place_and_route boolean t
conn2sch optimize_wire_label_locn boolean nil
conn2sch minimize_crossovers boolean nil
conn2sch generate_square_schematic boolean t
conn2sch extract_schematic boolean t
conn2sch verbose boolean nil
;Digital Ciruit Design Flow Environment Defaults
;Session Options
dcdf dcdfNoDirectNetlister boolean nil
dcdf dcdfDefaultFileDir string ""
; ddserv Environment Variables
ddserv.browser onOpen boolean nil
ddserv.browser onOther boolean nil
ddserv.browser onPlace boolean nil
ddserv.ciw promptOnExit boolean t
ddserv.he objectFilter string "same"
ddserv.he objectScope string "current instance"
ddserv.lib dmChoice string "No DM"
ddserv.lib enableCopyInDFII boolean nil
ddserv.lib newLibDir string ""
ddserv.lib techChoice cyclic "compile"
ddserv showWhatsNew string "yes"
; Graphics Editor and Design Editor Environment Variables
; Installation-wide customizations should be made to the
; to the .cdsenv file in $CDS_INST_DIR/tools/dfII/samples
; directory. Make user-specific customizations to the
; .cdsenv file in your home directory.
graphic accessEdgesOn boolean nil
graphic arrayDisplay string "Full"
graphic askSaveOnReturn boolean t
graphic coalesceLimit int 10
graphic coalesceRatio int 10
graphic defaultNewCellName string ""
graphic defaultNewLibName string ""
graphic defaultNewViewName string ""
graphic defaultOpenCellName string ""
graphic defaultOpenLibName string ""
graphic defaultOpenViewName string ""
graphic defaultToolName string ""
graphic displayPinNames boolean t
graphic displayStretchHandles boolean t
graphic displaySchDashText boolean nil
graphic dotsOn boolean t
graphic drawAxesOn boolean t
graphic drawDottedGridOn boolean t
graphic drawGridOn boolean t
graphic drawInstancePins boolean t
graphic drawPRBoundary boolean nil
graphic drawSurroundingOn boolean t
graphic drfPath string ""
graphic dynamicHilightOn boolean t
graphic eipRedraw boolean t
graphic filterSize float 1.0
graphic filterSizeDrawingStyle string "filled"
graphic gridMultiple int 5
graphic gridSpacing float 1.0
graphic iconsOn boolean t
graphic instLabel string "master"
graphic iterNum int 500
graphic jumpersOn boolean t
graphic leCheckMissingLayers boolean nil
graphic leCheckMissingMasters boolean nil
graphic leDispNetExpr boolean t
graphic markerZoom boolean nil
graphic markerShowIgnore boolean t
graphic markerSeverity string "all"
graphic markerZoomScale int 4
graphic maxDragFig int 500
graphic minLabelSize float 1.0
graphic minRefreshArea int 500
graphic minStippleSize float 1.0
graphic netsOn boolean t
graphic originMarkersOn boolean t
graphic outlineOnly boolean t
graphic packetDialogBoxes boolean t
graphic partialSelect boolean t
graphic pathCL string "yes"
graphic netExprDisplay string "expression only"
graphic pathWidth float 5.0
graphic probeTextOn boolean t
graphic pruneSize float 10
graphic segSnapMode string "anyAngle"
graphic selectionAperture int 5
graphic snapMode string "anyAngle"
graphic snapToGrid boolean t
graphic startLevel int 0
graphic stopLevel int 0
graphic stretchHandlesLayer string "y0 drawing"
graphic textJustificationOn boolean t
graphic tinyInstDetail boolean nil
graphic transformMarkersOn boolean t
graphic useTrueBBox boolean t
graphic viewNameList string ""
graphic viewNameToTypeList string ""
graphic xSnapSpacing float 1.0
graphic ySnapSpacing float 1.0
graphic cursorShape boolean nil
graphic drawEngine int 0
graphic openToStopLevel boolean nil
graphic displayViaShapes boolean nil
;hspiceD environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;hspiceD opts partition variables
hspiceD.opts PARHIER string "LOCAL"
hspiceD.opts GENK boolean nil
hspiceD.opts RISETIME string "0"
hspiceD.opts RELQ string "1e-2"
hspiceD.opts FFTOUT boolean nil
hspiceD.opts LVLTIM string "DVDT (1)"
hspiceD.opts ARTIST string "On (2)"
hspiceD.opts NEWTOL boolean nil
hspiceD.opts ABSMOS string "1e-6"
hspiceD.opts DIAGNOSTIC boolean nil
hspiceD.opts MODMONTE boolean nil
hspiceD.opts VFLOOR string "0"
hspiceD.opts FS string "25e-2"
hspiceD.opts CO string "Narrow (80)"
hspiceD.opts DEFAS string "0"
hspiceD.opts RESMIN string "1e-5"
hspiceD.opts WARNLIMIT string "1"
hspiceD.opts TRCON string "On (1)"
hspiceD.opts PSF string "ASCII (2)"
hspiceD.opts BRIEF boolean nil
hspiceD.opts ICSWEEP boolean nil
hspiceD.opts DCFOR string "0"
hspiceD.opts DCHOLD string "1"
hspiceD.opts GMIN string "1e-12"
hspiceD.opts INGOLD string "SPICE (2)"
hspiceD.opts NODE boolean nil
hspiceD.opts DCSTEP string "0"
hspiceD.opts ZUKEN string "Off (1)"
hspiceD.opts TRTOL string "7"
hspiceD.opts BYTOL string "5e-5"
hspiceD.opts AUTOSTOP boolean nil
hspiceD.opts LIMTIM string "2.0"
hspiceD.opts EXPMAX string "8e+1"
hspiceD.opts DVDT string "Balance (3)"
hspiceD.opts PUTMEAS boolean nil
hspiceD.opts NOWARN boolean nil
hspiceD.opts MONTECON boolean nil
hspiceD.opts BEEP string "Off (0)"
hspiceD.opts MEASSORT boolean nil
hspiceD.opts NUMDGT string "4"
hspiceD.opts ITL5 string "0"
hspiceD.opts BADCHR boolean nil
hspiceD.opts PIVTOL string "1e-15"
hspiceD.opts METHOD string "TRAP"
hspiceD.opts LIMPTS string "2001"
hspiceD.opts CHGTOL string "1e-15"
hspiceD.opts GSHUNT string "0"
hspiceD.opts DVTR string "1e+3"
hspiceD.opts DI string "0"
hspiceD.opts HIER_SCALE string "None ()"
hspiceD.opts CSHDC string "1e-12"
hspiceD.opts RELI string "1e-2"
hspiceD.opts PATHNUM boolean nil
hspiceD.opts DEFW string "1e-4"
hspiceD.opts POST_VERSION string "2001"
hspiceD.opts DCON string "Auto (0)"
hspiceD.opts DEFL string "1e-4"
hspiceD.opts DEFNRS string "0"
hspiceD.opts ABSV string "5e-5"
hspiceD.opts CONVERGE string "Autoconvergance (0)"
hspiceD.opts NOPIV boolean nil
hspiceD.opts LENNAM string "8"
hspiceD.opts DCAP string "2"
hspiceD.opts DLENCSDF string "5"
hspiceD.opts ITLPZ string "100"
hspiceD.opts MBYPASS string "1"
hspiceD.opts GMINDC string "1e-12"
hspiceD.opts RELV string "1e-3"
hspiceD.opts GRAMP string "0"
hspiceD.opts ASPEC boolean nil
hspiceD.opts DV string "1e+3"
hspiceD.opts SEED string "259200"
hspiceD.opts RMIN string "1e-9"
hspiceD.opts RELVDC string "1e-3"
hspiceD.opts ACCT string "Enabled (1)"
hspiceD.opts RELMOS string "5e-2"
hspiceD.opts TEMPDC string "25"
hspiceD.opts ACCURATE boolean nil
hspiceD.opts CSDF boolean nil
hspiceD.opts SEARCH boolean nil
hspiceD.opts MAXAMP string "0"
hspiceD.opts NOMOD boolean nil
hspiceD.opts PIVREF string "1e8"
hspiceD.opts NOPAGE boolean nil
hspiceD.opts ALT9999 boolean nil
hspiceD.opts CAPTAB boolean nil
hspiceD.opts ITL1 string "2e+2"
hspiceD.opts ITL2 string "5e+1"
hspiceD.opts POST string "Binary (1)"
hspiceD.opts PIVREL string "1e-20"
hspiceD.opts ALT999 boolean nil
hspiceD.opts MEASFAIL boolean nil
hspiceD.opts STATFL string "Create .st0 (0)"
hspiceD.opts BKPSIZ string "5000"
hspiceD.opts ABSVAR string ".5"
hspiceD.opts ITRPRT boolean nil
hspiceD.opts SPICE boolean nil
hspiceD.opts GMAX string "1e+2"
hspiceD.opts RMAX string "2"
hspiceD.opts OFF boolean nil
hspiceD.opts BYPASS string "1"
hspiceD.opts OPTS boolean nil
hspiceD.opts IMIN string "3"
hspiceD.opts KCLTEST boolean nil
hspiceD.opts CDS string "Off (0)"
hspiceD.opts RELH string "5e-2"
hspiceD.opts ALTCHK string "On (1)"
hspiceD.opts ACOUT string "Star-Hspice Method (1)"
hspiceD.opts FT string "25e-2"
hspiceD.opts WL boolean nil
hspiceD.opts LIST boolean nil
hspiceD.opts RELVAR string ".30"
hspiceD.opts MAXORD string "Normal (2)"
hspiceD.opts DEFPS string "0"
hspiceD.opts MEASOUT boolean nil
hspiceD.opts FAST boolean nil
hspiceD.opts CPTIME string "1e+7"
hspiceD.opts IMAX string "8"
hspiceD.opts DEFNRD string "0"
hspiceD.opts OPTLST string "No Info (0)"
hspiceD.opts ABSVDC string "5e-5"
hspiceD.opts INTERP boolean nil
hspiceD.opts PROBE boolean nil
hspiceD.opts DCCAP boolean nil
hspiceD.opts DEFAD string "0"
hspiceD.opts TIMERES string "1e-15"
hspiceD.opts SCALM string "1"
hspiceD.opts TNOM string "25"
hspiceD.opts POSTTOP string "0"
hspiceD.opts MODSRH boolean nil
hspiceD.opts KLIM string "1e-2"
hspiceD.opts H9007 boolean nil
hspiceD.opts UNWRAP boolean nil
hspiceD.opts CVTOL string ".2"
hspiceD.opts PLIM string "SPICE (1)"
hspiceD.opts MENTOR string "Off (0)"
hspiceD.opts MEASDGT string "4"
hspiceD.opts NOTOP boolean nil
hspiceD.opts MU string ".5"
hspiceD.opts DEFPD string "0"
hspiceD.opts SLOPETOL string ".5"
hspiceD.opts SCALE string "1"
hspiceD.opts CSHUNT string "0"
hspiceD.opts EPSMIN string "1e-28"
hspiceD.opts EXPLI string "0"
hspiceD.opts NOELCK boolean nil
hspiceD.opts ABSI string "1e-9"
hspiceD.opts BINPRINT boolean nil
hspiceD.opts PIVOT string "Fast, non-pivoting (10)"
hspiceD.opts ITLPTRAN string "30"
hspiceD.opts PURETP boolean nil
hspiceD.opts ABSH string "0"
;hspiceD outputs partition variables
hspiceD.outputs allAnalogNV boolean t
hspiceD.outputs allAnalogTC boolean nil
;hspiceD envOpts partition variables
hspiceD.envOpts autoDisplay boolean t
hspiceD.envOpts stopViewList string "hspiceD spice"
hspiceD.envOpts printComments boolean nil
hspiceD.envOpts switchViewList string "hspiceD spice cmos_sch cmos.sch schematic"
;hspiceD init partition variables
hspiceD.init processPriority int 0
;hspiceD ac partition variables
hspiceD.ac enable toggle (nil)
hspiceD.ac sweepType string "decade"
hspiceD.ac numPoints string "10"
hspiceD.ac fstart string ""
hspiceD.ac fstop string ""
hspiceD.ac points string ""
;hspiceD acOpts partition variables
;hspiceD dc partition variables
hspiceD.dc enable toggle (nil)
hspiceD.dc sweep string "Source"
hspiceD.dc designVar string ""
hspiceD.dc source string ""
hspiceD.dc sweepType string "Automatic"
hspiceD.dc start string ""
hspiceD.dc stop string ""
hspiceD.dc stepSize string ""
hspiceD.dc numPoints string ""
hspiceD.dc poiNumPoints string ""
hspiceD.dc points string ""
;hspiceD dcOpts partition variables
;hspiceD noise partition variables
hspiceD.noise enable toggle (nil)
hspiceD.noise node string ""
hspiceD.noise insrc string ""
hspiceD.noise nums string "0"
;hspiceD noiseOpts partition variables
;hspiceD op partition variables
hspiceD.op enable toggle (nil)
hspiceD.op format string "all"
hspiceD.op time string ""
;hspiceD opOpts partition variables
;hspiceD tran partition variables
hspiceD.tran enable toggle (nil)
hspiceD.tran start string ""
hspiceD.tran stop string ""
hspiceD.tran step string ""
hspiceD.tran uic boolean nil
;hspiceD tranOpts partition variables
;hspiceS environment variables
;hspiceS opts partition variables
hspiceS.opts PARHIER string "GLOBAL"
hspiceS.opts GENK string "1"
hspiceS.opts RELQ string "1e-2"
hspiceS.opts LVLTIM string "default ( 1 )"
hspiceS.opts BKPSZE string "5000"
hspiceS.opts ARTIST string "artistdefault ( 2 )"
hspiceS.opts ABSMOS string "1e-6"
hspiceS.opts NEWTOL string "off"
hspiceS.opts RMAXDC string "1e+2"
hspiceS.opts DIAGNOSTIC string "off"
hspiceS.opts VFLOOR string "0"
hspiceS.opts FS string "25e-2"
hspiceS.opts CO string "78"
hspiceS.opts DEFAS string "0"
hspiceS.opts UIC string "off"
hspiceS.opts RESMIN string "1e-5"
hspiceS.opts WARNLIMIT string "1"
hspiceS.opts PSF string "artistdefault ( 2 )"
hspiceS.opts BRIEF string "off"
hspiceS.opts ICSWEEP string "default ( 1 )"
hspiceS.opts DCFOR string "0"
hspiceS.opts DCHOLD string "1"
hspiceS.opts GMIN string "1e-12"
hspiceS.opts INGOLD string "artistdefault ( 2 )"
hspiceS.opts DCSTEP string "0"
hspiceS.opts NODE string "off"
hspiceS.opts TRTOL string "7"
hspiceS.opts LIMTIM string "2.0"
hspiceS.opts EXPMAX string "8e+1"
hspiceS.opts DVDT string "default ( 3 )"
hspiceS.opts NOWARN string "off"
hspiceS.opts ITL5 string "0"
hspiceS.opts NUMDGT string "default ( 4 )"
hspiceS.opts BADCHR string "off"
hspiceS.opts PIVTOL string "1e-15"
hspiceS.opts LIMPTS string "2001"
hspiceS.opts METHOD string "TRAP"
hspiceS.opts CHGTOL string "1e-15"
hspiceS.opts GSHUNT string "0"
hspiceS.opts DVTR string "1e+3"
hspiceS.opts DI string "1e+2"
hspiceS.opts CSHDC string "1e-12"
hspiceS.opts RELI string "1e-2"
hspiceS.opts PATHNUM string "off"
hspiceS.opts DEFW string "1e-4"
hspiceS.opts DCON string "default ( 0 )"
hspiceS.opts DEFL string "1e-4"
hspiceS.opts DEFNRS string "0"
hspiceS.opts TIMRES string "1E-12"
hspiceS.opts CONVERGE string "default ( 1 )"
hspiceS.opts ABSV string "5e-5"
hspiceS.opts LENNAM string "8"
hspiceS.opts NOPIV string "off"
hspiceS.opts DCAP string "default ( 2 )"
hspiceS.opts GMINDC string "1e-12"
hspiceS.opts RELV string "1e-3"
hspiceS.opts GRAMP string "0"
hspiceS.opts ASPEC string "off"
hspiceS.opts DV string "1e+3"
hspiceS.opts RMIN string "1e-9"
hspiceS.opts RELVDC string "1e-3"
hspiceS.opts ACCT string "default ( 1 )"
hspiceS.opts SPMESS string "default ( 1 )"
hspiceS.opts RELMOS string "5e-2"
hspiceS.opts TEMPDC string "25"
hspiceS.opts CSDF string "off"
hspiceS.opts ACCURA string "off"
hspiceS.opts MAXAMP string "0"
hspiceS.opts NOMOD string "off"
hspiceS.opts PIVREF string "1e8"
hspiceS.opts NOPAGE string "off"
hspiceS.opts CAPTAB string "off"
hspiceS.opts ITL1 string "2e+2"
hspiceS.opts ITL2 string "5e+1"
hspiceS.opts POST string "default ( 0 )"
hspiceS.opts PIVREL string "1e-4"
hspiceS.opts ABSVAR string ".5"
hspiceS.opts ITRPRT string "off"
hspiceS.opts SPICE string "off"
hspiceS.opts GMAX string "1e+2"
hspiceS.opts RMAX string "2"
hspiceS.opts BYPASS string "default ( 0 )"
hspiceS.opts OFF string "0"
hspiceS.opts IMIN string "3"
hspiceS.opts KCLTEST string "off"
hspiceS.opts OPTS string "off"
hspiceS.opts RELH string "5e-2"
hspiceS.opts ACOUT string "default ( 1 )"
hspiceS.opts FT string "25e-2"
hspiceS.opts WL string "default ( 0 )"
hspiceS.opts LIST string "on"
hspiceS.opts RELVAR string ".30"
hspiceS.opts DCOPPT string "1"
hspiceS.opts MAXORD string "default ( 2 )"
hspiceS.opts DEFPS string "0"
hspiceS.opts MEASOUT string "on"
hspiceS.opts FAST string "off"
hspiceS.opts CPTIME string "1e+7"
hspiceS.opts IMAX string "8"
hspiceS.opts DEFNRD string "0"
hspiceS.opts OPTLST string "default ( 0 )"
hspiceS.opts ABSVDC string "5e-5"
hspiceS.opts INTERP string "0"
hspiceS.opts DCCAP string "off"
hspiceS.opts DEFAD string "0"
hspiceS.opts SCALM string "1"
hspiceS.opts TNOM string "25"
hspiceS.opts DOIRSCAL string "0"
hspiceS.opts KLIM string "1e-2"
hspiceS.opts AUTOST string "off"
hspiceS.opts H9007 string "off"
hspiceS.opts UNWRAP string "off"
hspiceS.opts CVTOL string ".2"
hspiceS.opts PLIM string "default ( 1 )"
hspiceS.opts K2LIM string "0"
hspiceS.opts MBYPAS string "1"
hspiceS.opts MEASDGT string "default ( 4 )"
hspiceS.opts DEFPD string "0"
hspiceS.opts MU string ".5"
hspiceS.opts NOTOP string "off"
hspiceS.opts SCALE string "1"
hspiceS.opts CSHUNT string "0"
hspiceS.opts EPSMIN string "1e-28"
hspiceS.opts SDA string "default ( 0 )"
hspiceS.opts ABSI string "1e-9"
hspiceS.opts NOELCK string "off"
hspiceS.opts PIVOT string "default ( 10 )"
hspiceS.opts ABSH string "0"
;hspiceS outputs partition variables
hspiceS.outputs allAnalogNV boolean t
;hspiceS envOpts partition variables
hspiceS.envOpts updateFile string ""
hspiceS.envOpts stimulusFile string ""
hspiceS.envOpts instViewListTable string ""
hspiceS.envOpts doInstBased boolean nil
hspiceS.envOpts stopViewList string "hspiceS spice"
hspiceS.envOpts reNetlist boolean nil
hspiceS.envOpts includeSyntax string "cdsSpice"
hspiceS.envOpts initFile string ""
hspiceS.envOpts printComments boolean nil
hspiceS.envOpts netlistType string "hierarchical"
hspiceS.envOpts generateMapFile boolean nil
hspiceS.envOpts includeFile string ""
hspiceS.envOpts instStopListTable string ""
hspiceS.envOpts switchViewList string "hspiceS spice cmos_sch cmos.sch schematic"
;hspiceS init partition variables
hspiceS.init processPriority int 0
;hspiceS dc partition variables
hspiceS.dc enable toggle (nil)
hspiceS.dc from string ""
hspiceS.dc to string ""
hspiceS.dc by string ""
hspiceS.dc device string ""
;hspiceS dcOpts partition variables
;hspiceS noise partition variables
hspiceS.noise enable toggle (nil)
hspiceS.noise source string ""
hspiceS.noise output string ""
hspiceS.noise listEvery string "1"
;hspiceS noiseOpts partition variables
;hspiceS ac partition variables
hspiceS.ac enable toggle (nil)
hspiceS.ac from string ""
hspiceS.ac to string ""
hspiceS.ac incrType string "Logarithmic"
hspiceS.ac lin string ""
hspiceS.ac log string ""
;hspiceS acOpts partition variables
;hspiceS tran partition variables
hspiceS.tran enable toggle (nil)
hspiceS.tran from string ""
hspiceS.tran to string ""
hspiceS.tran by string ""
hspiceS.tran delmax string ""
;hspiceS tranOpts partition variables
;hspiceSVerilog environment variables
;hspiceSVerilog opts partition variables
hspiceSVerilog.opts GENK string "1"
hspiceSVerilog.opts PARHIER string "GLOBAL"
hspiceSVerilog.opts RELQ string "1e-2"
hspiceSVerilog.opts LVLTIM string "default ( 1 )"
hspiceSVerilog.opts ARTIST string "artistdefault ( 2 )"
hspiceSVerilog.opts BKPSZE string "5000"
hspiceSVerilog.opts NEWTOL string "off"
hspiceSVerilog.opts ABSMOS string "1e-6"
hspiceSVerilog.opts RMAXDC string "1e+2"
hspiceSVerilog.opts DIAGNOSTIC string "off"
hspiceSVerilog.opts VFLOOR string "0"
hspiceSVerilog.opts FS string "25e-2"
hspiceSVerilog.opts CO string "78"
hspiceSVerilog.opts DEFAS string "0"
hspiceSVerilog.opts RESMIN string "1e-5"
hspiceSVerilog.opts UIC string "off"
hspiceSVerilog.opts PSF string "artistdefault ( 2 )"
hspiceSVerilog.opts WARNLIMIT string "1"
hspiceSVerilog.opts ICSWEEP string "default ( 1 )"
hspiceSVerilog.opts BRIEF string "off"
hspiceSVerilog.opts DCFOR string "0"
hspiceSVerilog.opts GMIN string "1e-12"
hspiceSVerilog.opts DCHOLD string "1"
hspiceSVerilog.opts INGOLD string "artistdefault ( 2 )"
hspiceSVerilog.opts DCSTEP string "0"
hspiceSVerilog.opts NODE string "off"
hspiceSVerilog.opts TRTOL string "7"
hspiceSVerilog.opts LIMTIM string "2.0"
hspiceSVerilog.opts EXPMAX string "8e+1"
hspiceSVerilog.opts DVDT string "default ( 3 )"
hspiceSVerilog.opts NOWARN string "off"
hspiceSVerilog.opts ITL5 string "0"
hspiceSVerilog.opts NUMDGT string "default ( 4 )"
hspiceSVerilog.opts BADCHR string "off"
hspiceSVerilog.opts PIVTOL string "1e-15"
hspiceSVerilog.opts LIMPTS string "2001"
hspiceSVerilog.opts METHOD string "TRAP"
hspiceSVerilog.opts CHGTOL string "1e-15"
hspiceSVerilog.opts GSHUNT string "0"
hspiceSVerilog.opts DVTR string "1e+3"
hspiceSVerilog.opts DI string "1e+2"
hspiceSVerilog.opts CSHDC string "1e-12"
hspiceSVerilog.opts RELI string "1e-2"
hspiceSVerilog.opts PATHNUM string "off"
hspiceSVerilog.opts DEFW string "1e-4"
hspiceSVerilog.opts DCON string "default ( 0 )"
hspiceSVerilog.opts DEFL string "1e-4"
hspiceSVerilog.opts DEFNRS string "0"
hspiceSVerilog.opts TIMRES string "1E-12"
hspiceSVerilog.opts CONVERGE string "default ( 1 )"
hspiceSVerilog.opts ABSV string "5e-5"
hspiceSVerilog.opts LENNAM string "8"
hspiceSVerilog.opts NOPIV string "off"
hspiceSVerilog.opts DCAP string "default ( 2 )"
hspiceSVerilog.opts GMINDC string "1e-12"
hspiceSVerilog.opts RELV string "1e-3"
hspiceSVerilog.opts GRAMP string "0"
hspiceSVerilog.opts ASPEC string "off"
hspiceSVerilog.opts DV string "1e+3"
hspiceSVerilog.opts RMIN string "1e-9"
hspiceSVerilog.opts RELVDC string "1e-3"
hspiceSVerilog.opts ACCT string "default ( 1 )"
hspiceSVerilog.opts SPMESS string "default ( 1 )"
hspiceSVerilog.opts RELMOS string "5e-2"
hspiceSVerilog.opts TEMPDC string "25"
hspiceSVerilog.opts CSDF string "off"
hspiceSVerilog.opts ACCURA string "off"
hspiceSVerilog.opts MAXAMP string "0"
hspiceSVerilog.opts NOMOD string "off"
hspiceSVerilog.opts PIVREF string "1e8"
hspiceSVerilog.opts NOPAGE string "off"
hspiceSVerilog.opts CAPTAB string "off"
hspiceSVerilog.opts ITL1 string "2e+2"
hspiceSVerilog.opts ITL2 string "5e+1"
hspiceSVerilog.opts POST string "default ( 0 )"
hspiceSVerilog.opts PIVREL string "1e-4"
hspiceSVerilog.opts ABSVAR string ".5"
hspiceSVerilog.opts ITRPRT string "off"
hspiceSVerilog.opts SPICE string "off"
hspiceSVerilog.opts GMAX string "1e+2"
hspiceSVerilog.opts RMAX string "2"
hspiceSVerilog.opts BYPASS string "default ( 0 )"
hspiceSVerilog.opts OFF string "0"
hspiceSVerilog.opts IMIN string "3"
hspiceSVerilog.opts KCLTEST string "off"
hspiceSVerilog.opts OPTS string "off"
hspiceSVerilog.opts ACOUT string "default ( 1 )"
hspiceSVerilog.opts RELH string "5e-2"
hspiceSVerilog.opts FT string "25e-2"
hspiceSVerilog.opts LIST string "on"
hspiceSVerilog.opts WL string "default ( 0 )"
hspiceSVerilog.opts RELVAR string ".30"
hspiceSVerilog.opts MAXORD string "default ( 2 )"
hspiceSVerilog.opts DCOPPT string "1"
hspiceSVerilog.opts MEASOUT string "on"
hspiceSVerilog.opts DEFPS string "0"
hspiceSVerilog.opts FAST string "off"
hspiceSVerilog.opts IMAX string "8"
hspiceSVerilog.opts CPTIME string "1e+7"
hspiceSVerilog.opts DEFNRD string "0"
hspiceSVerilog.opts OPTLST string "default ( 0 )"
hspiceSVerilog.opts INTERP string "0"
hspiceSVerilog.opts ABSVDC string "5e-5"
hspiceSVerilog.opts DEFAD string "0"
hspiceSVerilog.opts DCCAP string "off"
hspiceSVerilog.opts SCALM string "1"
hspiceSVerilog.opts DOIRSCAL string "0"
hspiceSVerilog.opts TNOM string "25"
hspiceSVerilog.opts KLIM string "1e-2"
hspiceSVerilog.opts H9007 string "off"
hspiceSVerilog.opts AUTOST string "off"
hspiceSVerilog.opts CVTOL string ".2"
hspiceSVerilog.opts UNWRAP string "off"
hspiceSVerilog.opts K2LIM string "0"
hspiceSVerilog.opts PLIM string "default ( 1 )"
hspiceSVerilog.opts MEASDGT string "default ( 4 )"
hspiceSVerilog.opts MBYPAS string "1"
hspiceSVerilog.opts NOTOP string "off"
hspiceSVerilog.opts MU string ".5"
hspiceSVerilog.opts DEFPD string "0"
hspiceSVerilog.opts EPSMIN string "1e-28"
hspiceSVerilog.opts CSHUNT string "0"
hspiceSVerilog.opts SCALE string "1"
hspiceSVerilog.opts NOELCK string "off"
hspiceSVerilog.opts ABSI string "1e-9"
hspiceSVerilog.opts SDA string "default ( 0 )"
hspiceSVerilog.opts PIVOT string "default ( 10 )"
hspiceSVerilog.opts ABSH string "0"
;hspiceSVerilog outputs partition variables
hspiceSVerilog.outputs allDigitalNV boolean t
hspiceSVerilog.outputs allAnalogNV boolean t
;hspiceSVerilog verimixOpts partition variables
hspiceSVerilog.verimixOpts filename6 string ""
hspiceSVerilog.verimixOpts maxDCIter int 0
hspiceSVerilog.verimixOpts scope1 string ""
hspiceSVerilog.verimixOpts scope10 string ""
hspiceSVerilog.verimixOpts filename8 string ""
hspiceSVerilog.verimixOpts dcInterval float 0.0
hspiceSVerilog.verimixOpts scope3 string ""
hspiceSVerilog.verimixOpts scope8 string ""
hspiceSVerilog.verimixOpts scope7 string ""
hspiceSVerilog.verimixOpts filename7 string ""
hspiceSVerilog.verimixOpts scope string ""
hspiceSVerilog.verimixOpts filename4 string ""
hspiceSVerilog.verimixOpts filename string ""
hspiceSVerilog.verimixOpts filename1 string ""
hspiceSVerilog.verimixOpts scope9 string ""
hspiceSVerilog.verimixOpts importsdfswitch boolean nil
hspiceSVerilog.verimixOpts filename2 string ""
hspiceSVerilog.verimixOpts numberofsdffiles int 2
hspiceSVerilog.verimixOpts scope2 string ""
hspiceSVerilog.verimixOpts scope6 string ""
hspiceSVerilog.verimixOpts filename10 string ""
hspiceSVerilog.verimixOpts delaymodechoice string "Ignore"
hspiceSVerilog.verimixOpts sdfmixedswitch boolean t
hspiceSVerilog.verimixOpts filename9 string ""
hspiceSVerilog.verimixOpts scope5 string ""
hspiceSVerilog.verimixOpts filename5 string ""
hspiceSVerilog.verimixOpts filename3 string ""
hspiceSVerilog.verimixOpts scope4 string ""
;hspiceSVerilog verilogOpts partition variables
hspiceSVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
hspiceSVerilog.verilogOpts optionsFile string ""
hspiceSVerilog.verilogOpts twinTurbo boolean nil
hspiceSVerilog.verilogOpts suppressMessages boolean nil
hspiceSVerilog.verilogOpts libraryFile string ""
hspiceSVerilog.verilogOpts behaveProfile boolean nil
hspiceSVerilog.verilogOpts verimixLog string "verilog.log"
hspiceSVerilog.verilogOpts simVision boolean nil
hspiceSVerilog.verilogOpts pulseSpec boolean nil
hspiceSVerilog.verilogOpts commandFile string ""
hspiceSVerilog.verilogOpts pulseError int 100
hspiceSVerilog.verilogOpts stopCompile boolean nil
hspiceSVerilog.verilogOpts keepNodes string "Minimum"
hspiceSVerilog.verilogOpts accelerationCA boolean nil
hspiceSVerilog.verilogOpts turboRadio string "Default"
hspiceSVerilog.verilogOpts libraryDir string ""
hspiceSVerilog.verilogOpts suppressWarnings boolean nil
hspiceSVerilog.verilogOpts accelerationSwitches boolean nil
hspiceSVerilog.verilogOpts accelerationNormal boolean t
hspiceSVerilog.verilogOpts delayType string "Typical"
hspiceSVerilog.verilogOpts pulseReject int 100
hspiceSVerilog.verilogOpts delayMode string "Default"
hspiceSVerilog.verilogOpts vermixBinary string "verilog.vmx"
;hspiceSVerilog init partition variables
hspiceSVerilog.init processPriority int 0
;hspiceSVerilog envOpts partition variables
hspiceSVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
hspiceSVerilog.envOpts mspNetlistMode string "Flat"
hspiceSVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
hspiceSVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
hspiceSVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
hspiceSVerilog.envOpts mspSetupNetlistEscapeName boolean nil
hspiceSVerilog.envOpts updateFile string ""
hspiceSVerilog.envOpts stimulusFile string ""
hspiceSVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
hspiceSVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
hspiceSVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
hspiceSVerilog.envOpts reNetlist boolean nil
hspiceSVerilog.envOpts includeSyntax string "cdsSpice"
hspiceSVerilog.envOpts mspSetupNetlistPinMap boolean nil
hspiceSVerilog.envOpts mspSetupNetlistBus boolean t
hspiceSVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
hspiceSVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
hspiceSVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
hspiceSVerilog.envOpts mspSetupNetlistExplicit boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
hspiceSVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
hspiceSVerilog.envOpts initFile string ""
hspiceSVerilog.envOpts printComments boolean nil
hspiceSVerilog.envOpts includeFile string ""
hspiceSVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
hspiceSVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
hspiceSVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimTimeValue int 1
hspiceSVerilog.envOpts mspSetupNetlistUseLib boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
hspiceSVerilog.envOpts mspSetupNetlistNullPort boolean nil
hspiceSVerilog.envOpts mspSetupNetlistDropPortRange boolean t
hspiceSVerilog.envOpts mspSetupNetlistUpCase boolean nil
hspiceSVerilog.envOpts generateMapFile boolean nil
hspiceSVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;hspiceSVerilog dc partition variables
hspiceSVerilog.dc enable toggle (nil)
hspiceSVerilog.dc from string ""
hspiceSVerilog.dc to string ""
hspiceSVerilog.dc by string ""
hspiceSVerilog.dc device string ""
;hspiceSVerilog dcOpts partition variables
;hspiceSVerilog noise partition variables
hspiceSVerilog.noise enable toggle (nil)
hspiceSVerilog.noise source string ""
hspiceSVerilog.noise output string ""
hspiceSVerilog.noise listEvery string "1"
;hspiceSVerilog noiseOpts partition variables
;hspiceSVerilog ac partition variables
hspiceSVerilog.ac enable toggle (nil)
hspiceSVerilog.ac from string ""
hspiceSVerilog.ac to string ""
hspiceSVerilog.ac incrType string "Logarithmic"
hspiceSVerilog.ac lin string ""
hspiceSVerilog.ac log string ""
;hspiceSVerilog acOpts partition variables
;hspiceSVerilog tran partition variables
hspiceSVerilog.tran enable toggle (nil)
hspiceSVerilog.tran from string ""
hspiceSVerilog.tran to string ""
hspiceSVerilog.tran by string ""
hspiceSVerilog.tran delmax string ""
;hspiceSVerilog tranOpts partition variables
; Copyright (C) 1997
; Cadence Design Systems Inc. All Rights Reserved.
; $Author: cvsadm $
; $Revision: 1.3.4.1 $
; $Date: 2004/06/16 16:42:51 $
; $State: Exp $
iccTranslator enableProbing boolean t
iccTranslator enableComponentUpdate boolean t
iccTranslator enableAutoImport boolean t
iccTranslator exportCommand string "cdba2icc"
iccTranslator importCommand string "icc2cdba"
iccTranslator iccCommand string "ic_craft"
iccTranslator iccDirectory string ""
iccTranslator exportDirectory string ""
iccTranslator rulesDirectory string ""
iccTranslator logOpPointLimit int 0
iccTranslator oversizePins boolean t
iccTranslator singleImageClusters boolean nil
iccTranslator exportVersion int 11
iccTranslator iccMajorSubVersion int 1
iccTranslator iccMinorSubVersion int 33
iccTranslator permutablePins boolean t
iccTranslator caseSensitive boolean t
iccTranslator schematicStrict boolean nil
iccTranslator keepViaImageOrigin boolean nil
iccTranslator exportTo string "VCR"
iccTranslator pinByPinModelEvaluate boolean nil
iccTranslator alwaysPinModelEvaluate boolean nil
iccTranslator autoTrimPins boolean t
iccTranslator makeVariantViasSpare boolean nil
iccTranslator hierIncrementUpdate boolean nil
iccTranslator MPPAsPolygons boolean nil
iccTranslator noIoPorts boolean nil
iccTranslator findKeepoutWidth boolean nil
iccTranslator.ExportEditor layoutLibrary string ""
iccTranslator.ExportEditor layoutCell string ""
iccTranslator.ExportEditor layoutView string ""
iccTranslator.ExportEditor layoutArea string ""
iccTranslator.ExportEditor netlistSource string "layoutCellview"
iccTranslator.ExportEditor netlistLibrary string ""
iccTranslator.ExportEditor netlistCell string ""
iccTranslator.ExportEditor netlistView string ""
iccTranslator.ExportEditor netlistFile string ""
iccTranslator.ExportEditor useAlternateViews boolean nil
iccTranslator.ExportEditor alternateViews string ""
iccTranslator.ExportEditor conductorDepth int 32
iccTranslator.ExportEditor keepoutDepth int 32
iccTranslator.ExportEditor pinConnection string "strong"
iccTranslator.ExportEditor useMarker boolean nil
iccTranslator.ExportEditor exportMode string "foreground"
iccTranslator.ExportEditor fullConnectivity boolean t
iccTranslator.ExportEditor cutToEdge boolean nil
iccTranslator.ExportEditor interLayer boolean t
iccTranslator.ExportEditor incrementalUpdate boolean t
iccTranslator.ExportEditor useRulesFile boolean nil
iccTranslator.ExportEditor rulesFile string ""
iccTranslator.ExportEditor routerOption string "vcr"
iccTranslator.ExportEditor startICC boolean t
iccTranslator.ExportEditor iccOptions string ""
iccTranslator.ImportEditor importFile string ""
iccTranslator.ImportEditor importFileType string "session"
iccTranslator.ImportEditor importLibrary string ""
iccTranslator.ImportEditor importCell string ""
iccTranslator.ImportEditor importView string ""
iccTranslator.ImportEditor boundary boolean t
iccTranslator.ImportEditor placement boolean t
iccTranslator.ImportEditor routes boolean t
iccTranslator.ImportEditor importMode string "foreground"
iccTranslator.ImportEditor segmentedPath boolean nil
iccTranslator.ImportEditor usePinPurpose boolean nil
ihdl ihdlLoadFileName string "~/.ihdlEnvFile";Load file name
ihdl pin_master_basic_lib boolean t
ihdl pin_master_cells string "ipin opin iopin"
;1************************************************************************
;2* Layout Environment Variables
;3* There are three categories in this file. Public env, wire editor env
;4* and private env. Privat envs should never be touched by customers.
;5************************************************************************
;* The following layout editor environment variables are for customer
;* use. Refer to the documentation for complete information.
layout abutServerOn boolean t
layout accessEdgesOn boolean nil
layout acuteAnglePath boolean t
layout alignApplySeparation boolean t
layout alignApplySpacings string "Component Space"
layout alignDirection string "vertical"
layout alignLayer string ""
layout alignMethod string "Component Origin"
layout alignSelectionMode string "preselect"
layout alignSeparation float 1.0
layout applyBounce boolean nil
layout arrayDisplay string "Full"
layout autoContact boolean nil
layout autoExtractEnabled boolean t
layout autoInstPin boolean nil
layout autoNetName boolean t
layout autoPermutePins boolean t
layout autoRefresh boolean nil
layout autoSetRefPoint boolean t
layout chopShape cyclic "rectangle"
layout confirmDelete boolean nil
layout contactColumns int 1
layout contactDefFromTechfile boolean t
layout contactDelX float 0.0
layout contactDelY float 0.0
layout contactJustify cyclic "centerCenter"
layout contactLength float 0.8
layout contactName string ""
layout contactResetDelXY boolean t
layout contactResetXYBias boolean t
layout contactResetRowCol boolean t
layout contactRows int 1
layout contactWidth float 0.8
layout copyColumns int 1
layout copyResetRowCol boolean nil
layout copyRows int 1
layout copyToLayer boolean nil
layout createPinLabel boolean nil
layout cursorShape boolean nil
layout deleteTarget cyclic "selected"
layout descendPromptForView boolean nil
layout devClass string ""
layout devType string ""
layout displayPinNames boolean nil
layout displayRefPoint boolean nil
layout displayStartLevel int 0
layout displayStopLevel int 0
layout displayStretchHandles boolean nil
layout dotsOn boolean nil
layout drawAxesOn boolean t
layout drawDottedGridOn boolean t
layout drawGridOn boolean t
layout drawInstancePins boolean nil
layout drawSurroundingOn boolean t
layout drdEditMode cyclic "off"
layout drdEditHierDepth int 0
layout drdEditDisplayMarkers boolean nil
layout drdEditDisplayHalo boolean nil
layout drdEditDisplayText boolean t
layout drdEditDisplayArrows boolean t
layout drdEditDisplayEdges boolean nil
layout dynamicHilightOn boolean t
layout extractCheckAll boolean nil
layout extractEnabled boolean t
layout extractStopLevel int 0
layout filterSize float 6.0
layout filterSizeDrawingStyle string "empty"
layout fixedWidthPaths boolean nil
layout flattenMode cyclic "one level"
layout flattenPCells boolean nil
layout gravityAperture float 0.3
layout gravityBounceX float 0.0
layout gravityBounceY float 0.0
layout gravityDepth int 0
layout gravityOn boolean nil
layout gravityType string "pin edge midpoint nexus vertex end centerline"
layout gridMultiple int 5
layout gridSpacing float 1.0
layout iconsOn boolean nil
layout ignoreBounce boolean nil
layout instCellName string ""
layout instColumns int 1
layout instDelX float 0.0
layout instDelY float 0.0
layout instLabel string "master"
layout instLibName string ""
layout instName string ""
layout instRows int 1
layout instViewName string "layout"
layout keepFirstTermName boolean nil
layout keepRuler boolean t
layout labelAttach boolean nil
layout labelDrafting boolean t
layout labelFontStyle cyclic "stick"
layout labelHeight float 1.0
layout labelJustify cyclic "centerCenter"
layout labelOverbar boolean nil
layout layerTapCycle boolean nil
layout leDispNetExpr boolean t
layout leWindowBBox string "((120 185) (1020 875))"
layout lockAngles boolean t
layout magnification float 1.0
layout maintainConnections boolean nil
layout markerZoomScale int 1
layout maxDragFig int 500
layout modCornerRadius float 1.0
layout modCornerType cyclic "radial"
layout modalCommands boolean t
layout moveToLayer boolean nil
layout mppASCIIFileName string ""
layout mppTemplate string "New"
layout multiSegRuler boolean nil
layout nPtsToTaper int 20
layout allowLockedRoutes boolean nil
layout netsOn boolean nil
layout numLevels int 32
layout numSides int 20
layout openToStopLevel boolean t
layout orientation cyclic "R0"
layout resetOrientation boolean t
layout originMarkersOn boolean nil
layout partialSelect boolean nil
layout pathBeginExt float 0.0
layout pathCL cyclic "yes"
layout pathEndExt float 0.0
layout pathJustify cyclic "center"
layout pathOffset float 0.0
layout pathStyle cyclic "truncateExtend"
layout pathWidth float 0.6
layout pinAccessDir string "left right top bottom"
layout pinLength float 0.6
layout pinSelectionMode cyclic "ignoreLPP"
layout pinShape cyclic "rectangle"
layout pinTextLayer string "text"
layout pinTextPurpose string "drawing"
layout pinTextSameLayer boolean nil
layout pinType string ""
layout pinWidth float 0.6
layout pinXPitch float 0.0
layout pinYPitch float 0.0
layout pinsAreSymbolic boolean t
layout pinLayerPurpose string ""
layout polygonArc boolean nil
layout preservePins boolean nil
layout preserveRodObjects boolean nil
layout preserveTerminalContacts boolean nil
layout propClass cyclic "attributes"
layout recursionCheck boolean t
layout removeChopShape boolean t
layout replaceFigs boolean t
layout reshapeType cyclic "rectangle"
layout rodAutoName string ""
layout segSnapMode string "orthogonal"
layout selectOnlyInstWithSelectableShapes boolean nil
layout selectionAperture int 5
layout showLPPFullName boolean nil
layout showWhatsNew string "yes"
layout snapMode string "orthogonal"
layout snapToGrid boolean nil
layout startLevel int 0
layout stopLevel int 0
layout stretchPCellApplyToName boolean t
layout taperStyle cyclic "linear"
layout termDirection cyclic "inputOutput"
layout termName string ""
layout textJustificationOn boolean t
layout tinyInstDetail boolean nil
layout trlBendFac float 1.0
layout trlBendStyle cyclic "bend"
layout trlChamFac float 0.6
layout trlNPtsToPI int 20
layout trlRadFac float 3.0
layout trlWidth1 float 20.0
layout trlWidth2 float 20.0
layout updatePCellIncrement float -1.0
layout useDefaultVia boolean t
layout useEditorBackgroundColorForLSW boolean t
layout useTrueBBox boolean nil
layout userVia string ""
layout xSnapSpacing float 0.1
layout ySnapSpacing float 0.1
layout yankShape cyclic "rectangle"
layout zoomToFig boolean nil
layout cdsViaXcutSpacing float 0.0
layout cdsViaYcutSpacing float 0.0
layout cdsViaLayer1XEnclosure float 0.0
layout cdsViaLayer1YEnclosure float 0.0
layout cdsViaLayer2XEnclosure float 0.0
layout cdsViaLayer2YEnclosure float 0.0
layout cdsViaLayer1XDirEnclosure float 0.0
layout cdsViaLayer1YDirEnclosure float 0.0
layout cdsViaLayer2XDirEnclosure float 0.0
layout cdsViaLayer2YDirEnclosure float 0.0
layout cdsViaLayer1Direction string ""
layout cdsViaLayer2Direction string ""
layout cdsViaStackedVias boolean nil
layout cdsViaResetXYCutSpacing boolean t
layout cdsViaResetLayer1XYEnclosure boolean t
layout cdsViaResetLayer2XYEnclosure boolean t
layout cdsViaResetLayer1XYDirEnclosure boolean t
layout cdsViaResetLayer2XYDirEnclosure boolean t
layout cdsViaResetLayerDirection boolean t
layout cdsViaResetOrigin boolean t
layout displayViaShapes boolean nil
layout tapType string "layer"
layout remasterInstCheckTerms boolean nil
layout remasterInstSearchLibText string ""
layout remasterInstSearchCellText string ""
layout remasterInstSearchViewText string ""
layout remasterInstUpdateLibText string ""
layout remasterInstUpdateCellText string ""
layout remasterInstUpdateViewText string ""
layout chainMode cyclic "selected"
layout anchor cyclic "left"
layout shortEnhContactForm boolean nil
layout markNetRange cyclic "Top to bottom"
layout markNetStartLevel int 0
layout markNetStopLevel int 0
layout markNetAutoColorCycle boolean t
layout markNetDumpNetObj boolean nil
layout measurementDisplayOn boolean nil
layout measurementTextHeight int 10
layout measurementDisplayTypes string "deltaXY distance radius area length"
;* The following layout editor environment variables are for customer use
;* with the wire editor functionality in Virtuoso XL Layout Editor only.
;* Refer to the documentation for complete information.
layout allowFloatingNets boolean nil
layout allowJogs boolean t
layout allowRedundantWiring boolean t
layout autoAdjustLength boolean nil
layout autoShield boolean nil
layout busOverride cyclic "ignore"
layout busOverrideValue float 1.0
layout busWireSpacing float 0.0
layout busWireSpacingType cyclic "wirewire"
layout checkConflict boolean t
layout checkCornerCorner boolean nil
layout checkCrossTalk boolean t
layout checkLength boolean t
layout checkLimitWay boolean nil
layout checkMaxProcessWireWidth boolean nil
layout checkMaxStackViaDepth boolean nil
layout checkMaxTotalVia boolean nil
layout checkMinMaskEdgeLength boolean nil
layout checkMinProcessWireWidth boolean t
layout checkMiter boolean nil
layout checkNetOrder boolean nil
layout checkOffManGridPin boolean nil
layout checkOffWireGridPin boolean nil
layout checkPinSpacing boolean t
layout checkPolygonWire boolean t
layout checkProtected boolean nil
layout checkReentrantPath boolean t
layout checkRegion boolean t
layout checkSameNet boolean nil
layout checkSegment boolean nil
layout checkStub boolean nil
layout checkUseLayers boolean nil
layout checkUseVias boolean nil
layout checkWireExtension boolean nil
layout doFile string ""
layout enableBusRouting boolean t
layout enableTandemPair boolean nil
layout fitViaPattern boolean nil
layout gatherBusWires boolean nil
layout inaccessiblePin boolean t
layout interactiveChecking boolean t
layout matchPinWidth boolean nil
layout matchPinWidthValue cyclic "narrow"
layout matchWireWidth boolean nil
layout multiplePinsConnection boolean t
layout pinLargerMaxProcessWidth boolean nil
layout pinSmallerMinProcessWidth boolean t
layout pushComponent boolean nil
layout pushRouting boolean t
layout routeAsManyAsPossible boolean nil
layout routeToCursor boolean nil
layout routeToCursorStyle cyclic "singleLayer"
layout sameNetChecking boolean nil
layout showTimingMeter boolean nil
layout showTimingOctagon boolean nil
layout snapToPinOrigin boolean nil
layout useDoFile boolean nil
layout viaAssistance cyclic "snap"
layout viaPattern cyclic "diag_1"
layout allowViaOnCurrentLayer boolean t
;* The following layout editor environment variables are for internal Cadence
;* use only. Changing the values of these variables my cause the layout editor
;* or other Cadence software to behave improperly or quit.
layout abutPerpSnapOn boolean t
layout coalesceLimit int 16
layout coalesceRatio int 50
layout connStatus cyclic "needToConnect"
layout contactInstLibName string ""
layout criticality int 10
layout eipRedraw boolean nil
layout figOrder cyclic "current"
layout iterNum int 0
layout jumpersOn boolean nil
layout minLabelSize float 1.0
layout minRefreshArea int 10
layout minStippleSize float 1.0
layout moreDialogs boolean t
layout netName string ""
layout outlineOnly boolean t
layout pickNCreate boolean nil
layout pinInstLibName string ""
layout probeTextOn boolean t
layout pruneSize float 1.0
layout routeMenuOn boolean t
layout toggle boolean nil
layout transformMarkersOn boolean t
layout viewNameList string ""
;3* There are three categories in this file. Public env, LO env
;4* and private env. Private envs should never be touched by customers.
layoutMigrate priorityUserDefined int 10
layoutMigrate priorityUser int 9
layoutMigrate priorityAreaHole int 8
layoutMigrate priorityScale int 7
layoutMigrate prioritySpace int 6
layoutMigrate priorityEnclose int 5
layoutMigrate priorityExtend int 4
layoutMigrate priorityWidth int 3
layoutMigrate priorityNoJog int 2
layoutMigrate priorityAlign int 1
layoutMigrate addToSelection boolean t
layoutMigrate visibleLayer boolean t
layoutMigrate selectableLayer boolean nil
layoutMigrate exclusiveLayer boolean nil
layoutMigrate exclusiveArea boolean nil
layoutMigrate migrateLibraries boolean nil
layoutMigrate mapPcellParams boolean nil
layoutMigrate useSchematicLinks boolean nil
layoutMigrate debugMode boolean t
layoutMigrate doPreProcess boolean t
layoutMigrate preprocessScript string "preprocess.qts"
layoutMigrate doAstractSource boolean nil
layoutMigrate abstractSourceScript string "abstractsource.qts"
layoutMigrate doAbstractTarget boolean nil
layoutMigrate abstractTargetScript string "abstracttarget.qts"
layoutMigrate doPremigrate boolean nil
layoutMigrate premigrateScript string "premigrate.qts"
layoutMigrate doNetlistBinding boolean nil
layoutMigrate netlistFile string "netlist.cdl"
layoutMigrate useConstraintScript boolean nil
layoutMigrate constraintScript string "constraints.qts"
layoutMigrate doPostprocess boolean t
layoutMigrate postprocessScript string "postprocess.qts"
layoutMigrate lastScript string ""
layoutMigrate optimizeX boolean t
layoutMigrate optimizeY boolean t
layoutMigrate allowZeroEdges boolean t
layoutMigrate allow45Edges boolean t
layoutMigrate scaleDevicesWires boolean t
layoutMigrate sumDeviceLegs boolean t
layoutMigrate lockPcells boolean nil
layoutMigrate useQuickSolver boolean nil
layoutMigrate centerLabels boolean nil
layoutMigrate minimizeMemory boolean nil
layoutMigrate keepResultsOnDisk boolean t
layoutMigrate expandSingletons boolean nil
layoutMigrate optimizeEnclose boolean nil
layoutMigrate genConstraintStats boolean nil
layoutMigrate optimizeEffort int 1
layoutMigrate autoRelaxDevices boolean nil
layoutMigrate autorelaxMaxConstraints boolean nil
layoutMigrate autorelaxConstraintsByType boolean nil
layoutMigrate autoRelaxTolerance float 50.0
layoutMigrate autoJogEdges boolean nil
layoutMigrate autoJogWires boolean nil
layoutMigrate autoJogLimit int 1000
layoutMigrate autoJogThreshold float 100.0
layoutMigrate revisitOneByOne2D boolean nil
layoutMigrate revisit2DCost float 100.0
layoutMigrate revisitFlash2D boolean t
layoutMigrate manufGrid2D boolean t
layoutMigrate changeEndOfLine boolean t
layoutMigrate changeCommonRun boolean t
layoutMigrate changeCornerCorner boolean t
layoutMigrate manufGridEnable boolean t
layoutMigrate manufGridPercent float 0.1
layoutMigrate manufGridIteration int 500
layoutMigrate manufGridCPUTime int 10000
layoutMigrate manufGridNoQuickSolver boolean t
layoutMigrate ioGridEnable boolean t
layoutMigrate ioGridPercent float 1.0
layoutMigrate ioGridIteration int 500
layoutMigrate ioGridCPUTime int 10000
layoutMigrate collapseVirtuals boolean t
layoutMigrate ignoreLengthsNetlistBinding boolean nil
layoutMigrate ignoreLengthsLayoutExtraction boolean nil
layoutMigrate propagateTieoffs boolean t
layoutMigrate remoteHost string ""
layoutMigrate remoteWorkingDir string ""
layoutMigrate useRemoteHost boolean nil
layoutMigrate remoteVirtuosoDir string ""
layoutMigrate RemoteQtkDir string ""
layoutMigrate remoteExecPath string ""
layoutMigrate processPriority int 15
layoutMigrate justFixMode boolean nil
layoutOptimize priorityUserDefined int 10
layoutOptimize priorityUser int 9
layoutOptimize priorityAreaHole int 8
layoutOptimize priorityScale int 7
layoutOptimize prioritySpace int 6
layoutOptimize priorityEnclose int 5
layoutOptimize priorityExtend int 4
layoutOptimize priorityWidth int 3
layoutOptimize priorityNoJog int 2
layoutOptimize priorityAlign int 1
layoutOptimize addToSelection boolean t
layoutOptimize visibleLayer boolean t
layoutOptimize selectableLayer boolean nil
layoutOptimize exclusiveLayer boolean nil
layoutOptimize exclusiveArea boolean nil
layoutOptimize migrateLibraries boolean nil
layoutOptimize mapPcellParams boolean nil
layoutOptimize useSchematicLinks boolean nil
layoutOptimize debugMode boolean t
layoutOptimize doPreProcess boolean nil
layoutOptimize preprocessScript string "preprocess.qts"
layoutOptimize doAstractSource boolean nil
layoutOptimize abstractSourceScript string "abstractsource.qts"
layoutOptimize doAbstractTarget boolean nil
layoutOptimize abstractTargetScript string "abstracttarget.qts"
layoutOptimize doPremigrate boolean nil
layoutOptimize premigrateScript string "premigrate.qts"
layoutOptimize doNetlistBinding boolean nil
layoutOptimize netlistFile string "netlist.cdl"
layoutOptimize useConstraintScript boolean nil
layoutOptimize constraintScript string "constraints.qts"
layoutOptimize doPostprocess boolean nil
layoutOptimize postprocessScript string "postprocess.qts"
layoutOptimize lastScript string ""
layoutOptimize optimizeX boolean t
layoutOptimize optimizeY boolean t
layoutOptimize allowZeroEdges boolean t
layoutOptimize allow45Edges boolean t
layoutOptimize scaleDevicesWires boolean nil
layoutOptimize sumDeviceLegs boolean nil
layoutOptimize lockPcells boolean nil
layoutOptimize useQuickSolver boolean nil
layoutOptimize centerLabels boolean nil
layoutOptimize minimizeMemory boolean nil
layoutOptimize keepResultsOnDisk boolean nil
layoutOptimize expandSingletons boolean nil
layoutOptimize optimizeEnclose boolean nil
layoutOptimize genConstraintStats boolean nil
layoutOptimize optimizeEffort int 1
layoutOptimize autoRelaxDevices boolean nil
layoutOptimize autorelaxMaxConstraints boolean nil
layoutOptimize autorelaxConstraintsByType boolean nil
layoutOptimize autoRelaxTolerance float 50.0
layoutOptimize autoJogEdges boolean nil
layoutOptimize autoJogWires boolean nil
layoutOptimize autoJogLimit int 1000
layoutOptimize autoJogThreshold float 100.0
layoutOptimize revisitOneByOne2D boolean nil
layoutOptimize revisit2DCost float 100.0
layoutOptimize revisitFlash2D boolean t
layoutOptimize manufGrid2D boolean nil
layoutOptimize changeEndOfLine boolean t
layoutOptimize changeCommonRun boolean t
layoutOptimize changeCornerCorner boolean t
layoutOptimize manufGridEnable boolean t
layoutOptimize manufGridPercent float 0.1
layoutOptimize manufGridIteration int 500
layoutOptimize manufGridCPUTime int 500
layoutOptimize manufGridNoQuickSolver boolean t
layoutOptimize ioGridEnable boolean t
layoutOptimize ioGridPercent float 1.0
layoutOptimize ioGridIteration int 500
layoutOptimize ioGridCPUTime int 1000
layoutOptimize collapseVirtuals boolean t
layoutOptimize ignoreLengthsNetlistBinding boolean nil
layoutOptimize ignoreLengthsLayoutExtraction boolean nil
layoutOptimize propagateTieoffs boolean t
layoutOptimize remoteHost string ""
layoutOptimize remoteWorkingDir string ""
layoutOptimize useRemoteHost boolean nil
layoutOptimize remoteVirtuosoDir string ""
layoutOptimize RemoteQtkDir string ""
layoutOptimize remoteExecPath string ""
layoutOptimize processPriority int 15
layoutOptimize justFixMode boolean nil
layoutOptimize.state menuState string "Migrate"
;2* Layout XL Environment Variables
;3* Note: entries in this file must be in alphabetical order.
;4************************************************************
layoutXL autoAbutment boolean t
layoutXL autoArrange boolean t
layoutXL autoSpace boolean t
layoutXL checkTimeStamps boolean t
layoutXL ciwWindow string "((0 0) (0 0))"
layoutXL constraintAssistedMode boolean nil
layoutXL createBoundaryLabel boolean nil
layoutXL crossSelect boolean t
layoutXL ignoredParams string "lxIgnoredParams dleIgnoredParams lxStopList dleStopList lxUseCell dleUseCell maskLayoutViewName posi instancesLastChanged instNamePrefix pin# lxTimeStamp dleSchExtractPath lxPlacementStatus"
layoutXL ignoreParamsForCAS string ""
layoutXL dlrNetConstNetClass string "neutral"
layoutXL dlrNetConstNetWeight string "normal"
layoutXL dlrRoutingBoundaryOption string "auto boundary"
layoutXL flightLineEnable boolean t
layoutXL ignoreNames string "lvsIgnore ignore nlAction"
layoutXL incNetCycleHilite boolean t
layoutXL incNetHiliteLayer string "y0 drawing"
layoutXL initAspectRatio float 1.0
layoutXL initAspectRatioOption string "Aspect Ratio W/H"
layoutXL initBoundaryLayer string "prBoundary drawing"
layoutXL initEstimateArea boolean t
layoutXL initIOLabelType string "Label"
layoutXL initIOPinLayer string ""
layoutXL initIOPinName string ""
layoutXL initPinHeight float 0.0
layoutXL initPinWidth float 0.0
layoutXL initPinMultiplicity int 1
layoutXL initPrBoundaryH float 0.0
layoutXL initPrBoundaryW float 0.0
layoutXL initSymbolicPins boolean nil
layoutXL initUtilization float 25.0
layoutXL initGlobalNetPins boolean t
layoutXL initCreatePins boolean t
layoutXL initCreateInstances boolean t
layoutXL initCreateBoundary boolean t
layoutXL initDoStacking boolean nil
layoutXL initDoFolding boolean nil
layoutXL layoutWindow string "((0 0) (0 0))"
layoutXL lswWindow string "((0 0) (0 0))"
layoutXL lxAllowPseudoParallelNets boolean nil
layoutXL lxDeltaWidth float 0.0
layoutXL lxDoNotCheck boolean nil
layoutXL lxLocalAbutment boolean nil
layoutXL lxSchExtractTopLevelOnly boolean nil
layoutXL lxStackPartitionParameters string "(1 8)"
layoutXL lxWidthTolerance string "(0.0 0.0)"
layoutXL mfactorNames string "m M"
layoutXL mfactorSplit boolean t
layoutXL moveAsGroup boolean t
layoutXL orientation string "R0"
layoutXL paramTolerance float 1e-06
layoutXL pathLayerFilter string ""
layoutXL pathProbe boolean t
layoutXL pathPurposeList string "drawing net pin"
layoutXL pathSwitchLayer boolean t
layoutXL pathSwitchPurpose boolean t
layoutXL pinTextSamePurpose boolean nil
layoutXL preserveTerminalContacts boolean nil
layoutXL probeCycleHilite boolean t
layoutXL probeDevice boolean t
layoutXL probeHiliteLayer string "hilite drawing"
layoutXL probeNet boolean t
layoutXL probePin boolean t
layoutXL probeInfoInCIW boolean nil
layoutXL infoWindow boolean t
layoutXL schematicWindow string "((0 0) (0 0))"
layoutXL showIncNetEnable boolean nil
layoutXL stopList string "layout compacted symbolic"
layoutXL templateFileName string ""
layoutXL updateReplacesMasters boolean t
layoutXL updateWithMarkers boolean t
layoutXL viewList string "schematic netlist symbol layout compacted symbolic"
layoutXL vxlDebugLog boolean nil
layoutXL vxlDebugLogFileName string "/tmp/vxl.log"
layoutXL initCreateMTM boolean nil
layoutXL sfactorNames string "s S"
layoutXL sfactorParam string "r R c C l L"
layoutXL mfactorSplitParamNames string "w"
layoutXL setPPConn boolean t
layoutXL lxSupplyNetNames string "vcc vcc! vcc: vdd vdd! vdd:"
layoutXL lxGroundNetNames string "gnd gnd! gnd: vss vss! vss:"
layoutXL lxGenerationOrientation string "preserve"
layoutXL lxGenerationTopLevelOnly boolean nil
layoutXL lxInitResetSource boolean nil
layoutXL compTypeRefLibs string "NONE"
layoutXL traverseMixedHierarchies boolean nil
layoutXL lxEvalCDFCallbacks boolean nil
layoutXL cloningDoExactMatch boolean nil
layoutXL.placement allowRotation boolean t
layoutXL.placement globalPlacement boolean t
layoutXL.placement openWindow boolean nil
layoutXL.placement optimizePlacement boolean nil
layoutXL.placement rulesFile string ""
layoutXL.placement runTime cyclic "moderate"
layoutXL.placement saveAs boolean nil
layoutXL.placement saveAsCellName string ""
layoutXL.placement saveAsLibName string ""
layoutXL.placement saveAsViewName string ""
layoutXL.placement vcpConductorDepth int 2
layoutXL.placement vcpKeepoutDepth int 2
layoutXL lxStackMinimalFolding boolean nil
layoutXL lxFingeringNames string "fingers finger"
layoutXL.placement rowGroundLayer string ""
layoutXL.placement rowGroundName string ""
layoutXL.placement rowGroundWidth float 1.0
layoutXL.placement rowPowerLayer string ""
layoutXL.placement rowPowerName string ""
layoutXL.placement rowPowerWidth float 1.0
layoutXL.placement rowSupplySpacing string ""
layoutXL.placement rowSupplyPosition cyclic "Outside"
layoutXL.placement rowSTDAllowFlip boolean t
layoutXL.placement rowMOSSupplyPattern cyclic "N-P-P-N"
layoutXL.placement rowSTDSupplyPattern cyclic "G-P-P-G"
layoutXL.placement congestionMapLayers string "((designFlow drawing) (designFlow drawing1) (designFlow drawing2) (designFlow drawing3) (designFlow drawing4) (designFlow drawing5) (designFlow drawing6) (designFlow drawing7) (designFlow drawing8) (designFlow drawing9))"
layoutXL.placement vcpGlobalPathScript string ""
layoutXL.placement vcpVerboseLevel int 1
layoutXL.placement vcpWriteToCIW boolean nil
;mmsimenv environment variables
;FORMAT: tool.partition varName type value private {choices, minmax} comment
;mmsimenv configuration defaults
mmsimenv.conf analogStopViewSet string "spectreS cdsSpice spice veriloga ahdl auLvs spectre"
mmsimenv.conf digitalStopViewSet string "verilog behavioral functional hdl system verilogNetlist msps"
modelwriter path string ""
modelwriter nodefault boolean nil
; Copyright (C) 2001 Cadence Design Systems, Inc. All Rights Reserved.
; $Revision: 1.1.8.1.2.1 $
;Mixed Signal Parasitic Simulation (MSPS) Environment Defaults
;FORMAT: tool[.partition] varName type value private {choices, minmax} comment
;Globals
msps schematicLibName string ""
msps schematicCellName string ""
msps schematicViewName string "schematic"
msps extractedLibName string ""
msps extractedCellName string ""
msps extractedViewName string "extracted"
msps switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
msps stopViewList string "cdsSpice spice"
msps instViewListTable string ""
;Parasitic Probing
msps.parProbe maxListSize int 20
msps.parProbe sortBy string "C"
;Back Annotation
msps.backAnnotate fontSize float 0.05
msps.backAnnotate xOffset float 0.01
msps.backAnnotate yOffset float 0.01
msps.backAnnotate sortBy string "C"
msps.backAnnotate parasiticFile string "parasitic_file"
;Build Analog
msps.buildAnalog setParasitics string "Include All"
msps.buildAnalog analogExtractedViewName string "analog_extracted"
; Copyright (C) 2000 Cadence Design Systems, Inc. All Rights Reserved.
; $Revision: 1.2.8.1.2.1 $
;Mixed Signal Parasitic Simulation for Assura Verification (MSPS-AV) Environment Defaults
;Globals
mspsAv schematicLibName string ""
mspsAv schematicCellName string ""
mspsAv schematicViewName string "schematic"
mspsAv extractedLibName string ""
mspsAv extractedCellName string ""
mspsAv extractedViewName string "av_extracted"
mspsAv switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
mspsAv stopViewList string "cdsSpice spice"
mspsAv instViewListTable string ""
mspsAv backAnnotateR boolean t
;Parasitic Probing
mspsAv.parProbe maxListSize int 20
mspsAv.parProbe sortBy string "C"
mspsAv.parProbe parasiticProbeFile string "parasitic_probing"
mspsAv.pwbCore schematicOpenReadOnly boolean t
mspsAv.backAnnotate fontSize float 0.05
mspsAv.backAnnotate Xoffset float 0.01
mspsAv.backAnnotate Yoffset float 0.01
mspsAv.backAnnotate sortBy string "C"
mspsAv.backAnnotate parasiticFile string "parasitic_file"
;Build Analog
mspsAv.buildAnalog setParasitics string "Include All"
mspsAv.buildAnalog analogExtractedViewName string "av_analog_extracted"
; Neocell Environment Variables
neocell ArchFile string ""
neocell MapFile string ""
neocell DefaultFile string ""
neocell UseBlockRules boolean nil
neocell BlockRulesFile string ""
neocell ExportDir string ""
neocell StartNeoCell boolean t
neocell ImportViewName string "layout"
neocell ImportTextDisplay boolean nil
neocell ImportBoundary boolean t
neocell ExportOptions string ""
neocell SymViewList string "symbolic layout"
neocell IgnoreParamTolerance boolean t
neocell VariantParamTolerance int 10
neocell VerboseWarn boolean t
neocell InitDFIIlib string ""
neocell NewDFIIlib string ""
neocell TempDir string ""
neocell TechPath string ""
neocell IgnorePinAccess boolean nil
neocell ImportPinLabelFont string "stick"
neocell ImportPinLabelSize float -1.0
neocell DisableSchExtract boolean nil
neocell TechFile string ""
neocell DisplayFile string ""
neocell pinConnection string "full"
neocell CEDefaultTab string "DevStyle"
neocell overridePinPurpose string ""
; ROD Environment Variables
rod evalILExprOn boolean t
rod minWidthCheckingOn boolean t
rod minSpacingCheckingOn boolean t
rod minEnclosureCheckingOn boolean t
rod preserveAlignInfoOn boolean t
; Composer Schematic Editor Environment Variables
; NOTE: This file should NOT be edited because it is automatically
; generated; customizations should be made to the file in
; <install_dir>/tools/dfII/samples/.cdsenv.
schematic autoDot boolean t
schematic blockDirRules cyclic "edge"
schematic broadcast boolean nil
schematic browserType string "library"
schematic checkAlways boolean nil
schematic checkBeepOn boolean t
schematic checkHierSave boolean t
schematic checkSupportAMS boolean nil
schematic checkSymTime int 1
schematic compBackTrace boolean t
schematic condOp cyclic "=="
schematic createCvOptions boolean t
schematic createInstResetCDF boolean t
schematic createInstShowCDF boolean t
schematic createLabelFontHeight float 0.0625
schematic createLabelFontStyle cyclic "stick"
schematic createLabelHorzOffset float 0.045
schematic createLabelHorzPosition cyclic "above"
schematic createLabelHorzRotation cyclic "R0"
schematic createLabelJustify cyclic "lowerCenter"
schematic createLabelOffsetMode boolean t
schematic createLabelVertOffset float 0.045
schematic createLabelVertPosition cyclic "left"
schematic createLabelVertRotation cyclic "R90"
schematic cvDisplay boolean t
schematic defWideWireWidth float 0.0625
schematic defaultsFile string ""
schematic deleteInstPinsWire boolean t
schematic descendSheet string "sheet"
schematic descendTarget string "query user"
schematic differential boolean nil
schematic dotOverlap float 0.03125
schematic drawMode string "anyAngle"
schematic drawModeRoute string "route"
schematic echoToCIW boolean t
schematic editPropCDFParamView string "Use Tools Filter"
schematic editPropShowCDF boolean t
schematic editPropShowSystem boolean nil
schematic editPropShowUser boolean t
schematic findAccessMode string "edit"
schematic findZoomButton boolean nil
schematic flightWidth float 0.0
schematic gravityOn boolean t
schematic invokeKanjiEditor string "kterm -km euc -e vi"
schematic libList string ""
schematic markerSeverity string "all"
schematic markerShowIgnore boolean t
schematic markerSource toggle (t t t t)
schematic markerType toggle (t t)
schematic markerZoom boolean nil
schematic maxLabelOffsetUU float 0.045
schematic minMarkerSize float 0.05
schematic modalCommands boolean t
schematic netExprDisplay cyclic "value only"
schematic netNameMethod cyclic "prefix"
schematic netNamePrefix string "net"
schematic netNameRangeDescend boolean nil
schematic netNameSeparator string "_"
schematic noteFontHeight float 0.0625
schematic noteFontStyle cyclic "stick"
schematic noteJustify cyclic "lowerCenter"
schematic noteShape cyclic "line"
schematic noteShapeLineStyle cyclic "solid"
schematic noteType cyclic "normalLabel"
schematic pinBackTrace boolean t
schematic pinNameSeed string "pin"
schematic pinRefDuplicates boolean nil
schematic pinRefFormat string "<sheetNumber><zone><referenceName>"
schematic pinRefSorting string "Sheet Number"
schematic replSaveChanges boolean nil
schematic runSRC boolean t
schematic runVIC boolean t
schematic saveAction cyclic "Ask Me"
schematic schCoalesceLimit int 2
schematic schDisplayDepth int 3
schematic schDrawAxesOn boolean nil
schematic schDynamicHilightOn boolean t
schematic schFilterSize float 0.3
schematic schGridMultiple int 8
schematic schGridSpacing float 0.125
schematic schGridType cyclic "dotted"
schematic schHdlCrossViewCheck boolean t
schematic schHdlCrossViewString string ""
schematic schHdlEditAfterError boolean t
schematic schHdlNetToInoutPort toggle (t t t t t t t)
schematic schHdlNetToInputPort toggle (t t t t t t t)
schematic schHdlNoHierarchy boolean nil
schematic schHdlPrintCommand string "lpr"
schematic schHdlVerbose boolean nil
schematic schMaxDragFig int 100
schematic schPathType cyclic "full"
schematic schShowDirectConnects boolean nil
schematic schShowLabelOrigin boolean nil
schematic schSnapSpacing float 0.0625
schematic schWindowBBox string "((120 185) (1020 875))"
schematic schematicAreaPartialSelect boolean nil
schematic schematicSelectFilter string "allSchObj instancePin"
schematic sensitiveMenu boolean t
schematic shapeLineType cyclic "narrow"
schematic shapeLineWidth float 0.0625
schematic simProbeAutoPlace boolean nil
schematic simProbeFormat string "<state>"
schematic simProbeType string "monitor"
schematic snapEnabled boolean t
schematic spanLib string "do not check"
schematic srcConnByName cyclic "ignored"
schematic srcFloatingBIDIR cyclic "warning"
schematic srcFloatingIO cyclic "warning"
schematic srcFloatingInput cyclic "warning"
schematic srcFloatingNets cyclic "warning"
schematic srcFloatingOutput cyclic "warning"
schematic srcInhPinNetCollision cyclic "ignored"
schematic srcInheritedConn cyclic "ignored"
schematic srcInstNameExpr string ""
schematic srcInstNameSyntax cyclic "ignored"
schematic srcInstOverlap cyclic "warning"
schematic srcInstOverlapValue int 10
schematic srcMaxLabelOffset cyclic "ignored"
schematic srcNameCollision cyclic "warning"
schematic srcNetNameExpr string ""
schematic srcNetNameSyntax cyclic "ignored"
schematic srcNoOverrideNet cyclic "warning"
schematic srcOffsheetConnCheck cyclic "ignored"
schematic srcPinNetCollision cyclic "ignored"
schematic srcShortedOutputs cyclic "warning"
schematic srcSolderOnCrossover cyclic "warning"
schematic srcSparseIndexBus cyclic "ignored"
schematic srcTermNameExpr string ""
schematic srcTermNameSyntax cyclic "ignored"
schematic srcUnconnectedWires cyclic "ignored"
schematic srcVHDLSyntax cyclic "ignored"
schematic srcVerilogSyntax cyclic "ignored"
schematic ssgPackageLabels cyclic "none"
schematic ssgSortPins cyclic "alphanumeric"
schematic statusBanner boolean t
schematic statusBannerXY boolean nil
schematic stickyWireLabelRange float 0.3125
schematic symCoalesceLimit int 2
schematic symDisplayDepth int 3
schematic symDrawAxesOn boolean nil
schematic symDynamicHilightOn boolean t
schematic symFilterSize float 0.3
schematic symGridMultiple int 8
schematic symGridSpacing float 0.125
schematic symGridType cyclic "dotted"
schematic symMaxDragFig int 100
schematic symPathType cyclic "full"
schematic symShowDirectConnects boolean nil
schematic symShowLabelOrigin boolean nil
schematic symSnapSpacing float 0.0625
schematic symWindowBBox string "((120 185) (1020 875))"
schematic symbolAreaPartialSelect boolean nil
schematic symbolLabelChoice cyclic "instance label"
schematic symbolLabelChoiceText string ""
schematic symbolLabelFontHeight float 0.0625
schematic symbolLabelFontStyle cyclic "stick"
schematic symbolLabelJustify cyclic "lowerCenter"
schematic symbolLabelType cyclic "NLPLabel"
schematic symbolPinFlatten boolean t
schematic symbolPinIncrCount int 1
schematic symbolPinLocate cyclic "left"
schematic symbolPinUsage string ""
schematic symbolSelectFilter string "allSymObj"
schematic symbolShape cyclic "line"
schematic symbolShapeFillStyle cyclic "outline"
schematic transToSheetType string "single"
schematic tsgTemplateType string "digital"
schematic updateConn boolean t
schematic updateInstResetCDF boolean t
schematic vicExactPinMatch boolean nil
schematic vicIgnoreInhTermAll boolean t
schematic vicIgnoreInhTermList string ""
schematic vicIgnoreInhTermViewList string ""
schematic vicInheritedPinMatch boolean t
schematic vicInheritedPins boolean t
schematic vicSeverity cyclic "warning"
schematic vicViewList string "symbol schematic functional behavioral system opt_sch opt_net"
schematic viewNameList string "schematic symbol"
schematic wireBackTrace boolean nil
schematic zoomOutButton boolean nil
;spectre environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spectre opts partition variables
spectre.opts multithread string ""
spectre.opts title string ""
spectre.opts audit string ""
spectre.opts nthreads string ""
spectre.opts mos_method string ""
spectre.opts ckptclock string "1800"
spectre.opts flow string ""
spectre.opts cols string "80"
spectre.opts opptcheck string ""
spectre.opts maxwarnstologfile string ""
spectre.opts reltol string "1e-3"
spectre.opts notation string ""
spectre.opts senstype string ""
spectre.opts warn string ""
spectre.opts approx string ""
spectre.opts info string ""
spectre.opts sensformat string ""
spectre.opts quantities string ""
spectre.opts pivabs string ""
spectre.opts compatible string ""
spectre.opts ignshorts string ""
spectre.opts gmin string "1e-12"
spectre.opts rforce string "1"
spectre.opts note string ""
spectre.opts homotopy string ""
spectre.opts debug string ""
spectre.opts iabstol string "1e-12"
spectre.opts maxwarns string "5"
spectre.opts tempeffects string ""
spectre.opts vabstol string "1e-6"
spectre.opts macromodels string ""
spectre.opts temp string "27"
spectre.opts tnom string "27"
spectre.opts maxnotes string "5"
spectre.opts narrate string ""
spectre.opts value string ""
spectre.opts gmin_check string ""
spectre.opts pivrel string "1e-3"
spectre.opts pivotdc string ""
spectre.opts digits string "5"
spectre.opts maxnotestologfile string ""
spectre.opts diagnose string ""
spectre.opts scale string "1.0"
spectre.opts scalem string "1.0"
spectre.opts error string ""
spectre.opts inventory string ""
spectre.opts topcheck string ""
spectre.opts limit string ""
spectre.opts sensfile string "../psf/sens.output"
;spectre outputs partition variables
spectre.outputs currents string ""
spectre.outputs outputParamInfo boolean t
spectre.outputs modelParamInfo boolean t
spectre.outputs subcktprobelvl string ""
spectre.outputs saveahdlvars string ""
spectre.outputs pwr string ""
spectre.outputs nestlvl string ""
spectre.outputs elementInfo boolean t
spectre.outputs useprobes string ""
spectre.outputs save string "allpub"
;spectre envOpts partition variables
spectre.envOpts stopViewList string "spectre"
spectre.envOpts switchViewList string "spectre cmos_sch cmos.sch schematic veriloga ahdl"
spectre.envOpts enableArclength boolean nil
spectre.envOpts autoDisplay boolean t
spectre.envOpts simOutputFormat string "psfbin"
spectre.envOpts spp string ""
spectre.envOpts analysisOrder string ""
spectre.envOpts paramRangeCheckFile string ""
spectre.envOpts printComments boolean nil
spectre.envOpts checkpoint string ""
spectre.envOpts recover string ""
spectre.envOpts firstRun boolean t
spectre.envOpts userCmdLineOption string ""
;spectre init partition variables
spectre.init processPriority int 0
;spectre pz partition variables
spectre.pz enable toggle (nil)
spectre.pz outType string "voltage"
spectre.pz p string ""
spectre.pz n string ""
spectre.pz oprobe string ""
spectre.pz inType string "voltage"
spectre.pz inVsrc string ""
spectre.pz inIsrc string ""
spectre.pz iprobe string ""
spectre.pz sweep string ""
spectre.pz freq string "1"
spectre.pz dev string ""
spectre.pz deviceParam string ""
spectre.pz mod string ""
spectre.pz modelParam string ""
spectre.pz designVar string ""
spectre.pz param string ""
spectre.pz rangeType string "Start-Stop"
spectre.pz start string ""
spectre.pz stop string ""
spectre.pz center string ""
spectre.pz span string ""
spectre.pz incrType string "Automatic"
spectre.pz stepTypeLin string "Step Size"
spectre.pz stepTypeLog string "Points Per Decade"
spectre.pz step string ""
spectre.pz lin string ""
spectre.pz dec string ""
spectre.pz log string ""
spectre.pz useDiscrete boolean nil
spectre.pz values string ""
spectre.pz porti string "1"
;spectre pzOpts partition variables
spectre.pzOpts readns string ""
spectre.pzOpts oppoint string ""
spectre.pzOpts fmax string ""
spectre.pzOpts zeroonly string ""
spectre.pzOpts prevoppoint string ""
spectre.pzOpts restart string ""
spectre.pzOpts annotate string ""
spectre.pzOpts stats string ""
;spectre dcmatch partition variables
spectre.dcmatch enable toggle (nil)
spectre.dcmatch outType string "voltage"
spectre.dcmatch p string ""
spectre.dcmatch n string ""
spectre.dcmatch oprobe string ""
spectre.dcmatch sweep string ""
spectre.dcmatch dev string ""
spectre.dcmatch deviceParam string ""
spectre.dcmatch mod string ""
spectre.dcmatch modelParam string ""
spectre.dcmatch designVar string ""
spectre.dcmatch param string ""
spectre.dcmatch rangeType string "Start-Stop"
spectre.dcmatch start string ""
spectre.dcmatch stop string ""
spectre.dcmatch center string ""
spectre.dcmatch span string ""
spectre.dcmatch incrType string "Automatic"
spectre.dcmatch stepTypeLin string "Step Size"
spectre.dcmatch stepTypeLog string "Points Per Decade"
spectre.dcmatch step string ""
spectre.dcmatch lin string ""
spectre.dcmatch dec string ""
spectre.dcmatch log string ""
spectre.dcmatch useDiscrete boolean nil
spectre.dcmatch values string ""
spectre.dcmatch mth string ""
spectre.dcmatch porti string "1"
spectre.dcmatch portv string ""
;spectre dcmatchOpts partition variables
spectre.dcmatchOpts readns string ""
spectre.dcmatchOpts save string ""
spectre.dcmatchOpts nestlvl string ""
spectre.dcmatchOpts oppoint string ""
spectre.dcmatchOpts prevoppoint string ""
spectre.dcmatchOpts restart string ""
spectre.dcmatchOpts annotate string "status"
spectre.dcmatchOpts stats string ""
spectre.dcmatchOpts where string "rawfile"
;spectre stb partition variables
spectre.stb enable toggle (nil)
spectre.stb sweep string "Frequency"
spectre.stb freq string ""
spectre.stb dev string ""
spectre.stb deviceParam string ""
spectre.stb mod string ""
spectre.stb modelParam string ""
spectre.stb designVar string ""
spectre.stb param string ""
spectre.stb rangeType string "Start-Stop"
spectre.stb start string ""
spectre.stb stop string ""
spectre.stb center string ""
spectre.stb span string ""
spectre.stb incrType string "Automatic"
spectre.stb stepTypeLin string "Step Size"
spectre.stb stepTypeLog string "Points Per Decade"
spectre.stb step string ""
spectre.stb lin string ""
spectre.stb dec string ""
spectre.stb log string ""
spectre.stb useDiscrete boolean nil
spectre.stb values string ""
spectre.stb probe string ""
;spectre stbOpts partition variables
spectre.stbOpts prevoppoint string ""
spectre.stbOpts readns string ""
spectre.stbOpts save string ""
spectre.stbOpts nestlvl string ""
spectre.stbOpts oppoint string ""
spectre.stbOpts restart string ""
spectre.stbOpts annotate string "status"
spectre.stbOpts stats string ""
;spectre tran partition variables
spectre.tran enable toggle (nil)
spectre.tran stop string ""
spectre.tran errpreset string ""
;spectre tranOpts partition variables
spectre.tranOpts start string ""
spectre.tranOpts outputstart string ""
spectre.tranOpts step string ""
spectre.tranOpts maxstep string ""
spectre.tranOpts ic string ""
spectre.tranOpts skipdc string ""
spectre.tranOpts readic string ""
spectre.tranOpts readns string ""
spectre.tranOpts cmin string ""
spectre.tranOpts write string "spectre.ic"
spectre.tranOpts writefinal string "spectre.fc"
spectre.tranOpts ckptperiod string ""
spectre.tranOpts method string ""
spectre.tranOpts relref string ""
spectre.tranOpts lteratio string ""
spectre.tranOpts stats string ""
spectre.tranOpts annotate string "status"
spectre.tranOpts save string ""
spectre.tranOpts nestlvl string ""
spectre.tranOpts oppoint string ""
spectre.tranOpts skipstart string ""
spectre.tranOpts skipstop string ""
spectre.tranOpts skipcount string ""
spectre.tranOpts strobeperiod string ""
spectre.tranOpts strobedelay string ""
spectre.tranOpts compression string ""
spectre.tranOpts infotimes string ""
spectre.tranOpts flushpoints string ""
spectre.tranOpts flushtime string ""
spectre.tranOpts flushofftime string ""
spectre.tranOpts maxiters string "5"
spectre.tranOpts restart string ""
spectre.tranOpts captab boolean nil
spectre.tranOpts timed boolean nil
spectre.tranOpts threshold string "0.0"
spectre.tranOpts detail string "node"
spectre.tranOpts sort string "name"
;spectre envlp partition variables
spectre.envlp enable toggle (nil)
spectre.envlp clockname string ""
spectre.envlp stop string ""
spectre.envlp harmonics string "Number of harmonics"
spectre.envlp harms string ""
spectre.envlp harmsvec string ""
spectre.envlp errpreset string ""
;spectre envlpOpts partition variables
spectre.envlpOpts start string ""
spectre.envlpOpts outputstart string ""
spectre.envlpOpts tstab string ""
spectre.envlpOpts modulationbw string ""
spectre.envlpOpts maxstep string ""
spectre.envlpOpts envmaxstep string ""
spectre.envlpOpts ic string ""
spectre.envlpOpts skipdc string ""
spectre.envlpOpts readic string ""
spectre.envlpOpts readns string ""
spectre.envlpOpts cmin string ""
spectre.envlpOpts write string ""
spectre.envlpOpts writefinal string ""
spectre.envlpOpts swapfile string ""
spectre.envlpOpts method string ""
spectre.envlpOpts relref string ""
spectre.envlpOpts lteratio string ""
spectre.envlpOpts envlteratio string ""
spectre.envlpOpts steadyratio string ""
spectre.envlpOpts stats string ""
spectre.envlpOpts annotate string "status"
spectre.envlpOpts save string ""
spectre.envlpOpts nestlvl string ""
spectre.envlpOpts compression string ""
spectre.envlpOpts outputtype string ""
spectre.envlpOpts strobeperiod string ""
spectre.envlpOpts maxiters string ""
spectre.envlpOpts restart string ""
spectre.envlpOpts envmaxiters string ""
;spectre ac partition variables
spectre.ac enable toggle (nil)
spectre.ac sweep string "Frequency"
spectre.ac freq string ""
spectre.ac dev string ""
spectre.ac deviceParam string ""
spectre.ac mod string ""
spectre.ac modelParam string ""
spectre.ac designVar string ""
spectre.ac param string ""
spectre.ac rangeType string "Start-Stop"
spectre.ac start string ""
spectre.ac stop string ""
spectre.ac center string ""
spectre.ac span string ""
spectre.ac incrType string "Automatic"
spectre.ac stepTypeLin string "Step Size"
spectre.ac stepTypeLog string "Points Per Decade"
spectre.ac step string ""
spectre.ac lin string ""
spectre.ac dec string ""
spectre.ac log string ""
spectre.ac useDiscrete boolean nil
spectre.ac values string ""
;spectre acOpts partition variables
spectre.acOpts readns string ""
spectre.acOpts prevoppoint string ""
spectre.acOpts save string ""
spectre.acOpts nestlvl string ""
spectre.acOpts oppoint string ""
spectre.acOpts restart string ""
spectre.acOpts annotate string "status"
spectre.acOpts stats string ""
;spectre dc partition variables
spectre.dc enable toggle (nil)
spectre.dcop enable toggle (nil)
spectre.dc saveOppoint boolean nil
spectre.dc sweep string ""
spectre.dc dev string ""
spectre.dc deviceParam string ""
spectre.dc mod string ""
spectre.dc modelParam string ""
spectre.dc designVar string ""
spectre.dc param string ""
spectre.dc rangeType string "Start-Stop"
spectre.dc start string ""
spectre.dc stop string ""
spectre.dc center string ""
spectre.dc span string ""
spectre.dc incrType string "Automatic"
spectre.dc stepTypeLin string "Step Size"
spectre.dc stepTypeLog string "Points Per Decade"
spectre.dc step string ""
spectre.dc lin string ""
spectre.dc dec string ""
spectre.dc log string ""
spectre.dc useDiscrete boolean nil
spectre.dc values string ""
;spectre dcOpts partition variables
spectre.dcOpts force string ""
spectre.dcopOpts force string ""
spectre.dcOpts readns string ""
spectre.dcopOpts readns string ""
spectre.dcOpts readforce string ""
spectre.dcopOpts readforce string ""
spectre.dcOpts write string "spectre.dc"
spectre.dcopOpts write string "spectre.dc"
spectre.dcOpts writefinal string ""
spectre.dcopOpts writefinal string ""
spectre.dcOpts save string ""
spectre.dcopOpts save string ""
spectre.dcOpts nestlvl string ""
spectre.dcopOpts nestlvl string ""
spectre.dcOpts print string ""
spectre.dcopOpts print string ""
spectre.dcOpts check string ""
spectre.dcopOpts check string ""
spectre.dcOpts oppoint string "rawfile"
spectre.dcopOpts oppoint string "rawfile"
spectre.dcOpts homotopy string ""
spectre.dcopOpts homotopy string ""
spectre.dcOpts restart string ""
spectre.dcopOpts restart string ""
spectre.dcOpts maxiters string "150"
spectre.dcopOpts maxiters string "150"
spectre.dcOpts maxsteps string "10000"
spectre.dcopOpts maxsteps string "10000"
spectre.dcOpts annotate string "status"
spectre.dcopOpts annotate string "status"
spectre.dcOpts captab boolean nil
spectre.dcopOpts captab boolean nil
spectre.dcOpts threshold string "0.0"
spectre.dcopOpts threshold string "0.0"
spectre.dcOpts detail string "node"
spectre.dcopOpts detail string "node"
spectre.dcOpts sort string "name"
spectre.dcopOpts sort string "name"
;spectre noise partition variables
spectre.noise enable toggle (nil)
spectre.noise sweep string "Frequency"
spectre.noise freq string ""
spectre.noise dev string ""
spectre.noise deviceParam string ""
spectre.noise mod string ""
spectre.noise modelParam string ""
spectre.noise designVar string ""
spectre.noise param string ""
spectre.noise rangeType string "Start-Stop"
spectre.noise start string ""
spectre.noise stop string ""
spectre.noise center string ""
spectre.noise span string ""
spectre.noise incrType string "Automatic"
spectre.noise stepTypeLin string "Step Size"
spectre.noise stepTypeLog string "Points Per Decade"
spectre.noise step string ""
spectre.noise lin string ""
spectre.noise dec string ""
spectre.noise log string ""
spectre.noise useDiscrete boolean nil
spectre.noise values string ""
spectre.noise outType string "probe"
spectre.noise p string ""
spectre.noise n string ""
spectre.noise oprobe string ""
spectre.noise inType string "port"
spectre.noise inVsrc string ""
spectre.noise inIsrc string ""
spectre.noise iprobe string ""
spectre.noise inPort string ""
;spectre noiseOpts partition variables
spectre.noiseOpts readns string ""
spectre.noiseOpts prevoppoint string ""
spectre.noiseOpts save string ""
spectre.noiseOpts nestlvl string ""
spectre.noiseOpts oppoint string ""
spectre.noiseOpts restart string ""
spectre.noiseOpts annotate string "status"
spectre.noiseOpts stats string ""
;spectre xf partition variables
spectre.xf enable toggle (nil)
spectre.xf sweep string "Frequency"
spectre.xf freq string ""
spectre.xf dev string ""
spectre.xf deviceParam string ""
spectre.xf mod string ""
spectre.xf modelParam string ""
spectre.xf designVar string ""
spectre.xf param string ""
spectre.xf rangeType string "Start-Stop"
spectre.xf start string ""
spectre.xf stop string ""
spectre.xf center string ""
spectre.xf span string ""
spectre.xf incrType string "Automatic"
spectre.xf stepTypeLin string "Step Size"
spectre.xf stepTypeLog string "Points Per Decade"
spectre.xf step string ""
spectre.xf lin string ""
spectre.xf dec string ""
spectre.xf log string ""
spectre.xf useDiscrete boolean nil
spectre.xf values string ""
spectre.xf outType string "voltage"
spectre.xf p string ""
spectre.xf n string ""
spectre.xf probe string ""
;spectre xfOpts partition variables
spectre.xfOpts readns string ""
spectre.xfOpts prevoppoint string ""
spectre.xfOpts stimuli string ""
spectre.xfOpts save string ""
spectre.xfOpts nestlvl string ""
spectre.xfOpts oppoint string ""
spectre.xfOpts restart string ""
spectre.xfOpts annotate string "status"
spectre.xfOpts stats string ""
;spectre sp partition variables
spectre.sp enable toggle (nil)
spectre.sp ports string ""
spectre.sp sweep string "Frequency"
spectre.sp freq string ""
spectre.sp dev string ""
spectre.sp deviceParam string ""
spectre.sp mod string ""
spectre.sp modelParam string ""
spectre.sp designVar string ""
spectre.sp param string ""
spectre.sp rangeType string "Start-Stop"
spectre.sp start string ""
spectre.sp stop string ""
spectre.sp center string ""
spectre.sp span string ""
spectre.sp incrType string "Automatic"
spectre.sp stepTypeLin string "Step Size"
spectre.sp stepTypeLog string "Points Per Decade"
spectre.sp step string ""
spectre.sp lin string ""
spectre.sp dec string ""
spectre.sp log string ""
spectre.sp useDiscrete boolean nil
spectre.sp values string ""
spectre.sp donoise string "no"
spectre.sp oprobe string ""
spectre.sp iprobe string ""
;spectre spOpts partition variables
spectre.spOpts readns string ""
spectre.spOpts prevoppoint string ""
spectre.spOpts file string ""
spectre.spOpts datafmt string ""
spectre.spOpts datatype string ""
spectre.spOpts noisedata string ""
spectre.spOpts oppoint string ""
spectre.spOpts restart string ""
spectre.spOpts annotate string "status"
spectre.spOpts stats string ""
;spectre pss partition variables
spectre.pss enable toggle (nil)
spectre.pss paramListBox string ""
spectre.pss fundListBox string ""
spectre.pss stimName string ""
spectre.pss freqName string ""
spectre.pss freqVal string ""
spectre.pss signalLevel string "Large"
spectre.pss srcId string ""
spectre.pss maxHarms string ""
spectre.pss freqPeriod string "Beat Frequency"
spectre.pss fund string ""
spectre.pss autoCalc boolean nil
spectre.pss period string ""
spectre.pss harmonics string "Number of harmonics"
spectre.pss harms string ""
spectre.pss indices string ""
spectre.pss Aindices string ""
spectre.pss harmsvec string ""
spectre.pss selFreqFrom string "0"
spectre.pss selFreqTo string "1e12"
spectre.pss order string "1"
spectre.pss harmsAndFreqsTitle string ""
spectre.pss harmsAndFreqsTitle2 string ""
spectre.pss harmsAndFreqs string ""
spectre.pss arrayCoeffs string ""
spectre.pss harmCoeffs string ""
spectre.pss harmListMem string ""
spectre.pss errpreset string ""
spectre.pss tstab string ""
spectre.pss saveinit string ""
spectre.pss oscana boolean nil
spectre.pss p string ""
spectre.pss n string ""
spectre.pss sweepB boolean nil
spectre.pss sweep string "Variable"
spectre.pss freqVar string "no"
spectre.pss designVar string ""
spectre.pss dev string ""
spectre.pss deviceParam string ""
spectre.pss mod string ""
spectre.pss modelParam string ""
spectre.pss param string ""
spectre.pss rangeType string "Start-Stop"
spectre.pss start string ""
spectre.pss stop string ""
spectre.pss center string ""
spectre.pss span string ""
spectre.pss incrType string "Linear"
spectre.pss stepTypeLin string "Step Size"
spectre.pss stepTypeLog string "Points Per Decade"
spectre.pss step string ""
spectre.pss lin string ""
spectre.pss dec string ""
spectre.pss log string ""
spectre.pss useDiscrete boolean nil
spectre.pss values string ""
;spectre pssOpts partition variables
spectre.pssOpts step string ""
spectre.pssOpts maxstep string ""
spectre.pssOpts ic string ""
spectre.pssOpts skipdc string ""
spectre.pssOpts readic string ""
spectre.pssOpts readns string ""
spectre.pssOpts cmin string ""
spectre.pssOpts write string ""
spectre.pssOpts writefinal string ""
spectre.pssOpts swapfile string ""
spectre.pssOpts writepss string ""
spectre.pssOpts readpss string ""
spectre.pssOpts method string ""
spectre.pssOpts tstabmethod string ""
spectre.pssOpts relref string ""
spectre.pssOpts lteratio string ""
spectre.pssOpts steadyratio string ""
spectre.pssOpts maxacfreq string ""
spectre.pssOpts maxperiods string ""
spectre.pssOpts finitediff string ""
spectre.pssOpts highorder string ""
spectre.pssOpts psaratio string ""
spectre.pssOpts maxorder string ""
spectre.pssOpts fullpssvec string ""
spectre.pssOpts stats string ""
spectre.pssOpts annotate string "status"
spectre.pssOpts save string ""
spectre.pssOpts nestlvl string ""
spectre.pssOpts oppoint string ""
spectre.pssOpts skipstart string ""
spectre.pssOpts skipstop string ""
spectre.pssOpts skipcount string ""
spectre.pssOpts strobeperiod string ""
spectre.pssOpts strobedelay string ""
spectre.pssOpts compression string ""
spectre.pssOpts outputtype string ""
spectre.pssOpts maxiters string ""
spectre.pssOpts restart string ""
spectre.pssOpts tstart string ""
;spectre pac partition variables
spectre.pac enable toggle (nil)
spectre.pac fund string ""
spectre.pac period string ""
spectre.pac modsource string ""
spectre.pac moduppersideband string "0"
spectre.pac inmodharmnum string "1"
spectre.pac outmodharmvec string "1"
spectre.pac inputType string "SSB"
spectre.pac modulatedToggle boolean nil
spectre.pac modulated string ""
spectre.pac singlePt string "Single-Point []"
spectre.pac sweeptype string " "
spectre.pac relharmnum string ""
spectre.pac rangeType string "Start-Stop"
spectre.pac start string ""
spectre.pac stop string ""
spectre.pac center string ""
spectre.pac span string ""
spectre.pac incrType string "Automatic"
spectre.pac stepTypeLin string "Step Size"
spectre.pac stepTypeLog string "Points Per Decade"
spectre.pac step string ""
spectre.pac lin string ""
spectre.pac dec string ""
spectre.pac log string ""
spectre.pac useDiscrete boolean nil
spectre.pac values string ""
spectre.pac harmonics string "Maximum sideband"
spectre.pac maxsideband string ""
spectre.pac indices string ""
spectre.pac Aindices string ""
spectre.pac sidebands string ""
spectre.pac side string "upper"
spectre.pac selFreqFrom string "0"
spectre.pac selFreqTo string "1e12"
spectre.pac order string "1"
spectre.pac harmsAndFreqsTitle string ""
spectre.pac harmsAndFreqsTitle2 string ""
spectre.pac harmsAndFreqs string ""
spectre.pac arrayCoeffs string ""
spectre.pac harmCoeffs string ""
spectre.pac harmListMem string ""
;spectre pacOpts partition variables
spectre.pacOpts tolerance string ""
spectre.pacOpts gear_order string ""
spectre.pacOpts solver string ""
spectre.pacOpts oscsolver string ""
spectre.pacOpts stats string ""
spectre.pacOpts annotate string "status"
spectre.pacOpts freqaxis string ""
spectre.pacOpts save string ""
spectre.pacOpts nestlvl string ""
spectre.pacOpts outputperiod string ""
;spectre pnoise partition variables
spectre.pnoise enable toggle (nil)
spectre.pnoise fund string ""
spectre.pnoise period string ""
spectre.pnoise singlePt string "Single-Point []"
spectre.pnoise sweeptype string " "
spectre.pnoise relharmnum string ""
spectre.pnoise rangeType string "Start-Stop"
spectre.pnoise start string ""
spectre.pnoise stop string ""
spectre.pnoise center string ""
spectre.pnoise span string ""
spectre.pnoise incrType string "Automatic"
spectre.pnoise stepTypeLin string "Step Size"
spectre.pnoise stepTypeLog string "Points Per Decade"
spectre.pnoise step string ""
spectre.pnoise lin string ""
spectre.pnoise dec string ""
spectre.pnoise log string ""
spectre.pnoise useDiscrete boolean nil
spectre.pnoise values string ""
spectre.pnoise harmonics string "Maximum sideband"
spectre.pnoise maxsideband string ""
spectre.pnoise indices string ""
spectre.pnoise Aindices string ""
spectre.pnoise sidebands string ""
spectre.pnoise side string "upper"
spectre.pnoise selFreqFrom string "0"
spectre.pnoise selFreqTo string "1e12"
spectre.pnoise order string "1"
spectre.pnoise harmsAndFreqsTitle string ""
spectre.pnoise harmsAndFreqsTitle2 string ""
spectre.pnoise harmsAndFreqs string ""
spectre.pnoise arrayCoeffs string ""
spectre.pnoise harmCoeffs string ""
spectre.pnoise harmListMem string ""
spectre.pnoise outType string "probe"
spectre.pnoise p string ""
spectre.pnoise n string ""
spectre.pnoise oprobe string ""
spectre.pnoise inType string "port"
spectre.pnoise inVsrc string ""
spectre.pnoise inIsrc string ""
spectre.pnoise iprobe string ""
spectre.pnoise inPort string ""
spectre.pnoise refsbSelect string "Enter in field"
spectre.pnoise refsideband string ""
spectre.pnoise refsbFreqFrom string "0"
spectre.pnoise refsbFreqTo string "1e12"
spectre.pnoise refsbOrder string "1"
spectre.pnoise refsbTitle string ""
spectre.pnoise refsbListbox string ""
spectre.pnoise noisetype string "sources"
spectre.pnoise tdnoise string "Noise Skip Count"
spectre.pnoise noiseskipcount string ""
spectre.pnoise numberofpoints string ""
spectre.pnoise maxcycles string ""
spectre.pnoise useDiscreteNoise boolean nil
spectre.pnoise noisetimepoints string ""
spectre.pnoise useDiscreteCorr boolean nil
spectre.pnoise cycles string ""
;spectre pnoiseOpts partition variables
spectre.pnoiseOpts tolerance string ""
spectre.pnoiseOpts gear_order string ""
spectre.pnoiseOpts solver string ""
spectre.pnoiseOpts oscsolver string ""
spectre.pnoiseOpts stats string ""
spectre.pnoiseOpts annotate string "status"
spectre.pnoiseOpts save string ""
spectre.pnoiseOpts nestlvl string ""
spectre.pnoiseOpts saveallsidebands string ""
;spectre pxf partition variables
spectre.pxf enable toggle (nil)
spectre.pxf fund string ""
spectre.pxf period string ""
spectre.pxf moduppersideband string "0"
spectre.pxf outmodharmnum string "1"
spectre.pxf inmodharmvec string "1"
spectre.pxf outputType string "SSB"
spectre.pxf modulatedToggle boolean nil
spectre.pxf modulated string ""
spectre.pxf outType string "voltage"
spectre.pxf p string ""
spectre.pxf n string ""
spectre.pxf probe string ""
spectre.pxf singlePt string "Single-Point []"
spectre.pxf sweeptype string " "
spectre.pxf relharmnum string ""
spectre.pxf rangeType string "Start-Stop"
spectre.pxf start string ""
spectre.pxf stop string ""
spectre.pxf center string ""
spectre.pxf span string ""
spectre.pxf incrType string "Automatic"
spectre.pxf stepTypeLin string "Step Size"
spectre.pxf stepTypeLog string "Points Per Decade"
spectre.pxf step string ""
spectre.pxf lin string ""
spectre.pxf dec string ""
spectre.pxf log string ""
spectre.pxf useDiscrete boolean nil
spectre.pxf values string ""
spectre.pxf harmonics string "Maximum sideband"
spectre.pxf maxsideband string ""
spectre.pxf indices string ""
spectre.pxf Aindices string ""
spectre.pxf sidebands string ""
spectre.pxf side string "upper"
spectre.pxf selFreqFrom string "0"
spectre.pxf selFreqTo string "1e12"
spectre.pxf order string "1"
spectre.pxf harmsAndFreqsTitle string ""
spectre.pxf harmsAndFreqsTitle2 string ""
spectre.pxf harmsAndFreqs string ""
spectre.pxf arrayCoeffs string ""
spectre.pxf harmCoeffs string ""
spectre.pxf harmListMem string ""
;spectre pxfOpts partition variables
spectre.pxfOpts tolerance string ""
spectre.pxfOpts gear_order string ""
spectre.pxfOpts solver string ""
spectre.pxfOpts oscsolver string ""
spectre.pxfOpts stats string ""
spectre.pxfOpts annotate string "status"
spectre.pxfOpts stimuli string ""
spectre.pxfOpts freqaxis string ""
spectre.pxfOpts save string ""
spectre.pxfOpts nestlvl string ""
;spectre psp partition variables
spectre.psp enable toggle (nil)
spectre.psp singlePt string "Single-Point []"
spectre.psp sweeptype string " "
spectre.psp rangeType string "Start-Stop"
spectre.psp start string ""
spectre.psp stop string ""
spectre.psp center string ""
spectre.psp span string ""
spectre.psp incrType string "Automatic"
spectre.psp stepTypeLin string "Step Size"
spectre.psp stepTypeLog string "Points Per Decade"
spectre.psp step string ""
spectre.psp lin string ""
spectre.psp dec string ""
spectre.psp log string ""
spectre.psp useDiscrete boolean nil
spectre.psp values string ""
spectre.psp portharmsvec string ""
spectre.psp ports string ""
spectre.psp selectPorts boolean t
spectre.psp harmsvec string ""
spectre.psp freqRange string ""
spectre.psp listPortHarm string ""
spectre.psp listPortName string ""
spectre.psp listPortNum string ""
spectre.psp portChoiceList string ""
spectre.psp portChoiceListHeading string ""
spectre.psp donoise string "yes"
spectre.psp maxsideband string ""
;spectre pspOpts partition variables
spectre.pspOpts tolerance string ""
spectre.pspOpts gear_order string ""
spectre.pspOpts solver string ""
spectre.pspOpts oscsolver string ""
spectre.pspOpts annotate string "status"
spectre.pspOpts stats string ""
spectre.pspOpts freqaxis string ""
;spectre qpss partition variables
spectre.qpss enable toggle (nil)
spectre.qpss paramListBox string ""
spectre.qpss fundListBox string ""
spectre.qpss stimName string ""
spectre.qpss freqName string ""
spectre.qpss freqVal string ""
spectre.qpss signalLevel string "Moderate"
spectre.qpss srcId string ""
spectre.qpss maxHarms string ""
spectre.qpss funds string ""
spectre.qpss maxharms string ""
spectre.qpss harmonics boolean nil
spectre.qpss selFreqFrom string "0"
spectre.qpss selFreqTo string "1e12"
spectre.qpss harmsAndFreqsTitle string ""
spectre.qpss harmsAndFreqs string ""
spectre.qpss errpreset string ""
spectre.qpss tstab string ""
spectre.qpss saveinit string ""
spectre.qpss sweepB boolean nil
spectre.qpss sweep string "Variable"
spectre.qpss freqVar string "no"
spectre.qpss designVar string ""
spectre.qpss dev string ""
spectre.qpss deviceParam string ""
spectre.qpss mod string ""
spectre.qpss modelParam string ""
spectre.qpss param string ""
spectre.qpss rangeType string "Start-Stop"
spectre.qpss start string ""
spectre.qpss stop string ""
spectre.qpss center string ""
spectre.qpss span string ""
spectre.qpss incrType string "Linear"
spectre.qpss stepTypeLin string "Step Size"
spectre.qpss stepTypeLog string "Points Per Decade"
spectre.qpss step string ""
spectre.qpss lin string ""
spectre.qpss dec string ""
spectre.qpss log string ""
spectre.qpss useDiscrete boolean nil
spectre.qpss values string ""
;spectre qpssOpts partition variables
spectre.qpssOpts step string ""
spectre.qpssOpts maxstep string ""
spectre.qpssOpts ic string ""
spectre.qpssOpts skipdc string ""
spectre.qpssOpts readic string ""
spectre.qpssOpts readns string ""
spectre.qpssOpts cmin string ""
spectre.qpssOpts write string ""
spectre.qpssOpts writefinal string ""
spectre.qpssOpts swapfile string ""
spectre.qpssOpts writeqpss string ""
spectre.qpssOpts readqpss string ""
spectre.qpssOpts method string ""
spectre.qpssOpts relref string ""
spectre.qpssOpts lteratio string ""
spectre.qpssOpts steadyratio string ""
spectre.qpssOpts maxperiods string ""
spectre.qpssOpts stats string ""
spectre.qpssOpts annotate string "status"
spectre.qpssOpts save string ""
spectre.qpssOpts nestlvl string ""
spectre.qpssOpts oppoint string ""
spectre.qpssOpts skipstart string ""
spectre.qpssOpts skipstop string ""
spectre.qpssOpts skipcount string ""
spectre.qpssOpts strobeperiod string ""
spectre.qpssOpts strobedelay string ""
spectre.qpssOpts compression string ""
spectre.qpssOpts maxiters string ""
spectre.qpssOpts restart string ""
spectre.qpssOpts tstart string ""
;spectre qpac partition variables
spectre.qpac enable toggle (nil)
spectre.qpac singlePt string "Single-Point []"
spectre.qpac sweeptype string " "
spectre.qpac relharmvec string ""
spectre.qpac rangeType string "Start-Stop"
spectre.qpac start string ""
spectre.qpac stop string ""
spectre.qpac center string ""
spectre.qpac span string ""
spectre.qpac incrType string "Automatic"
spectre.qpac stepTypeLin string "Step Size"
spectre.qpac stepTypeLog string "Points Per Decade"
spectre.qpac step string ""
spectre.qpac lin string ""
spectre.qpac dec string ""
spectre.qpac log string ""
spectre.qpac useDiscrete boolean nil
spectre.qpac values string ""
spectre.qpac sbsm string "Maximum clock order"
spectre.qpac clockmaxharm string ""
spectre.qpac selFreqFrom string "0"
spectre.qpac selFreqTo string "1e12"
spectre.qpac order string "1"
spectre.qpac harmsAndFreqsTitle string ""
spectre.qpac harmsAndFreqsTitle2 string ""
spectre.qpac harmsAndFreqs string ""
spectre.qpac arrayCoeffs string ""
spectre.qpac harmCoeffs string ""
spectre.qpac harmListMem string ""
spectre.qpac sidevec string ""
;spectre qpacOpts partition variables
spectre.qpacOpts tolerance string ""
spectre.qpacOpts gear_order string ""
spectre.qpacOpts solver string ""
spectre.qpacOpts stats string ""
spectre.qpacOpts annotate string "status"
spectre.qpacOpts freqaxis string ""
spectre.qpacOpts save string ""
spectre.qpacOpts nestlvl string ""
;spectre qpnoise partition variables
spectre.qpnoise enable toggle (nil)
spectre.qpnoise singlePt string "Single-Point []"
spectre.qpnoise sweeptype string " "
spectre.qpnoise relharmvec string ""
spectre.qpnoise rangeType string "Start-Stop"
spectre.qpnoise start string ""
spectre.qpnoise stop string ""
spectre.qpnoise center string ""
spectre.qpnoise span string ""
spectre.qpnoise incrType string "Automatic"
spectre.qpnoise stepTypeLin string "Step Size"
spectre.qpnoise stepTypeLog string "Points Per Decade"
spectre.qpnoise step string ""
spectre.qpnoise lin string ""
spectre.qpnoise dec string ""
spectre.qpnoise log string ""
spectre.qpnoise useDiscrete boolean nil
spectre.qpnoise values string ""
spectre.qpnoise sbsm string "Maximum clock order"
spectre.qpnoise clockmaxharm string ""
spectre.qpnoise selFreqFrom string "0"
spectre.qpnoise selFreqTo string "1e12"
spectre.qpnoise order string "1"
spectre.qpnoise harmsAndFreqsTitle string ""
spectre.qpnoise harmsAndFreqsTitle2 string ""
spectre.qpnoise harmsAndFreqs string ""
spectre.qpnoise arrayCoeffs string ""
spectre.qpnoise harmCoeffs string ""
spectre.qpnoise harmListMem string ""
spectre.qpnoise sidevec string ""
spectre.qpnoise outType string "probe"
spectre.qpnoise p string ""
spectre.qpnoise n string ""
spectre.qpnoise oprobe string ""
spectre.qpnoise inType string "port"
spectre.qpnoise inVsrc string ""
spectre.qpnoise inIsrc string ""
spectre.qpnoise iprobe string ""
spectre.qpnoise inPort string ""
spectre.qpnoise refsbSelect string "Enter in field"
spectre.qpnoise refsideband string ""
spectre.qpnoise refsbFreqFrom string "0"
spectre.qpnoise refsbFreqTo string "1e12"
spectre.qpnoise refsbOrder string "1"
spectre.qpnoise refsbTitle string ""
spectre.qpnoise refsbListbox string ""
;spectre qpnoiseOpts partition variables
spectre.qpnoiseOpts tolerance string ""
spectre.qpnoiseOpts gear_order string ""
spectre.qpnoiseOpts solver string ""
spectre.qpnoiseOpts stats string ""
spectre.qpnoiseOpts annotate string "status"
spectre.qpnoiseOpts save string ""
spectre.qpnoiseOpts nestlvl string ""
spectre.qpnoiseOpts saveallsidebands string ""
;spectre qpxf partition variables
spectre.qpxf enable toggle (nil)
spectre.qpxf singlePt string "Single-Point []"
spectre.qpxf sweeptype string " "
spectre.qpxf relharmvec string ""
spectre.qpxf rangeType string "Start-Stop"
spectre.qpxf start string ""
spectre.qpxf stop string ""
spectre.qpxf center string ""
spectre.qpxf span string ""
spectre.qpxf incrType string "Automatic"
spectre.qpxf stepTypeLin string "Step Size"
spectre.qpxf stepTypeLog string "Points Per Decade"
spectre.qpxf step string ""
spectre.qpxf lin string ""
spectre.qpxf dec string ""
spectre.qpxf log string ""
spectre.qpxf useDiscrete boolean nil
spectre.qpxf values string ""
spectre.qpxf sbsm string "Maximum clock order"
spectre.qpxf clockmaxharm string ""
spectre.qpxf selFreqFrom string "0"
spectre.qpxf selFreqTo string "1e12"
spectre.qpxf order string "1"
spectre.qpxf harmsAndFreqsTitle string ""
spectre.qpxf harmsAndFreqsTitle2 string ""
spectre.qpxf harmsAndFreqs string ""
spectre.qpxf arrayCoeffs string ""
spectre.qpxf harmCoeffs string ""
spectre.qpxf harmListMem string ""
spectre.qpxf sidevec string ""
spectre.qpxf outType string "voltage"
spectre.qpxf p string ""
spectre.qpxf n string ""
spectre.qpxf probe string ""
;spectre qpxfOpts partition variables
spectre.qpxfOpts tolerance string ""
spectre.qpxfOpts gear_order string ""
spectre.qpxfOpts solver string ""
spectre.qpxfOpts stats string ""
spectre.qpxfOpts annotate string "status"
spectre.qpxfOpts stimuli string ""
spectre.qpxfOpts freqaxis string ""
spectre.qpxfOpts save string ""
spectre.qpxfOpts nestlvl string ""
;spectre qpsp partition variables
spectre.qpsp enable toggle (nil)
spectre.qpsp singlePt string "Single-Point []"
spectre.qpsp sweeptype string " "
spectre.qpsp rangeType string "Start-Stop"
spectre.qpsp start string ""
spectre.qpsp stop string ""
spectre.qpsp center string ""
spectre.qpsp span string ""
spectre.qpsp incrType string "Automatic"
spectre.qpsp stepTypeLin string "Step Size"
spectre.qpsp stepTypeLog string "Points Per Decade"
spectre.qpsp step string ""
spectre.qpsp lin string ""
spectre.qpsp dec string ""
spectre.qpsp log string ""
spectre.qpsp useDiscrete boolean nil
spectre.qpsp values string ""
spectre.qpsp portharmsvec string ""
spectre.qpsp ports string ""
spectre.qpsp selectPorts boolean t
spectre.qpsp harmsvec string ""
spectre.qpsp freqRange string ""
spectre.qpsp listPortHarm string ""
spectre.qpsp listPortName string ""
spectre.qpsp listPortNum string ""
spectre.qpsp portChoiceList string ""
spectre.qpsp portChoiceListHeading string ""
spectre.qpsp donoise string "yes"
spectre.qpsp clockmaxharm string ""
;spectre qpspOpts partition variables
spectre.qpspOpts tolerance string ""
spectre.qpspOpts gear_order string ""
spectre.qpspOpts solver string ""
spectre.qpspOpts annotate string "status"
spectre.qpspOpts stats string ""
spectre.qpspOpts freqaxis string ""
;spectre sens partition variables
spectre.sens enable toggle (nil)
spectre.sens sensType toggle (nil nil nil)
spectre.sens analyses_list string ""
spectre.sens outputs string ""
spectre.sens output_list string ""
spectre.sens net string ""
spectre.sens term string ""
;spectre sensOpts partition variables
;spectreS environment variables
;spectreS opts partition variables
spectreS.opts title string ""
spectreS.opts audit string ""
spectreS.opts ckptclock string "1800"
spectreS.opts flow string ""
spectreS.opts cols string "80"
spectreS.opts opptcheck string ""
spectreS.opts reltol string "1e-3"
spectreS.opts notation string ""
spectreS.opts warn string ""
spectreS.opts approx string ""
spectreS.opts info string ""
spectreS.opts quantities string ""
spectreS.opts pivabs string ""
spectreS.opts compatible string ""
spectreS.opts ignshorts string ""
spectreS.opts gmin string "1e-12"
spectreS.opts rforce string "1"
spectreS.opts homotopy string ""
spectreS.opts debug string ""
spectreS.opts iabstol string "1e-12"
spectreS.opts maxwarns string "5"
spectreS.opts tempeffects string ""
spectreS.opts vabstol string "1e-6"
spectreS.opts temp string "27"
spectreS.opts tnom string "27"
spectreS.opts narrate string ""
spectreS.opts value string ""
spectreS.opts gmin_check string ""
spectreS.opts pivrel string "1e-3"
spectreS.opts pivotdc string ""
spectreS.opts digits string "5"
spectreS.opts diagnose string ""
spectreS.opts scale string "1.0"
spectreS.opts scalem string "1.0"
spectreS.opts error string ""
spectreS.opts inventory string ""
spectreS.opts topcheck string ""
spectreS.opts limit string ""
;spectreS outputs partition variables
spectreS.outputs allAnalogACTC boolean nil
spectreS.outputs allAhdlVars boolean nil
spectreS.outputs allAnalogNV boolean t
spectreS.outputs allAnalogTC boolean nil
;spectreS envOpts partition variables
spectreS.envOpts updateFile string ""
spectreS.envOpts stimulusFile string ""
spectreS.envOpts instViewListTable string ""
spectreS.envOpts doInstBased boolean nil
spectreS.envOpts stopViewList string "spectreS spice"
spectreS.envOpts paramRangeCheckFile string ""
spectreS.envOpts includeSyntax string "cdsSpice"
spectreS.envOpts initFile string ""
spectreS.envOpts printComments boolean nil
spectreS.envOpts netlistType string "hierarchical"
spectreS.envOpts generateMapFile boolean nil
spectreS.envOpts includeFile string ""
spectreS.envOpts recover boolean nil
spectreS.envOpts instStopListTable string ""
spectreS.envOpts switchViewList string "spectreS spice cmos_sch cmos.sch schematic veriloga ahdl"
;spectreS init partition variables
spectreS.init processPriority int 0
;spectreS tran partition variables
spectreS.tran enable toggle (nil)
spectreS.tran to string ""
spectreS.tran errpreset string ""
;spectreS tranOpts partition variables
spectreS.tranOpts start string ""
spectreS.tranOpts outputstart string ""
spectreS.tranOpts step string ""
spectreS.tranOpts maxstep string ""
spectreS.tranOpts ic string ""
spectreS.tranOpts skipdc string ""
spectreS.tranOpts readic string ""
spectreS.tranOpts readns string ""
spectreS.tranOpts cmin string ""
spectreS.tranOpts write string "spectre.ic"
spectreS.tranOpts writefinal string "spectre.fc"
spectreS.tranOpts ckptperiod string ""
spectreS.tranOpts method string "default"
spectreS.tranOpts relref string "default"
spectreS.tranOpts lteratio string ""
spectreS.tranOpts stats string ""
spectreS.tranOpts annotate string "status"
spectreS.tranOpts oppoint string ""
spectreS.tranOpts skipstart string ""
spectreS.tranOpts skipstop string ""
spectreS.tranOpts skipcount string ""
spectreS.tranOpts strobeperiod string ""
spectreS.tranOpts strobedelay string ""
spectreS.tranOpts compression string "no"
spectreS.tranOpts maxiters string "5"
spectreS.tranOpts restart string ""
;spectreS ac partition variables
spectreS.ac enable toggle (nil)
spectreS.ac sweep string "Frequency"
spectreS.ac freq string ""
spectreS.ac device string ""
spectreS.ac deviceParam string ""
spectreS.ac model string ""
spectreS.ac modelParam string ""
spectreS.ac temperature string "temp"
spectreS.ac rangeType string "Start-Stop"
spectreS.ac from string ""
spectreS.ac to string ""
spectreS.ac center string ""
spectreS.ac span string ""
spectreS.ac incrType string "Automatic"
spectreS.ac stepTypeLin string "Step Size"
spectreS.ac stepTypeLog string "Points Per Decade"
spectreS.ac by string ""
spectreS.ac lin string ""
spectreS.ac dec string ""
spectreS.ac log string ""
spectreS.ac useDiscrete boolean nil
spectreS.ac values string ""
;spectreS acOpts partition variables
spectreS.acOpts readns string ""
spectreS.acOpts oppoint string ""
spectreS.acOpts restart string ""
spectreS.acOpts annotate string "status"
spectreS.acOpts stats string ""
;spectreS dc partition variables
spectreS.dc enable toggle (nil)
spectreS.dcop enable toggle (nil)
spectreS.dc saveOppoint boolean nil
spectreS.dc oppoint string "rawfile"
spectreS.dc save string "allpub"
spectreS.dc sweep string ""
spectreS.dc device string ""
spectreS.dc deviceParam string ""
spectreS.dc model string ""
spectreS.dc modelParam string ""
spectreS.dc temperature string "temp"
spectreS.dc rangeType string "Start-Stop"
spectreS.dc from string ""
spectreS.dc to string ""
spectreS.dc center string ""
spectreS.dc span string ""
spectreS.dc incrType string "Automatic"
spectreS.dc stepTypeLin string "Step Size"
spectreS.dc stepTypeLog string "Points Per Decade"
spectreS.dc by string ""
spectreS.dc lin string ""
spectreS.dc dec string ""
spectreS.dc log string ""
spectreS.dc useDiscrete boolean nil
spectreS.dc values string ""
;spectreS dcOpts partition variables
spectreS.dcOpts force string ""
spectreS.dcopOpts force string ""
spectreS.dcOpts readns string ""
spectreS.dcopOpts readns string ""
spectreS.dcOpts readforce string ""
spectreS.dcopOpts readforce string ""
spectreS.dcOpts write string "spectre.dc"
spectreS.dcopOpts write string "spectre.dc"
spectreS.dcOpts writefinal string ""
spectreS.dcopOpts writefinal string ""
spectreS.dcOpts print string ""
spectreS.dcopOpts print string ""
spectreS.dcOpts check string ""
spectreS.dcopOpts check string ""
spectreS.dcOpts homotopy string ""
spectreS.dcopOpts homotopy string ""
spectreS.dcOpts restart string ""
spectreS.dcopOpts restart string ""
spectreS.dcOpts maxiters string "150"
spectreS.dcopOpts maxiters string "150"
spectreS.dcOpts maxsteps string "10000"
spectreS.dcopOpts maxsteps string "10000"
spectreS.dcOpts annotate string "status"
spectreS.dcopOpts annotate string "status"
;spectreS noise partition variables
spectreS.noise enable toggle (nil)
spectreS.noise sweep string "Frequency"
spectreS.noise freq string ""
spectreS.noise device string ""
spectreS.noise deviceParam string ""
spectreS.noise model string ""
spectreS.noise modelParam string ""
spectreS.noise temperature string "temp"
spectreS.noise rangeType string "Start-Stop"
spectreS.noise from string ""
spectreS.noise to string ""
spectreS.noise center string ""
spectreS.noise span string ""
spectreS.noise incrType string "Automatic"
spectreS.noise stepTypeLin string "Step Size"
spectreS.noise stepTypeLog string "Points Per Decade"
spectreS.noise by string ""
spectreS.noise lin string ""
spectreS.noise dec string ""
spectreS.noise log string ""
spectreS.noise useDiscrete boolean nil
spectreS.noise values string ""
spectreS.noise outNoiseType string "voltage"
spectreS.noise negNode string "/gnd!"
spectreS.noise posNode string ""
spectreS.noise outVsrc string ""
spectreS.noise inNoiseType string "voltage"
spectreS.noise inVsrc string ""
spectreS.noise inIsrc string ""
spectreS.noise inPort string ""
;spectreS noiseOpts partition variables
spectreS.noiseOpts readns string ""
spectreS.noiseOpts oppoint string ""
spectreS.noiseOpts restart string ""
spectreS.noiseOpts annotate string "status"
spectreS.noiseOpts stats string ""
;spectreS xf partition variables
spectreS.xf enable toggle (nil)
spectreS.xf sweep string "Frequency"
spectreS.xf freq string ""
spectreS.xf device string ""
spectreS.xf deviceParam string ""
spectreS.xf model string ""
spectreS.xf modelParam string ""
spectreS.xf temperature string "temp"
spectreS.xf rangeType string "Start-Stop"
spectreS.xf from string ""
spectreS.xf to string ""
spectreS.xf center string ""
spectreS.xf span string ""
spectreS.xf incrType string "Automatic"
spectreS.xf stepTypeLin string "Step Size"
spectreS.xf stepTypeLog string "Points Per Decade"
spectreS.xf by string ""
spectreS.xf lin string ""
spectreS.xf dec string ""
spectreS.xf log string ""
spectreS.xf useDiscrete boolean nil
spectreS.xf values string ""
spectreS.xf outXfType string "voltage"
spectreS.xf negNode string "/gnd!"
spectreS.xf posNode string ""
spectreS.xf outVsrc string ""
;spectreS xfOpts partition variables
spectreS.xfOpts readns string ""
spectreS.xfOpts stimuli string ""
spectreS.xfOpts oppoint string ""
spectreS.xfOpts restart string ""
spectreS.xfOpts annotate string "status"
spectreS.xfOpts stats string ""
;spectreS sp partition variables
spectreS.sp enable toggle (nil)
spectreS.sp sweep string "Frequency"
spectreS.sp frequency string ""
spectreS.sp device string ""
spectreS.sp deviceParam string ""
spectreS.sp model string ""
spectreS.sp modelParam string ""
spectreS.sp temperature string "temp"
spectreS.sp rangeType string "Start-Stop"
spectreS.sp from string ""
spectreS.sp to string ""
spectreS.sp center string ""
spectreS.sp span string ""
spectreS.sp incrType string "Automatic"
spectreS.sp stepTypeLin string "Step Size"
spectreS.sp stepTypeLog string "Points Per Decade"
spectreS.sp by string ""
spectreS.sp lin string ""
spectreS.sp dec string ""
spectreS.sp log string ""
spectreS.sp useDiscrete boolean nil
spectreS.sp values string ""
spectreS.sp donoise boolean nil
spectreS.sp oprobe string ""
spectreS.sp iprobe string ""
;spectreS spOpts partition variables
spectreS.spOpts readns string ""
spectreS.spOpts file string ""
spectreS.spOpts oppoint string ""
spectreS.spOpts reftemp string ""
spectreS.spOpts restart string ""
spectreS.spOpts annotate string "status"
spectreS.spOpts stats string ""
;spectreS spss partition variables
spectreS.spss enable toggle (nil)
spectreS.spss paramListBox string ""
spectreS.spss fundListBox string ""
spectreS.spss stimName string ""
spectreS.spss freqName string ""
spectreS.spss freqVal string ""
spectreS.spss signalLevel string "Moderate"
spectreS.spss srcId string ""
spectreS.spss maxHarms string ""
spectreS.spss freqPeriod string "Fundamental (Beat) Frequency"
spectreS.spss fund string ""
spectreS.spss period string ""
spectreS.spss harmonics string "None"
spectreS.spss numharmonics string ""
spectreS.spss arrayharmonics string ""
spectreS.spss none string "0"
spectreS.spss selFreqFrom string ""
spectreS.spss selFreqTo string ""
spectreS.spss harmsAndFreqsTitle string ""
spectreS.spss harmsAndFreqs string ""
spectreS.spss errpreset string ""
spectreS.spss tstab string ""
spectreS.spss saveinit string ""
spectreS.spss oscana boolean nil
spectreS.spss oscRefNode string "/gnd!"
spectreS.spss oscNode string ""
spectreS.spss sweep string "frequency/period"
spectreS.spss designVar string ""
spectreS.spss rangeType string "Start-Stop"
spectreS.spss from string ""
spectreS.spss to string ""
spectreS.spss center string ""
spectreS.spss span string ""
spectreS.spss incrType string "Linear"
spectreS.spss stepTypeLin string "Step Size"
spectreS.spss stepTypeLog string "Points Per Decade"
spectreS.spss by string ""
spectreS.spss lin string ""
spectreS.spss dec string ""
spectreS.spss log string ""
spectreS.spss useDiscrete boolean nil
spectreS.spss values string ""
spectreS.spss analysisList string ""
spectreS.spss pacEnable boolean nil
spectreS.spss pacfund string ""
spectreS.spss pacRelative boolean nil
spectreS.spss pacsweeptype string ""
spectreS.spss pacharmonics string "Zero sideband only"
spectreS.spss pacnumharmonics string ""
spectreS.spss pacarrayharmonics string ""
spectreS.spss pacselFreqFrom string ""
spectreS.spss pacselFreqTo string ""
spectreS.spss pacharmsAndFreqsTitle string ""
spectreS.spss pacharmsAndFreqs string ""
spectreS.spss pnoiseEnable boolean nil
spectreS.spss pnoisefund string ""
spectreS.spss pnoiseRelative boolean nil
spectreS.spss pnoisesweeptype string ""
spectreS.spss pnoiseharmonics string "Zero sideband only"
spectreS.spss pnoisenumharmonics string ""
spectreS.spss pnoisearrayharmonics string ""
spectreS.spss pnoiseselFreqFrom string ""
spectreS.spss pnoiseselFreqTo string ""
spectreS.spss pnoiseharmsAndFreqsTitle string ""
spectreS.spss pnoiseharmsAndFreqs string ""
spectreS.spss pnoiseoutProbeType string "voltage"
spectreS.spss pnoisenegNode string "/gnd!"
spectreS.spss pnoiseposNode string ""
spectreS.spss pnoiseoutVsrc string ""
spectreS.spss pnoiseinNoiseType string "none"
spectreS.spss pnoiseinVsrc string ""
spectreS.spss pnoiseinIsrc string ""
spectreS.spss pnoiseinPort string ""
spectreS.spss pnoiserefsideband string ""
spectreS.spss pxfEnable boolean nil
spectreS.spss pxffund string ""
spectreS.spss pxfRelative boolean nil
spectreS.spss pxfsweeptype string ""
spectreS.spss pxfharmonics string "Zero sideband only"
spectreS.spss pxfnumharmonics string ""
spectreS.spss pxfarrayharmonics string ""
spectreS.spss pxfselFreqFrom string ""
spectreS.spss pxfselFreqTo string ""
spectreS.spss pxfharmsAndFreqsTitle string ""
spectreS.spss pxfharmsAndFreqs string ""
spectreS.spss pxfoutProbeType string "voltage"
spectreS.spss pxfnegNode string "/gnd!"
spectreS.spss pxfposNode string ""
spectreS.spss pxfoutVsrc string ""
;spectreS spssOpts partition variables
spectreS.spssOpts step string ""
spectreS.spssOpts maxstep string ""
spectreS.spssOpts ic string ""
spectreS.spssOpts skipdc string ""
spectreS.spssOpts readic string ""
spectreS.spssOpts readns string ""
spectreS.spssOpts cmin string ""
spectreS.spssOpts write string ""
spectreS.spssOpts writefinal string ""
spectreS.spssOpts swapfile string ""
spectreS.spssOpts method string ""
spectreS.spssOpts relref string ""
spectreS.spssOpts lteratio string ""
spectreS.spssOpts steadyratio string ""
spectreS.spssOpts maxacfreq string ""
spectreS.spssOpts maxperiods string ""
spectreS.spssOpts stats string ""
spectreS.spssOpts annotate string "status"
spectreS.spssOpts oppoint string ""
spectreS.spssOpts skipstart string ""
spectreS.spssOpts skipstop string ""
spectreS.spssOpts skipcount string ""
spectreS.spssOpts strobeperiod string ""
spectreS.spssOpts strobedelay string ""
spectreS.spssOpts compression string ""
spectreS.spssOpts maxiters string ""
spectreS.spssOpts restart string ""
spectreS.spssOpts tstart string ""
spectreS.spssOpts tolerance string ""
spectreS.spssOpts gearorder string ""
spectreS.spssOpts solver string ""
spectreS.spssOpts stats2 string ""
spectreS.spssOpts annotate2 string "status"
spectreS.spssOpts freqaxis string ""
spectreS.spssOpts tolerance2 string ""
spectreS.spssOpts gearorder2 string ""
spectreS.spssOpts solver2 string ""
spectreS.spssOpts stats3 string ""
spectreS.spssOpts annotate3 string "status"
spectreS.spssOpts stimuli string ""
spectreS.spssOpts freqaxis2 string ""
spectreS.spssOpts tolerance3 string ""
spectreS.spssOpts gearorder3 string ""
spectreS.spssOpts solver3 string ""
spectreS.spssOpts stats4 string ""
spectreS.spssOpts annotate4 string "status"
;spectreS pss partition variables
spectreS.pss enable toggle (nil)
spectreS.pss paramListBox string ""
spectreS.pss fundListBox string ""
spectreS.pss stimName string ""
spectreS.pss freqName string ""
spectreS.pss freqVal string ""
spectreS.pss signalLevel string "Moderate"
spectreS.pss srcId string ""
spectreS.pss maxHarms string ""
spectreS.pss freqPeriod string "Fundamental (Beat) Frequency"
spectreS.pss fund string ""
spectreS.pss period string ""
spectreS.pss harmonics string "None"
spectreS.pss numharmonics string ""
spectreS.pss arrayharmonics string ""
spectreS.pss none string "0"
spectreS.pss selFreqFrom string ""
spectreS.pss selFreqTo string ""
spectreS.pss harmsAndFreqsTitle string ""
spectreS.pss harmsAndFreqs string ""
spectreS.pss errpreset string ""
spectreS.pss tstab string ""
spectreS.pss saveinit string ""
spectreS.pss oscana boolean nil
spectreS.pss oscRefNode string "/gnd!"
spectreS.pss oscNode string ""
spectreS.pss analysisList string ""
spectreS.pss pacEnable boolean nil
spectreS.pss pacRelative boolean nil
spectreS.pss pacsweeptype string ""
spectreS.pss pacrangeType string "Start-Stop"
spectreS.pss pacfrom string ""
spectreS.pss pacto string ""
spectreS.pss paccenter string ""
spectreS.pss pacspan string ""
spectreS.pss pacincrType string "Automatic"
spectreS.pss pacstepTypeLin string "Step Size"
spectreS.pss pacstepTypeLog string "Points Per Decade"
spectreS.pss pacby string ""
spectreS.pss paclin string ""
spectreS.pss pacdec string ""
spectreS.pss paclog string ""
spectreS.pss pacuseDiscrete boolean nil
spectreS.pss pacvalues string ""
spectreS.pss pacharmonics string "Zero sideband only"
spectreS.pss pacnumharmonics string ""
spectreS.pss pacarrayharmonics string ""
spectreS.pss pacselFreqFrom string ""
spectreS.pss pacselFreqTo string ""
spectreS.pss pacharmsAndFreqsTitle string ""
spectreS.pss pacharmsAndFreqs string ""
spectreS.pss pnoiseEnable boolean nil
spectreS.pss pnoiseRelative boolean nil
spectreS.pss pnoisesweeptype string ""
spectreS.pss pnoiserangeType string "Start-Stop"
spectreS.pss pnoisefrom string ""
spectreS.pss pnoiseto string ""
spectreS.pss pnoisecenter string ""
spectreS.pss pnoisespan string ""
spectreS.pss pnoiseincrType string "Automatic"
spectreS.pss pnoisestepTypeLin string "Step Size"
spectreS.pss pnoisestepTypeLog string "Points Per Decade"
spectreS.pss pnoiseby string ""
spectreS.pss pnoiselin string ""
spectreS.pss pnoisedec string ""
spectreS.pss pnoiselog string ""
spectreS.pss pnoiseuseDiscrete boolean nil
spectreS.pss pnoisevalues string ""
spectreS.pss pnoiseharmonics string "Zero sideband only"
spectreS.pss pnoisenumharmonics string ""
spectreS.pss pnoisearrayharmonics string ""
spectreS.pss pnoiseselFreqFrom string ""
spectreS.pss pnoiseselFreqTo string ""
spectreS.pss pnoiseharmsAndFreqsTitle string ""
spectreS.pss pnoiseharmsAndFreqs string ""
spectreS.pss pnoiseoutProbeType string "voltage"
spectreS.pss pnoisenegNode string "/gnd!"
spectreS.pss pnoiseposNode string ""
spectreS.pss pnoiseoutVsrc string ""
spectreS.pss pnoiseinNoiseType string "none"
spectreS.pss pnoiseinVsrc string ""
spectreS.pss pnoiseinIsrc string ""
spectreS.pss pnoiseinPort string ""
spectreS.pss pnoiserefsideband string ""
spectreS.pss pxfEnable boolean nil
spectreS.pss pxfRelative boolean nil
spectreS.pss pxfsweeptype string ""
spectreS.pss pxfrangeType string "Start-Stop"
spectreS.pss pxffrom string ""
spectreS.pss pxfto string ""
spectreS.pss pxfcenter string ""
spectreS.pss pxfspan string ""
spectreS.pss pxfincrType string "Automatic"
spectreS.pss pxfstepTypeLin string "Step Size"
spectreS.pss pxfstepTypeLog string "Points Per Decade"
spectreS.pss pxfby string ""
spectreS.pss pxflin string ""
spectreS.pss pxfdec string ""
spectreS.pss pxflog string ""
spectreS.pss pxfuseDiscrete boolean nil
spectreS.pss pxfvalues string ""
spectreS.pss pxfharmonics string "Zero sideband only"
spectreS.pss pxfnumharmonics string ""
spectreS.pss pxfarrayharmonics string ""
spectreS.pss pxfselFreqFrom string ""
spectreS.pss pxfselFreqTo string ""
spectreS.pss pxfharmsAndFreqsTitle string ""
spectreS.pss pxfharmsAndFreqs string ""
spectreS.pss pxfoutProbeType string "voltage"
spectreS.pss pxfnegNode string "/gnd!"
spectreS.pss pxfposNode string ""
spectreS.pss pxfoutVsrc string ""
;spectreS pssOpts partition variables
spectreS.pssOpts step string ""
spectreS.pssOpts maxstep string ""
spectreS.pssOpts ic string ""
spectreS.pssOpts skipdc string ""
spectreS.pssOpts readic string ""
spectreS.pssOpts readns string ""
spectreS.pssOpts cmin string ""
spectreS.pssOpts write string ""
spectreS.pssOpts writefinal string ""
spectreS.pssOpts swapfile string ""
spectreS.pssOpts method string ""
spectreS.pssOpts relref string ""
spectreS.pssOpts lteratio string ""
spectreS.pssOpts steadyratio string ""
spectreS.pssOpts maxacfreq string ""
spectreS.pssOpts maxperiods string ""
spectreS.pssOpts stats string ""
spectreS.pssOpts annotate string "status"
spectreS.pssOpts oppoint string ""
spectreS.pssOpts skipstart string ""
spectreS.pssOpts skipstop string ""
spectreS.pssOpts skipcount string ""
spectreS.pssOpts strobeperiod string ""
spectreS.pssOpts strobedelay string ""
spectreS.pssOpts compression string ""
spectreS.pssOpts maxiters string ""
spectreS.pssOpts restart string ""
spectreS.pssOpts tstart string ""
spectreS.pssOpts tolerance string ""
spectreS.pssOpts gearorder string ""
spectreS.pssOpts solver string ""
spectreS.pssOpts stats2 string ""
spectreS.pssOpts annotate2 string "status"
spectreS.pssOpts freqaxis string ""
spectreS.pssOpts tolerance2 string ""
spectreS.pssOpts gearorder2 string ""
spectreS.pssOpts solver2 string ""
spectreS.pssOpts stats3 string ""
spectreS.pssOpts annotate3 string "status"
spectreS.pssOpts stimuli string ""
spectreS.pssOpts freqaxis2 string ""
spectreS.pssOpts tolerance3 string ""
spectreS.pssOpts gearorder3 string ""
spectreS.pssOpts solver3 string ""
spectreS.pssOpts stats4 string ""
spectreS.pssOpts annotate4 string "status"
;spectreS pdisto partition variables
spectreS.pdisto enable toggle (nil)
spectreS.pdisto paramListBox string ""
spectreS.pdisto fundListBox string ""
spectreS.pdisto stimName string ""
spectreS.pdisto freqName string ""
spectreS.pdisto freqVal string ""
spectreS.pdisto signalLevel string "Moderate"
spectreS.pdisto srcId string ""
spectreS.pdisto maxHarms string ""
spectreS.pdisto fundsList string ""
spectreS.pdisto maxHarmsList string ""
spectreS.pdisto errpreset string ""
spectreS.pdisto tstab string ""
spectreS.pdisto saveinit string ""
;spectreS pdistoOpts partition variables
spectreS.pdistoOpts step string ""
spectreS.pdistoOpts maxstep string ""
spectreS.pdistoOpts ic string ""
spectreS.pdistoOpts skipdc string ""
spectreS.pdistoOpts readic string ""
spectreS.pdistoOpts readns string ""
spectreS.pdistoOpts cmin string ""
spectreS.pdistoOpts tolerance string ""
spectreS.pdistoOpts gearorder string ""
spectreS.pdistoOpts solver string ""
spectreS.pdistoOpts write string ""
spectreS.pdistoOpts writefinal string ""
spectreS.pdistoOpts swapfile string ""
spectreS.pdistoOpts method string ""
spectreS.pdistoOpts relref string ""
spectreS.pdistoOpts lteratio string ""
spectreS.pdistoOpts steadyratio string ""
spectreS.pdistoOpts maxacfreq string ""
spectreS.pdistoOpts maxperiods string ""
spectreS.pdistoOpts stats string ""
spectreS.pdistoOpts annotate string "status"
spectreS.pdistoOpts oppoint string ""
spectreS.pdistoOpts skipstart string ""
spectreS.pdistoOpts skipstop string ""
spectreS.pdistoOpts skipcount string ""
spectreS.pdistoOpts strobeperiod string ""
spectreS.pdistoOpts strobedelay string ""
spectreS.pdistoOpts compression string ""
spectreS.pdistoOpts freqaxis string ""
spectreS.pdistoOpts maxiters string ""
spectreS.pdistoOpts restart string ""
spectreS.pdistoOpts tstart string ""
;spectreS spac partition variables
spectreS.spac enable toggle (nil)
spectreS.spac fund string ""
spectreS.spac Relative boolean nil
spectreS.spac sweeptype string ""
spectreS.spac harmonics string "Zero sideband only"
spectreS.spac numharmonics string ""
spectreS.spac arrayharmonics string ""
spectreS.spac selFreqFrom string ""
spectreS.spac selFreqTo string ""
spectreS.spac harmsAndFreqsTitle string ""
spectreS.spac harmsAndFreqs string ""
;spectreS spacOpts partition variables
spectreS.spacOpts tolerance string ""
spectreS.spacOpts gearorder string ""
spectreS.spacOpts solver string ""
spectreS.spacOpts stats2 string ""
spectreS.spacOpts annotate2 string "status"
spectreS.spacOpts freqaxis string ""
;spectreS spnoise partition variables
spectreS.spnoise enable toggle (nil)
spectreS.spnoise fund string ""
spectreS.spnoise Relative boolean nil
spectreS.spnoise sweeptype string ""
spectreS.spnoise harmonics string "Zero sideband only"
spectreS.spnoise numharmonics string ""
spectreS.spnoise arrayharmonics string ""
spectreS.spnoise selFreqFrom string ""
spectreS.spnoise selFreqTo string ""
spectreS.spnoise harmsAndFreqsTitle string ""
spectreS.spnoise harmsAndFreqs string ""
spectreS.spnoise outType string "voltage"
spectreS.spnoise negNode string "/gnd!"
spectreS.spnoise posNode string ""
spectreS.spnoise outVsrc string ""
spectreS.spnoise inNoiseType string "none"
spectreS.spnoise inVsrc string ""
spectreS.spnoise inIsrc string ""
spectreS.spnoise inPort string ""
spectreS.spnoise refsideband string ""
;spectreS spnoiseOpts partition variables
spectreS.spnoiseOpts tolerance3 string ""
spectreS.spnoiseOpts gearorder3 string ""
spectreS.spnoiseOpts solver3 string ""
spectreS.spnoiseOpts stats4 string ""
spectreS.spnoiseOpts annotate4 string "status"
;spectreS spxf partition variables
spectreS.spxf enable toggle (nil)
spectreS.spxf fund string ""
spectreS.spxf Relative boolean nil
spectreS.spxf sweeptype string ""
spectreS.spxf harmonics string "Zero sideband only"
spectreS.spxf numharmonics string ""
spectreS.spxf arrayharmonics string ""
spectreS.spxf selFreqFrom string ""
spectreS.spxf selFreqTo string ""
spectreS.spxf harmsAndFreqsTitle string ""
spectreS.spxf harmsAndFreqs string ""
spectreS.spxf outType string "voltage"
spectreS.spxf negNode string "/gnd!"
spectreS.spxf posNode string ""
spectreS.spxf outVsrc string ""
;spectreS spxfOpts partition variables
spectreS.spxfOpts tolerance2 string ""
spectreS.spxfOpts gearorder2 string ""
spectreS.spxfOpts solver2 string ""
spectreS.spxfOpts stats3 string ""
spectreS.spxfOpts annotate3 string "status"
spectreS.spxfOpts stimuli string ""
spectreS.spxfOpts freqaxis2 string ""
;spectreS pac partition variables
spectreS.pac enable toggle (nil)
spectreS.pac fund string ""
spectreS.pac Relative boolean nil
spectreS.pac sweeptype string ""
spectreS.pac rangeType string "Start-Stop"
spectreS.pac from string ""
spectreS.pac to string ""
spectreS.pac center string ""
spectreS.pac span string ""
spectreS.pac incrType string "Automatic"
spectreS.pac stepTypeLin string "Step Size"
spectreS.pac stepTypeLog string "Points Per Decade"
spectreS.pac by string ""
spectreS.pac lin string ""
spectreS.pac dec string ""
spectreS.pac log string ""
spectreS.pac useDiscrete boolean nil
spectreS.pac values string ""
spectreS.pac harmonics string "Zero sideband only"
spectreS.pac numharmonics string ""
spectreS.pac arrayharmonics string ""
spectreS.pac selFreqFrom string ""
spectreS.pac selFreqTo string ""
spectreS.pac harmsAndFreqsTitle string ""
spectreS.pac harmsAndFreqs string ""
;spectreS pacOpts partition variables
spectreS.pacOpts tolerance string ""
spectreS.pacOpts gearorder string ""
spectreS.pacOpts solver string ""
spectreS.pacOpts stats2 string ""
spectreS.pacOpts annotate2 string "status"
spectreS.pacOpts freqaxis string ""
;spectreS pnoise partition variables
spectreS.pnoise enable toggle (nil)
spectreS.pnoise fund string ""
spectreS.pnoise Relative boolean nil
spectreS.pnoise sweeptype string ""
spectreS.pnoise rangeType string "Start-Stop"
spectreS.pnoise from string ""
spectreS.pnoise to string ""
spectreS.pnoise center string ""
spectreS.pnoise span string ""
spectreS.pnoise incrType string "Automatic"
spectreS.pnoise stepTypeLin string "Step Size"
spectreS.pnoise stepTypeLog string "Points Per Decade"
spectreS.pnoise by string ""
spectreS.pnoise lin string ""
spectreS.pnoise dec string ""
spectreS.pnoise log string ""
spectreS.pnoise useDiscrete boolean nil
spectreS.pnoise values string ""
spectreS.pnoise harmonics string "Zero sideband only"
spectreS.pnoise numharmonics string ""
spectreS.pnoise arrayharmonics string ""
spectreS.pnoise selFreqFrom string ""
spectreS.pnoise selFreqTo string ""
spectreS.pnoise harmsAndFreqsTitle string ""
spectreS.pnoise harmsAndFreqs string ""
spectreS.pnoise outType string "voltage"
spectreS.pnoise negNode string "/gnd!"
spectreS.pnoise posNode string ""
spectreS.pnoise outVsrc string ""
spectreS.pnoise inNoiseType string "none"
spectreS.pnoise inVsrc string ""
spectreS.pnoise inIsrc string ""
spectreS.pnoise inPort string ""
spectreS.pnoise refsideband string ""
;spectreS pnoiseOpts partition variables
spectreS.pnoiseOpts tolerance3 string ""
spectreS.pnoiseOpts gearorder3 string ""
spectreS.pnoiseOpts solver3 string ""
spectreS.pnoiseOpts stats4 string ""
spectreS.pnoiseOpts annotate4 string "status"
;spectreS pxf partition variables
spectreS.pxf enable toggle (nil)
spectreS.pxf fund string ""
spectreS.pxf Relative boolean nil
spectreS.pxf sweeptype string ""
spectreS.pxf rangeType string "Start-Stop"
spectreS.pxf from string ""
spectreS.pxf to string ""
spectreS.pxf center string ""
spectreS.pxf span string ""
spectreS.pxf incrType string "Automatic"
spectreS.pxf stepTypeLin string "Step Size"
spectreS.pxf stepTypeLog string "Points Per Decade"
spectreS.pxf by string ""
spectreS.pxf lin string ""
spectreS.pxf dec string ""
spectreS.pxf log string ""
spectreS.pxf useDiscrete boolean nil
spectreS.pxf values string ""
spectreS.pxf harmonics string "Zero sideband only"
spectreS.pxf numharmonics string ""
spectreS.pxf arrayharmonics string ""
spectreS.pxf selFreqFrom string ""
spectreS.pxf selFreqTo string ""
spectreS.pxf harmsAndFreqsTitle string ""
spectreS.pxf harmsAndFreqs string ""
spectreS.pxf outType string "voltage"
spectreS.pxf negNode string "/gnd!"
spectreS.pxf posNode string ""
spectreS.pxf outVsrc string ""
;spectreS pxfOpts partition variables
spectreS.pxfOpts tolerance2 string ""
spectreS.pxfOpts gearorder2 string ""
spectreS.pxfOpts solver2 string ""
spectreS.pxfOpts stats3 string ""
spectreS.pxfOpts annotate3 string "status"
spectreS.pxfOpts stimuli string ""
spectreS.pxfOpts freqaxis2 string ""
;spectreSVerilog environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spectreSVerilog opts partition variables
spectreSVerilog.opts title string ""
spectreSVerilog.opts audit string ""
spectreSVerilog.opts ckptclock string "1800"
spectreSVerilog.opts flow string ""
spectreSVerilog.opts cols string "80"
spectreSVerilog.opts opptcheck string ""
spectreSVerilog.opts reltol string "1e-3"
spectreSVerilog.opts notation string ""
spectreSVerilog.opts warn string ""
spectreSVerilog.opts approx string ""
spectreSVerilog.opts info string ""
spectreSVerilog.opts quantities string ""
spectreSVerilog.opts pivabs string ""
spectreSVerilog.opts compatible string ""
spectreSVerilog.opts ignshorts string ""
spectreSVerilog.opts gmin string "1e-12"
spectreSVerilog.opts rforce string "1"
spectreSVerilog.opts homotopy string ""
spectreSVerilog.opts iabstol string "1e-12"
spectreSVerilog.opts debug string ""
spectreSVerilog.opts tempeffects string ""
spectreSVerilog.opts maxwarns string "5"
spectreSVerilog.opts vabstol string "1e-6"
spectreSVerilog.opts tnom string "27"
spectreSVerilog.opts temp string "27"
spectreSVerilog.opts gmin_check string ""
spectreSVerilog.opts value string ""
spectreSVerilog.opts narrate string ""
spectreSVerilog.opts scale string "1.0"
spectreSVerilog.opts diagnose string ""
spectreSVerilog.opts digits string "5"
spectreSVerilog.opts pivotdc string ""
spectreSVerilog.opts pivrel string "1e-3"
spectreSVerilog.opts scalem string "1.0"
spectreSVerilog.opts limit string ""
spectreSVerilog.opts topcheck string ""
spectreSVerilog.opts inventory string ""
spectreSVerilog.opts error string ""
;spectreSVerilog outputs partition variables
spectreSVerilog.outputs allAnalogACTC boolean nil
spectreSVerilog.outputs allDigitalNV boolean t
spectreSVerilog.outputs allAnalogNV boolean t
spectreSVerilog.outputs allAhdlVars boolean nil
spectreSVerilog.outputs allAnalogTC boolean nil
;spectreSVerilog verimixOpts partition variables
spectreSVerilog.verimixOpts filename6 string ""
spectreSVerilog.verimixOpts maxDCIter int 0
spectreSVerilog.verimixOpts scope1 string ""
spectreSVerilog.verimixOpts scope10 string ""
spectreSVerilog.verimixOpts filename8 string ""
spectreSVerilog.verimixOpts dcInterval float 0.0
spectreSVerilog.verimixOpts scope3 string ""
spectreSVerilog.verimixOpts scope8 string ""
spectreSVerilog.verimixOpts scope7 string ""
spectreSVerilog.verimixOpts filename7 string ""
spectreSVerilog.verimixOpts scope string ""
spectreSVerilog.verimixOpts filename4 string ""
spectreSVerilog.verimixOpts filename string ""
spectreSVerilog.verimixOpts filename1 string ""
spectreSVerilog.verimixOpts scope9 string ""
spectreSVerilog.verimixOpts importsdfswitch boolean nil
spectreSVerilog.verimixOpts filename2 string ""
spectreSVerilog.verimixOpts numberofsdffiles int 2
spectreSVerilog.verimixOpts scope2 string ""
spectreSVerilog.verimixOpts scope6 string ""
spectreSVerilog.verimixOpts filename10 string ""
spectreSVerilog.verimixOpts delaymodechoice string "Ignore"
spectreSVerilog.verimixOpts sdfmixedswitch boolean t
spectreSVerilog.verimixOpts filename9 string ""
spectreSVerilog.verimixOpts scope5 string ""
spectreSVerilog.verimixOpts filename5 string ""
spectreSVerilog.verimixOpts filename3 string ""
spectreSVerilog.verimixOpts scope4 string ""
;spectreSVerilog verilogOpts partition variables
spectreSVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
spectreSVerilog.verilogOpts optionsFile string ""
spectreSVerilog.verilogOpts twinTurbo boolean nil
spectreSVerilog.verilogOpts suppressMessages boolean nil
spectreSVerilog.verilogOpts libraryFile string ""
spectreSVerilog.verilogOpts behaveProfile boolean nil
spectreSVerilog.verilogOpts verimixLog string "verilog.log"
spectreSVerilog.verilogOpts simVision boolean nil
spectreSVerilog.verilogOpts pulseSpec boolean nil
spectreSVerilog.verilogOpts commandFile string ""
spectreSVerilog.verilogOpts pulseError int 100
spectreSVerilog.verilogOpts stopCompile boolean nil
spectreSVerilog.verilogOpts keepNodes string "Minimum"
spectreSVerilog.verilogOpts accelerationCA boolean nil
spectreSVerilog.verilogOpts turboRadio string "Default"
spectreSVerilog.verilogOpts libraryDir string ""
spectreSVerilog.verilogOpts suppressWarnings boolean nil
spectreSVerilog.verilogOpts accelerationSwitches boolean nil
spectreSVerilog.verilogOpts accelerationNormal boolean t
spectreSVerilog.verilogOpts delayType string "Typical"
spectreSVerilog.verilogOpts pulseReject int 100
spectreSVerilog.verilogOpts delayMode string "Default"
spectreSVerilog.verilogOpts vermixBinary string "verilog.vmx"
;spectreSVerilog init partition variables
spectreSVerilog.init processPriority int 0
;spectreSVerilog envOpts partition variables
spectreSVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreSVerilog.envOpts mspNetlistMode string "Flat"
spectreSVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
spectreSVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
spectreSVerilog.envOpts outputFormat string "AWD"
spectreSVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
spectreSVerilog.envOpts mspSetupNetlistEscapeName boolean nil
spectreSVerilog.envOpts updateFile string ""
spectreSVerilog.envOpts stimulusFile string ""
spectreSVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
spectreSVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
spectreSVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
spectreSVerilog.envOpts includeSyntax string "cdsSpice"
spectreSVerilog.envOpts mspSetupNetlistPinMap boolean nil
spectreSVerilog.envOpts mspSetupNetlistBus boolean t
spectreSVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
spectreSVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
spectreSVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
spectreSVerilog.envOpts mspSetupNetlistExplicit boolean nil
spectreSVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
spectreSVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
spectreSVerilog.envOpts paramRangeCheckFile string ""
spectreSVerilog.envOpts initFile string ""
spectreSVerilog.envOpts printComments boolean nil
spectreSVerilog.envOpts includeFile string ""
spectreSVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
spectreSVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
spectreSVerilog.envOpts recover boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreSVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimTimeValue int 1
spectreSVerilog.envOpts mspSetupNetlistUseLib boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
spectreSVerilog.envOpts mspSetupNetlistNullPort boolean nil
spectreSVerilog.envOpts mspSetupNetlistDropPortRange boolean t
spectreSVerilog.envOpts mspSetupNetlistUpCase boolean nil
spectreSVerilog.envOpts generateMapFile boolean nil
spectreSVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;spectreSVerilog tran partition variables
spectreSVerilog.tran enable toggle (nil)
spectreSVerilog.tran to string ""
spectreSVerilog.tran errpreset string ""
;spectreSVerilog tranOpts partition variables
spectreSVerilog.tranOpts start string ""
spectreSVerilog.tranOpts outputstart string ""
spectreSVerilog.tranOpts step string ""
spectreSVerilog.tranOpts maxstep string ""
spectreSVerilog.tranOpts ic string ""
spectreSVerilog.tranOpts skipdc string ""
spectreSVerilog.tranOpts readic string ""
spectreSVerilog.tranOpts readns string ""
spectreSVerilog.tranOpts cmin string ""
spectreSVerilog.tranOpts write string "spectre.ic"
spectreSVerilog.tranOpts writefinal string "spectre.fc"
spectreSVerilog.tranOpts ckptperiod string ""
spectreSVerilog.tranOpts method string "default"
spectreSVerilog.tranOpts relref string "default"
spectreSVerilog.tranOpts lteratio string ""
spectreSVerilog.tranOpts stats string ""
spectreSVerilog.tranOpts annotate string "status"
spectreSVerilog.tranOpts oppoint string ""
spectreSVerilog.tranOpts skipstart string ""
spectreSVerilog.tranOpts skipstop string ""
spectreSVerilog.tranOpts skipcount string ""
spectreSVerilog.tranOpts strobeperiod string ""
spectreSVerilog.tranOpts strobedelay string ""
spectreSVerilog.tranOpts compression string "no"
spectreSVerilog.tranOpts maxiters string "5"
spectreSVerilog.tranOpts restart string ""
;spectreSVerilog ac partition variables
spectreSVerilog.ac enable toggle (nil)
spectreSVerilog.ac sweep string "Frequency"
spectreSVerilog.ac freq string ""
spectreSVerilog.ac device string ""
spectreSVerilog.ac deviceParam string ""
spectreSVerilog.ac model string ""
spectreSVerilog.ac modelParam string ""
spectreSVerilog.ac temperature string "temp"
spectreSVerilog.ac rangeType string "Start-Stop"
spectreSVerilog.ac from string ""
spectreSVerilog.ac to string ""
spectreSVerilog.ac center string ""
spectreSVerilog.ac span string ""
spectreSVerilog.ac incrType string "Automatic"
spectreSVerilog.ac stepTypeLin string "Step Size"
spectreSVerilog.ac stepTypeLog string "Points Per Decade"
spectreSVerilog.ac by string ""
spectreSVerilog.ac lin string ""
spectreSVerilog.ac dec string ""
spectreSVerilog.ac log string ""
spectreSVerilog.ac useDiscrete boolean nil
spectreSVerilog.ac values string ""
;spectreSVerilog acOpts partition variables
spectreSVerilog.acOpts readns string ""
spectreSVerilog.acOpts oppoint string ""
spectreSVerilog.acOpts restart string ""
spectreSVerilog.acOpts annotate string "status"
spectreSVerilog.acOpts stats string ""
;spectreSVerilog dc partition variables
spectreSVerilog.dc enable toggle (nil)
spectreSVerilog.dcop enable toggle (nil)
spectreSVerilog.dc saveOppoint boolean nil
spectreSVerilog.dc oppoint string "rawfile"
spectreSVerilog.dc save string "allpub"
spectreSVerilog.dc sweep string ""
spectreSVerilog.dc device string ""
spectreSVerilog.dc deviceParam string ""
spectreSVerilog.dc model string ""
spectreSVerilog.dc modelParam string ""
spectreSVerilog.dc temperature string "temp"
spectreSVerilog.dc rangeType string "Start-Stop"
spectreSVerilog.dc from string ""
spectreSVerilog.dc to string ""
spectreSVerilog.dc center string ""
spectreSVerilog.dc span string ""
spectreSVerilog.dc incrType string "Automatic"
spectreSVerilog.dc stepTypeLin string "Step Size"
spectreSVerilog.dc stepTypeLog string "Points Per Decade"
spectreSVerilog.dc by string ""
spectreSVerilog.dc lin string ""
spectreSVerilog.dc dec string ""
spectreSVerilog.dc log string ""
spectreSVerilog.dc useDiscrete boolean nil
spectreSVerilog.dc values string ""
;spectreSVerilog dcOpts partition variables
spectreSVerilog.dcOpts force string ""
spectreSVerilog.dcopOpts force string ""
spectreSVerilog.dcOpts readns string ""
spectreSVerilog.dcopOpts readns string ""
spectreSVerilog.dcOpts readforce string ""
spectreSVerilog.dcopOpts readforce string ""
spectreSVerilog.dcOpts write string "spectre.dc"
spectreSVerilog.dcopOpts write string "spectre.dc"
spectreSVerilog.dcOpts writefinal string ""
spectreSVerilog.dcopOpts writefinal string ""
spectreSVerilog.dcOpts print string ""
spectreSVerilog.dcopOpts print string ""
spectreSVerilog.dcOpts check string ""
spectreSVerilog.dcopOpts check string ""
spectreSVerilog.dcOpts homotopy string ""
spectreSVerilog.dcopOpts homotopy string ""
spectreSVerilog.dcOpts restart string ""
spectreSVerilog.dcopOpts restart string ""
spectreSVerilog.dcOpts maxiters string "150"
spectreSVerilog.dcopOpts maxiters string "150"
spectreSVerilog.dcOpts maxsteps string "10000"
spectreSVerilog.dcopOpts maxsteps string "10000"
spectreSVerilog.dcOpts annotate string "status"
spectreSVerilog.dcopOpts annotate string "status"
;spectreSVerilog noise partition variables
spectreSVerilog.noise enable toggle (nil)
spectreSVerilog.noise sweep string "Frequency"
spectreSVerilog.noise freq string ""
spectreSVerilog.noise device string ""
spectreSVerilog.noise deviceParam string ""
spectreSVerilog.noise model string ""
spectreSVerilog.noise modelParam string ""
spectreSVerilog.noise temperature string "temp"
spectreSVerilog.noise rangeType string "Start-Stop"
spectreSVerilog.noise from string ""
spectreSVerilog.noise to string ""
spectreSVerilog.noise center string ""
spectreSVerilog.noise span string ""
spectreSVerilog.noise incrType string "Automatic"
spectreSVerilog.noise stepTypeLin string "Step Size"
spectreSVerilog.noise stepTypeLog string "Points Per Decade"
spectreSVerilog.noise by string ""
spectreSVerilog.noise lin string ""
spectreSVerilog.noise dec string ""
spectreSVerilog.noise log string ""
spectreSVerilog.noise useDiscrete boolean nil
spectreSVerilog.noise values string ""
spectreSVerilog.noise outNoiseType string "voltage"
spectreSVerilog.noise negNode string "/gnd!"
spectreSVerilog.noise posNode string ""
spectreSVerilog.noise outVsrc string ""
spectreSVerilog.noise inNoiseType string "voltage"
spectreSVerilog.noise inVsrc string ""
spectreSVerilog.noise inIsrc string ""
spectreSVerilog.noise inPort string ""
;spectreSVerilog noiseOpts partition variables
spectreSVerilog.noiseOpts readns string ""
spectreSVerilog.noiseOpts oppoint string ""
spectreSVerilog.noiseOpts restart string ""
spectreSVerilog.noiseOpts annotate string "status"
spectreSVerilog.noiseOpts stats string ""
;spectreSVerilog xf partition variables
spectreSVerilog.xf enable toggle (nil)
spectreSVerilog.xf sweep string "Frequency"
spectreSVerilog.xf freq string ""
spectreSVerilog.xf device string ""
spectreSVerilog.xf deviceParam string ""
spectreSVerilog.xf model string ""
spectreSVerilog.xf modelParam string ""
spectreSVerilog.xf temperature string "temp"
spectreSVerilog.xf rangeType string "Start-Stop"
spectreSVerilog.xf from string ""
spectreSVerilog.xf to string ""
spectreSVerilog.xf center string ""
spectreSVerilog.xf span string ""
spectreSVerilog.xf incrType string "Automatic"
spectreSVerilog.xf stepTypeLin string "Step Size"
spectreSVerilog.xf stepTypeLog string "Points Per Decade"
spectreSVerilog.xf by string ""
spectreSVerilog.xf lin string ""
spectreSVerilog.xf dec string ""
spectreSVerilog.xf log string ""
spectreSVerilog.xf useDiscrete boolean nil
spectreSVerilog.xf values string ""
spectreSVerilog.xf outXfType string "voltage"
spectreSVerilog.xf negNode string "/gnd!"
spectreSVerilog.xf posNode string ""
spectreSVerilog.xf outVsrc string ""
;spectreSVerilog xfOpts partition variables
spectreSVerilog.xfOpts readns string ""
spectreSVerilog.xfOpts stimuli string ""
spectreSVerilog.xfOpts oppoint string ""
spectreSVerilog.xfOpts restart string ""
spectreSVerilog.xfOpts annotate string "status"
spectreSVerilog.xfOpts stats string ""
;spectreSVerilog sp partition variables
spectreSVerilog.sp enable toggle (nil)
spectreSVerilog.sp sweep string "Frequency"
spectreSVerilog.sp frequency string ""
spectreSVerilog.sp device string ""
spectreSVerilog.sp deviceParam string ""
spectreSVerilog.sp model string ""
spectreSVerilog.sp modelParam string ""
spectreSVerilog.sp temperature string "temp"
spectreSVerilog.sp rangeType string "Start-Stop"
spectreSVerilog.sp from string ""
spectreSVerilog.sp to string ""
spectreSVerilog.sp center string ""
spectreSVerilog.sp span string ""
spectreSVerilog.sp incrType string "Automatic"
spectreSVerilog.sp stepTypeLin string "Step Size"
spectreSVerilog.sp stepTypeLog string "Points Per Decade"
spectreSVerilog.sp by string ""
spectreSVerilog.sp lin string ""
spectreSVerilog.sp dec string ""
spectreSVerilog.sp log string ""
spectreSVerilog.sp useDiscrete boolean nil
spectreSVerilog.sp values string ""
spectreSVerilog.sp donoise boolean nil
spectreSVerilog.sp oprobe string ""
spectreSVerilog.sp iprobe string ""
;spectreSVerilog spOpts partition variables
spectreSVerilog.spOpts readns string ""
spectreSVerilog.spOpts file string ""
spectreSVerilog.spOpts oppoint string ""
spectreSVerilog.spOpts reftemp string ""
spectreSVerilog.spOpts restart string ""
spectreSVerilog.spOpts annotate string "status"
spectreSVerilog.spOpts stats string ""
;spectreSVerilog spss partition variables
spectreSVerilog.spss enable toggle (nil)
spectreSVerilog.spss paramListBox string ""
spectreSVerilog.spss fundListBox string ""
spectreSVerilog.spss stimName string ""
spectreSVerilog.spss freqName string ""
spectreSVerilog.spss freqVal string ""
spectreSVerilog.spss signalLevel string "Moderate"
spectreSVerilog.spss srcId string ""
spectreSVerilog.spss maxHarms string ""
spectreSVerilog.spss freqPeriod string "Fundamental (Beat) Frequency"
spectreSVerilog.spss fund string ""
spectreSVerilog.spss period string ""
spectreSVerilog.spss harmonics string "None"
spectreSVerilog.spss numharmonics string ""
spectreSVerilog.spss arrayharmonics string ""
spectreSVerilog.spss none string "0"
spectreSVerilog.spss selFreqFrom string ""
spectreSVerilog.spss selFreqTo string ""
spectreSVerilog.spss harmsAndFreqsTitle string ""
spectreSVerilog.spss harmsAndFreqs string ""
spectreSVerilog.spss errpreset string ""
spectreSVerilog.spss tstab string ""
spectreSVerilog.spss saveinit string ""
spectreSVerilog.spss oscana boolean nil
spectreSVerilog.spss oscRefNode string "/gnd!"
spectreSVerilog.spss oscNode string ""
spectreSVerilog.spss sweep string "frequency/period"
spectreSVerilog.spss designVar string ""
spectreSVerilog.spss rangeType string "Start-Stop"
spectreSVerilog.spss from string ""
spectreSVerilog.spss to string ""
spectreSVerilog.spss center string ""
spectreSVerilog.spss span string ""
spectreSVerilog.spss incrType string "Linear"
spectreSVerilog.spss stepTypeLin string "Step Size"
spectreSVerilog.spss stepTypeLog string "Points Per Decade"
spectreSVerilog.spss by string ""
spectreSVerilog.spss lin string ""
spectreSVerilog.spss dec string ""
spectreSVerilog.spss log string ""
spectreSVerilog.spss useDiscrete boolean nil
spectreSVerilog.spss values string ""
spectreSVerilog.spss analysisList string ""
spectreSVerilog.spss pacEnable boolean nil
spectreSVerilog.spss pacfund string ""
spectreSVerilog.spss pacRelative boolean nil
spectreSVerilog.spss pacsweeptype string ""
spectreSVerilog.spss pacharmonics string "Zero sideband only"
spectreSVerilog.spss pacnumharmonics string ""
spectreSVerilog.spss pacarrayharmonics string ""
spectreSVerilog.spss pacselFreqFrom string ""
spectreSVerilog.spss pacselFreqTo string ""
spectreSVerilog.spss pacharmsAndFreqsTitle string ""
spectreSVerilog.spss pacharmsAndFreqs string ""
spectreSVerilog.spss pnoiseEnable boolean nil
spectreSVerilog.spss pnoisefund string ""
spectreSVerilog.spss pnoiseRelative boolean nil
spectreSVerilog.spss pnoisesweeptype string ""
spectreSVerilog.spss pnoiseharmonics string "Zero sideband only"
spectreSVerilog.spss pnoisenumharmonics string ""
spectreSVerilog.spss pnoisearrayharmonics string ""
spectreSVerilog.spss pnoiseselFreqFrom string ""
spectreSVerilog.spss pnoiseselFreqTo string ""
spectreSVerilog.spss pnoiseharmsAndFreqsTitle string ""
spectreSVerilog.spss pnoiseharmsAndFreqs string ""
spectreSVerilog.spss pnoiseoutProbeType string "voltage"
spectreSVerilog.spss pnoisenegNode string "/gnd!"
spectreSVerilog.spss pnoiseposNode string ""
spectreSVerilog.spss pnoiseoutVsrc string ""
spectreSVerilog.spss pnoiseinNoiseType string "none"
spectreSVerilog.spss pnoiseinVsrc string ""
spectreSVerilog.spss pnoiseinIsrc string ""
spectreSVerilog.spss pnoiseinPort string ""
spectreSVerilog.spss pnoiserefsideband string ""
spectreSVerilog.spss pxfEnable boolean nil
spectreSVerilog.spss pxffund string ""
spectreSVerilog.spss pxfRelative boolean nil
spectreSVerilog.spss pxfsweeptype string ""
spectreSVerilog.spss pxfharmonics string "Zero sideband only"
spectreSVerilog.spss pxfnumharmonics string ""
spectreSVerilog.spss pxfarrayharmonics string ""
spectreSVerilog.spss pxfselFreqFrom string ""
spectreSVerilog.spss pxfselFreqTo string ""
spectreSVerilog.spss pxfharmsAndFreqsTitle string ""
spectreSVerilog.spss pxfharmsAndFreqs string ""
spectreSVerilog.spss pxfoutProbeType string "voltage"
spectreSVerilog.spss pxfnegNode string "/gnd!"
spectreSVerilog.spss pxfposNode string ""
spectreSVerilog.spss pxfoutVsrc string ""
;spectreSVerilog spssOpts partition variables
spectreSVerilog.spssOpts step string ""
spectreSVerilog.spssOpts maxstep string ""
spectreSVerilog.spssOpts ic string ""
spectreSVerilog.spssOpts skipdc string ""
spectreSVerilog.spssOpts readic string ""
spectreSVerilog.spssOpts readns string ""
spectreSVerilog.spssOpts cmin string ""
spectreSVerilog.spssOpts write string ""
spectreSVerilog.spssOpts writefinal string ""
spectreSVerilog.spssOpts swapfile string ""
spectreSVerilog.spssOpts method string ""
spectreSVerilog.spssOpts relref string ""
spectreSVerilog.spssOpts lteratio string ""
spectreSVerilog.spssOpts steadyratio string ""
spectreSVerilog.spssOpts maxacfreq string ""
spectreSVerilog.spssOpts maxperiods string ""
spectreSVerilog.spssOpts stats string ""
spectreSVerilog.spssOpts annotate string "status"
spectreSVerilog.spssOpts oppoint string ""
spectreSVerilog.spssOpts skipstart string ""
spectreSVerilog.spssOpts skipstop string ""
spectreSVerilog.spssOpts skipcount string ""
spectreSVerilog.spssOpts strobeperiod string ""
spectreSVerilog.spssOpts strobedelay string ""
spectreSVerilog.spssOpts compression string ""
spectreSVerilog.spssOpts maxiters string ""
spectreSVerilog.spssOpts restart string ""
spectreSVerilog.spssOpts tstart string ""
spectreSVerilog.spssOpts tolerance string ""
spectreSVerilog.spssOpts gearorder string ""
spectreSVerilog.spssOpts solver string ""
spectreSVerilog.spssOpts stats2 string ""
spectreSVerilog.spssOpts annotate2 string "status"
spectreSVerilog.spssOpts freqaxis string ""
spectreSVerilog.spssOpts tolerance2 string ""
spectreSVerilog.spssOpts gearorder2 string ""
spectreSVerilog.spssOpts solver2 string ""
spectreSVerilog.spssOpts stats3 string ""
spectreSVerilog.spssOpts annotate3 string "status"
spectreSVerilog.spssOpts stimuli string ""
spectreSVerilog.spssOpts freqaxis2 string ""
spectreSVerilog.spssOpts tolerance3 string ""
spectreSVerilog.spssOpts gearorder3 string ""
spectreSVerilog.spssOpts solver3 string ""
spectreSVerilog.spssOpts stats4 string ""
spectreSVerilog.spssOpts annotate4 string "status"
;spectreSVerilog pss partition variables
spectreSVerilog.pss enable toggle (nil)
spectreSVerilog.pss paramListBox string ""
spectreSVerilog.pss fundListBox string ""
spectreSVerilog.pss stimName string ""
spectreSVerilog.pss freqName string ""
spectreSVerilog.pss freqVal string ""
spectreSVerilog.pss signalLevel string "Moderate"
spectreSVerilog.pss srcId string ""
spectreSVerilog.pss maxHarms string ""
spectreSVerilog.pss freqPeriod string "Fundamental (Beat) Frequency"
spectreSVerilog.pss fund string ""
spectreSVerilog.pss period string ""
spectreSVerilog.pss harmonics string "None"
spectreSVerilog.pss numharmonics string ""
spectreSVerilog.pss arrayharmonics string ""
spectreSVerilog.pss none string "0"
spectreSVerilog.pss selFreqFrom string ""
spectreSVerilog.pss selFreqTo string ""
spectreSVerilog.pss harmsAndFreqsTitle string ""
spectreSVerilog.pss harmsAndFreqs string ""
spectreSVerilog.pss errpreset string ""
spectreSVerilog.pss tstab string ""
spectreSVerilog.pss saveinit string ""
spectreSVerilog.pss oscana boolean nil
spectreSVerilog.pss oscRefNode string "/gnd!"
spectreSVerilog.pss oscNode string ""
spectreSVerilog.pss analysisList string ""
spectreSVerilog.pss pacEnable boolean nil
spectreSVerilog.pss pacRelative boolean nil
spectreSVerilog.pss pacsweeptype string ""
spectreSVerilog.pss pacrangeType string "Start-Stop"
spectreSVerilog.pss pacfrom string ""
spectreSVerilog.pss pacto string ""
spectreSVerilog.pss paccenter string ""
spectreSVerilog.pss pacspan string ""
spectreSVerilog.pss pacincrType string "Automatic"
spectreSVerilog.pss pacstepTypeLin string "Step Size"
spectreSVerilog.pss pacstepTypeLog string "Points Per Decade"
spectreSVerilog.pss pacby string ""
spectreSVerilog.pss paclin string ""
spectreSVerilog.pss pacdec string ""
spectreSVerilog.pss paclog string ""
spectreSVerilog.pss pacuseDiscrete boolean nil
spectreSVerilog.pss pacvalues string ""
spectreSVerilog.pss pacharmonics string "Zero sideband only"
spectreSVerilog.pss pacnumharmonics string ""
spectreSVerilog.pss pacarrayharmonics string ""
spectreSVerilog.pss pacselFreqFrom string ""
spectreSVerilog.pss pacselFreqTo string ""
spectreSVerilog.pss pacharmsAndFreqsTitle string ""
spectreSVerilog.pss pacharmsAndFreqs string ""
spectreSVerilog.pss pnoiseEnable boolean nil
spectreSVerilog.pss pnoiseRelative boolean nil
spectreSVerilog.pss pnoisesweeptype string ""
spectreSVerilog.pss pnoiserangeType string "Start-Stop"
spectreSVerilog.pss pnoisefrom string ""
spectreSVerilog.pss pnoiseto string ""
spectreSVerilog.pss pnoisecenter string ""
spectreSVerilog.pss pnoisespan string ""
spectreSVerilog.pss pnoiseincrType string "Automatic"
spectreSVerilog.pss pnoisestepTypeLin string "Step Size"
spectreSVerilog.pss pnoisestepTypeLog string "Points Per Decade"
spectreSVerilog.pss pnoiseby string ""
spectreSVerilog.pss pnoiselin string ""
spectreSVerilog.pss pnoisedec string ""
spectreSVerilog.pss pnoiselog string ""
spectreSVerilog.pss pnoiseuseDiscrete boolean nil
spectreSVerilog.pss pnoisevalues string ""
spectreSVerilog.pss pnoiseharmonics string "Zero sideband only"
spectreSVerilog.pss pnoisenumharmonics string ""
spectreSVerilog.pss pnoisearrayharmonics string ""
spectreSVerilog.pss pnoiseselFreqFrom string ""
spectreSVerilog.pss pnoiseselFreqTo string ""
spectreSVerilog.pss pnoiseharmsAndFreqsTitle string ""
spectreSVerilog.pss pnoiseharmsAndFreqs string ""
spectreSVerilog.pss pnoiseoutProbeType string "voltage"
spectreSVerilog.pss pnoisenegNode string "/gnd!"
spectreSVerilog.pss pnoiseposNode string ""
spectreSVerilog.pss pnoiseoutVsrc string ""
spectreSVerilog.pss pnoiseinNoiseType string "none"
spectreSVerilog.pss pnoiseinVsrc string ""
spectreSVerilog.pss pnoiseinIsrc string ""
spectreSVerilog.pss pnoiseinPort string ""
spectreSVerilog.pss pnoiserefsideband string ""
spectreSVerilog.pss pxfEnable boolean nil
spectreSVerilog.pss pxfRelative boolean nil
spectreSVerilog.pss pxfsweeptype string ""
spectreSVerilog.pss pxfrangeType string "Start-Stop"
spectreSVerilog.pss pxffrom string ""
spectreSVerilog.pss pxfto string ""
spectreSVerilog.pss pxfcenter string ""
spectreSVerilog.pss pxfspan string ""
spectreSVerilog.pss pxfincrType string "Automatic"
spectreSVerilog.pss pxfstepTypeLin string "Step Size"
spectreSVerilog.pss pxfstepTypeLog string "Points Per Decade"
spectreSVerilog.pss pxfby string ""
spectreSVerilog.pss pxflin string ""
spectreSVerilog.pss pxfdec string ""
spectreSVerilog.pss pxflog string ""
spectreSVerilog.pss pxfuseDiscrete boolean nil
spectreSVerilog.pss pxfvalues string ""
spectreSVerilog.pss pxfharmonics string "Zero sideband only"
spectreSVerilog.pss pxfnumharmonics string ""
spectreSVerilog.pss pxfarrayharmonics string ""
spectreSVerilog.pss pxfselFreqFrom string ""
spectreSVerilog.pss pxfselFreqTo string ""
spectreSVerilog.pss pxfharmsAndFreqsTitle string ""
spectreSVerilog.pss pxfharmsAndFreqs string ""
spectreSVerilog.pss pxfoutProbeType string "voltage"
spectreSVerilog.pss pxfnegNode string "/gnd!"
spectreSVerilog.pss pxfposNode string ""
spectreSVerilog.pss pxfoutVsrc string ""
;spectreSVerilog pssOpts partition variables
spectreSVerilog.pssOpts step string ""
spectreSVerilog.pssOpts maxstep string ""
spectreSVerilog.pssOpts ic string ""
spectreSVerilog.pssOpts skipdc string ""
spectreSVerilog.pssOpts readic string ""
spectreSVerilog.pssOpts readns string ""
spectreSVerilog.pssOpts cmin string ""
spectreSVerilog.pssOpts write string ""
spectreSVerilog.pssOpts writefinal string ""
spectreSVerilog.pssOpts swapfile string ""
spectreSVerilog.pssOpts method string ""
spectreSVerilog.pssOpts relref string ""
spectreSVerilog.pssOpts lteratio string ""
spectreSVerilog.pssOpts steadyratio string ""
spectreSVerilog.pssOpts maxacfreq string ""
spectreSVerilog.pssOpts maxperiods string ""
spectreSVerilog.pssOpts stats string ""
spectreSVerilog.pssOpts annotate string "status"
spectreSVerilog.pssOpts oppoint string ""
spectreSVerilog.pssOpts skipstart string ""
spectreSVerilog.pssOpts skipstop string ""
spectreSVerilog.pssOpts skipcount string ""
spectreSVerilog.pssOpts strobeperiod string ""
spectreSVerilog.pssOpts strobedelay string ""
spectreSVerilog.pssOpts compression string ""
spectreSVerilog.pssOpts maxiters string ""
spectreSVerilog.pssOpts restart string ""
spectreSVerilog.pssOpts tstart string ""
spectreSVerilog.pssOpts tolerance string ""
spectreSVerilog.pssOpts gearorder string ""
spectreSVerilog.pssOpts solver string ""
spectreSVerilog.pssOpts stats2 string ""
spectreSVerilog.pssOpts annotate2 string "status"
spectreSVerilog.pssOpts freqaxis string ""
spectreSVerilog.pssOpts tolerance2 string ""
spectreSVerilog.pssOpts gearorder2 string ""
spectreSVerilog.pssOpts solver2 string ""
spectreSVerilog.pssOpts stats3 string ""
spectreSVerilog.pssOpts annotate3 string "status"
spectreSVerilog.pssOpts stimuli string ""
spectreSVerilog.pssOpts freqaxis2 string ""
spectreSVerilog.pssOpts tolerance3 string ""
spectreSVerilog.pssOpts gearorder3 string ""
spectreSVerilog.pssOpts solver3 string ""
spectreSVerilog.pssOpts stats4 string ""
spectreSVerilog.pssOpts annotate4 string "status"
;spectreSVerilog pdisto partition variables
spectreSVerilog.pdisto enable toggle (nil)
spectreSVerilog.pdisto paramListBox string ""
spectreSVerilog.pdisto fundListBox string ""
spectreSVerilog.pdisto stimName string ""
spectreSVerilog.pdisto freqName string ""
spectreSVerilog.pdisto freqVal string ""
spectreSVerilog.pdisto signalLevel string "Moderate"
spectreSVerilog.pdisto srcId string ""
spectreSVerilog.pdisto maxHarms string ""
spectreSVerilog.pdisto fundsList string ""
spectreSVerilog.pdisto maxHarmsList string ""
spectreSVerilog.pdisto errpreset string ""
spectreSVerilog.pdisto tstab string ""
spectreSVerilog.pdisto saveinit string ""
;spectreSVerilog pdistoOpts partition variables
spectreSVerilog.pdistoOpts step string ""
spectreSVerilog.pdistoOpts maxstep string ""
spectreSVerilog.pdistoOpts ic string ""
spectreSVerilog.pdistoOpts skipdc string ""
spectreSVerilog.pdistoOpts readic string ""
spectreSVerilog.pdistoOpts readns string ""
spectreSVerilog.pdistoOpts cmin string ""
spectreSVerilog.pdistoOpts tolerance string ""
spectreSVerilog.pdistoOpts gearorder string ""
spectreSVerilog.pdistoOpts solver string ""
spectreSVerilog.pdistoOpts write string ""
spectreSVerilog.pdistoOpts writefinal string ""
spectreSVerilog.pdistoOpts swapfile string ""
spectreSVerilog.pdistoOpts method string ""
spectreSVerilog.pdistoOpts relref string ""
spectreSVerilog.pdistoOpts lteratio string ""
spectreSVerilog.pdistoOpts steadyratio string ""
spectreSVerilog.pdistoOpts maxacfreq string ""
spectreSVerilog.pdistoOpts maxperiods string ""
spectreSVerilog.pdistoOpts stats string ""
spectreSVerilog.pdistoOpts annotate string "status"
spectreSVerilog.pdistoOpts oppoint string ""
spectreSVerilog.pdistoOpts skipstart string ""
spectreSVerilog.pdistoOpts skipstop string ""
spectreSVerilog.pdistoOpts skipcount string ""
spectreSVerilog.pdistoOpts strobeperiod string ""
spectreSVerilog.pdistoOpts strobedelay string ""
spectreSVerilog.pdistoOpts compression string ""
spectreSVerilog.pdistoOpts freqaxis string ""
spectreSVerilog.pdistoOpts maxiters string ""
spectreSVerilog.pdistoOpts restart string ""
spectreSVerilog.pdistoOpts tstart string ""
;spectreSVerilog spac partition variables
spectreSVerilog.spac enable toggle (nil)
spectreSVerilog.spac fund string ""
spectreSVerilog.spac Relative boolean nil
spectreSVerilog.spac sweeptype string ""
spectreSVerilog.spac harmonics string "Zero sideband only"
spectreSVerilog.spac numharmonics string ""
spectreSVerilog.spac arrayharmonics string ""
spectreSVerilog.spac selFreqFrom string ""
spectreSVerilog.spac selFreqTo string ""
spectreSVerilog.spac harmsAndFreqsTitle string ""
spectreSVerilog.spac harmsAndFreqs string ""
;spectreSVerilog spacOpts partition variables
spectreSVerilog.spacOpts tolerance string ""
spectreSVerilog.spacOpts gearorder string ""
spectreSVerilog.spacOpts solver string ""
spectreSVerilog.spacOpts stats2 string ""
spectreSVerilog.spacOpts annotate2 string "status"
spectreSVerilog.spacOpts freqaxis string ""
;spectreSVerilog spnoise partition variables
spectreSVerilog.spnoise enable toggle (nil)
spectreSVerilog.spnoise fund string ""
spectreSVerilog.spnoise Relative boolean nil
spectreSVerilog.spnoise sweeptype string ""
spectreSVerilog.spnoise harmonics string "Zero sideband only"
spectreSVerilog.spnoise numharmonics string ""
spectreSVerilog.spnoise arrayharmonics string ""
spectreSVerilog.spnoise selFreqFrom string ""
spectreSVerilog.spnoise selFreqTo string ""
spectreSVerilog.spnoise harmsAndFreqsTitle string ""
spectreSVerilog.spnoise harmsAndFreqs string ""
spectreSVerilog.spnoise outType string "voltage"
spectreSVerilog.spnoise negNode string "/gnd!"
spectreSVerilog.spnoise posNode string ""
spectreSVerilog.spnoise outVsrc string ""
spectreSVerilog.spnoise inNoiseType string "none"
spectreSVerilog.spnoise inVsrc string ""
spectreSVerilog.spnoise inIsrc string ""
spectreSVerilog.spnoise inPort string ""
spectreSVerilog.spnoise refsideband string ""
;spectreSVerilog spnoiseOpts partition variables
spectreSVerilog.spnoiseOpts tolerance3 string ""
spectreSVerilog.spnoiseOpts gearorder3 string ""
spectreSVerilog.spnoiseOpts solver3 string ""
spectreSVerilog.spnoiseOpts stats4 string ""
spectreSVerilog.spnoiseOpts annotate4 string "status"
;spectreSVerilog spxf partition variables
spectreSVerilog.spxf enable toggle (nil)
spectreSVerilog.spxf fund string ""
spectreSVerilog.spxf Relative boolean nil
spectreSVerilog.spxf sweeptype string ""
spectreSVerilog.spxf harmonics string "Zero sideband only"
spectreSVerilog.spxf numharmonics string ""
spectreSVerilog.spxf arrayharmonics string ""
spectreSVerilog.spxf selFreqFrom string ""
spectreSVerilog.spxf selFreqTo string ""
spectreSVerilog.spxf harmsAndFreqsTitle string ""
spectreSVerilog.spxf harmsAndFreqs string ""
spectreSVerilog.spxf outType string "voltage"
spectreSVerilog.spxf negNode string "/gnd!"
spectreSVerilog.spxf posNode string ""
spectreSVerilog.spxf outVsrc string ""
;spectreSVerilog spxfOpts partition variables
spectreSVerilog.spxfOpts tolerance2 string ""
spectreSVerilog.spxfOpts gearorder2 string ""
spectreSVerilog.spxfOpts solver2 string ""
spectreSVerilog.spxfOpts stats3 string ""
spectreSVerilog.spxfOpts annotate3 string "status"
spectreSVerilog.spxfOpts stimuli string ""
spectreSVerilog.spxfOpts freqaxis2 string ""
;spectreSVerilog pac partition variables
spectreSVerilog.pac enable toggle (nil)
spectreSVerilog.pac fund string ""
spectreSVerilog.pac Relative boolean nil
spectreSVerilog.pac sweeptype string ""
spectreSVerilog.pac rangeType string "Start-Stop"
spectreSVerilog.pac from string ""
spectreSVerilog.pac to string ""
spectreSVerilog.pac center string ""
spectreSVerilog.pac span string ""
spectreSVerilog.pac incrType string "Automatic"
spectreSVerilog.pac stepTypeLin string "Step Size"
spectreSVerilog.pac stepTypeLog string "Points Per Decade"
spectreSVerilog.pac by string ""
spectreSVerilog.pac lin string ""
spectreSVerilog.pac dec string ""
spectreSVerilog.pac log string ""
spectreSVerilog.pac useDiscrete boolean nil
spectreSVerilog.pac values string ""
spectreSVerilog.pac harmonics string "Zero sideband only"
spectreSVerilog.pac numharmonics string ""
spectreSVerilog.pac arrayharmonics string ""
spectreSVerilog.pac selFreqFrom string ""
spectreSVerilog.pac selFreqTo string ""
spectreSVerilog.pac harmsAndFreqsTitle string ""
spectreSVerilog.pac harmsAndFreqs string ""
;spectreSVerilog pacOpts partition variables
spectreSVerilog.pacOpts tolerance string ""
spectreSVerilog.pacOpts gearorder string ""
spectreSVerilog.pacOpts solver string ""
spectreSVerilog.pacOpts stats2 string ""
spectreSVerilog.pacOpts annotate2 string "status"
spectreSVerilog.pacOpts freqaxis string ""
;spectreSVerilog pnoise partition variables
spectreSVerilog.pnoise enable toggle (nil)
spectreSVerilog.pnoise fund string ""
spectreSVerilog.pnoise Relative boolean nil
spectreSVerilog.pnoise sweeptype string ""
spectreSVerilog.pnoise rangeType string "Start-Stop"
spectreSVerilog.pnoise from string ""
spectreSVerilog.pnoise to string ""
spectreSVerilog.pnoise center string ""
spectreSVerilog.pnoise span string ""
spectreSVerilog.pnoise incrType string "Automatic"
spectreSVerilog.pnoise stepTypeLin string "Step Size"
spectreSVerilog.pnoise stepTypeLog string "Points Per Decade"
spectreSVerilog.pnoise by string ""
spectreSVerilog.pnoise lin string ""
spectreSVerilog.pnoise dec string ""
spectreSVerilog.pnoise log string ""
spectreSVerilog.pnoise useDiscrete boolean nil
spectreSVerilog.pnoise values string ""
spectreSVerilog.pnoise harmonics string "Zero sideband only"
spectreSVerilog.pnoise numharmonics string ""
spectreSVerilog.pnoise arrayharmonics string ""
spectreSVerilog.pnoise selFreqFrom string ""
spectreSVerilog.pnoise selFreqTo string ""
spectreSVerilog.pnoise harmsAndFreqsTitle string ""
spectreSVerilog.pnoise harmsAndFreqs string ""
spectreSVerilog.pnoise outType string "voltage"
spectreSVerilog.pnoise negNode string "/gnd!"
spectreSVerilog.pnoise posNode string ""
spectreSVerilog.pnoise outVsrc string ""
spectreSVerilog.pnoise inNoiseType string "none"
spectreSVerilog.pnoise inVsrc string ""
spectreSVerilog.pnoise inIsrc string ""
spectreSVerilog.pnoise inPort string ""
spectreSVerilog.pnoise refsideband string ""
;spectreSVerilog pnoiseOpts partition variables
spectreSVerilog.pnoiseOpts tolerance3 string ""
spectreSVerilog.pnoiseOpts gearorder3 string ""
spectreSVerilog.pnoiseOpts solver3 string ""
spectreSVerilog.pnoiseOpts stats4 string ""
spectreSVerilog.pnoiseOpts annotate4 string "status"
;spectreSVerilog pxf partition variables
spectreSVerilog.pxf enable toggle (nil)
spectreSVerilog.pxf fund string ""
spectreSVerilog.pxf Relative boolean nil
spectreSVerilog.pxf sweeptype string ""
spectreSVerilog.pxf rangeType string "Start-Stop"
spectreSVerilog.pxf from string ""
spectreSVerilog.pxf to string ""
spectreSVerilog.pxf center string ""
spectreSVerilog.pxf span string ""
spectreSVerilog.pxf incrType string "Automatic"
spectreSVerilog.pxf stepTypeLin string "Step Size"
spectreSVerilog.pxf stepTypeLog string "Points Per Decade"
spectreSVerilog.pxf by string ""
spectreSVerilog.pxf lin string ""
spectreSVerilog.pxf dec string ""
spectreSVerilog.pxf log string ""
spectreSVerilog.pxf useDiscrete boolean nil
spectreSVerilog.pxf values string ""
spectreSVerilog.pxf harmonics string "Zero sideband only"
spectreSVerilog.pxf numharmonics string ""
spectreSVerilog.pxf arrayharmonics string ""
spectreSVerilog.pxf selFreqFrom string ""
spectreSVerilog.pxf selFreqTo string ""
spectreSVerilog.pxf harmsAndFreqsTitle string ""
spectreSVerilog.pxf harmsAndFreqs string ""
spectreSVerilog.pxf outType string "voltage"
spectreSVerilog.pxf negNode string "/gnd!"
spectreSVerilog.pxf posNode string ""
spectreSVerilog.pxf outVsrc string ""
;spectreSVerilog pxfOpts partition variables
spectreSVerilog.pxfOpts tolerance2 string ""
spectreSVerilog.pxfOpts gearorder2 string ""
spectreSVerilog.pxfOpts solver2 string ""
spectreSVerilog.pxfOpts stats3 string ""
spectreSVerilog.pxfOpts annotate3 string "status"
spectreSVerilog.pxfOpts stimuli string ""
spectreSVerilog.pxfOpts freqaxis2 string ""
;spectreVerilog environment variables
;spectreVerilog opts partition variables
spectreVerilog.opts multithread string ""
spectreVerilog.opts title string ""
spectreVerilog.opts audit string ""
spectreVerilog.opts nthreads string ""
spectreVerilog.opts mos_method string ""
spectreVerilog.opts ckptclock string "1800"
spectreVerilog.opts flow string ""
spectreVerilog.opts cols string "80"
spectreVerilog.opts opptcheck string ""
spectreVerilog.opts maxwarnstologfile string ""
spectreVerilog.opts reltol string "1e-3"
spectreVerilog.opts notation string ""
spectreVerilog.opts senstype string ""
spectreVerilog.opts approx string ""
spectreVerilog.opts warn string ""
spectreVerilog.opts info string ""
spectreVerilog.opts quantities string ""
spectreVerilog.opts sensformat string ""
spectreVerilog.opts pivabs string ""
spectreVerilog.opts compatible string ""
spectreVerilog.opts gmin string "1e-12"
spectreVerilog.opts ignshorts string ""
spectreVerilog.opts rforce string "1"
spectreVerilog.opts homotopy string ""
spectreVerilog.opts note string ""
spectreVerilog.opts iabstol string "1e-12"
spectreVerilog.opts debug string ""
spectreVerilog.opts tempeffects string ""
spectreVerilog.opts maxwarns string "5"
spectreVerilog.opts vabstol string "1e-6"
spectreVerilog.opts macromodels string ""
spectreVerilog.opts tnom string "27"
spectreVerilog.opts temp string "27"
spectreVerilog.opts gmin_check string ""
spectreVerilog.opts value string ""
spectreVerilog.opts narrate string ""
spectreVerilog.opts maxnotes string "5"
spectreVerilog.opts scale string "1.0"
spectreVerilog.opts diagnose string ""
spectreVerilog.opts maxnotestologfile string ""
spectreVerilog.opts digits string "5"
spectreVerilog.opts pivotdc string ""
spectreVerilog.opts pivrel string "1e-3"
spectreVerilog.opts scalem string "1.0"
spectreVerilog.opts limit string ""
spectreVerilog.opts topcheck string ""
spectreVerilog.opts inventory string ""
spectreVerilog.opts error string ""
spectreVerilog.opts sensfile string "../psf/sens.output"
;spectreVerilog outputs partition variables
spectreVerilog.outputs currents string ""
spectreVerilog.outputs subcktprobelvl string ""
spectreVerilog.outputs modelParamInfo boolean t
spectreVerilog.outputs outputParamInfo boolean t
spectreVerilog.outputs allDigitalNV boolean t
spectreVerilog.outputs pwr string ""
spectreVerilog.outputs saveahdlvars string ""
spectreVerilog.outputs nestlvl string ""
spectreVerilog.outputs elementInfo boolean t
spectreVerilog.outputs save string "allpub"
spectreVerilog.outputs useprobes string ""
;spectreVerilog verimixOpts partition variables
spectreVerilog.verimixOpts filename6 string ""
spectreVerilog.verimixOpts maxDCIter int 0
spectreVerilog.verimixOpts scope1 string ""
spectreVerilog.verimixOpts scope10 string ""
spectreVerilog.verimixOpts filename8 string ""
spectreVerilog.verimixOpts dcInterval float 0.0
spectreVerilog.verimixOpts scope3 string ""
spectreVerilog.verimixOpts scope8 string ""
spectreVerilog.verimixOpts scope7 string ""
spectreVerilog.verimixOpts filename7 string ""
spectreVerilog.verimixOpts scope string ""
spectreVerilog.verimixOpts filename4 string ""
spectreVerilog.verimixOpts filename string ""
spectreVerilog.verimixOpts filename1 string ""
spectreVerilog.verimixOpts scope9 string ""
spectreVerilog.verimixOpts importsdfswitch boolean nil
spectreVerilog.verimixOpts filename2 string ""
spectreVerilog.verimixOpts numberofsdffiles int 2
spectreVerilog.verimixOpts scope2 string ""
spectreVerilog.verimixOpts scope6 string ""
spectreVerilog.verimixOpts filename10 string ""
spectreVerilog.verimixOpts delaymodechoice string "Ignore"
spectreVerilog.verimixOpts sdfmixedswitch boolean t
spectreVerilog.verimixOpts filename9 string ""
spectreVerilog.verimixOpts scope5 string ""
spectreVerilog.verimixOpts filename5 string ""
spectreVerilog.verimixOpts filename3 string ""
spectreVerilog.verimixOpts scope4 string ""
;spectreVerilog verilogOpts partition variables
spectreVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
spectreVerilog.verilogOpts optionsFile string ""
spectreVerilog.verilogOpts twinTurbo boolean nil
spectreVerilog.verilogOpts suppressMessages boolean nil
spectreVerilog.verilogOpts libraryFile string ""
spectreVerilog.verilogOpts behaveProfile boolean nil
spectreVerilog.verilogOpts verimixLog string "verilog.log"
spectreVerilog.verilogOpts simVision boolean nil
spectreVerilog.verilogOpts pulseSpec boolean nil
spectreVerilog.verilogOpts commandFile string ""
spectreVerilog.verilogOpts pulseError int 100
spectreVerilog.verilogOpts stopCompile boolean nil
spectreVerilog.verilogOpts keepNodes string "Minimum"
spectreVerilog.verilogOpts accelerationCA boolean nil
spectreVerilog.verilogOpts turboRadio string "Default"
spectreVerilog.verilogOpts libraryDir string ""
spectreVerilog.verilogOpts suppressWarnings boolean nil
spectreVerilog.verilogOpts accelerationSwitches boolean nil
spectreVerilog.verilogOpts accelerationNormal boolean t
spectreVerilog.verilogOpts delayType string "Typical"
spectreVerilog.verilogOpts pulseReject int 100
spectreVerilog.verilogOpts delayMode string "Default"
spectreVerilog.verilogOpts vermixBinary string "verilog.vmx"
;spectreVerilog init partition variables
spectreVerilog.init processPriority int 0
;spectreVerilog envOpts partition variables
spectreVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
spectreVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
spectreVerilog.envOpts outputFormat string "AWD"
spectreVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
spectreVerilog.envOpts mspSetupNetlistEscapeName boolean nil
spectreVerilog.envOpts enableArclength boolean nil
spectreVerilog.envOpts autoDisplay boolean t
spectreVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
spectreVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
spectreVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
spectreVerilog.envOpts simOutputFormat string "psfbin"
spectreVerilog.envOpts spp string ""
spectreVerilog.envOpts mspSetupNetlistPinMap boolean nil
spectreVerilog.envOpts mspSetupNetlistBus boolean t
spectreVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
spectreVerilog.envOpts analysisOrder string ""
spectreVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
spectreVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
spectreVerilog.envOpts mspSetupNetlistExplicit boolean nil
spectreVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
spectreVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
spectreVerilog.envOpts paramRangeCheckFile string ""
spectreVerilog.envOpts printComments boolean nil
spectreVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
spectreVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
spectreVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
spectreVerilog.envOpts mspSetupNetlistSimTimeValue int 1
spectreVerilog.envOpts mspSetupNetlistUseLib boolean nil
spectreVerilog.envOpts firstRun boolean t
spectreVerilog.envOpts mspSetupNetlistNullPort boolean nil
spectreVerilog.envOpts mspSetupNetlistDropPortRange boolean t
spectreVerilog.envOpts userCmdLineOption string ""
spectreVerilog.envOpts mspSetupNetlistUpCase boolean nil
spectreVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;spectreVerilog pz partition variables
spectreVerilog.pz enable toggle (nil)
spectreVerilog.pz outType string "voltage"
spectreVerilog.pz p string ""
spectreVerilog.pz n string ""
spectreVerilog.pz oprobe string ""
spectreVerilog.pz inType string "voltage"
spectreVerilog.pz inVsrc string ""
spectreVerilog.pz inIsrc string ""
spectreVerilog.pz iprobe string ""
spectreVerilog.pz sweep string ""
spectreVerilog.pz freq string "1"
spectreVerilog.pz dev string ""
spectreVerilog.pz deviceParam string ""
spectreVerilog.pz mod string ""
spectreVerilog.pz modelParam string ""
spectreVerilog.pz designVar string ""
spectreVerilog.pz param string ""
spectreVerilog.pz rangeType string "Start-Stop"
spectreVerilog.pz start string ""
spectreVerilog.pz stop string ""
spectreVerilog.pz center string ""
spectreVerilog.pz span string ""
spectreVerilog.pz incrType string "Automatic"
spectreVerilog.pz stepTypeLin string "Step Size"
spectreVerilog.pz stepTypeLog string "Points Per Decade"
spectreVerilog.pz step string ""
spectreVerilog.pz lin string ""
spectreVerilog.pz dec string ""
spectreVerilog.pz log string ""
spectreVerilog.pz useDiscrete boolean nil
spectreVerilog.pz values string ""
spectreVerilog.pz porti string "1"
;spectreVerilog pzOpts partition variables
spectreVerilog.pzOpts readns string ""
spectreVerilog.pzOpts oppoint string ""
spectreVerilog.pzOpts fmax string ""
spectreVerilog.pzOpts zeroonly string ""
spectreVerilog.pzOpts prevoppoint string ""
spectreVerilog.pzOpts restart string ""
spectreVerilog.pzOpts annotate string ""
spectreVerilog.pzOpts stats string ""
;spectreVerilog dcmatch partition variables
spectreVerilog.dcmatch enable toggle (nil)
spectreVerilog.dcmatch outType string "voltage"
spectreVerilog.dcmatch p string ""
spectreVerilog.dcmatch n string ""
spectreVerilog.dcmatch oprobe string ""
spectreVerilog.dcmatch sweep string ""
spectreVerilog.dcmatch dev string ""
spectreVerilog.dcmatch deviceParam string ""
spectreVerilog.dcmatch mod string ""
spectreVerilog.dcmatch modelParam string ""
spectreVerilog.dcmatch designVar string ""
spectreVerilog.dcmatch param string ""
spectreVerilog.dcmatch rangeType string "Start-Stop"
spectreVerilog.dcmatch start string ""
spectreVerilog.dcmatch stop string ""
spectreVerilog.dcmatch center string ""
spectreVerilog.dcmatch span string ""
spectreVerilog.dcmatch incrType string "Automatic"
spectreVerilog.dcmatch stepTypeLin string "Step Size"
spectreVerilog.dcmatch stepTypeLog string "Points Per Decade"
spectreVerilog.dcmatch step string ""
spectreVerilog.dcmatch lin string ""
spectreVerilog.dcmatch dec string ""
spectreVerilog.dcmatch log string ""
spectreVerilog.dcmatch useDiscrete boolean nil
spectreVerilog.dcmatch values string ""
spectreVerilog.dcmatch mth string ""
spectreVerilog.dcmatch porti string "1"
spectreVerilog.dcmatch portv string ""
;spectreVerilog dcmatchOpts partition variables
spectreVerilog.dcmatchOpts readns string ""
spectreVerilog.dcmatchOpts save string ""
spectreVerilog.dcmatchOpts nestlvl string ""
spectreVerilog.dcmatchOpts oppoint string ""
spectreVerilog.dcmatchOpts prevoppoint string ""
spectreVerilog.dcmatchOpts restart string ""
spectreVerilog.dcmatchOpts annotate string "status"
spectreVerilog.dcmatchOpts stats string ""
spectreVerilog.dcmatchOpts where string "rawfile"
;spectreVerilog stb partition variables
spectreVerilog.stb enable toggle (nil)
spectreVerilog.stb sweep string "Frequency"
spectreVerilog.stb freq string ""
spectreVerilog.stb dev string ""
spectreVerilog.stb deviceParam string ""
spectreVerilog.stb mod string ""
spectreVerilog.stb modelParam string ""
spectreVerilog.stb designVar string ""
spectreVerilog.stb param string ""
spectreVerilog.stb rangeType string "Start-Stop"
spectreVerilog.stb start string ""
spectreVerilog.stb stop string ""
spectreVerilog.stb center string ""
spectreVerilog.stb span string ""
spectreVerilog.stb incrType string "Automatic"
spectreVerilog.stb stepTypeLin string "Step Size"
spectreVerilog.stb stepTypeLog string "Points Per Decade"
spectreVerilog.stb step string ""
spectreVerilog.stb lin string ""
spectreVerilog.stb dec string ""
spectreVerilog.stb log string ""
spectreVerilog.stb useDiscrete boolean nil
spectreVerilog.stb values string ""
spectreVerilog.stb probe string ""
;spectreVerilog stbOpts partition variables
spectreVerilog.stbOpts prevoppoint string ""
spectreVerilog.stbOpts readns string ""
spectreVerilog.stbOpts save string ""
spectreVerilog.stbOpts nestlvl string ""
spectreVerilog.stbOpts oppoint string ""
spectreVerilog.stbOpts restart string ""
spectreVerilog.stbOpts annotate string "status"
spectreVerilog.stbOpts stats string ""
;spectreVerilog tran partition variables
spectreVerilog.tran enable toggle (nil)
spectreVerilog.tran stop string ""
spectreVerilog.tran errpreset string ""
;spectreVerilog tranOpts partition variables
spectreVerilog.tranOpts start string ""
spectreVerilog.tranOpts outputstart string ""
spectreVerilog.tranOpts step string ""
spectreVerilog.tranOpts maxstep string ""
spectreVerilog.tranOpts ic string ""
spectreVerilog.tranOpts skipdc string ""
spectreVerilog.tranOpts readic string ""
spectreVerilog.tranOpts readns string ""
spectreVerilog.tranOpts cmin string ""
spectreVerilog.tranOpts write string "spectre.ic"
spectreVerilog.tranOpts writefinal string "spectre.fc"
spectreVerilog.tranOpts ckptperiod string ""
spectreVerilog.tranOpts method string ""
spectreVerilog.tranOpts relref string ""
spectreVerilog.tranOpts lteratio string ""
spectreVerilog.tranOpts stats string ""
spectreVerilog.tranOpts annotate string "status"
spectreVerilog.tranOpts save string ""
spectreVerilog.tranOpts nestlvl string ""
spectreVerilog.tranOpts oppoint string ""
spectreVerilog.tranOpts skipstart string ""
spectreVerilog.tranOpts skipstop string ""
spectreVerilog.tranOpts skipcount string ""
spectreVerilog.tranOpts strobeperiod string ""
spectreVerilog.tranOpts strobedelay string ""
spectreVerilog.tranOpts compression string ""
spectreVerilog.tranOpts infotimes string ""
spectreVerilog.tranOpts flushpoints string ""
spectreVerilog.tranOpts flushtime string ""
spectreVerilog.tranOpts flushofftime string ""
spectreVerilog.tranOpts maxiters string "5"
spectreVerilog.tranOpts restart string ""
spectreVerilog.tranOpts captab boolean nil
spectreVerilog.tranOpts timed boolean nil
spectreVerilog.tranOpts threshold string "0.0"
spectreVerilog.tranOpts detail string "node"
spectreVerilog.tranOpts sort string "name"
;spectreVerilog envlp partition variables
spectreVerilog.envlp enable toggle (nil)
spectreVerilog.envlp clockname string ""
spectreVerilog.envlp stop string ""
spectreVerilog.envlp harmonics string "Number of harmonics"
spectreVerilog.envlp harms string ""
spectreVerilog.envlp harmsvec string ""
spectreVerilog.envlp errpreset string ""
;spectreVerilog envlpOpts partition variables
spectreVerilog.envlpOpts start string ""
spectreVerilog.envlpOpts outputstart string ""
spectreVerilog.envlpOpts tstab string ""
spectreVerilog.envlpOpts modulationbw string ""
spectreVerilog.envlpOpts maxstep string ""
spectreVerilog.envlpOpts envmaxstep string ""
spectreVerilog.envlpOpts ic string ""
spectreVerilog.envlpOpts skipdc string ""
spectreVerilog.envlpOpts readic string ""
spectreVerilog.envlpOpts readns string ""
spectreVerilog.envlpOpts cmin string ""
spectreVerilog.envlpOpts write string ""
spectreVerilog.envlpOpts writefinal string ""
spectreVerilog.envlpOpts swapfile string ""
spectreVerilog.envlpOpts method string ""
spectreVerilog.envlpOpts relref string ""
spectreVerilog.envlpOpts lteratio string ""
spectreVerilog.envlpOpts envlteratio string ""
spectreVerilog.envlpOpts steadyratio string ""
spectreVerilog.envlpOpts stats string ""
spectreVerilog.envlpOpts annotate string "status"
spectreVerilog.envlpOpts save string ""
spectreVerilog.envlpOpts nestlvl string ""
spectreVerilog.envlpOpts compression string ""
spectreVerilog.envlpOpts outputtype string ""
spectreVerilog.envlpOpts strobeperiod string ""
spectreVerilog.envlpOpts maxiters string ""
spectreVerilog.envlpOpts restart string ""
spectreVerilog.envlpOpts envmaxiters string ""
;spectreVerilog ac partition variables
spectreVerilog.ac enable toggle (nil)
spectreVerilog.ac sweep string "Frequency"
spectreVerilog.ac freq string ""
spectreVerilog.ac dev string ""
spectreVerilog.ac deviceParam string ""
spectreVerilog.ac mod string ""
spectreVerilog.ac modelParam string ""
spectreVerilog.ac designVar string ""
spectreVerilog.ac param string ""
spectreVerilog.ac rangeType string "Start-Stop"
spectreVerilog.ac start string ""
spectreVerilog.ac stop string ""
spectreVerilog.ac center string ""
spectreVerilog.ac span string ""
spectreVerilog.ac incrType string "Automatic"
spectreVerilog.ac stepTypeLin string "Step Size"
spectreVerilog.ac stepTypeLog string "Points Per Decade"
spectreVerilog.ac step string ""
spectreVerilog.ac lin string ""
spectreVerilog.ac dec string ""
spectreVerilog.ac log string ""
spectreVerilog.ac useDiscrete boolean nil
spectreVerilog.ac values string ""
;spectreVerilog acOpts partition variables
spectreVerilog.acOpts readns string ""
spectreVerilog.acOpts prevoppoint string ""
spectreVerilog.acOpts save string ""
spectreVerilog.acOpts nestlvl string ""
spectreVerilog.acOpts oppoint string ""
spectreVerilog.acOpts restart string ""
spectreVerilog.acOpts annotate string "status"
spectreVerilog.acOpts stats string ""
;spectreVerilog dc partition variables
spectreVerilog.dc enable toggle (nil)
spectreVerilog.dcop enable toggle (nil)
spectreVerilog.dc saveOppoint boolean nil
spectreVerilog.dc sweep string ""
spectreVerilog.dc dev string ""
spectreVerilog.dc deviceParam string ""
spectreVerilog.dc mod string ""
spectreVerilog.dc modelParam string ""
spectreVerilog.dc designVar string ""
spectreVerilog.dc param string ""
spectreVerilog.dc rangeType string "Start-Stop"
spectreVerilog.dc start string ""
spectreVerilog.dc stop string ""
spectreVerilog.dc center string ""
spectreVerilog.dc span string ""
spectreVerilog.dc incrType string "Automatic"
spectreVerilog.dc stepTypeLin string "Step Size"
spectreVerilog.dc stepTypeLog string "Points Per Decade"
spectreVerilog.dc step string ""
spectreVerilog.dc lin string ""
spectreVerilog.dc dec string ""
spectreVerilog.dc log string ""
spectreVerilog.dc useDiscrete boolean nil
spectreVerilog.dc values string ""
;spectreVerilog dcOpts partition variables
spectreVerilog.dcOpts force string ""
spectreVerilog.dcopOpts force string ""
spectreVerilog.dcOpts readns string ""
spectreVerilog.dcopOpts readns string ""
spectreVerilog.dcOpts readforce string ""
spectreVerilog.dcopOpts readforce string ""
spectreVerilog.dcOpts write string "spectre.dc"
spectreVerilog.dcopOpts write string "spectre.dc"
spectreVerilog.dcOpts writefinal string ""
spectreVerilog.dcopOpts writefinal string ""
spectreVerilog.dcOpts save string ""
spectreVerilog.dcopOpts save string ""
spectreVerilog.dcOpts nestlvl string ""
spectreVerilog.dcopOpts nestlvl string ""
spectreVerilog.dcOpts print string ""
spectreVerilog.dcopOpts print string ""
spectreVerilog.dcOpts check string ""
spectreVerilog.dcopOpts check string ""
spectreVerilog.dcOpts oppoint string "rawfile"
spectreVerilog.dcopOpts oppoint string "rawfile"
spectreVerilog.dcOpts homotopy string ""
spectreVerilog.dcopOpts homotopy string ""
spectreVerilog.dcOpts restart string ""
spectreVerilog.dcopOpts restart string ""
spectreVerilog.dcOpts maxiters string "150"
spectreVerilog.dcopOpts maxiters string "150"
spectreVerilog.dcOpts maxsteps string "10000"
spectreVerilog.dcopOpts maxsteps string "10000"
spectreVerilog.dcOpts annotate string "status"
spectreVerilog.dcopOpts annotate string "status"
spectreVerilog.dcOpts captab boolean nil
spectreVerilog.dcopOpts captab boolean nil
spectreVerilog.dcOpts threshold string "0.0"
spectreVerilog.dcopOpts threshold string "0.0"
spectreVerilog.dcOpts detail string "node"
spectreVerilog.dcopOpts detail string "node"
spectreVerilog.dcOpts sort string "name"
spectreVerilog.dcopOpts sort string "name"
;spectreVerilog noise partition variables
spectreVerilog.noise enable toggle (nil)
spectreVerilog.noise sweep string "Frequency"
spectreVerilog.noise freq string ""
spectreVerilog.noise dev string ""
spectreVerilog.noise deviceParam string ""
spectreVerilog.noise mod string ""
spectreVerilog.noise modelParam string ""
spectreVerilog.noise designVar string ""
spectreVerilog.noise param string ""
spectreVerilog.noise rangeType string "Start-Stop"
spectreVerilog.noise start string ""
spectreVerilog.noise stop string ""
spectreVerilog.noise center string ""
spectreVerilog.noise span string ""
spectreVerilog.noise incrType string "Automatic"
spectreVerilog.noise stepTypeLin string "Step Size"
spectreVerilog.noise stepTypeLog string "Points Per Decade"
spectreVerilog.noise step string ""
spectreVerilog.noise lin string ""
spectreVerilog.noise dec string ""
spectreVerilog.noise log string ""
spectreVerilog.noise useDiscrete boolean nil
spectreVerilog.noise values string ""
spectreVerilog.noise outType string "probe"
spectreVerilog.noise p string ""
spectreVerilog.noise n string ""
spectreVerilog.noise oprobe string ""
spectreVerilog.noise inType string "port"
spectreVerilog.noise inVsrc string ""
spectreVerilog.noise inIsrc string ""
spectreVerilog.noise iprobe string ""
spectreVerilog.noise inPort string ""
;spectreVerilog noiseOpts partition variables
spectreVerilog.noiseOpts readns string ""
spectreVerilog.noiseOpts prevoppoint string ""
spectreVerilog.noiseOpts save string ""
spectreVerilog.noiseOpts nestlvl string ""
spectreVerilog.noiseOpts oppoint string ""
spectreVerilog.noiseOpts restart string ""
spectreVerilog.noiseOpts annotate string "status"
spectreVerilog.noiseOpts stats string ""
;spectreVerilog xf partition variables
spectreVerilog.xf enable toggle (nil)
spectreVerilog.xf sweep string "Frequency"
spectreVerilog.xf freq string ""
spectreVerilog.xf dev string ""
spectreVerilog.xf deviceParam string ""
spectreVerilog.xf mod string ""
spectreVerilog.xf modelParam string ""
spectreVerilog.xf designVar string ""
spectreVerilog.xf param string ""
spectreVerilog.xf rangeType string "Start-Stop"
spectreVerilog.xf start string ""
spectreVerilog.xf stop string ""
spectreVerilog.xf center string ""
spectreVerilog.xf span string ""
spectreVerilog.xf incrType string "Automatic"
spectreVerilog.xf stepTypeLin string "Step Size"
spectreVerilog.xf stepTypeLog string "Points Per Decade"
spectreVerilog.xf step string ""
spectreVerilog.xf lin string ""
spectreVerilog.xf dec string ""
spectreVerilog.xf log string ""
spectreVerilog.xf useDiscrete boolean nil
spectreVerilog.xf values string ""
spectreVerilog.xf outType string "voltage"
spectreVerilog.xf p string ""
spectreVerilog.xf n string ""
spectreVerilog.xf probe string ""
;spectreVerilog xfOpts partition variables
spectreVerilog.xfOpts readns string ""
spectreVerilog.xfOpts prevoppoint string ""
spectreVerilog.xfOpts stimuli string ""
spectreVerilog.xfOpts save string ""
spectreVerilog.xfOpts nestlvl string ""
spectreVerilog.xfOpts oppoint string ""
spectreVerilog.xfOpts restart string ""
spectreVerilog.xfOpts annotate string "status"
spectreVerilog.xfOpts stats string ""
;spectreVerilog sp partition variables
spectreVerilog.sp enable toggle (nil)
spectreVerilog.sp ports string ""
spectreVerilog.sp sweep string "Frequency"
spectreVerilog.sp freq string ""
spectreVerilog.sp dev string ""
spectreVerilog.sp deviceParam string ""
spectreVerilog.sp mod string ""
spectreVerilog.sp modelParam string ""
spectreVerilog.sp designVar string ""
spectreVerilog.sp param string ""
spectreVerilog.sp rangeType string "Start-Stop"
spectreVerilog.sp start string ""
spectreVerilog.sp stop string ""
spectreVerilog.sp center string ""
spectreVerilog.sp span string ""
spectreVerilog.sp incrType string "Automatic"
spectreVerilog.sp stepTypeLin string "Step Size"
spectreVerilog.sp stepTypeLog string "Points Per Decade"
spectreVerilog.sp step string ""
spectreVerilog.sp lin string ""
spectreVerilog.sp dec string ""
spectreVerilog.sp log string ""
spectreVerilog.sp useDiscrete boolean nil
spectreVerilog.sp values string ""
spectreVerilog.sp donoise string "no"
spectreVerilog.sp oprobe string ""
spectreVerilog.sp iprobe string ""
;spectreVerilog spOpts partition variables
spectreVerilog.spOpts readns string ""
spectreVerilog.spOpts prevoppoint string ""
spectreVerilog.spOpts file string ""
spectreVerilog.spOpts datafmt string ""
spectreVerilog.spOpts datatype string ""
spectreVerilog.spOpts noisedata string ""
spectreVerilog.spOpts oppoint string ""
spectreVerilog.spOpts restart string ""
spectreVerilog.spOpts annotate string "status"
spectreVerilog.spOpts stats string ""
;spectreVerilog pss partition variables
spectreVerilog.pss enable toggle (nil)
spectreVerilog.pss paramListBox string ""
spectreVerilog.pss fundListBox string ""
spectreVerilog.pss stimName string ""
spectreVerilog.pss freqName string ""
spectreVerilog.pss freqVal string ""
spectreVerilog.pss signalLevel string "Large"
spectreVerilog.pss srcId string ""
spectreVerilog.pss maxHarms string ""
spectreVerilog.pss freqPeriod string "Beat Frequency"
spectreVerilog.pss fund string ""
spectreVerilog.pss autoCalc boolean nil
spectreVerilog.pss period string ""
spectreVerilog.pss harmonics string "Number of harmonics"
spectreVerilog.pss harms string ""
spectreVerilog.pss indices string ""
spectreVerilog.pss Aindices string ""
spectreVerilog.pss harmsvec string ""
spectreVerilog.pss selFreqFrom string "0"
spectreVerilog.pss selFreqTo string "1e12"
spectreVerilog.pss order string "1"
spectreVerilog.pss harmsAndFreqsTitle string ""
spectreVerilog.pss harmsAndFreqsTitle2 string ""
spectreVerilog.pss harmsAndFreqs string ""
spectreVerilog.pss arrayCoeffs string ""
spectreVerilog.pss harmCoeffs string ""
spectreVerilog.pss harmListMem string ""
spectreVerilog.pss errpreset string ""
spectreVerilog.pss tstab string ""
spectreVerilog.pss saveinit string ""
spectreVerilog.pss oscana boolean nil
spectreVerilog.pss p string ""
spectreVerilog.pss n string ""
spectreVerilog.pss sweepB boolean nil
spectreVerilog.pss sweep string "Variable"
spectreVerilog.pss freqVar string "no"
spectreVerilog.pss designVar string ""
spectreVerilog.pss dev string ""
spectreVerilog.pss deviceParam string ""
spectreVerilog.pss mod string ""
spectreVerilog.pss modelParam string ""
spectreVerilog.pss param string ""
spectreVerilog.pss rangeType string "Start-Stop"
spectreVerilog.pss start string ""
spectreVerilog.pss stop string ""
spectreVerilog.pss center string ""
spectreVerilog.pss span string ""
spectreVerilog.pss incrType string "Linear"
spectreVerilog.pss stepTypeLin string "Step Size"
spectreVerilog.pss stepTypeLog string "Points Per Decade"
spectreVerilog.pss step string ""
spectreVerilog.pss lin string ""
spectreVerilog.pss dec string ""
spectreVerilog.pss log string ""
spectreVerilog.pss useDiscrete boolean nil
spectreVerilog.pss values string ""
;spectreVerilog pssOpts partition variables
spectreVerilog.pssOpts step string ""
spectreVerilog.pssOpts maxstep string ""
spectreVerilog.pssOpts ic string ""
spectreVerilog.pssOpts skipdc string ""
spectreVerilog.pssOpts readic string ""
spectreVerilog.pssOpts readns string ""
spectreVerilog.pssOpts cmin string ""
spectreVerilog.pssOpts write string ""
spectreVerilog.pssOpts writefinal string ""
spectreVerilog.pssOpts swapfile string ""
spectreVerilog.pssOpts writepss string ""
spectreVerilog.pssOpts readpss string ""
spectreVerilog.pssOpts method string ""
spectreVerilog.pssOpts tstabmethod string ""
spectreVerilog.pssOpts relref string ""
spectreVerilog.pssOpts lteratio string ""
spectreVerilog.pssOpts steadyratio string ""
spectreVerilog.pssOpts maxacfreq string ""
spectreVerilog.pssOpts maxperiods string ""
spectreVerilog.pssOpts finitediff string ""
spectreVerilog.pssOpts highorder string ""
spectreVerilog.pssOpts psaratio string ""
spectreVerilog.pssOpts maxorder string ""
spectreVerilog.pssOpts fullpssvec string ""
spectreVerilog.pssOpts stats string ""
spectreVerilog.pssOpts annotate string "status"
spectreVerilog.pssOpts save string ""
spectreVerilog.pssOpts nestlvl string ""
spectreVerilog.pssOpts oppoint string ""
spectreVerilog.pssOpts skipstart string ""
spectreVerilog.pssOpts skipstop string ""
spectreVerilog.pssOpts skipcount string ""
spectreVerilog.pssOpts strobeperiod string ""
spectreVerilog.pssOpts strobedelay string ""
spectreVerilog.pssOpts compression string ""
spectreVerilog.pssOpts outputtype string ""
spectreVerilog.pssOpts maxiters string ""
spectreVerilog.pssOpts restart string ""
spectreVerilog.pssOpts tstart string ""
;spectreVerilog pac partition variables
spectreVerilog.pac enable toggle (nil)
spectreVerilog.pac fund string ""
spectreVerilog.pac period string ""
spectreVerilog.pac modsource string ""
spectreVerilog.pac moduppersideband string "0"
spectreVerilog.pac inmodharmnum string "1"
spectreVerilog.pac outmodharmvec string "1"
spectreVerilog.pac inputType string "SSB"
spectreVerilog.pac modulatedToggle boolean nil
spectreVerilog.pac modulated string ""
spectreVerilog.pac singlePt string "Single-Point []"
spectreVerilog.pac sweeptype string " "
spectreVerilog.pac relharmnum string ""
spectreVerilog.pac rangeType string "Start-Stop"
spectreVerilog.pac start string ""
spectreVerilog.pac stop string ""
spectreVerilog.pac center string ""
spectreVerilog.pac span string ""
spectreVerilog.pac incrType string "Automatic"
spectreVerilog.pac stepTypeLin string "Step Size"
spectreVerilog.pac stepTypeLog string "Points Per Decade"
spectreVerilog.pac step string ""
spectreVerilog.pac lin string ""
spectreVerilog.pac dec string ""
spectreVerilog.pac log string ""
spectreVerilog.pac useDiscrete boolean nil
spectreVerilog.pac values string ""
spectreVerilog.pac harmonics string "Maximum sideband"
spectreVerilog.pac maxsideband string ""
spectreVerilog.pac indices string ""
spectreVerilog.pac Aindices string ""
spectreVerilog.pac sidebands string ""
spectreVerilog.pac side string "upper"
spectreVerilog.pac selFreqFrom string "0"
spectreVerilog.pac selFreqTo string "1e12"
spectreVerilog.pac order string "1"
spectreVerilog.pac harmsAndFreqsTitle string ""
spectreVerilog.pac harmsAndFreqsTitle2 string ""
spectreVerilog.pac harmsAndFreqs string ""
spectreVerilog.pac arrayCoeffs string ""
spectreVerilog.pac harmCoeffs string ""
spectreVerilog.pac harmListMem string ""
;spectreVerilog pacOpts partition variables
spectreVerilog.pacOpts tolerance string ""
spectreVerilog.pacOpts gear_order string ""
spectreVerilog.pacOpts solver string ""
spectreVerilog.pacOpts oscsolver string ""
spectreVerilog.pacOpts stats string ""
spectreVerilog.pacOpts annotate string "status"
spectreVerilog.pacOpts freqaxis string ""
spectreVerilog.pacOpts save string ""
spectreVerilog.pacOpts nestlvl string ""
spectreVerilog.pacOpts outputperiod string ""
;spectreVerilog pnoise partition variables
spectreVerilog.pnoise enable toggle (nil)
spectreVerilog.pnoise fund string ""
spectreVerilog.pnoise period string ""
spectreVerilog.pnoise singlePt string "Single-Point []"
spectreVerilog.pnoise sweeptype string " "
spectreVerilog.pnoise relharmnum string ""
spectreVerilog.pnoise rangeType string "Start-Stop"
spectreVerilog.pnoise start string ""
spectreVerilog.pnoise stop string ""
spectreVerilog.pnoise center string ""
spectreVerilog.pnoise span string ""
spectreVerilog.pnoise incrType string "Automatic"
spectreVerilog.pnoise stepTypeLin string "Step Size"
spectreVerilog.pnoise stepTypeLog string "Points Per Decade"
spectreVerilog.pnoise step string ""
spectreVerilog.pnoise lin string ""
spectreVerilog.pnoise dec string ""
spectreVerilog.pnoise log string ""
spectreVerilog.pnoise useDiscrete boolean nil
spectreVerilog.pnoise values string ""
spectreVerilog.pnoise harmonics string "Maximum sideband"
spectreVerilog.pnoise maxsideband string ""
spectreVerilog.pnoise indices string ""
spectreVerilog.pnoise Aindices string ""
spectreVerilog.pnoise sidebands string ""
spectreVerilog.pnoise side string "upper"
spectreVerilog.pnoise selFreqFrom string "0"
spectreVerilog.pnoise selFreqTo string "1e12"
spectreVerilog.pnoise order string "1"
spectreVerilog.pnoise harmsAndFreqsTitle string ""
spectreVerilog.pnoise harmsAndFreqsTitle2 string ""
spectreVerilog.pnoise harmsAndFreqs string ""
spectreVerilog.pnoise arrayCoeffs string ""
spectreVerilog.pnoise harmCoeffs string ""
spectreVerilog.pnoise harmListMem string ""
spectreVerilog.pnoise outType string "probe"
spectreVerilog.pnoise p string ""
spectreVerilog.pnoise n string ""
spectreVerilog.pnoise oprobe string ""
spectreVerilog.pnoise inType string "port"
spectreVerilog.pnoise inVsrc string ""
spectreVerilog.pnoise inIsrc string ""
spectreVerilog.pnoise iprobe string ""
spectreVerilog.pnoise inPort string ""
spectreVerilog.pnoise refsbSelect string "Enter in field"
spectreVerilog.pnoise refsideband string ""
spectreVerilog.pnoise refsbFreqFrom string "0"
spectreVerilog.pnoise refsbFreqTo string "1e12"
spectreVerilog.pnoise refsbOrder string "1"
spectreVerilog.pnoise refsbTitle string ""
spectreVerilog.pnoise refsbListbox string ""
spectreVerilog.pnoise noisetype string "sources"
spectreVerilog.pnoise tdnoise string "Noise Skip Count"
spectreVerilog.pnoise noiseskipcount string ""
spectreVerilog.pnoise numberofpoints string ""
spectreVerilog.pnoise maxcycles string ""
spectreVerilog.pnoise useDiscreteNoise boolean nil
spectreVerilog.pnoise noisetimepoints string ""
spectreVerilog.pnoise useDiscreteCorr boolean nil
spectreVerilog.pnoise cycles string ""
;spectreVerilog pnoiseOpts partition variables
spectreVerilog.pnoiseOpts tolerance string ""
spectreVerilog.pnoiseOpts gear_order string ""
spectreVerilog.pnoiseOpts solver string ""
spectreVerilog.pnoiseOpts oscsolver string ""
spectreVerilog.pnoiseOpts stats string ""
spectreVerilog.pnoiseOpts annotate string "status"
spectreVerilog.pnoiseOpts save string ""
spectreVerilog.pnoiseOpts nestlvl string ""
spectreVerilog.pnoiseOpts saveallsidebands string ""
;spectreVerilog pxf partition variables
spectreVerilog.pxf enable toggle (nil)
spectreVerilog.pxf fund string ""
spectreVerilog.pxf period string ""
spectreVerilog.pxf moduppersideband string "0"
spectreVerilog.pxf outmodharmnum string "1"
spectreVerilog.pxf inmodharmvec string "1"
spectreVerilog.pxf outputType string "SSB"
spectreVerilog.pxf modulatedToggle boolean nil
spectreVerilog.pxf modulated string ""
spectreVerilog.pxf outType string "voltage"
spectreVerilog.pxf p string ""
spectreVerilog.pxf n string ""
spectreVerilog.pxf probe string ""
spectreVerilog.pxf singlePt string "Single-Point []"
spectreVerilog.pxf sweeptype string " "
spectreVerilog.pxf relharmnum string ""
spectreVerilog.pxf rangeType string "Start-Stop"
spectreVerilog.pxf start string ""
spectreVerilog.pxf stop string ""
spectreVerilog.pxf center string ""
spectreVerilog.pxf span string ""
spectreVerilog.pxf incrType string "Automatic"
spectreVerilog.pxf stepTypeLin string "Step Size"
spectreVerilog.pxf stepTypeLog string "Points Per Decade"
spectreVerilog.pxf step string ""
spectreVerilog.pxf lin string ""
spectreVerilog.pxf dec string ""
spectreVerilog.pxf log string ""
spectreVerilog.pxf useDiscrete boolean nil
spectreVerilog.pxf values string ""
spectreVerilog.pxf harmonics string "Maximum sideband"
spectreVerilog.pxf maxsideband string ""
spectreVerilog.pxf indices string ""
spectreVerilog.pxf Aindices string ""
spectreVerilog.pxf sidebands string ""
spectreVerilog.pxf side string "upper"
spectreVerilog.pxf selFreqFrom string "0"
spectreVerilog.pxf selFreqTo string "1e12"
spectreVerilog.pxf order string "1"
spectreVerilog.pxf harmsAndFreqsTitle string ""
spectreVerilog.pxf harmsAndFreqsTitle2 string ""
spectreVerilog.pxf harmsAndFreqs string ""
spectreVerilog.pxf arrayCoeffs string ""
spectreVerilog.pxf harmCoeffs string ""
spectreVerilog.pxf harmListMem string ""
;spectreVerilog pxfOpts partition variables
spectreVerilog.pxfOpts tolerance string ""
spectreVerilog.pxfOpts gear_order string ""
spectreVerilog.pxfOpts solver string ""
spectreVerilog.pxfOpts oscsolver string ""
spectreVerilog.pxfOpts stats string ""
spectreVerilog.pxfOpts annotate string "status"
spectreVerilog.pxfOpts stimuli string ""
spectreVerilog.pxfOpts freqaxis string ""
spectreVerilog.pxfOpts save string ""
spectreVerilog.pxfOpts nestlvl string ""
;spectreVerilog psp partition variables
spectreVerilog.psp enable toggle (nil)
spectreVerilog.psp singlePt string "Single-Point []"
spectreVerilog.psp sweeptype string " "
spectreVerilog.psp rangeType string "Start-Stop"
spectreVerilog.psp start string ""
spectreVerilog.psp stop string ""
spectreVerilog.psp center string ""
spectreVerilog.psp span string ""
spectreVerilog.psp incrType string "Automatic"
spectreVerilog.psp stepTypeLin string "Step Size"
spectreVerilog.psp stepTypeLog string "Points Per Decade"
spectreVerilog.psp step string ""
spectreVerilog.psp lin string ""
spectreVerilog.psp dec string ""
spectreVerilog.psp log string ""
spectreVerilog.psp useDiscrete boolean nil
spectreVerilog.psp values string ""
spectreVerilog.psp portharmsvec string ""
spectreVerilog.psp ports string ""
spectreVerilog.psp selectPorts boolean t
spectreVerilog.psp harmsvec string ""
spectreVerilog.psp freqRange string ""
spectreVerilog.psp listPortHarm string ""
spectreVerilog.psp listPortName string ""
spectreVerilog.psp listPortNum string ""
spectreVerilog.psp portChoiceList string ""
spectreVerilog.psp portChoiceListHeading string ""
spectreVerilog.psp donoise string "yes"
spectreVerilog.psp maxsideband string ""
;spectreVerilog pspOpts partition variables
spectreVerilog.pspOpts tolerance string ""
spectreVerilog.pspOpts gear_order string ""
spectreVerilog.pspOpts solver string ""
spectreVerilog.pspOpts oscsolver string ""
spectreVerilog.pspOpts annotate string "status"
spectreVerilog.pspOpts stats string ""
spectreVerilog.pspOpts freqaxis string ""
;spectreVerilog qpss partition variables
spectreVerilog.qpss enable toggle (nil)
spectreVerilog.qpss paramListBox string ""
spectreVerilog.qpss fundListBox string ""
spectreVerilog.qpss stimName string ""
spectreVerilog.qpss freqName string ""
spectreVerilog.qpss freqVal string ""
spectreVerilog.qpss signalLevel string "Moderate"
spectreVerilog.qpss srcId string ""
spectreVerilog.qpss maxHarms string ""
spectreVerilog.qpss funds string ""
spectreVerilog.qpss maxharms string ""
spectreVerilog.qpss harmonics boolean nil
spectreVerilog.qpss selFreqFrom string "0"
spectreVerilog.qpss selFreqTo string "1e12"
spectreVerilog.qpss harmsAndFreqsTitle string ""
spectreVerilog.qpss harmsAndFreqs string ""
spectreVerilog.qpss errpreset string ""
spectreVerilog.qpss tstab string ""
spectreVerilog.qpss saveinit string ""
spectreVerilog.qpss sweepB boolean nil
spectreVerilog.qpss sweep string "Variable"
spectreVerilog.qpss freqVar string "no"
spectreVerilog.qpss designVar string ""
spectreVerilog.qpss dev string ""
spectreVerilog.qpss deviceParam string ""
spectreVerilog.qpss mod string ""
spectreVerilog.qpss modelParam string ""
spectreVerilog.qpss param string ""
spectreVerilog.qpss rangeType string "Start-Stop"
spectreVerilog.qpss start string ""
spectreVerilog.qpss stop string ""
spectreVerilog.qpss center string ""
spectreVerilog.qpss span string ""
spectreVerilog.qpss incrType string "Linear"
spectreVerilog.qpss stepTypeLin string "Step Size"
spectreVerilog.qpss stepTypeLog string "Points Per Decade"
spectreVerilog.qpss step string ""
spectreVerilog.qpss lin string ""
spectreVerilog.qpss dec string ""
spectreVerilog.qpss log string ""
spectreVerilog.qpss useDiscrete boolean nil
spectreVerilog.qpss values string ""
;spectreVerilog qpssOpts partition variables
spectreVerilog.qpssOpts step string ""
spectreVerilog.qpssOpts maxstep string ""
spectreVerilog.qpssOpts ic string ""
spectreVerilog.qpssOpts skipdc string ""
spectreVerilog.qpssOpts readic string ""
spectreVerilog.qpssOpts readns string ""
spectreVerilog.qpssOpts cmin string ""
spectreVerilog.qpssOpts write string ""
spectreVerilog.qpssOpts writefinal string ""
spectreVerilog.qpssOpts swapfile string ""
spectreVerilog.qpssOpts writeqpss string ""
spectreVerilog.qpssOpts readqpss string ""
spectreVerilog.qpssOpts method string ""
spectreVerilog.qpssOpts relref string ""
spectreVerilog.qpssOpts lteratio string ""
spectreVerilog.qpssOpts steadyratio string ""
spectreVerilog.qpssOpts maxperiods string ""
spectreVerilog.qpssOpts stats string ""
spectreVerilog.qpssOpts annotate string "status"
spectreVerilog.qpssOpts save string ""
spectreVerilog.qpssOpts nestlvl string ""
spectreVerilog.qpssOpts oppoint string ""
spectreVerilog.qpssOpts skipstart string ""
spectreVerilog.qpssOpts skipstop string ""
spectreVerilog.qpssOpts skipcount string ""
spectreVerilog.qpssOpts strobeperiod string ""
spectreVerilog.qpssOpts strobedelay string ""
spectreVerilog.qpssOpts compression string ""
spectreVerilog.qpssOpts maxiters string ""
spectreVerilog.qpssOpts restart string ""
spectreVerilog.qpssOpts tstart string ""
;spectreVerilog qpac partition variables
spectreVerilog.qpac enable toggle (nil)
spectreVerilog.qpac singlePt string "Single-Point []"
spectreVerilog.qpac sweeptype string " "
spectreVerilog.qpac relharmvec string ""
spectreVerilog.qpac rangeType string "Start-Stop"
spectreVerilog.qpac start string ""
spectreVerilog.qpac stop string ""
spectreVerilog.qpac center string ""
spectreVerilog.qpac span string ""
spectreVerilog.qpac incrType string "Automatic"
spectreVerilog.qpac stepTypeLin string "Step Size"
spectreVerilog.qpac stepTypeLog string "Points Per Decade"
spectreVerilog.qpac step string ""
spectreVerilog.qpac lin string ""
spectreVerilog.qpac dec string ""
spectreVerilog.qpac log string ""
spectreVerilog.qpac useDiscrete boolean nil
spectreVerilog.qpac values string ""
spectreVerilog.qpac sbsm string "Maximum clock order"
spectreVerilog.qpac clockmaxharm string ""
spectreVerilog.qpac selFreqFrom string "0"
spectreVerilog.qpac selFreqTo string "1e12"
spectreVerilog.qpac order string "1"
spectreVerilog.qpac harmsAndFreqsTitle string ""
spectreVerilog.qpac harmsAndFreqsTitle2 string ""
spectreVerilog.qpac harmsAndFreqs string ""
spectreVerilog.qpac arrayCoeffs string ""
spectreVerilog.qpac harmCoeffs string ""
spectreVerilog.qpac harmListMem string ""
spectreVerilog.qpac sidevec string ""
;spectreVerilog qpacOpts partition variables
spectreVerilog.qpacOpts tolerance string ""
spectreVerilog.qpacOpts gear_order string ""
spectreVerilog.qpacOpts solver string ""
spectreVerilog.qpacOpts stats string ""
spectreVerilog.qpacOpts annotate string "status"
spectreVerilog.qpacOpts freqaxis string ""
spectreVerilog.qpacOpts save string ""
spectreVerilog.qpacOpts nestlvl string ""
;spectreVerilog qpnoise partition variables
spectreVerilog.qpnoise enable toggle (nil)
spectreVerilog.qpnoise singlePt string "Single-Point []"
spectreVerilog.qpnoise sweeptype string " "
spectreVerilog.qpnoise relharmvec string ""
spectreVerilog.qpnoise rangeType string "Start-Stop"
spectreVerilog.qpnoise start string ""
spectreVerilog.qpnoise stop string ""
spectreVerilog.qpnoise center string ""
spectreVerilog.qpnoise span string ""
spectreVerilog.qpnoise incrType string "Automatic"
spectreVerilog.qpnoise stepTypeLin string "Step Size"
spectreVerilog.qpnoise stepTypeLog string "Points Per Decade"
spectreVerilog.qpnoise step string ""
spectreVerilog.qpnoise lin string ""
spectreVerilog.qpnoise dec string ""
spectreVerilog.qpnoise log string ""
spectreVerilog.qpnoise useDiscrete boolean nil
spectreVerilog.qpnoise values string ""
spectreVerilog.qpnoise sbsm string "Maximum clock order"
spectreVerilog.qpnoise clockmaxharm string ""
spectreVerilog.qpnoise selFreqFrom string "0"
spectreVerilog.qpnoise selFreqTo string "1e12"
spectreVerilog.qpnoise order string "1"
spectreVerilog.qpnoise harmsAndFreqsTitle string ""
spectreVerilog.qpnoise harmsAndFreqsTitle2 string ""
spectreVerilog.qpnoise harmsAndFreqs string ""
spectreVerilog.qpnoise arrayCoeffs string ""
spectreVerilog.qpnoise harmCoeffs string ""
spectreVerilog.qpnoise harmListMem string ""
spectreVerilog.qpnoise sidevec string ""
spectreVerilog.qpnoise outType string "probe"
spectreVerilog.qpnoise p string ""
spectreVerilog.qpnoise n string ""
spectreVerilog.qpnoise oprobe string ""
spectreVerilog.qpnoise inType string "port"
spectreVerilog.qpnoise inVsrc string ""
spectreVerilog.qpnoise inIsrc string ""
spectreVerilog.qpnoise iprobe string ""
spectreVerilog.qpnoise inPort string ""
spectreVerilog.qpnoise refsbSelect string "Enter in field"
spectreVerilog.qpnoise refsideband string ""
spectreVerilog.qpnoise refsbFreqFrom string "0"
spectreVerilog.qpnoise refsbFreqTo string "1e12"
spectreVerilog.qpnoise refsbOrder string "1"
spectreVerilog.qpnoise refsbTitle string ""
spectreVerilog.qpnoise refsbListbox string ""
;spectreVerilog qpnoiseOpts partition variables
spectreVerilog.qpnoiseOpts tolerance string ""
spectreVerilog.qpnoiseOpts gear_order string ""
spectreVerilog.qpnoiseOpts solver string ""
spectreVerilog.qpnoiseOpts stats string ""
spectreVerilog.qpnoiseOpts annotate string "status"
spectreVerilog.qpnoiseOpts save string ""
spectreVerilog.qpnoiseOpts nestlvl string ""
spectreVerilog.qpnoiseOpts saveallsidebands string ""
;spectreVerilog qpxf partition variables
spectreVerilog.qpxf enable toggle (nil)
spectreVerilog.qpxf singlePt string "Single-Point []"
spectreVerilog.qpxf sweeptype string " "
spectreVerilog.qpxf relharmvec string ""
spectreVerilog.qpxf rangeType string "Start-Stop"
spectreVerilog.qpxf start string ""
spectreVerilog.qpxf stop string ""
spectreVerilog.qpxf center string ""
spectreVerilog.qpxf span string ""
spectreVerilog.qpxf incrType string "Automatic"
spectreVerilog.qpxf stepTypeLin string "Step Size"
spectreVerilog.qpxf stepTypeLog string "Points Per Decade"
spectreVerilog.qpxf step string ""
spectreVerilog.qpxf lin string ""
spectreVerilog.qpxf dec string ""
spectreVerilog.qpxf log string ""
spectreVerilog.qpxf useDiscrete boolean nil
spectreVerilog.qpxf values string ""
spectreVerilog.qpxf sbsm string "Maximum clock order"
spectreVerilog.qpxf clockmaxharm string ""
spectreVerilog.qpxf selFreqFrom string "0"
spectreVerilog.qpxf selFreqTo string "1e12"
spectreVerilog.qpxf order string "1"
spectreVerilog.qpxf harmsAndFreqsTitle string ""
spectreVerilog.qpxf harmsAndFreqsTitle2 string ""
spectreVerilog.qpxf harmsAndFreqs string ""
spectreVerilog.qpxf arrayCoeffs string ""
spectreVerilog.qpxf harmCoeffs string ""
spectreVerilog.qpxf harmListMem string ""
spectreVerilog.qpxf sidevec string ""
spectreVerilog.qpxf outType string "voltage"
spectreVerilog.qpxf p string ""
spectreVerilog.qpxf n string ""
spectreVerilog.qpxf probe string ""
;spectreVerilog qpxfOpts partition variables
spectreVerilog.qpxfOpts tolerance string ""
spectreVerilog.qpxfOpts gear_order string ""
spectreVerilog.qpxfOpts solver string ""
spectreVerilog.qpxfOpts stats string ""
spectreVerilog.qpxfOpts annotate string "status"
spectreVerilog.qpxfOpts stimuli string ""
spectreVerilog.qpxfOpts freqaxis string ""
spectreVerilog.qpxfOpts save string ""
spectreVerilog.qpxfOpts nestlvl string ""
;spectreVerilog qpsp partition variables
spectreVerilog.qpsp enable toggle (nil)
spectreVerilog.qpsp singlePt string "Single-Point []"
spectreVerilog.qpsp sweeptype string " "
spectreVerilog.qpsp rangeType string "Start-Stop"
spectreVerilog.qpsp start string ""
spectreVerilog.qpsp stop string ""
spectreVerilog.qpsp center string ""
spectreVerilog.qpsp span string ""
spectreVerilog.qpsp incrType string "Automatic"
spectreVerilog.qpsp stepTypeLin string "Step Size"
spectreVerilog.qpsp stepTypeLog string "Points Per Decade"
spectreVerilog.qpsp step string ""
spectreVerilog.qpsp lin string ""
spectreVerilog.qpsp dec string ""
spectreVerilog.qpsp log string ""
spectreVerilog.qpsp useDiscrete boolean nil
spectreVerilog.qpsp values string ""
spectreVerilog.qpsp portharmsvec string ""
spectreVerilog.qpsp ports string ""
spectreVerilog.qpsp selectPorts boolean t
spectreVerilog.qpsp harmsvec string ""
spectreVerilog.qpsp freqRange string ""
spectreVerilog.qpsp listPortHarm string ""
spectreVerilog.qpsp listPortName string ""
spectreVerilog.qpsp listPortNum string ""
spectreVerilog.qpsp portChoiceList string ""
spectreVerilog.qpsp portChoiceListHeading string ""
spectreVerilog.qpsp donoise string "yes"
spectreVerilog.qpsp clockmaxharm string ""
;spectreVerilog qpspOpts partition variables
spectreVerilog.qpspOpts tolerance string ""
spectreVerilog.qpspOpts gear_order string ""
spectreVerilog.qpspOpts solver string ""
spectreVerilog.qpspOpts annotate string "status"
spectreVerilog.qpspOpts stats string ""
spectreVerilog.qpspOpts freqaxis string ""
;spectreVerilog sens partition variables
spectreVerilog.sens enable toggle (nil)
spectreVerilog.sens sensType toggle (nil nil nil)
spectreVerilog.sens analyses_list string ""
spectreVerilog.sens outputs string ""
spectreVerilog.sens output_list string ""
spectreVerilog.sens net string ""
spectreVerilog.sens term string ""
;spectreVerilog sensOpts partition variables
;spice3 environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spice3 outputs partition variables
spice3.outputs allAnalogNV boolean t
spice3.outputs allAnalogTC boolean nil
;spice3 envOpts partition variables
spice3.envOpts stopViewList string "spice3"
spice3.envOpts printComments boolean nil
spice3.envOpts autoDisplay boolean t
spice3.envOpts switchViewList string "spice3 cmos_sch cmos.sch schematic veriloga ahdl"
;spice3 init partition variables
;spice3 opts partition variables
spice3.opts ITL5 string "5000"
spice3.opts ITL4 string "10"
spice3.opts DEFAD string "0.0"
spice3.opts RELTOL string "1e-3"
spice3.opts METHOD string ""
spice3.opts DEFAS string "0.0"
spice3.opts CHGTOL string "1e-14"
spice3.opts GMIN string "1e-12"
spice3.opts DEFW string "100.0"
spice3.opts TEMP string "27"
spice3.opts PIVREL string "1e-3"
spice3.opts TRTOL string "7.0"
spice3.opts VNTOL string "1e-6"
spice3.opts DEFL string "100.0"
spice3.opts ITL3 string "4"
spice3.opts ITL2 string "50"
spice3.opts ITL1 string "100"
spice3.opts TNOM string "27"
spice3.opts PIVTOL string "1e-13"
spice3.opts ABSTOL string "1e-12"
;spice3 dc partition variables
spice3.dc enable toggle (nil)
spice3.dc vstart string ""
spice3.dc vstop string ""
spice3.dc vincr string ""
spice3.dc srcnam string ""
;spice3 dcOpts partition variables
;spice3 ac partition variables
spice3.ac enable toggle (nil)
spice3.ac fstart string ""
spice3.ac fstop string ""
spice3.ac incrType string "DEC"
spice3.ac log string ""
spice3.ac lin string ""
;spice3 acOpts partition variables
;spice3 tran partition variables
spice3.tran enable toggle (nil)
spice3.tran tstart string ""
spice3.tran tstop string ""
spice3.tran tstep string ""
spice3.tran tmax string ""
;spice3 tranOpts partition variables
;SCA Extraction Environment Defaults
;FORMAT: tool[.partition] varName type value private {choices, minmax} comment
subx subRunDir string "./SCA"
subx subProcFile string "./sample.proc"
subx subModelName string "substrate"
subx subAccuLevel string "medium"
subx subFreq string "1e9"
subx subSync boolean t
subx subNetexpDefault string "scagnd!"
subx subNetexpProp string ""
subx subMethod string "full"
;User Preference Defaults
ui winPlaceStyle boolean nil
ui setWinTraversal boolean nil
ui showScrollBars boolean nil
ui showPromptLines boolean t
ui showStatusLines boolean t
ui showFixedMenu cyclic "On Left-Side "
ui showFixedMenuLabels boolean t
ui infix boolean nil
ui showOptionForms boolean nil
ui undoLevel int 1
ui nestLimit int 5
ui dblClkTime int 200
ui beepVolume int 0
ui textFont string "-*-courier-medium-r-*-*-12-*-*-*-*-*-iso8859-1"
ui formButtonLocation cyclic "Top "
;Log Filter Defaults
ui menuCmdInput boolean nil
ui promptInput boolean nil
ui userOutput boolean t
ui menuCmdOutput boolean nil
ui progResultsOutput boolean t
ui errorMsg boolean t
ui warningMsg boolean t
ui dragDisplayHint string "normal"
vhdl analyzeMode cyclic "on"
vhdl batchScriptFile string ""
vhdl batchSim cyclic "interactive"
vhdl compareSimDB string "simcmp.log"
vhdl Cosim9404 boolean nil
vhdl createVHDLDir boolean t
vhdl currentSimDB string ""
vhdl dataLocation string ""
vhdl defAttributes string ""
vhdl defBodyViewName string "body"
vhdl defConfigViewName string "configuration"
vhdl defDataDirectory string "vhdllib"
vhdl defEntityViewName string "entity"
vhdl defGenerics string ""
vhdl defGlobals string "(("vdd!" "'1'")("gnd!" "'0'"))"
vhdl defPackageNames string "ieee.std_logic_1164.all"
vhdl defPackageViewName string "package"
vhdl defScalarType string "std_ulogic"
vhdl defVectorType string "std_ulogic_vector"
vhdl defViewName string "vhdl"
vhdl deleteVHDLDir boolean nil
vhdl displaySimCmpResults boolean t
vhdl elaborateMode cyclic "on"
vhdl exportCatFiles boolean t
vhdl exportDirectory string ""
vhdl exportLibNameExt string ".exp"
vhdl exportNetlist cyclic "off"
vhdl generateComponentConfig boolean nil
vhdl goldenSimDB string ""
vhdl ignoreWarnings boolean nil
vhdl importCaseSensitivity boolean t
vhdl importCompatibilityOpt boolean nil
vhdl importCompileAfterImport boolean nil
vhdl importCompilerOptions string ""
vhdl importComponentDensity int 0
vhdl importConfig boolean nil
vhdl importFileFilter string "*.vhd"
vhdl importFontHeight float 0.0625
vhdl importFullPlaceRoute boolean t
vhdl importGenSymbols boolean nil
vhdl importGroundLiterals string "'0'"
vhdl importGroundNetName string "gnd!"
vhdl importGroundType string "std_ulogic"
vhdl importIgnoreContassFunc boolean nil
vhdl importIgnoreExtraPins boolean nil
vhdl importLibName string ""
vhdl importLineComponentSpacing float 0.5
vhdl importLineLineSpacing float 0.2
vhdl importMaxNoCols int 1024
vhdl importMaxNoRows int 1024
vhdl importMinmizeCrossovers boolean t
vhdl importOptimizeLabels boolean t
vhdl importOverwriteExistingView boolean t
vhdl importPinPlacement cyclic "Left and Right Sides"
vhdl importPinPlacementFile string ""
vhdl importPowerLiterals string "'1'"
vhdl importPowerNetName string "vdd!"
vhdl importPowerType string "std_ulogic"
vhdl importReferenceLibraries string "basic US_8ths ieee std sample"
vhdl importRunInBackground boolean t
vhdl importSeparateUnits boolean t
vhdl importSheetBorderSize string ""
vhdl importSquareSchematics boolean t
vhdl importStructuralViewType cyclic "schematic"
vhdl importSummaryFile string "./vhdlin.summary"
vhdl importSymbolViewName string "symbol"
vhdl importv93Opt boolean nil
vhdl importWorkLibName string ""
vhdl invokeLaunchTool boolean nil
vhdl invokeLeapfrogSystemWindow boolean nil
vhdl invokeNCTools boolean t
vhdl libCellViewCaseSensitive boolean t
vhdl maxErrors int 10
vhdl netConfig string "config1"
vhdl netHierSpec cyclic "Simple"
vhdl netIgnoreUnboundCells boolean nil
vhdl netMode cyclic "incremental"
vhdl netScope cyclic "hierarchy"
vhdl overwriteEntity boolean nil
vhdl portMapMode cyclic "named association"
vhdl printCommand string "lpr"
vhdl rangeDir cyclic "default"
vhdl remoteFileAccess cyclic "Automount"
vhdl remoteHostName string "localhost"
vhdl remoteSim cyclic "locally"
vhdl runCheckBeforeSim boolean t
vhdl schHdlParseUsingNcvhdl boolean t
vhdl simCompareLength int 100
vhdl simCompareOffset int 0
vhdl simModel string "SIM"
vhdl simTimeUnits cyclic "ns"
vhdl simTolerance int 0
vhdl stopLibList string "basic sample ieee"
vhdl stopViewList string "symbol"
vhdl switchViewList string "stimulus schematic structure dataflow behavior symbol"
vhdl synergySourceLibrary string ""
vhdl synergySymbolLibraries string "basic US_8ths"
vhdl testBenchCellName string "test"
vhdl testBenchLibName string ""
vhdl testBenchStimulusFile string ""
vhdl testBenchViewName string "stimulus"
vhdl testModeOn boolean nil
vhdl topCellName string ""
vhdl topLevelInstanceName string "dut"
vhdl topLibraryName string ""
vhdl topVersion string ""
vhdl topViewName string "schematic"
vhdl translateMode cyclic "library"
vhdl translateTypes toggle (t t t)
vhdl useUserLibraries boolean nil
vhdl verilogNetlistOpts string ""
vhdl verilogRunDir string ""
vhdl verilogSimOpts string "-q"
vhdl vhdlIdentCaseSensitive boolean t
vhdl whichVLibsFile cyclic "user"
vhdl workCellName string ""
vhdl workLibraryName string ""
vhdl workVersion string ""
vhdl workViewName string "schematic"
vhdlams Cosim9404 boolean nil
vhdlams analyzeMode cyclic "on"
vhdlams batchScriptFile string ""
vhdlams batchSim cyclic "interactive"
vhdlams compareSimDB string "simcmp.log"
vhdlams createVHDLDir boolean t
vhdlams currentSimDB string ""
vhdlams dataLocation string ""
vhdlams defAttributes string ""
vhdlams defBodyViewName string "body"
vhdlams defConfigViewName string "configuration"
vhdlams defDataDirectory string "vhdllib"
vhdlams defEntityViewName string "entity"
vhdlams defGenerics string ""
vhdlams defGlobals string "(("vdd!" "'1'")("gnd!" "'0'"))"
vhdlams defPackageNames string "ieee.std_logic_1164.all ieee.electrical_systems.all"
vhdlams defPackageViewName string "package"
vhdlams defScalarType string "electrical"
vhdlams defVectorType string "std_ulogic_vector"
vhdlams defScalarDomain string "terminal"
vhdlams defVectorDomain string "signal"
vhdlams defViewName string "vhdl"
vhdlams deleteVHDLDir boolean nil
vhdlams displaySimCmpResults boolean t
vhdlams elaborateMode cyclic "on"
vhdlams exportCatFiles boolean t
vhdlams exportDirectory string ""
vhdlams exportLibNameExt string ".exp"
vhdlams exportNetlist cyclic "off"
vhdlams generateComponentConfig boolean nil
vhdlams goldenSimDB string ""
vhdlams ignoreWarnings boolean nil
vhdlams importCaseSensitivity boolean t
vhdlams importCompatibilityOpt boolean nil
vhdlams importCompileAfterImport boolean nil
vhdlams importCompilerOptions string ""
vhdlams importComponentDensity int 0
vhdlams importConfig boolean nil
vhdlams importFileFilter string "*.vhd"
vhdlams importFontHeight float 0.0625
vhdlams importFullPlaceRoute boolean t
vhdlams importGenSymbols boolean nil
vhdlams importGroundLiterals string "'0'"
vhdlams importGroundNetName string "gnd!"
vhdlams importGroundType string "std_ulogic"
vhdlams importIgnoreContassFunc boolean nil
vhdlams importIgnoreExtraPins boolean nil
vhdlams importLibName string ""
vhdlams importLineComponentSpacing float 0.5
vhdlams importLineLineSpacing float 0.2
vhdlams importMaxNoCols int 1024
vhdlams importMaxNoRows int 1024
vhdlams importMinmizeCrossovers boolean t
vhdlams importOptimizeLabels boolean t
vhdlams importOverwriteExistingView boolean t
vhdlams importPinPlacement cyclic "Left and Right Sides"
vhdlams importPinPlacementFile string ""
vhdlams importPowerLiterals string "'1'"
vhdlams importPowerNetName string "vdd!"
vhdlams importPowerType string "std_ulogic"
vhdlams importReferenceLibraries string "basic US_8ths ieee std sample"
vhdlams importRunInBackground boolean t
vhdlams importSeparateUnits boolean t
vhdlams importSheetBorderSize string ""
vhdlams importSquareSchematics boolean t
vhdlams importStructuralViewType cyclic "schematic"
vhdlams importSummaryFile string "./vhdlin.summary"
vhdlams importSymbolViewName string "symbol"
vhdlams importWorkLibName string ""
vhdlams importv93Opt boolean nil
vhdlams invokeLaunchTool boolean nil
vhdlams invokeLeapfrogSystemWindow boolean nil
vhdlams invokeNCTools boolean t
vhdlams libCellViewCaseSensitive boolean t
vhdlams maxErrors int 10
vhdlams netConfig string "config1"
vhdlams netHierSpec cyclic "Simple"
vhdlams netIgnoreUnboundCells boolean nil
vhdlams netMode cyclic "incremental"
vhdlams netScope cyclic "hierarchy"
vhdlams overwriteEntity boolean nil
vhdlams portMapMode cyclic "named association"
vhdlams printCommand string "lpr"
vhdlams rangeDir cyclic "default"
vhdlams remoteFileAccess cyclic "Automount"
vhdlams remoteHostName string "localhost"
vhdlams remoteSim cyclic "locally"
vhdlams runCheckBeforeSim boolean t
vhdlams schHdlParseUsingNcvhdl boolean t
vhdlams simCompareLength int 100
vhdlams simCompareOffset int 0
vhdlams simModel string "SIM"
vhdlams simTimeUnits cyclic "ns"
vhdlams simTolerance int 0
vhdlams stopLibList string "basic sample ieee"
vhdlams stopViewList string "symbol"
vhdlams switchViewList string "stimulus schematic structure dataflow behavior symbol"
vhdlams synergySourceLibrary string ""
vhdlams synergySymbolLibraries string "basic US_8ths"
vhdlams testBenchCellName string "test"
vhdlams testBenchLibName string ""
vhdlams testBenchStimulusFile string ""
vhdlams testBenchViewName string "stimulus"
vhdlams testModeOn boolean nil
vhdlams topCellName string ""
vhdlams topLevelInstanceName string "dut"
vhdlams topLibraryName string ""
vhdlams topVersion string ""
vhdlams topViewName string "schematic"
vhdlams translateMode cyclic "library"
vhdlams translateTypes toggle (t t t)
vhdlams verilogNetlistOpts string ""
vhdlams verilogRunDir string ""
vhdlams verilogSimOpts string "-q"
vhdlams vhdlIdentCaseSensitive boolean t
vhdlams whichVLibsFile cyclic "user"
vhdlams workCellName string ""
vhdlams workLibraryName string ""
vhdlams workVersion string ""
vhdlams workViewName string "schematic"
.cdsinit file for my home directory is:
filepath: <cds_install_dir>/samples/local/cdsinit
dfII version: 4.4
This file should be copied as <cds_install_dir>/local/.cdsinit
and customized as a site startup file. The site startup file is
read and executed when the Design Framework II software starts.
This file can load all the application configuration files and
application bind key files.
It also sets the library search path ( which may be overriden by the
user customization file.
Finally this file transfers control to the user by executing the
The user customization file may be
./.cdsinit - .cdsinit in the working directory
~/.cdsinit - .cdsinit in the user's home directory
This site file checks if a .cdsinit exists in the working directory
and executes it. If .cdsinit does not exist in the user's working
directory then ~/.cdsinit is executed if it exists.
Please read the entire file and the comments before you start
customizing the file. See the section below on File Installation
for a list of sample files supplied.
There are bind key definition files supplied for different
applications. The relevant bind key definitions files must
be loaded if you want bind keys defined for that application.
See section LOAD APPLICATION BIND KEY DEFINITIONS.
In order for any window placements to work correctly the following
X resource must be set in the .Xdefaults or .xresources file
pertaining to your hardware platform.
Mwm*clientAutoPlace: False
After setting the resource read in the resource file with the command
xrdb <resource_filename>
and restart the Motif window manager.
The function
prependInstallPath("string")
adds the installation path to the string argument
For this reason there should NOT be a space at the beginning of the
string.
There SHOULD be a space at the end of the string if more paths are to
follow.
This function is used to make path specification in this file
independant of the exact installation path.
The function let() creates local variables ( example: libPath ).
This makes sure that any global variables are not accidentally modified.
; File Installation
; CONFIGURATION FILES
; The following configuration files are delivered in the 4.4 release:
; <cds_install_dir>/samples/local
; aaConfig.il - analog
; dciConfig.il - Cadence to Synopsys Interface
; metConfig.il - Designing with Composer
; using metric measurements
; sysConfig.il - systems
; uiConfig.il - user interface
; The configuration files are used to initialize parameters and
; forms.
; ENVIRONMENT VARIABLES
; Schematic, Layout and Graphic environment variable defaults are now found in
; <cds_install_dir>/etc/tools/
; layout/.cdsenv
; schematic/.cdsenv
; graphic/.cdsenv
; These can be customized in the user's ./cdsenv and ~/.cdsenv files.
; A .cdsenv file can be created by using CIW->options->save defaults.
; BIND KEY DEFINITION FILES
; The following bind key definition files are delivered in the
; 4.3 release:
; leBindKeys.il - layout editor
; schBindKeys.il - schematic editor
; CUSTOMIZATION FILES
; The following customization files are delivered in the
; 4.3 release:
; <cds_install_dir>/samples/local/cdsinit - site customization
; <cds_install_dir>/cdsuser/.cdsinit - user customization
; ADMINISTRATION
; The site administrator should install the "site" files as follows: ;
; 1. Copy <cds_install_dir>/samples/local/cdsinit
; to <cds_install_dir>/local/.cdsinit
; and modify the file
; (If <cds_install_dir>/local does not exist create it)
; <cds_install_dir>/local is the site customization directory.
; This directory is not sent as part of the software. The site
; administrator must create this directory. Whenever software is
; upgraded the Cadence installation process retains the site
; administration directory if it exists.
; 2. If default configuration needs to be changed copy the
; relevant configuration file
; from: 4.3/samples/local
; to: 4.3/local
; and modify the file(s)
; 3. If default bind key definitions need to be changed copy the
; relevant bind key definition file
; to: 4.3/local
; 4. Copy 4.3/cdsuser/.cdsinit to the user's home or working
; directory - Do this step only if the user does not already
; have a .cdsinit file.
; If after site customization each user wants to customize
; portions of the configuration or bind keys definitions
; they should copy the relevant sections from the files in
; 4.3/samples/local
; into
; the user's customization file
; ./.cdsinit or ~/.cdsinit
; FILE LOADING ORDER
; 1. The configuration files are not automatically loaded.
; Remove the comment on the filename line to load the file.
; The search order for the configuration files is:
; 4.3/local
; 2. The bind key definition files are not automatically loaded.
; The search order for the bind key definition files is:
; 4.3/local
; 4.3/samples/local
; 3. Load user customization file
; ./.cdsinit - load .cdsinit in the working directory if it exists
; else
; ~/.cdsinit - load .cdsinit in the user's home directory
; This file does NOT load both user customization files even if both exist.
;# LOAD APPLICATION CONFIGURATION FILES
;Remove the comment ; if you want to load the specific configuration file
;If you do not load the configuration files the applications will use the
;default configurations.
let( (configFileList file path saveSkillPath)
configFileList = '(
; "aaConfig.il"
; "dciConfig.il"
; "leConfig.il"
; "metConfig.il"
; "schConfig.il"
; "sysConfig.il"
; "uiConfig.il"
; This is the path that is searched for the files
path = strcat(
; If you want to add another path add it here as a string
prependInstallPath("local ")
saveSkillPath=getSkillPath()
setSkillPath(path)
foreach(file configFileList
if(isFile(file) then
loadi(file)
setSkillPath(saveSkillPath)
hiiSetFont("text" "-adobe-courier-bold-r-*-*-12-*")
;# LOAD APPLICATION BIND KEY DEFINITIONS
;Add the comment ; if you do not want to load the specific
;bind key definition file.
;If you do not load the bind key definitions the applications will not
;have any bind keys defined.
;If you load the bind key definition file but the application is not
;registered ( product not licensed or checked out ) then you might get
;a warning that looks like
; *WARNING* "Schematics is not registered yet"
;This warning can be ignored if you know that the product is not
;licensed or checked out.
let( (bindKeyFileList file path saveSkillPath)
bindKeyFileList = '(
"leBindKeys.il"
"schBindKeys.il"
path = strcat(
prependInstallPath("samples/local")
setSkillPath(path)
foreach(file bindKeyFileList
if(isFile(file ) then
loadi(file)
; An individual user may wish to add some bindkeys of his/her own or
; over ride some default loaded bindkeys. For more information about
; bindkeys see the manual "SKILL Reference Manual, Language Fundamentals",
; Chapter 4.
; Here is an example of setting one bindkey on "F2" than prints
; "Hello world" to the CIW when pressed in the CIW.
;hiSetBindKey("Command Interpreter" "<Key>F2" "printf("Hello World")")
; Here is an example of setting keys for more than one application
;let( (app appList)
; appList = '(
; "Command Interpreter"
; "Schematics"
; "Symbol"
; Add other applications here
; foreach(app appList
; hiSetBindKey(app "<Key>F4" "printf("Hello ")")
; hiSetBindKey(app "<Key>F5" "printf("World")")
;# SETTINGS FOR SKILL PATH and SKILL PROGRAMMING
; The function sstatus() sets the status of variables
; The variable writeProtect controls if a SKILL function can be
; redefined or not;
; Any functions defined after writeProtect = t CANNOT be redefined
; Any functions defined after writeProtect = nil CAN be redefined
; If you are going to create SKILL programs and define functions set the
; status of writeProtect to nil at the beginning of your session.
; Set skill search path. The SKILL search path contains directories
; to be searched to locate SKILL programs when program names are
; specified without full path names.
; The operation could be reading, writing or loading a SKILL program.
; Source technology files are considered SKILL files and when loading
; or dumping the technology file SKILL search path will be used.
sstatus(writeProtect nil)
let((skillPath)
skillPath= strcat(
". ~ " ; Current & home directory
prependInstallPath("samples/techfile ") ; sample source technology files
setSkillPath(skillPath)
; VERIFICATION - DIVA/INQUERY/DRACULA ENCAPS #
; There are no configuration variables for these
; applications to be set in the .cdsinit. You may
; need to create a .simrc file, using the example
; in <cds_install_dir>/cdsuser/.simrc
;# PLACE AND ROUTE - CELL3, CE, BE, PREVIEW,GE #
; The geSetProbeNetStopLevel default is zero.
; To probe routing in channels, it must be >= 2.
; geSetProbeNetStopLevel(0) ; 20 is a good number.
;# LAS and COMPACTOR #
; applications to be set in the .cdsinit. You need
; to add information to your technology file. See
; the LAS and COMPACTOR reference manuals for
; details about technology file additions.
;# Customizing the 4.x environment with: #
;# SETTING AmPLD DEFAULTS (Data I/O Abel 4.x) #
; No Setup is required if using the default system shipped from Cadence.
; If you are using your own Abel or need to customize the system Please
; See Appendix A of the Programmable Logic Design System Users Guide.
;# DESIGN FLOWS #
; The design flows can be used with no customization, but customizing
; them for your personal preference can greatly enhance your
; productivity. Please See the Design Flow users guide for details.
; Bring up top flow ...
;amdfTopFlow()
;# MISCELLANEOUS
; Set your own prompt in the CIW. The first argument is the prompt.
; The second argument is not used yet.
; The variable editor defines the text editor to be used when any of
; the applications invoke an editor. For example technology dump and
; edit operation opens an editor window.
; The editor may also be set by
; unix environment variable EDITOR
; setenv EDITOR 'xedit'
; When Design Framework is invoked the SKILL variable editor is set
; to the value of the unix variable EDITOR.
; If EDITOR is not defined the SKILL variable
; editor is set to "vi"
; You may also set the variable to execute a UNIX command
; that invokes an xterm window of given size and location
; and starts an editor program.
; Example:
; editor = "xterm -geometry 80x40 -e emacs"
; Size of xterm in the above example is 80 characters by 40 lines.
; With some editors on certain platforms the variable editor must
; be defined as shown above.
; Some application which require a text editor may be using the UNIX
; variable EDITOR instead of the SKILL variable editor. It is a good
; idea to set the UNIX variable EDITOR to the text editor of your
; choice which will automatically set the SKILL variable editor.
;setPrompts("Ready >" "")
;editor = "xterm -geometry 85x50 -e vi";
printf("END OF SITE CUSTOMIZATION\n")
;# LOAD USER CUSTOMIZATION FILE
;The site customization file is going to load the user
;customization file. In case you have copied this site
;customization file as your user customization file
;comment out or remove the next section to prevent
;recursive loading of ./.cdsinit
load(strcat(getShellEnvVar("MGC_HOME")
"/shared/pkgs/icv.x86/tools/queryskl/calibre.skl"))
load("./leBindKeys.il")
;//# SONNET CADENCE VIRTUOSO INTERFACE SETUP
;END OF THE SITE CUSTOMIZATION FILE
.cdsenv file for my home directory is:
";This is a sample environment variable file containing the default
;values for environment variables in Design Framework II products.
;See the appropriate tool documentation regarding the use and
;choices for each variable.
;To customize your defaults, use this file as a template and place
;a modified version of this file in ../local/.cdsenv. This
;local version should typically reflect the values of your system
;defaults as set by your site coordinator. To specify more personal
;defaults, place a modified version of either this or the
;../local/.cdsenv file into your home directory as .cdsenv.
;Your ../local/.cdsenv file will be loaded first, followed
;by the .cdsenv in your home directory, so any values in ~/.cdsenv
;will override those previously loaded.
;UltraSim environment variables
;UltraSim opts partition variables
UltraSim.opts UsimRAAgeDomain string "loglog"
UltraSim.opts rshort string "1e-6"
UltraSim.opts simSave boolean nil
UltraSim.opts abstoli string "1.00e-12"
UltraSim.opts UsimTAMaxPerTime string ""
UltraSim.opts UsimPAEnabled boolean nil
UltraSim.opts UsimNAOutputSort string "name"
UltraSim.opts simSaveFile string ""
UltraSim.opts UsimTASigNames string ""
UltraSim.opts dc string "Complete DC (1)"
UltraSim.opts TNOMDC string "27"
UltraSim.opts other string ""
UltraSim.opts UsimPADepth string "1"
UltraSim.opts simRestart boolean nil
UltraSim.opts otherSpice string ""
UltraSim.opts wf_tres string "1e-12"
UltraSim.opts UsimPATimeIntervals string ""
UltraSim.opts UsimRAMode string "HCI only"
UltraSim.opts rcr_fmax string "1e9"
UltraSim.opts simTimePoints string ""
UltraSim.opts UsimTASigEdgeType string "rise"
UltraSim.opts UsimRADeltaDToggle boolean t
UltraSim.opts tol string "0.01"
UltraSim.opts wf_reltol string ""
UltraSim.opts wf_abstoli string "1e-12"
UltraSim.opts UsimTARefSigEdgeType string "rise"
UltraSim.opts wf_format string "PSF"
UltraSim.opts UsimRAAgeMethod string "interp"
UltraSim.opts UsimTASigLowThreshold string ""
UltraSim.opts UsimTAEnabled boolean nil
UltraSim.opts UsimTAMinLowTime string ""
UltraSim.opts UsimNA toggle (nil)
UltraSim.opts postl string "No RCR (0)"
UltraSim.opts abstolv string "1.00e-06"
UltraSim.opts diode_method string "Analog Table (A)"
UltraSim.opts UsimRAAgeproc string ""
UltraSim.opts ParasiticRCFile string ""
UltraSim.opts UsimTAMinHighTime string ""
UltraSim.opts UsimOptMethod boolean nil
UltraSim.opts UsimPA toggle (nil)
UltraSim.opts UsimRAMinAge float 0.0
UltraSim.opts UsimTA toggle (nil)
UltraSim.opts UsimTAMaxHighTime string ""
UltraSim.opts wf_abstolv string "1e-6"
UltraSim.opts UsimRADeltaD float 0.1
UltraSim.opts simLoadFile string ""
UltraSim.opts UsimPALimit string ""
UltraSim.opts TEMPDC string "27"
UltraSim.opts UsimTARefSig string ""
UltraSim.opts mos_method string "Analog/MS Table (A)"
UltraSim.opts UsimRANBTIAgeproc string ""
UltraSim.opts wf_filter boolean t
UltraSim.opts UsimTARefSigHighThreshold string ""
UltraSim.opts UsimTANegWindow string ""
UltraSim.opts UsimTASigHighThreshold string ""
UltraSim.opts UsimTAMinPerTime string ""
UltraSim.opts UsimTAReportTitle string ""
UltraSim.opts dump_step string ""
UltraSim.opts speed string "Default (5)"
UltraSim.opts dcut boolean nil
UltraSim.opts UsimPAPort string ""
UltraSim.opts UsimTASubcktName string ""
UltraSim.opts UsimNALimit string ""
UltraSim.opts UsimRAAgingTime string "10y"
UltraSim.opts scale string "1.0"
UltraSim.opts rvshort string "1e-6"
UltraSim.opts UsimPAName string ""
UltraSim.opts analog string "Default (1)"
UltraSim.opts UsimTAMaxLowTime string ""
UltraSim.opts UsimPAOutputSort string "avg"
UltraSim.opts UsimPAPower boolean nil
UltraSim.opts UsimTASetupTime string ""
UltraSim.opts lshort string "0"
UltraSim.opts dcut_field string ""
UltraSim.opts UsimTATrigger string "both"
UltraSim.opts UsimOptMethodHier boolean nil
UltraSim.opts simRepeat string ""
UltraSim.opts sim_mode string "Mixed Signal (MS)"
UltraSim.opts cgndr string "0"
UltraSim.opts UsimTADisplaySetting string ""
UltraSim.opts cgnd string "1e-20"
UltraSim.opts UsimRA toggle (nil)
UltraSim.opts UsimTARefSigLowThreshold string ""
UltraSim.opts UsimTACheckType string "setup"
UltraSim.opts UsimNASortIs string "inc"
UltraSim.opts scalem string "1.0"
UltraSim.opts UsimTADepth string ""
UltraSim.opts UsimPADisplaySetting string ""
UltraSim.opts lvshort string "0"
;UltraSim outputs partition variables
UltraSim.outputs UsimOptionLogicSubckt3 string ""
UltraSim.outputs UsimOptionLogicDepth3 string "1"
UltraSim.outputs UsimOptionProbeAnalog boolean t
UltraSim.outputs UsimOptionAllLogicNV5 boolean nil
UltraSim.outputs UsimOptionLogicLowThreshold string ""
UltraSim.outputs UsimOptionLogicSubckt2 string ""
UltraSim.outputs UsimOptionLogicHighThreshold string ""
UltraSim.outputs UsimOptionLogicIncludeRC boolean nil
UltraSim.outputs UsimOptionLogicSubckt string ""
UltraSim.outputs UsimOptionLogicSubckt5 string ""
UltraSim.outputs UsimOptionLogicDepth4 string "1"
UltraSim.outputs UsimOptionAllAnalogTC boolean nil
UltraSim.outputs UsimOptionAllLogicNV boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC4 boolean nil
UltraSim.outputs UsimOptionLogicDepth string "1"
UltraSim.outputs UsimOptionLogicLowThreshold2 string ""
UltraSim.outputs UsimOptionAllLogicNV2 boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC2 boolean nil
UltraSim.outputs UsimOptionNumberVolThreshold string "1"
UltraSim.outputs UsimOptionLogicSubckt4 string ""
UltraSim.outputs UsimOptionLogicHighThreshold4 string ""
UltraSim.outputs UsimOptionAllAnalogNV boolean nil
UltraSim.outputs UsimOptionLogicLowThreshold5 string ""
UltraSim.outputs UsimOptionIncludeRC boolean nil
UltraSim.outputs UsimOptionDepth string "1"
UltraSim.outputs UsimOptionLogicHighThreshold2 string ""
UltraSim.outputs UsimOptionLogicIncludeRC5 boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC3 boolean nil
UltraSim.outputs UsimOptionLogicHighThreshold3 string ""
UltraSim.outputs UsimOptionLogicDepth5 string "1"
UltraSim.outputs UsimOptionLogicLowThreshold3 string ""
UltraSim.outputs UsimOptionLogicLowThreshold4 string ""
UltraSim.outputs UsimOptionProbeLogic boolean nil
UltraSim.outputs UsimOptionAllLogicNV3 boolean nil
UltraSim.outputs UsimOptionAllLogicNV4 boolean nil
UltraSim.outputs UsimOptionLogicHighThreshold5 string ""
UltraSim.outputs UsimOptionLogicDepth2 string "1"
;UltraSim envOpts partition variables
UltraSim.envOpts stopViewList string "spectre"
UltraSim.envOpts switchViewList string "spectre cmos_sch cmos.sch schematic veriloga"
UltraSim.envOpts netlistFormat string "spectre"
UltraSim.envOpts autoDisplay boolean t
UltraSim.envOpts printComments boolean nil
UltraSim.envOpts UltraSimVectorFile string ""
UltraSim.envOpts UltraSimVcdFile string ""
UltraSim.envOpts userCmdLineOption string ""
UltraSim.envOpts UltraSimVcdInfo string ""
;UltraSim init partition variables
UltraSim.init processPriority int 0
;UltraSim tran partition variables
UltraSim.tran enable toggle (nil)
UltraSim.tran stop string ""
;UltraSim tranOpts partition variables
UltraSim.tranOpts start string ""
UltraSim.tranOpts outputstart string ""
UltraSim.tranOpts step string "1e-9"
UltraSim.tranOpts readic string ""
UltraSim.tranOpts write string "UltraSim.ic"
UltraSim.tranOpts writefinal string "UltraSim.fc"
UltraSim.tranOpts method_new string ""
UltraSim.tranOpts infotimes string ""
UltraSim.tranOpts maxstep string ""
UltraSim.tranOpts max_start string ""
UltraSim.tranOpts max_stop string ""
UltraSim.tranOpts max_subckt string ""
;UltraSimVerilog environment variables
;UltraSimVerilog opts partition variables
UltraSimVerilog.opts rshort string "1e-6"
UltraSimVerilog.opts UsimRAAgeDomain string "loglog"
UltraSimVerilog.opts simSave boolean nil
UltraSimVerilog.opts UsimTAMaxPerTime string ""
UltraSimVerilog.opts abstoli string "1.00e-12"
UltraSimVerilog.opts UsimPAEnabled boolean nil
UltraSimVerilog.opts UsimNAOutputSort string "name"
UltraSimVerilog.opts simSaveFile string ""
UltraSimVerilog.opts UsimTASigNames string ""
UltraSimVerilog.opts TNOMDC string "27"
UltraSimVerilog.opts dc string "Complete DC (1)"
UltraSimVerilog.opts other string ""
UltraSimVerilog.opts otherSpice string ""
UltraSimVerilog.opts simRestart boolean nil
UltraSimVerilog.opts UsimPADepth string "1"
UltraSimVerilog.opts wf_tres string "1e-12"
UltraSimVerilog.opts UsimPATimeIntervals string ""
UltraSimVerilog.opts UsimRAMode string "HCI only"
UltraSimVerilog.opts rcr_fmax string "1e9"
UltraSimVerilog.opts simTimePoints string ""
UltraSimVerilog.opts UsimTASigEdgeType string "rise"
UltraSimVerilog.opts UsimRADeltaDToggle boolean t
UltraSimVerilog.opts tol string "0.01"
UltraSimVerilog.opts wf_reltol string ""
UltraSimVerilog.opts wf_abstoli string "1e-12"
UltraSimVerilog.opts UsimTARefSigEdgeType string "rise"
UltraSimVerilog.opts UsimRAAgeMethod string "interp"
UltraSimVerilog.opts UsimTASigLowThreshold string ""
UltraSimVerilog.opts UsimTAEnabled boolean nil
UltraSimVerilog.opts UsimTAMinLowTime string ""
UltraSimVerilog.opts UsimNA toggle (nil)
UltraSimVerilog.opts postl string "No RCR (0)"
UltraSimVerilog.opts abstolv string "1.00e-06"
UltraSimVerilog.opts diode_method string "Analog Table (A)"
UltraSimVerilog.opts UsimRAAgeproc string ""
UltraSimVerilog.opts ParasiticRCFile string ""
UltraSimVerilog.opts UsimTAMinHighTime string ""
UltraSimVerilog.opts UsimOptMethod boolean nil
UltraSimVerilog.opts UsimPA toggle (nil)
UltraSimVerilog.opts UsimRAMinAge float 0.0
UltraSimVerilog.opts UsimTA toggle (nil)
UltraSimVerilog.opts UsimTAMaxHighTime string ""
UltraSimVerilog.opts wf_abstolv string "1e-6"
UltraSimVerilog.opts UsimRADeltaD float 0.1
UltraSimVerilog.opts simLoadFile string ""
UltraSimVerilog.opts UsimPALimit string ""
UltraSimVerilog.opts TEMPDC string "27"
UltraSimVerilog.opts UsimTARefSig string ""
UltraSimVerilog.opts mos_method string "Analog/MS Table (A)"
UltraSimVerilog.opts UsimRANBTIAgeproc string ""
UltraSimVerilog.opts wf_filter boolean t
UltraSimVerilog.opts UsimTARefSigHighThreshold string ""
UltraSimVerilog.opts UsimTANegWindow string ""
UltraSimVerilog.opts UsimTASigHighThreshold string ""
UltraSimVerilog.opts UsimTAMinPerTime string ""
UltraSimVerilog.opts UsimTAReportTitle string ""
UltraSimVerilog.opts dump_step string ""
UltraSimVerilog.opts speed string "Default (5)"
UltraSimVerilog.opts dcut boolean nil
UltraSimVerilog.opts UsimPAPort string ""
UltraSimVerilog.opts UsimTASubcktName string ""
UltraSimVerilog.opts UsimNALimit string ""
UltraSimVerilog.opts UsimRAAgingTime string "10y"
UltraSimVerilog.opts scale string "1.0"
UltraSimVerilog.opts rvshort string "1e-6"
UltraSimVerilog.opts UsimPAName string ""
UltraSimVerilog.opts analog string "Default (1)"
UltraSimVerilog.opts UsimTAMaxLowTime string ""
UltraSimVerilog.opts UsimPAOutputSort string "avg"
UltraSimVerilog.opts UsimPAPower boolean nil
UltraSimVerilog.opts UsimTASetupTime string ""
UltraSimVerilog.opts lshort string "0"
UltraSimVerilog.opts dcut_field string ""
UltraSimVerilog.opts UsimTATrigger string "both"
UltraSimVerilog.opts UsimOptMethodHier boolean nil
UltraSimVerilog.opts simRepeat string ""
UltraSimVerilog.opts UsimTADisplaySetting string ""
UltraSimVerilog.opts cgndr string "0"
UltraSimVerilog.opts sim_mode string "Mixed Signal (MS)"
UltraSimVerilog.opts cgnd string "1e-20"
UltraSimVerilog.opts UsimRA toggle (nil)
UltraSimVerilog.opts UsimTARefSigLowThreshold string ""
UltraSimVerilog.opts UsimTACheckType string "setup"
UltraSimVerilog.opts UsimNASortIs string "inc"
UltraSimVerilog.opts scalem string "1.0"
UltraSimVerilog.opts UsimPADisplaySetting string ""
UltraSimVerilog.opts UsimTADepth string ""
UltraSimVerilog.opts lvshort string "0"
;UltraSimVerilog outputs partition variables
UltraSimVerilog.outputs UsimOptionLogicSubckt3 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth3 string "1"
UltraSimVerilog.outputs UsimOptionProbeAnalog boolean t
UltraSimVerilog.outputs UsimOptionAllLogicNV5 boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt2 string ""
UltraSimVerilog.outputs UsimOptionLogicHighThreshold string ""
UltraSimVerilog.outputs UsimOptionLogicIncludeRC boolean nil
UltraSimVerilog.outputs UsimOptionLogicSubckt string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt5 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth4 string "1"
UltraSimVerilog.outputs UsimOptionAllAnalogTC boolean nil
UltraSimVerilog.outputs UsimOptionAllLogicNV boolean nil
UltraSimVerilog.outputs UsimOptionLogicIncludeRC4 boolean nil
UltraSimVerilog.outputs UsimOptionLogicDepth string "1"
UltraSimVerilog.outputs UsimOptionLogicLowThreshold2 string ""
UltraSimVerilog.outputs UsimOptionAllLogicNV2 boolean nil
UltraSimVerilog.outputs UsimOptionNumberVolThreshold string "1"
UltraSimVerilog.outputs UsimOptionLogicIncludeRC2 boolean nil
UltraSimVerilog.outputs UsimOptionAllAnalogNV boolean nil
UltraSimVerilog.outputs UsimOptionLogicHighThreshold4 string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt4 string ""
UltraSimVerilog.outputs UsimOptionDepth string "1"
UltraSimVerilog.outputs UsimOptionIncludeRC boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold5 string ""
UltraSimVerilog.outputs allDigitalNV boolean t
UltraSimVerilog.outputs UsimOptionLogicHighThreshold2 string ""
UltraSimVerilog.outputs UsimOptionLogicHighThreshold3 string ""
UltraSimVerilog.outputs UsimOptionLogicIncludeRC3 boolean nil
UltraSimVerilog.outputs UsimOptionLogicIncludeRC5 boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold3 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth5 string "1"
UltraSimVerilog.outputs UsimOptionProbeLogic boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold4 string ""
UltraSimVerilog.outputs UsimOptionAllLogicNV3 boolean nil
UltraSimVerilog.outputs UsimOptionAllLogicNV4 boolean nil
UltraSimVerilog.outputs UsimOptionLogicDepth2 string "1"
UltraSimVerilog.outputs UsimOptionLogicHighThreshold5 string ""
;UltraSimVerilog verimixOpts partition variables
UltraSimVerilog.verimixOpts filename6 string ""
UltraSimVerilog.verimixOpts maxDCIter int 0
UltraSimVerilog.verimixOpts scope1 string ""
UltraSimVerilog.verimixOpts scope10 string ""
UltraSimVerilog.verimixOpts filename8 string ""
UltraSimVerilog.verimixOpts dcInterval float 0.0
UltraSimVerilog.verimixOpts scope3 string ""
UltraSimVerilog.verimixOpts scope8 string ""
UltraSimVerilog.verimixOpts scope7 string ""
UltraSimVerilog.verimixOpts filename7 string ""
UltraSimVerilog.verimixOpts scope string ""
UltraSimVerilog.verimixOpts filename4 string ""
UltraSimVerilog.verimixOpts filename string ""
UltraSimVerilog.verimixOpts filename1 string ""
UltraSimVerilog.verimixOpts scope9 string ""
UltraSimVerilog.verimixOpts importsdfswitch boolean nil
UltraSimVerilog.verimixOpts filename2 string ""
UltraSimVerilog.verimixOpts numberofsdffiles int 2
UltraSimVerilog.verimixOpts scope2 string ""
UltraSimVerilog.verimixOpts scope6 string ""
UltraSimVerilog.verimixOpts filename10 string ""
UltraSimVerilog.verimixOpts delaymodechoice string "Ignore"
UltraSimVerilog.verimixOpts sdfmixedswitch boolean t
UltraSimVerilog.verimixOpts filename9 string ""
UltraSimVerilog.verimixOpts scope5 string ""
UltraSimVerilog.verimixOpts filename5 string ""
UltraSimVerilog.verimixOpts filename3 string ""
UltraSimVerilog.verimixOpts scope4 string ""
;UltraSimVerilog verilogOpts partition variables
UltraSimVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
UltraSimVerilog.verilogOpts optionsFile string ""
UltraSimVerilog.verilogOpts twinTurbo boolean nil
UltraSimVerilog.verilogOpts suppressMessages boolean nil
UltraSimVerilog.verilogOpts libraryFile string ""
UltraSimVerilog.verilogOpts behaveProfile boolean nil
UltraSimVerilog.verilogOpts verimixLog string "verilog.log"
UltraSimVerilog.verilogOpts simVision boolean nil
UltraSimVerilog.verilogOpts pulseSpec boolean nil
UltraSimVerilog.verilogOpts commandFile string ""
UltraSimVerilog.verilogOpts pulseError int 100
UltraSimVerilog.verilogOpts stopCompile boolean nil
UltraSimVerilog.verilogOpts keepNodes string "Minimum"
UltraSimVerilog.verilogOpts accelerationCA boolean nil
UltraSimVerilog.verilogOpts turboRadio string "Default"
UltraSimVerilog.verilogOpts libraryDir string ""
UltraSimVerilog.verilogOpts suppressWarnings boolean nil
UltraSimVerilog.verilogOpts accelerationSwitches boolean nil
UltraSimVerilog.verilogOpts accelerationNormal boolean t
UltraSimVerilog.verilogOpts delayType string "Typical"
UltraSimVerilog.verilogOpts pulseReject int 100
UltraSimVerilog.verilogOpts delayMode string "Default"
UltraSimVerilog.verilogOpts vermixBinary string "verilog.vmx"
;UltraSimVerilog init partition variables
UltraSimVerilog.init processPriority int 0
;UltraSimVerilog envOpts partition variables
UltraSimVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
UltraSimVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
UltraSimVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
UltraSimVerilog.envOpts outputFormat string "AWD"
UltraSimVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
UltraSimVerilog.envOpts mspSetupNetlistEscapeName boolean nil
UltraSimVerilog.envOpts autoDisplay boolean t
UltraSimVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
UltraSimVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
UltraSimVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
UltraSimVerilog.envOpts mspSetupNetlistPinMap boolean nil
UltraSimVerilog.envOpts mspSetupNetlistBus boolean t
UltraSimVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
UltraSimVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
UltraSimVerilog.envOpts mspSetupNetlistExplicit boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
UltraSimVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
UltraSimVerilog.envOpts printComments boolean nil
UltraSimVerilog.envOpts UltraSimVectorFile string ""
UltraSimVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
UltraSimVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimTimeValue int 1
UltraSimVerilog.envOpts mspSetupNetlistUseLib boolean nil
UltraSimVerilog.envOpts UltraSimVcdFile string ""
UltraSimVerilog.envOpts mspSetupNetlistNullPort boolean nil
UltraSimVerilog.envOpts mspSetupNetlistDropPortRange boolean t
UltraSimVerilog.envOpts userCmdLineOption string ""
UltraSimVerilog.envOpts mspSetupNetlistUpCase boolean nil
UltraSimVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
UltraSimVerilog.envOpts UltraSimVcdInfo string ""
;UltraSimVerilog tran partition variables
UltraSimVerilog.tran enable toggle (nil)
UltraSimVerilog.tran stop string ""
;UltraSimVerilog tranOpts partition variables
UltraSimVerilog.tranOpts start string ""
UltraSimVerilog.tranOpts outputstart string ""
UltraSimVerilog.tranOpts step string "1e-9"
UltraSimVerilog.tranOpts readic string ""
UltraSimVerilog.tranOpts write string "UltraSim.ic"
UltraSimVerilog.tranOpts writefinal string "UltraSim.fc"
UltraSimVerilog.tranOpts method_new string ""
UltraSimVerilog.tranOpts infotimes string ""
UltraSimVerilog.tranOpts maxstep string ""
UltraSimVerilog.tranOpts max_start string ""
UltraSimVerilog.tranOpts max_stop string ""
UltraSimVerilog.tranOpts max_subckt string ""
;1*******************************************************
;2* DLE/DLR Environment Variables
;3*******************************************************
adle lxLocalAbutment boolean nil
;AMS-Direct Environment Defaults
amsDirect amsCompMode boolean nil
amsDirect amsLSB_MSB boolean nil
amsDirect amsScalarInstances boolean t
amsDirect includeInstCdfParams boolean nil
amsDirect amsVerbose boolean nil
amsDirect amsMaxErrors int 50
amsDirect amsExcludeParams string ""
amsDirect hdlVarFile string ""
amsDirect simRunDirLoc string ""
amsDirect logFileName string "ams_direct.log"
amsDirect initFile string ""
amsDirect amsDefinitionViews string ""
amsDirect amsExpScalingFactor cyclic "no"
amsDirect modifyParamScope cyclic "no"
amsDirect.prep allowUndefParams boolean t
amsDirect.prep detailedDisciplineRes boolean nil
amsDirect.prep forceGlobalSync boolean nil
amsDirect.prep ncsimGUI boolean t
amsDirect.prep ncsimTcl boolean nil
amsDirect.prep runNcelab boolean t
amsDirect.prep runNcsim boolean t
amsDirect.prep use5xForVHDL boolean t
amsDirect.prep ncelabAnnoSimtime boolean nil
amsDirect.prep ncelabCoverage boolean nil
amsDirect.prep ncelabEpulseNeg boolean nil
amsDirect.prep ncelabIeee1634 boolean nil
amsDirect.prep ncelabInterconnmultisrc boolean nil
amsDirect.prep ncelabLibverbose boolean nil
amsDirect.prep ncelabMessages boolean nil
amsDirect.prep ncelabNostdout boolean nil
amsDirect.prep ncelabNoTchkMsg boolean nil
amsDirect.prep ncelabNoTchkXgen boolean nil
amsDirect.prep ncelabNotimingchecks boolean nil
amsDirect.prep ncelabNovitalaccl boolean t
amsDirect.prep ncelabNoVpdmsg boolean nil
amsDirect.prep ncelabNoVpdXgen boolean nil
amsDirect.prep ncelabNtcWarn boolean nil
amsDirect.prep ncelabPathpulse boolean nil
amsDirect.prep ncelabPlinooptwarn boolean nil
amsDirect.prep ncelabPlinowarn boolean nil
amsDirect.prep ncelabPresrvResFn boolean nil
amsDirect.prep ncelabSdfNocheckCelltype boolean nil
amsDirect.prep ncelabSdfNoHeader boolean nil
amsDirect.prep ncelabSdfNoWarnings boolean nil
amsDirect.prep ncelabSdfWorstcaseRounding boolean nil
amsDirect.prep ncelabStatus boolean t
amsDirect.prep ncelabUpdate boolean t
amsDirect.prep ncelabV93 boolean nil
amsDirect.prep ncelabNosource boolean nil
amsDirect.prep ncelabUseAfile boolean nil
amsDirect.prep ncelabUseGenafile boolean nil
amsDirect.prep ncelabExpand boolean nil
amsDirect.prep ncelabRelax boolean nil
amsDirect.prep ncelabDisableenht boolean nil
amsDirect.prep ncelabNonegtchk boolean nil
amsDirect.prep ncelabNoipd boolean nil
amsDirect.prep ncelabSdfverbose boolean nil
amsDirect.prep ncelabNoautosdf boolean nil
amsDirect.prep ncelabNeverwarn boolean nil
amsDirect.prep ncelabNocopyright boolean nil
amsDirect.prep ncelabUseGeneric boolean nil
amsDirect.prep ncelabUsePulseR boolean nil
amsDirect.prep ncelabUsePulseE boolean nil
amsDirect.prep ncelabUsePulseIntR boolean nil
amsDirect.prep ncelabUsePulseIntE boolean nil
amsDirect.prep ncelabUseExtendtcheckdatalimit boolean nil
amsDirect.prep ncelabUseExtendtcheckreferencelimit boolean nil
amsDirect.prep ncelabNonotifier boolean nil
amsDirect.prep ncelabUseSdfprecision boolean nil
amsDirect.prep ncsimEpulseNoMsg boolean nil
amsDirect.prep ncsimExtassertmsg boolean nil
amsDirect.prep ncsimMessages boolean nil
amsDirect.prep ncsimNeverwarn boolean nil
amsDirect.prep ncsimNocifcheck boolean nil
amsDirect.prep ncsimNosource boolean nil
amsDirect.prep ncsimNostdout boolean nil
amsDirect.prep ncsimPlinooptwarn boolean nil
amsDirect.prep ncsimPlinowarn boolean nil
amsDirect.prep ncsimProfile boolean nil
amsDirect.prep ncsimProfthread boolean nil
amsDirect.prep ncsimRedmem boolean nil
amsDirect.prep ncsimStatus boolean nil
amsDirect.prep ncsimUnbuffered boolean nil
amsDirect.prep ncsimUpdate boolean t
amsDirect.prep ncelabUseAddArgs boolean nil
amsDirect.prep ncsimUseAddArgs boolean nil
amsDirect.prep ncelabMaxErrors int 50
amsDirect.prep ncelabPulseE int 100
amsDirect.prep ncelabPulseIntE int 100
amsDirect.prep ncelabPulseIntR int 100
amsDirect.prep ncelabPulseR int 100
amsDirect.prep ncelabExtendtcheckdatalimit int 0
amsDirect.prep ncelabExtendtcheckreferencelimit int 0
amsDirect.prep ncsimMaxErrors int 50
amsDirect.prep analogControlFile string ""
amsDirect.prep cdsGlobalsLib string ""
amsDirect.prep cdsGlobalsView string ""
amsDirect.prep compileExcludeLibs string ""
amsDirect.prep connectRulesCell string "mixedsignal"
amsDirect.prep connectRulesCell2 string "ConnRules_5V_full"
amsDirect.prep connectRulesLib string ""
amsDirect.prep connectRulesView string ""
amsDirect.prep discipline string "logic"
amsDirect.prep language string "verilog"
amsDirect.prep ncelabArguments string ""
amsDirect.prep ncsimArguments string ""
amsDirect.prep simVisScriptFile string ""
amsDirect.prep timescale string "1ns/1ns"
amsDirect.prep vlogGroundSigs string "gnd!"
amsDirect.prep vlogSupply0Sigs string ""
amsDirect.prep vlogSupply1Sigs string ""
amsDirect.prep ncelabAfile string ""
amsDirect.prep ncelabGenafile string ""
amsDirect.prep ncelabLoadpli1 string ""
amsDirect.prep ncelabLoadvpi string ""
amsDirect.prep ncelabSdfCmdFile string ""
amsDirect.prep ncelabTopLvlGeneric string ""
amsDirect.prep ncelabSdfprecision string ""
amsDirect.prep ncelabNowarn string ""
amsDirect.prep ncsimLoadvpi string ""
amsDirect.prep ncsimNowarn string ""
amsDirect.prep ncelabModelFilePaths string ""
amsDirect.prep compileMode cyclic "incremental"
amsDirect.prep netlistMode cyclic "incremental"
amsDirect.prep ncelabAccess cyclic "Read"
amsDirect.prep ncelabDelayMode cyclic "None"
amsDirect.prep ncelabDelayType cyclic "None"
amsDirect.prep ncelabEpulseFiltering cyclic "None"
amsDirect.prep ncelabLogFileAction cyclic "Overwrite log file"
amsDirect.prep ncelabOmichecklvl cyclic "Standard"
amsDirect.prep ncelabVipdelay cyclic "Typical"
amsDirect.prep ncsimLogFileAction cyclic "Overwrite log file"
amsDirect.prep ncsimOmichecklvl cyclic "None"
amsDirect.simcntl scapprox boolean nil
amsDirect.simcntl scdebug boolean nil
amsDirect.simcntl scdiagnose boolean nil
amsDirect.simcntl scerror boolean t
amsDirect.simcntl scignshorts boolean nil
amsDirect.simcntl scinfo boolean t
amsDirect.simcntl scmacromod boolean nil
amsDirect.simcntl scnarrate boolean t
amsDirect.simcntl scnote boolean t
amsDirect.simcntl scopptcheck boolean t
amsDirect.simcntl scpivotdc boolean nil
amsDirect.simcntl scscfusefileflag boolean nil
amsDirect.simcntl scspscflag boolean nil
amsDirect.simcntl scstats boolean nil
amsDirect.simcntl scwarn boolean t
amsDirect.simcntl scfastbreak boolean nil
amsDirect.simcntl scusemodeleval boolean nil
amsDirect.simcntl scdigits int 5
amsDirect.simcntl scmaxiters int 5
amsDirect.simcntl scmaxnotes int 5
amsDirect.simcntl scmaxwarn int 5
amsDirect.simcntl scscale int 1
amsDirect.simcntl scscalem int 1
amsDirect.simcntl scskipcount int 0
amsDirect.simcntl sccmin string "0.0"
amsDirect.simcntl scaddlglblopts string ""
amsDirect.simcntl scaddltranopts string ""
amsDirect.simcntl scgmin string "1e-12"
amsDirect.simcntl sciabstol string "1e-12"
amsDirect.simcntl scicstmt string ""
amsDirect.simcntl sclteratio string ""
amsDirect.simcntl scmaxstep string ""
amsDirect.simcntl scpivabs string "0.0"
amsDirect.simcntl scpivrel string "1e-3"
amsDirect.simcntl screadic string ""
amsDirect.simcntl screadns string ""
amsDirect.simcntl screltol string ""
amsDirect.simcntl scrforce string "1.0"
amsDirect.simcntl scalem string "1.0"
amsDirect.simcntl scale string "1.0"
amsDirect.simcntl scscfincfile string ""
amsDirect.simcntl scscftimestamp string ""
amsDirect.simcntl scskipstart string "0.0"
amsDirect.simcntl scskipstop string "0.0"
amsDirect.simcntl scstep string ""
amsDirect.simcntl scstop string "0.0"
amsDirect.simcntl scstrobedelay string "0.0"
amsDirect.simcntl scstrobeperiod string "0.0"
amsDirect.simcntl sctemp string "27.0"
amsDirect.simcntl sctitle string ""
amsDirect.simcntl sctnom string "27.0"
amsDirect.simcntl scvabstol string "1e-6"
amsDirect.simcntl scwrite string ""
amsDirect.simcntl scwritefinal string ""
amsDirect.simcntl scannotate cyclic "sweep"
amsDirect.simcntl scaudit cyclic "detailed"
amsDirect.simcntl sccheckstmt cyclic "all"
amsDirect.simcntl sccompatible cyclic "spectre"
amsDirect.simcntl scerrpreset cyclic "moderate"
amsDirect.simcntl scgmincheck cyclic "max_v_only"
amsDirect.simcntl schomotopy cyclic "all"
amsDirect.simcntl scic cyclic "all"
amsDirect.simcntl scinventory cyclic "detailed"
amsDirect.simcntl sclimit cyclic "dev"
amsDirect.simcntl scmethod cyclic "<Default value>"
amsDirect.simcntl scnotation cyclic "eng"
amsDirect.simcntl scquantities cyclic "no"
amsDirect.simcntl screlref cyclic "<Default value>"
amsDirect.simcntl scskipdc cyclic "no"
amsDirect.simcntl sctempeffects cyclic "all"
amsDirect.simcntl sctopcheck cyclic "full"
amsDirect.simcntl sctransave cyclic "allpub"
amsDirect.simcntl scmodelevaltype cyclic "s"
amsDirect.vhdl allowNoEntityUpdate boolean nil
amsDirect.vhdl checkAndNetlist boolean nil
amsDirect.vhdl checkOnly boolean nil
amsDirect.vhdl compileAsAMS boolean t
amsDirect.vhdl forceEntitySync boolean nil
amsDirect.vhdl forceInlineCompDecl boolean nil
amsDirect.vhdl netlistAfterCdfChange boolean nil
amsDirect.vhdl prohibitCompile boolean nil
amsDirect.vhdl useProcessViewNamesOnly boolean nil
amsDirect.vhdl lexpragma boolean nil
amsDirect.vhdl messages boolean nil
amsDirect.vhdl neverwarn boolean nil
amsDirect.vhdl nopragmawarn boolean nil
amsDirect.vhdl nostdout boolean nil
amsDirect.vhdl novitalcheck boolean nil
amsDirect.vhdl pragma boolean nil
amsDirect.vhdl relax boolean nil
amsDirect.vhdl status boolean nil
amsDirect.vhdl update boolean t
amsDirect.vhdl v93 boolean t
amsDirect.vhdl vhdllinedebug boolean nil
amsDirect.vhdl ncvhdlUseAddArgs boolean nil
amsDirect.vhdl maxErrors int 50
amsDirect.vhdl amsEligibleViewTypes string "schematic schematicSymbol"
amsDirect.vhdl defaultObject string "quantity"
amsDirect.vhdl defaultScalarNature string "real"
amsDirect.vhdl defaultScalarType string "quantity"
amsDirect.vhdl defaultVectorNature string "real_vector"
amsDirect.vhdl defaultVectorType string "quantity"
amsDirect.vhdl defPackageNames string ""
amsDirect.vhdl excludeViewNames string ""
amsDirect.vhdl ncvhdlArguments string ""
amsDirect.vhdl processViewNames string ""
amsDirect.vhdl templateFile string ""
amsDirect.vhdl templateScript string ""
amsDirect.vhdl logFileAction cyclic "Overwrite log file"
amsDirect.vhdl nowarn string ""
amsDirect.vhdl allowDeviantBuses cyclic "no"
amsDirect.vhdl allowIllegalIdentifiers cyclic "warn"
amsDirect.vhdl allowNameCollisions cyclic "warn"
amsDirect.vhdl allowPortNetMismatches cyclic "no"
amsDirect.vhdl allowSparseBuses cyclic "warn"
amsDirect.vhdl headerText cyclic "none"
amsDirect.vlog checkAndNetlist boolean nil
amsDirect.vlog checkOnly boolean nil
amsDirect.vlog compileAsAMS boolean t
amsDirect.vlog ifdefLanguageExtensions boolean nil
amsDirect.vlog netlistAfterCdfChange boolean nil
amsDirect.vlog prohibitCompile boolean nil
amsDirect.vlog useDefparam boolean nil
amsDirect.vlog useProcessViewNamesOnly boolean nil
amsDirect.vlog checktasks boolean nil
amsDirect.vlog ieee1364 boolean nil
amsDirect.vlog noline boolean nil
amsDirect.vlog lexpragma boolean nil
amsDirect.vlog markcelldefines boolean nil
amsDirect.vlog messages boolean nil
amsDirect.vlog neverwarn boolean nil
amsDirect.vlog nomempack boolean nil
amsDirect.vlog nopragmawarn boolean nil
amsDirect.vlog nostdout boolean nil
amsDirect.vlog pragma boolean nil
amsDirect.vlog status boolean nil
amsDirect.vlog update boolean t
amsDirect.vlog vloglinedebug boolean nil
amsDirect.vlog ncvlogUseAddArgs boolean nil
amsDirect.vlog netlistUDFAsMacro boolean nil
amsDirect.vlog bindCdsAliasLib boolean t
amsDirect.vlog bindCdsAliasView boolean t
amsDirect.vlog maxErrors int 50
amsDirect.vlog amsEligibleViewTypes string "schematic"
amsDirect.vlog excludeViewNames string ""
amsDirect.vlog includeFiles string "(disciplines.vams)"
amsDirect.vlog ncvlogArguments string ""
amsDirect.vlog paramDefVals string ""
amsDirect.vlog paramGlobalDefVal string "0"
amsDirect.vlog processViewNames string ""
amsDirect.vlog templateFile string ""
amsDirect.vlog templateScript string ""
amsDirect.vlog incdir string ""
amsDirect.vlog macro string ""
amsDirect.vlog nowarn string ""
amsDirect.vlog allowDeviantBuses cyclic "no"
amsDirect.vlog allowIllegalIdentifiers cyclic "warn"
amsDirect.vlog allowNameCollisions cyclic "warn"
amsDirect.vlog allowSparseBuses cyclic "warn"
amsDirect.vlog headerText cyclic "none"
amsDirect.vlog logFileAction cyclic "Overwrite log file"
amsDirect.vlog iterInstExpFormat string "%b_%i"
amsDirect.vlog netClashFormat string "%b_netclash"
amsDirect.vlog instClashFormat string "%b_instclash"
amsDirect.vlog aliasInstFormat string "ams_alias_inst_%i"
;Analog Artist Simulation Environment Defaults
;Session Options
asimenv windowBased boolean t
asimenv schematicBased boolean nil
asimenv saveDir string "~/.artist_states"
asimenv saveQuery boolean t
asimenv loadCorners boolean t
asimenv designEditMode boolean nil;edit/read open mode
asimenv showWhatsNew string "yes"
asimenv.startup simulator string "spectre"
asimenv.startup projectDir string "~/simulation"
asimenv.startup hostMode string "local"
asimenv.startup host string ""
asimenv.startup remoteDir string ""
asimenv.startup digitalHostMode string "local"
asimenv.startup digitalHost string ""
;Window Options
asimenv.window x int 1
asimenv.window y int 317
;Load State Dialog
asimenv.loadstate modelSetup boolean t
;when set to nil, loadstate form opens with Model Setup deselected by default
;Plotting Options
asimenv.plotting autoPlot boolean t
asimenv.plotting overlay boolean nil
asimenv.plotting immediatePlot boolean nil
asimenv.plotting designName boolean t
asimenv.plotting simulationDate boolean t
asimenv.plotting temperature boolean nil
asimenv.plotting variables boolean nil
asimenv.plotting scalarOutputs boolean nil
asimenv.plotting icons boolean t
asimenv.plotting fontSize int 11
asimenv.plotting width int 564
asimenv.plotting height int 428
asimenv.plotting x int 577
asimenv.plotting y int 373
asimenv.plotting displayMode cyclic "auto"
asimenv.plotting stripModeType cyclic "auto"
asimenv.plotting immediatePrint boolean t
asimenv.plotting printInlines boolean t
;Command-Type-In Window
asimenv.window width int 650
asimenv.window height int 275
;Miscellaneous
asimenv.misc saveDefaultsToOCEAN boolean nil
asimenv.misc numberOfSavedRuns int 0
asimenv.misc browserCenterMode boolean nil
asimenv.misc updateCDFtermOrder boolean nil
asimenv.misc queryCDFtermOrder boolean t
asimenv.misc oceanScriptFile string "./oceanScript.ocn"
asimenv.userPref printNotation cyclic "suffix"
asimenv.userPref printCommentChar string "#"
;Noise summary options
asimenv.noiseSummary digits int 6
asimenv.noiseSummary percentDecimals int 2
;obsolete simulator startup form variables
asimenv.startup sessionName string "schematic"
asimenv.startup libName string ""
asimenv.startup cellName string ""
asimenv.startup viewName string ""
asimenv.startup versionName string ""
asimenv.netlist obsoleteWarnings int 1
;Distributed Processing
;Please do not add any options other than for Artist Distributed
;below this point.
;asimenv.startup hostMode - value of 'distributed' enables distributed processing
asimenv.distributed externalServer boolean nil
;If set non-nil, the job server is started remotely.
asimenv.distributed autoJobSubmit boolean nil
;If set non-nil, job setup form is NOT presented to user at job submit time.
asimenv.distributed showMessages boolean t
;If set non-nil, a message is displayed in the CIW or OCEAN terminal
;when a job is completed.
asimenv.distributed queueName string ""
;Sets the default queue name. If unspecified, system default is used.
asimenv.distributed hostName string ""
;Sets the default host name. If unspecified, host is automatically selected.
asimenv.distributed startTime string ""
;Sets the default start time for a job (in 24 hr. format). If unspecified, job runs immediately.
asimenv.distributed startDay cyclic "today"
;Sets the default start day for a job. If `today', then job will always run on the same day it is submitted
asimenv.distributed expTime string ""
;Sets the default expiration time for a job (in 24 hr. format). If unspecified, expiration time
;is based on the value of the `timeLimit' variable.
asimenv.distributed expDay cyclic "today"
;Sets the default expiration day for a job. If `today', then job will always run on the same day it is submitted
asimenv.distributed timeLimit cyclic "none"
;Sets the default time limit for a job. If `none', then no time limit is imposed.
;If `unspecified', then expiration time is based on value of `expTime' and `expDay' variables.
asimenv.distributed emailNotify boolean t
;If set non-nil, email notification is provided following job termination.
asimenv.distributed mailTo string ""
;Sets the default list of users who will receive job termination notification email.
;If unspecified, and emailNotify is t, then default value is the user's id.
asimenv.distributed logsInEmail boolean t
;If set non-nil, stdout and stderr logs will be included in the termination email.
asimenv.distributed stateFile string "~/.adpState"
;Sets the filename containing the job server's state.
asimenv.distributed daysBeforeExpire int 3
;Specifies the number of days after which terminated jobs will be deleted from
;the job server.
asimenv.distributed block boolean nil
;If set non-nil, the process will be blocked until the job has completed.
asimenv.distributed copyMode boolean nil
;If set non-nil, the input data for the job is copied to /tmp on the execution host,
;the job is run there locally (i.e. no network read/write), and the output data is
;copied back to the submission host.
asimenv.distributed copyModeDir string "/tmp"
;The directory, relative to the execution host, that will be used for setting up the
;working directory of a copy mode job.
asimenv.distributed loginShell cyclic "none"
;Specifies login shell for the job. If `none', then the user's local environment
;is copied over to the execution host and used as the job's environment.
asimenv.distributed numOfTasks int 0
;Specifies the default number of tasks a job should be broken into.
;This is used by the Monte Carlo tool.
;If zero, then number of tasks is bases on queue and/or host settings
asimenv.distributed jobArgsInOceanScript boolean nil
;Indicates job arguments should be added to run commands when
;OCEAN script is generated.
asimenv.distributed puttogetherqueue string ""
;Used to specify the queue to be used for Put Together Job
asimenv.distributed copyNetlist boolean nil
;Used to specify whether netlist directory needs to be copied from execution
;host to submission host. This may be required if during simulation, some files
;are generated under netlist dir
;Used to specify whether to remove the job from DP database after job completion.
;So that, if set to t, the same job name is used repeatedly.
;Used to specify whether list option for specifying hosts needs to be displayed
;in Job Submit Form. If set to nil the list option will not be displayed.
;Used to specify the default value for Shell_Cmd_at_Finish as available in job
;submit form.
asimenv.distributed logsDir string "/tmp"
;Used to specify the directory where the log files would be generated
asimenv.distributed mailAllLogs boolean nil
;Used to specify whether to send the log files in mail for all the tasks
;If set to t, log files would be mailed for each task and a summary mail would be
;sent after completion of all the tasks. If set to nil just a summary mail would be
asimenv.distributed logFile string "~/cdsDPSetupChk.log"
asimenv.distributed clockSync boolean nil
asimenv.distributed lsfResourceString string ""
;Used to specify the Default LSF Resource String
asimenv.distributed donotCopyCore boolean t
;Used to specify whether DP need to filter the core files while copying the directories
;If set to t then all the files with name starting from core will be filtered out
;If set to nil then all the files will be copied
; Copyright (C) 1991
; Cadence Design Systems, Analog Division
; All Rights Reserved.
; $Source: /cvsrep/group/artist/src/auCdl/cdsenv,v $
; $Author: cvsadm $
; $Revision: 1.1 $
; $Date: 2003/10/06 04:16:43 $
; $State: Exp $
;auCdl Environment Variables
;For cell-view to cell-view:
auCdl.envOpts defaultSubcircuitCall string "ansCdlSubcktCall"
;auCore Environment Variables
;Note: The tool registration file should not be edited.
;Customization should be based on the file in <cdshier>/samples/.cdsenv.
;Tool Filter list of simulators
auCore.toolFilter toolList string "spectre spectreS cdsSpice auCdl auLvs hspiceS hspiceD UltraSim "
;Tool Filter list of simulators selected by default
auCore.toolFilter defaultTools string "spectre spectreS auCdl auLvs"
;Tool Filter variable to enable auto update
auCore.toolFilter autoUpdate boolean nil
;Logic Levels form variables
auCore.voltageLevels highlayer cyclic "y2"
auCore.voltageLevels midlayer cyclic "y4"
auCore.voltageLevels lowlayer cyclic "y6"
auCore.voltageLevels high float 2.0
auCore.voltageLevels low float 0.8
auCore.voltageLevels type string "DC"
auCore.voltageLevels time float 0.0
;The following variable indicates the release to which the Artist cdsenv
;variables are compliant. Set to the current release to disable
;automatic variable detection/conversion of user's .cdsenv file.
auCore artVarVer string ""
; $Source: /cvsrep/group/artist/src/auLvs/cdsenv,v $
; $Author: zhaag $
; $Revision: 1.1.12.1 $
; $Date: 2004/10/13 09:30:08 $
; $State: Exp $
auLvs.envOpts defaultSubcircuitCall string "ansLvsCompPrim"
;Calculator environment variables
;FORMAT: tool[.partition] varName varType default private {choices,min/max}
;calculator modes
calculator mode cyclic "RPN"
calculator uimode cyclic "standard"
calculator eval boolean nil
calculator dstack boolean nil
calculator oldexpr boolean t
calculator browserOldExpr boolean nil
;clip special function variables
calculator.clip from string ""
calculator.clip to string ""
;value special function variables
calculator.value at string ""
;x value at maximum special function variables
calculator.xmax nth string "1"
;x value at minimum special function variables
calculator.xmin nth string "1"
;ipn special function variables
calculator.ipn spurOrder string "3"
calculator.ipn refHarmonic string "1"
calculator.ipn spurHarmonic string "1"
calculator.ipn extPoint string "0"
calculator.ipn refOrder string "1"
;ipnVRI special function variables
calculator.ipnVRI spurHarmonic string ""
calculator.ipnVRI refHarmonic string ""
calculator.ipnVRI ordspur string ""
calculator.ipnVRI epoint string ""
calculator.ipnVRI rport string ""
calculator.ipnVRI measurePrompt cyclic "Input Referred IPN"
calculator.ipnVRI powerSwPrompt cyclic "Variable Sweep"
calculator.ipnVRI measure string ""
calculator.ipnVRI psweep string ""
;phaseNoise special function variables
calculator.phaseNoise nth string "0"
calculator.phaseNoise noiseResNam string "pnoise.pss"
;compression special function variables
calculator.compression nth string "0"
calculator.compression x string "0"
calculator.compression compress string "1"
calculator.compressionVRI harmonic string ""
calculator.compressionVRI epoint string ""
calculator.compressionVRI rport string ""
calculator.compressionVRI gcomp string ""
calculator.compressionVRI measurePrompt cyclic "Input Referred Compression"
calculator.compressionVRI measure string ""
;harmonic special function variable
calculator.harmonic nth string "0"
calculator.harmonic spurHarmonic string "1"
calculator.harmonic refHarmonic string "1"
;harmonicFreq special function variable
calculator.harmonicFreq nth string "1"
;tangent special function variables
calculator.tangent x string "0"
calculator.tangent y string "0"
calculator.tangent slope string "1.0"
;discrete fourier transform special function variables
calculator.dft from string ""
calculator.dft to string ""
calculator.dft samples string "64"
calculator.dft windowName cyclic "Rectangular"
calculator.dft smooth float 1.0
calculator.dft cgtype cyclic "(none)"
calculator.dft cohGain float 1.0
calculator.psd from string ""
calculator.psd to string ""
calculator.psd samples string "512"
calculator.psd windowName cyclic "Hanning"
calculator.psd smooth float 1.0
calculator.psd cgtype cyclic "(none)"
calculator.psd cohGain float 1.0
calculator.psd detrending cyclic "None"
calculator.psd windowSize string "256"
calculator.psdbb from string ""
calculator.psdbb to string ""
calculator.psdbb samples string "512"
calculator.psdbb windowName cyclic "Hanning"
calculator.psdbb smooth float 1.0
calculator.psdbb cgtype cyclic "(none)"
calculator.psdbb cohGain float 1.0
calculator.psdbb detrending cyclic "None"
calculator.psdbb windowSize string "256"
;total harmonic distortion special function variables
calculator.thd from string ""
calculator.thd to string ""
calculator.thd samples string "64"
calculator.thd fundamental string ""
;threshold crossing special function variables
calculator.cross value string "2.5"
calculator.cross nth string "1"
calculator.cross type cyclic "either"
;root value special function variables
calculator.root value string "2.5"
calculator.root nth string "1"
;fourier evaluation special function variables
calculator.fourEval from string ""
calculator.fourEval to string ""
calculator.fourEval by string ""
;convolution special function variables
calculator.convolve from string ""
calculator.convolve to string ""
calculator.convolve incr cyclic "linear"
calculator.convolve by string ""
;threshold delay special function variables
calculator.delay value_a string "2.5"
calculator.delay nth_a string "1"
calculator.delay type_a cyclic "either"
calculator.delay value_b string "2.5"
calculator.delay nth_b string "1"
calculator.delay type_b cyclic "either"
;bandwidth special function variables
calculator.bandwidth db string "3"
calculator.bandwidth type cyclic "low"
;rise time special function variables
calculator.riseTime initial string ""
calculator.riseTime itype cyclic "y at x"
calculator.riseTime final string ""
calculator.riseTime ftype cyclic "y at x"
calculator.riseTime theta_a string "10"
calculator.riseTime theta_b string "90"
;slew rate special function variables
calculator.slewRate initial string ""
calculator.slewRate itype cyclic "y at x"
calculator.slewRate final string ""
calculator.slewRate ftype cyclic "y at x"
calculator.slewRate theta_a string "10"
calculator.slewRate theta_b string "90"
;sample special function variables
calculator.sample from string ""
calculator.sample to string ""
calculator.sample incr cyclic "linear"
calculator.sample by string ""
;settling time special function variables
calculator.settlingTime initial string ""
calculator.settlingTime itype cyclic "y at x"
calculator.settlingTime final string ""
calculator.settlingTime ftype cyclic "y at x"
calculator.settlingTime theta string "5"
;overshoot special function variables
calculator.overshoot initial string ""
calculator.overshoot itype cyclic "y at x"
calculator.overshoot final string ""
calculator.overshoot ftype cyclic "y at x"
;table special function variables
calculator.table filename string ""
calculator.table name string ""
calculator.table xcolumn int 1
calculator.table ycolumn int 2
calculator.table xskip int 0
calculator.table yskip int 0
;left shift special function variables
calculator.lshift delta string "0"
;rms noise special function variables
calculator.rmsNoise from string ""
calculator.rmsNoise to string ""
;eyeDiagram special function variables
calculator.eyeDiagram start string "0"
calculator.eyeDiagram stop string "0"
calculator.eyeDiagram period string "0"
;defInteg special function variables
calculator.integ initial string ""
calculator.integ final string ""
; cdba Environment Variables
; This tool registration file should not be edited
; since customization is done via the file in
; <cdshier>/samples/.cdsenv
cdba dbInstNamingGlobalInc boolean nil
cdba dbNumCPU int 1
cdba dbStatCacheOn boolean nil
cdba.DBUPerUU behavioral int 160
cdba.DBUPerUU graphic int 1000
cdba.DBUPerUU logicModel int 160
cdba.DBUPerUU maskLayout int 1000
cdba.DBUPerUU netlist int 160
cdba.DBUPerUU package int 160
cdba.DBUPerUU PCB int 160
cdba.DBUPerUU schematic int 160
cdba.DBUPerUU schematicSymbol int 160
cdba.DBUPerUU stranger int 1000
cdba.DBUPerUU symbolic int 1000
cdba.DBUPerUU verilogMap int 160
cdba.userUnits behavioral cyclic "inch"
cdba.userUnits graphic cyclic "micron"
cdba.userUnits logicModel cyclic "inch"
cdba.userUnits maskLayout cyclic "micron"
cdba.userUnits netlist cyclic "inch"
cdba.userUnits package cyclic "inch"
cdba.userUnits PCB cyclic "inch"
cdba.userUnits schematic cyclic "inch"
cdba.userUnits schematicSymbol cyclic "inch"
cdba.userUnits stranger cyclic "micron"
cdba.userUnits symbolic cyclic "micron"
cdba.userUnits verilogMap cyclic "inch"
; this file is tools/dfII/etc/tools/cdsLibEditor/.cdsenv, format is:
; tool[.partition] varName varType default private {choices,min/max}
cdsLibEditor.main autoExclEdit boolean nil
cdsLibEditor.main warnExclLock boolean t
; this file is tools/dfII/etc/tools/cdsLibManager/.cdsenv, format is:
cdsLibManager.ckCancel useOptionText string ""
cdsLibManager.ckCancel useOptionsOn boolean nil
cdsLibManager.ckIn selectMatches toggle (t nil nil nil)
cdsLibManager.ckIn useOptionText string ""
cdsLibManager.ckIn useOptionsOn boolean nil
cdsLibManager.ckOut useOptionText string ""
cdsLibManager.ckOut useOptionsOn boolean nil
cdsLibManager.copy addToCategoryName string ""
cdsLibManager.copy addToCategoryOn boolean nil
cdsLibManager.copy addToCellsPattern string "*"
cdsLibManager.copy allViewsOn boolean t
cdsLibManager.copy exactHierOn boolean nil
cdsLibManager.copy extraViews string ""
cdsLibManager.copy hierOn boolean nil
cdsLibManager.copy skipLibsOn boolean t
cdsLibManager.copy skipLibsText string ""
cdsLibManager.copy skipLibsText1 string ""
cdsLibManager.copy skipLibsText10 string ""
cdsLibManager.copy skipLibsText11 string ""
cdsLibManager.copy skipLibsText12 string ""
cdsLibManager.copy skipLibsText13 string ""
cdsLibManager.copy skipLibsText14 string ""
cdsLibManager.copy skipLibsText15 string ""
cdsLibManager.copy skipLibsText2 string ""
cdsLibManager.copy skipLibsText3 string ""
cdsLibManager.copy skipLibsText4 string ""
cdsLibManager.copy skipLibsText5 string ""
cdsLibManager.copy skipLibsText6 string ""
cdsLibManager.copy skipLibsText7 string ""
cdsLibManager.copy skipLibsText8 string ""
cdsLibManager.copy skipLibsText9 string ""
cdsLibManager.copy updateChoice toggle (t nil)
cdsLibManager.copy updateOn boolean nil
cdsLibManager.copy viewsText string ""
cdsLibManager.copy addPropFiles boolean t
cdsLibManager.copyError overwriteAll boolean nil
cdsLibManager.copyGlobals expandRadio toggle (t nil)
cdsLibManager.copyGlobals mpsRadio toggle (t nil)
cdsLibManager.copyGlobals stopMutations boolean t
cdsLibManager.copyGlobals useMonitor boolean t
cdsLibManager.copyGlobals warnRenameDM boolean t
cdsLibManager.copyVersion openView boolean t
cdsLibManager.copyVersion toLibrary string ""
cdsLibManager.copyVersion toView string ""
cdsLibManager.copyVersion useOptionText string ""
cdsLibManager.copyVersion useOptionsOn boolean nil
cdsLibManager.copyWizard addToCategoryName string ""
cdsLibManager.copyWizard addToCategoryOn boolean nil
cdsLibManager.copyWizard addToCellsPattern string "*"
cdsLibManager.copyWizard extraViews string ""
cdsLibManager.copyWizard skipLibsText string ""
cdsLibManager.copyWizard skipLibsText1 string ""
cdsLibManager.copyWizard skipLibsText10 string ""
cdsLibManager.copyWizard skipLibsText11 string ""
cdsLibManager.copyWizard skipLibsText12 string ""
cdsLibManager.copyWizard skipLibsText13 string ""
cdsLibManager.copyWizard skipLibsText14 string ""
cdsLibManager.copyWizard skipLibsText15 string ""
cdsLibManager.copyWizard skipLibsText2 string ""
cdsLibManager.copyWizard skipLibsText3 string ""
cdsLibManager.copyWizard skipLibsText4 string ""
cdsLibManager.copyWizard skipLibsText5 string ""
cdsLibManager.copyWizard skipLibsText6 string ""
cdsLibManager.copyWizard skipLibsText7 string ""
cdsLibManager.copyWizard skipLibsText8 string ""
cdsLibManager.copyWizard skipLibsText9 string ""
cdsLibManager.copyWizard updateChoice toggle (t nil)
cdsLibManager.copyWizard updateOn boolean t
cdsLibManager.customize mapTimeout float 5.0
cdsLibManager.customize showDFIIWarning boolean t
cdsLibManager.customize startupFile string "cdsLibMgr.il"
cdsLibManager.database addDb1 string ""
cdsLibManager.database addDb2 string ""
cdsLibManager.database addDb3 string ""
cdsLibManager.database addDb4 string ""
cdsLibManager.database addDb5 string ""
cdsLibManager.database addDb6 string ""
cdsLibManager.database addDb7 string ""
cdsLibManager.database addDb8 string ""
cdsLibManager.database addDb9 string ""
cdsLibManager.database ddDb string "com.cadence.interfaces.libAccess.cddLib5xDatabase"
cdsLibManager.database server string "com.cadence.interfaces.libAccess.ladLibraryServer"
cdsLibManager.defaults fileRadio toggle (nil t nil)
cdsLibManager.defaults saveAllOn boolean nil
cdsLibManager.defaults saveAsText string ".cdsenv"
cdsLibManager.delete libCheckOn boolean t
cdsLibManager.delete localRadio toggle (t nil)
cdsLibManager.deleteTag overrideRadio toggle (t nil nil nil)
cdsLibManager.deleteView localRadio toggle (t nil)
cdsLibManager.filter cellFilter string ""
cdsLibManager.filter viewFilter string ""
; The log file format is 'baseName[.UID][.host][.PID][.sequence].log'
cdsLibManager.log addHostID boolean nil
cdsLibManager.log addProcID boolean nil
cdsLibManager.log addSequence boolean nil
cdsLibManager.log addUserID boolean nil
cdsLibManager.log baseName string "libManager"
cdsLibManager.main categoryText string ""
cdsLibManager.main cellLevelText string ""
cdsLibManager.main dblClickEditCellView boolean t
cdsLibManager.main libraryText string ""
cdsLibManager.main showCategoriesOn boolean nil
cdsLibManager.main showFilesOn boolean nil
cdsLibManager.main viewLevelText string ""
cdsLibManager.newLib dmRadio toggle (t nil)
cdsLibManager.newLib pathText string ""
cdsLibManager.option forceEnv boolean nil
cdsLibManager.option useDMfilter boolean t
cdsLibManager.option useFastDM boolean t
cdsLibManager.rename updateOn boolean t
cdsLibManager.renameRefLib refreshSessionOn boolean t
cdsLibManager.submit useNameOn boolean nil
cdsLibManager.submit useNameText string ""
cdsLibManager.submit useOptionText string ""
cdsLibManager.submit useOptionsOn boolean nil
cdsLibManager.update useNameOn boolean nil
cdsLibManager.update useNameText string ""
cdsLibManager.update useOptionText string ""
cdsLibManager.update useOptionsOn boolean nil
;cdsSpice environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;cdsSpice opts partition variables
cdsSpice.opts TEMPDC string "25"
cdsSpice.opts NSIG string "4"
cdsSpice.opts TIMSAT string "0"
cdsSpice.opts RELTOL string "1e-3"
cdsSpice.opts MKS string "1"
cdsSpice.opts ITL5 string "999999"
cdsSpice.opts ARTSTR string "0"
cdsSpice.opts GMINON string "2"
cdsSpice.opts LVLTIM string "2"
cdsSpice.opts VCESAT string "0.0"
cdsSpice.opts ITL3 string "4"
cdsSpice.opts SCALEM string "1"
cdsSpice.opts GO2OFF string "0"
cdsSpice.opts ITL4 string "25"
cdsSpice.opts AVSTEP string ".33"
cdsSpice.opts ITL1 string "100"
cdsSpice.opts ITL2 string "100"
cdsSpice.opts METHOD string "1"
cdsSpice.opts CHGTOL string "1e-14"
cdsSpice.opts TNOM string "25"
cdsSpice.opts MORBKP string ".1"
cdsSpice.opts ABSTOL string "1e-12"
cdsSpice.opts UIC string "0"
cdsSpice.opts SINWAV string "1e+6"
cdsSpice.opts GRTEXT string "1"
cdsSpice.opts PRNOTE string "1"
cdsSpice.opts VLIMAX string "50000"
cdsSpice.opts GMIN string "1e-12"
cdsSpice.opts GSAVE string "0"
cdsSpice.opts INTTIM string "0"
cdsSpice.opts CNVREV string "2.4"
cdsSpice.opts DCSAT string "0"
cdsSpice.opts TINIT string ""
cdsSpice.opts VBESAT string "0.6"
cdsSpice.opts QADLIN string "0"
cdsSpice.opts MFNOIS string "0"
cdsSpice.opts TRTOL string "7"
cdsSpice.opts SCALE string "1"
cdsSpice.opts PSFFLG string "1"
cdsSpice.opts SPICE2G string "0"
cdsSpice.opts WRFLAG string "0"
cdsSpice.opts SPTEMP string "1"
cdsSpice.opts RON string "1"
cdsSpice.opts NRAMP string "0"
cdsSpice.opts VNTOL string "1e-6"
cdsSpice.opts NOWARN string "0"
cdsSpice.opts VBCSAT string "0.15"
cdsSpice.opts DCOPPT string "1"
cdsSpice.opts MAXORD string "2"
cdsSpice.opts SPMESS string "1"
;cdsSpice outputs partition variables
cdsSpice.outputs allAnalogNV boolean t
cdsSpice.outputs allAnalogTC boolean nil
;cdsSpice envOpts partition variables
cdsSpice.envOpts updateFile string ""
cdsSpice.envOpts stimulusFile string ""
cdsSpice.envOpts instViewListTable string ""
cdsSpice.envOpts doInstBased boolean nil
cdsSpice.envOpts stopViewList string "cdsSpice spice"
cdsSpice.envOpts includeSyntax string "cdsSpice"
cdsSpice.envOpts initFile string ""
cdsSpice.envOpts printComments boolean nil
cdsSpice.envOpts netlistType string "hierarchical"
cdsSpice.envOpts generateMapFile boolean nil
cdsSpice.envOpts includeFile string ""
cdsSpice.envOpts instStopListTable string ""
cdsSpice.envOpts switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
;cdsSpice init partition variables
cdsSpice.init processPriority int 0
;cdsSpice dc partition variables
cdsSpice.dc enable toggle (nil)
cdsSpice.dc from string ""
cdsSpice.dc to string ""
cdsSpice.dc by string ""
cdsSpice.dc device string ""
;cdsSpice dcOpts partition variables
;cdsSpice noise partition variables
cdsSpice.noise enable toggle (nil)
cdsSpice.noise source string ""
cdsSpice.noise output string ""
cdsSpice.noise listEvery string "1"
;cdsSpice noiseOpts partition variables
;cdsSpice ac partition variables
cdsSpice.ac enable toggle (nil)
cdsSpice.ac from string ""
cdsSpice.ac to string ""
cdsSpice.ac incrType string "Logarithmic"
cdsSpice.ac lin string ""
cdsSpice.ac log string ""
;cdsSpice acOpts partition variables
;cdsSpice tran partition variables
cdsSpice.tran enable toggle (nil)
cdsSpice.tran from string ""
cdsSpice.tran to string ""
cdsSpice.tran by string ""
cdsSpice.tran delmax string ""
cdsSpice.tran continue boolean nil
cdsSpice.tran newParam boolean nil
;cdsSpice tranOpts partition variables
;cdsSpiceVerilog environment variables
;cdsSpiceVerilog opts partition variables
cdsSpiceVerilog.opts TEMPDC string "25"
cdsSpiceVerilog.opts NSIG string "4"
cdsSpiceVerilog.opts TIMSAT string "0"
cdsSpiceVerilog.opts RELTOL string "1e-3"
cdsSpiceVerilog.opts MKS string "1"
cdsSpiceVerilog.opts ITL5 string "999999"
cdsSpiceVerilog.opts ARTSTR string "0"
cdsSpiceVerilog.opts GMINON string "2"
cdsSpiceVerilog.opts LVLTIM string "2"
cdsSpiceVerilog.opts VCESAT string "0.0"
cdsSpiceVerilog.opts ITL3 string "4"
cdsSpiceVerilog.opts SCALEM string "1"
cdsSpiceVerilog.opts GO2OFF string "0"
cdsSpiceVerilog.opts ITL4 string "25"
cdsSpiceVerilog.opts AVSTEP string ".33"
cdsSpiceVerilog.opts ITL1 string "100"
cdsSpiceVerilog.opts ITL2 string "100"
cdsSpiceVerilog.opts METHOD string "1"
cdsSpiceVerilog.opts CHGTOL string "1e-14"
cdsSpiceVerilog.opts TNOM string "25"
cdsSpiceVerilog.opts MORBKP string ".1"
cdsSpiceVerilog.opts ABSTOL string "1e-12"
cdsSpiceVerilog.opts UIC string "0"
cdsSpiceVerilog.opts GRTEXT string "1"
cdsSpiceVerilog.opts SINWAV string "1e+6"
cdsSpiceVerilog.opts PRNOTE string "1"
cdsSpiceVerilog.opts VLIMAX string "50000"
cdsSpiceVerilog.opts INTTIM string "0"
cdsSpiceVerilog.opts GSAVE string "0"
cdsSpiceVerilog.opts GMIN string "1e-12"
cdsSpiceVerilog.opts DCSAT string "0"
cdsSpiceVerilog.opts CNVREV string "2.4"
cdsSpiceVerilog.opts TINIT string ""
cdsSpiceVerilog.opts MFNOIS string "0"
cdsSpiceVerilog.opts QADLIN string "0"
cdsSpiceVerilog.opts VBESAT string "0.6"
cdsSpiceVerilog.opts PSFFLG string "1"
cdsSpiceVerilog.opts SCALE string "1"
cdsSpiceVerilog.opts TRTOL string "7"
cdsSpiceVerilog.opts SPICE2G string "0"
cdsSpiceVerilog.opts SPTEMP string "1"
cdsSpiceVerilog.opts WRFLAG string "0"
cdsSpiceVerilog.opts RON string "1"
cdsSpiceVerilog.opts NRAMP string "0"
cdsSpiceVerilog.opts NOWARN string "0"
cdsSpiceVerilog.opts VNTOL string "1e-6"
cdsSpiceVerilog.opts MAXORD string "2"
cdsSpiceVerilog.opts DCOPPT string "1"
cdsSpiceVerilog.opts VBCSAT string "0.15"
cdsSpiceVerilog.opts SPMESS string "1"
;cdsSpiceVerilog outputs partition variables
cdsSpiceVerilog.outputs allDigitalNV boolean t
cdsSpiceVerilog.outputs allAnalogNV boolean t
cdsSpiceVerilog.outputs allAnalogTC boolean nil
;cdsSpiceVerilog verimixOpts partition variables
cdsSpiceVerilog.verimixOpts filename6 string ""
cdsSpiceVerilog.verimixOpts maxDCIter int 0
cdsSpiceVerilog.verimixOpts scope1 string ""
cdsSpiceVerilog.verimixOpts scope10 string ""
cdsSpiceVerilog.verimixOpts filename8 string ""
cdsSpiceVerilog.verimixOpts dcInterval float 0.0
cdsSpiceVerilog.verimixOpts scope3 string ""
cdsSpiceVerilog.verimixOpts scope8 string ""
cdsSpiceVerilog.verimixOpts scope7 string ""
cdsSpiceVerilog.verimixOpts filename7 string ""
cdsSpiceVerilog.verimixOpts scope string ""
cdsSpiceVerilog.verimixOpts filename4 string ""
cdsSpiceVerilog.verimixOpts filename string ""
cdsSpiceVerilog.verimixOpts filename1 string ""
cdsSpiceVerilog.verimixOpts scope9 string ""
cdsSpiceVerilog.verimixOpts importsdfswitch boolean nil
cdsSpiceVerilog.verimixOpts filename2 string ""
cdsSpiceVerilog.verimixOpts numberofsdffiles int 2
cdsSpiceVerilog.verimixOpts scope2 string ""
cdsSpiceVerilog.verimixOpts scope6 string ""
cdsSpiceVerilog.verimixOpts filename10 string ""
cdsSpiceVerilog.verimixOpts delaymodechoice string "Ignore"
cdsSpiceVerilog.verimixOpts sdfmixedswitch boolean t
cdsSpiceVerilog.verimixOpts filename9 string ""
cdsSpiceVerilog.verimixOpts scope5 string ""
cdsSpiceVerilog.verimixOpts filename5 string ""
cdsSpiceVerilog.verimixOpts filename3 string ""
cdsSpiceVerilog.verimixOpts scope4 string ""
;cdsSpiceVerilog verilogOpts partition variables
cdsSpiceVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
cdsSpiceVerilog.verilogOpts optionsFile string ""
cdsSpiceVerilog.verilogOpts twinTurbo boolean nil
cdsSpiceVerilog.verilogOpts suppressMessages boolean nil
cdsSpiceVerilog.verilogOpts libraryFile string ""
cdsSpiceVerilog.verilogOpts behaveProfile boolean nil
cdsSpiceVerilog.verilogOpts verimixLog string "verilog.log"
cdsSpiceVerilog.verilogOpts simVision boolean nil
cdsSpiceVerilog.verilogOpts pulseSpec boolean nil
cdsSpiceVerilog.verilogOpts commandFile string ""
cdsSpiceVerilog.verilogOpts pulseError int 100
cdsSpiceVerilog.verilogOpts stopCompile boolean nil
cdsSpiceVerilog.verilogOpts keepNodes string "Minimum"
cdsSpiceVerilog.verilogOpts accelerationCA boolean nil
cdsSpiceVerilog.verilogOpts turboRadio string "Default"
cdsSpiceVerilog.verilogOpts libraryDir string ""
cdsSpiceVerilog.verilogOpts suppressWarnings boolean nil
cdsSpiceVerilog.verilogOpts accelerationSwitches boolean nil
cdsSpiceVerilog.verilogOpts accelerationNormal boolean t
cdsSpiceVerilog.verilogOpts delayType string "Typical"
cdsSpiceVerilog.verilogOpts pulseReject int 100
cdsSpiceVerilog.verilogOpts delayMode string "Default"
cdsSpiceVerilog.verilogOpts vermixBinary string "verilog.vmx"
;cdsSpiceVerilog init partition variables
cdsSpiceVerilog.init processPriority int 0
;cdsSpiceVerilog envOpts partition variables
cdsSpiceVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
cdsSpiceVerilog.envOpts mspNetlistMode string "Flat"
cdsSpiceVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistEscapeName boolean nil
cdsSpiceVerilog.envOpts updateFile string ""
cdsSpiceVerilog.envOpts stimulusFile string ""
cdsSpiceVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
cdsSpiceVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
cdsSpiceVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
cdsSpiceVerilog.envOpts includeSyntax string "cdsSpice"
cdsSpiceVerilog.envOpts mspSetupNetlistPinMap boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistBus boolean t
cdsSpiceVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
cdsSpiceVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
cdsSpiceVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
cdsSpiceVerilog.envOpts mspSetupNetlistExplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
cdsSpiceVerilog.envOpts initFile string ""
cdsSpiceVerilog.envOpts printComments boolean nil
cdsSpiceVerilog.envOpts includeFile string ""
cdsSpiceVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
cdsSpiceVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
cdsSpiceVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimTimeValue int 1
cdsSpiceVerilog.envOpts mspSetupNetlistUseLib boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistNullPort boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistDropPortRange boolean t
cdsSpiceVerilog.envOpts mspSetupNetlistUpCase boolean nil
cdsSpiceVerilog.envOpts generateMapFile boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;cdsSpiceVerilog dc partition variables
cdsSpiceVerilog.dc enable toggle (nil)
cdsSpiceVerilog.dc from string ""
cdsSpiceVerilog.dc to string ""
cdsSpiceVerilog.dc by string ""
cdsSpiceVerilog.dc device string ""
;cdsSpiceVerilog dcOpts partition variables
;cdsSpiceVerilog noise partition variables
cdsSpiceVerilog.noise enable toggle (nil)
cdsSpiceVerilog.noise source string ""
cdsSpiceVerilog.noise output string ""
cdsSpiceVerilog.noise listEvery string "1"
;cdsSpiceVerilog noiseOpts partition variables
;cdsSpiceVerilog ac partition variables
cdsSpiceVerilog.ac enable toggle (nil)
cdsSpiceVerilog.ac from string ""
cdsSpiceVerilog.ac to string ""
cdsSpiceVerilog.ac incrType string "Logarithmic"
cdsSpiceVerilog.ac lin string ""
cdsSpiceVerilog.ac log string ""
;cdsSpiceVerilog acOpts partition variables
;cdsSpiceVerilog tran partition variables
cdsSpiceVerilog.tran enable toggle (nil)
cdsSpiceVerilog.tran from string ""
cdsSpiceVerilog.tran to string ""
cdsSpiceVerilog.tran by string ""
cdsSpiceVerilog.tran delmax string ""
cdsSpiceVerilog.tran continue boolean nil
cdsSpiceVerilog.tran newParam boolean nil
;cdsSpiceVerilog tranOpts partition variables
; CMX CONSTRAINT MANAGER - ENVIRONMENT VARIABLES (FACTORY DEFAULTS)
; This tool registration file should not be edited since customization
; is done via the file in <cdshier>/samples/.cdsenv
;FACTORY DEFAULTS FOR NET-BASED SUPER CATEGORY (cmxNetBasedSuperCat)
;Net Class To Net Category (cmxClassToNetCat)
;default weight for constraints
cmx.cmxClassToNetCat defaultWeight int 200
;inter-layer clearance
cmx.cmxClassToNetCat defVal_ilc float 0.0
cmx.cmxClassToNetCat minVal_ilc float 0.0
cmx.cmxClassToNetCat maxVal_ilc float 0.0
;layer depth
cmx.cmxClassToNetCat defVal_depth int 0
cmx.cmxClassToNetCat minVal_depth int 0
cmx.cmxClassToNetCat maxVal_depth int 0
;Net-Class To Net-Class Category (cmxClassToClassCat)
cmx.cmxClassToClassCat defaultWeight int 200
cmx.cmxClassToClassCat defVal_ilc float 0.0
cmx.cmxClassToClassCat minVal_ilc float 0.0
cmx.cmxClassToClassCat maxVal_ilc float 0.0
;layer depth
cmx.cmxClassToClassCat defVal_depth int 0
cmx.cmxClassToClassCat minVal_depth int 0
cmx.cmxClassToClassCat maxVal_depth int 0
;Net To Net Category (cmxNetToNetCat)
cmx.cmxNetToNetCat defaultWeight int 200
cmx.cmxNetToNetCat defVal_ilc float 0.0
cmx.cmxNetToNetCat minVal_ilc float 0.0
cmx.cmxNetToNetCat maxVal_ilc float 0.0
;layer depth
cmx.cmxNetToNetCat defVal_depth int 0
cmx.cmxNetToNetCat minVal_depth int 0
cmx.cmxNetToNetCat maxVal_depth int 0
;differential pair gap
cmx.cmxNetToNetCat defVal_diffgap float 0.0
cmx.cmxNetToNetCat minVal_diffgap float 0.0
cmx.cmxNetToNetCat maxVal_diffgap float 0.0
;tandem shield overhang
cmx.cmxNetToNetCat defVal_tanhang float 0.0
cmx.cmxNetToNetCat minVal_tanhang float 0.0
cmx.cmxNetToNetCat maxVal_tanhang float 0.0
;parallel shield gap
cmx.cmxNetToNetCat defVal_pargap float 0.0
cmx.cmxNetToNetCat minVal_pargap float 0.0
cmx.cmxNetToNetCat maxVal_pargap float 0.0
;parallel shield width
cmx.cmxNetToNetCat defVal_parwidth float 0.0
cmx.cmxNetToNetCat minVal_parwidth float 0.0
cmx.cmxNetToNetCat maxVal_parwidth float 0.0
;Net/Net-Class Category (cmxNetCat)
cmx.cmxNetCat defaultWeight int 200
;net priority
cmx.cmxNetCat defVal_pri int 0
cmx.cmxNetCat minVal_pri int 0
cmx.cmxNetCat maxVal_pri int 255
;net width
cmx.cmxNetCat defVal_width float 0.0
cmx.cmxNetCat minVal_width float 0.0
cmx.cmxNetCat maxVal_width float 0.0
;minimum IR drop
cmx.cmxNetCat defVal_minird float 0.0
cmx.cmxNetCat minVal_minird float 0.0
cmx.cmxNetCat maxVal_minird float 0.0
;maximum IR drop
cmx.cmxNetCat defVal_maxird float 0.0
cmx.cmxNetCat minVal_maxird float 0.0
cmx.cmxNetCat maxVal_maxird float 0.0
;FACTORY DEFAULTS FOR GEOMETRIC SUPER CATEGORY (cmxGeometricSuperCat)
;Symmetry Category (cmxSymCat)
cmx.cmxSymCat defaultWeight int 200
;axis name
cmx.cmxSymCat defVal_axis string ""
;Grouping Category (cmxGroupingCat)
cmx.cmxGroupingCat defaultWeight int 200
;preserve relative position
cmx.cmxGroupingCat defVal_prPos boolean t
;no fence needed
cmx.cmxGroupingCat defVal_noFence boolean t
;fence shape name
cmx.cmxGroupingCat defVal_fence string ""
;exclude all
cmx.cmxGroupingCat defVal_exclAll boolean nil
;Alignment Category (cmxAlignCat)
cmx.cmxAlignCat defaultWeight int 200
;orientation
cmx.cmxAlignCat defVal_orient string "NO_CARE"
;alignment reference
cmx.cmxAlignCat defVal_alignRef string "NO_CARE"
;reference segment
cmx.cmxAlignCat defVal_segment int 0
;inner or outer edge
cmx.cmxAlignCat defVal_inner boolean t
;alignment layer
cmx.cmxAlignCat defVal_alignLayer string "bBox"
;check ordering
cmx.cmxAlignCat defVal_order boolean t
;compactor direction (for Compactor only)
cmx.cmxAlignCat defVal_compactDir boolean nil
;Fixed Category (cmxFixedCat)
cmx.cmxFixedCat defaultWeight int 200
;check x position
cmx.cmxFixedCat defVal_x boolean t
;default x value
cmx.cmxFixedCat defVal_xVal float 0.0
;check y position
cmx.cmxFixedCat defVal_y boolean t
;default y value
cmx.cmxFixedCat defVal_yVal float 0.0
;default orientation
cmx.cmxFixedCat defVal_orient string "AS_IS"
;default reference
cmx.cmxFixedCat defVal_refer string "CENTER"
;default user movable
cmx.cmxFixedCat defVal_userMovable boolean nil
;Distance Category (cmxDistCat)
cmx.cmxDistCat defaultWeight int 200
;check minimum manhattan x distance
cmx.cmxDistCat defVal_minX boolean t
;minimum manhattan x distance value
cmx.cmxDistCat defVal_minXVal float 0.0
;check maximum manhattan x distance
cmx.cmxDistCat defVal_maxX boolean t
;maximum manhattan x distance value
cmx.cmxDistCat defVal_maxXVal float 0.0
;check minimum manhattan y distance
cmx.cmxDistCat defVal_minY boolean t
;minimum manhattan y distance value
cmx.cmxDistCat defVal_minYVal float 0.0
;check maximum manhattan y distance
cmx.cmxDistCat defVal_maxY boolean t
;maximum manhattan y distance
cmx.cmxDistCat defVal_maxYVal float 0.0
;reference for measurement on x-axis
cmx.cmxDistCat defVal_referX string "CENTER"
;reference for measurement on y-axis
cmx.cmxDistCat defVal_referY string "CENTER"
;ROD Alignment Category (cmxRodAlignCat)
;default name for ROD object 1
;default handle name for ROD object 1
;default name for ROD object 2
;default handle name for ROD object 2
compactor hilite1LPP string "hilite drawing"
compactor hilite2LPP string "marker error"
compactor hilite3LPP string "hilite drawing1"
compactor hilite4LPP string "hilite drawing2"
compactor cpCpathLPP string "annotate drawing7"
compactor cpAuxLPP string "annotate drawing8"
compactor cpOutlineLPP string "annotate drawing9"
compactor useDBox boolean t
compactor arrowScale float 1.0
compactor zoomScale float 1.2
compactor checkSaved boolean t
conn2sch src_sch_lib string ""
conn2sch src_cell_name string ""
conn2sch src_view_name string ""
conn2sch dest_sch_lib string ""
conn2sch dest_view_name string "schematic"
conn2sch dest_cell_name string ""
conn2sch dest_symbol_view_name string "symbol"
conn2sch ref_lib_list string "analogLib basic sample"
conn2sch log_file_name string "./conn2sch.log"
conn2sch import_if_exists int 0
conn2sch sheet_symbol string "none "
conn2sch line_line_spacing float 0.2
conn2sch line_component_spacing float 0.5
conn2sch density_level int 0
conn2sch label_height int 10
conn2sch pin_placement string "left_and_right_sides"
conn2sch page_col_limit int 1024
conn2sch page_row_limit int 1024
conn2sch full_place_and_route boolean t
conn2sch optimize_wire_label_locn boolean nil
conn2sch minimize_crossovers boolean nil
conn2sch generate_square_schematic boolean t
conn2sch extract_schematic boolean t
conn2sch verbose boolean nil
;Digital Ciruit Design Flow Environment Defaults
;FORMAT: tool[.partition] varName type value private {choices, minmax} comment
;Session Options
dcdf dcdfNoDirectNetlister boolean nil
dcdf dcdfDefaultFileDir string ""
; ddserv Environment Variables
ddserv.browser onOpen boolean nil
ddserv.browser onOther boolean nil
ddserv.browser onPlace boolean nil
ddserv.ciw promptOnExit boolean t
ddserv.he objectFilter string "same"
ddserv.he objectScope string "current instance"
ddserv.lib dmChoice string "No DM"
ddserv.lib enableCopyInDFII boolean nil
ddserv.lib newLibDir string ""
ddserv.lib techChoice cyclic "compile"
ddserv showWhatsNew string "yes"
; Graphics Editor and Design Editor Environment Variables
; Installation-wide customizations should be made to the
; to the .cdsenv file in $CDS_INST_DIR/tools/dfII/samples
; directory. Make user-specific customizations to the
; .cdsenv file in your home directory.
graphic accessEdgesOn boolean nil
graphic arrayDisplay string "Full"
graphic askSaveOnReturn boolean t
graphic coalesceLimit int 10
graphic coalesceRatio int 10
graphic defaultNewCellName string ""
graphic defaultNewLibName string ""
graphic defaultNewViewName string ""
graphic defaultOpenCellName string ""
graphic defaultOpenLibName string ""
graphic defaultOpenViewName string ""
graphic defaultToolName string ""
graphic displayPinNames boolean t
graphic displayStretchHandles boolean t
graphic displaySchDashText boolean nil
graphic dotsOn boolean t
graphic drawAxesOn boolean t
graphic drawDottedGridOn boolean t
graphic drawGridOn boolean t
graphic drawInstancePins boolean t
graphic drawPRBoundary boolean nil
graphic drawSurroundingOn boolean t
graphic drfPath string ""
graphic dynamicHilightOn boolean t
graphic eipRedraw boolean t
graphic filterSize float 1.0
graphic filterSizeDrawingStyle string "filled"
graphic gridMultiple int 5
graphic gridSpacing float 1.0
graphic iconsOn boolean t
graphic instLabel string "master"
graphic iterNum int 500
graphic jumpersOn boolean t
graphic leCheckMissingLayers boolean nil
graphic leCheckMissingMasters boolean nil
graphic leDispNetExpr boolean t
graphic markerZoom boolean nil
graphic markerShowIgnore boolean t
graphic markerSeverity string "all"
graphic markerZoomScale int 4
graphic maxDragFig int 500
graphic minLabelSize float 1.0
graphic minRefreshArea int 500
graphic minStippleSize float 1.0
graphic netsOn boolean t
graphic originMarkersOn boolean t
graphic outlineOnly boolean t
graphic packetDialogBoxes boolean t
graphic partialSelect boolean t
graphic pathCL string "yes"
graphic netExprDisplay string "expression only"
graphic pathWidth float 5.0
graphic probeTextOn boolean t
graphic pruneSize float 10
graphic segSnapMode string "anyAngle"
graphic selectionAperture int 5
graphic snapMode string "anyAngle"
graphic snapToGrid boolean t
graphic startLevel int 0
graphic stopLevel int 0
graphic stretchHandlesLayer string "y0 drawing"
graphic textJustificationOn boolean t
graphic tinyInstDetail boolean nil
graphic transformMarkersOn boolean t
graphic useTrueBBox boolean t
graphic viewNameList string ""
graphic viewNameToTypeList string ""
graphic xSnapSpacing float 1.0
graphic ySnapSpacing float 1.0
graphic cursorShape boolean nil
graphic drawEngine int 0
graphic openToStopLevel boolean nil
graphic displayViaShapes boolean nil
;hspiceD environment variables
;hspiceD opts partition variables
hspiceD.opts PARHIER string "LOCAL"
hspiceD.opts GENK boolean nil
hspiceD.opts RISETIME string "0"
hspiceD.opts RELQ string "1e-2"
hspiceD.opts FFTOUT boolean nil
hspiceD.opts LVLTIM string "DVDT (1)"
hspiceD.opts ARTIST string "On (2)"
hspiceD.opts NEWTOL boolean nil
hspiceD.opts ABSMOS string "1e-6"
hspiceD.opts DIAGNOSTIC boolean nil
hspiceD.opts MODMONTE boolean nil
hspiceD.opts VFLOOR string "0"
hspiceD.opts FS string "25e-2"
hspiceD.opts CO string "Narrow (80)"
hspiceD.opts DEFAS string "0"
hspiceD.opts RESMIN string "1e-5"
hspiceD.opts WARNLIMIT string "1"
hspiceD.opts TRCON string "On (1)"
hspiceD.opts PSF string "ASCII (2)"
hspiceD.opts BRIEF boolean nil
hspiceD.opts ICSWEEP boolean nil
hspiceD.opts DCFOR string "0"
hspiceD.opts DCHOLD string "1"
hspiceD.opts GMIN string "1e-12"
hspiceD.opts INGOLD string "SPICE (2)"
hspiceD.opts NODE boolean nil
hspiceD.opts DCSTEP string "0"
hspiceD.opts ZUKEN string "Off (1)"
hspiceD.opts TRTOL string "7"
hspiceD.opts BYTOL string "5e-5"
hspiceD.opts AUTOSTOP boolean nil
hspiceD.opts LIMTIM string "2.0"
hspiceD.opts EXPMAX string "8e+1"
hspiceD.opts DVDT string "Balance (3)"
hspiceD.opts PUTMEAS boolean nil
hspiceD.opts NOWARN boolean nil
hspiceD.opts MONTECON boolean nil
hspiceD.opts BEEP string "Off (0)"
hspiceD.opts MEASSORT boolean nil
hspiceD.opts NUMDGT string "4"
hspiceD.opts ITL5 string "0"
hspiceD.opts BADCHR boolean nil
hspiceD.opts PIVTOL string "1e-15"
hspiceD.opts METHOD string "TRAP"
hspiceD.opts LIMPTS string "2001"
hspiceD.opts CHGTOL string "1e-15"
hspiceD.opts GSHUNT string "0"
hspiceD.opts DVTR string "1e+3"
hspiceD.opts DI string "0"
hspiceD.opts HIER_SCALE string "None ()"
hspiceD.opts CSHDC string "1e-12"
hspiceD.opts RELI string "1e-2"
hspiceD.opts PATHNUM boolean nil
hspiceD.opts DEFW string "1e-4"
hspiceD.opts POST_VERSION string "2001"
hspiceD.opts DCON string "Auto (0)"
hspiceD.opts DEFL string "1e-4"
hspiceD.opts DEFNRS string "0"
hspiceD.opts ABSV string "5e-5"
hspiceD.opts CONVERGE string "Autoconvergance (0)"
hspiceD.opts NOPIV boolean nil
hspiceD.opts LENNAM string "8"
hspiceD.opts DCAP string "2"
hspiceD.opts DLENCSDF string "5"
hspiceD.opts ITLPZ string "100"
hspiceD.opts MBYPASS string "1"
hspiceD.opts GMINDC string "1e-12"
hspiceD.opts RELV string "1e-3"
hspiceD.opts GRAMP string "0"
hspiceD.opts ASPEC boolean nil
hspiceD.opts DV string "1e+3"
hspiceD.opts SEED string "259200"
hspiceD.opts RMIN string "1e-9"
hspiceD.opts RELVDC string "1e-3"
hspiceD.opts ACCT string "Enabled (1)"
hspiceD.opts RELMOS string "5e-2"
hspiceD.opts TEMPDC string "25"
hspiceD.opts ACCURATE boolean nil
hspiceD.opts CSDF boolean nil
hspiceD.opts SEARCH boolean nil
hspiceD.opts MAXAMP string "0"
hspiceD.opts NOMOD boolean nil
hspiceD.opts PIVREF string "1e8"
hspiceD.opts NOPAGE boolean nil
hspiceD.opts ALT9999 boolean nil
hspiceD.opts CAPTAB boolean nil
hspiceD.opts ITL1 string "2e+2"
hspiceD.opts ITL2 string "5e+1"
hspiceD.opts POST string "Binary (1)"
hspiceD.opts PIVREL string "1e-20"
hspiceD.opts ALT999 boolean nil
hspiceD.opts MEASFAIL boolean nil
hspiceD.opts STATFL string "Create .st0 (0)"
hspiceD.opts BKPSIZ string "5000"
hspiceD.opts ABSVAR string ".5"
hspiceD.opts ITRPRT boolean nil
hspiceD.opts SPICE boolean nil
hspiceD.opts GMAX string "1e+2"
hspiceD.opts RMAX string "2"
hspiceD.opts OFF boolean nil
hspiceD.opts BYPASS string "1"
hspiceD.opts OPTS boolean nil
hspiceD.opts IMIN string "3"
hspiceD.opts KCLTEST boolean nil
hspiceD.opts CDS string "Off (0)"
hspiceD.opts RELH string "5e-2"
hspiceD.opts ALTCHK string "On (1)"
hspiceD.opts ACOUT string "Star-Hspice Method (1)"
hspiceD.opts FT string "25e-2"
hspiceD.opts WL boolean nil
hspiceD.opts LIST boolean nil
hspiceD.opts RELVAR string ".30"
hspiceD.opts MAXORD string "Normal (2)"
hspiceD.opts DEFPS string "0"
hspiceD.opts MEASOUT boolean nil
hspiceD.opts FAST boolean nil
hspiceD.opts CPTIME string "1e+7"
hspiceD.opts IMAX string "8"
hspiceD.opts DEFNRD string "0"
hspiceD.opts OPTLST string "No Info (0)"
hspiceD.opts ABSVDC string "5e-5"
hspiceD.opts INTERP boolean nil
hspiceD.opts PROBE boolean nil
hspiceD.opts DCCAP boolean nil
hspiceD.opts DEFAD string "0"
hspiceD.opts TIMERES string "1e-15"
hspiceD.opts SCALM string "1"
hspiceD.opts TNOM string "25"
hspiceD.opts POSTTOP string "0"
hspiceD.opts MODSRH boolean nil
hspiceD.opts KLIM string "1e-2"
hspiceD.opts H9007 boolean nil
hspiceD.opts UNWRAP boolean nil
hspiceD.opts CVTOL string ".2"
hspiceD.opts PLIM string "SPICE (1)"
hspiceD.opts MENTOR string "Off (0)"
hspiceD.opts MEASDGT string "4"
hspiceD.opts NOTOP boolean nil
hspiceD.opts MU string ".5"
hspiceD.opts DEFPD string "0"
hspiceD.opts SLOPETOL string ".5"
hspiceD.opts SCALE string "1"
hspiceD.opts CSHUNT string "0"
hspiceD.opts EPSMIN string "1e-28"
hspiceD.opts EXPLI string "0"
hspiceD.opts NOELCK boolean nil
hspiceD.opts ABSI string "1e-9"
hspiceD.opts BINPRINT boolean nil
hspiceD.opts PIVOT string "Fast, non-pivoting (10)"
hspiceD.opts ITLPTRAN string "30"
hspiceD.opts PURETP boolean nil
hspiceD.opts ABSH string "0"
;hspiceD outputs partition variables
hspiceD.outputs allAnalogNV boolean t
hspiceD.outputs allAnalogTC boolean nil
;hspiceD envOpts partition variables
hspiceD.envOpts autoDisplay boolean t
hspiceD.envOpts stopViewList string "hspiceD spice"
hspiceD.envOpts printComments boolean nil
hspiceD.envOpts switchViewList string "hspiceD spice cmos_sch cmos.sch schematic"
;hspiceD init partition variables
hspiceD.init processPriority int 0
;hspiceD ac partition variables
hspiceD.ac enable toggle (nil)
hspiceD.ac sweepType string "decade"
hspiceD.ac numPoints string "10"
hspiceD.ac fstart string ""
hspiceD.ac fstop string ""
hspiceD.ac points string ""
;hspiceD acOpts partition variables
;hspiceD dc partition variables
hspiceD.dc enable toggle (nil)
hspiceD.dc sweep string "Source"
hspiceD.dc designVar string ""
hspiceD.dc source string ""
hspiceD.dc sweepType string "Automatic"
hspiceD.dc start string ""
hspiceD.dc stop string ""
hspiceD.dc stepSize string ""
hspiceD.dc numPoints string ""
hspiceD.dc poiNumPoints string ""
hspiceD.dc points string ""
;hspiceD dcOpts partition variables
;hspiceD noise partition variables
hspiceD.noise enable toggle (nil)
hspiceD.noise node string ""
hspiceD.noise insrc string ""
hspiceD.noise nums string "0"
;hspiceD noiseOpts partition variables
;hspiceD op partition variables
hspiceD.op enable toggle (nil)
hspiceD.op format string "all"
hspiceD.op time string ""
;hspiceD opOpts partition variables
;hspiceD tran partition variables
hspiceD.tran enable toggle (nil)
hspiceD.tran start string ""
hspiceD.tran stop string ""
hspiceD.tran step string ""
hspiceD.tran uic boolean nil
;hspiceD tranOpts partition variables
;hspiceS environment variables
;hspiceS opts partition variables
hspiceS.opts PARHIER string "GLOBAL"
hspiceS.opts GENK string "1"
hspiceS.opts RELQ string "1e-2"
hspiceS.opts LVLTIM string "default ( 1 )"
hspiceS.opts BKPSZE string "5000"
hspiceS.opts ARTIST string "artistdefault ( 2 )"
hspiceS.opts ABSMOS string "1e-6"
hspiceS.opts NEWTOL string "off"
hspiceS.opts RMAXDC string "1e+2"
hspiceS.opts DIAGNOSTIC string "off"
hspiceS.opts VFLOOR string "0"
hspiceS.opts FS string "25e-2"
hspiceS.opts CO string "78"
hspiceS.opts DEFAS string "0"
hspiceS.opts UIC string "off"
hspiceS.opts RESMIN string "1e-5"
hspiceS.opts WARNLIMIT string "1"
hspiceS.opts PSF string "artistdefault ( 2 )"
hspiceS.opts BRIEF string "off"
hspiceS.opts ICSWEEP string "default ( 1 )"
hspiceS.opts DCFOR string "0"
hspiceS.opts DCHOLD string "1"
hspiceS.opts GMIN string "1e-12"
hspiceS.opts INGOLD string "artistdefault ( 2 )"
hspiceS.opts DCSTEP string "0"
hspiceS.opts NODE string "off"
hspiceS.opts TRTOL string "7"
hspiceS.opts LIMTIM string "2.0"
hspiceS.opts EXPMAX string "8e+1"
hspiceS.opts DVDT string "default ( 3 )"
hspiceS.opts NOWARN string "off"
hspiceS.opts ITL5 string "0"
hspiceS.opts NUMDGT string "default ( 4 )"
hspiceS.opts BADCHR string "off"
hspiceS.opts PIVTOL string "1e-15"
hspiceS.opts LIMPTS string "2001"
hspiceS.opts METHOD string "TRAP"
hspiceS.opts CHGTOL string "1e-15"
hspiceS.opts GSHUNT string "0"
hspiceS.opts DVTR string "1e+3"
hspiceS.opts DI string "1e+2"
hspiceS.opts CSHDC string "1e-12"
hspiceS.opts RELI string "1e-2"
hspiceS.opts PATHNUM string "off"
hspiceS.opts DEFW string "1e-4"
hspiceS.opts DCON string "default ( 0 )"
hspiceS.opts DEFL string "1e-4"
hspiceS.opts DEFNRS string "0"
hspiceS.opts TIMRES string "1E-12"
hspiceS.opts CONVERGE string "default ( 1 )"
hspiceS.opts ABSV string "5e-5"
hspiceS.opts LENNAM string "8"
hspiceS.opts NOPIV string "off"
hspiceS.opts DCAP string "default ( 2 )"
hspiceS.opts GMINDC string "1e-12"
hspiceS.opts RELV string "1e-3"
hspiceS.opts GRAMP string "0"
hspiceS.opts ASPEC string "off"
hspiceS.opts DV string "1e+3"
hspiceS.opts RMIN string "1e-9"
hspiceS.opts RELVDC string "1e-3"
hspiceS.opts ACCT string "default ( 1 )"
hspiceS.opts SPMESS string "default ( 1 )"
hspiceS.opts RELMOS string "5e-2"
hspiceS.opts TEMPDC string "25"
hspiceS.opts CSDF string "off"
hspiceS.opts ACCURA string "off"
hspiceS.opts MAXAMP string "0"
hspiceS.opts NOMOD string "off"
hspiceS.opts PIVREF string "1e8"
hspiceS.opts NOPAGE string "off"
hspiceS.opts CAPTAB string "off"
hspiceS.opts ITL1 string "2e+2"
hspiceS.opts ITL2 string "5e+1"
hspiceS.opts POST string "default ( 0 )"
hspiceS.opts PIVREL string "1e-4"
hspiceS.opts ABSVAR string ".5"
hspiceS.opts ITRPRT string "off"
hspiceS.opts SPICE string "off"
hspiceS.opts GMAX string "1e+2"
hspiceS.opts RMAX string "2"
hspiceS.opts BYPASS string "default ( 0 )"
hspiceS.opts OFF string "0"
hspiceS.opts IMIN string "3"
hspiceS.opts KCLTEST string "off"
hspiceS.opts OPTS string "off"
hspiceS.opts RELH string "5e-2"
hspiceS.opts ACOUT string "default ( 1 )"
hspiceS.opts FT string "25e-2"
hspiceS.opts WL string "default ( 0 )"
hspiceS.opts LIST string "on"
hspiceS.opts RELVAR string ".30"
hspiceS.opts DCOPPT string "1"
hspiceS.opts MAXORD string "default ( 2 )"
hspiceS.opts DEFPS string "0"
hspiceS.opts MEASOUT string "on"
hspiceS.opts FAST string "off"
hspiceS.opts CPTIME string "1e+7"
hspiceS.opts IMAX string "8"
hspiceS.opts DEFNRD string "0"
hspiceS.opts OPTLST string "default ( 0 )"
hspiceS.opts ABSVDC string "5e-5"
hspiceS.opts INTERP string "0"
hspiceS.opts DCCAP string "off"
hspiceS.opts DEFAD string "0"
hspiceS.opts SCALM string "1"
hspiceS.opts TNOM string "25"
hspiceS.opts DOIRSCAL string "0"
hspiceS.opts KLIM string "1e-2"
hspiceS.opts AUTOST string "off"
hspiceS.opts H9007 string "off"
hspiceS.opts UNWRAP string "off"
hspiceS.opts CVTOL string ".2"
hspiceS.opts PLIM string "default ( 1 )"
hspiceS.opts K2LIM string "0"
hspiceS.opts MBYPAS string "1"
hspiceS.opts MEASDGT string "default ( 4 )"
hspiceS.opts DEFPD string "0"
hspiceS.opts MU string ".5"
hspiceS.opts NOTOP string "off"
hspiceS.opts SCALE string "1"
hspiceS.opts CSHUNT string "0"
hspiceS.opts EPSMIN string "1e-28"
hspiceS.opts SDA string "default ( 0 )"
hspiceS.opts ABSI string "1e-9"
hspiceS.opts NOELCK string "off"
hspiceS.opts PIVOT string "default ( 10 )"
hspiceS.opts ABSH string "0"
;hspiceS outputs partition variables
hspiceS.outputs allAnalogNV boolean t
;hspiceS envOpts partition variables
hspiceS.envOpts updateFile string ""
hspiceS.envOpts stimulusFile string ""
hspiceS.envOpts instViewListTable string ""
hspiceS.envOpts doInstBased boolean nil
hspiceS.envOpts stopViewList string "hspiceS spice"
hspiceS.envOpts reNetlist boolean nil
hspiceS.envOpts includeSyntax string "cdsSpice"
hspiceS.envOpts initFile string ""
hspiceS.envOpts printComments boolean nil
hspiceS.envOpts netlistType string "hierarchical"
hspiceS.envOpts generateMapFile boolean nil
hspiceS.envOpts includeFile string ""
hspiceS.envOpts instStopListTable string ""
hspiceS.envOpts switchViewList string "hspiceS spice cmos_sch cmos.sch schematic"
;hspiceS init partition variables
hspiceS.init processPriority int 0
;hspiceS dc partition variables
hspiceS.dc enable toggle (nil)
hspiceS.dc from string ""
hspiceS.dc to string ""
hspiceS.dc by string ""
hspiceS.dc device string ""
;hspiceS dcOpts partition variables
;hspiceS noise partition variables
hspiceS.noise enable toggle (nil)
hspiceS.noise source string ""
hspiceS.noise output string ""
hspiceS.noise listEvery string "1"
;hspiceS noiseOpts partition variables
;hspiceS ac partition variables
hspiceS.ac enable toggle (nil)
hspiceS.ac from string ""
hspiceS.ac to string ""
hspiceS.ac incrType string "Logarithmic"
hspiceS.ac lin string ""
hspiceS.ac log string ""
;hspiceS acOpts partition variables
;hspiceS tran partition variables
hspiceS.tran enable toggle (nil)
hspiceS.tran from string ""
hspiceS.tran to string ""
hspiceS.tran by string ""
hspiceS.tran delmax string ""
;hspiceS tranOpts partition variables
;hspiceSVerilog environment variables
;hspiceSVerilog opts partition variables
hspiceSVerilog.opts GENK string "1"
hspiceSVerilog.opts PARHIER string "GLOBAL"
hspiceSVerilog.opts RELQ string "1e-2"
hspiceSVerilog.opts LVLTIM string "default ( 1 )"
hspiceSVerilog.opts ARTIST string "artistdefault ( 2 )"
hspiceSVerilog.opts BKPSZE string "5000"
hspiceSVerilog.opts NEWTOL string "off"
hspiceSVerilog.opts ABSMOS string "1e-6"
hspiceSVerilog.opts RMAXDC string "1e+2"
hspiceSVerilog.opts DIAGNOSTIC string "off"
hspiceSVerilog.opts VFLOOR string "0"
hspiceSVerilog.opts FS string "25e-2"
hspiceSVerilog.opts CO string "78"
hspiceSVerilog.opts DEFAS string "0"
hspiceSVerilog.opts RESMIN string "1e-5"
hspiceSVerilog.opts UIC string "off"
hspiceSVerilog.opts PSF string "artistdefault ( 2 )"
hspiceSVerilog.opts WARNLIMIT string "1"
hspiceSVerilog.opts ICSWEEP string "default ( 1 )"
hspiceSVerilog.opts BRIEF string "off"
hspiceSVerilog.opts DCFOR string "0"
hspiceSVerilog.opts GMIN string "1e-12"
hspiceSVerilog.opts DCHOLD string "1"
hspiceSVerilog.opts INGOLD string "artistdefault ( 2 )"
hspiceSVerilog.opts DCSTEP string "0"
hspiceSVerilog.opts NODE string "off"
hspiceSVerilog.opts TRTOL string "7"
hspiceSVerilog.opts LIMTIM string "2.0"
hspiceSVerilog.opts EXPMAX string "8e+1"
hspiceSVerilog.opts DVDT string "default ( 3 )"
hspiceSVerilog.opts NOWARN string "off"
hspiceSVerilog.opts ITL5 string "0"
hspiceSVerilog.opts NUMDGT string "default ( 4 )"
hspiceSVerilog.opts BADCHR string "off"
hspiceSVerilog.opts PIVTOL string "1e-15"
hspiceSVerilog.opts LIMPTS string "2001"
hspiceSVerilog.opts METHOD string "TRAP"
hspiceSVerilog.opts CHGTOL string "1e-15"
hspiceSVerilog.opts GSHUNT string "0"
hspiceSVerilog.opts DVTR string "1e+3"
hspiceSVerilog.opts DI string "1e+2"
hspiceSVerilog.opts CSHDC string "1e-12"
hspiceSVerilog.opts RELI string "1e-2"
hspiceSVerilog.opts PATHNUM string "off"
hspiceSVerilog.opts DEFW string "1e-4"
hspiceSVerilog.opts DCON string "default ( 0 )"
hspiceSVerilog.opts DEFL string "1e-4"
hspiceSVerilog.opts DEFNRS string "0"
hspiceSVerilog.opts TIMRES string "1E-12"
hspiceSVerilog.opts CONVERGE string "default ( 1 )"
hspiceSVerilog.opts ABSV string "5e-5"
hspiceSVerilog.opts LENNAM string "8"
hspiceSVerilog.opts NOPIV string "off"
hspiceSVerilog.opts DCAP string "default ( 2 )"
hspiceSVerilog.opts GMINDC string "1e-12"
hspiceSVerilog.opts RELV string "1e-3"
hspiceSVerilog.opts GRAMP string "0"
hspiceSVerilog.opts ASPEC string "off"
hspiceSVerilog.opts DV string "1e+3"
hspiceSVerilog.opts RMIN string "1e-9"
hspiceSVerilog.opts RELVDC string "1e-3"
hspiceSVerilog.opts ACCT string "default ( 1 )"
hspiceSVerilog.opts SPMESS string "default ( 1 )"
hspiceSVerilog.opts RELMOS string "5e-2"
hspiceSVerilog.opts TEMPDC string "25"
hspiceSVerilog.opts CSDF string "off"
hspiceSVerilog.opts ACCURA string "off"
hspiceSVerilog.opts MAXAMP string "0"
hspiceSVerilog.opts NOMOD string "off"
hspiceSVerilog.opts PIVREF string "1e8"
hspiceSVerilog.opts NOPAGE string "off"
hspiceSVerilog.opts CAPTAB string "off"
hspiceSVerilog.opts ITL1 string "2e+2"
hspiceSVerilog.opts ITL2 string "5e+1"
hspiceSVerilog.opts POST string "default ( 0 )"
hspiceSVerilog.opts PIVREL string "1e-4"
hspiceSVerilog.opts ABSVAR string ".5"
hspiceSVerilog.opts ITRPRT string "off"
hspiceSVerilog.opts SPICE string "off"
hspiceSVerilog.opts GMAX string "1e+2"
hspiceSVerilog.opts RMAX string "2"
hspiceSVerilog.opts BYPASS string "default ( 0 )"
hspiceSVerilog.opts OFF string "0"
hspiceSVerilog.opts IMIN string "3"
hspiceSVerilog.opts KCLTEST string "off"
hspiceSVerilog.opts OPTS string "off"
hspiceSVerilog.opts ACOUT string "default ( 1 )"
hspiceSVerilog.opts RELH string "5e-2"
hspiceSVerilog.opts FT string "25e-2"
hspiceSVerilog.opts LIST string "on"
hspiceSVerilog.opts WL string "default ( 0 )"
hspiceSVerilog.opts RELVAR string ".30"
hspiceSVerilog.opts MAXORD string "default ( 2 )"
hspiceSVerilog.opts DCOPPT string "1"
hspiceSVerilog.opts MEASOUT string "on"
hspiceSVerilog.opts DEFPS string "0"
hspiceSVerilog.opts FAST string "off"
hspiceSVerilog.opts IMAX string "8"
hspiceSVerilog.opts CPTIME string "1e+7"
hspiceSVerilog.opts DEFNRD string "0"
hspiceSVerilog.opts OPTLST string "default ( 0 )"
hspiceSVerilog.opts INTERP string "0"
hspiceSVerilog.opts ABSVDC string "5e-5"
hspiceSVerilog.opts DEFAD string "0"
hspiceSVerilog.opts DCCAP string "off"
hspiceSVerilog.opts SCALM string "1"
hspiceSVerilog.opts DOIRSCAL string "0"
hspiceSVerilog.opts TNOM string "25"
hspiceSVerilog.opts KLIM string "1e-2"
hspiceSVerilog.opts H9007 string "off"
hspiceSVerilog.opts AUTOST string "off"
hspiceSVerilog.opts CVTOL string ".2"
hspiceSVerilog.opts UNWRAP string "off"
hspiceSVerilog.opts K2LIM string "0"
hspiceSVerilog.opts PLIM string "default ( 1 )"
hspiceSVerilog.opts MEASDGT string "default ( 4 )"
hspiceSVerilog.opts MBYPAS string "1"
hspiceSVerilog.opts NOTOP string "off"
hspiceSVerilog.opts MU string ".5"
hspiceSVerilog.opts DEFPD string "0"
hspiceSVerilog.opts EPSMIN string "1e-28"
hspiceSVerilog.opts CSHUNT string "0"
hspiceSVerilog.opts SCALE string "1"
hspiceSVerilog.opts NOELCK string "off"
hspiceSVerilog.opts ABSI string "1e-9"
hspiceSVerilog.opts SDA string "default ( 0 )"
hspiceSVerilog.opts PIVOT string "default ( 10 )"
hspiceSVerilog.opts ABSH string "0"
;hspiceSVerilog outputs partition variables
hspiceSVerilog.outputs allDigitalNV boolean t
hspiceSVerilog.outputs allAnalogNV boolean t
;hspiceSVerilog verimixOpts partition variables
hspiceSVerilog.verimixOpts filename6 string ""
hspiceSVerilog.verimixOpts maxDCIter int 0
hspiceSVerilog.verimixOpts scope1 string ""
hspiceSVerilog.verimixOpts scope10 string ""
hspiceSVerilog.verimixOpts filename8 string ""
hspiceSVerilog.verimixOpts dcInterval float 0.0
hspiceSVerilog.verimixOpts scope3 string ""
hspiceSVerilog.verimixOpts scope8 string ""
hspiceSVerilog.verimixOpts scope7 string ""
hspiceSVerilog.verimixOpts filename7 string ""
hspiceSVerilog.verimixOpts scope string ""
hspiceSVerilog.verimixOpts filename4 string ""
hspiceSVerilog.verimixOpts filename string ""
hspiceSVerilog.verimixOpts filename1 string ""
hspiceSVerilog.verimixOpts scope9 string ""
hspiceSVerilog.verimixOpts importsdfswitch boolean nil
hspiceSVerilog.verimixOpts filename2 string ""
hspiceSVerilog.verimixOpts numberofsdffiles int 2
hspiceSVerilog.verimixOpts scope2 string ""
hspiceSVerilog.verimixOpts scope6 string ""
hspiceSVerilog.verimixOpts filename10 string ""
hspiceSVerilog.verimixOpts delaymodechoice string "Ignore"
hspiceSVerilog.verimixOpts sdfmixedswitch boolean t
hspiceSVerilog.verimixOpts filename9 string ""
hspiceSVerilog.verimixOpts scope5 string ""
hspiceSVerilog.verimixOpts filename5 string ""
hspiceSVerilog.verimixOpts filename3 string ""
hspiceSVerilog.verimixOpts scope4 string ""
;hspiceSVerilog verilogOpts partition variables
hspiceSVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
hspiceSVerilog.verilogOpts optionsFile string ""
hspiceSVerilog.verilogOpts twinTurbo boolean nil
hspiceSVerilog.verilogOpts suppressMessages boolean nil
hspiceSVerilog.verilogOpts libraryFile string ""
hspiceSVerilog.verilogOpts behaveProfile boolean nil
hspiceSVerilog.verilogOpts verimixLog string "verilog.log"
hspiceSVerilog.verilogOpts simVision boolean nil
hspiceSVerilog.verilogOpts pulseSpec boolean nil
hspiceSVerilog.verilogOpts commandFile string ""
hspiceSVerilog.verilogOpts pulseError int 100
hspiceSVerilog.verilogOpts stopCompile boolean nil
hspiceSVerilog.verilogOpts keepNodes string "Minimum"
hspiceSVerilog.verilogOpts accelerationCA boolean nil
hspiceSVerilog.verilogOpts turboRadio string "Default"
hspiceSVerilog.verilogOpts libraryDir string ""
hspiceSVerilog.verilogOpts suppressWarnings boolean nil
hspiceSVerilog.verilogOpts accelerationSwitches boolean nil
hspiceSVerilog.verilogOpts accelerationNormal boolean t
hspiceSVerilog.verilogOpts delayType string "Typical"
hspiceSVerilog.verilogOpts pulseReject int 100
hspiceSVerilog.verilogOpts delayMode string "Default"
hspiceSVerilog.verilogOpts vermixBinary string "verilog.vmx"
;hspiceSVerilog init partition variables
hspiceSVerilog.init processPriority int 0
;hspiceSVerilog envOpts partition variables
hspiceSVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
hspiceSVerilog.envOpts mspNetlistMode string "Flat"
hspiceSVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
hspiceSVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
hspiceSVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
hspiceSVerilog.envOpts mspSetupNetlistEscapeName boolean nil
hspiceSVerilog.envOpts updateFile string ""
hspiceSVerilog.envOpts stimulusFile string ""
hspiceSVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
hspiceSVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
hspiceSVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
hspiceSVerilog.envOpts reNetlist boolean nil
hspiceSVerilog.envOpts includeSyntax string "cdsSpice"
hspiceSVerilog.envOpts mspSetupNetlistPinMap boolean nil
hspiceSVerilog.envOpts mspSetupNetlistBus boolean t
hspiceSVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
hspiceSVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
hspiceSVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
hspiceSVerilog.envOpts mspSetupNetlistExplicit boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
hspiceSVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
hspiceSVerilog.envOpts initFile string ""
hspiceSVerilog.envOpts printComments boolean nil
hspiceSVerilog.envOpts includeFile string ""
hspiceSVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
hspiceSVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
hspiceSVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimTimeValue int 1
hspiceSVerilog.envOpts mspSetupNetlistUseLib boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
hspiceSVerilog.envOpts mspSetupNetlistNullPort boolean nil
hspiceSVerilog.envOpts mspSetupNetlistDropPortRange boolean t
hspiceSVerilog.envOpts mspSetupNetlistUpCase boolean nil
hspiceSVerilog.envOpts generateMapFile boolean nil
hspiceSVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;hspiceSVerilog dc partition variables
hspiceSVerilog.dc enable toggle (nil)
hspiceSVerilog.dc from string ""
hspiceSVerilog.dc to string ""
hspiceSVerilog.dc by string ""
hspiceSVerilog.dc device string ""
;hspiceSVerilog dcOpts partition variables
;hspiceSVerilog noise partition variables
hspiceSVerilog.noise enable toggle (nil)
hspiceSVerilog.noise source string ""
hspiceSVerilog.noise output string ""
hspiceSVerilog.noise listEvery string "1"
;hspiceSVerilog noiseOpts partition variables
;hspiceSVerilog ac partition variables
hspiceSVerilog.ac enable toggle (nil)
hspiceSVerilog.ac from string ""
hspiceSVerilog.ac to string ""
hspiceSVerilog.ac incrType string "Logarithmic"
hspiceSVerilog.ac lin string ""
hspiceSVerilog.ac log string ""
;hspiceSVerilog acOpts partition variables
;hspiceSVerilog tran partition variables
hspiceSVerilog.tran enable toggle (nil)
hspiceSVerilog.tran from string ""
hspiceSVerilog.tran to string ""
hspiceSVerilog.tran by string ""
hspiceSVerilog.tran delmax string ""
;hspiceSVerilog tranOpts partition variables
; Copyright (C) 1997
; Cadence Design Systems Inc. All Rights Reserved.
; $Author: cvsadm $
; $Revision: 1.3.4.1 $
; $Date: 2004/06/16 16:42:51 $
; $State: Exp $
iccTranslator enableProbing boolean t
iccTranslator enableComponentUpdate boolean t
iccTranslator enableAutoImport boolean t
iccTranslator exportCommand string "cdba2icc"
iccTranslator importCommand string "icc2cdba"
iccTranslator iccCommand string "ic_craft"
iccTranslator iccDirectory string ""
iccTranslator exportDirectory string ""
iccTranslator rulesDirectory string ""
iccTranslator logOpPointLimit int 0
iccTranslator oversizePins boolean t
iccTranslator singleImageClusters boolean nil
iccTranslator exportVersion int 11
iccTranslator iccMajorSubVersion int 1
iccTranslator iccMinorSubVersion int 33
iccTranslator permutablePins boolean t
iccTranslator caseSensitive boolean t
iccTranslator schematicStrict boolean nil
iccTranslator keepViaImageOrigin boolean nil
iccTranslator exportTo string "VCR"
iccTranslator pinByPinModelEvaluate boolean nil
iccTranslator alwaysPinModelEvaluate boolean nil
iccTranslator autoTrimPins boolean t
iccTranslator makeVariantViasSpare boolean nil
iccTranslator hierIncrementUpdate boolean nil
iccTranslator MPPAsPolygons boolean nil
iccTranslator noIoPorts boolean nil
iccTranslator findKeepoutWidth boolean nil
iccTranslator.ExportEditor layoutLibrary string ""
iccTranslator.ExportEditor layoutCell string ""
iccTranslator.ExportEditor layoutView string ""
iccTranslator.ExportEditor layoutArea string ""
iccTranslator.ExportEditor netlistSource string "layoutCellview"
iccTranslator.ExportEditor netlistLibrary string ""
iccTranslator.ExportEditor netlistCell string ""
iccTranslator.ExportEditor netlistView string ""
iccTranslator.ExportEditor netlistFile string ""
iccTranslator.ExportEditor useAlternateViews boolean nil
iccTranslator.ExportEditor alternateViews string ""
iccTranslator.ExportEditor conductorDepth int 32
iccTranslator.ExportEditor keepoutDepth int 32
iccTranslator.ExportEditor pinConnection string "strong"
iccTranslator.ExportEditor useMarker boolean nil
iccTranslator.ExportEditor exportMode string "foreground"
iccTranslator.ExportEditor fullConnectivity boolean t
iccTranslator.ExportEditor cutToEdge boolean nil
iccTranslator.ExportEditor interLayer boolean t
iccTranslator.ExportEditor incrementalUpdate boolean t
iccTranslator.ExportEditor useRulesFile boolean nil
iccTranslator.ExportEditor rulesFile string ""
iccTranslator.ExportEditor routerOption string "vcr"
iccTranslator.ExportEditor startICC boolean t
iccTranslator.ExportEditor iccOptions string ""
iccTranslator.ImportEditor importFile string ""
iccTranslator.ImportEditor importFileType string "session"
iccTranslator.ImportEditor importLibrary string ""
iccTranslator.ImportEditor importCell string ""
iccTranslator.ImportEditor importView string ""
iccTranslator.ImportEditor boundary boolean t
iccTranslator.ImportEditor placement boolean t
iccTranslator.ImportEditor routes boolean t
iccTranslator.ImportEditor importMode string "foreground"
iccTranslator.ImportEditor segmentedPath boolean nil
iccTranslator.ImportEditor usePinPurpose boolean nil
ihdl ihdlLoadFileName string "~/.ihdlEnvFile";Load file name
ihdl pin_master_basic_lib boolean t
ihdl pin_master_cells string "ipin opin iopin"
;1************************************************************************
;2* Layout Environment Variables
;3* There are three categories in this file. Public env, wire editor env
;4* and private env. Privat envs should never be touched by customers.
;5************************************************************************
;* The following layout editor environment variables are for customer
;* use. Refer to the documentation for complete information.
layout abutServerOn boolean t
layout accessEdgesOn boolean nil
layout acuteAnglePath boolean t
layout alignApplySeparation boolean t
layout alignApplySpacings string "Component Space"
layout alignDirection string "vertical"
layout alignLayer string ""
layout alignMethod string "Component Origin"
layout alignSelectionMode string "preselect"
layout alignSeparation float 1.0
layout applyBounce boolean nil
layout arrayDisplay string "Full"
layout autoContact boolean nil
layout autoExtractEnabled boolean t
layout autoInstPin boolean nil
layout autoNetName boolean t
layout autoPermutePins boolean t
layout autoRefresh boolean nil
layout autoSetRefPoint boolean t
layout chopShape cyclic "rectangle"
layout confirmDelete boolean nil
layout contactColumns int 1
layout contactDefFromTechfile boolean t
layout contactDelX float 0.0
layout contactDelY float 0.0
layout contactJustify cyclic "centerCenter"
layout contactLength float 0.8
layout contactName string ""
layout contactResetDelXY boolean t
layout contactResetXYBias boolean t
layout contactResetRowCol boolean t
layout contactRows int 1
layout contactWidth float 0.8
layout copyColumns int 1
layout copyResetRowCol boolean nil
layout copyRows int 1
layout copyToLayer boolean nil
layout createPinLabel boolean nil
layout cursorShape boolean nil
layout deleteTarget cyclic "selected"
layout descendPromptForView boolean nil
layout devClass string ""
layout devType string ""
layout displayPinNames boolean nil
layout displayRefPoint boolean nil
layout displayStartLevel int 0
layout displayStopLevel int 0
layout displayStretchHandles boolean nil
layout dotsOn boolean nil
layout drawAxesOn boolean t
layout drawDottedGridOn boolean t
layout drawGridOn boolean t
layout drawInstancePins boolean nil
layout drawSurroundingOn boolean t
layout drdEditMode cyclic "off"
layout drdEditHierDepth int 0
layout drdEditDisplayMarkers boolean nil
layout drdEditDisplayHalo boolean nil
layout drdEditDisplayText boolean t
layout drdEditDisplayArrows boolean t
layout drdEditDisplayEdges boolean nil
layout dynamicHilightOn boolean t
layout extractCheckAll boolean nil
layout extractEnabled boolean t
layout extractStopLevel int 0
layout filterSize float 6.0
layout filterSizeDrawingStyle string "empty"
layout fixedWidthPaths boolean nil
layout flattenMode cyclic "one level"
layout flattenPCells boolean nil
layout gravityAperture float 0.3
layout gravityBounceX float 0.0
layout gravityBounceY float 0.0
layout gravityDepth int 0
layout gravityOn boolean nil
layout gravityType string "pin edge midpoint nexus vertex end centerline"
layout gridMultiple int 5
layout gridSpacing float 1.0
layout iconsOn boolean nil
layout ignoreBounce boolean nil
layout instCellName string ""
layout instColumns int 1
layout instDelX float 0.0
layout instDelY float 0.0
layout instLabel string "master"
layout instLibName string ""
layout instName string ""
layout instRows int 1
layout instViewName string "layout"
layout keepFirstTermName boolean nil
layout keepRuler boolean t
layout labelAttach boolean nil
layout labelDrafting boolean t
layout labelFontStyle cyclic "stick"
layout labelHeight float 1.0
layout labelJustify cyclic "centerCenter"
layout labelOverbar boolean nil
layout layerTapCycle boolean nil
layout leDispNetExpr boolean t
layout leWindowBBox string "((120 185) (1020 875))"
layout lockAngles boolean t
layout magnification float 1.0
layout maintainConnections boolean nil
layout markerZoomScale int 1
layout maxDragFig int 500
layout modCornerRadius float 1.0
layout modCornerType cyclic "radial"
layout modalCommands boolean t
layout moveToLayer boolean nil
layout mppASCIIFileName string ""
layout mppTemplate string "New"
layout multiSegRuler boolean nil
layout nPtsToTaper int 20
layout allowLockedRoutes boolean nil
layout netsOn boolean nil
layout numLevels int 32
layout numSides int 20
layout openToStopLevel boolean t
layout orientation cyclic "R0"
layout resetOrientation boolean t
layout originMarkersOn boolean nil
layout partialSelect boolean nil
layout pathBeginExt float 0.0
layout pathCL cyclic "yes"
layout pathEndExt float 0.0
layout pathJustify cyclic "center"
layout pathOffset float 0.0
layout pathStyle cyclic "truncateExtend"
layout pathWidth float 0.6
layout pinAccessDir string "left right top bottom"
layout pinLength float 0.6
layout pinSelectionMode cyclic "ignoreLPP"
layout pinShape cyclic "rectangle"
layout pinTextLayer string "text"
layout pinTextPurpose string "drawing"
layout pinTextSameLayer boolean nil
layout pinType string ""
layout pinWidth float 0.6
layout pinXPitch float 0.0
layout pinYPitch float 0.0
layout pinsAreSymbolic boolean t
layout pinLayerPurpose string ""
layout polygonArc boolean nil
layout preservePins boolean nil
layout preserveRodObjects boolean nil
layout preserveTerminalContacts boolean nil
layout propClass cyclic "attributes"
layout recursionCheck boolean t
layout removeChopShape boolean t
layout replaceFigs boolean t
layout reshapeType cyclic "rectangle"
layout rodAutoName string ""
layout segSnapMode string "orthogonal"
layout selectOnlyInstWithSelectableShapes boolean nil
layout selectionAperture int 5
layout showLPPFullName boolean nil
layout showWhatsNew string "yes"
layout snapMode string "orthogonal"
layout snapToGrid boolean nil
layout startLevel int 0
layout stopLevel int 0
layout stretchPCellApplyToName boolean t
layout taperStyle cyclic "linear"
layout termDirection cyclic "inputOutput"
layout termName string ""
layout textJustificationOn boolean t
layout tinyInstDetail boolean nil
layout trlBendFac float 1.0
layout trlBendStyle cyclic "bend"
layout trlChamFac float 0.6
layout trlNPtsToPI int 20
layout trlRadFac float 3.0
layout trlWidth1 float 20.0
layout trlWidth2 float 20.0
layout updatePCellIncrement float -1.0
layout useDefaultVia boolean t
layout useEditorBackgroundColorForLSW boolean t
layout useTrueBBox boolean nil
layout userVia string ""
layout xSnapSpacing float 0.1
layout ySnapSpacing float 0.1
layout yankShape cyclic "rectangle"
layout zoomToFig boolean nil
layout cdsViaXcutSpacing float 0.0
layout cdsViaYcutSpacing float 0.0
layout cdsViaLayer1XEnclosure float 0.0
layout cdsViaLayer1YEnclosure float 0.0
layout cdsViaLayer2XEnclosure float 0.0
layout cdsViaLayer2YEnclosure float 0.0
layout cdsViaLayer1XDirEnclosure float 0.0
layout cdsViaLayer1YDirEnclosure float 0.0
layout cdsViaLayer2XDirEnclosure float 0.0
layout cdsViaLayer2YDirEnclosure float 0.0
layout cdsViaLayer1Direction string ""
layout cdsViaLayer2Direction string ""
layout cdsViaStackedVias boolean nil
layout cdsViaResetXYCutSpacing boolean t
layout cdsViaResetLayer1XYEnclosure boolean t
layout cdsViaResetLayer2XYEnclosure boolean t
layout cdsViaResetLayer1XYDirEnclosure boolean t
layout cdsViaResetLayer2XYDirEnclosure boolean t
layout cdsViaResetLayerDirection boolean t
layout cdsViaResetOrigin boolean t
layout displayViaShapes boolean nil
layout tapType string "layer"
layout remasterInstCheckTerms boolean nil
layout remasterInstSearchLibText string ""
layout remasterInstSearchCellText string ""
layout remasterInstSearchViewText string ""
layout remasterInstUpdateLibText string ""
layout remasterInstUpdateCellText string ""
layout remasterInstUpdateViewText string ""
layout chainMode cyclic "selected"
layout anchor cyclic "left"
layout shortEnhContactForm boolean nil
layout markNetRange cyclic "Top to bottom"
layout markNetStartLevel int 0
layout markNetStopLevel int 0
layout markNetAutoColorCycle boolean t
layout markNetDumpNetObj boolean nil
layout measurementDisplayOn boolean nil
layout measurementTextHeight int 10
layout measurementDisplayTypes string "deltaXY distance radius area length"
;* The following layout editor environment variables are for customer use
;* with the wire editor functionality in Virtuoso XL Layout Editor only.
;* Refer to the documentation for complete information.
layout allowFloatingNets boolean nil
layout allowJogs boolean t
layout allowRedundantWiring boolean t
layout autoAdjustLength boolean nil
layout autoShield boolean nil
layout busOverride cyclic "ignore"
layout busOverrideValue float 1.0
layout busWireSpacing float 0.0
layout busWireSpacingType cyclic "wirewire"
layout checkConflict boolean t
layout checkCornerCorner boolean nil
layout checkCrossTalk boolean t
layout checkLength boolean t
layout checkLimitWay boolean nil
layout checkMaxProcessWireWidth boolean nil
layout checkMaxStackViaDepth boolean nil
layout checkMaxTotalVia boolean nil
layout checkMinMaskEdgeLength boolean nil
layout checkMinProcessWireWidth boolean t
layout checkMiter boolean nil
layout checkNetOrder boolean nil
layout checkOffManGridPin boolean nil
layout checkOffWireGridPin boolean nil
layout checkPinSpacing boolean t
layout checkPolygonWire boolean t
layout checkProtected boolean nil
layout checkReentrantPath boolean t
layout checkRegion boolean t
layout checkSameNet boolean nil
layout checkSegment boolean nil
layout checkStub boolean nil
layout checkUseLayers boolean nil
layout checkUseVias boolean nil
layout checkWireExtension boolean nil
layout doFile string ""
layout enableBusRouting boolean t
layout enableTandemPair boolean nil
layout fitViaPattern boolean nil
layout gatherBusWires boolean nil
layout inaccessiblePin boolean t
layout interactiveChecking boolean t
layout matchPinWidth boolean nil
layout matchPinWidthValue cyclic "narrow"
layout matchWireWidth boolean nil
layout multiplePinsConnection boolean t
layout pinLargerMaxProcessWidth boolean nil
layout pinSmallerMinProcessWidth boolean t
layout pushComponent boolean nil
layout pushRouting boolean t
layout routeAsManyAsPossible boolean nil
layout routeToCursor boolean nil
layout routeToCursorStyle cyclic "singleLayer"
layout sameNetChecking boolean nil
layout showTimingMeter boolean nil
layout showTimingOctagon boolean nil
layout snapToPinOrigin boolean nil
layout useDoFile boolean nil
layout viaAssistance cyclic "snap"
layout viaPattern cyclic "diag_1"
layout allowViaOnCurrentLayer boolean t
;* The following layout editor environment variables are for internal Cadence
;* use only. Changing the values of these variables my cause the layout editor
;* or other Cadence software to behave improperly or quit.
layout abutPerpSnapOn boolean t
layout coalesceLimit int 16
layout coalesceRatio int 50
layout connStatus cyclic "needToConnect"
layout contactInstLibName string ""
layout criticality int 10
layout eipRedraw boolean nil
layout figOrder cyclic "current"
layout iterNum int 0
layout jumpersOn boolean nil
layout minLabelSize float 1.0
layout minRefreshArea int 10
layout minStippleSize float 1.0
layout moreDialogs boolean t
layout netName string ""
layout outlineOnly boolean t
layout pickNCreate boolean nil
layout pinInstLibName string ""
layout probeTextOn boolean t
layout pruneSize float 1.0
layout routeMenuOn boolean t
layout toggle boolean nil
layout transformMarkersOn boolean t
layout viewNameList string ""
;3* There are three categories in this file. Public env, LO env
;4* and private env. Private envs should never be touched by customers.
layoutMigrate priorityUserDefined int 10
layoutMigrate priorityUser int 9
layoutMigrate priorityAreaHole int 8
layoutMigrate priorityScale int 7
layoutMigrate prioritySpace int 6
layoutMigrate priorityEnclose int 5
layoutMigrate priorityExtend int 4
layoutMigrate priorityWidth int 3
layoutMigrate priorityNoJog int 2
layoutMigrate priorityAlign int 1
layoutMigrate addToSelection boolean t
layoutMigrate visibleLayer boolean t
layoutMigrate selectableLayer boolean nil
layoutMigrate exclusiveLayer boolean nil
layoutMigrate exclusiveArea boolean nil
layoutMigrate migrateLibraries boolean nil
layoutMigrate mapPcellParams boolean nil
layoutMigrate useSchematicLinks boolean nil
layoutMigrate debugMode boolean t
layoutMigrate doPreProcess boolean t
layoutMigrate preprocessScript string "preprocess.qts"
layoutMigrate doAstractSource boolean nil
layoutMigrate abstractSourceScript string "abstractsource.qts"
layoutMigrate doAbstractTarget boolean nil
layoutMigrate abstractTargetScript string "abstracttarget.qts"
layoutMigrate doPremigrate boolean nil
layoutMigrate premigrateScript string "premigrate.qts"
layoutMigrate doNetlistBinding boolean nil
layoutMigrate netlistFile string "netlist.cdl"
layoutMigrate useConstraintScript boolean nil
layoutMigrate constraintScript string "constraints.qts"
layoutMigrate doPostprocess boolean t
layoutMigrate postprocessScript string "postprocess.qts"
layoutMigrate lastScript string ""
layoutMigrate optimizeX boolean t
layoutMigrate optimizeY boolean t
layoutMigrate allowZeroEdges boolean t
layoutMigrate allow45Edges boolean t
layoutMigrate scaleDevicesWires boolean t
layoutMigrate sumDeviceLegs boolean t
layoutMigrate lockPcells boolean nil
layoutMigrate useQuickSolver boolean nil
layoutMigrate centerLabels boolean nil
layoutMigrate minimizeMemory boolean nil
layoutMigrate keepResultsOnDisk boolean t
layoutMigrate expandSingletons boolean nil
layoutMigrate optimizeEnclose boolean nil
layoutMigrate genConstraintStats boolean nil
layoutMigrate optimizeEffort int 1
layoutMigrate autoRelaxDevices boolean nil
layoutMigrate autorelaxMaxConstraints boolean nil
layoutMigrate autorelaxConstraintsByType boolean nil
layoutMigrate autoRelaxTolerance float 50.0
layoutMigrate autoJogEdges boolean nil
layoutMigrate autoJogWires boolean nil
layoutMigrate autoJogLimit int 1000
layoutMigrate autoJogThreshold float 100.0
layoutMigrate revisitOneByOne2D boolean nil
layoutMigrate revisit2DCost float 100.0
layoutMigrate revisitFlash2D boolean t
layoutMigrate manufGrid2D boolean t
layoutMigrate changeEndOfLine boolean t
layoutMigrate changeCommonRun boolean t
layoutMigrate changeCornerCorner boolean t
layoutMigrate manufGridEnable boolean t
layoutMigrate manufGridPercent float 0.1
layoutMigrate manufGridIteration int 500
layoutMigrate manufGridCPUTime int 10000
layoutMigrate manufGridNoQuickSolver boolean t
layoutMigrate ioGridEnable boolean t
layoutMigrate ioGridPercent float 1.0
layoutMigrate ioGridIteration int 500
layoutMigrate ioGridCPUTime int 10000
layoutMigrate collapseVirtuals boolean t
layoutMigrate ignoreLengthsNetlistBinding boolean nil
layoutMigrate ignoreLengthsLayoutExtraction boolean nil
layoutMigrate propagateTieoffs boolean t
layoutMigrate remoteHost string ""
layoutMigrate remoteWorkingDir string ""
layoutMigrate useRemoteHost boolean nil
layoutMigrate remoteVirtuosoDir string ""
layoutMigrate RemoteQtkDir string ""
layoutMigrate remoteExecPath string ""
layoutMigrate processPriority int 15
layoutMigrate justFixMode boolean nil
layoutOptimize priorityUserDefined int 10
layoutOptimize priorityUser int 9
layoutOptimize priorityAreaHole int 8
layoutOptimize priorityScale int 7
layoutOptimize prioritySpace int 6
layoutOptimize priorityEnclose int 5
layoutOptimize priorityExtend int 4
layoutOptimize priorityWidth int 3
layoutOptimize priorityNoJog int 2
layoutOptimize priorityAlign int 1
layoutOptimize addToSelection boolean t
layoutOptimize visibleLayer boolean t
layoutOptimize selectableLayer boolean nil
layoutOptimize exclusiveLayer boolean nil
layoutOptimize exclusiveArea boolean nil
layoutOptimize migrateLibraries boolean nil
layoutOptimize mapPcellParams boolean nil
layoutOptimize useSchematicLinks boolean nil
layoutOptimize debugMode boolean t
layoutOptimize doPreProcess boolean nil
layoutOptimize preprocessScript string "preprocess.qts"
layoutOptimize doAstractSource boolean nil
layoutOptimize abstractSourceScript string "abstractsource.qts"
layoutOptimize doAbstractTarget boolean nil
layoutOptimize abstractTargetScript string "abstracttarget.qts"
layoutOptimize doPremigrate boolean nil
layoutOptimize premigrateScript string "premigrate.qts"
layoutOptimize doNetlistBinding boolean nil
layoutOptimize netlistFile string "netlist.cdl"
layoutOptimize useConstraintScript boolean nil
layoutOptimize constraintScript string "constraints.qts"
layoutOptimize doPostprocess boolean nil
layoutOptimize postprocessScript string "postprocess.qts"
layoutOptimize lastScript string ""
layoutOptimize optimizeX boolean t
layoutOptimize optimizeY boolean t
layoutOptimize allowZeroEdges boolean t
layoutOptimize allow45Edges boolean t
layoutOptimize scaleDevicesWires boolean nil
layoutOptimize sumDeviceLegs boolean nil
layoutOptimize lockPcells boolean nil
layoutOptimize useQuickSolver boolean nil
layoutOptimize centerLabels boolean nil
layoutOptimize minimizeMemory boolean nil
layoutOptimize keepResultsOnDisk boolean nil
layoutOptimize expandSingletons boolean nil
layoutOptimize optimizeEnclose boolean nil
layoutOptimize genConstraintStats boolean nil
layoutOptimize optimizeEffort int 1
layoutOptimize autoRelaxDevices boolean nil
layoutOptimize autorelaxMaxConstraints boolean nil
layoutOptimize autorelaxConstraintsByType boolean nil
layoutOptimize autoRelaxTolerance float 50.0
layoutOptimize autoJogEdges boolean nil
layoutOptimize autoJogWires boolean nil
layoutOptimize autoJogLimit int 1000
layoutOptimize autoJogThreshold float 100.0
layoutOptimize revisitOneByOne2D boolean nil
layoutOptimize revisit2DCost float 100.0
layoutOptimize revisitFlash2D boolean t
layoutOptimize manufGrid2D boolean nil
layoutOptimize changeEndOfLine boolean t
layoutOptimize changeCommonRun boolean t
layoutOptimize changeCornerCorner boolean t
layoutOptimize manufGridEnable boolean t
layoutOptimize manufGridPercent float 0.1
layoutOptimize manufGridIteration int 500
layoutOptimize manufGridCPUTime int 500
layoutOptimize manufGridNoQuickSolver boolean t
layoutOptimize ioGridEnable boolean t
layoutOptimize ioGridPercent float 1.0
layoutOptimize ioGridIteration int 500
layoutOptimize ioGridCPUTime int 1000
layoutOptimize collapseVirtuals boolean t
layoutOptimize ignoreLengthsNetlistBinding boolean nil
layoutOptimize ignoreLengthsLayoutExtraction boolean nil
layoutOptimize propagateTieoffs boolean t
layoutOptimize remoteHost string ""
layoutOptimize remoteWorkingDir string ""
layoutOptimize useRemoteHost boolean nil
layoutOptimize remoteVirtuosoDir string ""
layoutOptimize RemoteQtkDir string ""
layoutOptimize remoteExecPath string ""
layoutOptimize processPriority int 15
layoutOptimize justFixMode boolean nil
layoutOptimize.state menuState string "Migrate"
;2* Layout XL Environment Variables
;3* Note: entries in this file must be in alphabetical order.
;4************************************************************
layoutXL autoAbutment boolean t
layoutXL autoArrange boolean t
layoutXL autoSpace boolean t
layoutXL checkTimeStamps boolean t
layoutXL ciwWindow string "((0 0) (0 0))"
layoutXL constraintAssistedMode boolean nil
layoutXL createBoundaryLabel boolean nil
layoutXL crossSelect boolean t
layoutXL ignoredParams string "lxIgnoredParams dleIgnoredParams lxStopList dleStopList lxUseCell dleUseCell maskLayoutViewName posi instancesLastChanged instNamePrefix pin# lxTimeStamp dleSchExtractPath lxPlacementStatus"
layoutXL ignoreParamsForCAS string ""
layoutXL dlrNetConstNetClass string "neutral"
layoutXL dlrNetConstNetWeight string "normal"
layoutXL dlrRoutingBoundaryOption string "auto boundary"
layoutXL flightLineEnable boolean t
layoutXL ignoreNames string "lvsIgnore ignore nlAction"
layoutXL incNetCycleHilite boolean t
layoutXL incNetHiliteLayer string "y0 drawing"
layoutXL initAspectRatio float 1.0
layoutXL initAspectRatioOption string "Aspect Ratio W/H"
layoutXL initBoundaryLayer string "prBoundary drawing"
layoutXL initEstimateArea boolean t
layoutXL initIOLabelType string "Label"
layoutXL initIOPinLayer string ""
layoutXL initIOPinName string ""
layoutXL initPinHeight float 0.0
layoutXL initPinWidth float 0.0
layoutXL initPinMultiplicity int 1
layoutXL initPrBoundaryH float 0.0
layoutXL initPrBoundaryW float 0.0
layoutXL initSymbolicPins boolean nil
layoutXL initUtilization float 25.0
layoutXL initGlobalNetPins boolean t
layoutXL initCreatePins boolean t
layoutXL initCreateInstances boolean t
layoutXL initCreateBoundary boolean t
layoutXL initDoStacking boolean nil
layoutXL initDoFolding boolean nil
layoutXL layoutWindow string "((0 0) (0 0))"
layoutXL lswWindow string "((0 0) (0 0))"
layoutXL lxAllowPseudoParallelNets boolean nil
layoutXL lxDeltaWidth float 0.0
layoutXL lxDoNotCheck boolean nil
layoutXL lxLocalAbutment boolean nil
layoutXL lxSchExtractTopLevelOnly boolean nil
layoutXL lxStackPartitionParameters string "(1 8)"
layoutXL lxWidthTolerance string "(0.0 0.0)"
layoutXL mfactorNames string "m M"
layoutXL mfactorSplit boolean t
layoutXL moveAsGroup boolean t
layoutXL orientation string "R0"
layoutXL paramTolerance float 1e-06
layoutXL pathLayerFilter string ""
layoutXL pathProbe boolean t
layoutXL pathPurposeList string "drawing net pin"
layoutXL pathSwitchLayer boolean t
layoutXL pathSwitchPurpose boolean t
layoutXL pinTextSamePurpose boolean nil
layoutXL preserveTerminalContacts boolean nil
layoutXL probeCycleHilite boolean t
layoutXL probeDevice boolean t
layoutXL probeHiliteLayer string "hilite drawing"
layoutXL probeNet boolean t
layoutXL probePin boolean t
layoutXL probeInfoInCIW boolean nil
layoutXL infoWindow boolean t
layoutXL schematicWindow string "((0 0) (0 0))"
layoutXL showIncNetEnable boolean nil
layoutXL stopList string "layout compacted symbolic"
layoutXL templateFileName string ""
layoutXL updateReplacesMasters boolean t
layoutXL updateWithMarkers boolean t
layoutXL viewList string "schematic netlist symbol layout compacted symbolic"
layoutXL vxlDebugLog boolean nil
layoutXL vxlDebugLogFileName string "/tmp/vxl.log"
layoutXL initCreateMTM boolean nil
layoutXL sfactorNames string "s S"
layoutXL sfactorParam string "r R c C l L"
layoutXL mfactorSplitParamNames string "w"
layoutXL setPPConn boolean t
layoutXL lxSupplyNetNames string "vcc vcc! vcc: vdd vdd! vdd:"
layoutXL lxGroundNetNames string "gnd gnd! gnd: vss vss! vss:"
layoutXL lxGenerationOrientation string "preserve"
layoutXL lxGenerationTopLevelOnly boolean nil
layoutXL lxInitResetSource boolean nil
layoutXL compTypeRefLibs string "NONE"
layoutXL traverseMixedHierarchies boolean nil
layoutXL lxEvalCDFCallbacks boolean nil
layoutXL cloningDoExactMatch boolean nil
layoutXL.placement allowRotation boolean t
layoutXL.placement globalPlacement boolean t
layoutXL.placement openWindow boolean nil
layoutXL.placement optimizePlacement boolean nil
layoutXL.placement rulesFile string ""
layoutXL.placement runTime cyclic "moderate"
layoutXL.placement saveAs boolean nil
layoutXL.placement saveAsCellName string ""
layoutXL.placement saveAsLibName string ""
layoutXL.placement saveAsViewName string ""
layoutXL.placement vcpConductorDepth int 2
layoutXL.placement vcpKeepoutDepth int 2
layoutXL lxStackMinimalFolding boolean nil
layoutXL lxFingeringNames string "fingers finger"
layoutXL.placement rowGroundLayer string ""
layoutXL.placement rowGroundName string ""
layoutXL.placement rowGroundWidth float 1.0
layoutXL.placement rowPowerLayer string ""
layoutXL.placement rowPowerName string ""
layoutXL.placement rowPowerWidth float 1.0
layoutXL.placement rowSupplySpacing string ""
layoutXL.placement rowSupplyPosition cyclic "Outside"
layoutXL.placement rowSTDAllowFlip boolean t
layoutXL.placement rowMOSSupplyPattern cyclic "N-P-P-N"
layoutXL.placement rowSTDSupplyPattern cyclic "G-P-P-G"
layoutXL.placement congestionMapLayers string "((designFlow drawing) (designFlow drawing1) (designFlow drawing2) (designFlow drawing3) (designFlow drawing4) (designFlow drawing5) (designFlow drawing6) (designFlow drawing7) (designFlow drawing8) (designFlow drawing9))"
layoutXL.placement vcpGlobalPathScript string ""
layoutXL.placement vcpVerboseLevel int 1
layoutXL.placement vcpWriteToCIW boolean nil
;mmsimenv environment variables
;FORMAT: tool.partition varName type value private {choices, minmax} comment
;mmsimenv configuration defaults
mmsimenv.conf analogStopViewSet string "spectreS cdsSpice spice veriloga ahdl auLvs spectre"
mmsimenv.conf digitalStopViewSet string "verilog behavioral functional hdl system verilogNetlist msps"
modelwriter path string ""
modelwriter nodefault boolean nil
; Copyright (C) 2001 Cadence Design Systems, Inc. All Rights Reserved.
; $Revision: 1.1.8.1.2.1 $
;Mixed Signal Parasitic Simulation (MSPS) Environment Defaults
;Globals
msps schematicLibName string ""
msps schematicCellName string ""
msps schematicViewName string "schematic"
msps extractedLibName string ""
msps extractedCellName string ""
msps extractedViewName string "extracted"
msps switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
msps stopViewList string "cdsSpice spice"
msps instViewListTable string ""
;Parasitic Probing
msps.parProbe maxListSize int 20
msps.parProbe sortBy string "C"
;Back Annotation
msps.backAnnotate fontSize float 0.05
msps.backAnnotate xOffset float 0.01
msps.backAnnotate yOffset float 0.01
msps.backAnnotate sortBy string "C"
msps.backAnnotate parasiticFile string "parasitic_file"
;Build Analog
msps.buildAnalog setParasitics string "Include All"
msps.buildAnalog analogExtractedViewName string "analog_extracted"
; Copyright (C) 2000 Cadence Design Systems, Inc. All Rights Reserved.
; $Revision: 1.2.8.1.2.1 $
;Mixed Signal Parasitic Simulation for Assura Verification (MSPS-AV) Environment Defaults
;Globals
mspsAv schematicLibName string ""
mspsAv schematicCellName string ""
mspsAv schematicViewName string "schematic"
mspsAv extractedLibName string ""
mspsAv extractedCellName string ""
mspsAv extractedViewName string "av_extracted"
mspsAv switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
mspsAv stopViewList string "cdsSpice spice"
mspsAv instViewListTable string ""
mspsAv backAnnotateR boolean t
;Parasitic Probing
mspsAv.parProbe maxListSize int 20
mspsAv.parProbe sortBy string "C"
mspsAv.parProbe parasiticProbeFile string "parasitic_probing"
mspsAv.pwbCore schematicOpenReadOnly boolean t
mspsAv.backAnnotate fontSize float 0.05
mspsAv.backAnnotate Xoffset float 0.01
mspsAv.backAnnotate Yoffset float 0.01
mspsAv.backAnnotate sortBy string "C"
mspsAv.backAnnotate parasiticFile string "parasitic_file"
;Build Analog
mspsAv.buildAnalog setParasitics string "Include All"
mspsAv.buildAnalog analogExtractedViewName string "av_analog_extracted"
; Neocell Environment Variables
neocell ArchFile string ""
neocell MapFile string ""
neocell DefaultFile string ""
neocell UseBlockRules boolean nil
neocell BlockRulesFile string ""
neocell ExportDir string ""
neocell StartNeoCell boolean t
neocell ImportViewName string "layout"
neocell ImportTextDisplay boolean nil
neocell ImportBoundary boolean t
neocell ExportOptions string ""
neocell SymViewList string "symbolic layout"
neocell IgnoreParamTolerance boolean t
neocell VariantParamTolerance int 10
neocell VerboseWarn boolean t
neocell InitDFIIlib string ""
neocell NewDFIIlib string ""
neocell TempDir string ""
neocell TechPath string ""
neocell IgnorePinAccess boolean nil
neocell ImportPinLabelFont string "stick"
neocell ImportPinLabelSize float -1.0
neocell DisableSchExtract boolean nil
neocell TechFile string ""
neocell DisplayFile string ""
neocell pinConnection string "full"
neocell CEDefaultTab string "DevStyle"
neocell overridePinPurpose string ""
; ROD Environment Variables
rod evalILExprOn boolean t
rod minWidthCheckingOn boolean t
rod minSpacingCheckingOn boolean t
rod minEnclosureCheckingOn boolean t
rod preserveAlignInfoOn boolean t
; Composer Schematic Editor Environment Variables
; NOTE: This file should NOT be edited because it is automatically
; generated; customizations should be made to the file in
; <install_dir>/tools/dfII/samples/.cdsenv.
schematic autoDot boolean t
schematic blockDirRules cyclic "edge"
schematic broadcast boolean nil
schematic browserType string "library"
schematic checkAlways boolean nil
schematic checkBeepOn boolean t
schematic checkHierSave boolean t
schematic checkSupportAMS boolean nil
schematic checkSymTime int 1
schematic compBackTrace boolean t
schematic condOp cyclic "=="
schematic createCvOptions boolean t
schematic createInstResetCDF boolean t
schematic createInstShowCDF boolean t
schematic createLabelFontHeight float 0.0625
schematic createLabelFontStyle cyclic "stick"
schematic createLabelHorzOffset float 0.045
schematic createLabelHorzPosition cyclic "above"
schematic createLabelHorzRotation cyclic "R0"
schematic createLabelJustify cyclic "lowerCenter"
schematic createLabelOffsetMode boolean t
schematic createLabelVertOffset float 0.045
schematic createLabelVertPosition cyclic "left"
schematic createLabelVertRotation cyclic "R90"
schematic cvDisplay boolean t
schematic defWideWireWidth float 0.0625
schematic defaultsFile string ""
schematic deleteInstPinsWire boolean t
schematic descendSheet string "sheet"
schematic descendTarget string "query user"
schematic differential boolean nil
schematic dotOverlap float 0.03125
schematic drawMode string "anyAngle"
schematic drawModeRoute string "route"
schematic echoToCIW boolean t
schematic editPropCDFParamView string "Use Tools Filter"
schematic editPropShowCDF boolean t
schematic editPropShowSystem boolean nil
schematic editPropShowUser boolean t
schematic findAccessMode string "edit"
schematic findZoomButton boolean nil
schematic flightWidth float 0.0
schematic gravityOn boolean t
schematic invokeKanjiEditor string "kterm -km euc -e vi"
schematic libList string ""
schematic markerSeverity string "all"
schematic markerShowIgnore boolean t
schematic markerSource toggle (t t t t)
schematic markerType toggle (t t)
schematic markerZoom boolean nil
schematic maxLabelOffsetUU float 0.045
schematic minMarkerSize float 0.05
schematic modalCommands boolean t
schematic netExprDisplay cyclic "value only"
schematic netNameMethod cyclic "prefix"
schematic netNamePrefix string "net"
schematic netNameRangeDescend boolean nil
schematic netNameSeparator string "_"
schematic noteFontHeight float 0.0625
schematic noteFontStyle cyclic "stick"
schematic noteJustify cyclic "lowerCenter"
schematic noteShape cyclic "line"
schematic noteShapeLineStyle cyclic "solid"
schematic noteType cyclic "normalLabel"
schematic pinBackTrace boolean t
schematic pinNameSeed string "pin"
schematic pinRefDuplicates boolean nil
schematic pinRefFormat string "<sheetNumber><zone><referenceName>"
schematic pinRefSorting string "Sheet Number"
schematic replSaveChanges boolean nil
schematic runSRC boolean t
schematic runVIC boolean t
schematic saveAction cyclic "Ask Me"
schematic schCoalesceLimit int 2
schematic schDisplayDepth int 3
schematic schDrawAxesOn boolean nil
schematic schDynamicHilightOn boolean t
schematic schFilterSize float 0.3
schematic schGridMultiple int 8
schematic schGridSpacing float 0.125
schematic schGridType cyclic "dotted"
schematic schHdlCrossViewCheck boolean t
schematic schHdlCrossViewString string ""
schematic schHdlEditAfterError boolean t
schematic schHdlNetToInoutPort toggle (t t t t t t t)
schematic schHdlNetToInputPort toggle (t t t t t t t)
schematic schHdlNoHierarchy boolean nil
schematic schHdlPrintCommand string "lpr"
schematic schHdlVerbose boolean nil
schematic schMaxDragFig int 100
schematic schPathType cyclic "full"
schematic schShowDirectConnects boolean nil
schematic schShowLabelOrigin boolean nil
schematic schSnapSpacing float 0.0625
schematic schWindowBBox string "((120 185) (1020 875))"
schematic schematicAreaPartialSelect boolean nil
schematic schematicSelectFilter string "allSchObj instancePin"
schematic sensitiveMenu boolean t
schematic shapeLineType cyclic "narrow"
schematic shapeLineWidth float 0.0625
schematic simProbeAutoPlace boolean nil
schematic simProbeFormat string "<state>"
schematic simProbeType string "monitor"
schematic snapEnabled boolean t
schematic spanLib string "do not check"
schematic srcConnByName cyclic "ignored"
schematic srcFloatingBIDIR cyclic "warning"
schematic srcFloatingIO cyclic "warning"
schematic srcFloatingInput cyclic "warning"
schematic srcFloatingNets cyclic "warning"
schematic srcFloatingOutput cyclic "warning"
schematic srcInhPinNetCollision cyclic "ignored"
schematic srcInheritedConn cyclic "ignored"
schematic srcInstNameExpr string ""
schematic srcInstNameSyntax cyclic "ignored"
schematic srcInstOverlap cyclic "warning"
schematic srcInstOverlapValue int 10
schematic srcMaxLabelOffset cyclic "ignored"
schematic srcNameCollision cyclic "warning"
schematic srcNetNameExpr string ""
schematic srcNetNameSyntax cyclic "ignored"
schematic srcNoOverrideNet cyclic "warning"
schematic srcOffsheetConnCheck cyclic "ignored"
schematic srcPinNetCollision cyclic "ignored"
schematic srcShortedOutputs cyclic "warning"
schematic srcSolderOnCrossover cyclic "warning"
schematic srcSparseIndexBus cyclic "ignored"
schematic srcTermNameExpr string ""
schematic srcTermNameSyntax cyclic "ignored"
schematic srcUnconnectedWires cyclic "ignored"
schematic srcVHDLSyntax cyclic "ignored"
schematic srcVerilogSyntax cyclic "ignored"
schematic ssgPackageLabels cyclic "none"
schematic ssgSortPins cyclic "alphanumeric"
schematic statusBanner boolean t
schematic statusBannerXY boolean nil
schematic stickyWireLabelRange float 0.3125
schematic symCoalesceLimit int 2
schematic symDisplayDepth int 3
schematic symDrawAxesOn boolean nil
schematic symDynamicHilightOn boolean t
schematic symFilterSize float 0.3
schematic symGridMultiple int 8
schematic symGridSpacing float 0.125
schematic symGridType cyclic "dotted"
schematic symMaxDragFig int 100
schematic symPathType cyclic "full"
schematic symShowDirectConnects boolean nil
schematic symShowLabelOrigin boolean nil
schematic symSnapSpacing float 0.0625
schematic symWindowBBox string "((120 185) (1020 875))"
schematic symbolAreaPartialSelect boolean nil
schematic symbolLabelChoice cyclic "instance label"
schematic symbolLabelChoiceText string ""
schematic symbolLabelFontHeight float 0.0625
schematic symbolLabelFontStyle cyclic "stick"
schematic symbolLabelJustify cyclic "lowerCenter"
schematic symbolLabelType cyclic "NLPLabel"
schematic symbolPinFlatten boolean t
schematic symbolPinIncrCount int 1
schematic symbolPinLocate cyclic "left"
schematic symbolPinUsage string ""
schematic symbolSelectFilter string "allSymObj"
schematic symbolShape cyclic "line"
schematic symbolShapeFillStyle cyclic "outline"
schematic transToSheetType string "single"
schematic tsgTemplateType string "digital"
schematic updateConn boolean t
schematic updateInstResetCDF boolean t
schematic vicExactPinMatch boolean nil
schematic vicIgnoreInhTermAll boolean t
schematic vicIgnoreInhTermList string ""
schematic vicIgnoreInhTermViewList string ""
schematic vicInheritedPinMatch boolean t
schematic vicInheritedPins boolean t
schematic vicSeverity cyclic "warning"
schematic vicViewList string "symbol schematic functional behavioral system opt_sch opt_net"
schematic viewNameList string "schematic symbol"
schematic wireBackTrace boolean nil
schematic zoomOutButton boolean nil
;spectre environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spectre opts partition variables
spectre.opts multithread string ""
spectre.opts title string ""
spectre.opts audit string ""
spectre.opts nthreads string ""
spectre.opts mos_method string ""
spectre.opts ckptclock string "1800"
spectre.opts flow string ""
spectre.opts cols string "80"
spectre.opts opptcheck string ""
spectre.opts maxwarnstologfile string ""
spectre.opts reltol string "1e-3"
spectre.opts notation string ""
spectre.opts senstype string ""
spectre.opts warn string ""
spectre.opts approx string ""
spectre.opts info string ""
spectre.opts sensformat string ""
spectre.opts quantities string ""
spectre.opts pivabs string ""
spectre.opts compatible string ""
spectre.opts ignshorts string ""
spectre.opts gmin string "1e-12"
spectre.opts rforce string "1"
spectre.opts note string ""
spectre.opts homotopy string ""
spectre.opts debug string ""
spectre.opts iabstol string "1e-12"
spectre.opts maxwarns string "5"
spectre.opts tempeffects string ""
spectre.opts vabstol string "1e-6"
spectre.opts macromodels string ""
spectre.opts temp string "27"
spectre.opts tnom string "27"
spectre.opts maxnotes string "5"
spectre.opts narrate string ""
spectre.opts value string ""
spectre.opts gmin_check string ""
spectre.opts pivrel string "1e-3"
spectre.opts pivotdc string ""
spectre.opts digits string "5"
spectre.opts maxnotestologfile string ""
spectre.opts diagnose string ""
spectre.opts scale string "1.0"
spectre.opts scalem string "1.0"
spectre.opts error string ""
spectre.opts inventory string ""
spectre.opts topcheck string ""
spectre.opts limit string ""
spectre.opts sensfile string "../psf/sens.output"
;spectre outputs partition variables
spectre.outputs currents string ""
spectre.outputs outputParamInfo boolean t
spectre.outputs modelParamInfo boolean t
spectre.outputs subcktprobelvl string ""
spectre.outputs saveahdlvars string ""
spectre.outputs pwr string ""
spectre.outputs nestlvl string ""
spectre.outputs elementInfo boolean t
spectre.outputs useprobes string ""
spectre.outputs save string "allpub"
;spectre envOpts partition variables
spectre.envOpts stopViewList string "spectre"
spectre.envOpts switchViewList string "spectre cmos_sch cmos.sch schematic veriloga ahdl"
spectre.envOpts enableArclength boolean nil
spectre.envOpts autoDisplay boolean t
spectre.envOpts simOutputFormat string "psfbin"
spectre.envOpts spp string ""
spectre.envOpts analysisOrder string ""
spectre.envOpts paramRangeCheckFile string ""
spectre.envOpts printComments boolean nil
spectre.envOpts checkpoint string ""
spectre.envOpts recover string ""
spectre.envOpts firstRun boolean t
spectre.envOpts userCmdLineOption string ""
;spectre init partition variables
spectre.init processPriority int 0
;spectre pz partition variables
spectre.pz enable toggle (nil)
spectre.pz outType string "voltage"
spectre.pz p string ""
spectre.pz n string ""
spectre.pz oprobe string ""
spectre.pz inType string "voltage"
spectre.pz inVsrc string ""
spectre.pz inIsrc string ""
spectre.pz iprobe string ""
spectre.pz sweep string ""
spectre.pz freq string "1"
spectre.pz dev string ""
spectre.pz deviceParam string ""
spectre.pz mod string ""
spectre.pz modelParam string ""
spectre.pz designVar string ""
spectre.pz param string ""
spectre.pz rangeType string "Start-Stop"
spectre.pz start string ""
spectre.pz stop string ""
spectre.pz center string ""
spectre.pz span string ""
spectre.pz incrType string "Automatic"
spectre.pz stepTypeLin string "Step Size"
spectre.pz stepTypeLog string "Points Per Decade"
spectre.pz step string ""
spectre.pz lin string ""
spectre.pz dec string ""
spectre.pz log string ""
spectre.pz useDiscrete boolean nil
spectre.pz values string ""
spectre.pz porti string "1"
;spectre pzOpts partition variables
spectre.pzOpts readns string ""
spectre.pzOpts oppoint string ""
spectre.pzOpts fmax string ""
spectre.pzOpts zeroonly string ""
spectre.pzOpts prevoppoint string ""
spectre.pzOpts restart string ""
spectre.pzOpts annotate string ""
spectre.pzOpts stats string ""
;spectre dcmatch partition variables
spectre.dcmatch enable toggle (nil)
spectre.dcmatch outType string "voltage"
spectre.dcmatch p string ""
spectre.dcmatch n string ""
spectre.dcmatch oprobe string ""
spectre.dcmatch sweep string ""
spectre.dcmatch dev string ""
spectre.dcmatch deviceParam string ""
spectre.dcmatch mod string ""
spectre.dcmatch modelParam string ""
spectre.dcmatch designVar string ""
spectre.dcmatch param string ""
spectre.dcmatch rangeType string "Start-Stop"
spectre.dcmatch start string ""
spectre.dcmatch stop string ""
spectre.dcmatch center string ""
spectre.dcmatch span string ""
spectre.dcmatch incrType string "Automatic"
spectre.dcmatch stepTypeLin string "Step Size"
spectre.dcmatch stepTypeLog string "Points Per Decade"
spectre.dcmatch step string ""
spectre.dcmatch lin string ""
spectre.dcmatch dec string ""
spectre.dcmatch log string ""
spectre.dcmatch useDiscrete boolean nil
spectre.dcmatch values string ""
spectre.dcmatch mth string ""
spectre.dcmatch porti string "1"
spectre.dcmatch portv string ""
;spectre dcmatchOpts partition variables
spectre.dcmatchOpts readns string ""
spectre.dcmatchOpts save string ""
spectre.dcmatchOpts nestlvl string ""
spectre.dcmatchOpts oppoint string ""
spectre.dcmatchOpts prevoppoint string ""
spectre.dcmatchOpts restart string ""
spectre.dcmatchOpts annotate string "status"
spectre.dcmatchOpts stats string ""
spectre.dcmatchOpts where string "rawfile"
;spectre stb partition variables
spectre.stb enable toggle (nil)
spectre.stb sweep string "Frequency"
spectre.stb freq string ""
spectre.stb dev string ""
spectre.stb deviceParam string ""
spectre.stb mod string ""
spectre.stb modelParam string ""
spectre.stb designVar string ""
spectre.stb param string ""
spectre.stb rangeType string "Start-Stop"
spectre.stb start string ""
spectre.stb stop string ""
spectre.stb center string ""
spectre.stb span string ""
spectre.stb incrType string "Automatic"
spectre.stb stepTypeLin string "Step Size"
spectre.stb stepTypeLog string "Points Per Decade"
spectre.stb step string ""
spectre.stb lin string ""
spectre.stb dec string ""
spectre.stb log string ""
spectre.stb useDiscrete boolean nil
spectre.stb values string ""
spectre.stb probe string ""
;spectre stbOpts partition variables
spectre.stbOpts prevoppoint string ""
spectre.stbOpts readns string ""
spectre.stbOpts save string ""
spectre.stbOpts nestlvl string ""
spectre.stbOpts oppoint string ""
spectre.stbOpts restart string ""
spectre.stbOpts annotate string "status"
spectre.stbOpts stats string ""
;spectre tran partition variables
spectre.tran enable toggle (nil)
spectre.tran stop string ""
spectre.tran errpreset string ""
;spectre tranOpts partition variables
spectre.tranOpts start string ""
spectre.tranOpts outputstart string ""
spectre.tranOpts step string ""
spectre.tranOpts maxstep string ""
spectre.tranOpts ic string ""
spectre.tranOpts skipdc string ""
spectre.tranOpts readic string ""
spectre.tranOpts readns string ""
spectre.tranOpts cmin string ""
spectre.tranOpts write string "spectre.ic"
spectre.tranOpts writefinal string "spectre.fc"
spectre.tranOpts ckptperiod string ""
spectre.tranOpts method string ""
spectre.tranOpts relref string ""
spectre.tranOpts lteratio string ""
spectre.tranOpts stats string ""
spectre.tranOpts annotate string "status"
spectre.tranOpts save string ""
spectre.tranOpts nestlvl string ""
spectre.tranOpts oppoint string ""
spectre.tranOpts skipstart string ""
spectre.tranOpts skipstop string ""
spectre.tranOpts skipcount string ""
spectre.tranOpts strobeperiod string ""
spectre.tranOpts strobedelay string ""
spectre.tranOpts compression string ""
spectre.tranOpts infotimes string ""
spectre.tranOpts flushpoints string ""
spectre.tranOpts flushtime string ""
spectre.tranOpts flushofftime string ""
spectre.tranOpts maxiters string "5"
spectre.tranOpts restart string ""
spectre.tranOpts captab boolean nil
spectre.tranOpts timed boolean nil
spectre.tranOpts threshold string "0.0"
spectre.tranOpts detail string "node"
spectre.tranOpts sort string "name"
;spectre envlp partition variables
spectre.envlp enable toggle (nil)
spectre.envlp clockname string ""
spectre.envlp stop string ""
spectre.envlp harmonics string "Number of harmonics"
spectre.envlp harms string ""
spectre.envlp harmsvec string ""
spectre.envlp errpreset string ""
;spectre envlpOpts partition variables
spectre.envlpOpts start string ""
spectre.envlpOpts outputstart string ""
spectre.envlpOpts tstab string ""
spectre.envlpOpts modulationbw string ""
spectre.envlpOpts maxstep string ""
spectre.envlpOpts envmaxstep string ""
spectre.envlpOpts ic string ""
spectre.envlpOpts skipdc string ""
spectre.envlpOpts readic string ""
spectre.envlpOpts readns string ""
spectre.envlpOpts cmin string ""
spectre.envlpOpts write string ""
spectre.envlpOpts writefinal string ""
spectre.envlpOpts swapfile string ""
spectre.envlpOpts method string ""
spectre.envlpOpts relref string ""
spectre.envlpOpts lteratio string ""
spectre.envlpOpts envlteratio string ""
spectre.envlpOpts steadyratio string ""
spectre.envlpOpts stats string ""
spectre.envlpOpts annotate string "status"
spectre.envlpOpts save string ""
spectre.envlpOpts nestlvl string ""
spectre.envlpOpts compression string ""
spectre.envlpOpts outputtype string ""
spectre.envlpOpts strobeperiod string ""
spectre.envlpOpts maxiters string ""
spectre.envlpOpts restart string ""
spectre.envlpOpts envmaxiters string ""
;spectre ac partition variables
spectre.ac enable toggle (nil)
spectre.ac sweep string "Frequency"
spectre.ac freq string ""
spectre.ac dev string ""
spectre.ac deviceParam string ""
spectre.ac mod string ""
spectre.ac modelParam string ""
spectre.ac designVar string ""
spectre.ac param string ""
spectre.ac rangeType string "Start-Stop"
spectre.ac start string ""
spectre.ac stop string ""
spectre.ac center string ""
spectre.ac span string ""
spectre.ac incrType string "Automatic"
spectre.ac stepTypeLin string "Step Size"
spectre.ac stepTypeLog string "Points Per Decade"
spectre.ac step string ""
spectre.ac lin string ""
spectre.ac dec string ""
spectre.ac log string ""
spectre.ac useDiscrete boolean nil
spectre.ac values string ""
;spectre acOpts partition variables
spectre.acOpts readns string ""
spectre.acOpts prevoppoint string ""
spectre.acOpts save string ""
spectre.acOpts nestlvl string ""
spectre.acOpts oppoint string ""
spectre.acOpts restart string ""
spectre.acOpts annotate string "status"
spectre.acOpts stats string ""
;spectre dc partition variables
spectre.dc enable toggle (nil)
spectre.dcop enable toggle (nil)
spectre.dc saveOppoint boolean nil
spectre.dc sweep string ""
spectre.dc dev string ""
spectre.dc deviceParam string ""
spectre.dc mod string ""
spectre.dc modelParam string ""
spectre.dc designVar string ""
spectre.dc param string ""
spectre.dc rangeType string "Start-Stop"
spectre.dc start string ""
spectre.dc stop string ""
spectre.dc center string ""
spectre.dc span string ""
spectre.dc incrType string "Automatic"
spectre.dc stepTypeLin string "Step Size"
spectre.dc stepTypeLog string "Points Per Decade"
spectre.dc step string ""
spectre.dc lin string ""
spectre.dc dec string ""
spectre.dc log string ""
spectre.dc useDiscrete boolean nil
spectre.dc values string ""
;spectre dcOpts partition variables
spectre.dcOpts force string ""
spectre.dcopOpts force string ""
spectre.dcOpts readns string ""
spectre.dcopOpts readns string ""
spectre.dcOpts readforce string ""
spectre.dcopOpts readforce string ""
spectre.dcOpts write string "spectre.dc"
spectre.dcopOpts write string "spectre.dc"
spectre.dcOpts writefinal string ""
spectre.dcopOpts writefinal string ""
spectre.dcOpts save string ""
spectre.dcopOpts save string ""
spectre.dcOpts nestlvl string ""
spectre.dcopOpts nestlvl string ""
spectre.dcOpts print string ""
spectre.dcopOpts print string ""
spectre.dcOpts check string ""
spectre.dcopOpts check string ""
spectre.dcOpts oppoint string "rawfile"
spectre.dcopOpts oppoint string "rawfile"
spectre.dcOpts homotopy string ""
spectre.dcopOpts homotopy string ""
spectre.dcOpts restart string ""
spectre.dcopOpts restart string ""
spectre.dcOpts maxiters string "150"
spectre.dcopOpts maxiters string "150"
spectre.dcOpts maxsteps string "10000"
spectre.dcopOpts maxsteps string "10000"
spectre.dcOpts annotate string "status"
spectre.dcopOpts annotate string "status"
spectre.dcOpts captab boolean nil
spectre.dcopOpts captab boolean nil
spectre.dcOpts threshold string "0.0"
spectre.dcopOpts threshold string "0.0"
spectre.dcOpts detail string "node"
spectre.dcopOpts detail string "node"
spectre.dcOpts sort string "name"
spectre.dcopOpts sort string "name"
;spectre noise partition variables
spectre.noise enable toggle (nil)
spectre.noise sweep string "Frequency"
spectre.noise freq string ""
spectre.noise dev string ""
spectre.noise deviceParam string ""
spectre.noise mod string ""
spectre.noise modelParam string ""
spectre.noise designVar string ""
spectre.noise param string ""
spectre.noise rangeType string "Start-Stop"
spectre.noise start string ""
spectre.noise stop string ""
spectre.noise center string ""
spectre.noise span string ""
spectre.noise incrType string "Automatic"
spectre.noise stepTypeLin string "Step Size"
spectre.noise stepTypeLog string "Points Per Decade"
spectre.noise step string ""
spectre.noise lin string ""
spectre.noise dec string ""
spectre.noise log string ""
spectre.noise useDiscrete boolean nil
spectre.noise values string ""
spectre.noise outType string "probe"
spectre.noise p string ""
spectre.noise n string ""
spectre.noise oprobe string ""
spectre.noise inType string "port"
spectre.noise inVsrc string ""
spectre.noise inIsrc string ""
spectre.noise iprobe string ""
spectre.noise inPort string ""
;spectre noiseOpts partition variables
spectre.noiseOpts readns string ""
spectre.noiseOpts prevoppoint string ""
spectre.noiseOpts save string ""
spectre.noiseOpts nestlvl string ""
spectre.noiseOpts oppoint string ""
spectre.noiseOpts restart string ""
spectre.noiseOpts annotate string "status"
spectre.noiseOpts stats string ""
;spectre xf partition variables
spectre.xf enable toggle (nil)
spectre.xf sweep string "Frequency"
spectre.xf freq string ""
spectre.xf dev string ""
spectre.xf deviceParam string ""
spectre.xf mod string ""
spectre.xf modelParam string ""
spectre.xf designVar string ""
spectre.xf param string ""
spectre.xf rangeType string "Start-Stop"
spectre.xf start string ""
spectre.xf stop string ""
spectre.xf center string ""
spectre.xf span string ""
spectre.xf incrType string "Automatic"
spectre.xf stepTypeLin string "Step Size"
spectre.xf stepTypeLog string "Points Per Decade"
spectre.xf step string ""
spectre.xf lin string ""
spectre.xf dec string ""
spectre.xf log string ""
spectre.xf useDiscrete boolean nil
spectre.xf values string ""
spectre.xf outType string "voltage"
spectre.xf p string ""
spectre.xf n string ""
spectre.xf probe string ""
;spectre xfOpts partition variables
spectre.xfOpts readns string ""
spectre.xfOpts prevoppoint string ""
spectre.xfOpts stimuli string ""
spectre.xfOpts save string ""
spectre.xfOpts nestlvl string ""
spectre.xfOpts oppoint string ""
spectre.xfOpts restart string ""
spectre.xfOpts annotate string "status"
spectre.xfOpts stats string ""
;spectre sp partition variables
spectre.sp enable toggle (nil)
spectre.sp ports string ""
spectre.sp sweep string "Frequency"
spectre.sp freq string ""
spectre.sp dev string ""
spectre.sp deviceParam string ""
spectre.sp mod string ""
spectre.sp modelParam string ""
spectre.sp designVar string ""
spectre.sp param string ""
spectre.sp rangeType string "Start-Stop"
spectre.sp start string ""
spectre.sp stop string ""
spectre.sp center string ""
spectre.sp span string ""
spectre.sp incrType string "Automatic"
spectre.sp stepTypeLin string "Step Size"
spectre.sp stepTypeLog string "Points Per Decade"
spectre.sp step string ""
spectre.sp lin string ""
spectre.sp dec string ""
spectre.sp log string ""
spectre.sp useDiscrete boolean nil
spectre.sp values string ""
spectre.sp donoise string "no"
spectre.sp oprobe string ""
spectre.sp iprobe string ""
;spectre spOpts partition variables
spectre.spOpts readns string ""
spectre.spOpts prevoppoint string ""
spectre.spOpts file string ""
spectre.spOpts datafmt string ""
spectre.spOpts datatype string ""
spectre.spOpts noisedata string ""
spectre.spOpts oppoint string ""
spectre.spOpts restart string ""
spectre.spOpts annotate string "status"
spectre.spOpts stats string ""
;spectre pss partition variables
spectre.pss enable toggle (nil)
spectre.pss paramListBox string ""
spectre.pss fundListBox string ""
spectre.pss stimName string ""
spectre.pss freqName string ""
spectre.pss freqVal string ""
spectre.pss signalLevel string "Large"
spectre.pss srcId string ""
spectre.pss maxHarms string ""
spectre.pss freqPeriod string "Beat Frequency"
spectre.pss fund string ""
spectre.pss autoCalc boolean nil
spectre.pss period string ""
spectre.pss harmonics string "Number of harmonics"
spectre.pss harms string ""
spectre.pss indices string ""
spectre.pss Aindices string ""
spectre.pss harmsvec string ""
spectre.pss selFreqFrom string "0"
spectre.pss selFreqTo string "1e12"
spectre.pss order string "1"
spectre.pss harmsAndFreqsTitle string ""
spectre.pss harmsAndFreqsTitle2 string ""
spectre.pss harmsAndFreqs string ""
spectre.pss arrayCoeffs string ""
spectre.pss harmCoeffs string ""
spectre.pss harmListMem string ""
spectre.pss errpreset string ""
spectre.pss tstab string ""
spectre.pss saveinit string ""
spectre.pss oscana boolean nil
spectre.pss p string ""
spectre.pss n string ""
spectre.pss sweepB boolean nil
spectre.pss sweep string "Variable"
spectre.pss freqVar string "no"
spectre.pss designVar string ""
spectre.pss dev string ""
spectre.pss deviceParam string ""
spectre.pss mod string ""
spectre.pss modelParam string ""
spectre.pss param string ""
spectre.pss rangeType string "Start-Stop"
spectre.pss start string ""
spectre.pss stop string ""
spectre.pss center string ""
spectre.pss span string ""
spectre.pss incrType string "Linear"
spectre.pss stepTypeLin string "Step Size"
spectre.pss stepTypeLog string "Points Per Decade"
spectre.pss step string ""
spectre.pss lin string ""
spectre.pss dec string ""
spectre.pss log string ""
spectre.pss useDiscrete boolean nil
spectre.pss values string ""
;spectre pssOpts partition variables
spectre.pssOpts step string ""
spectre.pssOpts maxstep string ""
spectre.pssOpts ic string ""
spectre.pssOpts skipdc string ""
spectre.pssOpts readic string ""
spectre.pssOpts readns string ""
spectre.pssOpts cmin string ""
spectre.pssOpts write string ""
spectre.pssOpts writefinal string ""
spectre.pssOpts swapfile string ""
spectre.pssOpts writepss string ""
spectre.pssOpts readpss string ""
spectre.pssOpts method string ""
spectre.pssOpts tstabmethod string ""
spectre.pssOpts relref string ""
spectre.pssOpts lteratio string ""
spectre.pssOpts steadyratio string ""
spectre.pssOpts maxacfreq string ""
spectre.pssOpts maxperiods string ""
spectre.pssOpts finitediff string ""
spectre.pssOpts highorder string ""
spectre.pssOpts psaratio string ""
spectre.pssOpts maxorder string ""
spectre.pssOpts fullpssvec string ""
spectre.pssOpts stats string ""
spectre.pssOpts annotate string "status"
spectre.pssOpts save string ""
spectre.pssOpts nestlvl string ""
spectre.pssOpts oppoint string ""
spectre.pssOpts skipstart string ""
spectre.pssOpts skipstop string ""
spectre.pssOpts skipcount string ""
spectre.pssOpts strobeperiod string ""
spectre.pssOpts strobedelay string ""
spectre.pssOpts compression string ""
spectre.pssOpts outputtype string ""
spectre.pssOpts maxiters string ""
spectre.pssOpts restart string ""
spectre.pssOpts tstart string ""
;spectre pac partition variables
spectre.pac enable toggle (nil)
spectre.pac fund string ""
spectre.pac period string ""
spectre.pac modsource string ""
spectre.pac moduppersideband string "0"
spectre.pac inmodharmnum string "1"
spectre.pac outmodharmvec string "1"
spectre.pac inputType string "SSB"
spectre.pac modulatedToggle boolean nil
spectre.pac modulated string ""
spectre.pac singlePt string "Single-Point []"
spectre.pac sweeptype string " "
spectre.pac relharmnum string ""
spectre.pac rangeType string "Start-Stop"
spectre.pac start string ""
spectre.pac stop string ""
spectre.pac center string ""
spectre.pac span string ""
spectre.pac incrType string "Automatic"
spectre.pac stepTypeLin string "Step Size"
spectre.pac stepTypeLog string "Points Per Decade"
spectre.pac step string ""
spectre.pac lin string ""
spectre.pac dec string ""
spectre.pac log string ""
spectre.pac useDiscrete boolean nil
spectre.pac values string ""
spectre.pac harmonics string "Maximum sideband"
spectre.pac maxsideband string ""
spectre.pac indices string ""
spectre.pac Aindices string ""
spectre.pac sidebands string ""
spectre.pac side string "upper"
spectre.pac selFreqFrom string "0"
spectre.pac selFreqTo string "1e12"
spectre.pac order string "1"
spectre.pac harmsAndFreqsTitle string ""
spectre.pac harmsAndFreqsTitle2 string ""
spectre.pac harmsAndFreqs string ""
spectre.pac arrayCoeffs string ""
spectre.pac harmCoeffs string ""
spectre.pac harmListMem string ""
;spectre pacOpts partition variables
spectre.pacOpts tolerance string ""
spectre.pacOpts gear_order string ""
spectre.pacOpts solver string ""
spectre.pacOpts oscsolver string ""
spectre.pacOpts stats string ""
spectre.pacOpts annotate string "status"
spectre.pacOpts freqaxis string ""
spectre.pacOpts save string ""
spectre.pacOpts nestlvl string ""
spectre.pacOpts outputperiod string ""
;spectre pnoise partition variables
spectre.pnoise enable toggle (nil)
spectre.pnoise fund string ""
spectre.pnoise period string ""
spectre.pnoise singlePt string "Single-Point []"
spectre.pnoise sweeptype string " "
spectre.pnoise relharmnum string ""
spectre.pnoise rangeType string "Start-Stop"
spectre.pnoise start string ""
spectre.pnoise stop string ""
spectre.pnoise center string ""
spectre.pnoise span string ""
spectre.pnoise incrType string "Automatic"
spectre.pnoise stepTypeLin string "Step Size"
spectre.pnoise stepTypeLog string "Points Per Decade"
spectre.pnoise step string ""
spectre.pnoise lin string ""
spectre.pnoise dec string ""
spectre.pnoise log string ""
spectre.pnoise useDiscrete boolean nil
spectre.pnoise values string ""
spectre.pnoise harmonics string "Maximum sideband"
spectre.pnoise maxsideband string ""
spectre.pnoise indices string ""
spectre.pnoise Aindices string ""
spectre.pnoise sidebands string ""
spectre.pnoise side string "upper"
spectre.pnoise selFreqFrom string "0"
spectre.pnoise selFreqTo string "1e12"
spectre.pnoise order string "1"
spectre.pnoise harmsAndFreqsTitle string ""
spectre.pnoise harmsAndFreqsTitle2 string ""
spectre.pnoise harmsAndFreqs string ""
spectre.pnoise arrayCoeffs string ""
spectre.pnoise harmCoeffs string ""
spectre.pnoise harmListMem string ""
spectre.pnoise outType string "probe"
spectre.pnoise p string ""
spectre.pnoise n string ""
spectre.pnoise oprobe string ""
spectre.pnoise inType string "port"
spectre.pnoise inVsrc string ""
spectre.pnoise inIsrc string ""
spectre.pnoise iprobe string ""
spectre.pnoise inPort string ""
spectre.pnoise refsbSelect string "Enter in field"
spectre.pnoise refsideband string ""
spectre.pnoise refsbFreqFrom string "0"
spectre.pnoise refsbFreqTo string "1e12"
spectre.pnoise refsbOrder string "1"
spectre.pnoise refsbTitle string ""
spectre.pnoise refsbListbox string ""
spectre.pnoise noisetype string "sources"
spectre.pnoise tdnoise string "Noise Skip Count"
spectre.pnoise noiseskipcount string ""
spectre.pnoise numberofpoints string ""
spectre.pnoise maxcycles string ""
spectre.pnoise useDiscreteNoise boolean nil
spectre.pnoise noisetimepoints string ""
spectre.pnoise useDiscreteCorr boolean nil
spectre.pnoise cycles string ""
;spectre pnoiseOpts partition variables
spectre.pnoiseOpts tolerance string ""
spectre.pnoiseOpts gear_order string ""
spectre.pnoiseOpts solver string ""
spectre.pnoiseOpts oscsolver string ""
spectre.pnoiseOpts stats string ""
spectre.pnoiseOpts annotate string "status"
spectre.pnoiseOpts save string ""
spectre.pnoiseOpts nestlvl string ""
spectre.pnoiseOpts saveallsidebands string ""
;spectre pxf partition variables
spectre.pxf enable toggle (nil)
spectre.pxf fund string ""
spectre.pxf period string ""
spectre.pxf moduppersideband string "0"
spectre.pxf outmodharmnum string "1"
spectre.pxf inmodharmvec string "1"
spectre.pxf outputType string "SSB"
spectre.pxf modulatedToggle boolean nil
spectre.pxf modulated string ""
spectre.pxf outType string "voltage"
spectre.pxf p string ""
spectre.pxf n string ""
spectre.pxf probe string ""
spectre.pxf singlePt string "Single-Point []"
spectre.pxf sweeptype string " "
spectre.pxf relharmnum string ""
spectre.pxf rangeType string "Start-Stop"
spectre.pxf start string ""
spectre.pxf stop string ""
spectre.pxf center string ""
spectre.pxf span string ""
spectre.pxf incrType string "Automatic"
spectre.pxf stepTypeLin string "Step Size"
spectre.pxf stepTypeLog string "Points Per Decade"
spectre.pxf step string ""
spectre.pxf lin string ""
spectre.pxf dec string ""
spectre.pxf log string ""
spectre.pxf useDiscrete boolean nil
spectre.pxf values string ""
spectre.pxf harmonics string "Maximum sideband"
spectre.pxf maxsideband string ""
spectre.pxf indices string ""
spectre.pxf Aindices string ""
spectre.pxf sidebands string ""
spectre.pxf side string "upper"
spectre.pxf selFreqFrom string "0"
spectre.pxf selFreqTo string "1e12"
spectre.pxf order string "1"
spectre.pxf harmsAndFreqsTitle string ""
spectre.pxf harmsAndFreqsTitle2 string ""
spectre.pxf harmsAndFreqs string ""
spectre.pxf arrayCoeffs string ""
spectre.pxf harmCoeffs string ""
spectre.pxf harmListMem string ""
;spectre pxfOpts partition variables
spectre.pxfOpts tolerance string ""
spectre.pxfOpts gear_order string ""
spectre.pxfOpts solver string ""
spectre.pxfOpts oscsolver string ""
spectre.pxfOpts stats string ""
spectre.pxfOpts annotate string "status"
spectre.pxfOpts stimuli string ""
spectre.pxfOpts freqaxis string ""
spectre.pxfOpts save string ""
spectre.pxfOpts nestlvl string ""
;spectre psp partition variables
spectre.psp enable toggle (nil)
spectre.psp singlePt string "Single-Point []"
spectre.psp sweeptype string " "
spectre.psp rangeType string "Start-Stop"
spectre.psp start string ""
spectre.psp stop string ""
spectre.psp center string ""
spectre.psp span string ""
spectre.psp incrType string "Automatic"
spectre.psp stepTypeLin string "Step Size"
spectre.psp stepTypeLog string "Points Per Decade"
spectre.psp step string ""
spectre.psp lin string ""
spectre.psp dec string ""
spectre.psp log string ""
spectre.psp useDiscrete boolean nil
spectre.psp values string ""
spectre.psp portharmsvec string ""
spectre.psp ports string ""
spectre.psp selectPorts boolean t
spectre.psp harmsvec string ""
spectre.psp freqRange string ""
spectre.psp listPortHarm string ""
spectre.psp listPortName string ""
spectre.psp listPortNum string ""
spectre.psp portChoiceList string ""
spectre.psp portChoiceListHeading string ""
spectre.psp donoise string "yes"
spectre.psp maxsideband string ""
;spectre pspOpts partition variables
spectre.pspOpts tolerance string ""
spectre.pspOpts gear_order string ""
spectre.pspOpts solver string ""
spectre.pspOpts oscsolver string ""
spectre.pspOpts annotate string "status"
spectre.pspOpts stats string ""
spectre.pspOpts freqaxis string ""
;spectre qpss partition variables
spectre.qpss enable toggle (nil)
spectre.qpss paramListBox string ""
spectre.qpss fundListBox string ""
spectre.qpss stimName string ""
spectre.qpss freqName string ""
spectre.qpss freqVal string ""
spectre.qpss signalLevel string "Moderate"
spectre.qpss srcId string ""
spectre.qpss maxHarms string ""
spectre.qpss funds string ""
spectre.qpss maxharms string ""
spectre.qpss harmonics boolean nil
spectre.qpss selFreqFrom string "0"
spectre.qpss selFreqTo string "1e12"
spectre.qpss harmsAndFreqsTitle string ""
spectre.qpss harmsAndFreqs string ""
spectre.qpss errpreset string ""
spectre.qpss tstab string ""
spectre.qpss saveinit string ""
spectre.qpss sweepB boolean nil
spectre.qpss sweep string "Variable"
spectre.qpss freqVar string "no"
spectre.qpss designVar string ""
spectre.qpss dev string ""
spectre.qpss deviceParam string ""
spectre.qpss mod string ""
spectre.qpss modelParam string ""
spectre.qpss param string ""
spectre.qpss rangeType string "Start-Stop"
spectre.qpss start string ""
spectre.qpss stop string ""
spectre.qpss center string ""
spectre.qpss span string ""
spectre.qpss incrType string "Linear"
spectre.qpss stepTypeLin string "Step Size"
spectre.qpss stepTypeLog string "Points Per Decade"
spectre.qpss step string ""
spectre.qpss lin string ""
spectre.qpss dec string ""
spectre.qpss log string ""
spectre.qpss useDiscrete boolean nil
spectre.qpss values string ""
;spectre qpssOpts partition variables
spectre.qpssOpts step string ""
spectre.qpssOpts maxstep string ""
spectre.qpssOpts ic string ""
spectre.qpssOpts skipdc string ""
spectre.qpssOpts readic string ""
spectre.qpssOpts readns string ""
spectre.qpssOpts cmin string ""
spectre.qpssOpts write string ""
spectre.qpssOpts writefinal string ""
spectre.qpssOpts swapfile string ""
spectre.qpssOpts writeqpss string ""
spectre.qpssOpts readqpss string ""
spectre.qpssOpts method string ""
spectre.qpssOpts relref string ""
spectre.qpssOpts lteratio string ""
spectre.qpssOpts steadyratio string ""
spectre.qpssOpts maxperiods string ""
spectre.qpssOpts stats string ""
spectre.qpssOpts annotate string "status"
spectre.qpssOpts save string ""
spectre.qpssOpts nestlvl string ""
spectre.qpssOpts oppoint string ""
spectre.qpssOpts skipstart string ""
spectre.qpssOpts skipstop string ""
spectre.qpssOpts skipcount string ""
spectre.qpssOpts strobeperiod string ""
spectre.qpssOpts strobedelay string ""
spectre.qpssOpts compression string ""
spectre.qpssOpts maxiters string ""
spectre.qpssOpts restart string ""
spectre.qpssOpts tstart string ""
;spectre qpac partition variables
spectre.qpac enable toggle (nil)
spectre.qpac singlePt string "Single-Point []"
spectre.qpac sweeptype string " "
spectre.qpac relharmvec string ""
spectre.qpac rangeType string "Start-Stop"
spectre.qpac start string ""
spectre.qpac stop string ""
spectre.qpac center string ""
spectre.qpac span string ""
spectre.qpac incrType string "Automatic"
spectre.qpac stepTypeLin string "Step Size"
spectre.qpac stepTypeLog string "Points Per Decade"
spectre.qpac step string ""
spectre.qpac lin string ""
spectre.qpac dec string ""
spectre.qpac log string ""
spectre.qpac useDiscrete boolean nil
spectre.qpac values string ""
spectre.qpac sbsm string "Maximum clock order"
spectre.qpac clockmaxharm string ""
spectre.qpac selFreqFrom string "0"
spectre.qpac selFreqTo string "1e12"
spectre.qpac order string "1"
spectre.qpac harmsAndFreqsTitle string ""
spectre.qpac harmsAndFreqsTitle2 string ""
spectre.qpac harmsAndFreqs string ""
spectre.qpac arrayCoeffs string ""
spectre.qpac harmCoeffs string ""
spectre.qpac harmListMem string ""
spectre.qpac sidevec string ""
;spectre qpacOpts partition variables
spectre.qpacOpts tolerance string ""
spectre.qpacOpts gear_order string ""
spectre.qpacOpts solver string ""
spectre.qpacOpts stats string ""
spectre.qpacOpts annotate string "status"
spectre.qpacOpts freqaxis string ""
spectre.qpacOpts save string ""
spectre.qpacOpts nestlvl string ""
;spectre qpnoise partition variables
spectre.qpnoise enable toggle (nil)
spectre.qpnoise singlePt string "Single-Point []"
spectre.qpnoise sweeptype string " "
spectre.qpnoise relharmvec string ""
spectre.qpnoise rangeType string "Start-Stop"
spectre.qpnoise start string ""
spectre.qpnoise stop string ""
spectre.qpnoise center string ""
spectre.qpnoise span string ""
spectre.qpnoise incrType string "Automatic"
spectre.qpnoise stepTypeLin string "Step Size"
spectre.qpnoise stepTypeLog string "Points Per Decade"
spectre.qpnoise step string ""
spectre.qpnoise lin string ""
spectre.qpnoise dec string ""
spectre.qpnoise log string ""
spectre.qpnoise useDiscrete boolean nil
spectre.qpnoise values string ""
spectre.qpnoise sbsm string "Maximum clock order"
spectre.qpnoise clockmaxharm string ""
spectre.qpnoise selFreqFrom string "0"
spectre.qpnoise selFreqTo string "1e12"
spectre.qpnoise order string "1"
spectre.qpnoise harmsAndFreqsTitle string ""
spectre.qpnoise harmsAndFreqsTitle2 string ""
spectre.qpnoise harmsAndFreqs string ""
spectre.qpnoise arrayCoeffs string ""
spectre.qpnoise harmCoeffs string ""
spectre.qpnoise harmListMem string ""
spectre.qpnoise sidevec string ""
spectre.qpnoise outType string "probe"
spectre.qpnoise p string ""
spectre.qpnoise n string ""
spectre.qpnoise oprobe string ""
spectre.qpnoise inType string "port"
spectre.qpnoise inVsrc string ""
spectre.qpnoise inIsrc string ""
spectre.qpnoise iprobe string ""
spectre.qpnoise inPort string ""
spectre.qpnoise refsbSelect string "Enter in field"
spectre.qpnoise refsideband string ""
spectre.qpnoise refsbFreqFrom string "0"
spectre.qpnoise refsbFreqTo string "1e12"
spectre.qpnoise refsbOrder string "1"
spectre.qpnoise refsbTitle string ""
spectre.qpnoise refsbListbox string ""
;spectre qpnoiseOpts partition variables
spectre.qpnoiseOpts tolerance string ""
spectre.qpnoiseOpts gear_order string ""
spectre.qpnoiseOpts solver string ""
spectre.qpnoiseOpts stats string ""
spectre.qpnoiseOpts annotate string "status"
spectre.qpnoiseOpts save string ""
spectre.qpnoiseOpts nestlvl string ""
spectre.qpnoiseOpts saveallsidebands string ""
;spectre qpxf partition variables
spectre.qpxf enable toggle (nil)
spectre.qpxf singlePt string "Single-Point []"
spectre.qpxf sweeptype string " "
spectre.qpxf relharmvec string ""
spectre.qpxf rangeType string "Start-Stop"
spectre.qpxf start string ""
spectre.qpxf stop string ""
spectre.qpxf center string ""
spectre.qpxf span string ""
spectre.qpxf incrType string "Automatic"
spectre.qpxf stepTypeLin string "Step Size"
spectre.qpxf stepTypeLog string "Points Per Decade"
spectre.qpxf step string ""
spectre.qpxf lin string ""
spectre.qpxf dec string ""
spectre.qpxf log string ""
spectre.qpxf useDiscrete boolean nil
spectre.qpxf values string ""
spectre.qpxf sbsm string "Maximum clock order"
spectre.qpxf clockmaxharm string ""
spectre.qpxf selFreqFrom string "0"
spectre.qpxf selFreqTo string "1e12"
spectre.qpxf order string "1"
spectre.qpxf harmsAndFreqsTitle string ""
spectre.qpxf harmsAndFreqsTitle2 string ""
spectre.qpxf harmsAndFreqs string ""
spectre.qpxf arrayCoeffs string ""
spectre.qpxf harmCoeffs string ""
spectre.qpxf harmListMem string ""
spectre.qpxf sidevec string ""
spectre.qpxf outType string "voltage"
spectre.qpxf p string ""
spectre.qpxf n string ""
spectre.qpxf probe string ""
;spectre qpxfOpts partition variables
spectre.qpxfOpts tolerance string ""
spectre.qpxfOpts gear_order string ""
spectre.qpxfOpts solver string ""
spectre.qpxfOpts stats string ""
spectre.qpxfOpts annotate string "status"
spectre.qpxfOpts stimuli string ""
spectre.qpxfOpts freqaxis string ""
spectre.qpxfOpts save string ""
spectre.qpxfOpts nestlvl string ""
;spectre qpsp partition variables
spectre.qpsp enable toggle (nil)
spectre.qpsp singlePt string "Single-Point []"
spectre.qpsp sweeptype string " "
spectre.qpsp rangeType string "Start-Stop"
spectre.qpsp start string ""
spectre.qpsp stop string ""
spectre.qpsp center string ""
spectre.qpsp span string ""
spectre.qpsp incrType string "Automatic"
spectre.qpsp stepTypeLin string "Step Size"
spectre.qpsp stepTypeLog string "Points Per Decade"
spectre.qpsp step string ""
spectre.qpsp lin string ""
spectre.qpsp dec string ""
spectre.qpsp log string ""
spectre.qpsp useDiscrete boolean nil
spectre.qpsp values string ""
spectre.qpsp portharmsvec string ""
spectre.qpsp ports string ""
spectre.qpsp selectPorts boolean t
spectre.qpsp harmsvec string ""
spectre.qpsp freqRange string ""
spectre.qpsp listPortHarm string ""
spectre.qpsp listPortName string ""
spectre.qpsp listPortNum string ""
spectre.qpsp portChoiceList string ""
spectre.qpsp portChoiceListHeading string ""
spectre.qpsp donoise string "yes"
spectre.qpsp clockmaxharm string ""
;spectre qpspOpts partition variables
spectre.qpspOpts tolerance string ""
spectre.qpspOpts gear_order string ""
spectre.qpspOpts solver string ""
spectre.qpspOpts annotate string "status"
spectre.qpspOpts stats string ""
spectre.qpspOpts freqaxis string ""
;spectre sens partition variables
spectre.sens enable toggle (nil)
spectre.sens sensType toggle (nil nil nil)
spectre.sens analyses_list string ""
spectre.sens outputs string ""
spectre.sens output_list string ""
spectre.sens net string ""
spectre.sens term string ""
;spectre sensOpts partition variables
;spectreS environment variables
;spectreS opts partition variables
spectreS.opts title string ""
spectreS.opts audit string ""
spectreS.opts ckptclock string "1800"
spectreS.opts flow string ""
spectreS.opts cols string "80"
spectreS.opts opptcheck string ""
spectreS.opts reltol string "1e-3"
spectreS.opts notation string ""
spectreS.opts warn string ""
spectreS.opts approx string ""
spectreS.opts info string ""
spectreS.opts quantities string ""
spectreS.opts pivabs string ""
spectreS.opts compatible string ""
spectreS.opts ignshorts string ""
spectreS.opts gmin string "1e-12"
spectreS.opts rforce string "1"
spectreS.opts homotopy string ""
spectreS.opts debug string ""
spectreS.opts iabstol string "1e-12"
spectreS.opts maxwarns string "5"
spectreS.opts tempeffects string ""
spectreS.opts vabstol string "1e-6"
spectreS.opts temp string "27"
spectreS.opts tnom string "27"
spectreS.opts narrate string ""
spectreS.opts value string ""
spectreS.opts gmin_check string ""
spectreS.opts pivrel string "1e-3"
spectreS.opts pivotdc string ""
spectreS.opts digits string "5"
spectreS.opts diagnose string ""
spectreS.opts scale string "1.0"
spectreS.opts scalem string "1.0"
spectreS.opts error string ""
spectreS.opts inventory string ""
spectreS.opts topcheck string ""
spectreS.opts limit string ""
;spectreS outputs partition variables
spectreS.outputs allAnalogACTC boolean nil
spectreS.outputs allAhdlVars boolean nil
spectreS.outputs allAnalogNV boolean t
spectreS.outputs allAnalogTC boolean nil
;spectreS envOpts partition variables
spectreS.envOpts updateFile string ""
spectreS.envOpts stimulusFile string ""
spectreS.envOpts instViewListTable string ""
spectreS.envOpts doInstBased boolean nil
spectreS.envOpts stopViewList string "spectreS spice"
spectreS.envOpts paramRangeCheckFile string ""
spectreS.envOpts includeSyntax string "cdsSpice"
spectreS.envOpts initFile string ""
spectreS.envOpts printComments boolean nil
spectreS.envOpts netlistType string "hierarchical"
spectreS.envOpts generateMapFile boolean nil
spectreS.envOpts includeFile string ""
spectreS.envOpts recover boolean nil
spectreS.envOpts instStopListTable string ""
spectreS.envOpts switchViewList string "spectreS spice cmos_sch cmos.sch schematic veriloga ahdl"
;spectreS init partition variables
spectreS.init processPriority int 0
;spectreS tran partition variables
spectreS.tran enable toggle (nil)
spectreS.tran to string ""
spectreS.tran errpreset string ""
;spectreS tranOpts partition variables
spectreS.tranOpts start string ""
spectreS.tranOpts outputstart string ""
spectreS.tranOpts step string ""
spectreS.tranOpts maxstep string ""
spectreS.tranOpts ic string ""
spectreS.tranOpts skipdc string ""
spectreS.tranOpts readic string ""
spectreS.tranOpts readns string ""
spectreS.tranOpts cmin string ""
spectreS.tranOpts write string "spectre.ic"
spectreS.tranOpts writefinal string "spectre.fc"
spectreS.tranOpts ckptperiod string ""
spectreS.tranOpts method string "default"
spectreS.tranOpts relref string "default"
spectreS.tranOpts lteratio string ""
spectreS.tranOpts stats string ""
spectreS.tranOpts annotate string "status"
spectreS.tranOpts oppoint string ""
spectreS.tranOpts skipstart string ""
spectreS.tranOpts skipstop string ""
spectreS.tranOpts skipcount string ""
spectreS.tranOpts strobeperiod string ""
spectreS.tranOpts strobedelay string ""
spectreS.tranOpts compression string "no"
spectreS.tranOpts maxiters string "5"
spectreS.tranOpts restart string ""
;spectreS ac partition variables
spectreS.ac enable toggle (nil)
spectreS.ac sweep string "Frequency"
spectreS.ac freq string ""
spectreS.ac device string ""
spectreS.ac deviceParam string ""
spectreS.ac model string ""
spectreS.ac modelParam string ""
spectreS.ac temperature string "temp"
spectreS.ac rangeType string "Start-Stop"
spectreS.ac from string ""
spectreS.ac to string ""
spectreS.ac center string ""
spectreS.ac span string ""
spectreS.ac incrType string "Automatic"
spectreS.ac stepTypeLin string "Step Size"
spectreS.ac stepTypeLog string "Points Per Decade"
spectreS.ac by string ""
spectreS.ac lin string ""
spectreS.ac dec string ""
spectreS.ac log string ""
spectreS.ac useDiscrete boolean nil
spectreS.ac values string ""
;spectreS acOpts partition variables
spectreS.acOpts readns string ""
spectreS.acOpts oppoint string ""
spectreS.acOpts restart string ""
spectreS.acOpts annotate string "status"
spectreS.acOpts stats string ""
;spectreS dc partition variables
spectreS.dc enable toggle (nil)
spectreS.dcop enable toggle (nil)
spectreS.dc saveOppoint boolean nil
spectreS.dc oppoint string "rawfile"
spectreS.dc save string "allpub"
spectreS.dc sweep string ""
spectreS.dc device string ""
spectreS.dc deviceParam string ""
spectreS.dc model string ""
spectreS.dc modelParam string ""
spectreS.dc temperature string "temp"
spectreS.dc rangeType string "Start-Stop"
spectreS.dc from string ""
spectreS.dc to string ""
spectreS.dc center string ""
spectreS.dc span string ""
spectreS.dc incrType string "Automatic"
spectreS.dc stepTypeLin string "Step Size"
spectreS.dc stepTypeLog string "Points Per Decade"
spectreS.dc by string ""
spectreS.dc lin string ""
spectreS.dc dec string ""
spectreS.dc log string ""
spectreS.dc useDiscrete boolean nil
spectreS.dc values string ""
;spectreS dcOpts partition variables
spectreS.dcOpts force string ""
spectreS.dcopOpts force string ""
spectreS.dcOpts readns string ""
spectreS.dcopOpts readns string ""
spectreS.dcOpts readforce string ""
spectreS.dcopOpts readforce string ""
spectreS.dcOpts write string "spectre.dc"
spectreS.dcopOpts write string "spectre.dc"
spectreS.dcOpts writefinal string ""
spectreS.dcopOpts writefinal string ""
spectreS.dcOpts print string ""
spectreS.dcopOpts print string ""
spectreS.dcOpts check string ""
spectreS.dcopOpts check string ""
spectreS.dcOpts homotopy string ""
spectreS.dcopOpts homotopy string ""
spectreS.dcOpts restart string ""
spectreS.dcopOpts restart string ""
spectreS.dcOpts maxiters string "150"
spectreS.dcopOpts maxiters string "150"
spectreS.dcOpts maxsteps string "10000"
spectreS.dcopOpts maxsteps string "10000"
spectreS.dcOpts annotate string "status"
spectreS.dcopOpts annotate string "status"
;spectreS noise partition variables
spectreS.noise enable toggle (nil)
spectreS.noise sweep string "Frequency"
spectreS.noise freq string ""
spectreS.noise device string ""
spectreS.noise deviceParam string ""
spectreS.noise model string ""
spectreS.noise modelParam string ""
spectreS.noise temperature string "temp"
spectreS.noise rangeType string "Start-Stop"
spectreS.noise from string ""
spectreS.noise to string ""
spectreS.noise center string ""
spectreS.noise span string ""
spectreS.noise incrType string "Automatic"
spectreS.noise stepTypeLin string "Step Size"
spectreS.noise stepTypeLog string "Points Per Decade"
spectreS.noise by string ""
spectreS.noise lin string ""
spectreS.noise dec string ""
spectreS.noise log string ""
spectreS.noise useDiscrete boolean nil
spectreS.noise values string ""
spectreS.noise outNoiseType string "voltage"
spectreS.noise negNode string "/gnd!"
spectreS.noise posNode string ""
spectreS.noise outVsrc string ""
spectreS.noise inNoiseType string "voltage"
spectreS.noise inVsrc string ""
spectreS.noise inIsrc string ""
spectreS.noise inPort string ""
;spectreS noiseOpts partition variables
spectreS.noiseOpts readns string ""
spectreS.noiseOpts oppoint string ""
spectreS.noiseOpts restart string ""
spectreS.noiseOpts annotate string "status"
spectreS.noiseOpts stats string ""
;spectreS xf partition variables
spectreS.xf enable toggle (nil)
spectreS.xf sweep string "Frequency"
spectreS.xf freq string ""
spectreS.xf device string ""
spectreS.xf deviceParam string ""
spectreS.xf model string ""
spectreS.xf modelParam string ""
spectreS.xf temperature string "temp"
spectreS.xf rangeType string "Start-Stop"
spectreS.xf from string ""
spectreS.xf to string ""
spectreS.xf center string ""
spectreS.xf span string ""
spectreS.xf incrType string "Automatic"
spectreS.xf stepTypeLin string "Step Size"
spectreS.xf stepTypeLog string "Points Per Decade"
spectreS.xf by string ""
spectreS.xf lin string ""
spectreS.xf dec string ""
spectreS.xf log string ""
spectreS.xf useDiscrete boolean nil
spectreS.xf values string ""
spectreS.xf outXfType string "voltage"
spectreS.xf negNode string "/gnd!"
spectreS.xf posNode string ""
spectreS.xf outVsrc string ""
;spectreS xfOpts partition variables
spectreS.xfOpts readns string ""
spectreS.xfOpts stimuli string ""
spectreS.xfOpts oppoint string ""
spectreS.xfOpts restart string ""
spectreS.xfOpts annotate string "status"
spectreS.xfOpts stats string ""
;spectreS sp partition variables
spectreS.sp enable toggle (nil)
spectreS.sp sweep string "Frequency"
spectreS.sp frequency string ""
spectreS.sp device string ""
spectreS.sp deviceParam string ""
spectreS.sp model string ""
spectreS.sp modelParam string ""
spectreS.sp temperature string "temp"
spectreS.sp rangeType string "Start-Stop"
spectreS.sp from string ""
spectreS.sp to string ""
spectreS.sp center string ""
spectreS.sp span string ""
spectreS.sp incrType string "Automatic"
spectreS.sp stepTypeLin string "Step Size"
spectreS.sp stepTypeLog string "Points Per Decade"
spectreS.sp by string ""
spectreS.sp lin string ""
spectreS.sp dec string ""
spectreS.sp log string ""
spectreS.sp useDiscrete boolean nil
spectreS.sp values string ""
spectreS.sp donoise boolean nil
spectreS.sp oprobe string ""
spectreS.sp iprobe string ""
;spectreS spOpts partition variables
spectreS.spOpts readns string ""
spectreS.spOpts file string ""
spectreS.spOpts oppoint string ""
spectreS.spOpts reftemp string ""
spectreS.spOpts restart string ""
spectreS.spOpts annotate string "status"
spectreS.spOpts stats string ""
;spectreS spss partition variables
spectreS.spss enable toggle (nil)
spectreS.spss paramListBox string ""
spectreS.spss fundListBox string ""
spectreS.spss stimName string ""
spectreS.spss freqName string ""
spectreS.spss freqVal string ""
spectreS.spss signalLevel string "Moderate"
spectreS.spss srcId string ""
spectreS.spss maxHarms string ""
spectreS.spss freqPeriod string "Fundamental (Beat) Frequency"
spectreS.spss fund string ""
spectreS.spss period string ""
spectreS.spss harmonics string "None"
spectreS.spss numharmonics string ""
spectreS.spss arrayharmonics string ""
spectreS.spss none string "0"
spectreS.spss selFreqFrom string ""
spectreS.spss selFreqTo string ""
spectreS.spss harmsAndFreqsTitle string ""
spectreS.spss harmsAndFreqs string ""
spectreS.spss errpreset string ""
spectreS.spss tstab string ""
spectreS.spss saveinit string ""
spectreS.spss oscana boolean nil
spectreS.spss oscRefNode string "/gnd!"
spectreS.spss oscNode string ""
spectreS.spss sweep string "frequency/period"
spectreS.spss designVar string ""
spectreS.spss rangeType string "Start-Stop"
spectreS.spss from string ""
spectreS.spss to string ""
spectreS.spss center string ""
spectreS.spss span string ""
spectreS.spss incrType string "Linear"
spectreS.spss stepTypeLin string "Step Size"
spectreS.spss stepTypeLog string "Points Per Decade"
spectreS.spss by string ""
spectreS.spss lin string ""
spectreS.spss dec string ""
spectreS.spss log string ""
spectreS.spss useDiscrete boolean nil
spectreS.spss values string ""
spectreS.spss analysisList string ""
spectreS.spss pacEnable boolean nil
spectreS.spss pacfund string ""
spectreS.spss pacRelative boolean nil
spectreS.spss pacsweeptype string ""
spectreS.spss pacharmonics string "Zero sideband only"
spectreS.spss pacnumharmonics string ""
spectreS.spss pacarrayharmonics string ""
spectreS.spss pacselFreqFrom string ""
spectreS.spss pacselFreqTo string ""
spectreS.spss pacharmsAndFreqsTitle string ""
spectreS.spss pacharmsAndFreqs string ""
spectreS.spss pnoiseEnable boolean nil
spectreS.spss pnoisefund string ""
spectreS.spss pnoiseRelative boolean nil
spectreS.spss pnoisesweeptype string ""
spectreS.spss pnoiseharmonics string "Zero sideband only"
spectreS.spss pnoisenumharmonics string ""
spectreS.spss pnoisearrayharmonics string ""
spectreS.spss pnoiseselFreqFrom string ""
spectreS.spss pnoiseselFreqTo string ""
spectreS.spss pnoiseharmsAndFreqsTitle string ""
spectreS.spss pnoiseharmsAndFreqs string ""
spectreS.spss pnoiseoutProbeType string "voltage"
spectreS.spss pnoisenegNode string "/gnd!"
spectreS.spss pnoiseposNode string ""
spectreS.spss pnoiseoutVsrc string ""
spectreS.spss pnoiseinNoiseType string "none"
spectreS.spss pnoiseinVsrc string ""
spectreS.spss pnoiseinIsrc string ""
spectreS.spss pnoiseinPort string ""
spectreS.spss pnoiserefsideband string ""
spectreS.spss pxfEnable boolean nil
spectreS.spss pxffund string ""
spectreS.spss pxfRelative boolean nil
spectreS.spss pxfsweeptype string ""
spectreS.spss pxfharmonics string "Zero sideband only"
spectreS.spss pxfnumharmonics string ""
spectreS.spss pxfarrayharmonics string ""
spectreS.spss pxfselFreqFrom string ""
spectreS.spss pxfselFreqTo string ""
spectreS.spss pxfharmsAndFreqsTitle string ""
spectreS.spss pxfharmsAndFreqs string ""
spectreS.spss pxfoutProbeType string "voltage"
spectreS.spss pxfnegNode string "/gnd!"
spectreS.spss pxfposNode string ""
spectreS.spss pxfoutVsrc string ""
;spectreS spssOpts partition variables
spectreS.spssOpts step string ""
spectreS.spssOpts maxstep string ""
spectreS.spssOpts ic string ""
spectreS.spssOpts skipdc string ""
spectreS.spssOpts readic string ""
spectreS.spssOpts readns string ""
spectreS.spssOpts cmin string ""
spectreS.spssOpts write string ""
spectreS.spssOpts writefinal string ""
spectreS.spssOpts swapfile string ""
spectreS.spssOpts method string ""
spectreS.spssOpts relref string ""
spectreS.spssOpts lteratio string ""
spectreS.spssOpts steadyratio string ""
spectreS.spssOpts maxacfreq string ""
spectreS.spssOpts maxperiods string ""
spectreS.spssOpts stats string ""
spectreS.spssOpts annotate string "status"
spectreS.spssOpts oppoint string ""
spectreS.spssOpts skipstart string ""
spectreS.spssOpts skipstop string ""
spectreS.spssOpts skipcount string ""
spectreS.spssOpts strobeperiod string ""
spectreS.spssOpts strobedelay string ""
spectreS.spssOpts compression string ""
spectreS.spssOpts maxiters string ""
spectreS.spssOpts restart string ""
spectreS.spssOpts tstart string ""
spectreS.spssOpts tolerance string ""
spectreS.spssOpts gearorder string ""
spectreS.spssOpts solver string ""
spectreS.spssOpts stats2 string ""
spectreS.spssOpts annotate2 string "status"
spectreS.spssOpts freqaxis string ""
spectreS.spssOpts tolerance2 string ""
spectreS.spssOpts gearorder2 string ""
spectreS.spssOpts solver2 string ""
spectreS.spssOpts stats3 string ""
spectreS.spssOpts annotate3 string "status"
spectreS.spssOpts stimuli string ""
spectreS.spssOpts freqaxis2 string ""
spectreS.spssOpts tolerance3 string ""
spectreS.spssOpts gearorder3 string ""
spectreS.spssOpts solver3 string ""
spectreS.spssOpts stats4 string ""
spectreS.spssOpts annotate4 string "status"
;spectreS pss partition variables
spectreS.pss enable toggle (nil)
spectreS.pss paramListBox string ""
spectreS.pss fundListBox string ""
spectreS.pss stimName string ""
spectreS.pss freqName string ""
spectreS.pss freqVal string ""
spectreS.pss signalLevel string "Moderate"
spectreS.pss srcId string ""
spectreS.pss maxHarms string ""
spectreS.pss freqPeriod string "Fundamental (Beat) Frequency"
spectreS.pss fund string ""
spectreS.pss period string ""
spectreS.pss harmonics string "None"
spectreS.pss numharmonics string ""
spectreS.pss arrayharmonics string ""
spectreS.pss none string "0"
spectreS.pss selFreqFrom string ""
spectreS.pss selFreqTo string ""
spectreS.pss harmsAndFreqsTitle string ""
spectreS.pss harmsAndFreqs string ""
spectreS.pss errpreset string ""
spectreS.pss tstab string ""
spectreS.pss saveinit string ""
spectreS.pss oscana boolean nil
spectreS.pss oscRefNode string "/gnd!"
spectreS.pss oscNode string ""
spectreS.pss analysisList string ""
spectreS.pss pacEnable boolean nil
spectreS.pss pacRelative boolean nil
spectreS.pss pacsweeptype string ""
spectreS.pss pacrangeType string "Start-Stop"
spectreS.pss pacfrom string ""
spectreS.pss pacto string ""
spectreS.pss paccenter string ""
spectreS.pss pacspan string ""
spectreS.pss pacincrType string "Automatic"
spectreS.pss pacstepTypeLin string "Step Size"
spectreS.pss pacstepTypeLog string "Points Per Decade"
spectreS.pss pacby string ""
spectreS.pss paclin string ""
spectreS.pss pacdec string ""
spectreS.pss paclog string ""
spectreS.pss pacuseDiscrete boolean nil
spectreS.pss pacvalues string ""
spectreS.pss pacharmonics string "Zero sideband only"
spectreS.pss pacnumharmonics string ""
spectreS.pss pacarrayharmonics string ""
spectreS.pss pacselFreqFrom string ""
spectreS.pss pacselFreqTo string ""
spectreS.pss pacharmsAndFreqsTitle string ""
spectreS.pss pacharmsAndFreqs string ""
spectreS.pss pnoiseEnable boolean nil
spectreS.pss pnoiseRelative boolean nil
spectreS.pss pnoisesweeptype string ""
spectreS.pss pnoiserangeType string "Start-Stop"
spectreS.pss pnoisefrom string ""
spectreS.pss pnoiseto string ""
spectreS.pss pnoisecenter string ""
spectreS.pss pnoisespan string ""
spectreS.pss pnoiseincrType string "Automatic"
spectreS.pss pnoisestepTypeLin string "Step Size"
spectreS.pss pnoisestepTypeLog string "Points Per Decade"
spectreS.pss pnoiseby string ""
spectreS.pss pnoiselin string ""
spectreS.pss pnoisedec string ""
spectreS.pss pnoiselog string ""
spectreS.pss pnoiseuseDiscrete boolean nil
spectreS.pss pnoisevalues string ""
spectreS.pss pnoiseharmonics string "Zero sideband only"
spectreS.pss pnoisenumharmonics string ""
spectreS.pss pnoisearrayharmonics string ""
spectreS.pss pnoiseselFreqFrom string ""
spectreS.pss pnoiseselFreqTo string ""
spectreS.pss pnoiseharmsAndFreqsTitle string ""
spectreS.pss pnoiseharmsAndFreqs string ""
spectreS.pss pnoiseoutProbeType string "voltage"
spectreS.pss pnoisenegNode string "/gnd!"
spectreS.pss pnoiseposNode string ""
spectreS.pss pnoiseoutVsrc string ""
spectreS.pss pnoiseinNoiseType string "none"
spectreS.pss pnoiseinVsrc string ""
spectreS.pss pnoiseinIsrc string ""
spectreS.pss pnoiseinPort string ""
spectreS.pss pnoiserefsideband string ""
spectreS.pss pxfEnable boolean nil
spectreS.pss pxfRelative boolean nil
spectreS.pss pxfsweeptype string ""
spectreS.pss pxfrangeType string "Start-Stop"
spectreS.pss pxffrom string ""
spectreS.pss pxfto string ""
spectreS.pss pxfcenter string ""
spectreS.pss pxfspan string ""
spectreS.pss pxfincrType string "Automatic"
spectreS.pss pxfstepTypeLin string "Step Size"
spectreS.pss pxfstepTypeLog string "Points Per Decade"
spectreS.pss pxfby string ""
spectreS.pss pxflin string ""
spectreS.pss pxfdec string ""
spectreS.pss pxflog string ""
spectreS.pss pxfuseDiscrete boolean nil
spectreS.pss pxfvalues string ""
spectreS.pss pxfharmonics string "Zero sideband only"
spectreS.pss pxfnumharmonics string ""
spectreS.pss pxfarrayharmonics string ""
spectreS.pss pxfselFreqFrom string ""
spectreS.pss pxfselFreqTo string ""
spectreS.pss pxfharmsAndFreqsTitle string ""
spectreS.pss pxfharmsAndFreqs string ""
spectreS.pss pxfoutProbeType string "voltage"
spectreS.pss pxfnegNode string "/gnd!"
spectreS.pss pxfposNode string ""
spectreS.pss pxfoutVsrc string ""
;spectreS pssOpts partition variables
spectreS.pssOpts step string ""
spectreS.pssOpts maxstep string ""
spectreS.pssOpts ic string ""
spectreS.pssOpts skipdc string ""
spectreS.pssOpts readic string ""
spectreS.pssOpts readns string ""
spectreS.pssOpts cmin string ""
spectreS.pssOpts write string ""
spectreS.pssOpts writefinal string ""
spectreS.pssOpts swapfile string ""
spectreS.pssOpts method string ""
spectreS.pssOpts relref string ""
spectreS.pssOpts lteratio string ""
spectreS.pssOpts steadyratio string ""
spectreS.pssOpts maxacfreq string ""
spectreS.pssOpts maxperiods string ""
spectreS.pssOpts stats string ""
spectreS.pssOpts annotate string "status"
spectreS.pssOpts oppoint string ""
spectreS.pssOpts skipstart string ""
spectreS.pssOpts skipstop string ""
spectreS.pssOpts skipcount string ""
spectreS.pssOpts strobeperiod string ""
spectreS.pssOpts strobedelay string ""
spectreS.pssOpts compression string ""
spectreS.pssOpts maxiters string ""
spectreS.pssOpts restart string ""
spectreS.pssOpts tstart string ""
spectreS.pssOpts tolerance string ""
spectreS.pssOpts gearorder string ""
spectreS.pssOpts solver string ""
spectreS.pssOpts stats2 string ""
spectreS.pssOpts annotate2 string "status"
spectreS.pssOpts freqaxis string ""
spectreS.pssOpts tolerance2 string ""
spectreS.pssOpts gearorder2 string ""
spectreS.pssOpts solver2 string ""
spectreS.pssOpts stats3 string ""
spectreS.pssOpts annotate3 string "status"
spectreS.pssOpts stimuli string ""
spectreS.pssOpts freqaxis2 string ""
spectreS.pssOpts tolerance3 string ""
spectreS.pssOpts gearorder3 string ""
spectreS.pssOpts solver3 string ""
spectreS.pssOpts stats4 string ""
spectreS.pssOpts annotate4 string "status"
;spectreS pdisto partition variables
spectreS.pdisto enable toggle (nil)
spectreS.pdisto paramListBox string ""
spectreS.pdisto fundListBox string ""
spectreS.pdisto stimName string ""
spectreS.pdisto freqName string ""
spectreS.pdisto freqVal string ""
spectreS.pdisto signalLevel string "Moderate"
spectreS.pdisto srcId string ""
spectreS.pdisto maxHarms string ""
spectreS.pdisto fundsList string ""
spectreS.pdisto maxHarmsList string ""
spectreS.pdisto errpreset string ""
spectreS.pdisto tstab string ""
spectreS.pdisto saveinit string ""
;spectreS pdistoOpts partition variables
spectreS.pdistoOpts step string ""
spectreS.pdistoOpts maxstep string ""
spectreS.pdistoOpts ic string ""
spectreS.pdistoOpts skipdc string ""
spectreS.pdistoOpts readic string ""
spectreS.pdistoOpts readns string ""
spectreS.pdistoOpts cmin string ""
spectreS.pdistoOpts tolerance string ""
spectreS.pdistoOpts gearorder string ""
spectreS.pdistoOpts solver string ""
spectreS.pdistoOpts write string ""
spectreS.pdistoOpts writefinal string ""
spectreS.pdistoOpts swapfile string ""
spectreS.pdistoOpts method string ""
spectreS.pdistoOpts relref string ""
spectreS.pdistoOpts lteratio string ""
spectreS.pdistoOpts steadyratio string ""
spectreS.pdistoOpts maxacfreq string ""
spectreS.pdistoOpts maxperiods string ""
spectreS.pdistoOpts stats string ""
spectreS.pdistoOpts annotate string "status"
spectreS.pdistoOpts oppoint string ""
spectreS.pdistoOpts skipstart string ""
spectreS.pdistoOpts skipstop string ""
spectreS.pdistoOpts skipcount string ""
spectreS.pdistoOpts strobeperiod string ""
spectreS.pdistoOpts strobedelay string ""
spectreS.pdistoOpts compression string ""
spectreS.pdistoOpts freqaxis string ""
spectreS.pdistoOpts maxiters string ""
spectreS.pdistoOpts restart string ""
spectreS.pdistoOpts tstart string ""
;spectreS spac partition variables
spectreS.spac enable toggle (nil)
spectreS.spac fund string ""
spectreS.spac Relative boolean nil
spectreS.spac sweeptype string ""
spectreS.spac harmonics string "Zero sideband only"
spectreS.spac numharmonics string ""
spectreS.spac arrayharmonics string ""
spectreS.spac selFreqFrom string ""
spectreS.spac selFreqTo string ""
spectreS.spac harmsAndFreqsTitle string ""
spectreS.spac harmsAndFreqs string ""
;spectreS spacOpts partition variables
spectreS.spacOpts tolerance string ""
spectreS.spacOpts gearorder string ""
spectreS.spacOpts solver string ""
spectreS.spacOpts stats2 string ""
spectreS.spacOpts annotate2 string "status"
spectreS.spacOpts freqaxis string ""
;spectreS spnoise partition variables
spectreS.spnoise enable toggle (nil)
spectreS.spnoise fund string ""
spectreS.spnoise Relative boolean nil
spectreS.spnoise sweeptype string ""
spectreS.spnoise harmonics string "Zero sideband only"
spectreS.spnoise numharmonics string ""
spectreS.spnoise arrayharmonics string ""
spectreS.spnoise selFreqFrom string ""
spectreS.spnoise selFreqTo string ""
spectreS.spnoise harmsAndFreqsTitle string ""
spectreS.spnoise harmsAndFreqs string ""
spectreS.spnoise outType string "voltage"
spectreS.spnoise negNode string "/gnd!"
spectreS.spnoise posNode string ""
spectreS.spnoise outVsrc string ""
spectreS.spnoise inNoiseType string "none"
spectreS.spnoise inVsrc string ""
spectreS.spnoise inIsrc string ""
spectreS.spnoise inPort string ""
spectreS.spnoise refsideband string ""
;spectreS spnoiseOpts partition variables
spectreS.spnoiseOpts tolerance3 string ""
spectreS.spnoiseOpts gearorder3 string ""
spectreS.spnoiseOpts solver3 string ""
spectreS.spnoiseOpts stats4 string ""
spectreS.spnoiseOpts annotate4 string "status"
;spectreS spxf partition variables
spectreS.spxf enable toggle (nil)
spectreS.spxf fund string ""
spectreS.spxf Relative boolean nil
spectreS.spxf sweeptype string ""
spectreS.spxf harmonics string "Zero sideband only"
spectreS.spxf numharmonics string ""
spectreS.spxf arrayharmonics string ""
spectreS.spxf selFreqFrom string ""
spectreS.spxf selFreqTo string ""
spectreS.spxf harmsAndFreqsTitle string ""
spectreS.spxf harmsAndFreqs string ""
spectreS.spxf outType string "voltage"
spectreS.spxf negNode string "/gnd!"
spectreS.spxf posNode string ""
spectreS.spxf outVsrc string ""
;spectreS spxfOpts partition variables
spectreS.spxfOpts tolerance2 string ""
spectreS.spxfOpts gearorder2 string ""
spectreS.spxfOpts solver2 string ""
spectreS.spxfOpts stats3 string ""
spectreS.spxfOpts annotate3 string "status"
spectreS.spxfOpts stimuli string ""
spectreS.spxfOpts freqaxis2 string ""
;spectreS pac partition variables
spectreS.pac enable toggle (nil)
spectreS.pac fund string ""
spectreS.pac Relative boolean nil
spectreS.pac sweeptype string ""
spectreS.pac rangeType string "Start-Stop"
spectreS.pac from string ""
spectreS.pac to string ""
spectreS.pac center string ""
spectreS.pac span string ""
spectreS.pac incrType string "Automatic"
spectreS.pac stepTypeLin string "Step Size"
spectreS.pac stepTypeLog string "Points Per Decade"
spectreS.pac by string ""
spectreS.pac lin string ""
spectreS.pac dec string ""
spectreS.pac log string ""
spectreS.pac useDiscrete boolean nil
spectreS.pac values string ""
spectreS.pac harmonics string "Zero sideband only"
spectreS.pac numharmonics string ""
spectreS.pac arrayharmonics string ""
spectreS.pac selFreqFrom string ""
spectreS.pac selFreqTo string ""
spectreS.pac harmsAndFreqsTitle string ""
spectreS.pac harmsAndFreqs string ""
;spectreS pacOpts partition variables
spectreS.pacOpts tolerance string ""
spectreS.pacOpts gearorder string ""
spectreS.pacOpts solver string ""
spectreS.pacOpts stats2 string ""
spectreS.pacOpts annotate2 string "status"
spectreS.pacOpts freqaxis string ""
;spectreS pnoise partition variables
spectreS.pnoise enable toggle (nil)
spectreS.pnoise fund string ""
spectreS.pnoise Relative boolean nil
spectreS.pnoise sweeptype string ""
spectreS.pnoise rangeType string "Start-Stop"
spectreS.pnoise from string ""
spectreS.pnoise to string ""
spectreS.pnoise center string ""
spectreS.pnoise span string ""
spectreS.pnoise incrType string "Automatic"
spectreS.pnoise stepTypeLin string "Step Size"
spectreS.pnoise stepTypeLog string "Points Per Decade"
spectreS.pnoise by string ""
spectreS.pnoise lin string ""
spectreS.pnoise dec string ""
spectreS.pnoise log string ""
spectreS.pnoise useDiscrete boolean nil
spectreS.pnoise values string ""
spectreS.pnoise harmonics string "Zero sideband only"
spectreS.pnoise numharmonics string ""
spectreS.pnoise arrayharmonics string ""
spectreS.pnoise selFreqFrom string ""
spectreS.pnoise selFreqTo string ""
spectreS.pnoise harmsAndFreqsTitle string ""
spectreS.pnoise harmsAndFreqs string ""
spectreS.pnoise outType string "voltage"
spectreS.pnoise negNode string "/gnd!"
spectreS.pnoise posNode string ""
spectreS.pnoise outVsrc string ""
spectreS.pnoise inNoiseType string "none"
spectreS.pnoise inVsrc string ""
spectreS.pnoise inIsrc string ""
spectreS.pnoise inPort string ""
spectreS.pnoise refsideband string ""
;spectreS pnoiseOpts partition variables
spectreS.pnoiseOpts tolerance3 string ""
spectreS.pnoiseOpts gearorder3 string ""
spectreS.pnoiseOpts solver3 string ""
spectreS.pnoiseOpts stats4 string ""
spectreS.pnoiseOpts annotate4 string "status"
;spectreS pxf partition variables
spectreS.pxf enable toggle (nil)
spectreS.pxf fund string ""
spectreS.pxf Relative boolean nil
spectreS.pxf sweeptype string ""
spectreS.pxf rangeType string "Start-Stop"
spectreS.pxf from string ""
spectreS.pxf to string ""
spectreS.pxf center string ""
spectreS.pxf span string ""
spectreS.pxf incrType string "Automatic"
spectreS.pxf stepTypeLin string "Step Size"
spectreS.pxf stepTypeLog string "Points Per Decade"
spectreS.pxf by string ""
spectreS.pxf lin string ""
spectreS.pxf dec string ""
spectreS.pxf log string ""
spectreS.pxf useDiscrete boolean nil
spectreS.pxf values string ""
spectreS.pxf harmonics string "Zero sideband only"
spectreS.pxf numharmonics string ""
spectreS.pxf arrayharmonics string ""
spectreS.pxf selFreqFrom string ""
spectreS.pxf selFreqTo string ""
spectreS.pxf harmsAndFreqsTitle string ""
spectreS.pxf harmsAndFreqs string ""
spectreS.pxf outType string "voltage"
spectreS.pxf negNode string "/gnd!"
spectreS.pxf posNode string ""
spectreS.pxf outVsrc string ""
;spectreS pxfOpts partition variables
spectreS.pxfOpts tolerance2 string ""
spectreS.pxfOpts gearorder2 string ""
spectreS.pxfOpts solver2 string ""
spectreS.pxfOpts stats3 string ""
spectreS.pxfOpts annotate3 string "status"
spectreS.pxfOpts stimuli string ""
spectreS.pxfOpts freqaxis2 string ""
;spectreSVerilog environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spectreSVerilog opts partition variables
spectreSVerilog.opts title string ""
spectreSVerilog.opts audit string ""
spectreSVerilog.opts ckptclock string "1800"
spectreSVerilog.opts flow string ""
spectreSVerilog.opts cols string "80"
spectreSVerilog.opts opptcheck string ""
spectreSVerilog.opts reltol string "1e-3"
spectreSVerilog.opts notation string ""
spectreSVerilog.opts warn string ""
spectreSVerilog.opts approx string ""
spectreSVerilog.opts info string ""
spectreSVerilog.opts quantities string ""
spectreSVerilog.opts pivabs string ""
spectreSVerilog.opts compatible string ""
spectreSVerilog.opts ignshorts string ""
spectreSVerilog.opts gmin string "1e-12"
spectreSVerilog.opts rforce string "1"
spectreSVerilog.opts homotopy string ""
spectreSVerilog.opts iabstol string "1e-12"
spectreSVerilog.opts debug string ""
spectreSVerilog.opts tempeffects string ""
spectreSVerilog.opts maxwarns string "5"
spectreSVerilog.opts vabstol string "1e-6"
spectreSVerilog.opts tnom string "27"
spectreSVerilog.opts temp string "27"
spectreSVerilog.opts gmin_check string ""
spectreSVerilog.opts value string ""
spectreSVerilog.opts narrate string ""
spectreSVerilog.opts scale string "1.0"
spectreSVerilog.opts diagnose string ""
spectreSVerilog.opts digits string "5"
spectreSVerilog.opts pivotdc string ""
spectreSVerilog.opts pivrel string "1e-3"
spectreSVerilog.opts scalem string "1.0"
spectreSVerilog.opts limit string ""
spectreSVerilog.opts topcheck string ""
spectreSVerilog.opts inventory string ""
spectreSVerilog.opts error string ""
;spectreSVerilog outputs partition variables
spectreSVerilog.outputs allAnalogACTC boolean nil
spectreSVerilog.outputs allDigitalNV boolean t
spectreSVerilog.outputs allAnalogNV boolean t
spectreSVerilog.outputs allAhdlVars boolean nil
spectreSVerilog.outputs allAnalogTC boolean nil
;spectreSVerilog verimixOpts partition variables
spectreSVerilog.verimixOpts filename6 string ""
spectreSVerilog.verimixOpts maxDCIter int 0
spectreSVerilog.verimixOpts scope1 string ""
spectreSVerilog.verimixOpts scope10 string ""
spectreSVerilog.verimixOpts filename8 string ""
spectreSVerilog.verimixOpts dcInterval float 0.0
spectreSVerilog.verimixOpts scope3 string ""
spectreSVerilog.verimixOpts scope8 string ""
spectreSVerilog.verimixOpts scope7 string ""
spectreSVerilog.verimixOpts filename7 string ""
spectreSVerilog.verimixOpts scope string ""
spectreSVerilog.verimixOpts filename4 string ""
spectreSVerilog.verimixOpts filename string ""
spectreSVerilog.verimixOpts filename1 string ""
spectreSVerilog.verimixOpts scope9 string ""
spectreSVerilog.verimixOpts importsdfswitch boolean nil
spectreSVerilog.verimixOpts filename2 string ""
spectreSVerilog.verimixOpts numberofsdffiles int 2
spectreSVerilog.verimixOpts scope2 string ""
spectreSVerilog.verimixOpts scope6 string ""
spectreSVerilog.verimixOpts filename10 string ""
spectreSVerilog.verimixOpts delaymodechoice string "Ignore"
spectreSVerilog.verimixOpts sdfmixedswitch boolean t
spectreSVerilog.verimixOpts filename9 string ""
spectreSVerilog.verimixOpts scope5 string ""
spectreSVerilog.verimixOpts filename5 string ""
spectreSVerilog.verimixOpts filename3 string ""
spectreSVerilog.verimixOpts scope4 string ""
;spectreSVerilog verilogOpts partition variables
spectreSVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
spectreSVerilog.verilogOpts optionsFile string ""
spectreSVerilog.verilogOpts twinTurbo boolean nil
spectreSVerilog.verilogOpts suppressMessages boolean nil
spectreSVerilog.verilogOpts libraryFile string ""
spectreSVerilog.verilogOpts behaveProfile boolean nil
spectreSVerilog.verilogOpts verimixLog string "verilog.log"
spectreSVerilog.verilogOpts simVision boolean nil
spectreSVerilog.verilogOpts pulseSpec boolean nil
spectreSVerilog.verilogOpts commandFile string ""
spectreSVerilog.verilogOpts pulseError int 100
spectreSVerilog.verilogOpts stopCompile boolean nil
spectreSVerilog.verilogOpts keepNodes string "Minimum"
spectreSVerilog.verilogOpts accelerationCA boolean nil
spectreSVerilog.verilogOpts turboRadio string "Default"
spectreSVerilog.verilogOpts libraryDir string ""
spectreSVerilog.verilogOpts suppressWarnings boolean nil
spectreSVerilog.verilogOpts accelerationSwitches boolean nil
spectreSVerilog.verilogOpts accelerationNormal boolean t
spectreSVerilog.verilogOpts delayType string "Typical"
spectreSVerilog.verilogOpts pulseReject int 100
spectreSVerilog.verilogOpts delayMode string "Default"
spectreSVerilog.verilogOpts vermixBinary string "verilog.vmx"
;spectreSVerilog init partition variables
spectreSVerilog.init processPriority int 0
;spectreSVerilog envOpts partition variables
spectreSVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreSVerilog.envOpts mspNetlistMode string "Flat"
spectreSVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
spectreSVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
spectreSVerilog.envOpts outputFormat string "AWD"
spectreSVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
spectreSVerilog.envOpts mspSetupNetlistEscapeName boolean nil
spectreSVerilog.envOpts updateFile string ""
spectreSVerilog.envOpts stimulusFile string ""
spectreSVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
spectreSVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
spectreSVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
spectreSVerilog.envOpts includeSyntax string "cdsSpice"
spectreSVerilog.envOpts mspSetupNetlistPinMap boolean nil
spectreSVerilog.envOpts mspSetupNetlistBus boolean t
spectreSVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
spectreSVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
spectreSVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
spectreSVerilog.envOpts mspSetupNetlistExplicit boolean nil
spectreSVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
spectreSVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
spectreSVerilog.envOpts paramRangeCheckFile string ""
spectreSVerilog.envOpts initFile string ""
spectreSVerilog.envOpts printComments boolean nil
spectreSVerilog.envOpts includeFile string ""
spectreSVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
spectreSVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
spectreSVerilog.envOpts recover boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreSVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimTimeValue int 1
spectreSVerilog.envOpts mspSetupNetlistUseLib boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
spectreSVerilog.envOpts mspSetupNetlistNullPort boolean nil
spectreSVerilog.envOpts mspSetupNetlistDropPortRange boolean t
spectreSVerilog.envOpts mspSetupNetlistUpCase boolean nil
spectreSVerilog.envOpts generateMapFile boolean nil
spectreSVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;spectreSVerilog tran partition variables
spectreSVerilog.tran enable toggle (nil)
spectreSVerilog.tran to string ""
spectreSVerilog.tran errpreset string ""
;spectreSVerilog tranOpts partition variables
spectreSVerilog.tranOpts start string ""
spectreSVerilog.tranOpts outputstart string ""
spectreSVerilog.tranOpts step string ""
spectreSVerilog.tranOpts maxstep string ""
spectreSVerilog.tranOpts ic string ""
spectreSVerilog.tranOpts skipdc string ""
spectreSVerilog.tranOpts readic string ""
spectreSVerilog.tranOpts readns string ""
spectreSVerilog.tranOpts cmin string ""
spectreSVerilog.tranOpts write string "spectre.ic"
spectreSVerilog.tranOpts writefinal string "spectre.fc"
spectreSVerilog.tranOpts ckptperiod string ""
spectreSVerilog.tranOpts method string "default"
spectreSVerilog.tranOpts relref string "default"
spectreSVerilog.tranOpts lteratio string ""
spectreSVerilog.tranOpts stats string ""
spectreSVerilog.tranOpts annotate string "status"
spectreSVerilog.tranOpts oppoint string ""
spectreSVerilog.tranOpts skipstart string ""
spectreSVerilog.tranOpts skipstop string ""
spectreSVerilog.tranOpts skipcount string ""
spectreSVerilog.tranOpts strobeperiod string ""
spectreSVerilog.tranOpts strobedelay string ""
spectreSVerilog.tranOpts compression string "no"
spectreSVerilog.tranOpts maxiters string "5"
spectreSVerilog.tranOpts restart string ""
;spectreSVerilog ac partition variables
spectreSVerilog.ac enable toggle (nil)
spectreSVerilog.ac sweep string "Frequency"
spectreSVerilog.ac freq string ""
spectreSVerilog.ac device string ""
spectreSVerilog.ac deviceParam string ""
spectreSVerilog.ac model string ""
spectreSVerilog.ac modelParam string ""
spectreSVerilog.ac temperature string "temp"
spectreSVerilog.ac rangeType string "Start-Stop"
spectreSVerilog.ac from string ""
spectreSVerilog.ac to string ""
spectreSVerilog.ac center string ""
spectreSVerilog.ac span string ""
spectreSVerilog.ac incrType string "Automatic"
spectreSVerilog.ac stepTypeLin string "Step Size"
spectreSVerilog.ac stepTypeLog string "Points Per Decade"
spectreSVerilog.ac by string ""
spectreSVerilog.ac lin string ""
spectreSVerilog.ac dec string ""
spectreSVerilog.ac log string ""
spectreSVerilog.ac useDiscrete boolean nil
spectreSVerilog.ac values string ""
;spectreSVerilog acOpts partition variables
spectreSVerilog.acOpts readns string ""
spectreSVerilog.acOpts oppoint string ""
spectreSVerilog.acOpts restart string ""
spectreSVerilog.acOpts annotate string "status"
spectreSVerilog.acOpts stats string ""
;spectreSVerilog dc partition variables
spectreSVerilog.dc enable toggle (nil)
spectreSVerilog.dcop enable toggle (nil)
spectreSVerilog.dc saveOppoint boolean nil
spectreSVerilog.dc oppoint string "rawfile"
spectreSVerilog.dc save string "allpub"
spectreSVerilog.dc sweep string ""
spectreSVerilog.dc device string ""
spectreSVerilog.dc deviceParam string ""
spectreSVerilog.dc model string ""
spectreSVerilog.dc modelParam string ""
spectreSVerilog.dc temperature string "temp"
spectreSVerilog.dc rangeType string "Start-Stop"
spectreSVerilog.dc from string ""
spectreSVerilog.dc to string ""
spectreSVerilog.dc center string ""
spectreSVerilog.dc span string ""
spectreSVerilog.dc incrType string "Automatic"
spectreSVerilog.dc stepTypeLin string "Step Size"
spectreSVerilog.dc stepTypeLog string "Points Per Decade"
spectreSVerilog.dc by string ""
spectreSVerilog.dc lin string ""
spectreSVerilog.dc dec string ""
spectreSVerilog.dc log string ""
spectreSVerilog.dc useDiscrete boolean nil
spectreSVerilog.dc values string ""
;spectreSVerilog dcOpts partition variables
spectreSVerilog.dcOpts force string ""
spectreSVerilog.dcopOpts force string ""
spectreSVerilog.dcOpts readns string ""
spectreSVerilog.dcopOpts readns string ""
spectreSVerilog.dcOpts readforce string ""
spectreSVerilog.dcopOpts readforce string ""
spectreSVerilog.dcOpts write string "spectre.dc"
spectreSVerilog.dcopOpts write string "spectre.dc"
spectreSVerilog.dcOpts writefinal string ""
spectreSVerilog.dcopOpts writefinal string ""
spectreSVerilog.dcOpts print string ""
spectreSVerilog.dcopOpts print string ""
spectreSVerilog.dcOpts check string ""
spectreSVerilog.dcopOpts check string ""
spectreSVerilog.dcOpts homotopy string ""
spectreSVerilog.dcopOpts homotopy string ""
spectreSVerilog.dcOpts restart string ""
spectreSVerilog.dcopOpts restart string ""
spectreSVerilog.dcOpts maxiters string "150"
spectreSVerilog.dcopOpts maxiters string "150"
spectreSVerilog.dcOpts maxsteps string "10000"
spectreSVerilog.dcopOpts maxsteps string "10000"
spectreSVerilog.dcOpts annotate string "status"
spectreSVerilog.dcopOpts annotate string "status"
;spectreSVerilog noise partition variables
spectreSVerilog.noise enable toggle (nil)
spectreSVerilog.noise sweep string "Frequency"
spectreSVerilog.noise freq string ""
spectreSVerilog.noise device string ""
spectreSVerilog.noise deviceParam string ""
spectreSVerilog.noise model string ""
spectreSVerilog.noise modelParam string ""
spectreSVerilog.noise temperature string "temp"
spectreSVerilog.noise rangeType string "Start-Stop"
spectreSVerilog.noise from string ""
spectreSVerilog.noise to string ""
spectreSVerilog.noise center string ""
spectreSVerilog.noise span string ""
spectreSVerilog.noise incrType string "Automatic"
spectreSVerilog.noise stepTypeLin string "Step Size"
spectreSVerilog.noise stepTypeLog string "Points Per Decade"
spectreSVerilog.noise by string ""
spectreSVerilog.noise lin string ""
spectreSVerilog.noise dec string ""
spectreSVerilog.noise log string ""
spectreSVerilog.noise useDiscrete boolean nil
spectreSVerilog.noise values string ""
spectreSVerilog.noise outNoiseType string "voltage"
spectreSVerilog.noise negNode string "/gnd!"
spectreSVerilog.noise posNode string ""
spectreSVerilog.noise outVsrc string ""
spectreSVerilog.noise inNoiseType string "voltage"
spectreSVerilog.noise inVsrc string ""
spectreSVerilog.noise inIsrc string ""
spectreSVerilog.noise inPort string ""
;spectreSVerilog noiseOpts partition variables
spectreSVerilog.noiseOpts readns string ""
spectreSVerilog.noiseOpts oppoint string ""
spectreSVerilog.noiseOpts restart string ""
spectreSVerilog.noiseOpts annotate string "status"
spectreSVerilog.noiseOpts stats string ""
;spectreSVerilog xf partition variables
spectreSVerilog.xf enable toggle (nil)
spectreSVerilog.xf sweep string "Frequency"
spectreSVerilog.xf freq string ""
spectreSVerilog.xf device string ""
spectreSVerilog.xf deviceParam string ""
spectreSVerilog.xf model string ""
spectreSVerilog.xf modelParam string ""
spectreSVerilog.xf temperature string "temp"
spectreSVerilog.xf rangeType string "Start-Stop"
spectreSVerilog.xf from string ""
spectreSVerilog.xf to string ""
spectreSVerilog.xf center string ""
spectreSVerilog.xf span string ""
spectreSVerilog.xf incrType string "Automatic"
spectreSVerilog.xf stepTypeLin string "Step Size"
spectreSVerilog.xf stepTypeLog string "Points Per Decade"
spectreSVerilog.xf by string ""
spectreSVerilog.xf lin string ""
spectreSVerilog.xf dec string ""
spectreSVerilog.xf log string ""
spectreSVerilog.xf useDiscrete boolean nil
spectreSVerilog.xf values string ""
spectreSVerilog.xf outXfType string "voltage"
spectreSVerilog.xf negNode string "/gnd!"
spectreSVerilog.xf posNode string ""
spectreSVerilog.xf outVsrc string ""
;spectreSVerilog xfOpts partition variables
spectreSVerilog.xfOpts readns string ""
spectreSVerilog.xfOpts stimuli string ""
spectreSVerilog.xfOpts oppoint string ""
spectreSVerilog.xfOpts restart string ""
spectreSVerilog.xfOpts annotate string "status"
spectreSVerilog.xfOpts stats string ""
;spectreSVerilog sp partition variables
spectreSVerilog.sp enable toggle (nil)
spectreSVerilog.sp sweep string "Frequency"
spectreSVerilog.sp frequency string ""
spectreSVerilog.sp device string ""
spectreSVerilog.sp deviceParam string ""
spectreSVerilog.sp model string ""
spectreSVerilog.sp modelParam string ""
spectreSVerilog.sp temperature string "temp"
spectreSVerilog.sp rangeType string "Start-Stop"
spectreSVerilog.sp from string ""
spectreSVerilog.sp to string ""
spectreSVerilog.sp center string ""
spectreSVerilog.sp span string ""
spectreSVerilog.sp incrType string "Automatic"
spectreSVerilog.sp stepTypeLin string "Step Size"
spectreSVerilog.sp stepTypeLog string "Points Per Decade"
spectreSVerilog.sp by string ""
spectreSVerilog.sp lin string ""
spectreSVerilog.sp dec string ""
spectreSVerilog.sp log string ""
spectreSVerilog.sp useDiscrete boolean nil
spectreSVerilog.sp values string ""
spectreSVerilog.sp donoise boolean nil
spectreSVerilog.sp oprobe string ""
spectreSVerilog.sp iprobe string ""
;spectreSVerilog spOpts partition variables
spectreSVerilog.spOpts readns string ""
spectreSVerilog.spOpts file string ""
spectreSVerilog.spOpts oppoint string ""
spectreSVerilog.spOpts reftemp string ""
spectreSVerilog.spOpts restart string ""
spectreSVerilog.spOpts annotate string "status"
spectreSVerilog.spOpts stats string ""
;spectreSVerilog spss partition variables
spectreSVerilog.spss enable toggle (nil)
spectreSVerilog.spss paramListBox string ""
spectreSVerilog.spss fundListBox string ""
spectreSVerilog.spss stimName string ""
spectreSVerilog.spss freqName string ""
spectreSVerilog.spss freqVal string ""
spectreSVerilog.spss signalLevel string "Moderate"
spectreSVerilog.spss srcId string ""
spectreSVerilog.spss maxHarms string ""
spectreSVerilog.spss freqPeriod string "Fundamental (Beat) Frequency"
spectreSVerilog.spss fund string ""
spectreSVerilog.spss period string ""
spectreSVerilog.spss harmonics string "None"
spectreSVerilog.spss numharmonics string ""
spectreSVerilog.spss arrayharmonics string ""
spectreSVerilog.spss none string "0"
spectreSVerilog.spss selFreqFrom string ""
spectreSVerilog.spss selFreqTo string ""
spectreSVerilog.spss harmsAndFreqsTitle string ""
spectreSVerilog.spss harmsAndFreqs string ""
spectreSVerilog.spss errpreset string ""
spectreSVerilog.spss tstab string ""
spectreSVerilog.spss saveinit string ""
spectreSVerilog.spss oscana boolean nil
spectreSVerilog.spss oscRefNode string "/gnd!"
spectreSVerilog.spss oscNode string ""
spectreSVerilog.spss sweep string "frequency/period"
spectreSVerilog.spss designVar string ""
spectreSVerilog.spss rangeType string "Start-Stop"
spectreSVerilog.spss from string ""
spectreSVerilog.spss to string ""
spectreSVerilog.spss center string ""
spectreSVerilog.spss span string ""
spectreSVerilog.spss incrType string "Linear"
spectreSVerilog.spss stepTypeLin string "Step Size"
spectreSVerilog.spss stepTypeLog string "Points Per Decade"
spectreSVerilog.spss by string ""
spectreSVerilog.spss lin string ""
spectreSVerilog.spss dec string ""
spectreSVerilog.spss log string ""
spectreSVerilog.spss useDiscrete boolean nil
spectreSVerilog.spss values string ""
spectreSVerilog.spss analysisList string ""
spectreSVerilog.spss pacEnable boolean nil
spectreSVerilog.spss pacfund string ""
spectreSVerilog.spss pacRelative boolean nil
spectreSVerilog.spss pacsweeptype string ""
spectreSVerilog.spss pacharmonics string "Zero sideband only"
spectreSVerilog.spss pacnumharmonics string ""
spectreSVerilog.spss pacarrayharmonics string ""
spectreSVerilog.spss pacselFreqFrom string ""
spectreSVerilog.spss pacselFreqTo string ""
spectreSVerilog.spss pacharmsAndFreqsTitle string ""
spectreSVerilog.spss pacharmsAndFreqs string ""
spectreSVerilog.spss pnoiseEnable boolean nil
spectreSVerilog.spss pnoisefund string ""
spectreSVerilog.spss pnoiseRelative boolean nil
spectreSVerilog.spss pnoisesweeptype string ""
spectreSVerilog.spss pnoiseharmonics string "Zero sideband only"
spectreSVerilog.spss pnoisenumharmonics string ""
spectreSVerilog.spss pnoisearrayharmonics string ""
spectreSVerilog.spss pnoiseselFreqFrom string ""
spectreSVerilog.spss pnoiseselFreqTo string ""
spectreSVerilog.spss pnoiseharmsAndFreqsTitle string ""
spectreSVerilog.spss pnoiseharmsAndFreqs string ""
spectreSVerilog.spss pnoiseoutProbeType string "voltage"
spectreSVerilog.spss pnoisenegNode string "/gnd!"
spectreSVerilog.spss pnoiseposNode string ""
spectreSVerilog.spss pnoiseoutVsrc string ""
spectreSVerilog.spss pnoiseinNoiseType string "none"
spectreSVerilog.spss pnoiseinVsrc string ""
spectreSVerilog.spss pnoiseinIsrc string ""
spectreSVerilog.spss pnoiseinPort string ""
spectreSVerilog.spss pnoiserefsideband string ""
spectreSVerilog.spss pxfEnable boolean nil
spectreSVerilog.spss pxffund string ""
spectreSVerilog.spss pxfRelative boolean nil
spectreSVerilog.spss pxfsweeptype string ""
spectreSVerilog.spss pxfharmonics string "Zero sideband only"
spectreSVerilog.spss pxfnumharmonics string ""
spectreSVerilog.spss pxfarrayharmonics string ""
spectreSVerilog.spss pxfselFreqFrom string ""
spectreSVerilog.spss pxfselFreqTo string ""
spectreSVerilog.spss pxfharmsAndFreqsTitle string ""
spectreSVerilog.spss pxfharmsAndFreqs string ""
spectreSVerilog.spss pxfoutProbeType string "voltage"
spectreSVerilog.spss pxfnegNode string "/gnd!"
spectreSVerilog.spss pxfposNode string ""
spectreSVerilog.spss pxfoutVsrc string ""
;spectreSVerilog spssOpts partition variables
spectreSVerilog.spssOpts step string ""
spectreSVerilog.spssOpts maxstep string ""
spectreSVerilog.spssOpts ic string ""
spectreSVerilog.spssOpts skipdc string ""
spectreSVerilog.spssOpts readic string ""
spectreSVerilog.spssOpts readns string ""
spectreSVerilog.spssOpts cmin string ""
spectreSVerilog.spssOpts write string ""
spectreSVerilog.spssOpts writefinal string ""
spectreSVerilog.spssOpts swapfile string ""
spectreSVerilog.spssOpts method string ""
spectreSVerilog.spssOpts relref string ""
spectreSVerilog.spssOpts lteratio string ""
spectreSVerilog.spssOpts steadyratio string ""
spectreSVerilog.spssOpts maxacfreq string ""
spectreSVerilog.spssOpts maxperiods string ""
spectreSVerilog.spssOpts stats string ""
spectreSVerilog.spssOpts annotate string "status"
spectreSVerilog.spssOpts oppoint string ""
spectreSVerilog.spssOpts skipstart string ""
spectreSVerilog.spssOpts skipstop string ""
spectreSVerilog.spssOpts skipcount string ""
spectreSVerilog.spssOpts strobeperiod string ""
spectreSVerilog.spssOpts strobedelay string ""
spectreSVerilog.spssOpts compression string ""
spectreSVerilog.spssOpts maxiters string ""
spectreSVerilog.spssOpts restart string ""
spectreSVerilog.spssOpts tstart string ""
spectreSVerilog.spssOpts tolerance string ""
spectreSVerilog.spssOpts gearorder string ""
spectreSVerilog.spssOpts solver string ""
spectreSVerilog.spssOpts stats2 string ""
spectreSVerilog.spssOpts annotate2 string "status"
spectreSVerilog.spssOpts freqaxis string ""
spectreSVerilog.spssOpts tolerance2 string ""
spectreSVerilog.spssOpts gearorder2 string ""
spectreSVerilog.spssOpts solver2 string ""
spectreSVerilog.spssOpts stats3 string ""
spectreSVerilog.spssOpts annotate3 string "status"
spectreSVerilog.spssOpts stimuli string ""
spectreSVerilog.spssOpts freqaxis2 string ""
spectreSVerilog.spssOpts tolerance3 string ""
spectreSVerilog.spssOpts gearorder3 string ""
spectreSVerilog.spssOpts solver3 string ""
spectreSVerilog.spssOpts stats4 string ""
spectreSVerilog.spssOpts annotate4 string "status"
;spectreSVerilog pss partition variables
spectreSVerilog.pss enable toggle (nil)
spectreSVerilog.pss paramListBox string ""
spectreSVerilog.pss fundListBox string ""
spectreSVerilog.pss stimName string ""
spectreSVerilog.pss freqName string ""
spectreSVerilog.pss freqVal string ""
spectreSVerilog.pss signalLevel string "Moderate"
spectreSVerilog.pss srcId string ""
spectreSVerilog.pss maxHarms string ""
spectreSVerilog.pss freqPeriod string "Fundamental (Beat) Frequency"
spectreSVerilog.pss fund string ""
spectreSVerilog.pss period string ""
spectreSVerilog.pss harmonics string "None"
spectreSVerilog.pss numharmonics string ""
spectreSVerilog.pss arrayharmonics string ""
spectreSVerilog.pss none string "0"
spectreSVerilog.pss selFreqFrom string ""
spectreSVerilog.pss selFreqTo string ""
spectreSVerilog.pss harmsAndFreqsTitle string ""
spectreSVerilog.pss harmsAndFreqs string ""
spectreSVerilog.pss errpreset string ""
spectreSVerilog.pss tstab string ""
spectreSVerilog.pss saveinit string ""
spectreSVerilog.pss oscana boolean nil
spectreSVerilog.pss oscRefNode string "/gnd!"
spectreSVerilog.pss oscNode string ""
spectreSVerilog.pss analysisList string ""
spectreSVerilog.pss pacEnable boolean nil
spectreSVerilog.pss pacRelative boolean nil
spectreSVerilog.pss pacsweeptype string ""
spectreSVerilog.pss pacrangeType string "Start-Stop"
spectreSVerilog.pss pacfrom string ""
spectreSVerilog.pss pacto string ""
spectreSVerilog.pss paccenter string ""
spectreSVerilog.pss pacspan string ""
spectreSVerilog.pss pacincrType string "Automatic"
spectreSVerilog.pss pacstepTypeLin string "Step Size"
spectreSVerilog.pss pacstepTypeLog string "Points Per Decade"
spectreSVerilog.pss pacby string ""
spectreSVerilog.pss paclin string ""
spectreSVerilog.pss pacdec string ""
spectreSVerilog.pss paclog string ""
spectreSVerilog.pss pacuseDiscrete boolean nil
spectreSVerilog.pss pacvalues string ""
spectreSVerilog.pss pacharmonics string "Zero sideband only"
spectreSVerilog.pss pacnumharmonics string ""
spectreSVerilog.pss pacarrayharmonics string ""
spectreSVerilog.pss pacselFreqFrom string ""
spectreSVerilog.pss pacselFreqTo string ""
spectreSVerilog.pss pacharmsAndFreqsTitle string ""
spectreSVerilog.pss pacharmsAndFreqs string ""
spectreSVerilog.pss pnoiseEnable boolean nil
spectreSVerilog.pss pnoiseRelative boolean nil
spectreSVerilog.pss pnoisesweeptype string ""
spectreSVerilog.pss pnoiserangeType string "Start-Stop"
spectreSVerilog.pss pnoisefrom string ""
spectreSVerilog.pss pnoiseto string ""
spectreSVerilog.pss pnoisecenter string ""
spectreSVerilog.pss pnoisespan string ""
spectreSVerilog.pss pnoiseincrType string "Automatic"
spectreSVerilog.pss pnoisestepTypeLin string "Step Size"
spectreSVerilog.pss pnoisestepTypeLog string "Points Per Decade"
spectreSVerilog.pss pnoiseby string ""
spectreSVerilog.pss pnoiselin string ""
spectreSVerilog.pss pnoisedec string ""
spectreSVerilog.pss pnoiselog string ""
spectreSVerilog.pss pnoiseuseDiscrete boolean nil
spectreSVerilog.pss pnoisevalues string ""
spectreSVerilog.pss pnoiseharmonics string "Zero sideband only"
spectreSVerilog.pss pnoisenumharmonics string ""
spectreSVerilog.pss pnoisearrayharmonics string ""
spectreSVerilog.pss pnoiseselFreqFrom string ""
spectreSVerilog.pss pnoiseselFreqTo string ""
spectreSVerilog.pss pnoiseharmsAndFreqsTitle string ""
spectreSVerilog.pss pnoiseharmsAndFreqs string ""
spectreSVerilog.pss pnoiseoutProbeType string "voltage"
spectreSVerilog.pss pnoisenegNode string "/gnd!"
spectreSVerilog.pss pnoiseposNode string ""
spectreSVerilog.pss pnoiseoutVsrc string ""
spectreSVerilog.pss pnoiseinNoiseType string "none"
spectreSVerilog.pss pnoiseinVsrc string ""
spectreSVerilog.pss pnoiseinIsrc string ""
spectreSVerilog.pss pnoiseinPort string ""
spectreSVerilog.pss pnoiserefsideband string ""
spectreSVerilog.pss pxfEnable boolean nil
spectreSVerilog.pss pxfRelative boolean nil
spectreSVerilog.pss pxfsweeptype string ""
spectreSVerilog.pss pxfrangeType string "Start-Stop"
spectreSVerilog.pss pxffrom string ""
spectreSVerilog.pss pxfto string ""
spectreSVerilog.pss pxfcenter string ""
spectreSVerilog.pss pxfspan string ""
spectreSVerilog.pss pxfincrType string "Automatic"
spectreSVerilog.pss pxfstepTypeLin string "Step Size"
spectreSVerilog.pss pxfstepTypeLog string "Points Per Decade"
spectreSVerilog.pss pxfby string ""
spectreSVerilog.pss pxflin string ""
spectreSVerilog.pss pxfdec string ""
spectreSVerilog.pss pxflog string ""
spectreSVerilog.pss pxfuseDiscrete boolean nil
spectreSVerilog.pss pxfvalues string ""
spectreSVerilog.pss pxfharmonics string "Zero sideband only"
spectreSVerilog.pss pxfnumharmonics string ""
spectreSVerilog.pss pxfarrayharmonics string ""
spectreSVerilog.pss pxfselFreqFrom string ""
spectreSVerilog.pss pxfselFreqTo string ""
spectreSVerilog.pss pxfharmsAndFreqsTitle string ""
spectreSVerilog.pss pxfharmsAndFreqs string ""
spectreSVerilog.pss pxfoutProbeType string "voltage"
spectreSVerilog.pss pxfnegNode string "/gnd!"
spectreSVerilog.pss pxfposNode string ""
spectreSVerilog.pss pxfoutVsrc string ""
;spectreSVerilog pssOpts partition variables
spectreSVerilog.pssOpts step string ""
spectreSVerilog.pssOpts maxstep string ""
spectreSVerilog.pssOpts ic string ""
spectreSVerilog.pssOpts skipdc string ""
spectreSVerilog.pssOpts readic string ""
spectreSVerilog.pssOpts readns string ""
spectreSVerilog.pssOpts cmin string ""
spectreSVerilog.pssOpts write string ""
spectreSVerilog.pssOpts writefinal string ""
spectreSVerilog.pssOpts swapfile string ""
spectreSVerilog.pssOpts method string ""
spectreSVerilog.pssOpts relref string ""
spectreSVerilog.pssOpts lteratio string ""
spectreSVerilog.pssOpts steadyratio string ""
spectreSVerilog.pssOpts maxacfreq string ""
spectreSVerilog.pssOpts maxperiods string ""
spectreSVerilog.pssOpts stats string ""
spectreSVerilog.pssOpts annotate string "status"
spectreSVerilog.pssOpts oppoint string ""
spectreSVerilog.pssOpts skipstart string ""
spectreSVerilog.pssOpts skipstop string ""
spectreSVerilog.pssOpts skipcount string ""
spectreSVerilog.pssOpts strobeperiod string ""
spectreSVerilog.pssOpts strobedelay string ""
spectreSVerilog.pssOpts compression string ""
spectreSVerilog.pssOpts maxiters string ""
spectreSVerilog.pssOpts restart string ""
spectreSVerilog.pssOpts tstart string ""
spectreSVerilog.pssOpts tolerance string ""
spectreSVerilog.pssOpts gearorder string ""
spectreSVerilog.pssOpts solver string ""
spectreSVerilog.pssOpts stats2 string ""
spectreSVerilog.pssOpts annotate2 string "status"
spectreSVerilog.pssOpts freqaxis string ""
spectreSVerilog.pssOpts tolerance2 string ""
spectreSVerilog.pssOpts gearorder2 string ""
spectreSVerilog.pssOpts solver2 string ""
spectreSVerilog.pssOpts stats3 string ""
spectreSVerilog.pssOpts annotate3 string "status"
spectreSVerilog.pssOpts stimuli string ""
spectreSVerilog.pssOpts freqaxis2 string ""
spectreSVerilog.pssOpts tolerance3 string ""
spectreSVerilog.pssOpts gearorder3 string ""
spectreSVerilog.pssOpts solver3 string ""
spectreSVerilog.pssOpts stats4 string ""
spectreSVerilog.pssOpts annotate4 string "status"
;spectreSVerilog pdisto partition variables
spectreSVerilog.pdisto enable toggle (nil)
spectreSVerilog.pdisto paramListBox string ""
spectreSVerilog.pdisto fundListBox string ""
spectreSVerilog.pdisto stimName string ""
spectreSVerilog.pdisto freqName string ""
spectreSVerilog.pdisto freqVal string ""
spectreSVerilog.pdisto signalLevel string "Moderate"
spectreSVerilog.pdisto srcId string ""
spectreSVerilog.pdisto maxHarms string ""
spectreSVerilog.pdisto fundsList string ""
spectreSVerilog.pdisto maxHarmsList string ""
spectreSVerilog.pdisto errpreset string ""
spectreSVerilog.pdisto tstab string ""
spectreSVerilog.pdisto saveinit string ""
;spectreSVerilog pdistoOpts partition variables
spectreSVerilog.pdistoOpts step string ""
spectreSVerilog.pdistoOpts maxstep string ""
spectreSVerilog.pdistoOpts ic string ""
spectreSVerilog.pdistoOpts skipdc string ""
spectreSVerilog.pdistoOpts readic string ""
spectreSVerilog.pdistoOpts readns string ""
spectreSVerilog.pdistoOpts cmin string ""
spectreSVerilog.pdistoOpts tolerance string ""
spectreSVerilog.pdistoOpts gearorder string ""
spectreSVerilog.pdistoOpts solver string ""
spectreSVerilog.pdistoOpts write string ""
spectreSVerilog.pdistoOpts writefinal string ""
spectreSVerilog.pdistoOpts swapfile string ""
spectreSVerilog.pdistoOpts method string ""
spectreSVerilog.pdistoOpts relref string ""
spectreSVerilog.pdistoOpts lteratio string ""
spectreSVerilog.pdistoOpts steadyratio string ""
spectreSVerilog.pdistoOpts maxacfreq string ""
spectreSVerilog.pdistoOpts maxperiods string ""
spectreSVerilog.pdistoOpts stats string ""
spectreSVerilog.pdistoOpts annotate string "status"
spectreSVerilog.pdistoOpts oppoint string ""
spectreSVerilog.pdistoOpts skipstart string ""
spectreSVerilog.pdistoOpts skipstop string ""
spectreSVerilog.pdistoOpts skipcount string ""
spectreSVerilog.pdistoOpts strobeperiod string ""
spectreSVerilog.pdistoOpts strobedelay string ""
spectreSVerilog.pdistoOpts compression string ""
spectreSVerilog.pdistoOpts freqaxis string ""
spectreSVerilog.pdistoOpts maxiters string ""
spectreSVerilog.pdistoOpts restart string ""
spectreSVerilog.pdistoOpts tstart string ""
;spectreSVerilog spac partition variables
spectreSVerilog.spac enable toggle (nil)
spectreSVerilog.spac fund string ""
spectreSVerilog.spac Relative boolean nil
spectreSVerilog.spac sweeptype string ""
spectreSVerilog.spac harmonics string "Zero sideband only"
spectreSVerilog.spac numharmonics string ""
spectreSVerilog.spac arrayharmonics string ""
spectreSVerilog.spac selFreqFrom string ""
spectreSVerilog.spac selFreqTo string ""
spectreSVerilog.spac harmsAndFreqsTitle string ""
spectreSVerilog.spac harmsAndFreqs string ""
;spectreSVerilog spacOpts partition variables
spectreSVerilog.spacOpts tolerance string ""
spectreSVerilog.spacOpts gearorder string ""
spectreSVerilog.spacOpts solver string ""
spectreSVerilog.spacOpts stats2 string ""
spectreSVerilog.spacOpts annotate2 string "status"
spectreSVerilog.spacOpts freqaxis string ""
;spectreSVerilog spnoise partition variables
spectreSVerilog.spnoise enable toggle (nil)
spectreSVerilog.spnoise fund string ""
spectreSVerilog.spnoise Relative boolean nil
spectreSVerilog.spnoise sweeptype string ""
spectreSVerilog.spnoise harmonics string "Zero sideband only"
spectreSVerilog.spnoise numharmonics string ""
spectreSVerilog.spnoise arrayharmonics string ""
spectreSVerilog.spnoise selFreqFrom string ""
spectreSVerilog.spnoise selFreqTo string ""
spectreSVerilog.spnoise harmsAndFreqsTitle string ""
spectreSVerilog.spnoise harmsAndFreqs string ""
spectreSVerilog.spnoise outType string "voltage"
spectreSVerilog.spnoise negNode string "/gnd!"
spectreSVerilog.spnoise posNode string ""
spectreSVerilog.spnoise outVsrc string ""
spectreSVerilog.spnoise inNoiseType string "none"
spectreSVerilog.spnoise inVsrc string ""
spectreSVerilog.spnoise inIsrc string ""
spectreSVerilog.spnoise inPort string ""
spectreSVerilog.spnoise refsideband string ""
;spectreSVerilog spnoiseOpts partition variables
spectreSVerilog.spnoiseOpts tolerance3 string ""
spectreSVerilog.spnoiseOpts gearorder3 string ""
spectreSVerilog.spnoiseOpts solver3 string ""
spectreSVerilog.spnoiseOpts stats4 string ""
spectreSVerilog.spnoiseOpts annotate4 string "status"
;spectreSVerilog spxf partition variables
spectreSVerilog.spxf enable toggle (nil)
spectreSVerilog.spxf fund string ""
spectreSVerilog.spxf Relative boolean nil
spectreSVerilog.spxf sweeptype string ""
spectreSVerilog.spxf harmonics string "Zero sideband only"
spectreSVerilog.spxf numharmonics string ""
spectreSVerilog.spxf arrayharmonics string ""
spectreSVerilog.spxf selFreqFrom string ""
spectreSVerilog.spxf selFreqTo string ""
spectreSVerilog.spxf harmsAndFreqsTitle string ""
spectreSVerilog.spxf harmsAndFreqs string ""
spectreSVerilog.spxf outType string "voltage"
spectreSVerilog.spxf negNode string "/gnd!"
spectreSVerilog.spxf posNode string ""
spectreSVerilog.spxf outVsrc string ""
;spectreSVerilog spxfOpts partition variables
spectreSVerilog.spxfOpts tolerance2 string ""
spectreSVerilog.spxfOpts gearorder2 string ""
spectreSVerilog.spxfOpts solver2 string ""
spectreSVerilog.spxfOpts stats3 string ""
spectreSVerilog.spxfOpts annotate3 string "status"
spectreSVerilog.spxfOpts stimuli string ""
spectreSVerilog.spxfOpts freqaxis2 string ""
;spectreSVerilog pac partition variables
spectreSVerilog.pac enable toggle (nil)
spectreSVerilog.pac fund string ""
spectreSVerilog.pac Relative boolean nil
spectreSVerilog.pac sweeptype string ""
spectreSVerilog.pac rangeType string "Start-Stop"
spectreSVerilog.pac from string ""
spectreSVerilog.pac to string ""
spectreSVerilog.pac center string ""
spectreSVerilog.pac span string ""
spectreSVerilog.pac incrType string "Automatic"
spectreSVerilog.pac stepTypeLin string "Step Size"
spectreSVerilog.pac stepTypeLog string "Points Per Decade"
spectreSVerilog.pac by string ""
spectreSVerilog.pac lin string ""
spectreSVerilog.pac dec string ""
spectreSVerilog.pac log string ""
spectreSVerilog.pac useDiscrete boolean nil
spectreSVerilog.pac values string ""
spectreSVerilog.pac harmonics string "Zero sideband only"
spectreSVerilog.pac numharmonics string ""
spectreSVerilog.pac arrayharmonics string ""
spectreSVerilog.pac selFreqFrom string ""
spectreSVerilog.pac selFreqTo string ""
spectreSVerilog.pac harmsAndFreqsTitle string ""
spectreSVerilog.pac harmsAndFreqs string ""
;spectreSVerilog pacOpts partition variables
spectreSVerilog.pacOpts tolerance string ""
spectreSVerilog.pacOpts gearorder string ""
spectreSVerilog.pacOpts solver string ""
spectreSVerilog.pacOpts stats2 string ""
spectreSVerilog.pacOpts annotate2 string "status"
spectreSVerilog.pacOpts freqaxis string ""
;spectreSVerilog pnoise partition variables
spectreSVerilog.pnoise enable toggle (nil)
spectreSVerilog.pnoise fund string ""
spectreSVerilog.pnoise Relative boolean nil
spectreSVerilog.pnoise sweeptype string ""
spectreSVerilog.pnoise rangeType string "Start-Stop"
spectreSVerilog.pnoise from string ""
spectreSVerilog.pnoise to string ""
spectreSVerilog.pnoise center string ""
spectreSVerilog.pnoise span string ""
spectreSVerilog.pnoise incrType string "Automatic"
spectreSVerilog.pnoise stepTypeLin string "Step Size"
spectreSVerilog.pnoise stepTypeLog string "Points Per Decade"
spectreSVerilog.pnoise by string ""
spectreSVerilog.pnoise lin string ""
spectreSVerilog.pnoise dec string ""
spectreSVerilog.pnoise log string ""
spectreSVerilog.pnoise useDiscrete boolean nil
spectreSVerilog.pnoise values string ""
spectreSVerilog.pnoise harmonics string "Zero sideband only"
spectreSVerilog.pnoise numharmonics string ""
spectreSVerilog.pnoise arrayharmonics string ""
spectreSVerilog.pnoise selFreqFrom string ""
spectreSVerilog.pnoise selFreqTo string ""
spectreSVerilog.pnoise harmsAndFreqsTitle string ""
spectreSVerilog.pnoise harmsAndFreqs string ""
spectreSVerilog.pnoise outType string "voltage"
spectreSVerilog.pnoise negNode string "/gnd!"
spectreSVerilog.pnoise posNode string ""
spectreSVerilog.pnoise outVsrc string ""
spectreSVerilog.pnoise inNoiseType string "none"
spectreSVerilog.pnoise inVsrc string ""
spectreSVerilog.pnoise inIsrc string ""
spectreSVerilog.pnoise inPort string ""
spectreSVerilog.pnoise refsideband string ""
;spectreSVerilog pnoiseOpts partition variables
spectreSVerilog.pnoiseOpts tolerance3 string ""
spectreSVerilog.pnoiseOpts gearorder3 string ""
spectreSVerilog.pnoiseOpts solver3 string ""
spectreSVerilog.pnoiseOpts stats4 string ""
spectreSVerilog.pnoiseOpts annotate4 string "status"
;spectreSVerilog pxf partition variables
spectreSVerilog.pxf enable toggle (nil)
spectreSVerilog.pxf fund string ""
spectreSVerilog.pxf Relative boolean nil
spectreSVerilog.pxf sweeptype string ""
spectreSVerilog.pxf rangeType string "Start-Stop"
spectreSVerilog.pxf from string ""
spectreSVerilog.pxf to string ""
spectreSVerilog.pxf center string ""
spectreSVerilog.pxf span string ""
spectreSVerilog.pxf incrType string "Automatic"
spectreSVerilog.pxf stepTypeLin string "Step Size"
spectreSVerilog.pxf stepTypeLog string "Points Per Decade"
spectreSVerilog.pxf by string ""
spectreSVerilog.pxf lin string ""
spectreSVerilog.pxf dec string ""
spectreSVerilog.pxf log string ""
spectreSVerilog.pxf useDiscrete boolean nil
spectreSVerilog.pxf values string ""
spectreSVerilog.pxf harmonics string "Zero sideband only"
spectreSVerilog.pxf numharmonics string ""
spectreSVerilog.pxf arrayharmonics string ""
spectreSVerilog.pxf selFreqFrom string ""
spectreSVerilog.pxf selFreqTo string ""
spectreSVerilog.pxf harmsAndFreqsTitle string ""
spectreSVerilog.pxf harmsAndFreqs string ""
spectreSVerilog.pxf outType string "voltage"
spectreSVerilog.pxf negNode string "/gnd!"
spectreSVerilog.pxf posNode string ""
spectreSVerilog.pxf outVsrc string ""
;spectreSVerilog pxfOpts partition variables
spectreSVerilog.pxfOpts tolerance2 string ""
spectreSVerilog.pxfOpts gearorder2 string ""
spectreSVerilog.pxfOpts solver2 string ""
spectreSVerilog.pxfOpts stats3 string ""
spectreSVerilog.pxfOpts annotate3 string "status"
spectreSVerilog.pxfOpts stimuli string ""
spectreSVerilog.pxfOpts freqaxis2 string ""
;spectreVerilog environment variables
;spectreVerilog opts partition variables
spectreVerilog.opts multithread string ""
spectreVerilog.opts title string ""
spectreVerilog.opts audit string ""
spectreVerilog.opts nthreads string ""
spectreVerilog.opts mos_method string ""
spectreVerilog.opts ckptclock string "1800"
spectreVerilog.opts flow string ""
spectreVerilog.opts cols string "80"
spectreVerilog.opts opptcheck string ""
spectreVerilog.opts maxwarnstologfile string ""
spectreVerilog.opts reltol string "1e-3"
spectreVerilog.opts notation string ""
spectreVerilog.opts senstype string ""
spectreVerilog.opts approx string ""
spectreVerilog.opts warn string ""
spectreVerilog.opts info string ""
spectreVerilog.opts quantities string ""
spectreVerilog.opts sensformat string ""
spectreVerilog.opts pivabs string ""
spectreVerilog.opts compatible string ""
spectreVerilog.opts gmin string "1e-12"
spectreVerilog.opts ignshorts string ""
spectreVerilog.opts rforce string "1"
spectreVerilog.opts homotopy string ""
spectreVerilog.opts note string ""
spectreVerilog.opts iabstol string "1e-12"
spectreVerilog.opts debug string ""
spectreVerilog.opts tempeffects string ""
spectreVerilog.opts maxwarns string "5"
spectreVerilog.opts vabstol string "1e-6"
spectreVerilog.opts macromodels string ""
spectreVerilog.opts tnom string "27"
spectreVerilog.opts temp string "27"
spectreVerilog.opts gmin_check string ""
spectreVerilog.opts value string ""
spectreVerilog.opts narrate string ""
spectreVerilog.opts maxnotes string "5"
spectreVerilog.opts scale string "1.0"
spectreVerilog.opts diagnose string ""
spectreVerilog.opts maxnotestologfile string ""
spectreVerilog.opts digits string "5"
spectreVerilog.opts pivotdc string ""
spectreVerilog.opts pivrel string "1e-3"
spectreVerilog.opts scalem string "1.0"
spectreVerilog.opts limit string ""
spectreVerilog.opts topcheck string ""
spectreVerilog.opts inventory string ""
spectreVerilog.opts error string ""
spectreVerilog.opts sensfile string "../psf/sens.output"
;spectreVerilog outputs partition variables
spectreVerilog.outputs currents string ""
spectreVerilog.outputs subcktprobelvl string ""
spectreVerilog.outputs modelParamInfo boolean t
spectreVerilog.outputs outputParamInfo boolean t
spectreVerilog.outputs allDigitalNV boolean t
spectreVerilog.outputs pwr string ""
spectreVerilog.outputs saveahdlvars string ""
spectreVerilog.outputs nestlvl string ""
spectreVerilog.outputs elementInfo boolean t
spectreVerilog.outputs save string "allpub"
spectreVerilog.outputs useprobes string ""
;spectreVerilog verimixOpts partition variables
spectreVerilog.verimixOpts filename6 string ""
spectreVerilog.verimixOpts maxDCIter int 0
spectreVerilog.verimixOpts scope1 string ""
spectreVerilog.verimixOpts scope10 string ""
spectreVerilog.verimixOpts filename8 string ""
spectreVerilog.verimixOpts dcInterval float 0.0
spectreVerilog.verimixOpts scope3 string ""
spectreVerilog.verimixOpts scope8 string ""
spectreVerilog.verimixOpts scope7 string ""
spectreVerilog.verimixOpts filename7 string ""
spectreVerilog.verimixOpts scope string ""
spectreVerilog.verimixOpts filename4 string ""
spectreVerilog.verimixOpts filename string ""
spectreVerilog.verimixOpts filename1 string ""
spectreVerilog.verimixOpts scope9 string ""
spectreVerilog.verimixOpts importsdfswitch boolean nil
spectreVerilog.verimixOpts filename2 string ""
spectreVerilog.verimixOpts numberofsdffiles int 2
spectreVerilog.verimixOpts scope2 string ""
spectreVerilog.verimixOpts scope6 string ""
spectreVerilog.verimixOpts filename10 string ""
spectreVerilog.verimixOpts delaymodechoice string "Ignore"
spectreVerilog.verimixOpts sdfmixedswitch boolean t
spectreVerilog.verimixOpts filename9 string ""
spectreVerilog.verimixOpts scope5 string ""
spectreVerilog.verimixOpts filename5 string ""
spectreVerilog.verimixOpts filename3 string ""
spectreVerilog.verimixOpts scope4 string ""
;spectreVerilog verilogOpts partition variables
spectreVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
spectreVerilog.verilogOpts optionsFile string ""
spectreVerilog.verilogOpts twinTurbo boolean nil
spectreVerilog.verilogOpts suppressMessages boolean nil
spectreVerilog.verilogOpts libraryFile string ""
spectreVerilog.verilogOpts behaveProfile boolean nil
spectreVerilog.verilogOpts verimixLog string "verilog.log"
spectreVerilog.verilogOpts simVision boolean nil
spectreVerilog.verilogOpts pulseSpec boolean nil
spectreVerilog.verilogOpts commandFile string ""
spectreVerilog.verilogOpts pulseError int 100
spectreVerilog.verilogOpts stopCompile boolean nil
spectreVerilog.verilogOpts keepNodes string "Minimum"
spectreVerilog.verilogOpts accelerationCA boolean nil
spectreVerilog.verilogOpts turboRadio string "Default"
spectreVerilog.verilogOpts libraryDir string ""
spectreVerilog.verilogOpts suppressWarnings boolean nil
spectreVerilog.verilogOpts accelerationSwitches boolean nil
spectreVerilog.verilogOpts accelerationNormal boolean t
spectreVerilog.verilogOpts delayType string "Typical"
spectreVerilog.verilogOpts pulseReject int 100
spectreVerilog.verilogOpts delayMode string "Default"
spectreVerilog.verilogOpts vermixBinary string "verilog.vmx"
;spectreVerilog init partition variables
spectreVerilog.init processPriority int 0
;spectreVerilog envOpts partition variables
spectreVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
spectreVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
spectreVerilog.envOpts outputFormat string "AWD"
spectreVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
spectreVerilog.envOpts mspSetupNetlistEscapeName boolean nil
spectreVerilog.envOpts enableArclength boolean nil
spectreVerilog.envOpts autoDisplay boolean t
spectreVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
spectreVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
spectreVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
spectreVerilog.envOpts simOutputFormat string "psfbin"
spectreVerilog.envOpts spp string ""
spectreVerilog.envOpts mspSetupNetlistPinMap boolean nil
spectreVerilog.envOpts mspSetupNetlistBus boolean t
spectreVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
spectreVerilog.envOpts analysisOrder string ""
spectreVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
spectreVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
spectreVerilog.envOpts mspSetupNetlistExplicit boolean nil
spectreVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
spectreVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
spectreVerilog.envOpts paramRangeCheckFile string ""
spectreVerilog.envOpts printComments boolean nil
spectreVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
spectreVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
spectreVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
spectreVerilog.envOpts mspSetupNetlistSimTimeValue int 1
spectreVerilog.envOpts mspSetupNetlistUseLib boolean nil
spectreVerilog.envOpts firstRun boolean t
spectreVerilog.envOpts mspSetupNetlistNullPort boolean nil
spectreVerilog.envOpts mspSetupNetlistDropPortRange boolean t
spectreVerilog.envOpts userCmdLineOption string ""
spectreVerilog.envOpts mspSetupNetlistUpCase boolean nil
spectreVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;spectreVerilog pz partition variables
spectreVerilog.pz enable toggle (nil)
spectreVerilog.pz outType string "voltage"
spectreVerilog.pz p string ""
spectreVerilog.pz n string ""
spectreVerilog.pz oprobe string ""
spectreVerilog.pz inType string "voltage"
spectreVerilog.pz inVsrc string ""
spectreVerilog.pz inIsrc string ""
spectreVerilog.pz iprobe string ""
spectreVerilog.pz sweep string ""
spectreVerilog.pz freq string "1"
spectreVerilog.pz dev string ""
spectreVerilog.pz deviceParam string ""
spectreVerilog.pz mod string ""
spectreVerilog.pz modelParam string ""
spectreVerilog.pz designVar string ""
spectreVerilog.pz param string ""
spectreVerilog.pz rangeType string "Start-Stop"
spectreVerilog.pz start string ""
spectreVerilog.pz stop string ""
spectreVerilog.pz center string ""
spectreVerilog.pz span string ""
spectreVerilog.pz incrType string "Automatic"
spectreVerilog.pz stepTypeLin string "Step Size"
spectreVerilog.pz stepTypeLog string "Points Per Decade"
spectreVerilog.pz step string ""
spectreVerilog.pz lin string ""
spectreVerilog.pz dec string ""
spectreVerilog.pz log string ""
spectreVerilog.pz useDiscrete boolean nil
spectreVerilog.pz values string ""
spectreVerilog.pz porti string "1"
;spectreVerilog pzOpts partition variables
spectreVerilog.pzOpts readns string ""
spectreVerilog.pzOpts oppoint string ""
spectreVerilog.pzOpts fmax string ""
spectreVerilog.pzOpts zeroonly string ""
spectreVerilog.pzOpts prevoppoint string ""
spectreVerilog.pzOpts restart string ""
spectreVerilog.pzOpts annotate string ""
spectreVerilog.pzOpts stats string ""
;spectreVerilog dcmatch partition variables
spectreVerilog.dcmatch enable toggle (nil)
spectreVerilog.dcmatch outType string "voltage"
spectreVerilog.dcmatch p string ""
spectreVerilog.dcmatch n string ""
spectreVerilog.dcmatch oprobe string ""
spectreVerilog.dcmatch sweep string ""
spectreVerilog.dcmatch dev string ""
spectreVerilog.dcmatch deviceParam string ""
spectreVerilog.dcmatch mod string ""
spectreVerilog.dcmatch modelParam string ""
spectreVerilog.dcmatch designVar string ""
spectreVerilog.dcmatch param string ""
spectreVerilog.dcmatch rangeType string "Start-Stop"
spectreVerilog.dcmatch start string ""
spectreVerilog.dcmatch stop string ""
spectreVerilog.dcmatch center string ""
spectreVerilog.dcmatch span string ""
spectreVerilog.dcmatch incrType string "Automatic"
spectreVerilog.dcmatch stepTypeLin string "Step Size"
spectreVerilog.dcmatch stepTypeLog string "Points Per Decade"
spectreVerilog.dcmatch step string ""
spectreVerilog.dcmatch lin string ""
spectreVerilog.dcmatch dec string ""
spectreVerilog.dcmatch log string ""
spectreVerilog.dcmatch useDiscrete boolean nil
spectreVerilog.dcmatch values string ""
spectreVerilog.dcmatch mth string ""
spectreVerilog.dcmatch porti string "1"
spectreVerilog.dcmatch portv string ""
;spectreVerilog dcmatchOpts partition variables
spectreVerilog.dcmatchOpts readns string ""
spectreVerilog.dcmatchOpts save string ""
spectreVerilog.dcmatchOpts nestlvl string ""
spectreVerilog.dcmatchOpts oppoint string ""
spectreVerilog.dcmatchOpts prevoppoint string ""
spectreVerilog.dcmatchOpts restart string ""
spectreVerilog.dcmatchOpts annotate string "status"
spectreVerilog.dcmatchOpts stats string ""
spectreVerilog.dcmatchOpts where string "rawfile"
;spectreVerilog stb partition variables
spectreVerilog.stb enable toggle (nil)
spectreVerilog.stb sweep string "Frequency"
spectreVerilog.stb freq string ""
spectreVerilog.stb dev string ""
spectreVerilog.stb deviceParam string ""
spectreVerilog.stb mod string ""
spectreVerilog.stb modelParam string ""
spectreVerilog.stb designVar string ""
spectreVerilog.stb param string ""
spectreVerilog.stb rangeType string "Start-Stop"
spectreVerilog.stb start string ""
spectreVerilog.stb stop string ""
spectreVerilog.stb center string ""
spectreVerilog.stb span string ""
spectreVerilog.stb incrType string "Automatic"
spectreVerilog.stb stepTypeLin string "Step Size"
spectreVerilog.stb stepTypeLog string "Points Per Decade"
spectreVerilog.stb step string ""
spectreVerilog.stb lin string ""
spectreVerilog.stb dec string ""
spectreVerilog.stb log string ""
spectreVerilog.stb useDiscrete boolean nil
spectreVerilog.stb values string ""
spectreVerilog.stb probe string ""
;spectreVerilog stbOpts partition variables
spectreVerilog.stbOpts prevoppoint string ""
spectreVerilog.stbOpts readns string ""
spectreVerilog.stbOpts save string ""
spectreVerilog.stbOpts nestlvl string ""
spectreVerilog.stbOpts oppoint string ""
spectreVerilog.stbOpts restart string ""
spectreVerilog.stbOpts annotate string "status"
spectreVerilog.stbOpts stats string ""
;spectreVerilog tran partition variables
spectreVerilog.tran enable toggle (nil)
spectreVerilog.tran stop string ""
spectreVerilog.tran errpreset string ""
;spectreVerilog tranOpts partition variables
spectreVerilog.tranOpts start string ""
spectreVerilog.tranOpts outputstart string ""
spectreVerilog.tranOpts step string ""
spectreVerilog.tranOpts maxstep string ""
spectreVerilog.tranOpts ic string ""
spectreVerilog.tranOpts skipdc string ""
spectreVerilog.tranOpts readic string ""
spectreVerilog.tranOpts readns string ""
spectreVerilog.tranOpts cmin string ""
spectreVerilog.tranOpts write string "spectre.ic"
spectreVerilog.tranOpts writefinal string "spectre.fc"
spectreVerilog.tranOpts ckptperiod string ""
spectreVerilog.tranOpts method string ""
spectreVerilog.tranOpts relref string ""
spectreVerilog.tranOpts lteratio string ""
spectreVerilog.tranOpts stats string ""
spectreVerilog.tranOpts annotate string "status"
spectreVerilog.tranOpts save string ""
spectreVerilog.tranOpts nestlvl string ""
spectreVerilog.tranOpts oppoint string ""
spectreVerilog.tranOpts skipstart string ""
spectreVerilog.tranOpts skipstop string ""
spectreVerilog.tranOpts skipcount string ""
spectreVerilog.tranOpts strobeperiod string ""
spectreVerilog.tranOpts strobedelay string ""
spectreVerilog.tranOpts compression string ""
spectreVerilog.tranOpts infotimes string ""
spectreVerilog.tranOpts flushpoints string ""
spectreVerilog.tranOpts flushtime string ""
spectreVerilog.tranOpts flushofftime string ""
spectreVerilog.tranOpts maxiters string "5"
spectreVerilog.tranOpts restart string ""
spectreVerilog.tranOpts captab boolean nil
spectreVerilog.tranOpts timed boolean nil
spectreVerilog.tranOpts threshold string "0.0"
spectreVerilog.tranOpts detail string "node"
spectreVerilog.tranOpts sort string "name"
;spectreVerilog envlp partition variables
spectreVerilog.envlp enable toggle (nil)
spectreVerilog.envlp clockname string ""
spectreVerilog.envlp stop string ""
spectreVerilog.envlp harmonics string "Number of harmonics"
spectreVerilog.envlp harms string ""
spectreVerilog.envlp harmsvec string ""
spectreVerilog.envlp errpreset string ""
;spectreVerilog envlpOpts partition variables
spectreVerilog.envlpOpts start string ""
spectreVerilog.envlpOpts outputstart string ""
spectreVerilog.envlpOpts tstab string ""
spectreVerilog.envlpOpts modulationbw string ""
spectreVerilog.envlpOpts maxstep string ""
spectreVerilog.envlpOpts envmaxstep string ""
spectreVerilog.envlpOpts ic string ""
spectreVerilog.envlpOpts skipdc string ""
spectreVerilog.envlpOpts readic string ""
spectreVerilog.envlpOpts readns string ""
spectreVerilog.envlpOpts cmin string ""
spectreVerilog.envlpOpts write string ""
spectreVerilog.envlpOpts writefinal string ""
spectreVerilog.envlpOpts swapfile string ""
spectreVerilog.envlpOpts method string ""
spectreVerilog.envlpOpts relref string ""
spectreVerilog.envlpOpts lteratio string ""
spectreVerilog.envlpOpts envlteratio string ""
spectreVerilog.envlpOpts steadyratio string ""
spectreVerilog.envlpOpts stats string ""
spectreVerilog.envlpOpts annotate string "status"
spectreVerilog.envlpOpts save string ""
spectreVerilog.envlpOpts nestlvl string ""
spectreVerilog.envlpOpts compression string ""
spectreVerilog.envlpOpts outputtype string ""
spectreVerilog.envlpOpts strobeperiod string ""
spectreVerilog.envlpOpts maxiters string ""
spectreVerilog.envlpOpts restart string ""
spectreVerilog.envlpOpts envmaxiters string ""
;spectreVerilog ac partition variables
spectreVerilog.ac enable toggle (nil)
spectreVerilog.ac sweep string "Frequency"
spectreVerilog.ac freq string ""
spectreVerilog.ac dev string ""
spectreVerilog.ac deviceParam string ""
spectreVerilog.ac mod string ""
spectreVerilog.ac modelParam string ""
spectreVerilog.ac designVar string ""
spectreVerilog.ac param string ""
spectreVerilog.ac rangeType string "Start-Stop"
spectreVerilog.ac start string ""
spectreVerilog.ac stop string ""
spectreVerilog.ac center string ""
spectreVerilog.ac span string ""
spectreVerilog.ac incrType string "Automatic"
spectreVerilog.ac stepTypeLin string "Step Size"
spectreVerilog.ac stepTypeLog string "Points Per Decade"
spectreVerilog.ac step string ""
spectreVerilog.ac lin string ""
spectreVerilog.ac dec string ""
spectreVerilog.ac log string ""
spectreVerilog.ac useDiscrete boolean nil
spectreVerilog.ac values string ""
;spectreVerilog acOpts partition variables
spectreVerilog.acOpts readns string ""
spectreVerilog.acOpts prevoppoint string ""
spectreVerilog.acOpts save string ""
spectreVerilog.acOpts nestlvl string ""
spectreVerilog.acOpts oppoint string ""
spectreVerilog.acOpts restart string ""
spectreVerilog.acOpts annotate string "status"
spectreVerilog.acOpts stats string ""
;spectreVerilog dc partition variables
spectreVerilog.dc enable toggle (nil)
spectreVerilog.dcop enable toggle (nil)
spectreVerilog.dc saveOppoint boolean nil
spectreVerilog.dc sweep string ""
spectreVerilog.dc dev string ""
spectreVerilog.dc deviceParam string ""
spectreVerilog.dc mod string ""
spectreVerilog.dc modelParam string ""
spectreVerilog.dc designVar string ""
spectreVerilog.dc param string ""
spectreVerilog.dc rangeType string "Start-Stop"
spectreVerilog.dc start string ""
spectreVerilog.dc stop string ""
spectreVerilog.dc center string ""
spectreVerilog.dc span string ""
spectreVerilog.dc incrType string "Automatic"
spectreVerilog.dc stepTypeLin string "Step Size"
spectreVerilog.dc stepTypeLog string "Points Per Decade"
spectreVerilog.dc step string ""
spectreVerilog.dc lin string ""
spectreVerilog.dc dec string ""
spectreVerilog.dc log string ""
spectreVerilog.dc useDiscrete boolean nil
spectreVerilog.dc values string ""
;spectreVerilog dcOpts partition variables
spectreVerilog.dcOpts force string ""
spectreVerilog.dcopOpts force string ""
spectreVerilog.dcOpts readns string ""
spectreVerilog.dcopOpts readns string ""
spectreVerilog.dcOpts readforce string ""
spectreVerilog.dcopOpts readforce string ""
spectreVerilog.dcOpts write string "spectre.dc"
spectreVerilog.dcopOpts write string "spectre.dc"
spectreVerilog.dcOpts writefinal string ""
spectreVerilog.dcopOpts writefinal string ""
spectreVerilog.dcOpts save string ""
spectreVerilog.dcopOpts save string ""
spectreVerilog.dcOpts nestlvl string ""
spectreVerilog.dcopOpts nestlvl string ""
spectreVerilog.dcOpts print string ""
spectreVerilog.dcopOpts print string ""
spectreVerilog.dcOpts check string ""
spectreVerilog.dcopOpts check string ""
spectreVerilog.dcOpts oppoint string "rawfile"
spectreVerilog.dcopOpts oppoint string "rawfile"
spectreVerilog.dcOpts homotopy string ""
spectreVerilog.dcopOpts homotopy string ""
spectreVerilog.dcOpts restart string ""
spectreVerilog.dcopOpts restart string ""
spectreVerilog.dcOpts maxiters string "150"
spectreVerilog.dcopOpts maxiters string "150"
spectreVerilog.dcOpts maxsteps string "10000"
spectreVerilog.dcopOpts maxsteps string "10000"
spectreVerilog.dcOpts annotate string "status"
spectreVerilog.dcopOpts annotate string "status"
spectreVerilog.dcOpts captab boolean nil
spectreVerilog.dcopOpts captab boolean nil
spectreVerilog.dcOpts threshold string "0.0"
spectreVerilog.dcopOpts threshold string "0.0"
spectreVerilog.dcOpts detail string "node"
spectreVerilog.dcopOpts detail string "node"
spectreVerilog.dcOpts sort string "name"
spectreVerilog.dcopOpts sort string "name"
;spectreVerilog noise partition variables
spectreVerilog.noise enable toggle (nil)
spectreVerilog.noise sweep string "Frequency"
spectreVerilog.noise freq string ""
spectreVerilog.noise dev string ""
spectreVerilog.noise deviceParam string ""
spectreVerilog.noise mod string ""
spectreVerilog.noise modelParam string ""
spectreVerilog.noise designVar string ""
spectreVerilog.noise param string ""
spectreVerilog.noise rangeType string "Start-Stop"
spectreVerilog.noise start string ""
spectreVerilog.noise stop string ""
spectreVerilog.noise center string ""
spectreVerilog.noise span string ""
spectreVerilog.noise incrType string "Automatic"
spectreVerilog.noise stepTypeLin string "Step Size"
spectreVerilog.noise stepTypeLog string "Points Per Decade"
spectreVerilog.noise step string ""
spectreVerilog.noise lin string ""
spectreVerilog.noise dec string ""
spectreVerilog.noise log string ""
spectreVerilog.noise useDiscrete boolean nil
spectreVerilog.noise values string ""
spectreVerilog.noise outType string "probe"
spectreVerilog.noise p string ""
spectreVerilog.noise n string ""
spectreVerilog.noise oprobe string ""
spectreVerilog.noise inType string "port"
spectreVerilog.noise inVsrc string ""
spectreVerilog.noise inIsrc string ""
spectreVerilog.noise iprobe string ""
spectreVerilog.noise inPort string ""
;spectreVerilog noiseOpts partition variables
spectreVerilog.noiseOpts readns string ""
spectreVerilog.noiseOpts prevoppoint string ""
spectreVerilog.noiseOpts save string ""
spectreVerilog.noiseOpts nestlvl string ""
spectreVerilog.noiseOpts oppoint string ""
spectreVerilog.noiseOpts restart string ""
spectreVerilog.noiseOpts annotate string "status"
spectreVerilog.noiseOpts stats string ""
;spectreVerilog xf partition variables
spectreVerilog.xf enable toggle (nil)
spectreVerilog.xf sweep string "Frequency"
spectreVerilog.xf freq string ""
spectreVerilog.xf dev string ""
spectreVerilog.xf deviceParam string ""
spectreVerilog.xf mod string ""
spectreVerilog.xf modelParam string ""
spectreVerilog.xf designVar string ""
spectreVerilog.xf param string ""
spectreVerilog.xf rangeType string "Start-Stop"
spectreVerilog.xf start string ""
spectreVerilog.xf stop string ""
spectreVerilog.xf center string ""
spectreVerilog.xf span string ""
spectreVerilog.xf incrType string "Automatic"
spectreVerilog.xf stepTypeLin string "Step Size"
spectreVerilog.xf stepTypeLog string "Points Per Decade"
spectreVerilog.xf step string ""
spectreVerilog.xf lin string ""
spectreVerilog.xf dec string ""
spectreVerilog.xf log string ""
spectreVerilog.xf useDiscrete boolean nil
spectreVerilog.xf values string ""
spectreVerilog.xf outType string "voltage"
spectreVerilog.xf p string ""
spectreVerilog.xf n string ""
spectreVerilog.xf probe string ""
;spectreVerilog xfOpts partition variables
spectreVerilog.xfOpts readns string ""
spectreVerilog.xfOpts prevoppoint string ""
spectreVerilog.xfOpts stimuli string ""
spectreVerilog.xfOpts save string ""
spectreVerilog.xfOpts nestlvl string ""
spectreVerilog.xfOpts oppoint string ""
spectreVerilog.xfOpts restart string ""
spectreVerilog.xfOpts annotate string "status"
spectreVerilog.xfOpts stats string ""
;spectreVerilog sp partition variables
spectreVerilog.sp enable toggle (nil)
spectreVerilog.sp ports string ""
spectreVerilog.sp sweep string "Frequency"
spectreVerilog.sp freq string ""
spectreVerilog.sp dev string ""
spectreVerilog.sp deviceParam string ""
spectreVerilog.sp mod string ""
spectreVerilog.sp modelParam string ""
spectreVerilog.sp designVar string ""
spectreVerilog.sp param string ""
spectreVerilog.sp rangeType string "Start-Stop"
spectreVerilog.sp start string ""
spectreVerilog.sp stop string ""
spectreVerilog.sp center string ""
spectreVerilog.sp span string ""
spectreVerilog.sp incrType string "Automatic"
spectreVerilog.sp stepTypeLin string "Step Size"
spectreVerilog.sp stepTypeLog string "Points Per Decade"
spectreVerilog.sp step string ""
spectreVerilog.sp lin string ""
spectreVerilog.sp dec string ""
spectreVerilog.sp log string ""
spectreVerilog.sp useDiscrete boolean nil
spectreVerilog.sp values string ""
spectreVerilog.sp donoise string "no"
spectreVerilog.sp oprobe string ""
spectreVerilog.sp iprobe string ""
;spectreVerilog spOpts partition variables
spectreVerilog.spOpts readns string ""
spectreVerilog.spOpts prevoppoint string ""
spectreVerilog.spOpts file string ""
spectreVerilog.spOpts datafmt string ""
spectreVerilog.spOpts datatype string ""
spectreVerilog.spOpts noisedata string ""
spectreVerilog.spOpts oppoint string ""
spectreVerilog.spOpts restart string ""
spectreVerilog.spOpts annotate string "status"
spectreVerilog.spOpts stats string ""
;spectreVerilog pss partition variables
spectreVerilog.pss enable toggle (nil)
spectreVerilog.pss paramListBox string ""
spectreVerilog.pss fundListBox string ""
spectreVerilog.pss stimName string ""
spectreVerilog.pss freqName string ""
spectreVerilog.pss freqVal string ""
spectreVerilog.pss signalLevel string "Large"
spectreVerilog.pss srcId string ""
spectreVerilog.pss maxHarms string ""
spectreVerilog.pss freqPeriod string "Beat Frequency"
spectreVerilog.pss fund string ""
spectreVerilog.pss autoCalc boolean nil
spectreVerilog.pss period string ""
spectreVerilog.pss harmonics string "Number of harmonics"
spectreVerilog.pss harms string ""
spectreVerilog.pss indices string ""
spectreVerilog.pss Aindices string ""
spectreVerilog.pss harmsvec string ""
spectreVerilog.pss selFreqFrom string "0"
spectreVerilog.pss selFreqTo string "1e12"
spectreVerilog.pss order string "1"
spectreVerilog.pss harmsAndFreqsTitle string ""
spectreVerilog.pss harmsAndFreqsTitle2 string ""
spectreVerilog.pss harmsAndFreqs string ""
spectreVerilog.pss arrayCoeffs string ""
spectreVerilog.pss harmCoeffs string ""
spectreVerilog.pss harmListMem string ""
spectreVerilog.pss errpreset string ""
spectreVerilog.pss tstab string ""
spectreVerilog.pss saveinit string ""
spectreVerilog.pss oscana boolean nil
spectreVerilog.pss p string ""
spectreVerilog.pss n string ""
spectreVerilog.pss sweepB boolean nil
spectreVerilog.pss sweep string "Variable"
spectreVerilog.pss freqVar string "no"
spectreVerilog.pss designVar string ""
spectreVerilog.pss dev string ""
spectreVerilog.pss deviceParam string ""
spectreVerilog.pss mod string ""
spectreVerilog.pss modelParam string ""
spectreVerilog.pss param string ""
spectreVerilog.pss rangeType string "Start-Stop"
spectreVerilog.pss start string ""
spectreVerilog.pss stop string ""
spectreVerilog.pss center string ""
spectreVerilog.pss span string ""
spectreVerilog.pss incrType string "Linear"
spectreVerilog.pss stepTypeLin string "Step Size"
spectreVerilog.pss stepTypeLog string "Points Per Decade"
spectreVerilog.pss step string ""
spectreVerilog.pss lin string ""
spectreVerilog.pss dec string ""
spectreVerilog.pss log string ""
spectreVerilog.pss useDiscrete boolean nil
spectreVerilog.pss values string ""
;spectreVerilog pssOpts partition variables
spectreVerilog.pssOpts step string ""
spectreVerilog.pssOpts maxstep string ""
spectreVerilog.pssOpts ic string ""
spectreVerilog.pssOpts skipdc string ""
spectreVerilog.pssOpts readic string ""
spectreVerilog.pssOpts readns string ""
spectreVerilog.pssOpts cmin string ""
spectreVerilog.pssOpts write string ""
spectreVerilog.pssOpts writefinal string ""
spectreVerilog.pssOpts swapfile string ""
spectreVerilog.pssOpts writepss string ""
spectreVerilog.pssOpts readpss string ""
spectreVerilog.pssOpts method string ""
spectreVerilog.pssOpts tstabmethod string ""
spectreVerilog.pssOpts relref string ""
spectreVerilog.pssOpts lteratio string ""
spectreVerilog.pssOpts steadyratio string ""
spectreVerilog.pssOpts maxacfreq string ""
spectreVerilog.pssOpts maxperiods string ""
spectreVerilog.pssOpts finitediff string ""
spectreVerilog.pssOpts highorder string ""
spectreVerilog.pssOpts psaratio string ""
spectreVerilog.pssOpts maxorder string ""
spectreVerilog.pssOpts fullpssvec string ""
spectreVerilog.pssOpts stats string ""
spectreVerilog.pssOpts annotate string "status"
spectreVerilog.pssOpts save string ""
spectreVerilog.pssOpts nestlvl string ""
spectreVerilog.pssOpts oppoint string ""
spectreVerilog.pssOpts skipstart string ""
spectreVerilog.pssOpts skipstop string ""
spectreVerilog.pssOpts skipcount string ""
spectreVerilog.pssOpts strobeperiod string ""
spectreVerilog.pssOpts strobedelay string ""
spectreVerilog.pssOpts compression string ""
spectreVerilog.pssOpts outputtype string ""
spectreVerilog.pssOpts maxiters string ""
spectreVerilog.pssOpts restart string ""
spectreVerilog.pssOpts tstart string ""
;spectreVerilog pac partition variables
spectreVerilog.pac enable toggle (nil)
spectreVerilog.pac fund string ""
spectreVerilog.pac period string ""
spectreVerilog.pac modsource string ""
spectreVerilog.pac moduppersideband string "0"
spectreVerilog.pac inmodharmnum string "1"
spectreVerilog.pac outmodharmvec string "1"
spectreVerilog.pac inputType string "SSB"
spectreVerilog.pac modulatedToggle boolean nil
spectreVerilog.pac modulated string ""
spectreVerilog.pac singlePt string "Single-Point []"
spectreVerilog.pac sweeptype string " "
spectreVerilog.pac relharmnum string ""
spectreVerilog.pac rangeType string "Start-Stop"
spectreVerilog.pac start string ""
spectreVerilog.pac stop string ""
spectreVerilog.pac center string ""
spectreVerilog.pac span string ""
spectreVerilog.pac incrType string "Automatic"
spectreVerilog.pac stepTypeLin string "Step Size"
spectreVerilog.pac stepTypeLog string "Points Per Decade"
spectreVerilog.pac step string ""
spectreVerilog.pac lin string ""
spectreVerilog.pac dec string ""
spectreVerilog.pac log string ""
spectreVerilog.pac useDiscrete boolean nil
spectreVerilog.pac values string ""
spectreVerilog.pac harmonics string "Maximum sideband"
spectreVerilog.pac maxsideband string ""
spectreVerilog.pac indices string ""
spectreVerilog.pac Aindices string ""
spectreVerilog.pac sidebands string ""
spectreVerilog.pac side string "upper"
spectreVerilog.pac selFreqFrom string "0"
spectreVerilog.pac selFreqTo string "1e12"
spectreVerilog.pac order string "1"
spectreVerilog.pac harmsAndFreqsTitle string ""
spectreVerilog.pac harmsAndFreqsTitle2 string ""
spectreVerilog.pac harmsAndFreqs string ""
spectreVerilog.pac arrayCoeffs string ""
spectreVerilog.pac harmCoeffs string ""
spectreVerilog.pac harmListMem string ""
;spectreVerilog pacOpts partition variables
spectreVerilog.pacOpts tolerance string ""
spectreVerilog.pacOpts gear_order string ""
spectreVerilog.pacOpts solver string ""
spectreVerilog.pacOpts oscsolver string ""
spectreVerilog.pacOpts stats string ""
spectreVerilog.pacOpts annotate string "status"
spectreVerilog.pacOpts freqaxis string ""
spectreVerilog.pacOpts save string ""
spectreVerilog.pacOpts nestlvl string ""
spectreVerilog.pacOpts outputperiod string ""
;spectreVerilog pnoise partition variables
spectreVerilog.pnoise enable toggle (nil)
spectreVerilog.pnoise fund string ""
spectreVerilog.pnoise period string ""
spectreVerilog.pnoise singlePt string "Single-Point []"
spectreVerilog.pnoise sweeptype string " "
spectreVerilog.pnoise relharmnum string ""
spectreVerilog.pnoise rangeType string "Start-Stop"
spectreVerilog.pnoise start string ""
spectreVerilog.pnoise stop string ""
spectreVerilog.pnoise center string ""
spectreVerilog.pnoise span string ""
spectreVerilog.pnoise incrType string "Automatic"
spectreVerilog.pnoise stepTypeLin string "Step Size"
spectreVerilog.pnoise stepTypeLog string "Points Per Decade"
spectreVerilog.pnoise step string ""
spectreVerilog.pnoise lin string ""
spectreVerilog.pnoise dec string ""
spectreVerilog.pnoise log string ""
spectreVerilog.pnoise useDiscrete boolean nil
spectreVerilog.pnoise values string ""
spectreVerilog.pnoise harmonics string "Maximum sideband"
spectreVerilog.pnoise maxsideband string ""
spectreVerilog.pnoise indices string ""
spectreVerilog.pnoise Aindices string ""
spectreVerilog.pnoise sidebands string ""
spectreVerilog.pnoise side string "upper"
spectreVerilog.pnoise selFreqFrom string "0"
spectreVerilog.pnoise selFreqTo string "1e12"
spectreVerilog.pnoise order string "1"
spectreVerilog.pnoise harmsAndFreqsTitle string ""
spectreVerilog.pnoise harmsAndFreqsTitle2 string ""
spectreVerilog.pnoise harmsAndFreqs string ""
spectreVerilog.pnoise arrayCoeffs string ""
spectreVerilog.pnoise harmCoeffs string ""
spectreVerilog.pnoise harmListMem string ""
spectreVerilog.pnoise outType string "probe"
spectreVerilog.pnoise p string ""
spectreVerilog.pnoise n string ""
spectreVerilog.pnoise oprobe string ""
spectreVerilog.pnoise inType string "port"
spectreVerilog.pnoise inVsrc string ""
spectreVerilog.pnoise inIsrc string ""
spectreVerilog.pnoise iprobe string ""
spectreVerilog.pnoise inPort string ""
spectreVerilog.pnoise refsbSelect string "Enter in field"
spectreVerilog.pnoise refsideband string ""
spectreVerilog.pnoise refsbFreqFrom string "0"
spectreVerilog.pnoise refsbFreqTo string "1e12"
spectreVerilog.pnoise refsbOrder string "1"
spectreVerilog.pnoise refsbTitle string ""
spectreVerilog.pnoise refsbListbox string ""
spectreVerilog.pnoise noisetype string "sources"
spectreVerilog.pnoise tdnoise string "Noise Skip Count"
spectreVerilog.pnoise noiseskipcount string ""
spectreVerilog.pnoise numberofpoints string ""
spectreVerilog.pnoise maxcycles string ""
spectreVerilog.pnoise useDiscreteNoise boolean nil
spectreVerilog.pnoise noisetimepoints string ""
spectreVerilog.pnoise useDiscreteCorr boolean nil
spectreVerilog.pnoise cycles string ""
;spectreVerilog pnoiseOpts partition variables
spectreVerilog.pnoiseOpts tolerance string ""
spectreVerilog.pnoiseOpts gear_order string ""
spectreVerilog.pnoiseOpts solver string ""
spectreVerilog.pnoiseOpts oscsolver string ""
spectreVerilog.pnoiseOpts stats string ""
spectreVerilog.pnoiseOpts annotate string "status"
spectreVerilog.pnoiseOpts save string ""
spectreVerilog.pnoiseOpts nestlvl string ""
spectreVerilog.pnoiseOpts saveallsidebands string ""
;spectreVerilog pxf partition variables
spectreVerilog.pxf enable toggle (nil)
spectreVerilog.pxf fund string ""
spectreVerilog.pxf period string ""
spectreVerilog.pxf moduppersideband string "0"
spectreVerilog.pxf outmodharmnum string "1"
spectreVerilog.pxf inmodharmvec string "1"
spectreVerilog.pxf outputType string "SSB"
spectreVerilog.pxf modulatedToggle boolean nil
spectreVerilog.pxf modulated string ""
spectreVerilog.pxf outType string "voltage"
spectreVerilog.pxf p string ""
spectreVerilog.pxf n string ""
spectreVerilog.pxf probe string ""
spectreVerilog.pxf singlePt string "Single-Point []"
spectreVerilog.pxf sweeptype string " "
spectreVerilog.pxf relharmnum string ""
spectreVerilog.pxf rangeType string "Start-Stop"
spectreVerilog.pxf start string ""
spectreVerilog.pxf stop string ""
spectreVerilog.pxf center string ""
spectreVerilog.pxf span string ""
spectreVerilog.pxf incrType string "Automatic"
spectreVerilog.pxf stepTypeLin string "Step Size"
spectreVerilog.pxf stepTypeLog string "Points Per Decade"
spectreVerilog.pxf step string ""
spectreVerilog.pxf lin string ""
spectreVerilog.pxf dec string ""
spectreVerilog.pxf log string ""
spectreVerilog.pxf useDiscrete boolean nil
spectreVerilog.pxf values string ""
spectreVerilog.pxf harmonics string "Maximum sideband"
spectreVerilog.pxf maxsideband string ""
spectreVerilog.pxf indices string ""
spectreVerilog.pxf Aindices string ""
spectreVerilog.pxf sidebands string ""
spectreVerilog.pxf side string "upper"
spectreVerilog.pxf selFreqFrom string "0"
spectreVerilog.pxf selFreqTo string "1e12"
spectreVerilog.pxf order string "1"
spectreVerilog.pxf harmsAndFreqsTitle string ""
spectreVerilog.pxf harmsAndFreqsTitle2 string ""
spectreVerilog.pxf harmsAndFreqs string ""
spectreVerilog.pxf arrayCoeffs string ""
spectreVerilog.pxf harmCoeffs string ""
spectreVerilog.pxf harmListMem string ""
;spectreVerilog pxfOpts partition variables
spectreVerilog.pxfOpts tolerance string ""
spectreVerilog.pxfOpts gear_order string ""
spectreVerilog.pxfOpts solver string ""
spectreVerilog.pxfOpts oscsolver string ""
spectreVerilog.pxfOpts stats string ""
spectreVerilog.pxfOpts annotate string "status"
spectreVerilog.pxfOpts stimuli string ""
spectreVerilog.pxfOpts freqaxis string ""
spectreVerilog.pxfOpts save string ""
spectreVerilog.pxfOpts nestlvl string ""
;spectreVerilog psp partition variables
spectreVerilog.psp enable toggle (nil)
spectreVerilog.psp singlePt string "Single-Point []"
spectreVerilog.psp sweeptype string " "
spectreVerilog.psp rangeType string "Start-Stop"
spectreVerilog.psp start string ""
spectreVerilog.psp stop string ""
spectreVerilog.psp center string ""
spectreVerilog.psp span string ""
spectreVerilog.psp incrType string "Automatic"
spectreVerilog.psp stepTypeLin string "Step Size"
spectreVerilog.psp stepTypeLog string "Points Per Decade"
spectreVerilog.psp step string ""
spectreVerilog.psp lin string ""
spectreVerilog.psp dec string ""
spectreVerilog.psp log string ""
spectreVerilog.psp useDiscrete boolean nil
spectreVerilog.psp values string ""
spectreVerilog.psp portharmsvec string ""
spectreVerilog.psp ports string ""
spectreVerilog.psp selectPorts boolean t
spectreVerilog.psp harmsvec string ""
spectreVerilog.psp freqRange string ""
spectreVerilog.psp listPortHarm string ""
spectreVerilog.psp listPortName string ""
spectreVerilog.psp listPortNum string ""
spectreVerilog.psp portChoiceList string ""
spectreVerilog.psp portChoiceListHeading string ""
spectreVerilog.psp donoise string "yes"
spectreVerilog.psp maxsideband string ""
;spectreVerilog pspOpts partition variables
spectreVerilog.pspOpts tolerance string ""
spectreVerilog.pspOpts gear_order string ""
spectreVerilog.pspOpts solver string ""
spectreVerilog.pspOpts oscsolver string ""
spectreVerilog.pspOpts annotate string "status"
spectreVerilog.pspOpts stats string ""
spectreVerilog.pspOpts freqaxis string ""
;spectreVerilog qpss partition variables
spectreVerilog.qpss enable toggle (nil)
spectreVerilog.qpss paramListBox string ""
spectreVerilog.qpss fundListBox string ""
spectreVerilog.qpss stimName string ""
spectreVerilog.qpss freqName string ""
spectreVerilog.qpss freqVal string ""
spectreVerilog.qpss signalLevel string "Moderate"
spectreVerilog.qpss srcId string ""
spectreVerilog.qpss maxHarms string ""
spectreVerilog.qpss funds string ""
spectreVerilog.qpss maxharms string ""
spectreVerilog.qpss harmonics boolean nil
spectreVerilog.qpss selFreqFrom string "0"
spectreVerilog.qpss selFreqTo string "1e12"
spectreVerilog.qpss harmsAndFreqsTitle string ""
spectreVerilog.qpss harmsAndFreqs string ""
spectreVerilog.qpss errpreset string ""
spectreVerilog.qpss tstab string ""
spectreVerilog.qpss saveinit string ""
spectreVerilog.qpss sweepB boolean nil
spectreVerilog.qpss sweep string "Variable"
spectreVerilog.qpss freqVar string "no"
spectreVerilog.qpss designVar string ""
spectreVerilog.qpss dev string ""
spectreVerilog.qpss deviceParam string ""
spectreVerilog.qpss mod string ""
spectreVerilog.qpss modelParam string ""
spectreVerilog.qpss param string ""
spectreVerilog.qpss rangeType string "Start-Stop"
spectreVerilog.qpss start string ""
spectreVerilog.qpss stop string ""
spectreVerilog.qpss center string ""
spectreVerilog.qpss span string ""
spectreVerilog.qpss incrType string "Linear"
spectreVerilog.qpss stepTypeLin string "Step Size"
spectreVerilog.qpss stepTypeLog string "Points Per Decade"
spectreVerilog.qpss step string ""
spectreVerilog.qpss lin string ""
spectreVerilog.qpss dec string ""
spectreVerilog.qpss log string ""
spectreVerilog.qpss useDiscrete boolean nil
spectreVerilog.qpss values string ""
;spectreVerilog qpssOpts partition variables
spectreVerilog.qpssOpts step string ""
spectreVerilog.qpssOpts maxstep string ""
spectreVerilog.qpssOpts ic string ""
spectreVerilog.qpssOpts skipdc string ""
spectreVerilog.qpssOpts readic string ""
spectreVerilog.qpssOpts readns string ""
spectreVerilog.qpssOpts cmin string ""
spectreVerilog.qpssOpts write string ""
spectreVerilog.qpssOpts writefinal string ""
spectreVerilog.qpssOpts swapfile string ""
spectreVerilog.qpssOpts writeqpss string ""
spectreVerilog.qpssOpts readqpss string ""
spectreVerilog.qpssOpts method string ""
spectreVerilog.qpssOpts relref string ""
spectreVerilog.qpssOpts lteratio string ""
spectreVerilog.qpssOpts steadyratio string ""
spectreVerilog.qpssOpts maxperiods string ""
spectreVerilog.qpssOpts stats string ""
spectreVerilog.qpssOpts annotate string "status"
spectreVerilog.qpssOpts save string ""
spectreVerilog.qpssOpts nestlvl string ""
spectreVerilog.qpssOpts oppoint string ""
spectreVerilog.qpssOpts skipstart string ""
spectreVerilog.qpssOpts skipstop string ""
spectreVerilog.qpssOpts skipcount string ""
spectreVerilog.qpssOpts strobeperiod string ""
spectreVerilog.qpssOpts strobedelay string ""
spectreVerilog.qpssOpts compression string ""
spectreVerilog.qpssOpts maxiters string ""
spectreVerilog.qpssOpts restart string ""
spectreVerilog.qpssOpts tstart string ""
;spectreVerilog qpac partition variables
spectreVerilog.qpac enable toggle (nil)
spectreVerilog.qpac singlePt string "Single-Point []"
spectreVerilog.qpac sweeptype string " "
spectreVerilog.qpac relharmvec string ""
spectreVerilog.qpac rangeType string "Start-Stop"
spectreVerilog.qpac start string ""
spectreVerilog.qpac stop string ""
spectreVerilog.qpac center string ""
spectreVerilog.qpac span string ""
spectreVerilog.qpac incrType string "Automatic"
spectreVerilog.qpac stepTypeLin string "Step Size"
spectreVerilog.qpac stepTypeLog string "Points Per Decade"
spectreVerilog.qpac step string ""
spectreVerilog.qpac lin string ""
spectreVerilog.qpac dec string ""
spectreVerilog.qpac log string ""
spectreVerilog.qpac useDiscrete boolean nil
spectreVerilog.qpac values string ""
spectreVerilog.qpac sbsm string "Maximum clock order"
spectreVerilog.qpac clockmaxharm string ""
spectreVerilog.qpac selFreqFrom string "0"
spectreVerilog.qpac selFreqTo string "1e12"
spectreVerilog.qpac order string "1"
spectreVerilog.qpac harmsAndFreqsTitle string ""
spectreVerilog.qpac harmsAndFreqsTitle2 string ""
spectreVerilog.qpac harmsAndFreqs string ""
spectreVerilog.qpac arrayCoeffs string ""
spectreVerilog.qpac harmCoeffs string ""
spectreVerilog.qpac harmListMem string ""
spectreVerilog.qpac sidevec string ""
;spectreVerilog qpacOpts partition variables
spectreVerilog.qpacOpts tolerance string ""
spectreVerilog.qpacOpts gear_order string ""
spectreVerilog.qpacOpts solver string ""
spectreVerilog.qpacOpts stats string ""
spectreVerilog.qpacOpts annotate string "status"
spectreVerilog.qpacOpts freqaxis string ""
spectreVerilog.qpacOpts save string ""
spectreVerilog.qpacOpts nestlvl string ""
;spectreVerilog qpnoise partition variables
spectreVerilog.qpnoise enable toggle (nil)
spectreVerilog.qpnoise singlePt string "Single-Point []"
spectreVerilog.qpnoise sweeptype string " "
spectreVerilog.qpnoise relharmvec string ""
spectreVerilog.qpnoise rangeType string "Start-Stop"
spectreVerilog.qpnoise start string ""
spectreVerilog.qpnoise stop string ""
spectreVerilog.qpnoise center string ""
spectreVerilog.qpnoise span string ""
spectreVerilog.qpnoise incrType string "Automatic"
spectreVerilog.qpnoise stepTypeLin string "Step Size"
spectreVerilog.qpnoise stepTypeLog string "Points Per Decade"
spectreVerilog.qpnoise step string ""
spectreVerilog.qpnoise lin string ""
spectreVerilog.qpnoise dec string ""
spectreVerilog.qpnoise log string ""
spectreVerilog.qpnoise useDiscrete boolean nil
spectreVerilog.qpnoise values string ""
spectreVerilog.qpnoise sbsm string "Maximum clock order"
spectreVerilog.qpnoise clockmaxharm string ""
spectreVerilog.qpnoise selFreqFrom string "0"
spectreVerilog.qpnoise selFreqTo string "1e12"
spectreVerilog.qpnoise order string "1"
spectreVerilog.qpnoise harmsAndFreqsTitle string ""
spectreVerilog.qpnoise harmsAndFreqsTitle2 string ""
spectreVerilog.qpnoise harmsAndFreqs string ""
spectreVerilog.qpnoise arrayCoeffs string ""
spectreVerilog.qpnoise harmCoeffs string ""
spectreVerilog.qpnoise harmListMem string ""
spectreVerilog.qpnoise sidevec string ""
spectreVerilog.qpnoise outType string "probe"
spectreVerilog.qpnoise p string ""
spectreVerilog.qpnoise n string ""
spectreVerilog.qpnoise oprobe string ""
spectreVerilog.qpnoise inType string "port"
spectreVerilog.qpnoise inVsrc string ""
spectreVerilog.qpnoise inIsrc string ""
spectreVerilog.qpnoise iprobe string ""
spectreVerilog.qpnoise inPort string ""
spectreVerilog.qpnoise refsbSelect string "Enter in field"
spectreVerilog.qpnoise refsideband string ""
spectreVerilog.qpnoise refsbFreqFrom string "0"
spectreVerilog.qpnoise refsbFreqTo string "1e12"
spectreVerilog.qpnoise refsbOrder string "1"
spectreVerilog.qpnoise refsbTitle string ""
spectreVerilog.qpnoise refsbListbox string ""
;spectreVerilog qpnoiseOpts partition variables
spectreVerilog.qpnoiseOpts tolerance string ""
spectreVerilog.qpnoiseOpts gear_order string ""
spectreVerilog.qpnoiseOpts solver string ""
spectreVerilog.qpnoiseOpts stats string ""
spectreVerilog.qpnoiseOpts annotate string "status"
spectreVerilog.qpnoiseOpts save string ""
spectreVerilog.qpnoiseOpts nestlvl string ""
spectreVerilog.qpnoiseOpts saveallsidebands string ""
;spectreVerilog qpxf partition variables
spectreVerilog.qpxf enable toggle (nil)
spectreVerilog.qpxf singlePt string "Single-Point []"
spectreVerilog.qpxf sweeptype string " "
spectreVerilog.qpxf relharmvec string ""
spectreVerilog.qpxf rangeType string "Start-Stop"
spectreVerilog.qpxf start string ""
spectreVerilog.qpxf stop string ""
spectreVerilog.qpxf center string ""
spectreVerilog.qpxf span string ""
spectreVerilog.qpxf incrType string "Automatic"
spectreVerilog.qpxf stepTypeLin string "Step Size"
spectreVerilog.qpxf stepTypeLog string "Points Per Decade"
spectreVerilog.qpxf step string ""
spectreVerilog.qpxf lin string ""
spectreVerilog.qpxf dec string ""
spectreVerilog.qpxf log string ""
spectreVerilog.qpxf useDiscrete boolean nil
spectreVerilog.qpxf values string ""
spectreVerilog.qpxf sbsm string "Maximum clock order"
spectreVerilog.qpxf clockmaxharm string ""
spectreVerilog.qpxf selFreqFrom string "0"
spectreVerilog.qpxf selFreqTo string "1e12"
spectreVerilog.qpxf order string "1"
spectreVerilog.qpxf harmsAndFreqsTitle string ""
spectreVerilog.qpxf harmsAndFreqsTitle2 string ""
spectreVerilog.qpxf harmsAndFreqs string ""
spectreVerilog.qpxf arrayCoeffs string ""
spectreVerilog.qpxf harmCoeffs string ""
spectreVerilog.qpxf harmListMem string ""
spectreVerilog.qpxf sidevec string ""
spectreVerilog.qpxf outType string "voltage"
spectreVerilog.qpxf p string ""
spectreVerilog.qpxf n string ""
spectreVerilog.qpxf probe string ""
;spectreVerilog qpxfOpts partition variables
spectreVerilog.qpxfOpts tolerance string ""
spectreVerilog.qpxfOpts gear_order string ""
spectreVerilog.qpxfOpts solver string ""
spectreVerilog.qpxfOpts stats string ""
spectreVerilog.qpxfOpts annotate string "status"
spectreVerilog.qpxfOpts stimuli string ""
spectreVerilog.qpxfOpts freqaxis string ""
spectreVerilog.qpxfOpts save string ""
spectreVerilog.qpxfOpts nestlvl string ""
;spectreVerilog qpsp partition variables
spectreVerilog.qpsp enable toggle (nil)
spectreVerilog.qpsp singlePt string "Single-Point []"
spectreVerilog.qpsp sweeptype string " "
spectreVerilog.qpsp rangeType string "Start-Stop"
spectreVerilog.qpsp start string ""
spectreVerilog.qpsp stop string ""
spectreVerilog.qpsp center string ""
spectreVerilog.qpsp span string ""
spectreVerilog.qpsp incrType string "Automatic"
spectreVerilog.qpsp stepTypeLin string "Step Size"
spectreVerilog.qpsp stepTypeLog string "Points Per Decade"
spectreVerilog.qpsp step string ""
spectreVerilog.qpsp lin string ""
spectreVerilog.qpsp dec string ""
spectreVerilog.qpsp log string ""
spectreVerilog.qpsp useDiscrete boolean nil
spectreVerilog.qpsp values string ""
spectreVerilog.qpsp portharmsvec string ""
spectreVerilog.qpsp ports string ""
spectreVerilog.qpsp selectPorts boolean t
spectreVerilog.qpsp harmsvec string ""
spectreVerilog.qpsp freqRange string ""
spectreVerilog.qpsp listPortHarm string ""
spectreVerilog.qpsp listPortName string ""
spectreVerilog.qpsp listPortNum string ""
spectreVerilog.qpsp portChoiceList string ""
spectreVerilog.qpsp portChoiceListHeading string ""
spectreVerilog.qpsp donoise string "yes"
spectreVerilog.qpsp clockmaxharm string ""
;spectreVerilog qpspOpts partition variables
spectreVerilog.qpspOpts tolerance string ""
spectreVerilog.qpspOpts gear_order string ""
spectreVerilog.qpspOpts solver string ""
spectreVerilog.qpspOpts annotate string "status"
spectreVerilog.qpspOpts stats string ""
spectreVerilog.qpspOpts freqaxis string ""
;spectreVerilog sens partition variables
spectreVerilog.sens enable toggle (nil)
spectreVerilog.sens sensType toggle (nil nil nil)
spectreVerilog.sens analyses_list string ""
spectreVerilog.sens outputs string ""
spectreVerilog.sens output_list string ""
spectreVerilog.sens net string ""
spectreVerilog.sens term string ""
;spectreVerilog sensOpts partition variables
;spice3 environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spice3 outputs partition variables
spice3.outputs allAnalogNV boolean t
spice3.outputs allAnalogTC boolean nil
;spice3 envOpts partition variables
spice3.envOpts stopViewList string "spice3"
spice3.envOpts printComments boolean nil
spice3.envOpts autoDisplay boolean t
spice3.envOpts switchViewList string "spice3 cmos_sch cmos.sch schematic veriloga ahdl"
;spice3 init partition variables
;spice3 opts partition variables
spice3.opts ITL5 string "5000"
spice3.opts ITL4 string "10"
spice3.opts DEFAD string "0.0"
spice3.opts RELTOL string "1e-3"
spice3.opts METHOD string ""
spice3.opts DEFAS string "0.0"
spice3.opts CHGTOL string "1e-14"
spice3.opts GMIN string "1e-12"
spice3.opts DEFW string "100.0"
spice3.opts TEMP string "27"
spice3.opts PIVREL string "1e-3"
spice3.opts TRTOL string "7.0"
spice3.opts VNTOL string "1e-6"
spice3.opts DEFL string "100.0"
spice3.opts ITL3 string "4"
spice3.opts ITL2 string "50"
spice3.opts ITL1 string "100"
spice3.opts TNOM string "27"
spice3.opts PIVTOL string "1e-13"
spice3.opts ABSTOL string "1e-12"
;spice3 dc partition variables
spice3.dc enable toggle (nil)
spice3.dc vstart string ""
spice3.dc vstop string ""
spice3.dc vincr string ""
spice3.dc srcnam string ""
;spice3 dcOpts partition variables
;spice3 ac partition variables
spice3.ac enable toggle (nil)
spice3.ac fstart string ""
spice3.ac fstop string ""
spice3.ac incrType string "DEC"
spice3.ac log string ""
spice3.ac lin string ""
;spice3 acOpts partition variables
;spice3 tran partition variables
spice3.tran enable toggle (nil)
spice3.tran tstart string ""
spice3.tran tstop string ""
spice3.tran tstep string ""
spice3.tran tmax string ""
;spice3 tranOpts partition variables
;SCA Extraction Environment Defaults
;FORMAT: tool[.partition] varName type value private {choices, minmax} comment
subx subRunDir string "./SCA"
subx subProcFile string "./sample.proc"
subx subModelName string "substrate"
subx subAccuLevel string "medium"
subx subFreq string "1e9"
subx subSync boolean t
subx subNetexpDefault string "scagnd!"
subx subNetexpProp string ""
subx subMethod string "full"
;User Preference Defaults
ui winPlaceStyle boolean nil
ui setWinTraversal boolean nil
ui showScrollBars boolean nil
ui showPromptLines boolean t
ui showStatusLines boolean t
ui showFixedMenu cyclic "On Left-Side "
ui showFixedMenuLabels boolean t
ui infix boolean nil
ui showOptionForms boolean nil
ui undoLevel int 1
ui nestLimit int 5
ui dblClkTime int 200
ui beepVolume int 0
ui textFont string "-*-courier-medium-r-*-*-12-*-*-*-*-*-iso8859-1"
ui formButtonLocation cyclic "Top "
;Log Filter Defaults
ui menuCmdInput boolean nil
ui promptInput boolean nil
ui userOutput boolean t
ui menuCmdOutput boolean nil
ui progResultsOutput boolean t
ui errorMsg boolean t
ui warningMsg boolean t
ui dragDisplayHint string "normal"
vhdl analyzeMode cyclic "on"
vhdl batchScriptFile string ""
vhdl batchSim cyclic "interactive"
vhdl compareSimDB string "simcmp.log"
vhdl Cosim9404 boolean nil
vhdl createVHDLDir boolean t
vhdl currentSimDB string ""
vhdl dataLocation string ""
vhdl defAttributes string ""
vhdl defBodyViewName string "body"
vhdl defConfigViewName string "configuration"
vhdl defDataDirectory string "vhdllib"
vhdl defEntityViewName string "entity"
vhdl defGenerics string ""
vhdl defGlobals string "(("vdd!" "'1'")("gnd!" "'0'"))"
vhdl defPackageNames string "ieee.std_logic_1164.all"
vhdl defPackageViewName string "package"
vhdl defScalarType string "std_ulogic"
vhdl defVectorType string "std_ulogic_vector"
vhdl defViewName string "vhdl"
vhdl deleteVHDLDir boolean nil
vhdl displaySimCmpResults boolean t
vhdl elaborateMode cyclic "on"
vhdl exportCatFiles boolean t
vhdl exportDirectory string ""
vhdl exportLibNameExt string ".exp"
vhdl exportNetlist cyclic "off"
vhdl generateComponentConfig boolean nil
vhdl goldenSimDB string ""
vhdl ignoreWarnings boolean nil
vhdl importCaseSensitivity boolean t
vhdl importCompatibilityOpt boolean nil
vhdl importCompileAfterImport boolean nil
vhdl importCompilerOptions string ""
vhdl importComponentDensity int 0
vhdl importConfig boolean nil
vhdl importFileFilter string "*.vhd"
vhdl importFontHeight float 0.0625
vhdl importFullPlaceRoute boolean t
vhdl importGenSymbols boolean nil
vhdl importGroundLiterals string "'0'"
vhdl importGroundNetName string "gnd!"
vhdl importGroundType string "std_ulogic"
vhdl importIgnoreContassFunc boolean nil
vhdl importIgnoreExtraPins boolean nil
vhdl importLibName string ""
vhdl importLineComponentSpacing float 0.5
vhdl importLineLineSpacing float 0.2
vhdl importMaxNoCols int 1024
vhdl importMaxNoRows int 1024
vhdl importMinmizeCrossovers boolean t
vhdl importOptimizeLabels boolean t
vhdl importOverwriteExistingView boolean t
vhdl importPinPlacement cyclic "Left and Right Sides"
vhdl importPinPlacementFile string ""
vhdl importPowerLiterals string "'1'"
vhdl importPowerNetName string "vdd!"
vhdl importPowerType string "std_ulogic"
vhdl importReferenceLibraries string "basic US_8ths ieee std sample"
vhdl importRunInBackground boolean t
vhdl importSeparateUnits boolean t
vhdl importSheetBorderSize string ""
vhdl importSquareSchematics boolean t
vhdl importStructuralViewType cyclic "schematic"
vhdl importSummaryFile string "./vhdlin.summary"
vhdl importSymbolViewName string "symbol"
vhdl importv93Opt boolean nil
vhdl importWorkLibName string ""
vhdl invokeLaunchTool boolean nil
vhdl invokeLeapfrogSystemWindow boolean nil
vhdl invokeNCTools boolean t
vhdl libCellViewCaseSensitive boolean t
vhdl maxErrors int 10
vhdl netConfig string "config1"
vhdl netHierSpec cyclic "Simple"
vhdl netIgnoreUnboundCells boolean nil
vhdl netMode cyclic "incremental"
vhdl netScope cyclic "hierarchy"
vhdl overwriteEntity boolean nil
vhdl portMapMode cyclic "named association"
vhdl printCommand string "lpr"
vhdl rangeDir cyclic "default"
vhdl remoteFileAccess cyclic "Automount"
vhdl remoteHostName string "localhost"
vhdl remoteSim cyclic "locally"
vhdl runCheckBeforeSim boolean t
vhdl schHdlParseUsingNcvhdl boolean t
vhdl simCompareLength int 100
vhdl simCompareOffset int 0
vhdl simModel string "SIM"
vhdl simTimeUnits cyclic "ns"
vhdl simTolerance int 0
vhdl stopLibList string "basic sample ieee"
vhdl stopViewList string "symbol"
vhdl switchViewList string "stimulus schematic structure dataflow behavior symbol"
vhdl synergySourceLibrary string ""
vhdl synergySymbolLibraries string "basic US_8ths"
vhdl testBenchCellName string "test"
vhdl testBenchLibName string ""
vhdl testBenchStimulusFile string ""
vhdl testBenchViewName string "stimulus"
vhdl testModeOn boolean nil
vhdl topCellName string ""
vhdl topLevelInstanceName string "dut"
vhdl topLibraryName string ""
vhdl topVersion string ""
vhdl topViewName string "schematic"
vhdl translateMode cyclic "library"
vhdl translateTypes toggle (t t t)
vhdl useUserLibraries boolean nil
vhdl verilogNetlistOpts string ""
vhdl verilogRunDir string ""
vhdl verilogSimOpts string "-q"
vhdl vhdlIdentCaseSensitive boolean t
vhdl whichVLibsFile cyclic "user"
vhdl workCellName string ""
vhdl workLibraryName string ""
vhdl workVersion string ""
vhdl workViewName string "schematic"
vhdlams Cosim9404 boolean nil
vhdlams analyzeMode cyclic "on"
vhdlams batchScriptFile string ""
vhdlams batchSim cyclic "interactive"
vhdlams compareSimDB string "simcmp.log"
vhdlams createVHDLDir boolean t
vhdlams currentSimDB string ""
vhdlams dataLocation string ""
vhdlams defAttributes string ""
vhdlams defBodyViewName string "body"
vhdlams defConfigViewName string "configuration"
vhdlams defDataDirectory string "vhdllib"
vhdlams defEntityViewName string "entity"
vhdlams defGenerics string ""
vhdlams defGlobals string "(("vdd!" "'1'")("gnd!" "'0'"))"
vhdlams defPackageNames string "ieee.std_logic_1164.all ieee.electrical_systems.all"
vhdlams defPackageViewName string "package"
vhdlams defScalarType string "electrical"
vhdlams defVectorType string "std_ulogic_vector"
vhdlams defScalarDomain string "terminal"
vhdlams defVectorDomain string "signal"
vhdlams defViewName string "vhdl"
vhdlams deleteVHDLDir boolean nil
vhdlams displaySimCmpResults boolean t
vhdlams elaborateMode cyclic "on"
vhdlams exportCatFiles boolean t
vhdlams exportDirectory string ""
vhdlams exportLibNameExt string ".exp"
vhdlams exportNetlist cyclic "off"
vhdlams generateComponentConfig boolean nil
vhdlams goldenSimDB string ""
vhdlams ignoreWarnings boolean nil
vhdlams importCaseSensitivity boolean t
vhdlams importCompatibilityOpt boolean nil
vhdlams importCompileAfterImport boolean nil
vhdlams importCompilerOptions string ""
vhdlams importComponentDensity int 0
vhdlams importConfig boolean nil
vhdlams importFileFilter string "*.vhd"
vhdlams importFontHeight float 0.0625
vhdlams importFullPlaceRoute boolean t
vhdlams importGenSymbols boolean nil
vhdlams importGroundLiterals string "'0'"
vhdlams importGroundNetName string "gnd!"
vhdlams importGroundType string "std_ulogic"
vhdlams importIgnoreContassFunc boolean nil
vhdlams importIgnoreExtraPins boolean nil
vhdlams importLibName string ""
vhdlams importLineComponentSpacing float 0.5
vhdlams importLineLineSpacing float 0.2
vhdlams importMaxNoCols int 1024
vhdlams importMaxNoRows int 1024
vhdlams importMinmizeCrossovers boolean t
vhdlams importOptimizeLabels boolean t
vhdlams importOverwriteExistingView boolean t
vhdlams importPinPlacement cyclic "Left and Right Sides"
vhdlams importPinPlacementFile string ""
vhdlams importPowerLiterals string "'1'"
vhdlams importPowerNetName string "vdd!"
vhdlams importPowerType string "std_ulogic"
vhdlams importReferenceLibraries string "basic US_8ths ieee std sample"
vhdlams importRunInBackground boolean t
vhdlams importSeparateUnits boolean t
vhdlams importSheetBorderSize string ""
vhdlams importSquareSchematics boolean t
vhdlams importStructuralViewType cyclic "schematic"
vhdlams importSummaryFile string "./vhdlin.summary"
vhdlams importSymbolViewName string "symbol"
vhdlams importWorkLibName string ""
vhdlams importv93Opt boolean nil
vhdlams invokeLaunchTool boolean nil
vhdlams invokeLeapfrogSystemWindow boolean nil
vhdlams invokeNCTools boolean t
vhdlams libCellViewCaseSensitive boolean t
vhdlams maxErrors int 10
vhdlams netConfig string "config1"
vhdlams netHierSpec cyclic "Simple"
vhdlams netIgnoreUnboundCells boolean nil
vhdlams netMode cyclic "incremental"
vhdlams netScope cyclic "hierarchy"
vhdlams overwriteEntity boolean nil
vhdlams portMapMode cyclic "named association"
vhdlams printCommand string "lpr"
vhdlams rangeDir cyclic "default"
vhdlams remoteFileAccess cyclic "Automount"
vhdlams remoteHostName string "localhost"
vhdlams remoteSim cyclic "locally"
vhdlams runCheckBeforeSim boolean t
vhdlams schHdlParseUsingNcvhdl boolean t
vhdlams simCompareLength int 100
vhdlams simCompareOffset int 0
vhdlams simModel string "SIM"
vhdlams simTimeUnits cyclic "ns"
vhdlams simTolerance int 0
vhdlams stopLibList string "basic sample ieee"
vhdlams stopViewList string "symbol"
vhdlams switchViewList string "stimulus schematic structure dataflow behavior symbol"
vhdlams synergySourceLibrary string ""
vhdlams synergySymbolLibraries string "basic US_8ths"
vhdlams testBenchCellName string "test"
vhdlams testBenchLibName string ""
vhdlams testBenchStimulusFile string ""
vhdlams testBenchViewName string "stimulus"
vhdlams testModeOn boolean nil
vhdlams topCellName string ""
vhdlams topLevelInstanceName string "dut"
vhdlams topLibraryName string ""
vhdlams topVersion string ""
vhdlams topViewName string "schematic"
vhdlams translateMode cyclic "library"
vhdlams translateTypes toggle (t t t)
vhdlams verilogNetlistOpts string ""
vhdlams verilogRunDir string ""
vhdlams verilogSimOpts string "-q"
vhdlams vhdlIdentCaseSensitive boolean t
vhdlams whichVLibsFile cyclic "user"
vhdlams workCellName string ""
vhdlams workLibraryName string ""
vhdlams workVersion string ""
vhdlams workViewName string "schematic"
Describe correctly.
State folder don't exist in the simulation folder.
Simulation states exist in test bench cell view or state directory.
Which one do you use ?
What value do you set for followings ?
"asimenv" "saveDir"
"asimenv.startup" "projectDir"
"asimenv" "saveAsCellview"
Show me ".cdsinit" and ".cdsenv" which you use at Univeristy Lab.
Show me ".cdsinit" and ".cdsenv" which you use at PC.
These files are located in both home_directory and work_directrory where you launch Cadence Virtuoso.
I just find .cdsinit & .cdsenv files.
.cdsinit file for my work directory is:
filepath: <cds_install_dir>/samples/local/cdsinit
dfII version: 4.4
This file should be copied as <cds_install_dir>/local/.cdsinit
and customized as a site startup file. The site startup file is
read and executed when the Design Framework II software starts.
This file can load all the application configuration files and
application bind key files.
It also sets the library search path ( which may be overriden by the
user customization file.
Finally this file transfers control to the user by executing the
The user customization file may be
./.cdsinit - .cdsinit in the working directory
~/.cdsinit - .cdsinit in the user's home directory
This site file checks if a .cdsinit exists in the working directory
and executes it. If .cdsinit does not exist in the user's working
directory then ~/.cdsinit is executed if it exists.
Please read the entire file and the comments before you start
customizing the file. See the section below on File Installation
for a list of sample files supplied.
There are bind key definition files supplied for different
applications. The relevant bind key definitions files must
be loaded if you want bind keys defined for that application.
See section LOAD APPLICATION BIND KEY DEFINITIONS.
In order for any window placements to work correctly the following
X resource must be set in the .Xdefaults or .xresources file
pertaining to your hardware platform.
Mwm*clientAutoPlace: False
After setting the resource read in the resource file with the command
xrdb <resource_filename>
and restart the Motif window manager.
The function
prependInstallPath("string")
adds the installation path to the string argument
For this reason there should NOT be a space at the beginning of the
string.
There SHOULD be a space at the end of the string if more paths are to
follow.
This function is used to make path specification in this file
independant of the exact installation path.
The function let() creates local variables ( example: libPath ).
This makes sure that any global variables are not accidentally modified.
; File Installation
; CONFIGURATION FILES
; The following configuration files are delivered in the 4.4 release:
; <cds_install_dir>/samples/local
; aaConfig.il - analog
; dciConfig.il - Cadence to Synopsys Interface
; metConfig.il - Designing with Composer
; using metric measurements
; sysConfig.il - systems
; uiConfig.il - user interface
; The configuration files are used to initialize parameters and
; forms.
; ENVIRONMENT VARIABLES
; Schematic, Layout and Graphic environment variable defaults are now found in
; <cds_install_dir>/etc/tools/
; layout/.cdsenv
; schematic/.cdsenv
; graphic/.cdsenv
; These can be customized in the user's ./cdsenv and ~/.cdsenv files.
; A .cdsenv file can be created by using CIW->options->save defaults.
; BIND KEY DEFINITION FILES
; The following bind key definition files are delivered in the
; 4.3 release:
; leBindKeys.il - layout editor
; schBindKeys.il - schematic editor
; CUSTOMIZATION FILES
; The following customization files are delivered in the
; 4.3 release:
; <cds_install_dir>/samples/local/cdsinit - site customization
; <cds_install_dir>/cdsuser/.cdsinit - user customization
; ADMINISTRATION
; The site administrator should install the "site" files as follows: ;
; 1. Copy <cds_install_dir>/samples/local/cdsinit
; to <cds_install_dir>/local/.cdsinit
; and modify the file
; (If <cds_install_dir>/local does not exist create it)
; <cds_install_dir>/local is the site customization directory.
; This directory is not sent as part of the software. The site
; administrator must create this directory. Whenever software is
; upgraded the Cadence installation process retains the site
; administration directory if it exists.
; 2. If default configuration needs to be changed copy the
; relevant configuration file
; from: 4.3/samples/local
; to: 4.3/local
; and modify the file(s)
; 3. If default bind key definitions need to be changed copy the
; relevant bind key definition file
; to: 4.3/local
; 4. Copy 4.3/cdsuser/.cdsinit to the user's home or working
; directory - Do this step only if the user does not already
; have a .cdsinit file.
; If after site customization each user wants to customize
; portions of the configuration or bind keys definitions
; they should copy the relevant sections from the files in
; 4.3/samples/local
; into
; the user's customization file
; ./.cdsinit or ~/.cdsinit
; FILE LOADING ORDER
; 1. The configuration files are not automatically loaded.
; Remove the comment on the filename line to load the file.
; The search order for the configuration files is:
; 4.3/local
; 2. The bind key definition files are not automatically loaded.
; The search order for the bind key definition files is:
; 4.3/local
; 4.3/samples/local
; 3. Load user customization file
; ./.cdsinit - load .cdsinit in the working directory if it exists
; else
; ~/.cdsinit - load .cdsinit in the user's home directory
; This file does NOT load both user customization files even if both exist.
;# LOAD APPLICATION CONFIGURATION FILES
;Remove the comment ; if you want to load the specific configuration file
;If you do not load the configuration files the applications will use the
;default configurations.
let( (configFileList file path saveSkillPath)
configFileList = '(
; "aaConfig.il"
; "dciConfig.il"
; "leConfig.il"
; "metConfig.il"
; "schConfig.il"
; "sysConfig.il"
; "uiConfig.il"
; This is the path that is searched for the files
path = strcat(
; If you want to add another path add it here as a string
prependInstallPath("local ")
saveSkillPath=getSkillPath()
setSkillPath(path)
foreach(file configFileList
if(isFile(file) then
loadi(file)
setSkillPath(saveSkillPath)
hiiSetFont("text" "-adobe-courier-bold-r-*-*-12-*")
;# LOAD APPLICATION BIND KEY DEFINITIONS
;Add the comment ; if you do not want to load the specific
;bind key definition file.
;If you do not load the bind key definitions the applications will not
;have any bind keys defined.
;If you load the bind key definition file but the application is not
;registered ( product not licensed or checked out ) then you might get
;a warning that looks like
; *WARNING* "Schematics is not registered yet"
;This warning can be ignored if you know that the product is not
;licensed or checked out.
let( (bindKeyFileList file path saveSkillPath)
bindKeyFileList = '(
"leBindKeys.il"
"schBindKeys.il"
path = strcat(
prependInstallPath("samples/local")
setSkillPath(path)
foreach(file bindKeyFileList
if(isFile(file ) then
loadi(file)
; An individual user may wish to add some bindkeys of his/her own or
; over ride some default loaded bindkeys. For more information about
; bindkeys see the manual "SKILL Reference Manual, Language Fundamentals",
; Chapter 4.
; Here is an example of setting one bindkey on "F2" than prints
; "Hello world" to the CIW when pressed in the CIW.
;hiSetBindKey("Command Interpreter" "<Key>F2" "printf("Hello World")")
; Here is an example of setting keys for more than one application
;let( (app appList)
; appList = '(
; "Command Interpreter"
; "Schematics"
; "Symbol"
; Add other applications here
; foreach(app appList
; hiSetBindKey(app "<Key>F4" "printf("Hello ")")
; hiSetBindKey(app "<Key>F5" "printf("World")")
;# SETTINGS FOR SKILL PATH and SKILL PROGRAMMING
; The function sstatus() sets the status of variables
; The variable writeProtect controls if a SKILL function can be
; redefined or not;
; Any functions defined after writeProtect = t CANNOT be redefined
; Any functions defined after writeProtect = nil CAN be redefined
; If you are going to create SKILL programs and define functions set the
; status of writeProtect to nil at the beginning of your session.
; Set skill search path. The SKILL search path contains directories
; to be searched to locate SKILL programs when program names are
; specified without full path names.
; The operation could be reading, writing or loading a SKILL program.
; Source technology files are considered SKILL files and when loading
; or dumping the technology file SKILL search path will be used.
sstatus(writeProtect nil)
let((skillPath)
skillPath= strcat(
". ~ " ; Current & home directory
prependInstallPath("samples/techfile ") ; sample source technology files
setSkillPath(skillPath)
; VERIFICATION - DIVA/INQUERY/DRACULA ENCAPS #
; There are no configuration variables for these
; applications to be set in the .cdsinit. You may
; need to create a .simrc file, using the example
; in <cds_install_dir>/cdsuser/.simrc
;# PLACE AND ROUTE - CELL3, CE, BE, PREVIEW,GE #
; The geSetProbeNetStopLevel default is zero.
; To probe routing in channels, it must be >= 2.
; geSetProbeNetStopLevel(0) ; 20 is a good number.
;# LAS and COMPACTOR #
; applications to be set in the .cdsinit. You need
; to add information to your technology file. See
; the LAS and COMPACTOR reference manuals for
; details about technology file additions.
;# Customizing the 4.x environment with: #
;# SETTING AmPLD DEFAULTS (Data I/O Abel 4.x) #
; No Setup is required if using the default system shipped from Cadence.
; If you are using your own Abel or need to customize the system Please
; See Appendix A of the Programmable Logic Design System Users Guide.
;# DESIGN FLOWS #
; The design flows can be used with no customization, but customizing
; them for your personal preference can greatly enhance your
; productivity. Please See the Design Flow users guide for details.
; Bring up top flow ...
;amdfTopFlow()
;# MISCELLANEOUS
; Set your own prompt in the CIW. The first argument is the prompt.
; The second argument is not used yet.
; The variable editor defines the text editor to be used when any of
; the applications invoke an editor. For example technology dump and
; edit operation opens an editor window.
; The editor may also be set by
; unix environment variable EDITOR
; setenv EDITOR 'xedit'
; When Design Framework is invoked the SKILL variable editor is set
; to the value of the unix variable EDITOR.
; If EDITOR is not defined the SKILL variable
; editor is set to "vi"
; You may also set the variable to execute a UNIX command
; that invokes an xterm window of given size and location
; and starts an editor program.
; Example:
; editor = "xterm -geometry 80x40 -e emacs"
; Size of xterm in the above example is 80 characters by 40 lines.
; With some editors on certain platforms the variable editor must
; be defined as shown above.
; Some application which require a text editor may be using the UNIX
; variable EDITOR instead of the SKILL variable editor. It is a good
; idea to set the UNIX variable EDITOR to the text editor of your
; choice which will automatically set the SKILL variable editor.
;setPrompts("Ready >" "")
;editor = "xterm -geometry 85x50 -e vi";
printf("END OF SITE CUSTOMIZATION\n")
;# LOAD USER CUSTOMIZATION FILE
;The site customization file is going to load the user
;customization file. In case you have copied this site
;customization file as your user customization file
;comment out or remove the next section to prevent
;recursive loading of ./.cdsinit
load(strcat(getShellEnvVar("SNPS_SIMIF") "/interfaces/simif/virtuoso/discoveryAMS.al"))
load(strcat(getShellEnvVar("MGC_HOME")
"/shared/pkgs/icv.ixl/tools/queryskl/calibre.skl"))
load("./leBindKeys.il")
;//# SONNET CADENCE VIRTUOSO INTERFACE SETUP
;END OF THE SITE CUSTOMIZATION FILE
Also .cdsenv file for my work directory is:
";This is a sample environment variable file containing the default
;values for environment variables in Design Framework II products.
;See the appropriate tool documentation regarding the use and
;choices for each variable.
;To customize your defaults, use this file as a template and place
;a modified version of this file in ../local/.cdsenv. This
;local version should typically reflect the values of your system
;defaults as set by your site coordinator. To specify more personal
;defaults, place a modified version of either this or the
;../local/.cdsenv file into your home directory as .cdsenv.
;Your ../local/.cdsenv file will be loaded first, followed
;by the .cdsenv in your home directory, so any values in ~/.cdsenv
;will override those previously loaded.
;UltraSim environment variables
;UltraSim opts partition variables
UltraSim.opts UsimRAAgeDomain string "loglog"
UltraSim.opts rshort string "1e-6"
UltraSim.opts simSave boolean nil
UltraSim.opts abstoli string "1.00e-12"
UltraSim.opts UsimTAMaxPerTime string ""
UltraSim.opts UsimPAEnabled boolean nil
UltraSim.opts UsimNAOutputSort string "name"
UltraSim.opts simSaveFile string ""
UltraSim.opts UsimTASigNames string ""
UltraSim.opts dc string "Complete DC (1)"
UltraSim.opts TNOMDC string "27"
UltraSim.opts other string ""
UltraSim.opts UsimPADepth string "1"
UltraSim.opts simRestart boolean nil
UltraSim.opts otherSpice string ""
UltraSim.opts wf_tres string "1e-12"
UltraSim.opts UsimPATimeIntervals string ""
UltraSim.opts UsimRAMode string "HCI only"
UltraSim.opts rcr_fmax string "1e9"
UltraSim.opts simTimePoints string ""
UltraSim.opts UsimTASigEdgeType string "rise"
UltraSim.opts UsimRADeltaDToggle boolean t
UltraSim.opts tol string "0.01"
UltraSim.opts wf_reltol string ""
UltraSim.opts wf_abstoli string "1e-12"
UltraSim.opts UsimTARefSigEdgeType string "rise"
UltraSim.opts wf_format string "PSF"
UltraSim.opts UsimRAAgeMethod string "interp"
UltraSim.opts UsimTASigLowThreshold string ""
UltraSim.opts UsimTAEnabled boolean nil
UltraSim.opts UsimTAMinLowTime string ""
UltraSim.opts UsimNA toggle (nil)
UltraSim.opts postl string "No RCR (0)"
UltraSim.opts abstolv string "1.00e-06"
UltraSim.opts diode_method string "Analog Table (A)"
UltraSim.opts UsimRAAgeproc string ""
UltraSim.opts ParasiticRCFile string ""
UltraSim.opts UsimTAMinHighTime string ""
UltraSim.opts UsimOptMethod boolean nil
UltraSim.opts UsimPA toggle (nil)
UltraSim.opts UsimRAMinAge float 0.0
UltraSim.opts UsimTA toggle (nil)
UltraSim.opts UsimTAMaxHighTime string ""
UltraSim.opts wf_abstolv string "1e-6"
UltraSim.opts UsimRADeltaD float 0.1
UltraSim.opts simLoadFile string ""
UltraSim.opts UsimPALimit string ""
UltraSim.opts TEMPDC string "27"
UltraSim.opts UsimTARefSig string ""
UltraSim.opts mos_method string "Analog/MS Table (A)"
UltraSim.opts UsimRANBTIAgeproc string ""
UltraSim.opts wf_filter boolean t
UltraSim.opts UsimTARefSigHighThreshold string ""
UltraSim.opts UsimTANegWindow string ""
UltraSim.opts UsimTASigHighThreshold string ""
UltraSim.opts UsimTAMinPerTime string ""
UltraSim.opts UsimTAReportTitle string ""
UltraSim.opts dump_step string ""
UltraSim.opts speed string "Default (5)"
UltraSim.opts dcut boolean nil
UltraSim.opts UsimPAPort string ""
UltraSim.opts UsimTASubcktName string ""
UltraSim.opts UsimNALimit string ""
UltraSim.opts UsimRAAgingTime string "10y"
UltraSim.opts scale string "1.0"
UltraSim.opts rvshort string "1e-6"
UltraSim.opts UsimPAName string ""
UltraSim.opts analog string "Default (1)"
UltraSim.opts UsimTAMaxLowTime string ""
UltraSim.opts UsimPAOutputSort string "avg"
UltraSim.opts UsimPAPower boolean nil
UltraSim.opts UsimTASetupTime string ""
UltraSim.opts lshort string "0"
UltraSim.opts dcut_field string ""
UltraSim.opts UsimTATrigger string "both"
UltraSim.opts UsimOptMethodHier boolean nil
UltraSim.opts simRepeat string ""
UltraSim.opts sim_mode string "Mixed Signal (MS)"
UltraSim.opts cgndr string "0"
UltraSim.opts UsimTADisplaySetting string ""
UltraSim.opts cgnd string "1e-20"
UltraSim.opts UsimRA toggle (nil)
UltraSim.opts UsimTARefSigLowThreshold string ""
UltraSim.opts UsimTACheckType string "setup"
UltraSim.opts UsimNASortIs string "inc"
UltraSim.opts scalem string "1.0"
UltraSim.opts UsimTADepth string ""
UltraSim.opts UsimPADisplaySetting string ""
UltraSim.opts lvshort string "0"
;UltraSim outputs partition variables
UltraSim.outputs UsimOptionLogicSubckt3 string ""
UltraSim.outputs UsimOptionLogicDepth3 string "1"
UltraSim.outputs UsimOptionProbeAnalog boolean t
UltraSim.outputs UsimOptionAllLogicNV5 boolean nil
UltraSim.outputs UsimOptionLogicLowThreshold string ""
UltraSim.outputs UsimOptionLogicSubckt2 string ""
UltraSim.outputs UsimOptionLogicHighThreshold string ""
UltraSim.outputs UsimOptionLogicIncludeRC boolean nil
UltraSim.outputs UsimOptionLogicSubckt string ""
UltraSim.outputs UsimOptionLogicSubckt5 string ""
UltraSim.outputs UsimOptionLogicDepth4 string "1"
UltraSim.outputs UsimOptionAllAnalogTC boolean nil
UltraSim.outputs UsimOptionAllLogicNV boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC4 boolean nil
UltraSim.outputs UsimOptionLogicDepth string "1"
UltraSim.outputs UsimOptionLogicLowThreshold2 string ""
UltraSim.outputs UsimOptionAllLogicNV2 boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC2 boolean nil
UltraSim.outputs UsimOptionNumberVolThreshold string "1"
UltraSim.outputs UsimOptionLogicSubckt4 string ""
UltraSim.outputs UsimOptionLogicHighThreshold4 string ""
UltraSim.outputs UsimOptionAllAnalogNV boolean nil
UltraSim.outputs UsimOptionLogicLowThreshold5 string ""
UltraSim.outputs UsimOptionIncludeRC boolean nil
UltraSim.outputs UsimOptionDepth string "1"
UltraSim.outputs UsimOptionLogicHighThreshold2 string ""
UltraSim.outputs UsimOptionLogicIncludeRC5 boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC3 boolean nil
UltraSim.outputs UsimOptionLogicHighThreshold3 string ""
UltraSim.outputs UsimOptionLogicDepth5 string "1"
UltraSim.outputs UsimOptionLogicLowThreshold3 string ""
UltraSim.outputs UsimOptionLogicLowThreshold4 string ""
UltraSim.outputs UsimOptionProbeLogic boolean nil
UltraSim.outputs UsimOptionAllLogicNV3 boolean nil
UltraSim.outputs UsimOptionAllLogicNV4 boolean nil
UltraSim.outputs UsimOptionLogicHighThreshold5 string ""
UltraSim.outputs UsimOptionLogicDepth2 string "1"
;UltraSim envOpts partition variables
UltraSim.envOpts stopViewList string "spectre"
UltraSim.envOpts switchViewList string "spectre cmos_sch cmos.sch schematic veriloga"
UltraSim.envOpts netlistFormat string "spectre"
UltraSim.envOpts autoDisplay boolean t
UltraSim.envOpts printComments boolean nil
UltraSim.envOpts UltraSimVectorFile string ""
UltraSim.envOpts UltraSimVcdFile string ""
UltraSim.envOpts userCmdLineOption string ""
UltraSim.envOpts UltraSimVcdInfo string ""
;UltraSim init partition variables
UltraSim.init processPriority int 0
;UltraSim tran partition variables
UltraSim.tran enable toggle (nil)
UltraSim.tran stop string ""
;UltraSim tranOpts partition variables
UltraSim.tranOpts start string ""
UltraSim.tranOpts outputstart string ""
UltraSim.tranOpts step string "1e-9"
UltraSim.tranOpts readic string ""
UltraSim.tranOpts write string "UltraSim.ic"
UltraSim.tranOpts writefinal string "UltraSim.fc"
UltraSim.tranOpts method_new string ""
UltraSim.tranOpts infotimes string ""
UltraSim.tranOpts maxstep string ""
UltraSim.tranOpts max_start string ""
UltraSim.tranOpts max_stop string ""
UltraSim.tranOpts max_subckt string ""
;UltraSimVerilog environment variables
;UltraSimVerilog opts partition variables
UltraSimVerilog.opts rshort string "1e-6"
UltraSimVerilog.opts UsimRAAgeDomain string "loglog"
UltraSimVerilog.opts simSave boolean nil
UltraSimVerilog.opts UsimTAMaxPerTime string ""
UltraSimVerilog.opts abstoli string "1.00e-12"
UltraSimVerilog.opts UsimPAEnabled boolean nil
UltraSimVerilog.opts UsimNAOutputSort string "name"
UltraSimVerilog.opts simSaveFile string ""
UltraSimVerilog.opts UsimTASigNames string ""
UltraSimVerilog.opts TNOMDC string "27"
UltraSimVerilog.opts dc string "Complete DC (1)"
UltraSimVerilog.opts other string ""
UltraSimVerilog.opts otherSpice string ""
UltraSimVerilog.opts simRestart boolean nil
UltraSimVerilog.opts UsimPADepth string "1"
UltraSimVerilog.opts wf_tres string "1e-12"
UltraSimVerilog.opts UsimPATimeIntervals string ""
UltraSimVerilog.opts UsimRAMode string "HCI only"
UltraSimVerilog.opts rcr_fmax string "1e9"
UltraSimVerilog.opts simTimePoints string ""
UltraSimVerilog.opts UsimTASigEdgeType string "rise"
UltraSimVerilog.opts UsimRADeltaDToggle boolean t
UltraSimVerilog.opts tol string "0.01"
UltraSimVerilog.opts wf_reltol string ""
UltraSimVerilog.opts wf_abstoli string "1e-12"
UltraSimVerilog.opts UsimTARefSigEdgeType string "rise"
UltraSimVerilog.opts UsimRAAgeMethod string "interp"
UltraSimVerilog.opts UsimTASigLowThreshold string ""
UltraSimVerilog.opts UsimTAEnabled boolean nil
UltraSimVerilog.opts UsimTAMinLowTime string ""
UltraSimVerilog.opts UsimNA toggle (nil)
UltraSimVerilog.opts postl string "No RCR (0)"
UltraSimVerilog.opts abstolv string "1.00e-06"
UltraSimVerilog.opts diode_method string "Analog Table (A)"
UltraSimVerilog.opts UsimRAAgeproc string ""
UltraSimVerilog.opts ParasiticRCFile string ""
UltraSimVerilog.opts UsimTAMinHighTime string ""
UltraSimVerilog.opts UsimOptMethod boolean nil
UltraSimVerilog.opts UsimPA toggle (nil)
UltraSimVerilog.opts UsimRAMinAge float 0.0
UltraSimVerilog.opts UsimTA toggle (nil)
UltraSimVerilog.opts UsimTAMaxHighTime string ""
UltraSimVerilog.opts wf_abstolv string "1e-6"
UltraSimVerilog.opts UsimRADeltaD float 0.1
UltraSimVerilog.opts simLoadFile string ""
UltraSimVerilog.opts UsimPALimit string ""
UltraSimVerilog.opts TEMPDC string "27"
UltraSimVerilog.opts UsimTARefSig string ""
UltraSimVerilog.opts mos_method string "Analog/MS Table (A)"
UltraSimVerilog.opts UsimRANBTIAgeproc string ""
UltraSimVerilog.opts wf_filter boolean t
UltraSimVerilog.opts UsimTARefSigHighThreshold string ""
UltraSimVerilog.opts UsimTANegWindow string ""
UltraSimVerilog.opts UsimTASigHighThreshold string ""
UltraSimVerilog.opts UsimTAMinPerTime string ""
UltraSimVerilog.opts UsimTAReportTitle string ""
UltraSimVerilog.opts dump_step string ""
UltraSimVerilog.opts speed string "Default (5)"
UltraSimVerilog.opts dcut boolean nil
UltraSimVerilog.opts UsimPAPort string ""
UltraSimVerilog.opts UsimTASubcktName string ""
UltraSimVerilog.opts UsimNALimit string ""
UltraSimVerilog.opts UsimRAAgingTime string "10y"
UltraSimVerilog.opts scale string "1.0"
UltraSimVerilog.opts rvshort string "1e-6"
UltraSimVerilog.opts UsimPAName string ""
UltraSimVerilog.opts analog string "Default (1)"
UltraSimVerilog.opts UsimTAMaxLowTime string ""
UltraSimVerilog.opts UsimPAOutputSort string "avg"
UltraSimVerilog.opts UsimPAPower boolean nil
UltraSimVerilog.opts UsimTASetupTime string ""
UltraSimVerilog.opts lshort string "0"
UltraSimVerilog.opts dcut_field string ""
UltraSimVerilog.opts UsimTATrigger string "both"
UltraSimVerilog.opts UsimOptMethodHier boolean nil
UltraSimVerilog.opts simRepeat string ""
UltraSimVerilog.opts UsimTADisplaySetting string ""
UltraSimVerilog.opts cgndr string "0"
UltraSimVerilog.opts sim_mode string "Mixed Signal (MS)"
UltraSimVerilog.opts cgnd string "1e-20"
UltraSimVerilog.opts UsimRA toggle (nil)
UltraSimVerilog.opts UsimTARefSigLowThreshold string ""
UltraSimVerilog.opts UsimTACheckType string "setup"
UltraSimVerilog.opts UsimNASortIs string "inc"
UltraSimVerilog.opts scalem string "1.0"
UltraSimVerilog.opts UsimPADisplaySetting string ""
UltraSimVerilog.opts UsimTADepth string ""
UltraSimVerilog.opts lvshort string "0"
;UltraSimVerilog outputs partition variables
UltraSimVerilog.outputs UsimOptionLogicSubckt3 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth3 string "1"
UltraSimVerilog.outputs UsimOptionProbeAnalog boolean t
UltraSimVerilog.outputs UsimOptionAllLogicNV5 boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt2 string ""
UltraSimVerilog.outputs UsimOptionLogicHighThreshold string ""
UltraSimVerilog.outputs UsimOptionLogicIncludeRC boolean nil
UltraSimVerilog.outputs UsimOptionLogicSubckt string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt5 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth4 string "1"
UltraSimVerilog.outputs UsimOptionAllAnalogTC boolean nil
UltraSimVerilog.outputs UsimOptionAllLogicNV boolean nil
UltraSimVerilog.outputs UsimOptionLogicIncludeRC4 boolean nil
UltraSimVerilog.outputs UsimOptionLogicDepth string "1"
UltraSimVerilog.outputs UsimOptionLogicLowThreshold2 string ""
UltraSimVerilog.outputs UsimOptionAllLogicNV2 boolean nil
UltraSimVerilog.outputs UsimOptionNumberVolThreshold string "1"
UltraSimVerilog.outputs UsimOptionLogicIncludeRC2 boolean nil
UltraSimVerilog.outputs UsimOptionAllAnalogNV boolean nil
UltraSimVerilog.outputs UsimOptionLogicHighThreshold4 string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt4 string ""
UltraSimVerilog.outputs UsimOptionDepth string "1"
UltraSimVerilog.outputs UsimOptionIncludeRC boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold5 string ""
UltraSimVerilog.outputs allDigitalNV boolean t
UltraSimVerilog.outputs UsimOptionLogicHighThreshold2 string ""
UltraSimVerilog.outputs UsimOptionLogicHighThreshold3 string ""
UltraSimVerilog.outputs UsimOptionLogicIncludeRC3 boolean nil
UltraSimVerilog.outputs UsimOptionLogicIncludeRC5 boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold3 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth5 string "1"
UltraSimVerilog.outputs UsimOptionProbeLogic boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold4 string ""
UltraSimVerilog.outputs UsimOptionAllLogicNV3 boolean nil
UltraSimVerilog.outputs UsimOptionAllLogicNV4 boolean nil
UltraSimVerilog.outputs UsimOptionLogicDepth2 string "1"
UltraSimVerilog.outputs UsimOptionLogicHighThreshold5 string ""
;UltraSimVerilog verimixOpts partition variables
UltraSimVerilog.verimixOpts filename6 string ""
UltraSimVerilog.verimixOpts maxDCIter int 0
UltraSimVerilog.verimixOpts scope1 string ""
UltraSimVerilog.verimixOpts scope10 string ""
UltraSimVerilog.verimixOpts filename8 string ""
UltraSimVerilog.verimixOpts dcInterval float 0.0
UltraSimVerilog.verimixOpts scope3 string ""
UltraSimVerilog.verimixOpts scope8 string ""
UltraSimVerilog.verimixOpts scope7 string ""
UltraSimVerilog.verimixOpts filename7 string ""
UltraSimVerilog.verimixOpts scope string ""
UltraSimVerilog.verimixOpts filename4 string ""
UltraSimVerilog.verimixOpts filename string ""
UltraSimVerilog.verimixOpts filename1 string ""
UltraSimVerilog.verimixOpts scope9 string ""
UltraSimVerilog.verimixOpts importsdfswitch boolean nil
UltraSimVerilog.verimixOpts filename2 string ""
UltraSimVerilog.verimixOpts numberofsdffiles int 2
UltraSimVerilog.verimixOpts scope2 string ""
UltraSimVerilog.verimixOpts scope6 string ""
UltraSimVerilog.verimixOpts filename10 string ""
UltraSimVerilog.verimixOpts delaymodechoice string "Ignore"
UltraSimVerilog.verimixOpts sdfmixedswitch boolean t
UltraSimVerilog.verimixOpts filename9 string ""
UltraSimVerilog.verimixOpts scope5 string ""
UltraSimVerilog.verimixOpts filename5 string ""
UltraSimVerilog.verimixOpts filename3 string ""
UltraSimVerilog.verimixOpts scope4 string ""
;UltraSimVerilog verilogOpts partition variables
UltraSimVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
UltraSimVerilog.verilogOpts optionsFile string ""
UltraSimVerilog.verilogOpts twinTurbo boolean nil
UltraSimVerilog.verilogOpts suppressMessages boolean nil
UltraSimVerilog.verilogOpts libraryFile string ""
UltraSimVerilog.verilogOpts behaveProfile boolean nil
UltraSimVerilog.verilogOpts verimixLog string "verilog.log"
UltraSimVerilog.verilogOpts simVision boolean nil
UltraSimVerilog.verilogOpts pulseSpec boolean nil
UltraSimVerilog.verilogOpts commandFile string ""
UltraSimVerilog.verilogOpts pulseError int 100
UltraSimVerilog.verilogOpts stopCompile boolean nil
UltraSimVerilog.verilogOpts keepNodes string "Minimum"
UltraSimVerilog.verilogOpts accelerationCA boolean nil
UltraSimVerilog.verilogOpts turboRadio string "Default"
UltraSimVerilog.verilogOpts libraryDir string ""
UltraSimVerilog.verilogOpts suppressWarnings boolean nil
UltraSimVerilog.verilogOpts accelerationSwitches boolean nil
UltraSimVerilog.verilogOpts accelerationNormal boolean t
UltraSimVerilog.verilogOpts delayType string "Typical"
UltraSimVerilog.verilogOpts pulseReject int 100
UltraSimVerilog.verilogOpts delayMode string "Default"
UltraSimVerilog.verilogOpts vermixBinary string "verilog.vmx"
;UltraSimVerilog init partition variables
UltraSimVerilog.init processPriority int 0
;UltraSimVerilog envOpts partition variables
UltraSimVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
UltraSimVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
UltraSimVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
UltraSimVerilog.envOpts outputFormat string "AWD"
UltraSimVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
UltraSimVerilog.envOpts mspSetupNetlistEscapeName boolean nil
UltraSimVerilog.envOpts autoDisplay boolean t
UltraSimVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
UltraSimVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
UltraSimVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
UltraSimVerilog.envOpts mspSetupNetlistPinMap boolean nil
UltraSimVerilog.envOpts mspSetupNetlistBus boolean t
UltraSimVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
UltraSimVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
UltraSimVerilog.envOpts mspSetupNetlistExplicit boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
UltraSimVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
UltraSimVerilog.envOpts printComments boolean nil
UltraSimVerilog.envOpts UltraSimVectorFile string ""
UltraSimVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
UltraSimVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimTimeValue int 1
UltraSimVerilog.envOpts mspSetupNetlistUseLib boolean nil
UltraSimVerilog.envOpts UltraSimVcdFile string ""
UltraSimVerilog.envOpts mspSetupNetlistNullPort boolean nil
UltraSimVerilog.envOpts mspSetupNetlistDropPortRange boolean t
UltraSimVerilog.envOpts userCmdLineOption string ""
UltraSimVerilog.envOpts mspSetupNetlistUpCase boolean nil
UltraSimVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
UltraSimVerilog.envOpts UltraSimVcdInfo string ""
;UltraSimVerilog tran partition variables
UltraSimVerilog.tran enable toggle (nil)
UltraSimVerilog.tran stop string ""
;UltraSimVerilog tranOpts partition variables
UltraSimVerilog.tranOpts start string ""
UltraSimVerilog.tranOpts outputstart string ""
UltraSimVerilog.tranOpts step string "1e-9"
UltraSimVerilog.tranOpts readic string ""
UltraSimVerilog.tranOpts write string "UltraSim.ic"
UltraSimVerilog.tranOpts writefinal string "UltraSim.fc"
UltraSimVerilog.tranOpts method_new string ""
UltraSimVerilog.tranOpts infotimes string ""
UltraSimVerilog.tranOpts maxstep string ""
UltraSimVerilog.tranOpts max_start string ""
UltraSimVerilog.tranOpts max_stop string ""
UltraSimVerilog.tranOpts max_subckt string ""
;1*******************************************************
;2* DLE/DLR Environment Variables
;3*******************************************************
adle lxLocalAbutment boolean nil
;AMS-Direct Environment Defaults
amsDirect amsCompMode boolean nil
amsDirect amsLSB_MSB boolean nil
amsDirect amsScalarInstances boolean t
amsDirect includeInstCdfParams boolean nil
amsDirect amsVerbose boolean nil
amsDirect amsMaxErrors int 50
amsDirect amsExcludeParams string ""
amsDirect hdlVarFile string ""
amsDirect simRunDirLoc string ""
amsDirect logFileName string "ams_direct.log"
amsDirect initFile string ""
amsDirect amsDefinitionViews string ""
amsDirect amsExpScalingFactor cyclic "no"
amsDirect modifyParamScope cyclic "no"
amsDirect.prep allowUndefParams boolean t
amsDirect.prep detailedDisciplineRes boolean nil
amsDirect.prep forceGlobalSync boolean nil
amsDirect.prep ncsimGUI boolean t
amsDirect.prep ncsimTcl boolean nil
amsDirect.prep runNcelab boolean t
amsDirect.prep runNcsim boolean t
amsDirect.prep use5xForVHDL boolean t
amsDirect.prep ncelabAnnoSimtime boolean nil
amsDirect.prep ncelabCoverage boolean nil
amsDirect.prep ncelabEpulseNeg boolean nil
amsDirect.prep ncelabIeee1634 boolean nil
amsDirect.prep ncelabInterconnmultisrc boolean nil
amsDirect.prep ncelabLibverbose boolean nil
amsDirect.prep ncelabMessages boolean nil
amsDirect.prep ncelabNostdout boolean nil
amsDirect.prep ncelabNoTchkMsg boolean nil
amsDirect.prep ncelabNoTchkXgen boolean nil
amsDirect.prep ncelabNotimingchecks boolean nil
amsDirect.prep ncelabNovitalaccl boolean t
amsDirect.prep ncelabNoVpdmsg boolean nil
amsDirect.prep ncelabNoVpdXgen boolean nil
amsDirect.prep ncelabNtcWarn boolean nil
amsDirect.prep ncelabPathpulse boolean nil
amsDirect.prep ncelabPlinooptwarn boolean nil
amsDirect.prep ncelabPlinowarn boolean nil
amsDirect.prep ncelabPresrvResFn boolean nil
amsDirect.prep ncelabSdfNocheckCelltype boolean nil
amsDirect.prep ncelabSdfNoHeader boolean nil
amsDirect.prep ncelabSdfNoWarnings boolean nil
amsDirect.prep ncelabSdfWorstcaseRounding boolean nil
amsDirect.prep ncelabStatus boolean t
amsDirect.prep ncelabUpdate boolean t
amsDirect.prep ncelabV93 boolean nil
amsDirect.prep ncelabNosource boolean nil
amsDirect.prep ncelabUseAfile boolean nil
amsDirect.prep ncelabUseGenafile boolean nil
amsDirect.prep ncelabExpand boolean nil
amsDirect.prep ncelabRelax boolean nil
amsDirect.prep ncelabDisableenht boolean nil
amsDirect.prep ncelabNonegtchk boolean nil
amsDirect.prep ncelabNoipd boolean nil
amsDirect.prep ncelabSdfverbose boolean nil
amsDirect.prep ncelabNoautosdf boolean nil
amsDirect.prep ncelabNeverwarn boolean nil
amsDirect.prep ncelabNocopyright boolean nil
amsDirect.prep ncelabUseGeneric boolean nil
amsDirect.prep ncelabUsePulseR boolean nil
amsDirect.prep ncelabUsePulseE boolean nil
amsDirect.prep ncelabUsePulseIntR boolean nil
amsDirect.prep ncelabUsePulseIntE boolean nil
amsDirect.prep ncelabUseExtendtcheckdatalimit boolean nil
amsDirect.prep ncelabUseExtendtcheckreferencelimit boolean nil
amsDirect.prep ncelabNonotifier boolean nil
amsDirect.prep ncelabUseSdfprecision boolean nil
amsDirect.prep ncsimEpulseNoMsg boolean nil
amsDirect.prep ncsimExtassertmsg boolean nil
amsDirect.prep ncsimMessages boolean nil
amsDirect.prep ncsimNeverwarn boolean nil
amsDirect.prep ncsimNocifcheck boolean nil
amsDirect.prep ncsimNosource boolean nil
amsDirect.prep ncsimNostdout boolean nil
amsDirect.prep ncsimPlinooptwarn boolean nil
amsDirect.prep ncsimPlinowarn boolean nil
amsDirect.prep ncsimProfile boolean nil
amsDirect.prep ncsimProfthread boolean nil
amsDirect.prep ncsimRedmem boolean nil
amsDirect.prep ncsimStatus boolean nil
amsDirect.prep ncsimUnbuffered boolean nil
amsDirect.prep ncsimUpdate boolean t
amsDirect.prep ncelabUseAddArgs boolean nil
amsDirect.prep ncsimUseAddArgs boolean nil
amsDirect.prep ncelabMaxErrors int 50
amsDirect.prep ncelabPulseE int 100
amsDirect.prep ncelabPulseIntE int 100
amsDirect.prep ncelabPulseIntR int 100
amsDirect.prep ncelabPulseR int 100
amsDirect.prep ncelabExtendtcheckdatalimit int 0
amsDirect.prep ncelabExtendtcheckreferencelimit int 0
amsDirect.prep ncsimMaxErrors int 50
amsDirect.prep analogControlFile string ""
amsDirect.prep cdsGlobalsLib string ""
amsDirect.prep cdsGlobalsView string ""
amsDirect.prep compileExcludeLibs string ""
amsDirect.prep connectRulesCell string "mixedsignal"
amsDirect.prep connectRulesCell2 string "ConnRules_5V_full"
amsDirect.prep connectRulesLib string ""
amsDirect.prep connectRulesView string ""
amsDirect.prep discipline string "logic"
amsDirect.prep language string "verilog"
amsDirect.prep ncelabArguments string ""
amsDirect.prep ncsimArguments string ""
amsDirect.prep simVisScriptFile string ""
amsDirect.prep timescale string "1ns/1ns"
amsDirect.prep vlogGroundSigs string "gnd!"
amsDirect.prep vlogSupply0Sigs string ""
amsDirect.prep vlogSupply1Sigs string ""
amsDirect.prep ncelabAfile string ""
amsDirect.prep ncelabGenafile string ""
amsDirect.prep ncelabLoadpli1 string ""
amsDirect.prep ncelabLoadvpi string ""
amsDirect.prep ncelabSdfCmdFile string ""
amsDirect.prep ncelabTopLvlGeneric string ""
amsDirect.prep ncelabSdfprecision string ""
amsDirect.prep ncelabNowarn string ""
amsDirect.prep ncsimLoadvpi string ""
amsDirect.prep ncsimNowarn string ""
amsDirect.prep ncelabModelFilePaths string ""
amsDirect.prep compileMode cyclic "incremental"
amsDirect.prep netlistMode cyclic "incremental"
amsDirect.prep ncelabAccess cyclic "Read"
amsDirect.prep ncelabDelayMode cyclic "None"
amsDirect.prep ncelabDelayType cyclic "None"
amsDirect.prep ncelabEpulseFiltering cyclic "None"
amsDirect.prep ncelabLogFileAction cyclic "Overwrite log file"
amsDirect.prep ncelabOmichecklvl cyclic "Standard"
amsDirect.prep ncelabVipdelay cyclic "Typical"
amsDirect.prep ncsimLogFileAction cyclic "Overwrite log file"
amsDirect.prep ncsimOmichecklvl cyclic "None"
amsDirect.simcntl scapprox boolean nil
amsDirect.simcntl scdebug boolean nil
amsDirect.simcntl scdiagnose boolean nil
amsDirect.simcntl scerror boolean t
amsDirect.simcntl scignshorts boolean nil
amsDirect.simcntl scinfo boolean t
amsDirect.simcntl scmacromod boolean nil
amsDirect.simcntl scnarrate boolean t
amsDirect.simcntl scnote boolean t
amsDirect.simcntl scopptcheck boolean t
amsDirect.simcntl scpivotdc boolean nil
amsDirect.simcntl scscfusefileflag boolean nil
amsDirect.simcntl scspscflag boolean nil
amsDirect.simcntl scstats boolean nil
amsDirect.simcntl scwarn boolean t
amsDirect.simcntl scfastbreak boolean nil
amsDirect.simcntl scusemodeleval boolean nil
amsDirect.simcntl scdigits int 5
amsDirect.simcntl scmaxiters int 5
amsDirect.simcntl scmaxnotes int 5
amsDirect.simcntl scmaxwarn int 5
amsDirect.simcntl scscale int 1
amsDirect.simcntl scscalem int 1
amsDirect.simcntl scskipcount int 0
amsDirect.simcntl sccmin string "0.0"
amsDirect.simcntl scaddlglblopts string ""
amsDirect.simcntl scaddltranopts string ""
amsDirect.simcntl scgmin string "1e-12"
amsDirect.simcntl sciabstol string "1e-12"
amsDirect.simcntl scicstmt string ""
amsDirect.simcntl sclteratio string ""
amsDirect.simcntl scmaxstep string ""
amsDirect.simcntl scpivabs string "0.0"
amsDirect.simcntl scpivrel string "1e-3"
amsDirect.simcntl screadic string ""
amsDirect.simcntl screadns string ""
amsDirect.simcntl screltol string ""
amsDirect.simcntl scrforce string "1.0"
amsDirect.simcntl scalem string "1.0"
amsDirect.simcntl scale string "1.0"
amsDirect.simcntl scscfincfile string ""
amsDirect.simcntl scscftimestamp string ""
amsDirect.simcntl scskipstart string "0.0"
amsDirect.simcntl scskipstop string "0.0"
amsDirect.simcntl scstep string ""
amsDirect.simcntl scstop string "0.0"
amsDirect.simcntl scstrobedelay string "0.0"
amsDirect.simcntl scstrobeperiod string "0.0"
amsDirect.simcntl sctemp string "27.0"
amsDirect.simcntl sctitle string ""
amsDirect.simcntl sctnom string "27.0"
amsDirect.simcntl scvabstol string "1e-6"
amsDirect.simcntl scwrite string ""
amsDirect.simcntl scwritefinal string ""
amsDirect.simcntl scannotate cyclic "sweep"
amsDirect.simcntl scaudit cyclic "detailed"
amsDirect.simcntl sccheckstmt cyclic "all"
amsDirect.simcntl sccompatible cyclic "spectre"
amsDirect.simcntl scerrpreset cyclic "moderate"
amsDirect.simcntl scgmincheck cyclic "max_v_only"
amsDirect.simcntl schomotopy cyclic "all"
amsDirect.simcntl scic cyclic "all"
amsDirect.simcntl scinventory cyclic "detailed"
amsDirect.simcntl sclimit cyclic "dev"
amsDirect.simcntl scmethod cyclic "<Default value>"
amsDirect.simcntl scnotation cyclic "eng"
amsDirect.simcntl scquantities cyclic "no"
amsDirect.simcntl screlref cyclic "<Default value>"
amsDirect.simcntl scskipdc cyclic "no"
amsDirect.simcntl sctempeffects cyclic "all"
amsDirect.simcntl sctopcheck cyclic "full"
amsDirect.simcntl sctransave cyclic "allpub"
amsDirect.simcntl scmodelevaltype cyclic "s"
amsDirect.vhdl allowNoEntityUpdate boolean nil
amsDirect.vhdl checkAndNetlist boolean nil
amsDirect.vhdl checkOnly boolean nil
amsDirect.vhdl compileAsAMS boolean t
amsDirect.vhdl forceEntitySync boolean nil
amsDirect.vhdl forceInlineCompDecl boolean nil
amsDirect.vhdl netlistAfterCdfChange boolean nil
amsDirect.vhdl prohibitCompile boolean nil
amsDirect.vhdl useProcessViewNamesOnly boolean nil
amsDirect.vhdl lexpragma boolean nil
amsDirect.vhdl messages boolean nil
amsDirect.vhdl neverwarn boolean nil
amsDirect.vhdl nopragmawarn boolean nil
amsDirect.vhdl nostdout boolean nil
amsDirect.vhdl novitalcheck boolean nil
amsDirect.vhdl pragma boolean nil
amsDirect.vhdl relax boolean nil
amsDirect.vhdl status boolean nil
amsDirect.vhdl update boolean t
amsDirect.vhdl v93 boolean t
amsDirect.vhdl vhdllinedebug boolean nil
amsDirect.vhdl ncvhdlUseAddArgs boolean nil
amsDirect.vhdl maxErrors int 50
amsDirect.vhdl amsEligibleViewTypes string "schematic schematicSymbol"
amsDirect.vhdl defaultObject string "quantity"
amsDirect.vhdl defaultScalarNature string "real"
amsDirect.vhdl defaultScalarType string "quantity"
amsDirect.vhdl defaultVectorNature string "real_vector"
amsDirect.vhdl defaultVectorType string "quantity"
amsDirect.vhdl defPackageNames string ""
amsDirect.vhdl excludeViewNames string ""
amsDirect.vhdl ncvhdlArguments string ""
amsDirect.vhdl processViewNames string ""
amsDirect.vhdl templateFile string ""
amsDirect.vhdl templateScript string ""
amsDirect.vhdl logFileAction cyclic "Overwrite log file"
amsDirect.vhdl nowarn string ""
amsDirect.vhdl allowDeviantBuses cyclic "no"
amsDirect.vhdl allowIllegalIdentifiers cyclic "warn"
amsDirect.vhdl allowNameCollisions cyclic "warn"
amsDirect.vhdl allowPortNetMismatches cyclic "no"
amsDirect.vhdl allowSparseBuses cyclic "warn"
amsDirect.vhdl headerText cyclic "none"
amsDirect.vlog checkAndNetlist boolean nil
amsDirect.vlog checkOnly boolean nil
amsDirect.vlog compileAsAMS boolean t
amsDirect.vlog ifdefLanguageExtensions boolean nil
amsDirect.vlog netlistAfterCdfChange boolean nil
amsDirect.vlog prohibitCompile boolean nil
amsDirect.vlog useDefparam boolean nil
amsDirect.vlog useProcessViewNamesOnly boolean nil
amsDirect.vlog checktasks boolean nil
amsDirect.vlog ieee1364 boolean nil
amsDirect.vlog noline boolean nil
amsDirect.vlog lexpragma boolean nil
amsDirect.vlog markcelldefines boolean nil
amsDirect.vlog messages boolean nil
amsDirect.vlog neverwarn boolean nil
amsDirect.vlog nomempack boolean nil
amsDirect.vlog nopragmawarn boolean nil
amsDirect.vlog nostdout boolean nil
amsDirect.vlog pragma boolean nil
amsDirect.vlog status boolean nil
amsDirect.vlog update boolean t
amsDirect.vlog vloglinedebug boolean nil
amsDirect.vlog ncvlogUseAddArgs boolean nil
amsDirect.vlog netlistUDFAsMacro boolean nil
amsDirect.vlog bindCdsAliasLib boolean t
amsDirect.vlog bindCdsAliasView boolean t
amsDirect.vlog maxErrors int 50
amsDirect.vlog amsEligibleViewTypes string "schematic"
amsDirect.vlog excludeViewNames string ""
amsDirect.vlog includeFiles string "(disciplines.vams)"
amsDirect.vlog ncvlogArguments string ""
amsDirect.vlog paramDefVals string ""
amsDirect.vlog paramGlobalDefVal string "0"
amsDirect.vlog processViewNames string ""
amsDirect.vlog templateFile string ""
amsDirect.vlog templateScript string ""
amsDirect.vlog incdir string ""
amsDirect.vlog macro string ""
amsDirect.vlog nowarn string ""
amsDirect.vlog allowDeviantBuses cyclic "no"
amsDirect.vlog allowIllegalIdentifiers cyclic "warn"
amsDirect.vlog allowNameCollisions cyclic "warn"
amsDirect.vlog allowSparseBuses cyclic "warn"
amsDirect.vlog headerText cyclic "none"
amsDirect.vlog logFileAction cyclic "Overwrite log file"
amsDirect.vlog iterInstExpFormat string "%b_%i"
amsDirect.vlog netClashFormat string "%b_netclash"
amsDirect.vlog instClashFormat string "%b_instclash"
amsDirect.vlog aliasInstFormat string "ams_alias_inst_%i"
;Analog Artist Simulation Environment Defaults
;Session Options
asimenv windowBased boolean t
asimenv schematicBased boolean nil
asimenv saveDir string "~/.artist_states"
asimenv saveQuery boolean t
asimenv loadCorners boolean t
asimenv designEditMode boolean nil;edit/read open mode
asimenv showWhatsNew string "yes"
asimenv.startup simulator string "spectre"
asimenv.startup projectDir string "~/simulation"
asimenv.startup hostMode string "local"
asimenv.startup host string ""
asimenv.startup remoteDir string ""
asimenv.startup digitalHostMode string "local"
asimenv.startup digitalHost string ""
;Window Options
asimenv.window x int 1
asimenv.window y int 317
;Load State Dialog
asimenv.loadstate modelSetup boolean t
;when set to nil, loadstate form opens with Model Setup deselected by default
;Plotting Options
asimenv.plotting autoPlot boolean t
asimenv.plotting overlay boolean nil
asimenv.plotting immediatePlot boolean nil
asimenv.plotting designName boolean t
asimenv.plotting simulationDate boolean t
asimenv.plotting temperature boolean nil
asimenv.plotting variables boolean nil
asimenv.plotting scalarOutputs boolean nil
asimenv.plotting icons boolean t
asimenv.plotting fontSize int 11
asimenv.plotting width int 564
asimenv.plotting height int 428
asimenv.plotting x int 577
asimenv.plotting y int 373
asimenv.plotting displayMode cyclic "auto"
asimenv.plotting stripModeType cyclic "auto"
asimenv.plotting immediatePrint boolean t
asimenv.plotting printInlines boolean t
;Command-Type-In Window
asimenv.window width int 650
asimenv.window height int 275
;Miscellaneous
asimenv.misc saveDefaultsToOCEAN boolean nil
asimenv.misc numberOfSavedRuns int 0
asimenv.misc browserCenterMode boolean nil
asimenv.misc updateCDFtermOrder boolean nil
asimenv.misc queryCDFtermOrder boolean t
asimenv.misc oceanScriptFile string "./oceanScript.ocn"
asimenv.userPref printNotation cyclic "suffix"
asimenv.userPref printCommentChar string "#"
;Noise summary options
asimenv.noiseSummary digits int 6
asimenv.noiseSummary percentDecimals int 2
;obsolete simulator startup form variables
asimenv.startup sessionName string "schematic"
asimenv.startup libName string ""
asimenv.startup cellName string ""
asimenv.startup viewName string ""
asimenv.startup versionName string ""
asimenv.netlist obsoleteWarnings int 1
;Distributed Processing
;Please do not add any options other than for Artist Distributed
;below this point.
;asimenv.startup hostMode - value of 'distributed' enables distributed processing
asimenv.distributed externalServer boolean nil
;If set non-nil, the job server is started remotely.
asimenv.distributed autoJobSubmit boolean nil
;If set non-nil, job setup form is NOT presented to user at job submit time.
asimenv.distributed showMessages boolean t
;If set non-nil, a message is displayed in the CIW or OCEAN terminal
;when a job is completed.
asimenv.distributed queueName string ""
;Sets the default queue name. If unspecified, system default is used.
asimenv.distributed hostName string ""
;Sets the default host name. If unspecified, host is automatically selected.
asimenv.distributed startTime string ""
;Sets the default start time for a job (in 24 hr. format). If unspecified, job runs immediately.
asimenv.distributed startDay cyclic "today"
;Sets the default start day for a job. If `today', then job will always run on the same day it is submitted
asimenv.distributed expTime string ""
;Sets the default expiration time for a job (in 24 hr. format). If unspecified, expiration time
;is based on the value of the `timeLimit' variable.
asimenv.distributed expDay cyclic "today"
;Sets the default expiration day for a job. If `today', then job will always run on the same day it is submitted
asimenv.distributed timeLimit cyclic "none"
;Sets the default time limit for a job. If `none', then no time limit is imposed.
;If `unspecified', then expiration time is based on value of `expTime' and `expDay' variables.
asimenv.distributed emailNotify boolean t
;If set non-nil, email notification is provided following job termination.
asimenv.distributed mailTo string ""
;Sets the default list of users who will receive job termination notification email.
;If unspecified, and emailNotify is t, then default value is the user's id.
asimenv.distributed logsInEmail boolean t
;If set non-nil, stdout and stderr logs will be included in the termination email.
asimenv.distributed stateFile string "~/.adpState"
;Sets the filename containing the job server's state.
asimenv.distributed daysBeforeExpire int 3
;Specifies the number of days after which terminated jobs will be deleted from
;the job server.
asimenv.distributed block boolean nil
;If set non-nil, the process will be blocked until the job has completed.
asimenv.distributed copyMode boolean nil
;If set non-nil, the input data for the job is copied to /tmp on the execution host,
;the job is run there locally (i.e. no network read/write), and the output data is
;copied back to the submission host.
asimenv.distributed copyModeDir string "/tmp"
;The directory, relative to the execution host, that will be used for setting up the
;working directory of a copy mode job.
asimenv.distributed loginShell cyclic "none"
;Specifies login shell for the job. If `none', then the user's local environment
;is copied over to the execution host and used as the job's environment.
asimenv.distributed numOfTasks int 0
;Specifies the default number of tasks a job should be broken into.
;This is used by the Monte Carlo tool.
;If zero, then number of tasks is bases on queue and/or host settings
asimenv.distributed jobArgsInOceanScript boolean nil
;Indicates job arguments should be added to run commands when
;OCEAN script is generated.
asimenv.distributed puttogetherqueue string ""
;Used to specify the queue to be used for Put Together Job
asimenv.distributed copyNetlist boolean nil
;Used to specify whether netlist directory needs to be copied from execution
;host to submission host. This may be required if during simulation, some files
;are generated under netlist dir
;Used to specify whether to remove the job from DP database after job completion.
;So that, if set to t, the same job name is used repeatedly.
;Used to specify whether list option for specifying hosts needs to be displayed
;in Job Submit Form. If set to nil the list option will not be displayed.
;Used to specify the default value for Shell_Cmd_at_Finish as available in job
;submit form.
asimenv.distributed logsDir string "/tmp"
;Used to specify the directory where the log files would be generated
asimenv.distributed mailAllLogs boolean nil
;Used to specify whether to send the log files in mail for all the tasks
;If set to t, log files would be mailed for each task and a summary mail would be
;sent after completion of all the tasks. If set to nil just a summary mail would be
asimenv.distributed logFile string "~/cdsDPSetupChk.log"
asimenv.distributed clockSync boolean nil
asimenv.distributed lsfResourceString string ""
;Used to specify the Default LSF Resource String
asimenv.distributed donotCopyCore boolean t
;Used to specify whether DP need to filter the core files while copying the directories
;If set to t then all the files with name starting from core will be filtered out
;If set to nil then all the files will be copied
; Copyright (C) 1991
; Cadence Design Systems, Analog Division
; All Rights Reserved.
; $Source: /cvsrep/group/artist/src/auCdl/cdsenv,v $
; $Author: cvsadm $
; $Revision: 1.1 $
; $Date: 2003/10/06 04:16:43 $
; $State: Exp $
;auCdl Environment Variables
;For cell-view to cell-view:
auCdl.envOpts defaultSubcircuitCall string "ansCdlSubcktCall"
;auCore Environment Variables
;Note: The tool registration file should not be edited.
;Customization should be based on the file in <cdshier>/samples/.cdsenv.
;Tool Filter list of simulators
auCore.toolFilter toolList string "spectre spectreS cdsSpice auCdl auLvs hspiceS hspiceD UltraSim "
;Tool Filter list of simulators selected by default
auCore.toolFilter defaultTools string "spectre spectreS auCdl auLvs"
;Tool Filter variable to enable auto update
auCore.toolFilter autoUpdate boolean nil
;Logic Levels form variables
auCore.voltageLevels highlayer cyclic "y2"
auCore.voltageLevels midlayer cyclic "y4"
auCore.voltageLevels lowlayer cyclic "y6"
auCore.voltageLevels high float 2.0
auCore.voltageLevels low float 0.8
auCore.voltageLevels type string "DC"
auCore.voltageLevels time float 0.0
;The following variable indicates the release to which the Artist cdsenv
;variables are compliant. Set to the current release to disable
;automatic variable detection/conversion of user's .cdsenv file.
auCore artVarVer string ""
; $Source: /cvsrep/group/artist/src/auLvs/cdsenv,v $
; $Author: zhaag $
; $Revision: 1.1.12.1 $
; $Date: 2004/10/13 09:30:08 $
; $State: Exp $
auLvs.envOpts defaultSubcircuitCall string "ansLvsCompPrim"
;Calculator environment variables
;FORMAT: tool[.partition] varName varType default private {choices,min/max}
;calculator modes
calculator mode cyclic "RPN"
calculator uimode cyclic "standard"
calculator eval boolean nil
calculator dstack boolean nil
calculator oldexpr boolean t
calculator browserOldExpr boolean nil
;clip special function variables
calculator.clip from string ""
calculator.clip to string ""
;value special function variables
calculator.value at string ""
;x value at maximum special function variables
calculator.xmax nth string "1"
;x value at minimum special function variables
calculator.xmin nth string "1"
;ipn special function variables
calculator.ipn spurOrder string "3"
calculator.ipn refHarmonic string "1"
calculator.ipn spurHarmonic string "1"
calculator.ipn extPoint string "0"
calculator.ipn refOrder string "1"
;ipnVRI special function variables
calculator.ipnVRI spurHarmonic string ""
calculator.ipnVRI refHarmonic string ""
calculator.ipnVRI ordspur string ""
calculator.ipnVRI epoint string ""
calculator.ipnVRI rport string ""
calculator.ipnVRI measurePrompt cyclic "Input Referred IPN"
calculator.ipnVRI powerSwPrompt cyclic "Variable Sweep"
calculator.ipnVRI measure string ""
calculator.ipnVRI psweep string ""
;phaseNoise special function variables
calculator.phaseNoise nth string "0"
calculator.phaseNoise noiseResNam string "pnoise.pss"
;compression special function variables
calculator.compression nth string "0"
calculator.compression x string "0"
calculator.compression compress string "1"
calculator.compressionVRI harmonic string ""
calculator.compressionVRI epoint string ""
calculator.compressionVRI rport string ""
calculator.compressionVRI gcomp string ""
calculator.compressionVRI measurePrompt cyclic "Input Referred Compression"
calculator.compressionVRI measure string ""
;harmonic special function variable
calculator.harmonic nth string "0"
calculator.harmonic spurHarmonic string "1"
calculator.harmonic refHarmonic string "1"
;harmonicFreq special function variable
calculator.harmonicFreq nth string "1"
;tangent special function variables
calculator.tangent x string "0"
calculator.tangent y string "0"
calculator.tangent slope string "1.0"
;discrete fourier transform special function variables
calculator.dft from string ""
calculator.dft to string ""
calculator.dft samples string "64"
calculator.dft windowName cyclic "Rectangular"
calculator.dft smooth float 1.0
calculator.dft cgtype cyclic "(none)"
calculator.dft cohGain float 1.0
calculator.psd from string ""
calculator.psd to string ""
calculator.psd samples string "512"
calculator.psd windowName cyclic "Hanning"
calculator.psd smooth float 1.0
calculator.psd cgtype cyclic "(none)"
calculator.psd cohGain float 1.0
calculator.psd detrending cyclic "None"
calculator.psd windowSize string "256"
calculator.psdbb from string ""
calculator.psdbb to string ""
calculator.psdbb samples string "512"
calculator.psdbb windowName cyclic "Hanning"
calculator.psdbb smooth float 1.0
calculator.psdbb cgtype cyclic "(none)"
calculator.psdbb cohGain float 1.0
calculator.psdbb detrending cyclic "None"
calculator.psdbb windowSize string "256"
;total harmonic distortion special function variables
calculator.thd from string ""
calculator.thd to string ""
calculator.thd samples string "64"
calculator.thd fundamental string ""
;threshold crossing special function variables
calculator.cross value string "2.5"
calculator.cross nth string "1"
calculator.cross type cyclic "either"
;root value special function variables
calculator.root value string "2.5"
calculator.root nth string "1"
;fourier evaluation special function variables
calculator.fourEval from string ""
calculator.fourEval to string ""
calculator.fourEval by string ""
;convolution special function variables
calculator.convolve from string ""
calculator.convolve to string ""
calculator.convolve incr cyclic "linear"
calculator.convolve by string ""
;threshold delay special function variables
calculator.delay value_a string "2.5"
calculator.delay nth_a string "1"
calculator.delay type_a cyclic "either"
calculator.delay value_b string "2.5"
calculator.delay nth_b string "1"
calculator.delay type_b cyclic "either"
;bandwidth special function variables
calculator.bandwidth db string "3"
calculator.bandwidth type cyclic "low"
;rise time special function variables
calculator.riseTime initial string ""
calculator.riseTime itype cyclic "y at x"
calculator.riseTime final string ""
calculator.riseTime ftype cyclic "y at x"
calculator.riseTime theta_a string "10"
calculator.riseTime theta_b string "90"
;slew rate special function variables
calculator.slewRate initial string ""
calculator.slewRate itype cyclic "y at x"
calculator.slewRate final string ""
calculator.slewRate ftype cyclic "y at x"
calculator.slewRate theta_a string "10"
calculator.slewRate theta_b string "90"
;sample special function variables
calculator.sample from string ""
calculator.sample to string ""
calculator.sample incr cyclic "linear"
calculator.sample by string ""
;settling time special function variables
calculator.settlingTime initial string ""
calculator.settlingTime itype cyclic "y at x"
calculator.settlingTime final string ""
calculator.settlingTime ftype cyclic "y at x"
calculator.settlingTime theta string "5"
;overshoot special function variables
calculator.overshoot initial string ""
calculator.overshoot itype cyclic "y at x"
calculator.overshoot final string ""
calculator.overshoot ftype cyclic "y at x"
;table special function variables
calculator.table filename string ""
calculator.table name string ""
calculator.table xcolumn int 1
calculator.table ycolumn int 2
calculator.table xskip int 0
calculator.table yskip int 0
;left shift special function variables
calculator.lshift delta string "0"
;rms noise special function variables
calculator.rmsNoise from string ""
calculator.rmsNoise to string ""
;eyeDiagram special function variables
calculator.eyeDiagram start string "0"
calculator.eyeDiagram stop string "0"
calculator.eyeDiagram period string "0"
;defInteg special function variables
calculator.integ initial string ""
calculator.integ final string ""
; cdba Environment Variables
; This tool registration file should not be edited
; since customization is done via the file in
; <cdshier>/samples/.cdsenv
cdba dbInstNamingGlobalInc boolean nil
cdba dbNumCPU int 1
cdba dbStatCacheOn boolean nil
cdba.DBUPerUU behavioral int 160
cdba.DBUPerUU graphic int 1000
cdba.DBUPerUU logicModel int 160
cdba.DBUPerUU maskLayout int 1000
cdba.DBUPerUU netlist int 160
cdba.DBUPerUU package int 160
cdba.DBUPerUU PCB int 160
cdba.DBUPerUU schematic int 160
cdba.DBUPerUU schematicSymbol int 160
cdba.DBUPerUU stranger int 1000
cdba.DBUPerUU symbolic int 1000
cdba.DBUPerUU verilogMap int 160
cdba.userUnits behavioral cyclic "inch"
cdba.userUnits graphic cyclic "micron"
cdba.userUnits logicModel cyclic "inch"
cdba.userUnits maskLayout cyclic "micron"
cdba.userUnits netlist cyclic "inch"
cdba.userUnits package cyclic "inch"
cdba.userUnits PCB cyclic "inch"
cdba.userUnits schematic cyclic "inch"
cdba.userUnits schematicSymbol cyclic "inch"
cdba.userUnits stranger cyclic "micron"
cdba.userUnits symbolic cyclic "micron"
cdba.userUnits verilogMap cyclic "inch"
; this file is tools/dfII/etc/tools/cdsLibEditor/.cdsenv, format is:
; tool[.partition] varName varType default private {choices,min/max}
cdsLibEditor.main autoExclEdit boolean nil
cdsLibEditor.main warnExclLock boolean t
; this file is tools/dfII/etc/tools/cdsLibManager/.cdsenv, format is:
cdsLibManager.ckCancel useOptionText string ""
cdsLibManager.ckCancel useOptionsOn boolean nil
cdsLibManager.ckIn selectMatches toggle (t nil nil nil)
cdsLibManager.ckIn useOptionText string ""
cdsLibManager.ckIn useOptionsOn boolean nil
cdsLibManager.ckOut useOptionText string ""
cdsLibManager.ckOut useOptionsOn boolean nil
cdsLibManager.copy addToCategoryName string ""
cdsLibManager.copy addToCategoryOn boolean nil
cdsLibManager.copy addToCellsPattern string "*"
cdsLibManager.copy allViewsOn boolean t
cdsLibManager.copy exactHierOn boolean nil
cdsLibManager.copy extraViews string ""
cdsLibManager.copy hierOn boolean nil
cdsLibManager.copy skipLibsOn boolean t
cdsLibManager.copy skipLibsText string ""
cdsLibManager.copy skipLibsText1 string ""
cdsLibManager.copy skipLibsText10 string ""
cdsLibManager.copy skipLibsText11 string ""
cdsLibManager.copy skipLibsText12 string ""
cdsLibManager.copy skipLibsText13 string ""
cdsLibManager.copy skipLibsText14 string ""
cdsLibManager.copy skipLibsText15 string ""
cdsLibManager.copy skipLibsText2 string ""
cdsLibManager.copy skipLibsText3 string ""
cdsLibManager.copy skipLibsText4 string ""
cdsLibManager.copy skipLibsText5 string ""
cdsLibManager.copy skipLibsText6 string ""
cdsLibManager.copy skipLibsText7 string ""
cdsLibManager.copy skipLibsText8 string ""
cdsLibManager.copy skipLibsText9 string ""
cdsLibManager.copy updateChoice toggle (t nil)
cdsLibManager.copy updateOn boolean nil
cdsLibManager.copy viewsText string ""
cdsLibManager.copy addPropFiles boolean t
cdsLibManager.copyError overwriteAll boolean nil
cdsLibManager.copyGlobals expandRadio toggle (t nil)
cdsLibManager.copyGlobals mpsRadio toggle (t nil)
cdsLibManager.copyGlobals stopMutations boolean t
cdsLibManager.copyGlobals useMonitor boolean t
cdsLibManager.copyGlobals warnRenameDM boolean t
cdsLibManager.copyVersion openView boolean t
cdsLibManager.copyVersion toLibrary string ""
cdsLibManager.copyVersion toView string ""
cdsLibManager.copyVersion useOptionText string ""
cdsLibManager.copyVersion useOptionsOn boolean nil
cdsLibManager.copyWizard addToCategoryName string ""
cdsLibManager.copyWizard addToCategoryOn boolean nil
cdsLibManager.copyWizard addToCellsPattern string "*"
cdsLibManager.copyWizard extraViews string ""
cdsLibManager.copyWizard skipLibsText string ""
cdsLibManager.copyWizard skipLibsText1 string ""
cdsLibManager.copyWizard skipLibsText10 string ""
cdsLibManager.copyWizard skipLibsText11 string ""
cdsLibManager.copyWizard skipLibsText12 string ""
cdsLibManager.copyWizard skipLibsText13 string ""
cdsLibManager.copyWizard skipLibsText14 string ""
cdsLibManager.copyWizard skipLibsText15 string ""
cdsLibManager.copyWizard skipLibsText2 string ""
cdsLibManager.copyWizard skipLibsText3 string ""
cdsLibManager.copyWizard skipLibsText4 string ""
cdsLibManager.copyWizard skipLibsText5 string ""
cdsLibManager.copyWizard skipLibsText6 string ""
cdsLibManager.copyWizard skipLibsText7 string ""
cdsLibManager.copyWizard skipLibsText8 string ""
cdsLibManager.copyWizard skipLibsText9 string ""
cdsLibManager.copyWizard updateChoice toggle (t nil)
cdsLibManager.copyWizard updateOn boolean t
cdsLibManager.customize mapTimeout float 5.0
cdsLibManager.customize showDFIIWarning boolean t
cdsLibManager.customize startupFile string "cdsLibMgr.il"
cdsLibManager.database addDb1 string ""
cdsLibManager.database addDb2 string ""
cdsLibManager.database addDb3 string ""
cdsLibManager.database addDb4 string ""
cdsLibManager.database addDb5 string ""
cdsLibManager.database addDb6 string ""
cdsLibManager.database addDb7 string ""
cdsLibManager.database addDb8 string ""
cdsLibManager.database addDb9 string ""
cdsLibManager.database ddDb string "com.cadence.interfaces.libAccess.cddLib5xDatabase"
cdsLibManager.database server string "com.cadence.interfaces.libAccess.ladLibraryServer"
cdsLibManager.defaults fileRadio toggle (nil t nil)
cdsLibManager.defaults saveAllOn boolean nil
cdsLibManager.defaults saveAsText string ".cdsenv"
cdsLibManager.delete libCheckOn boolean t
cdsLibManager.delete localRadio toggle (t nil)
cdsLibManager.deleteTag overrideRadio toggle (t nil nil nil)
cdsLibManager.deleteView localRadio toggle (t nil)
cdsLibManager.filter cellFilter string ""
cdsLibManager.filter viewFilter string ""
; The log file format is 'baseName[.UID][.host][.PID][.sequence].log'
cdsLibManager.log addHostID boolean nil
cdsLibManager.log addProcID boolean nil
cdsLibManager.log addSequence boolean nil
cdsLibManager.log addUserID boolean nil
cdsLibManager.log baseName string "libManager"
cdsLibManager.main categoryText string ""
cdsLibManager.main cellLevelText string ""
cdsLibManager.main dblClickEditCellView boolean t
cdsLibManager.main libraryText string ""
cdsLibManager.main showCategoriesOn boolean nil
cdsLibManager.main showFilesOn boolean nil
cdsLibManager.main viewLevelText string ""
cdsLibManager.newLib dmRadio toggle (t nil)
cdsLibManager.newLib pathText string ""
cdsLibManager.option forceEnv boolean nil
cdsLibManager.option useDMfilter boolean t
cdsLibManager.option useFastDM boolean t
cdsLibManager.rename updateOn boolean t
cdsLibManager.renameRefLib refreshSessionOn boolean t
cdsLibManager.submit useNameOn boolean nil
cdsLibManager.submit useNameText string ""
cdsLibManager.submit useOptionText string ""
cdsLibManager.submit useOptionsOn boolean nil
cdsLibManager.update useNameOn boolean nil
cdsLibManager.update useNameText string ""
cdsLibManager.update useOptionText string ""
cdsLibManager.update useOptionsOn boolean nil
;cdsSpice environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;cdsSpice opts partition variables
cdsSpice.opts TEMPDC string "25"
cdsSpice.opts NSIG string "4"
cdsSpice.opts TIMSAT string "0"
cdsSpice.opts RELTOL string "1e-3"
cdsSpice.opts MKS string "1"
cdsSpice.opts ITL5 string "999999"
cdsSpice.opts ARTSTR string "0"
cdsSpice.opts GMINON string "2"
cdsSpice.opts LVLTIM string "2"
cdsSpice.opts VCESAT string "0.0"
cdsSpice.opts ITL3 string "4"
cdsSpice.opts SCALEM string "1"
cdsSpice.opts GO2OFF string "0"
cdsSpice.opts ITL4 string "25"
cdsSpice.opts AVSTEP string ".33"
cdsSpice.opts ITL1 string "100"
cdsSpice.opts ITL2 string "100"
cdsSpice.opts METHOD string "1"
cdsSpice.opts CHGTOL string "1e-14"
cdsSpice.opts TNOM string "25"
cdsSpice.opts MORBKP string ".1"
cdsSpice.opts ABSTOL string "1e-12"
cdsSpice.opts UIC string "0"
cdsSpice.opts SINWAV string "1e+6"
cdsSpice.opts GRTEXT string "1"
cdsSpice.opts PRNOTE string "1"
cdsSpice.opts VLIMAX string "50000"
cdsSpice.opts GMIN string "1e-12"
cdsSpice.opts GSAVE string "0"
cdsSpice.opts INTTIM string "0"
cdsSpice.opts CNVREV string "2.4"
cdsSpice.opts DCSAT string "0"
cdsSpice.opts TINIT string ""
cdsSpice.opts VBESAT string "0.6"
cdsSpice.opts QADLIN string "0"
cdsSpice.opts MFNOIS string "0"
cdsSpice.opts TRTOL string "7"
cdsSpice.opts SCALE string "1"
cdsSpice.opts PSFFLG string "1"
cdsSpice.opts SPICE2G string "0"
cdsSpice.opts WRFLAG string "0"
cdsSpice.opts SPTEMP string "1"
cdsSpice.opts RON string "1"
cdsSpice.opts NRAMP string "0"
cdsSpice.opts VNTOL string "1e-6"
cdsSpice.opts NOWARN string "0"
cdsSpice.opts VBCSAT string "0.15"
cdsSpice.opts DCOPPT string "1"
cdsSpice.opts MAXORD string "2"
cdsSpice.opts SPMESS string "1"
;cdsSpice outputs partition variables
cdsSpice.outputs allAnalogNV boolean t
cdsSpice.outputs allAnalogTC boolean nil
;cdsSpice envOpts partition variables
cdsSpice.envOpts updateFile string ""
cdsSpice.envOpts stimulusFile string ""
cdsSpice.envOpts instViewListTable string ""
cdsSpice.envOpts doInstBased boolean nil
cdsSpice.envOpts stopViewList string "cdsSpice spice"
cdsSpice.envOpts includeSyntax string "cdsSpice"
cdsSpice.envOpts initFile string ""
cdsSpice.envOpts printComments boolean nil
cdsSpice.envOpts netlistType string "hierarchical"
cdsSpice.envOpts generateMapFile boolean nil
cdsSpice.envOpts includeFile string ""
cdsSpice.envOpts instStopListTable string ""
cdsSpice.envOpts switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
;cdsSpice init partition variables
cdsSpice.init processPriority int 0
;cdsSpice dc partition variables
cdsSpice.dc enable toggle (nil)
cdsSpice.dc from string ""
cdsSpice.dc to string ""
cdsSpice.dc by string ""
cdsSpice.dc device string ""
;cdsSpice dcOpts partition variables
;cdsSpice noise partition variables
cdsSpice.noise enable toggle (nil)
cdsSpice.noise source string ""
cdsSpice.noise output string ""
cdsSpice.noise listEvery string "1"
;cdsSpice noiseOpts partition variables
;cdsSpice ac partition variables
cdsSpice.ac enable toggle (nil)
cdsSpice.ac from string ""
cdsSpice.ac to string ""
cdsSpice.ac incrType string "Logarithmic"
cdsSpice.ac lin string ""
cdsSpice.ac log string ""
;cdsSpice acOpts partition variables
;cdsSpice tran partition variables
cdsSpice.tran enable toggle (nil)
cdsSpice.tran from string ""
cdsSpice.tran to string ""
cdsSpice.tran by string ""
cdsSpice.tran delmax string ""
cdsSpice.tran continue boolean nil
cdsSpice.tran newParam boolean nil
;cdsSpice tranOpts partition variables
;cdsSpiceVerilog environment variables
;cdsSpiceVerilog opts partition variables
cdsSpiceVerilog.opts TEMPDC string "25"
cdsSpiceVerilog.opts NSIG string "4"
cdsSpiceVerilog.opts TIMSAT string "0"
cdsSpiceVerilog.opts RELTOL string "1e-3"
cdsSpiceVerilog.opts MKS string "1"
cdsSpiceVerilog.opts ITL5 string "999999"
cdsSpiceVerilog.opts ARTSTR string "0"
cdsSpiceVerilog.opts GMINON string "2"
cdsSpiceVerilog.opts LVLTIM string "2"
cdsSpiceVerilog.opts VCESAT string "0.0"
cdsSpiceVerilog.opts ITL3 string "4"
cdsSpiceVerilog.opts SCALEM string "1"
cdsSpiceVerilog.opts GO2OFF string "0"
cdsSpiceVerilog.opts ITL4 string "25"
cdsSpiceVerilog.opts AVSTEP string ".33"
cdsSpiceVerilog.opts ITL1 string "100"
cdsSpiceVerilog.opts ITL2 string "100"
cdsSpiceVerilog.opts METHOD string "1"
cdsSpiceVerilog.opts CHGTOL string "1e-14"
cdsSpiceVerilog.opts TNOM string "25"
cdsSpiceVerilog.opts MORBKP string ".1"
cdsSpiceVerilog.opts ABSTOL string "1e-12"
cdsSpiceVerilog.opts UIC string "0"
cdsSpiceVerilog.opts GRTEXT string "1"
cdsSpiceVerilog.opts SINWAV string "1e+6"
cdsSpiceVerilog.opts PRNOTE string "1"
cdsSpiceVerilog.opts VLIMAX string "50000"
cdsSpiceVerilog.opts INTTIM string "0"
cdsSpiceVerilog.opts GSAVE string "0"
cdsSpiceVerilog.opts GMIN string "1e-12"
cdsSpiceVerilog.opts DCSAT string "0"
cdsSpiceVerilog.opts CNVREV string "2.4"
cdsSpiceVerilog.opts TINIT string ""
cdsSpiceVerilog.opts MFNOIS string "0"
cdsSpiceVerilog.opts QADLIN string "0"
cdsSpiceVerilog.opts VBESAT string "0.6"
cdsSpiceVerilog.opts PSFFLG string "1"
cdsSpiceVerilog.opts SCALE string "1"
cdsSpiceVerilog.opts TRTOL string "7"
cdsSpiceVerilog.opts SPICE2G string "0"
cdsSpiceVerilog.opts SPTEMP string "1"
cdsSpiceVerilog.opts WRFLAG string "0"
cdsSpiceVerilog.opts RON string "1"
cdsSpiceVerilog.opts NRAMP string "0"
cdsSpiceVerilog.opts NOWARN string "0"
cdsSpiceVerilog.opts VNTOL string "1e-6"
cdsSpiceVerilog.opts MAXORD string "2"
cdsSpiceVerilog.opts DCOPPT string "1"
cdsSpiceVerilog.opts VBCSAT string "0.15"
cdsSpiceVerilog.opts SPMESS string "1"
;cdsSpiceVerilog outputs partition variables
cdsSpiceVerilog.outputs allDigitalNV boolean t
cdsSpiceVerilog.outputs allAnalogNV boolean t
cdsSpiceVerilog.outputs allAnalogTC boolean nil
;cdsSpiceVerilog verimixOpts partition variables
cdsSpiceVerilog.verimixOpts filename6 string ""
cdsSpiceVerilog.verimixOpts maxDCIter int 0
cdsSpiceVerilog.verimixOpts scope1 string ""
cdsSpiceVerilog.verimixOpts scope10 string ""
cdsSpiceVerilog.verimixOpts filename8 string ""
cdsSpiceVerilog.verimixOpts dcInterval float 0.0
cdsSpiceVerilog.verimixOpts scope3 string ""
cdsSpiceVerilog.verimixOpts scope8 string ""
cdsSpiceVerilog.verimixOpts scope7 string ""
cdsSpiceVerilog.verimixOpts filename7 string ""
cdsSpiceVerilog.verimixOpts scope string ""
cdsSpiceVerilog.verimixOpts filename4 string ""
cdsSpiceVerilog.verimixOpts filename string ""
cdsSpiceVerilog.verimixOpts filename1 string ""
cdsSpiceVerilog.verimixOpts scope9 string ""
cdsSpiceVerilog.verimixOpts importsdfswitch boolean nil
cdsSpiceVerilog.verimixOpts filename2 string ""
cdsSpiceVerilog.verimixOpts numberofsdffiles int 2
cdsSpiceVerilog.verimixOpts scope2 string ""
cdsSpiceVerilog.verimixOpts scope6 string ""
cdsSpiceVerilog.verimixOpts filename10 string ""
cdsSpiceVerilog.verimixOpts delaymodechoice string "Ignore"
cdsSpiceVerilog.verimixOpts sdfmixedswitch boolean t
cdsSpiceVerilog.verimixOpts filename9 string ""
cdsSpiceVerilog.verimixOpts scope5 string ""
cdsSpiceVerilog.verimixOpts filename5 string ""
cdsSpiceVerilog.verimixOpts filename3 string ""
cdsSpiceVerilog.verimixOpts scope4 string ""
;cdsSpiceVerilog verilogOpts partition variables
cdsSpiceVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
cdsSpiceVerilog.verilogOpts optionsFile string ""
cdsSpiceVerilog.verilogOpts twinTurbo boolean nil
cdsSpiceVerilog.verilogOpts suppressMessages boolean nil
cdsSpiceVerilog.verilogOpts libraryFile string ""
cdsSpiceVerilog.verilogOpts behaveProfile boolean nil
cdsSpiceVerilog.verilogOpts verimixLog string "verilog.log"
cdsSpiceVerilog.verilogOpts simVision boolean nil
cdsSpiceVerilog.verilogOpts pulseSpec boolean nil
cdsSpiceVerilog.verilogOpts commandFile string ""
cdsSpiceVerilog.verilogOpts pulseError int 100
cdsSpiceVerilog.verilogOpts stopCompile boolean nil
cdsSpiceVerilog.verilogOpts keepNodes string "Minimum"
cdsSpiceVerilog.verilogOpts accelerationCA boolean nil
cdsSpiceVerilog.verilogOpts turboRadio string "Default"
cdsSpiceVerilog.verilogOpts libraryDir string ""
cdsSpiceVerilog.verilogOpts suppressWarnings boolean nil
cdsSpiceVerilog.verilogOpts accelerationSwitches boolean nil
cdsSpiceVerilog.verilogOpts accelerationNormal boolean t
cdsSpiceVerilog.verilogOpts delayType string "Typical"
cdsSpiceVerilog.verilogOpts pulseReject int 100
cdsSpiceVerilog.verilogOpts delayMode string "Default"
cdsSpiceVerilog.verilogOpts vermixBinary string "verilog.vmx"
;cdsSpiceVerilog init partition variables
cdsSpiceVerilog.init processPriority int 0
;cdsSpiceVerilog envOpts partition variables
cdsSpiceVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
cdsSpiceVerilog.envOpts mspNetlistMode string "Flat"
cdsSpiceVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistEscapeName boolean nil
cdsSpiceVerilog.envOpts updateFile string ""
cdsSpiceVerilog.envOpts stimulusFile string ""
cdsSpiceVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
cdsSpiceVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
cdsSpiceVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
cdsSpiceVerilog.envOpts includeSyntax string "cdsSpice"
cdsSpiceVerilog.envOpts mspSetupNetlistPinMap boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistBus boolean t
cdsSpiceVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
cdsSpiceVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
cdsSpiceVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
cdsSpiceVerilog.envOpts mspSetupNetlistExplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
cdsSpiceVerilog.envOpts initFile string ""
cdsSpiceVerilog.envOpts printComments boolean nil
cdsSpiceVerilog.envOpts includeFile string ""
cdsSpiceVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
cdsSpiceVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
cdsSpiceVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimTimeValue int 1
cdsSpiceVerilog.envOpts mspSetupNetlistUseLib boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistNullPort boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistDropPortRange boolean t
cdsSpiceVerilog.envOpts mspSetupNetlistUpCase boolean nil
cdsSpiceVerilog.envOpts generateMapFile boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;cdsSpiceVerilog dc partition variables
cdsSpiceVerilog.dc enable toggle (nil)
cdsSpiceVerilog.dc from string ""
cdsSpiceVerilog.dc to string ""
cdsSpiceVerilog.dc by string ""
cdsSpiceVerilog.dc device string ""
;cdsSpiceVerilog dcOpts partition variables
;cdsSpiceVerilog noise partition variables
cdsSpiceVerilog.noise enable toggle (nil)
cdsSpiceVerilog.noise source string ""
cdsSpiceVerilog.noise output string ""
cdsSpiceVerilog.noise listEvery string "1"
;cdsSpiceVerilog noiseOpts partition variables
;cdsSpiceVerilog ac partition variables
cdsSpiceVerilog.ac enable toggle (nil)
cdsSpiceVerilog.ac from string ""
cdsSpiceVerilog.ac to string ""
cdsSpiceVerilog.ac incrType string "Logarithmic"
cdsSpiceVerilog.ac lin string ""
cdsSpiceVerilog.ac log string ""
;cdsSpiceVerilog acOpts partition variables
;cdsSpiceVerilog tran partition variables
cdsSpiceVerilog.tran enable toggle (nil)
cdsSpiceVerilog.tran from string ""
cdsSpiceVerilog.tran to string ""
cdsSpiceVerilog.tran by string ""
cdsSpiceVerilog.tran delmax string ""
cdsSpiceVerilog.tran continue boolean nil
cdsSpiceVerilog.tran newParam boolean nil
;cdsSpiceVerilog tranOpts partition variables
; CMX CONSTRAINT MANAGER - ENVIRONMENT VARIABLES (FACTORY DEFAULTS)
; This tool registration file should not be edited since customization
; is done via the file in <cdshier>/samples/.cdsenv
;FACTORY DEFAULTS FOR NET-BASED SUPER CATEGORY (cmxNetBasedSuperCat)
;Net Class To Net Category (cmxClassToNetCat)
;default weight for constraints
cmx.cmxClassToNetCat defaultWeight int 200
;inter-layer clearance
cmx.cmxClassToNetCat defVal_ilc float 0.0
cmx.cmxClassToNetCat minVal_ilc float 0.0
cmx.cmxClassToNetCat maxVal_ilc float 0.0
;layer depth
cmx.cmxClassToNetCat defVal_depth int 0
cmx.cmxClassToNetCat minVal_depth int 0
cmx.cmxClassToNetCat maxVal_depth int 0
;Net-Class To Net-Class Category (cmxClassToClassCat)
cmx.cmxClassToClassCat defaultWeight int 200
cmx.cmxClassToClassCat defVal_ilc float 0.0
cmx.cmxClassToClassCat minVal_ilc float 0.0
cmx.cmxClassToClassCat maxVal_ilc float 0.0
;layer depth
cmx.cmxClassToClassCat defVal_depth int 0
cmx.cmxClassToClassCat minVal_depth int 0
cmx.cmxClassToClassCat maxVal_depth int 0
;Net To Net Category (cmxNetToNetCat)
cmx.cmxNetToNetCat defaultWeight int 200
cmx.cmxNetToNetCat defVal_ilc float 0.0
cmx.cmxNetToNetCat minVal_ilc float 0.0
cmx.cmxNetToNetCat maxVal_ilc float 0.0
;layer depth
cmx.cmxNetToNetCat defVal_depth int 0
cmx.cmxNetToNetCat minVal_depth int 0
cmx.cmxNetToNetCat maxVal_depth int 0
;differential pair gap
cmx.cmxNetToNetCat defVal_diffgap float 0.0
cmx.cmxNetToNetCat minVal_diffgap float 0.0
cmx.cmxNetToNetCat maxVal_diffgap float 0.0
;tandem shield overhang
cmx.cmxNetToNetCat defVal_tanhang float 0.0
cmx.cmxNetToNetCat minVal_tanhang float 0.0
cmx.cmxNetToNetCat maxVal_tanhang float 0.0
;parallel shield gap
cmx.cmxNetToNetCat defVal_pargap float 0.0
cmx.cmxNetToNetCat minVal_pargap float 0.0
cmx.cmxNetToNetCat maxVal_pargap float 0.0
;parallel shield width
cmx.cmxNetToNetCat defVal_parwidth float 0.0
cmx.cmxNetToNetCat minVal_parwidth float 0.0
cmx.cmxNetToNetCat maxVal_parwidth float 0.0
;Net/Net-Class Category (cmxNetCat)
cmx.cmxNetCat defaultWeight int 200
;net priority
cmx.cmxNetCat defVal_pri int 0
cmx.cmxNetCat minVal_pri int 0
cmx.cmxNetCat maxVal_pri int 255
;net width
cmx.cmxNetCat defVal_width float 0.0
cmx.cmxNetCat minVal_width float 0.0
cmx.cmxNetCat maxVal_width float 0.0
;minimum IR drop
cmx.cmxNetCat defVal_minird float 0.0
cmx.cmxNetCat minVal_minird float 0.0
cmx.cmxNetCat maxVal_minird float 0.0
;maximum IR drop
cmx.cmxNetCat defVal_maxird float 0.0
cmx.cmxNetCat minVal_maxird float 0.0
cmx.cmxNetCat maxVal_maxird float 0.0
;FACTORY DEFAULTS FOR GEOMETRIC SUPER CATEGORY (cmxGeometricSuperCat)
;Symmetry Category (cmxSymCat)
cmx.cmxSymCat defaultWeight int 200
;axis name
cmx.cmxSymCat defVal_axis string ""
;Grouping Category (cmxGroupingCat)
cmx.cmxGroupingCat defaultWeight int 200
;preserve relative position
cmx.cmxGroupingCat defVal_prPos boolean t
;no fence needed
cmx.cmxGroupingCat defVal_noFence boolean t
;fence shape name
cmx.cmxGroupingCat defVal_fence string ""
;exclude all
cmx.cmxGroupingCat defVal_exclAll boolean nil
;Alignment Category (cmxAlignCat)
cmx.cmxAlignCat defaultWeight int 200
;orientation
cmx.cmxAlignCat defVal_orient string "NO_CARE"
;alignment reference
cmx.cmxAlignCat defVal_alignRef string "NO_CARE"
;reference segment
cmx.cmxAlignCat defVal_segment int 0
;inner or outer edge
cmx.cmxAlignCat defVal_inner boolean t
;alignment layer
cmx.cmxAlignCat defVal_alignLayer string "bBox"
;check ordering
cmx.cmxAlignCat defVal_order boolean t
;compactor direction (for Compactor only)
cmx.cmxAlignCat defVal_compactDir boolean nil
;Fixed Category (cmxFixedCat)
cmx.cmxFixedCat defaultWeight int 200
;check x position
cmx.cmxFixedCat defVal_x boolean t
;default x value
cmx.cmxFixedCat defVal_xVal float 0.0
;check y position
cmx.cmxFixedCat defVal_y boolean t
;default y value
cmx.cmxFixedCat defVal_yVal float 0.0
;default orientation
cmx.cmxFixedCat defVal_orient string "AS_IS"
;default reference
cmx.cmxFixedCat defVal_refer string "CENTER"
;default user movable
cmx.cmxFixedCat defVal_userMovable boolean nil
;Distance Category (cmxDistCat)
cmx.cmxDistCat defaultWeight int 200
;check minimum manhattan x distance
cmx.cmxDistCat defVal_minX boolean t
;minimum manhattan x distance value
cmx.cmxDistCat defVal_minXVal float 0.0
;check maximum manhattan x distance
cmx.cmxDistCat defVal_maxX boolean t
;maximum manhattan x distance value
cmx.cmxDistCat defVal_maxXVal float 0.0
;check minimum manhattan y distance
cmx.cmxDistCat defVal_minY boolean t
;minimum manhattan y distance value
cmx.cmxDistCat defVal_minYVal float 0.0
;check maximum manhattan y distance
cmx.cmxDistCat defVal_maxY boolean t
;maximum manhattan y distance
cmx.cmxDistCat defVal_maxYVal float 0.0
;reference for measurement on x-axis
cmx.cmxDistCat defVal_referX string "CENTER"
;reference for measurement on y-axis
cmx.cmxDistCat defVal_referY string "CENTER"
;ROD Alignment Category (cmxRodAlignCat)
;default name for ROD object 1
;default handle name for ROD object 1
;default name for ROD object 2
;default handle name for ROD object 2
compactor hilite1LPP string "hilite drawing"
compactor hilite2LPP string "marker error"
compactor hilite3LPP string "hilite drawing1"
compactor hilite4LPP string "hilite drawing2"
compactor cpCpathLPP string "annotate drawing7"
compactor cpAuxLPP string "annotate drawing8"
compactor cpOutlineLPP string "annotate drawing9"
compactor useDBox boolean t
compactor arrowScale float 1.0
compactor zoomScale float 1.2
compactor checkSaved boolean t
conn2sch src_sch_lib string ""
conn2sch src_cell_name string ""
conn2sch src_view_name string ""
conn2sch dest_sch_lib string ""
conn2sch dest_view_name string "schematic"
conn2sch dest_cell_name string ""
conn2sch dest_symbol_view_name string "symbol"
conn2sch ref_lib_list string "analogLib basic sample"
conn2sch log_file_name string "./conn2sch.log"
conn2sch import_if_exists int 0
conn2sch sheet_symbol string "none "
conn2sch line_line_spacing float 0.2
conn2sch line_component_spacing float 0.5
conn2sch density_level int 0
conn2sch label_height int 10
conn2sch pin_placement string "left_and_right_sides"
conn2sch page_col_limit int 1024
conn2sch page_row_limit int 1024
conn2sch full_place_and_route boolean t
conn2sch optimize_wire_label_locn boolean nil
conn2sch minimize_crossovers boolean nil
conn2sch generate_square_schematic boolean t
conn2sch extract_schematic boolean t
conn2sch verbose boolean nil
;Digital Ciruit Design Flow Environment Defaults
;FORMAT: tool[.partition] varName type value private {choices, minmax} comment
;Session Options
dcdf dcdfNoDirectNetlister boolean nil
dcdf dcdfDefaultFileDir string ""
; ddserv Environment Variables
ddserv.browser onOpen boolean nil
ddserv.browser onOther boolean nil
ddserv.browser onPlace boolean nil
ddserv.ciw promptOnExit boolean t
ddserv.he objectFilter string "same"
ddserv.he objectScope string "current instance"
ddserv.lib dmChoice string "No DM"
ddserv.lib enableCopyInDFII boolean nil
ddserv.lib newLibDir string ""
ddserv.lib techChoice cyclic "compile"
ddserv showWhatsNew string "yes"
; Graphics Editor and Design Editor Environment Variables
; Installation-wide customizations should be made to the
; to the .cdsenv file in $CDS_INST_DIR/tools/dfII/samples
; directory. Make user-specific customizations to the
; .cdsenv file in your home directory.
graphic accessEdgesOn boolean nil
graphic arrayDisplay string "Full"
graphic askSaveOnReturn boolean t
graphic coalesceLimit int 10
graphic coalesceRatio int 10
graphic defaultNewCellName string ""
graphic defaultNewLibName string ""
graphic defaultNewViewName string ""
graphic defaultOpenCellName string ""
graphic defaultOpenLibName string ""
graphic defaultOpenViewName string ""
graphic defaultToolName string ""
graphic displayPinNames boolean t
graphic displayStretchHandles boolean t
graphic displaySchDashText boolean nil
graphic dotsOn boolean t
graphic drawAxesOn boolean t
graphic drawDottedGridOn boolean t
graphic drawGridOn boolean t
graphic drawInstancePins boolean t
graphic drawPRBoundary boolean nil
graphic drawSurroundingOn boolean t
graphic drfPath string ""
graphic dynamicHilightOn boolean t
graphic eipRedraw boolean t
graphic filterSize float 1.0
graphic filterSizeDrawingStyle string "filled"
graphic gridMultiple int 5
graphic gridSpacing float 1.0
graphic iconsOn boolean t
graphic instLabel string "master"
graphic iterNum int 500
graphic jumpersOn boolean t
graphic leCheckMissingLayers boolean nil
graphic leCheckMissingMasters boolean nil
graphic leDispNetExpr boolean t
graphic markerZoom boolean nil
graphic markerShowIgnore boolean t
graphic markerSeverity string "all"
graphic markerZoomScale int 4
graphic maxDragFig int 500
graphic minLabelSize float 1.0
graphic minRefreshArea int 500
graphic minStippleSize float 1.0
graphic netsOn boolean t
graphic originMarkersOn boolean t
graphic outlineOnly boolean t
graphic packetDialogBoxes boolean t
graphic partialSelect boolean t
graphic pathCL string "yes"
graphic netExprDisplay string "expression only"
graphic pathWidth float 5.0
graphic probeTextOn boolean t
graphic pruneSize float 10
graphic segSnapMode string "anyAngle"
graphic selectionAperture int 5
graphic snapMode string "anyAngle"
graphic snapToGrid boolean t
graphic startLevel int 0
graphic stopLevel int 0
graphic stretchHandlesLayer string "y0 drawing"
graphic textJustificationOn boolean t
graphic tinyInstDetail boolean nil
graphic transformMarkersOn boolean t
graphic useTrueBBox boolean t
graphic viewNameList string ""
graphic viewNameToTypeList string ""
graphic xSnapSpacing float 1.0
graphic ySnapSpacing float 1.0
graphic cursorShape boolean nil
graphic drawEngine int 0
graphic openToStopLevel boolean nil
graphic displayViaShapes boolean nil
;hspiceD environment variables
;hspiceD opts partition variables
hspiceD.opts PARHIER string "LOCAL"
hspiceD.opts GENK boolean nil
hspiceD.opts RISETIME string "0"
hspiceD.opts RELQ string "1e-2"
hspiceD.opts FFTOUT boolean nil
hspiceD.opts LVLTIM string "DVDT (1)"
hspiceD.opts ARTIST string "On (2)"
hspiceD.opts NEWTOL boolean nil
hspiceD.opts ABSMOS string "1e-6"
hspiceD.opts DIAGNOSTIC boolean nil
hspiceD.opts MODMONTE boolean nil
hspiceD.opts VFLOOR string "0"
hspiceD.opts FS string "25e-2"
hspiceD.opts CO string "Narrow (80)"
hspiceD.opts DEFAS string "0"
hspiceD.opts RESMIN string "1e-5"
hspiceD.opts WARNLIMIT string "1"
hspiceD.opts TRCON string "On (1)"
hspiceD.opts PSF string "ASCII (2)"
hspiceD.opts BRIEF boolean nil
hspiceD.opts ICSWEEP boolean nil
hspiceD.opts DCFOR string "0"
hspiceD.opts DCHOLD string "1"
hspiceD.opts GMIN string "1e-12"
hspiceD.opts INGOLD string "SPICE (2)"
hspiceD.opts NODE boolean nil
hspiceD.opts DCSTEP string "0"
hspiceD.opts ZUKEN string "Off (1)"
hspiceD.opts TRTOL string "7"
hspiceD.opts BYTOL string "5e-5"
hspiceD.opts AUTOSTOP boolean nil
hspiceD.opts LIMTIM string "2.0"
hspiceD.opts EXPMAX string "8e+1"
hspiceD.opts DVDT string "Balance (3)"
hspiceD.opts PUTMEAS boolean nil
hspiceD.opts NOWARN boolean nil
hspiceD.opts MONTECON boolean nil
hspiceD.opts BEEP string "Off (0)"
hspiceD.opts MEASSORT boolean nil
hspiceD.opts NUMDGT string "4"
hspiceD.opts ITL5 string "0"
hspiceD.opts BADCHR boolean nil
hspiceD.opts PIVTOL string "1e-15"
hspiceD.opts METHOD string "TRAP"
hspiceD.opts LIMPTS string "2001"
hspiceD.opts CHGTOL string "1e-15"
hspiceD.opts GSHUNT string "0"
hspiceD.opts DVTR string "1e+3"
hspiceD.opts DI string "0"
hspiceD.opts HIER_SCALE string "None ()"
hspiceD.opts CSHDC string "1e-12"
hspiceD.opts RELI string "1e-2"
hspiceD.opts PATHNUM boolean nil
hspiceD.opts DEFW string "1e-4"
hspiceD.opts POST_VERSION string "2001"
hspiceD.opts DCON string "Auto (0)"
hspiceD.opts DEFL string "1e-4"
hspiceD.opts DEFNRS string "0"
hspiceD.opts ABSV string "5e-5"
hspiceD.opts CONVERGE string "Autoconvergance (0)"
hspiceD.opts NOPIV boolean nil
hspiceD.opts LENNAM string "8"
hspiceD.opts DCAP string "2"
hspiceD.opts DLENCSDF string "5"
hspiceD.opts ITLPZ string "100"
hspiceD.opts MBYPASS string "1"
hspiceD.opts GMINDC string "1e-12"
hspiceD.opts RELV string "1e-3"
hspiceD.opts GRAMP string "0"
hspiceD.opts ASPEC boolean nil
hspiceD.opts DV string "1e+3"
hspiceD.opts SEED string "259200"
hspiceD.opts RMIN string "1e-9"
hspiceD.opts RELVDC string "1e-3"
hspiceD.opts ACCT string "Enabled (1)"
hspiceD.opts RELMOS string "5e-2"
hspiceD.opts TEMPDC string "25"
hspiceD.opts ACCURATE boolean nil
hspiceD.opts CSDF boolean nil
hspiceD.opts SEARCH boolean nil
hspiceD.opts MAXAMP string "0"
hspiceD.opts NOMOD boolean nil
hspiceD.opts PIVREF string "1e8"
hspiceD.opts NOPAGE boolean nil
hspiceD.opts ALT9999 boolean nil
hspiceD.opts CAPTAB boolean nil
hspiceD.opts ITL1 string "2e+2"
hspiceD.opts ITL2 string "5e+1"
hspiceD.opts POST string "Binary (1)"
hspiceD.opts PIVREL string "1e-20"
hspiceD.opts ALT999 boolean nil
hspiceD.opts MEASFAIL boolean nil
hspiceD.opts STATFL string "Create .st0 (0)"
hspiceD.opts BKPSIZ string "5000"
hspiceD.opts ABSVAR string ".5"
hspiceD.opts ITRPRT boolean nil
hspiceD.opts SPICE boolean nil
hspiceD.opts GMAX string "1e+2"
hspiceD.opts RMAX string "2"
hspiceD.opts OFF boolean nil
hspiceD.opts BYPASS string "1"
hspiceD.opts OPTS boolean nil
hspiceD.opts IMIN string "3"
hspiceD.opts KCLTEST boolean nil
hspiceD.opts CDS string "Off (0)"
hspiceD.opts RELH string "5e-2"
hspiceD.opts ALTCHK string "On (1)"
hspiceD.opts ACOUT string "Star-Hspice Method (1)"
hspiceD.opts FT string "25e-2"
hspiceD.opts WL boolean nil
hspiceD.opts LIST boolean nil
hspiceD.opts RELVAR string ".30"
hspiceD.opts MAXORD string "Normal (2)"
hspiceD.opts DEFPS string "0"
hspiceD.opts MEASOUT boolean nil
hspiceD.opts FAST boolean nil
hspiceD.opts CPTIME string "1e+7"
hspiceD.opts IMAX string "8"
hspiceD.opts DEFNRD string "0"
hspiceD.opts OPTLST string "No Info (0)"
hspiceD.opts ABSVDC string "5e-5"
hspiceD.opts INTERP boolean nil
hspiceD.opts PROBE boolean nil
hspiceD.opts DCCAP boolean nil
hspiceD.opts DEFAD string "0"
hspiceD.opts TIMERES string "1e-15"
hspiceD.opts SCALM string "1"
hspiceD.opts TNOM string "25"
hspiceD.opts POSTTOP string "0"
hspiceD.opts MODSRH boolean nil
hspiceD.opts KLIM string "1e-2"
hspiceD.opts H9007 boolean nil
hspiceD.opts UNWRAP boolean nil
hspiceD.opts CVTOL string ".2"
hspiceD.opts PLIM string "SPICE (1)"
hspiceD.opts MENTOR string "Off (0)"
hspiceD.opts MEASDGT string "4"
hspiceD.opts NOTOP boolean nil
hspiceD.opts MU string ".5"
hspiceD.opts DEFPD string "0"
hspiceD.opts SLOPETOL string ".5"
hspiceD.opts SCALE string "1"
hspiceD.opts CSHUNT string "0"
hspiceD.opts EPSMIN string "1e-28"
hspiceD.opts EXPLI string "0"
hspiceD.opts NOELCK boolean nil
hspiceD.opts ABSI string "1e-9"
hspiceD.opts BINPRINT boolean nil
hspiceD.opts PIVOT string "Fast, non-pivoting (10)"
hspiceD.opts ITLPTRAN string "30"
hspiceD.opts PURETP boolean nil
hspiceD.opts ABSH string "0"
;hspiceD outputs partition variables
hspiceD.outputs allAnalogNV boolean t
hspiceD.outputs allAnalogTC boolean nil
;hspiceD envOpts partition variables
hspiceD.envOpts autoDisplay boolean t
hspiceD.envOpts stopViewList string "hspiceD spice"
hspiceD.envOpts printComments boolean nil
hspiceD.envOpts switchViewList string "hspiceD spice cmos_sch cmos.sch schematic"
;hspiceD init partition variables
hspiceD.init processPriority int 0
;hspiceD ac partition variables
hspiceD.ac enable toggle (nil)
hspiceD.ac sweepType string "decade"
hspiceD.ac numPoints string "10"
hspiceD.ac fstart string ""
hspiceD.ac fstop string ""
hspiceD.ac points string ""
;hspiceD acOpts partition variables
;hspiceD dc partition variables
hspiceD.dc enable toggle (nil)
hspiceD.dc sweep string "Source"
hspiceD.dc designVar string ""
hspiceD.dc source string ""
hspiceD.dc sweepType string "Automatic"
hspiceD.dc start string ""
hspiceD.dc stop string ""
hspiceD.dc stepSize string ""
hspiceD.dc numPoints string ""
hspiceD.dc poiNumPoints string ""
hspiceD.dc points string ""
;hspiceD dcOpts partition variables
;hspiceD noise partition variables
hspiceD.noise enable toggle (nil)
hspiceD.noise node string ""
hspiceD.noise insrc string ""
hspiceD.noise nums string "0"
;hspiceD noiseOpts partition variables
;hspiceD op partition variables
hspiceD.op enable toggle (nil)
hspiceD.op format string "all"
hspiceD.op time string ""
;hspiceD opOpts partition variables
;hspiceD tran partition variables
hspiceD.tran enable toggle (nil)
hspiceD.tran start string ""
hspiceD.tran stop string ""
hspiceD.tran step string ""
hspiceD.tran uic boolean nil
;hspiceD tranOpts partition variables
;hspiceS environment variables
;hspiceS opts partition variables
hspiceS.opts PARHIER string "GLOBAL"
hspiceS.opts GENK string "1"
hspiceS.opts RELQ string "1e-2"
hspiceS.opts LVLTIM string "default ( 1 )"
hspiceS.opts BKPSZE string "5000"
hspiceS.opts ARTIST string "artistdefault ( 2 )"
hspiceS.opts ABSMOS string "1e-6"
hspiceS.opts NEWTOL string "off"
hspiceS.opts RMAXDC string "1e+2"
hspiceS.opts DIAGNOSTIC string "off"
hspiceS.opts VFLOOR string "0"
hspiceS.opts FS string "25e-2"
hspiceS.opts CO string "78"
hspiceS.opts DEFAS string "0"
hspiceS.opts UIC string "off"
hspiceS.opts RESMIN string "1e-5"
hspiceS.opts WARNLIMIT string "1"
hspiceS.opts PSF string "artistdefault ( 2 )"
hspiceS.opts BRIEF string "off"
hspiceS.opts ICSWEEP string "default ( 1 )"
hspiceS.opts DCFOR string "0"
hspiceS.opts DCHOLD string "1"
hspiceS.opts GMIN string "1e-12"
hspiceS.opts INGOLD string "artistdefault ( 2 )"
hspiceS.opts DCSTEP string "0"
hspiceS.opts NODE string "off"
hspiceS.opts TRTOL string "7"
hspiceS.opts LIMTIM string "2.0"
hspiceS.opts EXPMAX string "8e+1"
hspiceS.opts DVDT string "default ( 3 )"
hspiceS.opts NOWARN string "off"
hspiceS.opts ITL5 string "0"
hspiceS.opts NUMDGT string "default ( 4 )"
hspiceS.opts BADCHR string "off"
hspiceS.opts PIVTOL string "1e-15"
hspiceS.opts LIMPTS string "2001"
hspiceS.opts METHOD string "TRAP"
hspiceS.opts CHGTOL string "1e-15"
hspiceS.opts GSHUNT string "0"
hspiceS.opts DVTR string "1e+3"
hspiceS.opts DI string "1e+2"
hspiceS.opts CSHDC string "1e-12"
hspiceS.opts RELI string "1e-2"
hspiceS.opts PATHNUM string "off"
hspiceS.opts DEFW string "1e-4"
hspiceS.opts DCON string "default ( 0 )"
hspiceS.opts DEFL string "1e-4"
hspiceS.opts DEFNRS string "0"
hspiceS.opts TIMRES string "1E-12"
hspiceS.opts CONVERGE string "default ( 1 )"
hspiceS.opts ABSV string "5e-5"
hspiceS.opts LENNAM string "8"
hspiceS.opts NOPIV string "off"
hspiceS.opts DCAP string "default ( 2 )"
hspiceS.opts GMINDC string "1e-12"
hspiceS.opts RELV string "1e-3"
hspiceS.opts GRAMP string "0"
hspiceS.opts ASPEC string "off"
hspiceS.opts DV string "1e+3"
hspiceS.opts RMIN string "1e-9"
hspiceS.opts RELVDC string "1e-3"
hspiceS.opts ACCT string "default ( 1 )"
hspiceS.opts SPMESS string "default ( 1 )"
hspiceS.opts RELMOS string "5e-2"
hspiceS.opts TEMPDC string "25"
hspiceS.opts CSDF string "off"
hspiceS.opts ACCURA string "off"
hspiceS.opts MAXAMP string "0"
hspiceS.opts NOMOD string "off"
hspiceS.opts PIVREF string "1e8"
hspiceS.opts NOPAGE string "off"
hspiceS.opts CAPTAB string "off"
hspiceS.opts ITL1 string "2e+2"
hspiceS.opts ITL2 string "5e+1"
hspiceS.opts POST string "default ( 0 )"
hspiceS.opts PIVREL string "1e-4"
hspiceS.opts ABSVAR string ".5"
hspiceS.opts ITRPRT string "off"
hspiceS.opts SPICE string "off"
hspiceS.opts GMAX string "1e+2"
hspiceS.opts RMAX string "2"
hspiceS.opts BYPASS string "default ( 0 )"
hspiceS.opts OFF string "0"
hspiceS.opts IMIN string "3"
hspiceS.opts KCLTEST string "off"
hspiceS.opts OPTS string "off"
hspiceS.opts RELH string "5e-2"
hspiceS.opts ACOUT string "default ( 1 )"
hspiceS.opts FT string "25e-2"
hspiceS.opts WL string "default ( 0 )"
hspiceS.opts LIST string "on"
hspiceS.opts RELVAR string ".30"
hspiceS.opts DCOPPT string "1"
hspiceS.opts MAXORD string "default ( 2 )"
hspiceS.opts DEFPS string "0"
hspiceS.opts MEASOUT string "on"
hspiceS.opts FAST string "off"
hspiceS.opts CPTIME string "1e+7"
hspiceS.opts IMAX string "8"
hspiceS.opts DEFNRD string "0"
hspiceS.opts OPTLST string "default ( 0 )"
hspiceS.opts ABSVDC string "5e-5"
hspiceS.opts INTERP string "0"
hspiceS.opts DCCAP string "off"
hspiceS.opts DEFAD string "0"
hspiceS.opts SCALM string "1"
hspiceS.opts TNOM string "25"
hspiceS.opts DOIRSCAL string "0"
hspiceS.opts KLIM string "1e-2"
hspiceS.opts AUTOST string "off"
hspiceS.opts H9007 string "off"
hspiceS.opts UNWRAP string "off"
hspiceS.opts CVTOL string ".2"
hspiceS.opts PLIM string "default ( 1 )"
hspiceS.opts K2LIM string "0"
hspiceS.opts MBYPAS string "1"
hspiceS.opts MEASDGT string "default ( 4 )"
hspiceS.opts DEFPD string "0"
hspiceS.opts MU string ".5"
hspiceS.opts NOTOP string "off"
hspiceS.opts SCALE string "1"
hspiceS.opts CSHUNT string "0"
hspiceS.opts EPSMIN string "1e-28"
hspiceS.opts SDA string "default ( 0 )"
hspiceS.opts ABSI string "1e-9"
hspiceS.opts NOELCK string "off"
hspiceS.opts PIVOT string "default ( 10 )"
hspiceS.opts ABSH string "0"
;hspiceS outputs partition variables
hspiceS.outputs allAnalogNV boolean t
;hspiceS envOpts partition variables
hspiceS.envOpts updateFile string ""
hspiceS.envOpts stimulusFile string ""
hspiceS.envOpts instViewListTable string ""
hspiceS.envOpts doInstBased boolean nil
hspiceS.envOpts stopViewList string "hspiceS spice"
hspiceS.envOpts reNetlist boolean nil
hspiceS.envOpts includeSyntax string "cdsSpice"
hspiceS.envOpts initFile string ""
hspiceS.envOpts printComments boolean nil
hspiceS.envOpts netlistType string "hierarchical"
hspiceS.envOpts generateMapFile boolean nil
hspiceS.envOpts includeFile string ""
hspiceS.envOpts instStopListTable string ""
hspiceS.envOpts switchViewList string "hspiceS spice cmos_sch cmos.sch schematic"
;hspiceS init partition variables
hspiceS.init processPriority int 0
;hspiceS dc partition variables
hspiceS.dc enable toggle (nil)
hspiceS.dc from string ""
hspiceS.dc to string ""
hspiceS.dc by string ""
hspiceS.dc device string ""
;hspiceS dcOpts partition variables
;hspiceS noise partition variables
hspiceS.noise enable toggle (nil)
hspiceS.noise source string ""
hspiceS.noise output string ""
hspiceS.noise listEvery string "1"
;hspiceS noiseOpts partition variables
;hspiceS ac partition variables
hspiceS.ac enable toggle (nil)
hspiceS.ac from string ""
hspiceS.ac to string ""
hspiceS.ac incrType string "Logarithmic"
hspiceS.ac lin string ""
hspiceS.ac log string ""
;hspiceS acOpts partition variables
;hspiceS tran partition variables
hspiceS.tran enable toggle (nil)
hspiceS.tran from string ""
hspiceS.tran to string ""
hspiceS.tran by string ""
hspiceS.tran delmax string ""
;hspiceS tranOpts partition variables
;hspiceSVerilog environment variables
;hspiceSVerilog opts partition variables
hspiceSVerilog.opts GENK string "1"
hspiceSVerilog.opts PARHIER string "GLOBAL"
hspiceSVerilog.opts RELQ string "1e-2"
hspiceSVerilog.opts LVLTIM string "default ( 1 )"
hspiceSVerilog.opts ARTIST string "artistdefault ( 2 )"
hspiceSVerilog.opts BKPSZE string "5000"
hspiceSVerilog.opts NEWTOL string "off"
hspiceSVerilog.opts ABSMOS string "1e-6"
hspiceSVerilog.opts RMAXDC string "1e+2"
hspiceSVerilog.opts DIAGNOSTIC string "off"
hspiceSVerilog.opts VFLOOR string "0"
hspiceSVerilog.opts FS string "25e-2"
hspiceSVerilog.opts CO string "78"
hspiceSVerilog.opts DEFAS string "0"
hspiceSVerilog.opts RESMIN string "1e-5"
hspiceSVerilog.opts UIC string "off"
hspiceSVerilog.opts PSF string "artistdefault ( 2 )"
hspiceSVerilog.opts WARNLIMIT string "1"
hspiceSVerilog.opts ICSWEEP string "default ( 1 )"
hspiceSVerilog.opts BRIEF string "off"
hspiceSVerilog.opts DCFOR string "0"
hspiceSVerilog.opts GMIN string "1e-12"
hspiceSVerilog.opts DCHOLD string "1"
hspiceSVerilog.opts INGOLD string "artistdefault ( 2 )"
hspiceSVerilog.opts DCSTEP string "0"
hspiceSVerilog.opts NODE string "off"
hspiceSVerilog.opts TRTOL string "7"
hspiceSVerilog.opts LIMTIM string "2.0"
hspiceSVerilog.opts EXPMAX string "8e+1"
hspiceSVerilog.opts DVDT string "default ( 3 )"
hspiceSVerilog.opts NOWARN string "off"
hspiceSVerilog.opts ITL5 string "0"
hspiceSVerilog.opts NUMDGT string "default ( 4 )"
hspiceSVerilog.opts BADCHR string "off"
hspiceSVerilog.opts PIVTOL string "1e-15"
hspiceSVerilog.opts LIMPTS string "2001"
hspiceSVerilog.opts METHOD string "TRAP"
hspiceSVerilog.opts CHGTOL string "1e-15"
hspiceSVerilog.opts GSHUNT string "0"
hspiceSVerilog.opts DVTR string "1e+3"
hspiceSVerilog.opts DI string "1e+2"
hspiceSVerilog.opts CSHDC string "1e-12"
hspiceSVerilog.opts RELI string "1e-2"
hspiceSVerilog.opts PATHNUM string "off"
hspiceSVerilog.opts DEFW string "1e-4"
hspiceSVerilog.opts DCON string "default ( 0 )"
hspiceSVerilog.opts DEFL string "1e-4"
hspiceSVerilog.opts DEFNRS string "0"
hspiceSVerilog.opts TIMRES string "1E-12"
hspiceSVerilog.opts CONVERGE string "default ( 1 )"
hspiceSVerilog.opts ABSV string "5e-5"
hspiceSVerilog.opts LENNAM string "8"
hspiceSVerilog.opts NOPIV string "off"
hspiceSVerilog.opts DCAP string "default ( 2 )"
hspiceSVerilog.opts GMINDC string "1e-12"
hspiceSVerilog.opts RELV string "1e-3"
hspiceSVerilog.opts GRAMP string "0"
hspiceSVerilog.opts ASPEC string "off"
hspiceSVerilog.opts DV string "1e+3"
hspiceSVerilog.opts RMIN string "1e-9"
hspiceSVerilog.opts RELVDC string "1e-3"
hspiceSVerilog.opts ACCT string "default ( 1 )"
hspiceSVerilog.opts SPMESS string "default ( 1 )"
hspiceSVerilog.opts RELMOS string "5e-2"
hspiceSVerilog.opts TEMPDC string "25"
hspiceSVerilog.opts CSDF string "off"
hspiceSVerilog.opts ACCURA string "off"
hspiceSVerilog.opts MAXAMP string "0"
hspiceSVerilog.opts NOMOD string "off"
hspiceSVerilog.opts PIVREF string "1e8"
hspiceSVerilog.opts NOPAGE string "off"
hspiceSVerilog.opts CAPTAB string "off"
hspiceSVerilog.opts ITL1 string "2e+2"
hspiceSVerilog.opts ITL2 string "5e+1"
hspiceSVerilog.opts POST string "default ( 0 )"
hspiceSVerilog.opts PIVREL string "1e-4"
hspiceSVerilog.opts ABSVAR string ".5"
hspiceSVerilog.opts ITRPRT string "off"
hspiceSVerilog.opts SPICE string "off"
hspiceSVerilog.opts GMAX string "1e+2"
hspiceSVerilog.opts RMAX string "2"
hspiceSVerilog.opts BYPASS string "default ( 0 )"
hspiceSVerilog.opts OFF string "0"
hspiceSVerilog.opts IMIN string "3"
hspiceSVerilog.opts KCLTEST string "off"
hspiceSVerilog.opts OPTS string "off"
hspiceSVerilog.opts ACOUT string "default ( 1 )"
hspiceSVerilog.opts RELH string "5e-2"
hspiceSVerilog.opts FT string "25e-2"
hspiceSVerilog.opts LIST string "on"
hspiceSVerilog.opts WL string "default ( 0 )"
hspiceSVerilog.opts RELVAR string ".30"
hspiceSVerilog.opts MAXORD string "default ( 2 )"
hspiceSVerilog.opts DCOPPT string "1"
hspiceSVerilog.opts MEASOUT string "on"
hspiceSVerilog.opts DEFPS string "0"
hspiceSVerilog.opts FAST string "off"
hspiceSVerilog.opts IMAX string "8"
hspiceSVerilog.opts CPTIME string "1e+7"
hspiceSVerilog.opts DEFNRD string "0"
hspiceSVerilog.opts OPTLST string "default ( 0 )"
hspiceSVerilog.opts INTERP string "0"
hspiceSVerilog.opts ABSVDC string "5e-5"
hspiceSVerilog.opts DEFAD string "0"
hspiceSVerilog.opts DCCAP string "off"
hspiceSVerilog.opts SCALM string "1"
hspiceSVerilog.opts DOIRSCAL string "0"
hspiceSVerilog.opts TNOM string "25"
hspiceSVerilog.opts KLIM string "1e-2"
hspiceSVerilog.opts H9007 string "off"
hspiceSVerilog.opts AUTOST string "off"
hspiceSVerilog.opts CVTOL string ".2"
hspiceSVerilog.opts UNWRAP string "off"
hspiceSVerilog.opts K2LIM string "0"
hspiceSVerilog.opts PLIM string "default ( 1 )"
hspiceSVerilog.opts MEASDGT string "default ( 4 )"
hspiceSVerilog.opts MBYPAS string "1"
hspiceSVerilog.opts NOTOP string "off"
hspiceSVerilog.opts MU string ".5"
hspiceSVerilog.opts DEFPD string "0"
hspiceSVerilog.opts EPSMIN string "1e-28"
hspiceSVerilog.opts CSHUNT string "0"
hspiceSVerilog.opts SCALE string "1"
hspiceSVerilog.opts NOELCK string "off"
hspiceSVerilog.opts ABSI string "1e-9"
hspiceSVerilog.opts SDA string "default ( 0 )"
hspiceSVerilog.opts PIVOT string "default ( 10 )"
hspiceSVerilog.opts ABSH string "0"
;hspiceSVerilog outputs partition variables
hspiceSVerilog.outputs allDigitalNV boolean t
hspiceSVerilog.outputs allAnalogNV boolean t
;hspiceSVerilog verimixOpts partition variables
hspiceSVerilog.verimixOpts filename6 string ""
hspiceSVerilog.verimixOpts maxDCIter int 0
hspiceSVerilog.verimixOpts scope1 string ""
hspiceSVerilog.verimixOpts scope10 string ""
hspiceSVerilog.verimixOpts filename8 string ""
hspiceSVerilog.verimixOpts dcInterval float 0.0
hspiceSVerilog.verimixOpts scope3 string ""
hspiceSVerilog.verimixOpts scope8 string ""
hspiceSVerilog.verimixOpts scope7 string ""
hspiceSVerilog.verimixOpts filename7 string ""
hspiceSVerilog.verimixOpts scope string ""
hspiceSVerilog.verimixOpts filename4 string ""
hspiceSVerilog.verimixOpts filename string ""
hspiceSVerilog.verimixOpts filename1 string ""
hspiceSVerilog.verimixOpts scope9 string ""
hspiceSVerilog.verimixOpts importsdfswitch boolean nil
hspiceSVerilog.verimixOpts filename2 string ""
hspiceSVerilog.verimixOpts numberofsdffiles int 2
hspiceSVerilog.verimixOpts scope2 string ""
hspiceSVerilog.verimixOpts scope6 string ""
hspiceSVerilog.verimixOpts filename10 string ""
hspiceSVerilog.verimixOpts delaymodechoice string "Ignore"
hspiceSVerilog.verimixOpts sdfmixedswitch boolean t
hspiceSVerilog.verimixOpts filename9 string ""
hspiceSVerilog.verimixOpts scope5 string ""
hspiceSVerilog.verimixOpts filename5 string ""
hspiceSVerilog.verimixOpts filename3 string ""
hspiceSVerilog.verimixOpts scope4 string ""
;hspiceSVerilog verilogOpts partition variables
hspiceSVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
hspiceSVerilog.verilogOpts optionsFile string ""
hspiceSVerilog.verilogOpts twinTurbo boolean nil
hspiceSVerilog.verilogOpts suppressMessages boolean nil
hspiceSVerilog.verilogOpts libraryFile string ""
hspiceSVerilog.verilogOpts behaveProfile boolean nil
hspiceSVerilog.verilogOpts verimixLog string "verilog.log"
hspiceSVerilog.verilogOpts simVision boolean nil
hspiceSVerilog.verilogOpts pulseSpec boolean nil
hspiceSVerilog.verilogOpts commandFile string ""
hspiceSVerilog.verilogOpts pulseError int 100
hspiceSVerilog.verilogOpts stopCompile boolean nil
hspiceSVerilog.verilogOpts keepNodes string "Minimum"
hspiceSVerilog.verilogOpts accelerationCA boolean nil
hspiceSVerilog.verilogOpts turboRadio string "Default"
hspiceSVerilog.verilogOpts libraryDir string ""
hspiceSVerilog.verilogOpts suppressWarnings boolean nil
hspiceSVerilog.verilogOpts accelerationSwitches boolean nil
hspiceSVerilog.verilogOpts accelerationNormal boolean t
hspiceSVerilog.verilogOpts delayType string "Typical"
hspiceSVerilog.verilogOpts pulseReject int 100
hspiceSVerilog.verilogOpts delayMode string "Default"
hspiceSVerilog.verilogOpts vermixBinary string "verilog.vmx"
;hspiceSVerilog init partition variables
hspiceSVerilog.init processPriority int 0
;hspiceSVerilog envOpts partition variables
hspiceSVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
hspiceSVerilog.envOpts mspNetlistMode string "Flat"
hspiceSVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
hspiceSVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
hspiceSVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
hspiceSVerilog.envOpts mspSetupNetlistEscapeName boolean nil
hspiceSVerilog.envOpts updateFile string ""
hspiceSVerilog.envOpts stimulusFile string ""
hspiceSVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
hspiceSVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
hspiceSVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
hspiceSVerilog.envOpts reNetlist boolean nil
hspiceSVerilog.envOpts includeSyntax string "cdsSpice"
hspiceSVerilog.envOpts mspSetupNetlistPinMap boolean nil
hspiceSVerilog.envOpts mspSetupNetlistBus boolean t
hspiceSVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
hspiceSVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
hspiceSVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
hspiceSVerilog.envOpts mspSetupNetlistExplicit boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
hspiceSVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
hspiceSVerilog.envOpts initFile string ""
hspiceSVerilog.envOpts printComments boolean nil
hspiceSVerilog.envOpts includeFile string ""
hspiceSVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
hspiceSVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
hspiceSVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimTimeValue int 1
hspiceSVerilog.envOpts mspSetupNetlistUseLib boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
hspiceSVerilog.envOpts mspSetupNetlistNullPort boolean nil
hspiceSVerilog.envOpts mspSetupNetlistDropPortRange boolean t
hspiceSVerilog.envOpts mspSetupNetlistUpCase boolean nil
hspiceSVerilog.envOpts generateMapFile boolean nil
hspiceSVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;hspiceSVerilog dc partition variables
hspiceSVerilog.dc enable toggle (nil)
hspiceSVerilog.dc from string ""
hspiceSVerilog.dc to string ""
hspiceSVerilog.dc by string ""
hspiceSVerilog.dc device string ""
;hspiceSVerilog dcOpts partition variables
;hspiceSVerilog noise partition variables
hspiceSVerilog.noise enable toggle (nil)
hspiceSVerilog.noise source string ""
hspiceSVerilog.noise output string ""
hspiceSVerilog.noise listEvery string "1"
;hspiceSVerilog noiseOpts partition variables
;hspiceSVerilog ac partition variables
hspiceSVerilog.ac enable toggle (nil)
hspiceSVerilog.ac from string ""
hspiceSVerilog.ac to string ""
hspiceSVerilog.ac incrType string "Logarithmic"
hspiceSVerilog.ac lin string ""
hspiceSVerilog.ac log string ""
;hspiceSVerilog acOpts partition variables
;hspiceSVerilog tran partition variables
hspiceSVerilog.tran enable toggle (nil)
hspiceSVerilog.tran from string ""
hspiceSVerilog.tran to string ""
hspiceSVerilog.tran by string ""
hspiceSVerilog.tran delmax string ""
;hspiceSVerilog tranOpts partition variables
; Copyright (C) 1997
; Cadence Design Systems Inc. All Rights Reserved.
; $Author: cvsadm $
; $Revision: 1.3.4.1 $
; $Date: 2004/06/16 16:42:51 $
; $State: Exp $
iccTranslator enableProbing boolean t
iccTranslator enableComponentUpdate boolean t
iccTranslator enableAutoImport boolean t
iccTranslator exportCommand string "cdba2icc"
iccTranslator importCommand string "icc2cdba"
iccTranslator iccCommand string "ic_craft"
iccTranslator iccDirectory string ""
iccTranslator exportDirectory string ""
iccTranslator rulesDirectory string ""
iccTranslator logOpPointLimit int 0
iccTranslator oversizePins boolean t
iccTranslator singleImageClusters boolean nil
iccTranslator exportVersion int 11
iccTranslator iccMajorSubVersion int 1
iccTranslator iccMinorSubVersion int 33
iccTranslator permutablePins boolean t
iccTranslator caseSensitive boolean t
iccTranslator schematicStrict boolean nil
iccTranslator keepViaImageOrigin boolean nil
iccTranslator exportTo string "VCR"
iccTranslator pinByPinModelEvaluate boolean nil
iccTranslator alwaysPinModelEvaluate boolean nil
iccTranslator autoTrimPins boolean t
iccTranslator makeVariantViasSpare boolean nil
iccTranslator hierIncrementUpdate boolean nil
iccTranslator MPPAsPolygons boolean nil
iccTranslator noIoPorts boolean nil
iccTranslator findKeepoutWidth boolean nil
iccTranslator.ExportEditor layoutLibrary string ""
iccTranslator.ExportEditor layoutCell string ""
iccTranslator.ExportEditor layoutView string ""
iccTranslator.ExportEditor layoutArea string ""
iccTranslator.ExportEditor netlistSource string "layoutCellview"
iccTranslator.ExportEditor netlistLibrary string ""
iccTranslator.ExportEditor netlistCell string ""
iccTranslator.ExportEditor netlistView string ""
iccTranslator.ExportEditor netlistFile string ""
iccTranslator.ExportEditor useAlternateViews boolean nil
iccTranslator.ExportEditor alternateViews string ""
iccTranslator.ExportEditor conductorDepth int 32
iccTranslator.ExportEditor keepoutDepth int 32
iccTranslator.ExportEditor pinConnection string "strong"
iccTranslator.ExportEditor useMarker boolean nil
iccTranslator.ExportEditor exportMode string "foreground"
iccTranslator.ExportEditor fullConnectivity boolean t
iccTranslator.ExportEditor cutToEdge boolean nil
iccTranslator.ExportEditor interLayer boolean t
iccTranslator.ExportEditor incrementalUpdate boolean t
iccTranslator.ExportEditor useRulesFile boolean nil
iccTranslator.ExportEditor rulesFile string ""
iccTranslator.ExportEditor routerOption string "vcr"
iccTranslator.ExportEditor startICC boolean t
iccTranslator.ExportEditor iccOptions string ""
iccTranslator.ImportEditor importFile string ""
iccTranslator.ImportEditor importFileType string "session"
iccTranslator.ImportEditor importLibrary string ""
iccTranslator.ImportEditor importCell string ""
iccTranslator.ImportEditor importView string ""
iccTranslator.ImportEditor boundary boolean t
iccTranslator.ImportEditor placement boolean t
iccTranslator.ImportEditor routes boolean t
iccTranslator.ImportEditor importMode string "foreground"
iccTranslator.ImportEditor segmentedPath boolean nil
iccTranslator.ImportEditor usePinPurpose boolean nil
ihdl ihdlLoadFileName string "~/.ihdlEnvFile";Load file name
ihdl pin_master_basic_lib boolean t
ihdl pin_master_cells string "ipin opin iopin"
;1************************************************************************
;2* Layout Environment Variables
;3* There are three categories in this file. Public env, wire editor env
;4* and private env. Privat envs should never be touched by customers.
;5************************************************************************
;* The following layout editor environment variables are for customer
;* use. Refer to the documentation for complete information.
layout abutServerOn boolean t
layout accessEdgesOn boolean nil
layout acuteAnglePath boolean t
layout alignApplySeparation boolean t
layout alignApplySpacings string "Component Space"
layout alignDirection string "vertical"
layout alignLayer string ""
layout alignMethod string "Component Origin"
layout alignSelectionMode string "preselect"
layout alignSeparation float 1.0
layout applyBounce boolean nil
layout arrayDisplay string "Full"
layout autoContact boolean nil
layout autoExtractEnabled boolean t
layout autoInstPin boolean nil
layout autoNetName boolean t
layout autoPermutePins boolean t
layout autoRefresh boolean nil
layout autoSetRefPoint boolean t
layout chopShape cyclic "rectangle"
layout confirmDelete boolean nil
layout contactColumns int 1
layout contactDefFromTechfile boolean t
layout contactDelX float 0.0
layout contactDelY float 0.0
layout contactJustify cyclic "centerCenter"
layout contactLength float 0.8
layout contactName string ""
layout contactResetDelXY boolean t
layout contactResetXYBias boolean t
layout contactResetRowCol boolean t
layout contactRows int 1
layout contactWidth float 0.8
layout copyColumns int 1
layout copyResetRowCol boolean nil
layout copyRows int 1
layout copyToLayer boolean nil
layout createPinLabel boolean nil
layout cursorShape boolean nil
layout deleteTarget cyclic "selected"
layout descendPromptForView boolean nil
layout devClass string ""
layout devType string ""
layout displayPinNames boolean nil
layout displayRefPoint boolean nil
layout displayStartLevel int 0
layout displayStopLevel int 0
layout displayStretchHandles boolean nil
layout dotsOn boolean nil
layout drawAxesOn boolean t
layout drawDottedGridOn boolean t
layout drawGridOn boolean t
layout drawInstancePins boolean nil
layout drawSurroundingOn boolean t
layout drdEditMode cyclic "off"
layout drdEditHierDepth int 0
layout drdEditDisplayMarkers boolean nil
layout drdEditDisplayHalo boolean nil
layout drdEditDisplayText boolean t
layout drdEditDisplayArrows boolean t
layout drdEditDisplayEdges boolean nil
layout dynamicHilightOn boolean t
layout extractCheckAll boolean nil
layout extractEnabled boolean t
layout extractStopLevel int 0
layout filterSize float 6.0
layout filterSizeDrawingStyle string "empty"
layout fixedWidthPaths boolean nil
layout flattenMode cyclic "one level"
layout flattenPCells boolean nil
layout gravityAperture float 0.3
layout gravityBounceX float 0.0
layout gravityBounceY float 0.0
layout gravityDepth int 0
layout gravityOn boolean nil
layout gravityType string "pin edge midpoint nexus vertex end centerline"
layout gridMultiple int 5
layout gridSpacing float 1.0
layout iconsOn boolean nil
layout ignoreBounce boolean nil
layout instCellName string ""
layout instColumns int 1
layout instDelX float 0.0
layout instDelY float 0.0
layout instLabel string "master"
layout instLibName string ""
layout instName string ""
layout instRows int 1
layout instViewName string "layout"
layout keepFirstTermName boolean nil
layout keepRuler boolean t
layout labelAttach boolean nil
layout labelDrafting boolean t
layout labelFontStyle cyclic "stick"
layout labelHeight float 1.0
layout labelJustify cyclic "centerCenter"
layout labelOverbar boolean nil
layout layerTapCycle boolean nil
layout leDispNetExpr boolean t
layout leWindowBBox string "((120 185) (1020 875))"
layout lockAngles boolean t
layout magnification float 1.0
layout maintainConnections boolean nil
layout markerZoomScale int 1
layout maxDragFig int 500
layout modCornerRadius float 1.0
layout modCornerType cyclic "radial"
layout modalCommands boolean t
layout moveToLayer boolean nil
layout mppASCIIFileName string ""
layout mppTemplate string "New"
layout multiSegRuler boolean nil
layout nPtsToTaper int 20
layout allowLockedRoutes boolean nil
layout netsOn boolean nil
layout numLevels int 32
layout numSides int 20
layout openToStopLevel boolean t
layout orientation cyclic "R0"
layout resetOrientation boolean t
layout originMarkersOn boolean nil
layout partialSelect boolean nil
layout pathBeginExt float 0.0
layout pathCL cyclic "yes"
layout pathEndExt float 0.0
layout pathJustify cyclic "center"
layout pathOffset float 0.0
layout pathStyle cyclic "truncateExtend"
layout pathWidth float 0.6
layout pinAccessDir string "left right top bottom"
layout pinLength float 0.6
layout pinSelectionMode cyclic "ignoreLPP"
layout pinShape cyclic "rectangle"
layout pinTextLayer string "text"
layout pinTextPurpose string "drawing"
layout pinTextSameLayer boolean nil
layout pinType string ""
layout pinWidth float 0.6
layout pinXPitch float 0.0
layout pinYPitch float 0.0
layout pinsAreSymbolic boolean t
layout pinLayerPurpose string ""
layout polygonArc boolean nil
layout preservePins boolean nil
layout preserveRodObjects boolean nil
layout preserveTerminalContacts boolean nil
layout propClass cyclic "attributes"
layout recursionCheck boolean t
layout removeChopShape boolean t
layout replaceFigs boolean t
layout reshapeType cyclic "rectangle"
layout rodAutoName string ""
layout segSnapMode string "orthogonal"
layout selectOnlyInstWithSelectableShapes boolean nil
layout selectionAperture int 5
layout showLPPFullName boolean nil
layout showWhatsNew string "yes"
layout snapMode string "orthogonal"
layout snapToGrid boolean nil
layout startLevel int 0
layout stopLevel int 0
layout stretchPCellApplyToName boolean t
layout taperStyle cyclic "linear"
layout termDirection cyclic "inputOutput"
layout termName string ""
layout textJustificationOn boolean t
layout tinyInstDetail boolean nil
layout trlBendFac float 1.0
layout trlBendStyle cyclic "bend"
layout trlChamFac float 0.6
layout trlNPtsToPI int 20
layout trlRadFac float 3.0
layout trlWidth1 float 20.0
layout trlWidth2 float 20.0
layout updatePCellIncrement float -1.0
layout useDefaultVia boolean t
layout useEditorBackgroundColorForLSW boolean t
layout useTrueBBox boolean nil
layout userVia string ""
layout xSnapSpacing float 0.1
layout ySnapSpacing float 0.1
layout yankShape cyclic "rectangle"
layout zoomToFig boolean nil
layout cdsViaXcutSpacing float 0.0
layout cdsViaYcutSpacing float 0.0
layout cdsViaLayer1XEnclosure float 0.0
layout cdsViaLayer1YEnclosure float 0.0
layout cdsViaLayer2XEnclosure float 0.0
layout cdsViaLayer2YEnclosure float 0.0
layout cdsViaLayer1XDirEnclosure float 0.0
layout cdsViaLayer1YDirEnclosure float 0.0
layout cdsViaLayer2XDirEnclosure float 0.0
layout cdsViaLayer2YDirEnclosure float 0.0
layout cdsViaLayer1Direction string ""
layout cdsViaLayer2Direction string ""
layout cdsViaStackedVias boolean nil
layout cdsViaResetXYCutSpacing boolean t
layout cdsViaResetLayer1XYEnclosure boolean t
layout cdsViaResetLayer2XYEnclosure boolean t
layout cdsViaResetLayer1XYDirEnclosure boolean t
layout cdsViaResetLayer2XYDirEnclosure boolean t
layout cdsViaResetLayerDirection boolean t
layout cdsViaResetOrigin boolean t
layout displayViaShapes boolean nil
layout tapType string "layer"
layout remasterInstCheckTerms boolean nil
layout remasterInstSearchLibText string ""
layout remasterInstSearchCellText string ""
layout remasterInstSearchViewText string ""
layout remasterInstUpdateLibText string ""
layout remasterInstUpdateCellText string ""
layout remasterInstUpdateViewText string ""
layout chainMode cyclic "selected"
layout anchor cyclic "left"
layout shortEnhContactForm boolean nil
layout markNetRange cyclic "Top to bottom"
layout markNetStartLevel int 0
layout markNetStopLevel int 0
layout markNetAutoColorCycle boolean t
layout markNetDumpNetObj boolean nil
layout measurementDisplayOn boolean nil
layout measurementTextHeight int 10
layout measurementDisplayTypes string "deltaXY distance radius area length"
;* The following layout editor environment variables are for customer use
;* with the wire editor functionality in Virtuoso XL Layout Editor only.
;* Refer to the documentation for complete information.
layout allowFloatingNets boolean nil
layout allowJogs boolean t
layout allowRedundantWiring boolean t
layout autoAdjustLength boolean nil
layout autoShield boolean nil
layout busOverride cyclic "ignore"
layout busOverrideValue float 1.0
layout busWireSpacing float 0.0
layout busWireSpacingType cyclic "wirewire"
layout checkConflict boolean t
layout checkCornerCorner boolean nil
layout checkCrossTalk boolean t
layout checkLength boolean t
layout checkLimitWay boolean nil
layout checkMaxProcessWireWidth boolean nil
layout checkMaxStackViaDepth boolean nil
layout checkMaxTotalVia boolean nil
layout checkMinMaskEdgeLength boolean nil
layout checkMinProcessWireWidth boolean t
layout checkMiter boolean nil
layout checkNetOrder boolean nil
layout checkOffManGridPin boolean nil
layout checkOffWireGridPin boolean nil
layout checkPinSpacing boolean t
layout checkPolygonWire boolean t
layout checkProtected boolean nil
layout checkReentrantPath boolean t
layout checkRegion boolean t
layout checkSameNet boolean nil
layout checkSegment boolean nil
layout checkStub boolean nil
layout checkUseLayers boolean nil
layout checkUseVias boolean nil
layout checkWireExtension boolean nil
layout doFile string ""
layout enableBusRouting boolean t
layout enableTandemPair boolean nil
layout fitViaPattern boolean nil
layout gatherBusWires boolean nil
layout inaccessiblePin boolean t
layout interactiveChecking boolean t
layout matchPinWidth boolean nil
layout matchPinWidthValue cyclic "narrow"
layout matchWireWidth boolean nil
layout multiplePinsConnection boolean t
layout pinLargerMaxProcessWidth boolean nil
layout pinSmallerMinProcessWidth boolean t
layout pushComponent boolean nil
layout pushRouting boolean t
layout routeAsManyAsPossible boolean nil
layout routeToCursor boolean nil
layout routeToCursorStyle cyclic "singleLayer"
layout sameNetChecking boolean nil
layout showTimingMeter boolean nil
layout showTimingOctagon boolean nil
layout snapToPinOrigin boolean nil
layout useDoFile boolean nil
layout viaAssistance cyclic "snap"
layout viaPattern cyclic "diag_1"
layout allowViaOnCurrentLayer boolean t
;* The following layout editor environment variables are for internal Cadence
;* use only. Changing the values of these variables my cause the layout editor
;* or other Cadence software to behave improperly or quit.
layout abutPerpSnapOn boolean t
layout coalesceLimit int 16
layout coalesceRatio int 50
layout connStatus cyclic "needToConnect"
layout contactInstLibName string ""
layout criticality int 10
layout eipRedraw boolean nil
layout figOrder cyclic "current"
layout iterNum int 0
layout jumpersOn boolean nil
layout minLabelSize float 1.0
layout minRefreshArea int 10
layout minStippleSize float 1.0
layout moreDialogs boolean t
layout netName string ""
layout outlineOnly boolean t
layout pickNCreate boolean nil
layout pinInstLibName string ""
layout probeTextOn boolean t
layout pruneSize float 1.0
layout routeMenuOn boolean t
layout toggle boolean nil
layout transformMarkersOn boolean t
layout viewNameList string ""
;3* There are three categories in this file. Public env, LO env
;4* and private env. Private envs should never be touched by customers.
layoutMigrate priorityUserDefined int 10
layoutMigrate priorityUser int 9
layoutMigrate priorityAreaHole int 8
layoutMigrate priorityScale int 7
layoutMigrate prioritySpace int 6
layoutMigrate priorityEnclose int 5
layoutMigrate priorityExtend int 4
layoutMigrate priorityWidth int 3
layoutMigrate priorityNoJog int 2
layoutMigrate priorityAlign int 1
layoutMigrate addToSelection boolean t
layoutMigrate visibleLayer boolean t
layoutMigrate selectableLayer boolean nil
layoutMigrate exclusiveLayer boolean nil
layoutMigrate exclusiveArea boolean nil
layoutMigrate migrateLibraries boolean nil
layoutMigrate mapPcellParams boolean nil
layoutMigrate useSchematicLinks boolean nil
layoutMigrate debugMode boolean t
layoutMigrate doPreProcess boolean t
layoutMigrate preprocessScript string "preprocess.qts"
layoutMigrate doAstractSource boolean nil
layoutMigrate abstractSourceScript string "abstractsource.qts"
layoutMigrate doAbstractTarget boolean nil
layoutMigrate abstractTargetScript string "abstracttarget.qts"
layoutMigrate doPremigrate boolean nil
layoutMigrate premigrateScript string "premigrate.qts"
layoutMigrate doNetlistBinding boolean nil
layoutMigrate netlistFile string "netlist.cdl"
layoutMigrate useConstraintScript boolean nil
layoutMigrate constraintScript string "constraints.qts"
layoutMigrate doPostprocess boolean t
layoutMigrate postprocessScript string "postprocess.qts"
layoutMigrate lastScript string ""
layoutMigrate optimizeX boolean t
layoutMigrate optimizeY boolean t
layoutMigrate allowZeroEdges boolean t
layoutMigrate allow45Edges boolean t
layoutMigrate scaleDevicesWires boolean t
layoutMigrate sumDeviceLegs boolean t
layoutMigrate lockPcells boolean nil
layoutMigrate useQuickSolver boolean nil
layoutMigrate centerLabels boolean nil
layoutMigrate minimizeMemory boolean nil
layoutMigrate keepResultsOnDisk boolean t
layoutMigrate expandSingletons boolean nil
layoutMigrate optimizeEnclose boolean nil
layoutMigrate genConstraintStats boolean nil
layoutMigrate optimizeEffort int 1
layoutMigrate autoRelaxDevices boolean nil
layoutMigrate autorelaxMaxConstraints boolean nil
layoutMigrate autorelaxConstraintsByType boolean nil
layoutMigrate autoRelaxTolerance float 50.0
layoutMigrate autoJogEdges boolean nil
layoutMigrate autoJogWires boolean nil
layoutMigrate autoJogLimit int 1000
layoutMigrate autoJogThreshold float 100.0
layoutMigrate revisitOneByOne2D boolean nil
layoutMigrate revisit2DCost float 100.0
layoutMigrate revisitFlash2D boolean t
layoutMigrate manufGrid2D boolean t
layoutMigrate changeEndOfLine boolean t
layoutMigrate changeCommonRun boolean t
layoutMigrate changeCornerCorner boolean t
layoutMigrate manufGridEnable boolean t
layoutMigrate manufGridPercent float 0.1
layoutMigrate manufGridIteration int 500
layoutMigrate manufGridCPUTime int 10000
layoutMigrate manufGridNoQuickSolver boolean t
layoutMigrate ioGridEnable boolean t
layoutMigrate ioGridPercent float 1.0
layoutMigrate ioGridIteration int 500
layoutMigrate ioGridCPUTime int 10000
layoutMigrate collapseVirtuals boolean t
layoutMigrate ignoreLengthsNetlistBinding boolean nil
layoutMigrate ignoreLengthsLayoutExtraction boolean nil
layoutMigrate propagateTieoffs boolean t
layoutMigrate remoteHost string ""
layoutMigrate remoteWorkingDir string ""
layoutMigrate useRemoteHost boolean nil
layoutMigrate remoteVirtuosoDir string ""
layoutMigrate RemoteQtkDir string ""
layoutMigrate remoteExecPath string ""
layoutMigrate processPriority int 15
layoutMigrate justFixMode boolean nil
layoutOptimize priorityUserDefined int 10
layoutOptimize priorityUser int 9
layoutOptimize priorityAreaHole int 8
layoutOptimize priorityScale int 7
layoutOptimize prioritySpace int 6
layoutOptimize priorityEnclose int 5
layoutOptimize priorityExtend int 4
layoutOptimize priorityWidth int 3
layoutOptimize priorityNoJog int 2
layoutOptimize priorityAlign int 1
layoutOptimize addToSelection boolean t
layoutOptimize visibleLayer boolean t
layoutOptimize selectableLayer boolean nil
layoutOptimize exclusiveLayer boolean nil
layoutOptimize exclusiveArea boolean nil
layoutOptimize migrateLibraries boolean nil
layoutOptimize mapPcellParams boolean nil
layoutOptimize useSchematicLinks boolean nil
layoutOptimize debugMode boolean t
layoutOptimize doPreProcess boolean nil
layoutOptimize preprocessScript string "preprocess.qts"
layoutOptimize doAstractSource boolean nil
layoutOptimize abstractSourceScript string "abstractsource.qts"
layoutOptimize doAbstractTarget boolean nil
layoutOptimize abstractTargetScript string "abstracttarget.qts"
layoutOptimize doPremigrate boolean nil
layoutOptimize premigrateScript string "premigrate.qts"
layoutOptimize doNetlistBinding boolean nil
layoutOptimize netlistFile string "netlist.cdl"
layoutOptimize useConstraintScript boolean nil
layoutOptimize constraintScript string "constraints.qts"
layoutOptimize doPostprocess boolean nil
layoutOptimize postprocessScript string "postprocess.qts"
layoutOptimize lastScript string ""
layoutOptimize optimizeX boolean t
layoutOptimize optimizeY boolean t
layoutOptimize allowZeroEdges boolean t
layoutOptimize allow45Edges boolean t
layoutOptimize scaleDevicesWires boolean nil
layoutOptimize sumDeviceLegs boolean nil
layoutOptimize lockPcells boolean nil
layoutOptimize useQuickSolver boolean nil
layoutOptimize centerLabels boolean nil
layoutOptimize minimizeMemory boolean nil
layoutOptimize keepResultsOnDisk boolean nil
layoutOptimize expandSingletons boolean nil
layoutOptimize optimizeEnclose boolean nil
layoutOptimize genConstraintStats boolean nil
layoutOptimize optimizeEffort int 1
layoutOptimize autoRelaxDevices boolean nil
layoutOptimize autorelaxMaxConstraints boolean nil
layoutOptimize autorelaxConstraintsByType boolean nil
layoutOptimize autoRelaxTolerance float 50.0
layoutOptimize autoJogEdges boolean nil
layoutOptimize autoJogWires boolean nil
layoutOptimize autoJogLimit int 1000
layoutOptimize autoJogThreshold float 100.0
layoutOptimize revisitOneByOne2D boolean nil
layoutOptimize revisit2DCost float 100.0
layoutOptimize revisitFlash2D boolean t
layoutOptimize manufGrid2D boolean nil
layoutOptimize changeEndOfLine boolean t
layoutOptimize changeCommonRun boolean t
layoutOptimize changeCornerCorner boolean t
layoutOptimize manufGridEnable boolean t
layoutOptimize manufGridPercent float 0.1
layoutOptimize manufGridIteration int 500
layoutOptimize manufGridCPUTime int 500
layoutOptimize manufGridNoQuickSolver boolean t
layoutOptimize ioGridEnable boolean t
layoutOptimize ioGridPercent float 1.0
layoutOptimize ioGridIteration int 500
layoutOptimize ioGridCPUTime int 1000
layoutOptimize collapseVirtuals boolean t
layoutOptimize ignoreLengthsNetlistBinding boolean nil
layoutOptimize ignoreLengthsLayoutExtraction boolean nil
layoutOptimize propagateTieoffs boolean t
layoutOptimize remoteHost string ""
layoutOptimize remoteWorkingDir string ""
layoutOptimize useRemoteHost boolean nil
layoutOptimize remoteVirtuosoDir string ""
layoutOptimize RemoteQtkDir string ""
layoutOptimize remoteExecPath string ""
layoutOptimize processPriority int 15
layoutOptimize justFixMode boolean nil
layoutOptimize.state menuState string "Migrate"
;2* Layout XL Environment Variables
;3* Note: entries in this file must be in alphabetical order.
;4************************************************************
layoutXL autoAbutment boolean t
layoutXL autoArrange boolean t
layoutXL autoSpace boolean t
layoutXL checkTimeStamps boolean t
layoutXL ciwWindow string "((0 0) (0 0))"
layoutXL constraintAssistedMode boolean nil
layoutXL createBoundaryLabel boolean nil
layoutXL crossSelect boolean t
layoutXL ignoredParams string "lxIgnoredParams dleIgnoredParams lxStopList dleStopList lxUseCell dleUseCell maskLayoutViewName posi instancesLastChanged instNamePrefix pin# lxTimeStamp dleSchExtractPath lxPlacementStatus"
layoutXL ignoreParamsForCAS string ""
layoutXL dlrNetConstNetClass string "neutral"
layoutXL dlrNetConstNetWeight string "normal"
layoutXL dlrRoutingBoundaryOption string "auto boundary"
layoutXL flightLineEnable boolean t
layoutXL ignoreNames string "lvsIgnore ignore nlAction"
layoutXL incNetCycleHilite boolean t
layoutXL incNetHiliteLayer string "y0 drawing"
layoutXL initAspectRatio float 1.0
layoutXL initAspectRatioOption string "Aspect Ratio W/H"
layoutXL initBoundaryLayer string "prBoundary drawing"
layoutXL initEstimateArea boolean t
layoutXL initIOLabelType string "Label"
layoutXL initIOPinLayer string ""
layoutXL initIOPinName string ""
layoutXL initPinHeight float 0.0
layoutXL initPinWidth float 0.0
layoutXL initPinMultiplicity int 1
layoutXL initPrBoundaryH float 0.0
layoutXL initPrBoundaryW float 0.0
layoutXL initSymbolicPins boolean nil
layoutXL initUtilization float 25.0
layoutXL initGlobalNetPins boolean t
layoutXL initCreatePins boolean t
layoutXL initCreateInstances boolean t
layoutXL initCreateBoundary boolean t
layoutXL initDoStacking boolean nil
layoutXL initDoFolding boolean nil
layoutXL layoutWindow string "((0 0) (0 0))"
layoutXL lswWindow string "((0 0) (0 0))"
layoutXL lxAllowPseudoParallelNets boolean nil
layoutXL lxDeltaWidth float 0.0
layoutXL lxDoNotCheck boolean nil
layoutXL lxLocalAbutment boolean nil
layoutXL lxSchExtractTopLevelOnly boolean nil
layoutXL lxStackPartitionParameters string "(1 8)"
layoutXL lxWidthTolerance string "(0.0 0.0)"
layoutXL mfactorNames string "m M"
layoutXL mfactorSplit boolean t
layoutXL moveAsGroup boolean t
layoutXL orientation string "R0"
layoutXL paramTolerance float 1e-06
layoutXL pathLayerFilter string ""
layoutXL pathProbe boolean t
layoutXL pathPurposeList string "drawing net pin"
layoutXL pathSwitchLayer boolean t
layoutXL pathSwitchPurpose boolean t
layoutXL pinTextSamePurpose boolean nil
layoutXL preserveTerminalContacts boolean nil
layoutXL probeCycleHilite boolean t
layoutXL probeDevice boolean t
layoutXL probeHiliteLayer string "hilite drawing"
layoutXL probeNet boolean t
layoutXL probePin boolean t
layoutXL probeInfoInCIW boolean nil
layoutXL infoWindow boolean t
layoutXL schematicWindow string "((0 0) (0 0))"
layoutXL showIncNetEnable boolean nil
layoutXL stopList string "layout compacted symbolic"
layoutXL templateFileName string ""
layoutXL updateReplacesMasters boolean t
layoutXL updateWithMarkers boolean t
layoutXL viewList string "schematic netlist symbol layout compacted symbolic"
layoutXL vxlDebugLog boolean nil
layoutXL vxlDebugLogFileName string "/tmp/vxl.log"
layoutXL initCreateMTM boolean nil
layoutXL sfactorNames string "s S"
layoutXL sfactorParam string "r R c C l L"
layoutXL mfactorSplitParamNames string "w"
layoutXL setPPConn boolean t
layoutXL lxSupplyNetNames string "vcc vcc! vcc: vdd vdd! vdd:"
layoutXL lxGroundNetNames string "gnd gnd! gnd: vss vss! vss:"
layoutXL lxGenerationOrientation string "preserve"
layoutXL lxGenerationTopLevelOnly boolean nil
layoutXL lxInitResetSource boolean nil
layoutXL compTypeRefLibs string "NONE"
layoutXL traverseMixedHierarchies boolean nil
layoutXL lxEvalCDFCallbacks boolean nil
layoutXL cloningDoExactMatch boolean nil
layoutXL.placement allowRotation boolean t
layoutXL.placement globalPlacement boolean t
layoutXL.placement openWindow boolean nil
layoutXL.placement optimizePlacement boolean nil
layoutXL.placement rulesFile string ""
layoutXL.placement runTime cyclic "moderate"
layoutXL.placement saveAs boolean nil
layoutXL.placement saveAsCellName string ""
layoutXL.placement saveAsLibName string ""
layoutXL.placement saveAsViewName string ""
layoutXL.placement vcpConductorDepth int 2
layoutXL.placement vcpKeepoutDepth int 2
layoutXL lxStackMinimalFolding boolean nil
layoutXL lxFingeringNames string "fingers finger"
layoutXL.placement rowGroundLayer string ""
layoutXL.placement rowGroundName string ""
layoutXL.placement rowGroundWidth float 1.0
layoutXL.placement rowPowerLayer string ""
layoutXL.placement rowPowerName string ""
layoutXL.placement rowPowerWidth float 1.0
layoutXL.placement rowSupplySpacing string ""
layoutXL.placement rowSupplyPosition cyclic "Outside"
layoutXL.placement rowSTDAllowFlip boolean t
layoutXL.placement rowMOSSupplyPattern cyclic "N-P-P-N"
layoutXL.placement rowSTDSupplyPattern cyclic "G-P-P-G"
layoutXL.placement congestionMapLayers string "((designFlow drawing) (designFlow drawing1) (designFlow drawing2) (designFlow drawing3) (designFlow drawing4) (designFlow drawing5) (designFlow drawing6) (designFlow drawing7) (designFlow drawing8) (designFlow drawing9))"
layoutXL.placement vcpGlobalPathScript string ""
layoutXL.placement vcpVerboseLevel int 1
layoutXL.placement vcpWriteToCIW boolean nil
;mmsimenv environment variables
;FORMAT: tool.partition varName type value private {choices, minmax} comment
;mmsimenv configuration defaults
mmsimenv.conf analogStopViewSet string "spectreS cdsSpice spice veriloga ahdl auLvs spectre"
mmsimenv.conf digitalStopViewSet string "verilog behavioral functional hdl system verilogNetlist msps"
modelwriter path string ""
modelwriter nodefault boolean nil
; Copyright (C) 2001 Cadence Design Systems, Inc. All Rights Reserved.
; $Revision: 1.1.8.1.2.1 $
;Mixed Signal Parasitic Simulation (MSPS) Environment Defaults
;Globals
msps schematicLibName string ""
msps schematicCellName string ""
msps schematicViewName string "schematic"
msps extractedLibName string ""
msps extractedCellName string ""
msps extractedViewName string "extracted"
msps switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
msps stopViewList string "cdsSpice spice"
msps instViewListTable string ""
;Parasitic Probing
msps.parProbe maxListSize int 20
msps.parProbe sortBy string "C"
;Back Annotation
msps.backAnnotate fontSize float 0.05
msps.backAnnotate xOffset float 0.01
msps.backAnnotate yOffset float 0.01
msps.backAnnotate sortBy string "C"
msps.backAnnotate parasiticFile string "parasitic_file"
;Build Analog
msps.buildAnalog setParasitics string "Include All"
msps.buildAnalog analogExtractedViewName string "analog_extracted"
; Copyright (C) 2000 Cadence Design Systems, Inc. All Rights Reserved.
; $Revision: 1.2.8.1.2.1 $
;Mixed Signal Parasitic Simulation for Assura Verification (MSPS-AV) Environment Defaults
;Globals
mspsAv schematicLibName string ""
mspsAv schematicCellName string ""
mspsAv schematicViewName string "schematic"
mspsAv extractedLibName string ""
mspsAv extractedCellName string ""
mspsAv extractedViewName string "av_extracted"
mspsAv switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
mspsAv stopViewList string "cdsSpice spice"
mspsAv instViewListTable string ""
mspsAv backAnnotateR boolean t
;Parasitic Probing
mspsAv.parProbe maxListSize int 20
mspsAv.parProbe sortBy string "C"
mspsAv.parProbe parasiticProbeFile string "parasitic_probing"
mspsAv.pwbCore schematicOpenReadOnly boolean t
mspsAv.backAnnotate fontSize float 0.05
mspsAv.backAnnotate Xoffset float 0.01
mspsAv.backAnnotate Yoffset float 0.01
mspsAv.backAnnotate sortBy string "C"
mspsAv.backAnnotate parasiticFile string "parasitic_file"
;Build Analog
mspsAv.buildAnalog setParasitics string "Include All"
mspsAv.buildAnalog analogExtractedViewName string "av_analog_extracted"
; Neocell Environment Variables
neocell ArchFile string ""
neocell MapFile string ""
neocell DefaultFile string ""
neocell UseBlockRules boolean nil
neocell BlockRulesFile string ""
neocell ExportDir string ""
neocell StartNeoCell boolean t
neocell ImportViewName string "layout"
neocell ImportTextDisplay boolean nil
neocell ImportBoundary boolean t
neocell ExportOptions string ""
neocell SymViewList string "symbolic layout"
neocell IgnoreParamTolerance boolean t
neocell VariantParamTolerance int 10
neocell VerboseWarn boolean t
neocell InitDFIIlib string ""
neocell NewDFIIlib string ""
neocell TempDir string ""
neocell TechPath string ""
neocell IgnorePinAccess boolean nil
neocell ImportPinLabelFont string "stick"
neocell ImportPinLabelSize float -1.0
neocell DisableSchExtract boolean nil
neocell TechFile string ""
neocell DisplayFile string ""
neocell pinConnection string "full"
neocell CEDefaultTab string "DevStyle"
neocell overridePinPurpose string ""
; ROD Environment Variables
rod evalILExprOn boolean t
rod minWidthCheckingOn boolean t
rod minSpacingCheckingOn boolean t
rod minEnclosureCheckingOn boolean t
rod preserveAlignInfoOn boolean t
; Composer Schematic Editor Environment Variables
; NOTE: This file should NOT be edited because it is automatically
; generated; customizations should be made to the file in
; <install_dir>/tools/dfII/samples/.cdsenv.
schematic autoDot boolean t
schematic blockDirRules cyclic "edge"
schematic broadcast boolean nil
schematic browserType string "library"
schematic checkAlways boolean nil
schematic checkBeepOn boolean t
schematic checkHierSave boolean t
schematic checkSupportAMS boolean nil
schematic checkSymTime int 1
schematic compBackTrace boolean t
schematic condOp cyclic "=="
schematic createCvOptions boolean t
schematic createInstResetCDF boolean t
schematic createInstShowCDF boolean t
schematic createLabelFontHeight float 0.0625
schematic createLabelFontStyle cyclic "stick"
schematic createLabelHorzOffset float 0.045
schematic createLabelHorzPosition cyclic "above"
schematic createLabelHorzRotation cyclic "R0"
schematic createLabelJustify cyclic "lowerCenter"
schematic createLabelOffsetMode boolean t
schematic createLabelVertOffset float 0.045
schematic createLabelVertPosition cyclic "left"
schematic createLabelVertRotation cyclic "R90"
schematic cvDisplay boolean t
schematic defWideWireWidth float 0.0625
schematic defaultsFile string ""
schematic deleteInstPinsWire boolean t
schematic descendSheet string "sheet"
schematic descendTarget string "query user"
schematic differential boolean nil
schematic dotOverlap float 0.03125
schematic drawMode string "anyAngle"
schematic drawModeRoute string "route"
schematic echoToCIW boolean t
schematic editPropCDFParamView string "Use Tools Filter"
schematic editPropShowCDF boolean t
schematic editPropShowSystem boolean nil
schematic editPropShowUser boolean t
schematic findAccessMode string "edit"
schematic findZoomButton boolean nil
schematic flightWidth float 0.0
schematic gravityOn boolean t
schematic invokeKanjiEditor string "kterm -km euc -e vi"
schematic libList string ""
schematic markerSeverity string "all"
schematic markerShowIgnore boolean t
schematic markerSource toggle (t t t t)
schematic markerType toggle (t t)
schematic markerZoom boolean nil
schematic maxLabelOffsetUU float 0.045
schematic minMarkerSize float 0.05
schematic modalCommands boolean t
schematic netExprDisplay cyclic "value only"
schematic netNameMethod cyclic "prefix"
schematic netNamePrefix string "net"
schematic netNameRangeDescend boolean nil
schematic netNameSeparator string "_"
schematic noteFontHeight float 0.0625
schematic noteFontStyle cyclic "stick"
schematic noteJustify cyclic "lowerCenter"
schematic noteShape cyclic "line"
schematic noteShapeLineStyle cyclic "solid"
schematic noteType cyclic "normalLabel"
schematic pinBackTrace boolean t
schematic pinNameSeed string "pin"
schematic pinRefDuplicates boolean nil
schematic pinRefFormat string "<sheetNumber><zone><referenceName>"
schematic pinRefSorting string "Sheet Number"
schematic replSaveChanges boolean nil
schematic runSRC boolean t
schematic runVIC boolean t
schematic saveAction cyclic "Ask Me"
schematic schCoalesceLimit int 2
schematic schDisplayDepth int 3
schematic schDrawAxesOn boolean nil
schematic schDynamicHilightOn boolean t
schematic schFilterSize float 0.3
schematic schGridMultiple int 8
schematic schGridSpacing float 0.125
schematic schGridType cyclic "dotted"
schematic schHdlCrossViewCheck boolean t
schematic schHdlCrossViewString string ""
schematic schHdlEditAfterError boolean t
schematic schHdlNetToInoutPort toggle (t t t t t t t)
schematic schHdlNetToInputPort toggle (t t t t t t t)
schematic schHdlNoHierarchy boolean nil
schematic schHdlPrintCommand string "lpr"
schematic schHdlVerbose boolean nil
schematic schMaxDragFig int 100
schematic schPathType cyclic "full"
schematic schShowDirectConnects boolean nil
schematic schShowLabelOrigin boolean nil
schematic schSnapSpacing float 0.0625
schematic schWindowBBox string "((120 185) (1020 875))"
schematic schematicAreaPartialSelect boolean nil
schematic schematicSelectFilter string "allSchObj instancePin"
schematic sensitiveMenu boolean t
schematic shapeLineType cyclic "narrow"
schematic shapeLineWidth float 0.0625
schematic simProbeAutoPlace boolean nil
schematic simProbeFormat string "<state>"
schematic simProbeType string "monitor"
schematic snapEnabled boolean t
schematic spanLib string "do not check"
schematic srcConnByName cyclic "ignored"
schematic srcFloatingBIDIR cyclic "warning"
schematic srcFloatingIO cyclic "warning"
schematic srcFloatingInput cyclic "warning"
schematic srcFloatingNets cyclic "warning"
schematic srcFloatingOutput cyclic "warning"
schematic srcInhPinNetCollision cyclic "ignored"
schematic srcInheritedConn cyclic "ignored"
schematic srcInstNameExpr string ""
schematic srcInstNameSyntax cyclic "ignored"
schematic srcInstOverlap cyclic "warning"
schematic srcInstOverlapValue int 10
schematic srcMaxLabelOffset cyclic "ignored"
schematic srcNameCollision cyclic "warning"
schematic srcNetNameExpr string ""
schematic srcNetNameSyntax cyclic "ignored"
schematic srcNoOverrideNet cyclic "warning"
schematic srcOffsheetConnCheck cyclic "ignored"
schematic srcPinNetCollision cyclic "ignored"
schematic srcShortedOutputs cyclic "warning"
schematic srcSolderOnCrossover cyclic "warning"
schematic srcSparseIndexBus cyclic "ignored"
schematic srcTermNameExpr string ""
schematic srcTermNameSyntax cyclic "ignored"
schematic srcUnconnectedWires cyclic "ignored"
schematic srcVHDLSyntax cyclic "ignored"
schematic srcVerilogSyntax cyclic "ignored"
schematic ssgPackageLabels cyclic "none"
schematic ssgSortPins cyclic "alphanumeric"
schematic statusBanner boolean t
schematic statusBannerXY boolean nil
schematic stickyWireLabelRange float 0.3125
schematic symCoalesceLimit int 2
schematic symDisplayDepth int 3
schematic symDrawAxesOn boolean nil
schematic symDynamicHilightOn boolean t
schematic symFilterSize float 0.3
schematic symGridMultiple int 8
schematic symGridSpacing float 0.125
schematic symGridType cyclic "dotted"
schematic symMaxDragFig int 100
schematic symPathType cyclic "full"
schematic symShowDirectConnects boolean nil
schematic symShowLabelOrigin boolean nil
schematic symSnapSpacing float 0.0625
schematic symWindowBBox string "((120 185) (1020 875))"
schematic symbolAreaPartialSelect boolean nil
schematic symbolLabelChoice cyclic "instance label"
schematic symbolLabelChoiceText string ""
schematic symbolLabelFontHeight float 0.0625
schematic symbolLabelFontStyle cyclic "stick"
schematic symbolLabelJustify cyclic "lowerCenter"
schematic symbolLabelType cyclic "NLPLabel"
schematic symbolPinFlatten boolean t
schematic symbolPinIncrCount int 1
schematic symbolPinLocate cyclic "left"
schematic symbolPinUsage string ""
schematic symbolSelectFilter string "allSymObj"
schematic symbolShape cyclic "line"
schematic symbolShapeFillStyle cyclic "outline"
schematic transToSheetType string "single"
schematic tsgTemplateType string "digital"
schematic updateConn boolean t
schematic updateInstResetCDF boolean t
schematic vicExactPinMatch boolean nil
schematic vicIgnoreInhTermAll boolean t
schematic vicIgnoreInhTermList string ""
schematic vicIgnoreInhTermViewList string ""
schematic vicInheritedPinMatch boolean t
schematic vicInheritedPins boolean t
schematic vicSeverity cyclic "warning"
schematic vicViewList string "symbol schematic functional behavioral system opt_sch opt_net"
schematic viewNameList string "schematic symbol"
schematic wireBackTrace boolean nil
schematic zoomOutButton boolean nil
;spectre environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spectre opts partition variables
spectre.opts multithread string ""
spectre.opts title string ""
spectre.opts audit string ""
spectre.opts nthreads string ""
spectre.opts mos_method string ""
spectre.opts ckptclock string "1800"
spectre.opts flow string ""
spectre.opts cols string "80"
spectre.opts opptcheck string ""
spectre.opts maxwarnstologfile string ""
spectre.opts reltol string "1e-3"
spectre.opts notation string ""
spectre.opts senstype string ""
spectre.opts warn string ""
spectre.opts approx string ""
spectre.opts info string ""
spectre.opts sensformat string ""
spectre.opts quantities string ""
spectre.opts pivabs string ""
spectre.opts compatible string ""
spectre.opts ignshorts string ""
spectre.opts gmin string "1e-12"
spectre.opts rforce string "1"
spectre.opts note string ""
spectre.opts homotopy string ""
spectre.opts debug string ""
spectre.opts iabstol string "1e-12"
spectre.opts maxwarns string "5"
spectre.opts tempeffects string ""
spectre.opts vabstol string "1e-6"
spectre.opts macromodels string ""
spectre.opts temp string "27"
spectre.opts tnom string "27"
spectre.opts maxnotes string "5"
spectre.opts narrate string ""
spectre.opts value string ""
spectre.opts gmin_check string ""
spectre.opts pivrel string "1e-3"
spectre.opts pivotdc string ""
spectre.opts digits string "5"
spectre.opts maxnotestologfile string ""
spectre.opts diagnose string ""
spectre.opts scale string "1.0"
spectre.opts scalem string "1.0"
spectre.opts error string ""
spectre.opts inventory string ""
spectre.opts topcheck string ""
spectre.opts limit string ""
spectre.opts sensfile string "../psf/sens.output"
;spectre outputs partition variables
spectre.outputs currents string ""
spectre.outputs outputParamInfo boolean t
spectre.outputs modelParamInfo boolean t
spectre.outputs subcktprobelvl string ""
spectre.outputs saveahdlvars string ""
spectre.outputs pwr string ""
spectre.outputs nestlvl string ""
spectre.outputs elementInfo boolean t
spectre.outputs useprobes string ""
spectre.outputs save string "allpub"
;spectre envOpts partition variables
spectre.envOpts stopViewList string "spectre"
spectre.envOpts switchViewList string "spectre cmos_sch cmos.sch schematic veriloga ahdl"
spectre.envOpts enableArclength boolean nil
spectre.envOpts autoDisplay boolean t
spectre.envOpts simOutputFormat string "psfbin"
spectre.envOpts spp string ""
spectre.envOpts analysisOrder string ""
spectre.envOpts paramRangeCheckFile string ""
spectre.envOpts printComments boolean nil
spectre.envOpts checkpoint string ""
spectre.envOpts recover string ""
spectre.envOpts firstRun boolean t
spectre.envOpts userCmdLineOption string ""
;spectre init partition variables
spectre.init processPriority int 0
;spectre pz partition variables
spectre.pz enable toggle (nil)
spectre.pz outType string "voltage"
spectre.pz p string ""
spectre.pz n string ""
spectre.pz oprobe string ""
spectre.pz inType string "voltage"
spectre.pz inVsrc string ""
spectre.pz inIsrc string ""
spectre.pz iprobe string ""
spectre.pz sweep string ""
spectre.pz freq string "1"
spectre.pz dev string ""
spectre.pz deviceParam string ""
spectre.pz mod string ""
spectre.pz modelParam string ""
spectre.pz designVar string ""
spectre.pz param string ""
spectre.pz rangeType string "Start-Stop"
spectre.pz start string ""
spectre.pz stop string ""
spectre.pz center string ""
spectre.pz span string ""
spectre.pz incrType string "Automatic"
spectre.pz stepTypeLin string "Step Size"
spectre.pz stepTypeLog string "Points Per Decade"
spectre.pz step string ""
spectre.pz lin string ""
spectre.pz dec string ""
spectre.pz log string ""
spectre.pz useDiscrete boolean nil
spectre.pz values string ""
spectre.pz porti string "1"
;spectre pzOpts partition variables
spectre.pzOpts readns string ""
spectre.pzOpts oppoint string ""
spectre.pzOpts fmax string ""
spectre.pzOpts zeroonly string ""
spectre.pzOpts prevoppoint string ""
spectre.pzOpts restart string ""
spectre.pzOpts annotate string ""
spectre.pzOpts stats string ""
;spectre dcmatch partition variables
spectre.dcmatch enable toggle (nil)
spectre.dcmatch outType string "voltage"
spectre.dcmatch p string ""
spectre.dcmatch n string ""
spectre.dcmatch oprobe string ""
spectre.dcmatch sweep string ""
spectre.dcmatch dev string ""
spectre.dcmatch deviceParam string ""
spectre.dcmatch mod string ""
spectre.dcmatch modelParam string ""
spectre.dcmatch designVar string ""
spectre.dcmatch param string ""
spectre.dcmatch rangeType string "Start-Stop"
spectre.dcmatch start string ""
spectre.dcmatch stop string ""
spectre.dcmatch center string ""
spectre.dcmatch span string ""
spectre.dcmatch incrType string "Automatic"
spectre.dcmatch stepTypeLin string "Step Size"
spectre.dcmatch stepTypeLog string "Points Per Decade"
spectre.dcmatch step string ""
spectre.dcmatch lin string ""
spectre.dcmatch dec string ""
spectre.dcmatch log string ""
spectre.dcmatch useDiscrete boolean nil
spectre.dcmatch values string ""
spectre.dcmatch mth string ""
spectre.dcmatch porti string "1"
spectre.dcmatch portv string ""
;spectre dcmatchOpts partition variables
spectre.dcmatchOpts readns string ""
spectre.dcmatchOpts save string ""
spectre.dcmatchOpts nestlvl string ""
spectre.dcmatchOpts oppoint string ""
spectre.dcmatchOpts prevoppoint string ""
spectre.dcmatchOpts restart string ""
spectre.dcmatchOpts annotate string "status"
spectre.dcmatchOpts stats string ""
spectre.dcmatchOpts where string "rawfile"
;spectre stb partition variables
spectre.stb enable toggle (nil)
spectre.stb sweep string "Frequency"
spectre.stb freq string ""
spectre.stb dev string ""
spectre.stb deviceParam string ""
spectre.stb mod string ""
spectre.stb modelParam string ""
spectre.stb designVar string ""
spectre.stb param string ""
spectre.stb rangeType string "Start-Stop"
spectre.stb start string ""
spectre.stb stop string ""
spectre.stb center string ""
spectre.stb span string ""
spectre.stb incrType string "Automatic"
spectre.stb stepTypeLin string "Step Size"
spectre.stb stepTypeLog string "Points Per Decade"
spectre.stb step string ""
spectre.stb lin string ""
spectre.stb dec string ""
spectre.stb log string ""
spectre.stb useDiscrete boolean nil
spectre.stb values string ""
spectre.stb probe string ""
;spectre stbOpts partition variables
spectre.stbOpts prevoppoint string ""
spectre.stbOpts readns string ""
spectre.stbOpts save string ""
spectre.stbOpts nestlvl string ""
spectre.stbOpts oppoint string ""
spectre.stbOpts restart string ""
spectre.stbOpts annotate string "status"
spectre.stbOpts stats string ""
;spectre tran partition variables
spectre.tran enable toggle (nil)
spectre.tran stop string ""
spectre.tran errpreset string ""
;spectre tranOpts partition variables
spectre.tranOpts start string ""
spectre.tranOpts outputstart string ""
spectre.tranOpts step string ""
spectre.tranOpts maxstep string ""
spectre.tranOpts ic string ""
spectre.tranOpts skipdc string ""
spectre.tranOpts readic string ""
spectre.tranOpts readns string ""
spectre.tranOpts cmin string ""
spectre.tranOpts write string "spectre.ic"
spectre.tranOpts writefinal string "spectre.fc"
spectre.tranOpts ckptperiod string ""
spectre.tranOpts method string ""
spectre.tranOpts relref string ""
spectre.tranOpts lteratio string ""
spectre.tranOpts stats string ""
spectre.tranOpts annotate string "status"
spectre.tranOpts save string ""
spectre.tranOpts nestlvl string ""
spectre.tranOpts oppoint string ""
spectre.tranOpts skipstart string ""
spectre.tranOpts skipstop string ""
spectre.tranOpts skipcount string ""
spectre.tranOpts strobeperiod string ""
spectre.tranOpts strobedelay string ""
spectre.tranOpts compression string ""
spectre.tranOpts infotimes string ""
spectre.tranOpts flushpoints string ""
spectre.tranOpts flushtime string ""
spectre.tranOpts flushofftime string ""
spectre.tranOpts maxiters string "5"
spectre.tranOpts restart string ""
spectre.tranOpts captab boolean nil
spectre.tranOpts timed boolean nil
spectre.tranOpts threshold string "0.0"
spectre.tranOpts detail string "node"
spectre.tranOpts sort string "name"
;spectre envlp partition variables
spectre.envlp enable toggle (nil)
spectre.envlp clockname string ""
spectre.envlp stop string ""
spectre.envlp harmonics string "Number of harmonics"
spectre.envlp harms string ""
spectre.envlp harmsvec string ""
spectre.envlp errpreset string ""
;spectre envlpOpts partition variables
spectre.envlpOpts start string ""
spectre.envlpOpts outputstart string ""
spectre.envlpOpts tstab string ""
spectre.envlpOpts modulationbw string ""
spectre.envlpOpts maxstep string ""
spectre.envlpOpts envmaxstep string ""
spectre.envlpOpts ic string ""
spectre.envlpOpts skipdc string ""
spectre.envlpOpts readic string ""
spectre.envlpOpts readns string ""
spectre.envlpOpts cmin string ""
spectre.envlpOpts write string ""
spectre.envlpOpts writefinal string ""
spectre.envlpOpts swapfile string ""
spectre.envlpOpts method string ""
spectre.envlpOpts relref string ""
spectre.envlpOpts lteratio string ""
spectre.envlpOpts envlteratio string ""
spectre.envlpOpts steadyratio string ""
spectre.envlpOpts stats string ""
spectre.envlpOpts annotate string "status"
spectre.envlpOpts save string ""
spectre.envlpOpts nestlvl string ""
spectre.envlpOpts compression string ""
spectre.envlpOpts outputtype string ""
spectre.envlpOpts strobeperiod string ""
spectre.envlpOpts maxiters string ""
spectre.envlpOpts restart string ""
spectre.envlpOpts envmaxiters string ""
;spectre ac partition variables
spectre.ac enable toggle (nil)
spectre.ac sweep string "Frequency"
spectre.ac freq string ""
spectre.ac dev string ""
spectre.ac deviceParam string ""
spectre.ac mod string ""
spectre.ac modelParam string ""
spectre.ac designVar string ""
spectre.ac param string ""
spectre.ac rangeType string "Start-Stop"
spectre.ac start string ""
spectre.ac stop string ""
spectre.ac center string ""
spectre.ac span string ""
spectre.ac incrType string "Automatic"
spectre.ac stepTypeLin string "Step Size"
spectre.ac stepTypeLog string "Points Per Decade"
spectre.ac step string ""
spectre.ac lin string ""
spectre.ac dec string ""
spectre.ac log string ""
spectre.ac useDiscrete boolean nil
spectre.ac values string ""
;spectre acOpts partition variables
spectre.acOpts readns string ""
spectre.acOpts prevoppoint string ""
spectre.acOpts save string ""
spectre.acOpts nestlvl string ""
spectre.acOpts oppoint string ""
spectre.acOpts restart string ""
spectre.acOpts annotate string "status"
spectre.acOpts stats string ""
;spectre dc partition variables
spectre.dc enable toggle (nil)
spectre.dcop enable toggle (nil)
spectre.dc saveOppoint boolean nil
spectre.dc sweep string ""
spectre.dc dev string ""
spectre.dc deviceParam string ""
spectre.dc mod string ""
spectre.dc modelParam string ""
spectre.dc designVar string ""
spectre.dc param string ""
spectre.dc rangeType string "Start-Stop"
spectre.dc start string ""
spectre.dc stop string ""
spectre.dc center string ""
spectre.dc span string ""
spectre.dc incrType string "Automatic"
spectre.dc stepTypeLin string "Step Size"
spectre.dc stepTypeLog string "Points Per Decade"
spectre.dc step string ""
spectre.dc lin string ""
spectre.dc dec string ""
spectre.dc log string ""
spectre.dc useDiscrete boolean nil
spectre.dc values string ""
;spectre dcOpts partition variables
spectre.dcOpts force string ""
spectre.dcopOpts force string ""
spectre.dcOpts readns string ""
spectre.dcopOpts readns string ""
spectre.dcOpts readforce string ""
spectre.dcopOpts readforce string ""
spectre.dcOpts write string "spectre.dc"
spectre.dcopOpts write string "spectre.dc"
spectre.dcOpts writefinal string ""
spectre.dcopOpts writefinal string ""
spectre.dcOpts save string ""
spectre.dcopOpts save string ""
spectre.dcOpts nestlvl string ""
spectre.dcopOpts nestlvl string ""
spectre.dcOpts print string ""
spectre.dcopOpts print string ""
spectre.dcOpts check string ""
spectre.dcopOpts check string ""
spectre.dcOpts oppoint string "rawfile"
spectre.dcopOpts oppoint string "rawfile"
spectre.dcOpts homotopy string ""
spectre.dcopOpts homotopy string ""
spectre.dcOpts restart string ""
spectre.dcopOpts restart string ""
spectre.dcOpts maxiters string "150"
spectre.dcopOpts maxiters string "150"
spectre.dcOpts maxsteps string "10000"
spectre.dcopOpts maxsteps string "10000"
spectre.dcOpts annotate string "status"
spectre.dcopOpts annotate string "status"
spectre.dcOpts captab boolean nil
spectre.dcopOpts captab boolean nil
spectre.dcOpts threshold string "0.0"
spectre.dcopOpts threshold string "0.0"
spectre.dcOpts detail string "node"
spectre.dcopOpts detail string "node"
spectre.dcOpts sort string "name"
spectre.dcopOpts sort string "name"
;spectre noise partition variables
spectre.noise enable toggle (nil)
spectre.noise sweep string "Frequency"
spectre.noise freq string ""
spectre.noise dev string ""
spectre.noise deviceParam string ""
spectre.noise mod string ""
spectre.noise modelParam string ""
spectre.noise designVar string ""
spectre.noise param string ""
spectre.noise rangeType string "Start-Stop"
spectre.noise start string ""
spectre.noise stop string ""
spectre.noise center string ""
spectre.noise span string ""
spectre.noise incrType string "Automatic"
spectre.noise stepTypeLin string "Step Size"
spectre.noise stepTypeLog string "Points Per Decade"
spectre.noise step string ""
spectre.noise lin string ""
spectre.noise dec string ""
spectre.noise log string ""
spectre.noise useDiscrete boolean nil
spectre.noise values string ""
spectre.noise outType string "probe"
spectre.noise p string ""
spectre.noise n string ""
spectre.noise oprobe string ""
spectre.noise inType string "port"
spectre.noise inVsrc string ""
spectre.noise inIsrc string ""
spectre.noise iprobe string ""
spectre.noise inPort string ""
;spectre noiseOpts partition variables
spectre.noiseOpts readns string ""
spectre.noiseOpts prevoppoint string ""
spectre.noiseOpts save string ""
spectre.noiseOpts nestlvl string ""
spectre.noiseOpts oppoint string ""
spectre.noiseOpts restart string ""
spectre.noiseOpts annotate string "status"
spectre.noiseOpts stats string ""
;spectre xf partition variables
spectre.xf enable toggle (nil)
spectre.xf sweep string "Frequency"
spectre.xf freq string ""
spectre.xf dev string ""
spectre.xf deviceParam string ""
spectre.xf mod string ""
spectre.xf modelParam string ""
spectre.xf designVar string ""
spectre.xf param string ""
spectre.xf rangeType string "Start-Stop"
spectre.xf start string ""
spectre.xf stop string ""
spectre.xf center string ""
spectre.xf span string ""
spectre.xf incrType string "Automatic"
spectre.xf stepTypeLin string "Step Size"
spectre.xf stepTypeLog string "Points Per Decade"
spectre.xf step string ""
spectre.xf lin string ""
spectre.xf dec string ""
spectre.xf log string ""
spectre.xf useDiscrete boolean nil
spectre.xf values string ""
spectre.xf outType string "voltage"
spectre.xf p string ""
spectre.xf n string ""
spectre.xf probe string ""
;spectre xfOpts partition variables
spectre.xfOpts readns string ""
spectre.xfOpts prevoppoint string ""
spectre.xfOpts stimuli string ""
spectre.xfOpts save string ""
spectre.xfOpts nestlvl string ""
spectre.xfOpts oppoint string ""
spectre.xfOpts restart string ""
spectre.xfOpts annotate string "status"
spectre.xfOpts stats string ""
;spectre sp partition variables
spectre.sp enable toggle (nil)
spectre.sp ports string ""
spectre.sp sweep string "Frequency"
spectre.sp freq string ""
spectre.sp dev string ""
spectre.sp deviceParam string ""
spectre.sp mod string ""
spectre.sp modelParam string ""
spectre.sp designVar string ""
spectre.sp param string ""
spectre.sp rangeType string "Start-Stop"
spectre.sp start string ""
spectre.sp stop string ""
spectre.sp center string ""
spectre.sp span string ""
spectre.sp incrType string "Automatic"
spectre.sp stepTypeLin string "Step Size"
spectre.sp stepTypeLog string "Points Per Decade"
spectre.sp step string ""
spectre.sp lin string ""
spectre.sp dec string ""
spectre.sp log string ""
spectre.sp useDiscrete boolean nil
spectre.sp values string ""
spectre.sp donoise string "no"
spectre.sp oprobe string ""
spectre.sp iprobe string ""
;spectre spOpts partition variables
spectre.spOpts readns string ""
spectre.spOpts prevoppoint string ""
spectre.spOpts file string ""
spectre.spOpts datafmt string ""
spectre.spOpts datatype string ""
spectre.spOpts noisedata string ""
spectre.spOpts oppoint string ""
spectre.spOpts restart string ""
spectre.spOpts annotate string "status"
spectre.spOpts stats string ""
;spectre pss partition variables
spectre.pss enable toggle (nil)
spectre.pss paramListBox string ""
spectre.pss fundListBox string ""
spectre.pss stimName string ""
spectre.pss freqName string ""
spectre.pss freqVal string ""
spectre.pss signalLevel string "Large"
spectre.pss srcId string ""
spectre.pss maxHarms string ""
spectre.pss freqPeriod string "Beat Frequency"
spectre.pss fund string ""
spectre.pss autoCalc boolean nil
spectre.pss period string ""
spectre.pss harmonics string "Number of harmonics"
spectre.pss harms string ""
spectre.pss indices string ""
spectre.pss Aindices string ""
spectre.pss harmsvec string ""
spectre.pss selFreqFrom string "0"
spectre.pss selFreqTo string "1e12"
spectre.pss order string "1"
spectre.pss harmsAndFreqsTitle string ""
spectre.pss harmsAndFreqsTitle2 string ""
spectre.pss harmsAndFreqs string ""
spectre.pss arrayCoeffs string ""
spectre.pss harmCoeffs string ""
spectre.pss harmListMem string ""
spectre.pss errpreset string ""
spectre.pss tstab string ""
spectre.pss saveinit string ""
spectre.pss oscana boolean nil
spectre.pss p string ""
spectre.pss n string ""
spectre.pss sweepB boolean nil
spectre.pss sweep string "Variable"
spectre.pss freqVar string "no"
spectre.pss designVar string ""
spectre.pss dev string ""
spectre.pss deviceParam string ""
spectre.pss mod string ""
spectre.pss modelParam string ""
spectre.pss param string ""
spectre.pss rangeType string "Start-Stop"
spectre.pss start string ""
spectre.pss stop string ""
spectre.pss center string ""
spectre.pss span string ""
spectre.pss incrType string "Linear"
spectre.pss stepTypeLin string "Step Size"
spectre.pss stepTypeLog string "Points Per Decade"
spectre.pss step string ""
spectre.pss lin string ""
spectre.pss dec string ""
spectre.pss log string ""
spectre.pss useDiscrete boolean nil
spectre.pss values string ""
;spectre pssOpts partition variables
spectre.pssOpts step string ""
spectre.pssOpts maxstep string ""
spectre.pssOpts ic string ""
spectre.pssOpts skipdc string ""
spectre.pssOpts readic string ""
spectre.pssOpts readns string ""
spectre.pssOpts cmin string ""
spectre.pssOpts write string ""
spectre.pssOpts writefinal string ""
spectre.pssOpts swapfile string ""
spectre.pssOpts writepss string ""
spectre.pssOpts readpss string ""
spectre.pssOpts method string ""
spectre.pssOpts tstabmethod string ""
spectre.pssOpts relref string ""
spectre.pssOpts lteratio string ""
spectre.pssOpts steadyratio string ""
spectre.pssOpts maxacfreq string ""
spectre.pssOpts maxperiods string ""
spectre.pssOpts finitediff string ""
spectre.pssOpts highorder string ""
spectre.pssOpts psaratio string ""
spectre.pssOpts maxorder string ""
spectre.pssOpts fullpssvec string ""
spectre.pssOpts stats string ""
spectre.pssOpts annotate string "status"
spectre.pssOpts save string ""
spectre.pssOpts nestlvl string ""
spectre.pssOpts oppoint string ""
spectre.pssOpts skipstart string ""
spectre.pssOpts skipstop string ""
spectre.pssOpts skipcount string ""
spectre.pssOpts strobeperiod string ""
spectre.pssOpts strobedelay string ""
spectre.pssOpts compression string ""
spectre.pssOpts outputtype string ""
spectre.pssOpts maxiters string ""
spectre.pssOpts restart string ""
spectre.pssOpts tstart string ""
;spectre pac partition variables
spectre.pac enable toggle (nil)
spectre.pac fund string ""
spectre.pac period string ""
spectre.pac modsource string ""
spectre.pac moduppersideband string "0"
spectre.pac inmodharmnum string "1"
spectre.pac outmodharmvec string "1"
spectre.pac inputType string "SSB"
spectre.pac modulatedToggle boolean nil
spectre.pac modulated string ""
spectre.pac singlePt string "Single-Point []"
spectre.pac sweeptype string " "
spectre.pac relharmnum string ""
spectre.pac rangeType string "Start-Stop"
spectre.pac start string ""
spectre.pac stop string ""
spectre.pac center string ""
spectre.pac span string ""
spectre.pac incrType string "Automatic"
spectre.pac stepTypeLin string "Step Size"
spectre.pac stepTypeLog string "Points Per Decade"
spectre.pac step string ""
spectre.pac lin string ""
spectre.pac dec string ""
spectre.pac log string ""
spectre.pac useDiscrete boolean nil
spectre.pac values string ""
spectre.pac harmonics string "Maximum sideband"
spectre.pac maxsideband string ""
spectre.pac indices string ""
spectre.pac Aindices string ""
spectre.pac sidebands string ""
spectre.pac side string "upper"
spectre.pac selFreqFrom string "0"
spectre.pac selFreqTo string "1e12"
spectre.pac order string "1"
spectre.pac harmsAndFreqsTitle string ""
spectre.pac harmsAndFreqsTitle2 string ""
spectre.pac harmsAndFreqs string ""
spectre.pac arrayCoeffs string ""
spectre.pac harmCoeffs string ""
spectre.pac harmListMem string ""
;spectre pacOpts partition variables
spectre.pacOpts tolerance string ""
spectre.pacOpts gear_order string ""
spectre.pacOpts solver string ""
spectre.pacOpts oscsolver string ""
spectre.pacOpts stats string ""
spectre.pacOpts annotate string "status"
spectre.pacOpts freqaxis string ""
spectre.pacOpts save string ""
spectre.pacOpts nestlvl string ""
spectre.pacOpts outputperiod string ""
;spectre pnoise partition variables
spectre.pnoise enable toggle (nil)
spectre.pnoise fund string ""
spectre.pnoise period string ""
spectre.pnoise singlePt string "Single-Point []"
spectre.pnoise sweeptype string " "
spectre.pnoise relharmnum string ""
spectre.pnoise rangeType string "Start-Stop"
spectre.pnoise start string ""
spectre.pnoise stop string ""
spectre.pnoise center string ""
spectre.pnoise span string ""
spectre.pnoise incrType string "Automatic"
spectre.pnoise stepTypeLin string "Step Size"
spectre.pnoise stepTypeLog string "Points Per Decade"
spectre.pnoise step string ""
spectre.pnoise lin string ""
spectre.pnoise dec string ""
spectre.pnoise log string ""
spectre.pnoise useDiscrete boolean nil
spectre.pnoise values string ""
spectre.pnoise harmonics string "Maximum sideband"
spectre.pnoise maxsideband string ""
spectre.pnoise indices string ""
spectre.pnoise Aindices string ""
spectre.pnoise sidebands string ""
spectre.pnoise side string "upper"
spectre.pnoise selFreqFrom string "0"
spectre.pnoise selFreqTo string "1e12"
spectre.pnoise order string "1"
spectre.pnoise harmsAndFreqsTitle string ""
spectre.pnoise harmsAndFreqsTitle2 string ""
spectre.pnoise harmsAndFreqs string ""
spectre.pnoise arrayCoeffs string ""
spectre.pnoise harmCoeffs string ""
spectre.pnoise harmListMem string ""
spectre.pnoise outType string "probe"
spectre.pnoise p string ""
spectre.pnoise n string ""
spectre.pnoise oprobe string ""
spectre.pnoise inType string "port"
spectre.pnoise inVsrc string ""
spectre.pnoise inIsrc string ""
spectre.pnoise iprobe string ""
spectre.pnoise inPort string ""
spectre.pnoise refsbSelect string "Enter in field"
spectre.pnoise refsideband string ""
spectre.pnoise refsbFreqFrom string "0"
spectre.pnoise refsbFreqTo string "1e12"
spectre.pnoise refsbOrder string "1"
spectre.pnoise refsbTitle string ""
spectre.pnoise refsbListbox string ""
spectre.pnoise noisetype string "sources"
spectre.pnoise tdnoise string "Noise Skip Count"
spectre.pnoise noiseskipcount string ""
spectre.pnoise numberofpoints string ""
spectre.pnoise maxcycles string ""
spectre.pnoise useDiscreteNoise boolean nil
spectre.pnoise noisetimepoints string ""
spectre.pnoise useDiscreteCorr boolean nil
spectre.pnoise cycles string ""
;spectre pnoiseOpts partition variables
spectre.pnoiseOpts tolerance string ""
spectre.pnoiseOpts gear_order string ""
spectre.pnoiseOpts solver string ""
spectre.pnoiseOpts oscsolver string ""
spectre.pnoiseOpts stats string ""
spectre.pnoiseOpts annotate string "status"
spectre.pnoiseOpts save string ""
spectre.pnoiseOpts nestlvl string ""
spectre.pnoiseOpts saveallsidebands string ""
;spectre pxf partition variables
spectre.pxf enable toggle (nil)
spectre.pxf fund string ""
spectre.pxf period string ""
spectre.pxf moduppersideband string "0"
spectre.pxf outmodharmnum string "1"
spectre.pxf inmodharmvec string "1"
spectre.pxf outputType string "SSB"
spectre.pxf modulatedToggle boolean nil
spectre.pxf modulated string ""
spectre.pxf outType string "voltage"
spectre.pxf p string ""
spectre.pxf n string ""
spectre.pxf probe string ""
spectre.pxf singlePt string "Single-Point []"
spectre.pxf sweeptype string " "
spectre.pxf relharmnum string ""
spectre.pxf rangeType string "Start-Stop"
spectre.pxf start string ""
spectre.pxf stop string ""
spectre.pxf center string ""
spectre.pxf span string ""
spectre.pxf incrType string "Automatic"
spectre.pxf stepTypeLin string "Step Size"
spectre.pxf stepTypeLog string "Points Per Decade"
spectre.pxf step string ""
spectre.pxf lin string ""
spectre.pxf dec string ""
spectre.pxf log string ""
spectre.pxf useDiscrete boolean nil
spectre.pxf values string ""
spectre.pxf harmonics string "Maximum sideband"
spectre.pxf maxsideband string ""
spectre.pxf indices string ""
spectre.pxf Aindices string ""
spectre.pxf sidebands string ""
spectre.pxf side string "upper"
spectre.pxf selFreqFrom string "0"
spectre.pxf selFreqTo string "1e12"
spectre.pxf order string "1"
spectre.pxf harmsAndFreqsTitle string ""
spectre.pxf harmsAndFreqsTitle2 string ""
spectre.pxf harmsAndFreqs string ""
spectre.pxf arrayCoeffs string ""
spectre.pxf harmCoeffs string ""
spectre.pxf harmListMem string ""
;spectre pxfOpts partition variables
spectre.pxfOpts tolerance string ""
spectre.pxfOpts gear_order string ""
spectre.pxfOpts solver string ""
spectre.pxfOpts oscsolver string ""
spectre.pxfOpts stats string ""
spectre.pxfOpts annotate string "status"
spectre.pxfOpts stimuli string ""
spectre.pxfOpts freqaxis string ""
spectre.pxfOpts save string ""
spectre.pxfOpts nestlvl string ""
;spectre psp partition variables
spectre.psp enable toggle (nil)
spectre.psp singlePt string "Single-Point []"
spectre.psp sweeptype string " "
spectre.psp rangeType string "Start-Stop"
spectre.psp start string ""
spectre.psp stop string ""
spectre.psp center string ""
spectre.psp span string ""
spectre.psp incrType string "Automatic"
spectre.psp stepTypeLin string "Step Size"
spectre.psp stepTypeLog string "Points Per Decade"
spectre.psp step string ""
spectre.psp lin string ""
spectre.psp dec string ""
spectre.psp log string ""
spectre.psp useDiscrete boolean nil
spectre.psp values string ""
spectre.psp portharmsvec string ""
spectre.psp ports string ""
spectre.psp selectPorts boolean t
spectre.psp harmsvec string ""
spectre.psp freqRange string ""
spectre.psp listPortHarm string ""
spectre.psp listPortName string ""
spectre.psp listPortNum string ""
spectre.psp portChoiceList string ""
spectre.psp portChoiceListHeading string ""
spectre.psp donoise string "yes"
spectre.psp maxsideband string ""
;spectre pspOpts partition variables
spectre.pspOpts tolerance string ""
spectre.pspOpts gear_order string ""
spectre.pspOpts solver string ""
spectre.pspOpts oscsolver string ""
spectre.pspOpts annotate string "status"
spectre.pspOpts stats string ""
spectre.pspOpts freqaxis string ""
;spectre qpss partition variables
spectre.qpss enable toggle (nil)
spectre.qpss paramListBox string ""
spectre.qpss fundListBox string ""
spectre.qpss stimName string ""
spectre.qpss freqName string ""
spectre.qpss freqVal string ""
spectre.qpss signalLevel string "Moderate"
spectre.qpss srcId string ""
spectre.qpss maxHarms string ""
spectre.qpss funds string ""
spectre.qpss maxharms string ""
spectre.qpss harmonics boolean nil
spectre.qpss selFreqFrom string "0"
spectre.qpss selFreqTo string "1e12"
spectre.qpss harmsAndFreqsTitle string ""
spectre.qpss harmsAndFreqs string ""
spectre.qpss errpreset string ""
spectre.qpss tstab string ""
spectre.qpss saveinit string ""
spectre.qpss sweepB boolean nil
spectre.qpss sweep string "Variable"
spectre.qpss freqVar string "no"
spectre.qpss designVar string ""
spectre.qpss dev string ""
spectre.qpss deviceParam string ""
spectre.qpss mod string ""
spectre.qpss modelParam string ""
spectre.qpss param string ""
spectre.qpss rangeType string "Start-Stop"
spectre.qpss start string ""
spectre.qpss stop string ""
spectre.qpss center string ""
spectre.qpss span string ""
spectre.qpss incrType string "Linear"
spectre.qpss stepTypeLin string "Step Size"
spectre.qpss stepTypeLog string "Points Per Decade"
spectre.qpss step string ""
spectre.qpss lin string ""
spectre.qpss dec string ""
spectre.qpss log string ""
spectre.qpss useDiscrete boolean nil
spectre.qpss values string ""
;spectre qpssOpts partition variables
spectre.qpssOpts step string ""
spectre.qpssOpts maxstep string ""
spectre.qpssOpts ic string ""
spectre.qpssOpts skipdc string ""
spectre.qpssOpts readic string ""
spectre.qpssOpts readns string ""
spectre.qpssOpts cmin string ""
spectre.qpssOpts write string ""
spectre.qpssOpts writefinal string ""
spectre.qpssOpts swapfile string ""
spectre.qpssOpts writeqpss string ""
spectre.qpssOpts readqpss string ""
spectre.qpssOpts method string ""
spectre.qpssOpts relref string ""
spectre.qpssOpts lteratio string ""
spectre.qpssOpts steadyratio string ""
spectre.qpssOpts maxperiods string ""
spectre.qpssOpts stats string ""
spectre.qpssOpts annotate string "status"
spectre.qpssOpts save string ""
spectre.qpssOpts nestlvl string ""
spectre.qpssOpts oppoint string ""
spectre.qpssOpts skipstart string ""
spectre.qpssOpts skipstop string ""
spectre.qpssOpts skipcount string ""
spectre.qpssOpts strobeperiod string ""
spectre.qpssOpts strobedelay string ""
spectre.qpssOpts compression string ""
spectre.qpssOpts maxiters string ""
spectre.qpssOpts restart string ""
spectre.qpssOpts tstart string ""
;spectre qpac partition variables
spectre.qpac enable toggle (nil)
spectre.qpac singlePt string "Single-Point []"
spectre.qpac sweeptype string " "
spectre.qpac relharmvec string ""
spectre.qpac rangeType string "Start-Stop"
spectre.qpac start string ""
spectre.qpac stop string ""
spectre.qpac center string ""
spectre.qpac span string ""
spectre.qpac incrType string "Automatic"
spectre.qpac stepTypeLin string "Step Size"
spectre.qpac stepTypeLog string "Points Per Decade"
spectre.qpac step string ""
spectre.qpac lin string ""
spectre.qpac dec string ""
spectre.qpac log string ""
spectre.qpac useDiscrete boolean nil
spectre.qpac values string ""
spectre.qpac sbsm string "Maximum clock order"
spectre.qpac clockmaxharm string ""
spectre.qpac selFreqFrom string "0"
spectre.qpac selFreqTo string "1e12"
spectre.qpac order string "1"
spectre.qpac harmsAndFreqsTitle string ""
spectre.qpac harmsAndFreqsTitle2 string ""
spectre.qpac harmsAndFreqs string ""
spectre.qpac arrayCoeffs string ""
spectre.qpac harmCoeffs string ""
spectre.qpac harmListMem string ""
spectre.qpac sidevec string ""
;spectre qpacOpts partition variables
spectre.qpacOpts tolerance string ""
spectre.qpacOpts gear_order string ""
spectre.qpacOpts solver string ""
spectre.qpacOpts stats string ""
spectre.qpacOpts annotate string "status"
spectre.qpacOpts freqaxis string ""
spectre.qpacOpts save string ""
spectre.qpacOpts nestlvl string ""
;spectre qpnoise partition variables
spectre.qpnoise enable toggle (nil)
spectre.qpnoise singlePt string "Single-Point []"
spectre.qpnoise sweeptype string " "
spectre.qpnoise relharmvec string ""
spectre.qpnoise rangeType string "Start-Stop"
spectre.qpnoise start string ""
spectre.qpnoise stop string ""
spectre.qpnoise center string ""
spectre.qpnoise span string ""
spectre.qpnoise incrType string "Automatic"
spectre.qpnoise stepTypeLin string "Step Size"
spectre.qpnoise stepTypeLog string "Points Per Decade"
spectre.qpnoise step string ""
spectre.qpnoise lin string ""
spectre.qpnoise dec string ""
spectre.qpnoise log string ""
spectre.qpnoise useDiscrete boolean nil
spectre.qpnoise values string ""
spectre.qpnoise sbsm string "Maximum clock order"
spectre.qpnoise clockmaxharm string ""
spectre.qpnoise selFreqFrom string "0"
spectre.qpnoise selFreqTo string "1e12"
spectre.qpnoise order string "1"
spectre.qpnoise harmsAndFreqsTitle string ""
spectre.qpnoise harmsAndFreqsTitle2 string ""
spectre.qpnoise harmsAndFreqs string ""
spectre.qpnoise arrayCoeffs string ""
spectre.qpnoise harmCoeffs string ""
spectre.qpnoise harmListMem string ""
spectre.qpnoise sidevec string ""
spectre.qpnoise outType string "probe"
spectre.qpnoise p string ""
spectre.qpnoise n string ""
spectre.qpnoise oprobe string ""
spectre.qpnoise inType string "port"
spectre.qpnoise inVsrc string ""
spectre.qpnoise inIsrc string ""
spectre.qpnoise iprobe string ""
spectre.qpnoise inPort string ""
spectre.qpnoise refsbSelect string "Enter in field"
spectre.qpnoise refsideband string ""
spectre.qpnoise refsbFreqFrom string "0"
spectre.qpnoise refsbFreqTo string "1e12"
spectre.qpnoise refsbOrder string "1"
spectre.qpnoise refsbTitle string ""
spectre.qpnoise refsbListbox string ""
;spectre qpnoiseOpts partition variables
spectre.qpnoiseOpts tolerance string ""
spectre.qpnoiseOpts gear_order string ""
spectre.qpnoiseOpts solver string ""
spectre.qpnoiseOpts stats string ""
spectre.qpnoiseOpts annotate string "status"
spectre.qpnoiseOpts save string ""
spectre.qpnoiseOpts nestlvl string ""
spectre.qpnoiseOpts saveallsidebands string ""
;spectre qpxf partition variables
spectre.qpxf enable toggle (nil)
spectre.qpxf singlePt string "Single-Point []"
spectre.qpxf sweeptype string " "
spectre.qpxf relharmvec string ""
spectre.qpxf rangeType string "Start-Stop"
spectre.qpxf start string ""
spectre.qpxf stop string ""
spectre.qpxf center string ""
spectre.qpxf span string ""
spectre.qpxf incrType string "Automatic"
spectre.qpxf stepTypeLin string "Step Size"
spectre.qpxf stepTypeLog string "Points Per Decade"
spectre.qpxf step string ""
spectre.qpxf lin string ""
spectre.qpxf dec string ""
spectre.qpxf log string ""
spectre.qpxf useDiscrete boolean nil
spectre.qpxf values string ""
spectre.qpxf sbsm string "Maximum clock order"
spectre.qpxf clockmaxharm string ""
spectre.qpxf selFreqFrom string "0"
spectre.qpxf selFreqTo string "1e12"
spectre.qpxf order string "1"
spectre.qpxf harmsAndFreqsTitle string ""
spectre.qpxf harmsAndFreqsTitle2 string ""
spectre.qpxf harmsAndFreqs string ""
spectre.qpxf arrayCoeffs string ""
spectre.qpxf harmCoeffs string ""
spectre.qpxf harmListMem string ""
spectre.qpxf sidevec string ""
spectre.qpxf outType string "voltage"
spectre.qpxf p string ""
spectre.qpxf n string ""
spectre.qpxf probe string ""
;spectre qpxfOpts partition variables
spectre.qpxfOpts tolerance string ""
spectre.qpxfOpts gear_order string ""
spectre.qpxfOpts solver string ""
spectre.qpxfOpts stats string ""
spectre.qpxfOpts annotate string "status"
spectre.qpxfOpts stimuli string ""
spectre.qpxfOpts freqaxis string ""
spectre.qpxfOpts save string ""
spectre.qpxfOpts nestlvl string ""
;spectre qpsp partition variables
spectre.qpsp enable toggle (nil)
spectre.qpsp singlePt string "Single-Point []"
spectre.qpsp sweeptype string " "
spectre.qpsp rangeType string "Start-Stop"
spectre.qpsp start string ""
spectre.qpsp stop string ""
spectre.qpsp center string ""
spectre.qpsp span string ""
spectre.qpsp incrType string "Automatic"
spectre.qpsp stepTypeLin string "Step Size"
spectre.qpsp stepTypeLog string "Points Per Decade"
spectre.qpsp step string ""
spectre.qpsp lin string ""
spectre.qpsp dec string ""
spectre.qpsp log string ""
spectre.qpsp useDiscrete boolean nil
spectre.qpsp values string ""
spectre.qpsp portharmsvec string ""
spectre.qpsp ports string ""
spectre.qpsp selectPorts boolean t
spectre.qpsp harmsvec string ""
spectre.qpsp freqRange string ""
spectre.qpsp listPortHarm string ""
spectre.qpsp listPortName string ""
spectre.qpsp listPortNum string ""
spectre.qpsp portChoiceList string ""
spectre.qpsp portChoiceListHeading string ""
spectre.qpsp donoise string "yes"
spectre.qpsp clockmaxharm string ""
;spectre qpspOpts partition variables
spectre.qpspOpts tolerance string ""
spectre.qpspOpts gear_order string ""
spectre.qpspOpts solver string ""
spectre.qpspOpts annotate string "status"
spectre.qpspOpts stats string ""
spectre.qpspOpts freqaxis string ""
;spectre sens partition variables
spectre.sens enable toggle (nil)
spectre.sens sensType toggle (nil nil nil)
spectre.sens analyses_list string ""
spectre.sens outputs string ""
spectre.sens output_list string ""
spectre.sens net string ""
spectre.sens term string ""
;spectre sensOpts partition variables
;spectreS environment variables
;spectreS opts partition variables
spectreS.opts title string ""
spectreS.opts audit string ""
spectreS.opts ckptclock string "1800"
spectreS.opts flow string ""
spectreS.opts cols string "80"
spectreS.opts opptcheck string ""
spectreS.opts reltol string "1e-3"
spectreS.opts notation string ""
spectreS.opts warn string ""
spectreS.opts approx string ""
spectreS.opts info string ""
spectreS.opts quantities string ""
spectreS.opts pivabs string ""
spectreS.opts compatible string ""
spectreS.opts ignshorts string ""
spectreS.opts gmin string "1e-12"
spectreS.opts rforce string "1"
spectreS.opts homotopy string ""
spectreS.opts debug string ""
spectreS.opts iabstol string "1e-12"
spectreS.opts maxwarns string "5"
spectreS.opts tempeffects string ""
spectreS.opts vabstol string "1e-6"
spectreS.opts temp string "27"
spectreS.opts tnom string "27"
spectreS.opts narrate string ""
spectreS.opts value string ""
spectreS.opts gmin_check string ""
spectreS.opts pivrel string "1e-3"
spectreS.opts pivotdc string ""
spectreS.opts digits string "5"
spectreS.opts diagnose string ""
spectreS.opts scale string "1.0"
spectreS.opts scalem string "1.0"
spectreS.opts error string ""
spectreS.opts inventory string ""
spectreS.opts topcheck string ""
spectreS.opts limit string ""
;spectreS outputs partition variables
spectreS.outputs allAnalogACTC boolean nil
spectreS.outputs allAhdlVars boolean nil
spectreS.outputs allAnalogNV boolean t
spectreS.outputs allAnalogTC boolean nil
;spectreS envOpts partition variables
spectreS.envOpts updateFile string ""
spectreS.envOpts stimulusFile string ""
spectreS.envOpts instViewListTable string ""
spectreS.envOpts doInstBased boolean nil
spectreS.envOpts stopViewList string "spectreS spice"
spectreS.envOpts paramRangeCheckFile string ""
spectreS.envOpts includeSyntax string "cdsSpice"
spectreS.envOpts initFile string ""
spectreS.envOpts printComments boolean nil
spectreS.envOpts netlistType string "hierarchical"
spectreS.envOpts generateMapFile boolean nil
spectreS.envOpts includeFile string ""
spectreS.envOpts recover boolean nil
spectreS.envOpts instStopListTable string ""
spectreS.envOpts switchViewList string "spectreS spice cmos_sch cmos.sch schematic veriloga ahdl"
;spectreS init partition variables
spectreS.init processPriority int 0
;spectreS tran partition variables
spectreS.tran enable toggle (nil)
spectreS.tran to string ""
spectreS.tran errpreset string ""
;spectreS tranOpts partition variables
spectreS.tranOpts start string ""
spectreS.tranOpts outputstart string ""
spectreS.tranOpts step string ""
spectreS.tranOpts maxstep string ""
spectreS.tranOpts ic string ""
spectreS.tranOpts skipdc string ""
spectreS.tranOpts readic string ""
spectreS.tranOpts readns string ""
spectreS.tranOpts cmin string ""
spectreS.tranOpts write string "spectre.ic"
spectreS.tranOpts writefinal string "spectre.fc"
spectreS.tranOpts ckptperiod string ""
spectreS.tranOpts method string "default"
spectreS.tranOpts relref string "default"
spectreS.tranOpts lteratio string ""
spectreS.tranOpts stats string ""
spectreS.tranOpts annotate string "status"
spectreS.tranOpts oppoint string ""
spectreS.tranOpts skipstart string ""
spectreS.tranOpts skipstop string ""
spectreS.tranOpts skipcount string ""
spectreS.tranOpts strobeperiod string ""
spectreS.tranOpts strobedelay string ""
spectreS.tranOpts compression string "no"
spectreS.tranOpts maxiters string "5"
spectreS.tranOpts restart string ""
;spectreS ac partition variables
spectreS.ac enable toggle (nil)
spectreS.ac sweep string "Frequency"
spectreS.ac freq string ""
spectreS.ac device string ""
spectreS.ac deviceParam string ""
spectreS.ac model string ""
spectreS.ac modelParam string ""
spectreS.ac temperature string "temp"
spectreS.ac rangeType string "Start-Stop"
spectreS.ac from string ""
spectreS.ac to string ""
spectreS.ac center string ""
spectreS.ac span string ""
spectreS.ac incrType string "Automatic"
spectreS.ac stepTypeLin string "Step Size"
spectreS.ac stepTypeLog string "Points Per Decade"
spectreS.ac by string ""
spectreS.ac lin string ""
spectreS.ac dec string ""
spectreS.ac log string ""
spectreS.ac useDiscrete boolean nil
spectreS.ac values string ""
;spectreS acOpts partition variables
spectreS.acOpts readns string ""
spectreS.acOpts oppoint string ""
spectreS.acOpts restart string ""
spectreS.acOpts annotate string "status"
spectreS.acOpts stats string ""
;spectreS dc partition variables
spectreS.dc enable toggle (nil)
spectreS.dcop enable toggle (nil)
spectreS.dc saveOppoint boolean nil
spectreS.dc oppoint string "rawfile"
spectreS.dc save string "allpub"
spectreS.dc sweep string ""
spectreS.dc device string ""
spectreS.dc deviceParam string ""
spectreS.dc model string ""
spectreS.dc modelParam string ""
spectreS.dc temperature string "temp"
spectreS.dc rangeType string "Start-Stop"
spectreS.dc from string ""
spectreS.dc to string ""
spectreS.dc center string ""
spectreS.dc span string ""
spectreS.dc incrType string "Automatic"
spectreS.dc stepTypeLin string "Step Size"
spectreS.dc stepTypeLog string "Points Per Decade"
spectreS.dc by string ""
spectreS.dc lin string ""
spectreS.dc dec string ""
spectreS.dc log string ""
spectreS.dc useDiscrete boolean nil
spectreS.dc values string ""
;spectreS dcOpts partition variables
spectreS.dcOpts force string ""
spectreS.dcopOpts force string ""
spectreS.dcOpts readns string ""
spectreS.dcopOpts readns string ""
spectreS.dcOpts readforce string ""
spectreS.dcopOpts readforce string ""
spectreS.dcOpts write string "spectre.dc"
spectreS.dcopOpts write string "spectre.dc"
spectreS.dcOpts writefinal string ""
spectreS.dcopOpts writefinal string ""
spectreS.dcOpts print string ""
spectreS.dcopOpts print string ""
spectreS.dcOpts check string ""
spectreS.dcopOpts check string ""
spectreS.dcOpts homotopy string ""
spectreS.dcopOpts homotopy string ""
spectreS.dcOpts restart string ""
spectreS.dcopOpts restart string ""
spectreS.dcOpts maxiters string "150"
spectreS.dcopOpts maxiters string "150"
spectreS.dcOpts maxsteps string "10000"
spectreS.dcopOpts maxsteps string "10000"
spectreS.dcOpts annotate string "status"
spectreS.dcopOpts annotate string "status"
;spectreS noise partition variables
spectreS.noise enable toggle (nil)
spectreS.noise sweep string "Frequency"
spectreS.noise freq string ""
spectreS.noise device string ""
spectreS.noise deviceParam string ""
spectreS.noise model string ""
spectreS.noise modelParam string ""
spectreS.noise temperature string "temp"
spectreS.noise rangeType string "Start-Stop"
spectreS.noise from string ""
spectreS.noise to string ""
spectreS.noise center string ""
spectreS.noise span string ""
spectreS.noise incrType string "Automatic"
spectreS.noise stepTypeLin string "Step Size"
spectreS.noise stepTypeLog string "Points Per Decade"
spectreS.noise by string ""
spectreS.noise lin string ""
spectreS.noise dec string ""
spectreS.noise log string ""
spectreS.noise useDiscrete boolean nil
spectreS.noise values string ""
spectreS.noise outNoiseType string "voltage"
spectreS.noise negNode string "/gnd!"
spectreS.noise posNode string ""
spectreS.noise outVsrc string ""
spectreS.noise inNoiseType string "voltage"
spectreS.noise inVsrc string ""
spectreS.noise inIsrc string ""
spectreS.noise inPort string ""
;spectreS noiseOpts partition variables
spectreS.noiseOpts readns string ""
spectreS.noiseOpts oppoint string ""
spectreS.noiseOpts restart string ""
spectreS.noiseOpts annotate string "status"
spectreS.noiseOpts stats string ""
;spectreS xf partition variables
spectreS.xf enable toggle (nil)
spectreS.xf sweep string "Frequency"
spectreS.xf freq string ""
spectreS.xf device string ""
spectreS.xf deviceParam string ""
spectreS.xf model string ""
spectreS.xf modelParam string ""
spectreS.xf temperature string "temp"
spectreS.xf rangeType string "Start-Stop"
spectreS.xf from string ""
spectreS.xf to string ""
spectreS.xf center string ""
spectreS.xf span string ""
spectreS.xf incrType string "Automatic"
spectreS.xf stepTypeLin string "Step Size"
spectreS.xf stepTypeLog string "Points Per Decade"
spectreS.xf by string ""
spectreS.xf lin string ""
spectreS.xf dec string ""
spectreS.xf log string ""
spectreS.xf useDiscrete boolean nil
spectreS.xf values string ""
spectreS.xf outXfType string "voltage"
spectreS.xf negNode string "/gnd!"
spectreS.xf posNode string ""
spectreS.xf outVsrc string ""
;spectreS xfOpts partition variables
spectreS.xfOpts readns string ""
spectreS.xfOpts stimuli string ""
spectreS.xfOpts oppoint string ""
spectreS.xfOpts restart string ""
spectreS.xfOpts annotate string "status"
spectreS.xfOpts stats string ""
;spectreS sp partition variables
spectreS.sp enable toggle (nil)
spectreS.sp sweep string "Frequency"
spectreS.sp frequency string ""
spectreS.sp device string ""
spectreS.sp deviceParam string ""
spectreS.sp model string ""
spectreS.sp modelParam string ""
spectreS.sp temperature string "temp"
spectreS.sp rangeType string "Start-Stop"
spectreS.sp from string ""
spectreS.sp to string ""
spectreS.sp center string ""
spectreS.sp span string ""
spectreS.sp incrType string "Automatic"
spectreS.sp stepTypeLin string "Step Size"
spectreS.sp stepTypeLog string "Points Per Decade"
spectreS.sp by string ""
spectreS.sp lin string ""
spectreS.sp dec string ""
spectreS.sp log string ""
spectreS.sp useDiscrete boolean nil
spectreS.sp values string ""
spectreS.sp donoise boolean nil
spectreS.sp oprobe string ""
spectreS.sp iprobe string ""
;spectreS spOpts partition variables
spectreS.spOpts readns string ""
spectreS.spOpts file string ""
spectreS.spOpts oppoint string ""
spectreS.spOpts reftemp string ""
spectreS.spOpts restart string ""
spectreS.spOpts annotate string "status"
spectreS.spOpts stats string ""
;spectreS spss partition variables
spectreS.spss enable toggle (nil)
spectreS.spss paramListBox string ""
spectreS.spss fundListBox string ""
spectreS.spss stimName string ""
spectreS.spss freqName string ""
spectreS.spss freqVal string ""
spectreS.spss signalLevel string "Moderate"
spectreS.spss srcId string ""
spectreS.spss maxHarms string ""
spectreS.spss freqPeriod string "Fundamental (Beat) Frequency"
spectreS.spss fund string ""
spectreS.spss period string ""
spectreS.spss harmonics string "None"
spectreS.spss numharmonics string ""
spectreS.spss arrayharmonics string ""
spectreS.spss none string "0"
spectreS.spss selFreqFrom string ""
spectreS.spss selFreqTo string ""
spectreS.spss harmsAndFreqsTitle string ""
spectreS.spss harmsAndFreqs string ""
spectreS.spss errpreset string ""
spectreS.spss tstab string ""
spectreS.spss saveinit string ""
spectreS.spss oscana boolean nil
spectreS.spss oscRefNode string "/gnd!"
spectreS.spss oscNode string ""
spectreS.spss sweep string "frequency/period"
spectreS.spss designVar string ""
spectreS.spss rangeType string "Start-Stop"
spectreS.spss from string ""
spectreS.spss to string ""
spectreS.spss center string ""
spectreS.spss span string ""
spectreS.spss incrType string "Linear"
spectreS.spss stepTypeLin string "Step Size"
spectreS.spss stepTypeLog string "Points Per Decade"
spectreS.spss by string ""
spectreS.spss lin string ""
spectreS.spss dec string ""
spectreS.spss log string ""
spectreS.spss useDiscrete boolean nil
spectreS.spss values string ""
spectreS.spss analysisList string ""
spectreS.spss pacEnable boolean nil
spectreS.spss pacfund string ""
spectreS.spss pacRelative boolean nil
spectreS.spss pacsweeptype string ""
spectreS.spss pacharmonics string "Zero sideband only"
spectreS.spss pacnumharmonics string ""
spectreS.spss pacarrayharmonics string ""
spectreS.spss pacselFreqFrom string ""
spectreS.spss pacselFreqTo string ""
spectreS.spss pacharmsAndFreqsTitle string ""
spectreS.spss pacharmsAndFreqs string ""
spectreS.spss pnoiseEnable boolean nil
spectreS.spss pnoisefund string ""
spectreS.spss pnoiseRelative boolean nil
spectreS.spss pnoisesweeptype string ""
spectreS.spss pnoiseharmonics string "Zero sideband only"
spectreS.spss pnoisenumharmonics string ""
spectreS.spss pnoisearrayharmonics string ""
spectreS.spss pnoiseselFreqFrom string ""
spectreS.spss pnoiseselFreqTo string ""
spectreS.spss pnoiseharmsAndFreqsTitle string ""
spectreS.spss pnoiseharmsAndFreqs string ""
spectreS.spss pnoiseoutProbeType string "voltage"
spectreS.spss pnoisenegNode string "/gnd!"
spectreS.spss pnoiseposNode string ""
spectreS.spss pnoiseoutVsrc string ""
spectreS.spss pnoiseinNoiseType string "none"
spectreS.spss pnoiseinVsrc string ""
spectreS.spss pnoiseinIsrc string ""
spectreS.spss pnoiseinPort string ""
spectreS.spss pnoiserefsideband string ""
spectreS.spss pxfEnable boolean nil
spectreS.spss pxffund string ""
spectreS.spss pxfRelative boolean nil
spectreS.spss pxfsweeptype string ""
spectreS.spss pxfharmonics string "Zero sideband only"
spectreS.spss pxfnumharmonics string ""
spectreS.spss pxfarrayharmonics string ""
spectreS.spss pxfselFreqFrom string ""
spectreS.spss pxfselFreqTo string ""
spectreS.spss pxfharmsAndFreqsTitle string ""
spectreS.spss pxfharmsAndFreqs string ""
spectreS.spss pxfoutProbeType string "voltage"
spectreS.spss pxfnegNode string "/gnd!"
spectreS.spss pxfposNode string ""
spectreS.spss pxfoutVsrc string ""
;spectreS spssOpts partition variables
spectreS.spssOpts step string ""
spectreS.spssOpts maxstep string ""
spectreS.spssOpts ic string ""
spectreS.spssOpts skipdc string ""
spectreS.spssOpts readic string ""
spectreS.spssOpts readns string ""
spectreS.spssOpts cmin string ""
spectreS.spssOpts write string ""
spectreS.spssOpts writefinal string ""
spectreS.spssOpts swapfile string ""
spectreS.spssOpts method string ""
spectreS.spssOpts relref string ""
spectreS.spssOpts lteratio string ""
spectreS.spssOpts steadyratio string ""
spectreS.spssOpts maxacfreq string ""
spectreS.spssOpts maxperiods string ""
spectreS.spssOpts stats string ""
spectreS.spssOpts annotate string "status"
spectreS.spssOpts oppoint string ""
spectreS.spssOpts skipstart string ""
spectreS.spssOpts skipstop string ""
spectreS.spssOpts skipcount string ""
spectreS.spssOpts strobeperiod string ""
spectreS.spssOpts strobedelay string ""
spectreS.spssOpts compression string ""
spectreS.spssOpts maxiters string ""
spectreS.spssOpts restart string ""
spectreS.spssOpts tstart string ""
spectreS.spssOpts tolerance string ""
spectreS.spssOpts gearorder string ""
spectreS.spssOpts solver string ""
spectreS.spssOpts stats2 string ""
spectreS.spssOpts annotate2 string "status"
spectreS.spssOpts freqaxis string ""
spectreS.spssOpts tolerance2 string ""
spectreS.spssOpts gearorder2 string ""
spectreS.spssOpts solver2 string ""
spectreS.spssOpts stats3 string ""
spectreS.spssOpts annotate3 string "status"
spectreS.spssOpts stimuli string ""
spectreS.spssOpts freqaxis2 string ""
spectreS.spssOpts tolerance3 string ""
spectreS.spssOpts gearorder3 string ""
spectreS.spssOpts solver3 string ""
spectreS.spssOpts stats4 string ""
spectreS.spssOpts annotate4 string "status"
;spectreS pss partition variables
spectreS.pss enable toggle (nil)
spectreS.pss paramListBox string ""
spectreS.pss fundListBox string ""
spectreS.pss stimName string ""
spectreS.pss freqName string ""
spectreS.pss freqVal string ""
spectreS.pss signalLevel string "Moderate"
spectreS.pss srcId string ""
spectreS.pss maxHarms string ""
spectreS.pss freqPeriod string "Fundamental (Beat) Frequency"
spectreS.pss fund string ""
spectreS.pss period string ""
spectreS.pss harmonics string "None"
spectreS.pss numharmonics string ""
spectreS.pss arrayharmonics string ""
spectreS.pss none string "0"
spectreS.pss selFreqFrom string ""
spectreS.pss selFreqTo string ""
spectreS.pss harmsAndFreqsTitle string ""
spectreS.pss harmsAndFreqs string ""
spectreS.pss errpreset string ""
spectreS.pss tstab string ""
spectreS.pss saveinit string ""
spectreS.pss oscana boolean nil
spectreS.pss oscRefNode string "/gnd!"
spectreS.pss oscNode string ""
spectreS.pss analysisList string ""
spectreS.pss pacEnable boolean nil
spectreS.pss pacRelative boolean nil
spectreS.pss pacsweeptype string ""
spectreS.pss pacrangeType string "Start-Stop"
spectreS.pss pacfrom string ""
spectreS.pss pacto string ""
spectreS.pss paccenter string ""
spectreS.pss pacspan string ""
spectreS.pss pacincrType string "Automatic"
spectreS.pss pacstepTypeLin string "Step Size"
spectreS.pss pacstepTypeLog string "Points Per Decade"
spectreS.pss pacby string ""
spectreS.pss paclin string ""
spectreS.pss pacdec string ""
spectreS.pss paclog string ""
spectreS.pss pacuseDiscrete boolean nil
spectreS.pss pacvalues string ""
spectreS.pss pacharmonics string "Zero sideband only"
spectreS.pss pacnumharmonics string ""
spectreS.pss pacarrayharmonics string ""
spectreS.pss pacselFreqFrom string ""
spectreS.pss pacselFreqTo string ""
spectreS.pss pacharmsAndFreqsTitle string ""
spectreS.pss pacharmsAndFreqs string ""
spectreS.pss pnoiseEnable boolean nil
spectreS.pss pnoiseRelative boolean nil
spectreS.pss pnoisesweeptype string ""
spectreS.pss pnoiserangeType string "Start-Stop"
spectreS.pss pnoisefrom string ""
spectreS.pss pnoiseto string ""
spectreS.pss pnoisecenter string ""
spectreS.pss pnoisespan string ""
spectreS.pss pnoiseincrType string "Automatic"
spectreS.pss pnoisestepTypeLin string "Step Size"
spectreS.pss pnoisestepTypeLog string "Points Per Decade"
spectreS.pss pnoiseby string ""
spectreS.pss pnoiselin string ""
spectreS.pss pnoisedec string ""
spectreS.pss pnoiselog string ""
spectreS.pss pnoiseuseDiscrete boolean nil
spectreS.pss pnoisevalues string ""
spectreS.pss pnoiseharmonics string "Zero sideband only"
spectreS.pss pnoisenumharmonics string ""
spectreS.pss pnoisearrayharmonics string ""
spectreS.pss pnoiseselFreqFrom string ""
spectreS.pss pnoiseselFreqTo string ""
spectreS.pss pnoiseharmsAndFreqsTitle string ""
spectreS.pss pnoiseharmsAndFreqs string ""
spectreS.pss pnoiseoutProbeType string "voltage"
spectreS.pss pnoisenegNode string "/gnd!"
spectreS.pss pnoiseposNode string ""
spectreS.pss pnoiseoutVsrc string ""
spectreS.pss pnoiseinNoiseType string "none"
spectreS.pss pnoiseinVsrc string ""
spectreS.pss pnoiseinIsrc string ""
spectreS.pss pnoiseinPort string ""
spectreS.pss pnoiserefsideband string ""
spectreS.pss pxfEnable boolean nil
spectreS.pss pxfRelative boolean nil
spectreS.pss pxfsweeptype string ""
spectreS.pss pxfrangeType string "Start-Stop"
spectreS.pss pxffrom string ""
spectreS.pss pxfto string ""
spectreS.pss pxfcenter string ""
spectreS.pss pxfspan string ""
spectreS.pss pxfincrType string "Automatic"
spectreS.pss pxfstepTypeLin string "Step Size"
spectreS.pss pxfstepTypeLog string "Points Per Decade"
spectreS.pss pxfby string ""
spectreS.pss pxflin string ""
spectreS.pss pxfdec string ""
spectreS.pss pxflog string ""
spectreS.pss pxfuseDiscrete boolean nil
spectreS.pss pxfvalues string ""
spectreS.pss pxfharmonics string "Zero sideband only"
spectreS.pss pxfnumharmonics string ""
spectreS.pss pxfarrayharmonics string ""
spectreS.pss pxfselFreqFrom string ""
spectreS.pss pxfselFreqTo string ""
spectreS.pss pxfharmsAndFreqsTitle string ""
spectreS.pss pxfharmsAndFreqs string ""
spectreS.pss pxfoutProbeType string "voltage"
spectreS.pss pxfnegNode string "/gnd!"
spectreS.pss pxfposNode string ""
spectreS.pss pxfoutVsrc string ""
;spectreS pssOpts partition variables
spectreS.pssOpts step string ""
spectreS.pssOpts maxstep string ""
spectreS.pssOpts ic string ""
spectreS.pssOpts skipdc string ""
spectreS.pssOpts readic string ""
spectreS.pssOpts readns string ""
spectreS.pssOpts cmin string ""
spectreS.pssOpts write string ""
spectreS.pssOpts writefinal string ""
spectreS.pssOpts swapfile string ""
spectreS.pssOpts method string ""
spectreS.pssOpts relref string ""
spectreS.pssOpts lteratio string ""
spectreS.pssOpts steadyratio string ""
spectreS.pssOpts maxacfreq string ""
spectreS.pssOpts maxperiods string ""
spectreS.pssOpts stats string ""
spectreS.pssOpts annotate string "status"
spectreS.pssOpts oppoint string ""
spectreS.pssOpts skipstart string ""
spectreS.pssOpts skipstop string ""
spectreS.pssOpts skipcount string ""
spectreS.pssOpts strobeperiod string ""
spectreS.pssOpts strobedelay string ""
spectreS.pssOpts compression string ""
spectreS.pssOpts maxiters string ""
spectreS.pssOpts restart string ""
spectreS.pssOpts tstart string ""
spectreS.pssOpts tolerance string ""
spectreS.pssOpts gearorder string ""
spectreS.pssOpts solver string ""
spectreS.pssOpts stats2 string ""
spectreS.pssOpts annotate2 string "status"
spectreS.pssOpts freqaxis string ""
spectreS.pssOpts tolerance2 string ""
spectreS.pssOpts gearorder2 string ""
spectreS.pssOpts solver2 string ""
spectreS.pssOpts stats3 string ""
spectreS.pssOpts annotate3 string "status"
spectreS.pssOpts stimuli string ""
spectreS.pssOpts freqaxis2 string ""
spectreS.pssOpts tolerance3 string ""
spectreS.pssOpts gearorder3 string ""
spectreS.pssOpts solver3 string ""
spectreS.pssOpts stats4 string ""
spectreS.pssOpts annotate4 string "status"
;spectreS pdisto partition variables
spectreS.pdisto enable toggle (nil)
spectreS.pdisto paramListBox string ""
spectreS.pdisto fundListBox string ""
spectreS.pdisto stimName string ""
spectreS.pdisto freqName string ""
spectreS.pdisto freqVal string ""
spectreS.pdisto signalLevel string "Moderate"
spectreS.pdisto srcId string ""
spectreS.pdisto maxHarms string ""
spectreS.pdisto fundsList string ""
spectreS.pdisto maxHarmsList string ""
spectreS.pdisto errpreset string ""
spectreS.pdisto tstab string ""
spectreS.pdisto saveinit string ""
;spectreS pdistoOpts partition variables
spectreS.pdistoOpts step string ""
spectreS.pdistoOpts maxstep string ""
spectreS.pdistoOpts ic string ""
spectreS.pdistoOpts skipdc string ""
spectreS.pdistoOpts readic string ""
spectreS.pdistoOpts readns string ""
spectreS.pdistoOpts cmin string ""
spectreS.pdistoOpts tolerance string ""
spectreS.pdistoOpts gearorder string ""
spectreS.pdistoOpts solver string ""
spectreS.pdistoOpts write string ""
spectreS.pdistoOpts writefinal string ""
spectreS.pdistoOpts swapfile string ""
spectreS.pdistoOpts method string ""
spectreS.pdistoOpts relref string ""
spectreS.pdistoOpts lteratio string ""
spectreS.pdistoOpts steadyratio string ""
spectreS.pdistoOpts maxacfreq string ""
spectreS.pdistoOpts maxperiods string ""
spectreS.pdistoOpts stats string ""
spectreS.pdistoOpts annotate string "status"
spectreS.pdistoOpts oppoint string ""
spectreS.pdistoOpts skipstart string ""
spectreS.pdistoOpts skipstop string ""
spectreS.pdistoOpts skipcount string ""
spectreS.pdistoOpts strobeperiod string ""
spectreS.pdistoOpts strobedelay string ""
spectreS.pdistoOpts compression string ""
spectreS.pdistoOpts freqaxis string ""
spectreS.pdistoOpts maxiters string ""
spectreS.pdistoOpts restart string ""
spectreS.pdistoOpts tstart string ""
;spectreS spac partition variables
spectreS.spac enable toggle (nil)
spectreS.spac fund string ""
spectreS.spac Relative boolean nil
spectreS.spac sweeptype string ""
spectreS.spac harmonics string "Zero sideband only"
spectreS.spac numharmonics string ""
spectreS.spac arrayharmonics string ""
spectreS.spac selFreqFrom string ""
spectreS.spac selFreqTo string ""
spectreS.spac harmsAndFreqsTitle string ""
spectreS.spac harmsAndFreqs string ""
;spectreS spacOpts partition variables
spectreS.spacOpts tolerance string ""
spectreS.spacOpts gearorder string ""
spectreS.spacOpts solver string ""
spectreS.spacOpts stats2 string ""
spectreS.spacOpts annotate2 string "status"
spectreS.spacOpts freqaxis string ""
;spectreS spnoise partition variables
spectreS.spnoise enable toggle (nil)
spectreS.spnoise fund string ""
spectreS.spnoise Relative boolean nil
spectreS.spnoise sweeptype string ""
spectreS.spnoise harmonics string "Zero sideband only"
spectreS.spnoise numharmonics string ""
spectreS.spnoise arrayharmonics string ""
spectreS.spnoise selFreqFrom string ""
spectreS.spnoise selFreqTo string ""
spectreS.spnoise harmsAndFreqsTitle string ""
spectreS.spnoise harmsAndFreqs string ""
spectreS.spnoise outType string "voltage"
spectreS.spnoise negNode string "/gnd!"
spectreS.spnoise posNode string ""
spectreS.spnoise outVsrc string ""
spectreS.spnoise inNoiseType string "none"
spectreS.spnoise inVsrc string ""
spectreS.spnoise inIsrc string ""
spectreS.spnoise inPort string ""
spectreS.spnoise refsideband string ""
;spectreS spnoiseOpts partition variables
spectreS.spnoiseOpts tolerance3 string ""
spectreS.spnoiseOpts gearorder3 string ""
spectreS.spnoiseOpts solver3 string ""
spectreS.spnoiseOpts stats4 string ""
spectreS.spnoiseOpts annotate4 string "status"
;spectreS spxf partition variables
spectreS.spxf enable toggle (nil)
spectreS.spxf fund string ""
spectreS.spxf Relative boolean nil
spectreS.spxf sweeptype string ""
spectreS.spxf harmonics string "Zero sideband only"
spectreS.spxf numharmonics string ""
spectreS.spxf arrayharmonics string ""
spectreS.spxf selFreqFrom string ""
spectreS.spxf selFreqTo string ""
spectreS.spxf harmsAndFreqsTitle string ""
spectreS.spxf harmsAndFreqs string ""
spectreS.spxf outType string "voltage"
spectreS.spxf negNode string "/gnd!"
spectreS.spxf posNode string ""
spectreS.spxf outVsrc string ""
;spectreS spxfOpts partition variables
spectreS.spxfOpts tolerance2 string ""
spectreS.spxfOpts gearorder2 string ""
spectreS.spxfOpts solver2 string ""
spectreS.spxfOpts stats3 string ""
spectreS.spxfOpts annotate3 string "status"
spectreS.spxfOpts stimuli string ""
spectreS.spxfOpts freqaxis2 string ""
;spectreS pac partition variables
spectreS.pac enable toggle (nil)
spectreS.pac fund string ""
spectreS.pac Relative boolean nil
spectreS.pac sweeptype string ""
spectreS.pac rangeType string "Start-Stop"
spectreS.pac from string ""
spectreS.pac to string ""
spectreS.pac center string ""
spectreS.pac span string ""
spectreS.pac incrType string "Automatic"
spectreS.pac stepTypeLin string "Step Size"
spectreS.pac stepTypeLog string "Points Per Decade"
spectreS.pac by string ""
spectreS.pac lin string ""
spectreS.pac dec string ""
spectreS.pac log string ""
spectreS.pac useDiscrete boolean nil
spectreS.pac values string ""
spectreS.pac harmonics string "Zero sideband only"
spectreS.pac numharmonics string ""
spectreS.pac arrayharmonics string ""
spectreS.pac selFreqFrom string ""
spectreS.pac selFreqTo string ""
spectreS.pac harmsAndFreqsTitle string ""
spectreS.pac harmsAndFreqs string ""
;spectreS pacOpts partition variables
spectreS.pacOpts tolerance string ""
spectreS.pacOpts gearorder string ""
spectreS.pacOpts solver string ""
spectreS.pacOpts stats2 string ""
spectreS.pacOpts annotate2 string "status"
spectreS.pacOpts freqaxis string ""
;spectreS pnoise partition variables
spectreS.pnoise enable toggle (nil)
spectreS.pnoise fund string ""
spectreS.pnoise Relative boolean nil
spectreS.pnoise sweeptype string ""
spectreS.pnoise rangeType string "Start-Stop"
spectreS.pnoise from string ""
spectreS.pnoise to string ""
spectreS.pnoise center string ""
spectreS.pnoise span string ""
spectreS.pnoise incrType string "Automatic"
spectreS.pnoise stepTypeLin string "Step Size"
spectreS.pnoise stepTypeLog string "Points Per Decade"
spectreS.pnoise by string ""
spectreS.pnoise lin string ""
spectreS.pnoise dec string ""
spectreS.pnoise log string ""
spectreS.pnoise useDiscrete boolean nil
spectreS.pnoise values string ""
spectreS.pnoise harmonics string "Zero sideband only"
spectreS.pnoise numharmonics string ""
spectreS.pnoise arrayharmonics string ""
spectreS.pnoise selFreqFrom string ""
spectreS.pnoise selFreqTo string ""
spectreS.pnoise harmsAndFreqsTitle string ""
spectreS.pnoise harmsAndFreqs string ""
spectreS.pnoise outType string "voltage"
spectreS.pnoise negNode string "/gnd!"
spectreS.pnoise posNode string ""
spectreS.pnoise outVsrc string ""
spectreS.pnoise inNoiseType string "none"
spectreS.pnoise inVsrc string ""
spectreS.pnoise inIsrc string ""
spectreS.pnoise inPort string ""
spectreS.pnoise refsideband string ""
;spectreS pnoiseOpts partition variables
spectreS.pnoiseOpts tolerance3 string ""
spectreS.pnoiseOpts gearorder3 string ""
spectreS.pnoiseOpts solver3 string ""
spectreS.pnoiseOpts stats4 string ""
spectreS.pnoiseOpts annotate4 string "status"
;spectreS pxf partition variables
spectreS.pxf enable toggle (nil)
spectreS.pxf fund string ""
spectreS.pxf Relative boolean nil
spectreS.pxf sweeptype string ""
spectreS.pxf rangeType string "Start-Stop"
spectreS.pxf from string ""
spectreS.pxf to string ""
spectreS.pxf center string ""
spectreS.pxf span string ""
spectreS.pxf incrType string "Automatic"
spectreS.pxf stepTypeLin string "Step Size"
spectreS.pxf stepTypeLog string "Points Per Decade"
spectreS.pxf by string ""
spectreS.pxf lin string ""
spectreS.pxf dec string ""
spectreS.pxf log string ""
spectreS.pxf useDiscrete boolean nil
spectreS.pxf values string ""
spectreS.pxf harmonics string "Zero sideband only"
spectreS.pxf numharmonics string ""
spectreS.pxf arrayharmonics string ""
spectreS.pxf selFreqFrom string ""
spectreS.pxf selFreqTo string ""
spectreS.pxf harmsAndFreqsTitle string ""
spectreS.pxf harmsAndFreqs string ""
spectreS.pxf outType string "voltage"
spectreS.pxf negNode string "/gnd!"
spectreS.pxf posNode string ""
spectreS.pxf outVsrc string ""
;spectreS pxfOpts partition variables
spectreS.pxfOpts tolerance2 string ""
spectreS.pxfOpts gearorder2 string ""
spectreS.pxfOpts solver2 string ""
spectreS.pxfOpts stats3 string ""
spectreS.pxfOpts annotate3 string "status"
spectreS.pxfOpts stimuli string ""
spectreS.pxfOpts freqaxis2 string ""
;spectreSVerilog environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spectreSVerilog opts partition variables
spectreSVerilog.opts title string ""
spectreSVerilog.opts audit string ""
spectreSVerilog.opts ckptclock string "1800"
spectreSVerilog.opts flow string ""
spectreSVerilog.opts cols string "80"
spectreSVerilog.opts opptcheck string ""
spectreSVerilog.opts reltol string "1e-3"
spectreSVerilog.opts notation string ""
spectreSVerilog.opts warn string ""
spectreSVerilog.opts approx string ""
spectreSVerilog.opts info string ""
spectreSVerilog.opts quantities string ""
spectreSVerilog.opts pivabs string ""
spectreSVerilog.opts compatible string ""
spectreSVerilog.opts ignshorts string ""
spectreSVerilog.opts gmin string "1e-12"
spectreSVerilog.opts rforce string "1"
spectreSVerilog.opts homotopy string ""
spectreSVerilog.opts iabstol string "1e-12"
spectreSVerilog.opts debug string ""
spectreSVerilog.opts tempeffects string ""
spectreSVerilog.opts maxwarns string "5"
spectreSVerilog.opts vabstol string "1e-6"
spectreSVerilog.opts tnom string "27"
spectreSVerilog.opts temp string "27"
spectreSVerilog.opts gmin_check string ""
spectreSVerilog.opts value string ""
spectreSVerilog.opts narrate string ""
spectreSVerilog.opts scale string "1.0"
spectreSVerilog.opts diagnose string ""
spectreSVerilog.opts digits string "5"
spectreSVerilog.opts pivotdc string ""
spectreSVerilog.opts pivrel string "1e-3"
spectreSVerilog.opts scalem string "1.0"
spectreSVerilog.opts limit string ""
spectreSVerilog.opts topcheck string ""
spectreSVerilog.opts inventory string ""
spectreSVerilog.opts error string ""
;spectreSVerilog outputs partition variables
spectreSVerilog.outputs allAnalogACTC boolean nil
spectreSVerilog.outputs allDigitalNV boolean t
spectreSVerilog.outputs allAnalogNV boolean t
spectreSVerilog.outputs allAhdlVars boolean nil
spectreSVerilog.outputs allAnalogTC boolean nil
;spectreSVerilog verimixOpts partition variables
spectreSVerilog.verimixOpts filename6 string ""
spectreSVerilog.verimixOpts maxDCIter int 0
spectreSVerilog.verimixOpts scope1 string ""
spectreSVerilog.verimixOpts scope10 string ""
spectreSVerilog.verimixOpts filename8 string ""
spectreSVerilog.verimixOpts dcInterval float 0.0
spectreSVerilog.verimixOpts scope3 string ""
spectreSVerilog.verimixOpts scope8 string ""
spectreSVerilog.verimixOpts scope7 string ""
spectreSVerilog.verimixOpts filename7 string ""
spectreSVerilog.verimixOpts scope string ""
spectreSVerilog.verimixOpts filename4 string ""
spectreSVerilog.verimixOpts filename string ""
spectreSVerilog.verimixOpts filename1 string ""
spectreSVerilog.verimixOpts scope9 string ""
spectreSVerilog.verimixOpts importsdfswitch boolean nil
spectreSVerilog.verimixOpts filename2 string ""
spectreSVerilog.verimixOpts numberofsdffiles int 2
spectreSVerilog.verimixOpts scope2 string ""
spectreSVerilog.verimixOpts scope6 string ""
spectreSVerilog.verimixOpts filename10 string ""
spectreSVerilog.verimixOpts delaymodechoice string "Ignore"
spectreSVerilog.verimixOpts sdfmixedswitch boolean t
spectreSVerilog.verimixOpts filename9 string ""
spectreSVerilog.verimixOpts scope5 string ""
spectreSVerilog.verimixOpts filename5 string ""
spectreSVerilog.verimixOpts filename3 string ""
spectreSVerilog.verimixOpts scope4 string ""
;spectreSVerilog verilogOpts partition variables
spectreSVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
spectreSVerilog.verilogOpts optionsFile string ""
spectreSVerilog.verilogOpts twinTurbo boolean nil
spectreSVerilog.verilogOpts suppressMessages boolean nil
spectreSVerilog.verilogOpts libraryFile string ""
spectreSVerilog.verilogOpts behaveProfile boolean nil
spectreSVerilog.verilogOpts verimixLog string "verilog.log"
spectreSVerilog.verilogOpts simVision boolean nil
spectreSVerilog.verilogOpts pulseSpec boolean nil
spectreSVerilog.verilogOpts commandFile string ""
spectreSVerilog.verilogOpts pulseError int 100
spectreSVerilog.verilogOpts stopCompile boolean nil
spectreSVerilog.verilogOpts keepNodes string "Minimum"
spectreSVerilog.verilogOpts accelerationCA boolean nil
spectreSVerilog.verilogOpts turboRadio string "Default"
spectreSVerilog.verilogOpts libraryDir string ""
spectreSVerilog.verilogOpts suppressWarnings boolean nil
spectreSVerilog.verilogOpts accelerationSwitches boolean nil
spectreSVerilog.verilogOpts accelerationNormal boolean t
spectreSVerilog.verilogOpts delayType string "Typical"
spectreSVerilog.verilogOpts pulseReject int 100
spectreSVerilog.verilogOpts delayMode string "Default"
spectreSVerilog.verilogOpts vermixBinary string "verilog.vmx"
;spectreSVerilog init partition variables
spectreSVerilog.init processPriority int 0
;spectreSVerilog envOpts partition variables
spectreSVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreSVerilog.envOpts mspNetlistMode string "Flat"
spectreSVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
spectreSVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
spectreSVerilog.envOpts outputFormat string "AWD"
spectreSVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
spectreSVerilog.envOpts mspSetupNetlistEscapeName boolean nil
spectreSVerilog.envOpts updateFile string ""
spectreSVerilog.envOpts stimulusFile string ""
spectreSVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
spectreSVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
spectreSVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
spectreSVerilog.envOpts includeSyntax string "cdsSpice"
spectreSVerilog.envOpts mspSetupNetlistPinMap boolean nil
spectreSVerilog.envOpts mspSetupNetlistBus boolean t
spectreSVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
spectreSVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
spectreSVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
spectreSVerilog.envOpts mspSetupNetlistExplicit boolean nil
spectreSVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
spectreSVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
spectreSVerilog.envOpts paramRangeCheckFile string ""
spectreSVerilog.envOpts initFile string ""
spectreSVerilog.envOpts printComments boolean nil
spectreSVerilog.envOpts includeFile string ""
spectreSVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
spectreSVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
spectreSVerilog.envOpts recover boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreSVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimTimeValue int 1
spectreSVerilog.envOpts mspSetupNetlistUseLib boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
spectreSVerilog.envOpts mspSetupNetlistNullPort boolean nil
spectreSVerilog.envOpts mspSetupNetlistDropPortRange boolean t
spectreSVerilog.envOpts mspSetupNetlistUpCase boolean nil
spectreSVerilog.envOpts generateMapFile boolean nil
spectreSVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;spectreSVerilog tran partition variables
spectreSVerilog.tran enable toggle (nil)
spectreSVerilog.tran to string ""
spectreSVerilog.tran errpreset string ""
;spectreSVerilog tranOpts partition variables
spectreSVerilog.tranOpts start string ""
spectreSVerilog.tranOpts outputstart string ""
spectreSVerilog.tranOpts step string ""
spectreSVerilog.tranOpts maxstep string ""
spectreSVerilog.tranOpts ic string ""
spectreSVerilog.tranOpts skipdc string ""
spectreSVerilog.tranOpts readic string ""
spectreSVerilog.tranOpts readns string ""
spectreSVerilog.tranOpts cmin string ""
spectreSVerilog.tranOpts write string "spectre.ic"
spectreSVerilog.tranOpts writefinal string "spectre.fc"
spectreSVerilog.tranOpts ckptperiod string ""
spectreSVerilog.tranOpts method string "default"
spectreSVerilog.tranOpts relref string "default"
spectreSVerilog.tranOpts lteratio string ""
spectreSVerilog.tranOpts stats string ""
spectreSVerilog.tranOpts annotate string "status"
spectreSVerilog.tranOpts oppoint string ""
spectreSVerilog.tranOpts skipstart string ""
spectreSVerilog.tranOpts skipstop string ""
spectreSVerilog.tranOpts skipcount string ""
spectreSVerilog.tranOpts strobeperiod string ""
spectreSVerilog.tranOpts strobedelay string ""
spectreSVerilog.tranOpts compression string "no"
spectreSVerilog.tranOpts maxiters string "5"
spectreSVerilog.tranOpts restart string ""
;spectreSVerilog ac partition variables
spectreSVerilog.ac enable toggle (nil)
spectreSVerilog.ac sweep string "Frequency"
spectreSVerilog.ac freq string ""
spectreSVerilog.ac device string ""
spectreSVerilog.ac deviceParam string ""
spectreSVerilog.ac model string ""
spectreSVerilog.ac modelParam string ""
spectreSVerilog.ac temperature string "temp"
spectreSVerilog.ac rangeType string "Start-Stop"
spectreSVerilog.ac from string ""
spectreSVerilog.ac to string ""
spectreSVerilog.ac center string ""
spectreSVerilog.ac span string ""
spectreSVerilog.ac incrType string "Automatic"
spectreSVerilog.ac stepTypeLin string "Step Size"
spectreSVerilog.ac stepTypeLog string "Points Per Decade"
spectreSVerilog.ac by string ""
spectreSVerilog.ac lin string ""
spectreSVerilog.ac dec string ""
spectreSVerilog.ac log string ""
spectreSVerilog.ac useDiscrete boolean nil
spectreSVerilog.ac values string ""
;spectreSVerilog acOpts partition variables
spectreSVerilog.acOpts readns string ""
spectreSVerilog.acOpts oppoint string ""
spectreSVerilog.acOpts restart string ""
spectreSVerilog.acOpts annotate string "status"
spectreSVerilog.acOpts stats string ""
;spectreSVerilog dc partition variables
spectreSVerilog.dc enable toggle (nil)
spectreSVerilog.dcop enable toggle (nil)
spectreSVerilog.dc saveOppoint boolean nil
spectreSVerilog.dc oppoint string "rawfile"
spectreSVerilog.dc save string "allpub"
spectreSVerilog.dc sweep string ""
spectreSVerilog.dc device string ""
spectreSVerilog.dc deviceParam string ""
spectreSVerilog.dc model string ""
spectreSVerilog.dc modelParam string ""
spectreSVerilog.dc temperature string "temp"
spectreSVerilog.dc rangeType string "Start-Stop"
spectreSVerilog.dc from string ""
spectreSVerilog.dc to string ""
spectreSVerilog.dc center string ""
spectreSVerilog.dc span string ""
spectreSVerilog.dc incrType string "Automatic"
spectreSVerilog.dc stepTypeLin string "Step Size"
spectreSVerilog.dc stepTypeLog string "Points Per Decade"
spectreSVerilog.dc by string ""
spectreSVerilog.dc lin string ""
spectreSVerilog.dc dec string ""
spectreSVerilog.dc log string ""
spectreSVerilog.dc useDiscrete boolean nil
spectreSVerilog.dc values string ""
;spectreSVerilog dcOpts partition variables
spectreSVerilog.dcOpts force string ""
spectreSVerilog.dcopOpts force string ""
spectreSVerilog.dcOpts readns string ""
spectreSVerilog.dcopOpts readns string ""
spectreSVerilog.dcOpts readforce string ""
spectreSVerilog.dcopOpts readforce string ""
spectreSVerilog.dcOpts write string "spectre.dc"
spectreSVerilog.dcopOpts write string "spectre.dc"
spectreSVerilog.dcOpts writefinal string ""
spectreSVerilog.dcopOpts writefinal string ""
spectreSVerilog.dcOpts print string ""
spectreSVerilog.dcopOpts print string ""
spectreSVerilog.dcOpts check string ""
spectreSVerilog.dcopOpts check string ""
spectreSVerilog.dcOpts homotopy string ""
spectreSVerilog.dcopOpts homotopy string ""
spectreSVerilog.dcOpts restart string ""
spectreSVerilog.dcopOpts restart string ""
spectreSVerilog.dcOpts maxiters string "150"
spectreSVerilog.dcopOpts maxiters string "150"
spectreSVerilog.dcOpts maxsteps string "10000"
spectreSVerilog.dcopOpts maxsteps string "10000"
spectreSVerilog.dcOpts annotate string "status"
spectreSVerilog.dcopOpts annotate string "status"
;spectreSVerilog noise partition variables
spectreSVerilog.noise enable toggle (nil)
spectreSVerilog.noise sweep string "Frequency"
spectreSVerilog.noise freq string ""
spectreSVerilog.noise device string ""
spectreSVerilog.noise deviceParam string ""
spectreSVerilog.noise model string ""
spectreSVerilog.noise modelParam string ""
spectreSVerilog.noise temperature string "temp"
spectreSVerilog.noise rangeType string "Start-Stop"
spectreSVerilog.noise from string ""
spectreSVerilog.noise to string ""
spectreSVerilog.noise center string ""
spectreSVerilog.noise span string ""
spectreSVerilog.noise incrType string "Automatic"
spectreSVerilog.noise stepTypeLin string "Step Size"
spectreSVerilog.noise stepTypeLog string "Points Per Decade"
spectreSVerilog.noise by string ""
spectreSVerilog.noise lin string ""
spectreSVerilog.noise dec string ""
spectreSVerilog.noise log string ""
spectreSVerilog.noise useDiscrete boolean nil
spectreSVerilog.noise values string ""
spectreSVerilog.noise outNoiseType string "voltage"
spectreSVerilog.noise negNode string "/gnd!"
spectreSVerilog.noise posNode string ""
spectreSVerilog.noise outVsrc string ""
spectreSVerilog.noise inNoiseType string "voltage"
spectreSVerilog.noise inVsrc string ""
spectreSVerilog.noise inIsrc string ""
spectreSVerilog.noise inPort string ""
;spectreSVerilog noiseOpts partition variables
spectreSVerilog.noiseOpts readns string ""
spectreSVerilog.noiseOpts oppoint string ""
spectreSVerilog.noiseOpts restart string ""
spectreSVerilog.noiseOpts annotate string "status"
spectreSVerilog.noiseOpts stats string ""
;spectreSVerilog xf partition variables
spectreSVerilog.xf enable toggle (nil)
spectreSVerilog.xf sweep string "Frequency"
spectreSVerilog.xf freq string ""
spectreSVerilog.xf device string ""
spectreSVerilog.xf deviceParam string ""
spectreSVerilog.xf model string ""
spectreSVerilog.xf modelParam string ""
spectreSVerilog.xf temperature string "temp"
spectreSVerilog.xf rangeType string "Start-Stop"
spectreSVerilog.xf from string ""
spectreSVerilog.xf to string ""
spectreSVerilog.xf center string ""
spectreSVerilog.xf span string ""
spectreSVerilog.xf incrType string "Automatic"
spectreSVerilog.xf stepTypeLin string "Step Size"
spectreSVerilog.xf stepTypeLog string "Points Per Decade"
spectreSVerilog.xf by string ""
spectreSVerilog.xf lin string ""
spectreSVerilog.xf dec string ""
spectreSVerilog.xf log string ""
spectreSVerilog.xf useDiscrete boolean nil
spectreSVerilog.xf values string ""
spectreSVerilog.xf outXfType string "voltage"
spectreSVerilog.xf negNode string "/gnd!"
spectreSVerilog.xf posNode string ""
spectreSVerilog.xf outVsrc string ""
;spectreSVerilog xfOpts partition variables
spectreSVerilog.xfOpts readns string ""
spectreSVerilog.xfOpts stimuli string ""
spectreSVerilog.xfOpts oppoint string ""
spectreSVerilog.xfOpts restart string ""
spectreSVerilog.xfOpts annotate string "status"
spectreSVerilog.xfOpts stats string ""
;spectreSVerilog sp partition variables
spectreSVerilog.sp enable toggle (nil)
spectreSVerilog.sp sweep string "Frequency"
spectreSVerilog.sp frequency string ""
spectreSVerilog.sp device string ""
spectreSVerilog.sp deviceParam string ""
spectreSVerilog.sp model string ""
spectreSVerilog.sp modelParam string ""
spectreSVerilog.sp temperature string "temp"
spectreSVerilog.sp rangeType string "Start-Stop"
spectreSVerilog.sp from string ""
spectreSVerilog.sp to string ""
spectreSVerilog.sp center string ""
spectreSVerilog.sp span string ""
spectreSVerilog.sp incrType string "Automatic"
spectreSVerilog.sp stepTypeLin string "Step Size"
spectreSVerilog.sp stepTypeLog string "Points Per Decade"
spectreSVerilog.sp by string ""
spectreSVerilog.sp lin string ""
spectreSVerilog.sp dec string ""
spectreSVerilog.sp log string ""
spectreSVerilog.sp useDiscrete boolean nil
spectreSVerilog.sp values string ""
spectreSVerilog.sp donoise boolean nil
spectreSVerilog.sp oprobe string ""
spectreSVerilog.sp iprobe string ""
;spectreSVerilog spOpts partition variables
spectreSVerilog.spOpts readns string ""
spectreSVerilog.spOpts file string ""
spectreSVerilog.spOpts oppoint string ""
spectreSVerilog.spOpts reftemp string ""
spectreSVerilog.spOpts restart string ""
spectreSVerilog.spOpts annotate string "status"
spectreSVerilog.spOpts stats string ""
;spectreSVerilog spss partition variables
spectreSVerilog.spss enable toggle (nil)
spectreSVerilog.spss paramListBox string ""
spectreSVerilog.spss fundListBox string ""
spectreSVerilog.spss stimName string ""
spectreSVerilog.spss freqName string ""
spectreSVerilog.spss freqVal string ""
spectreSVerilog.spss signalLevel string "Moderate"
spectreSVerilog.spss srcId string ""
spectreSVerilog.spss maxHarms string ""
spectreSVerilog.spss freqPeriod string "Fundamental (Beat) Frequency"
spectreSVerilog.spss fund string ""
spectreSVerilog.spss period string ""
spectreSVerilog.spss harmonics string "None"
spectreSVerilog.spss numharmonics string ""
spectreSVerilog.spss arrayharmonics string ""
spectreSVerilog.spss none string "0"
spectreSVerilog.spss selFreqFrom string ""
spectreSVerilog.spss selFreqTo string ""
spectreSVerilog.spss harmsAndFreqsTitle string ""
spectreSVerilog.spss harmsAndFreqs string ""
spectreSVerilog.spss errpreset string ""
spectreSVerilog.spss tstab string ""
spectreSVerilog.spss saveinit string ""
spectreSVerilog.spss oscana boolean nil
spectreSVerilog.spss oscRefNode string "/gnd!"
spectreSVerilog.spss oscNode string ""
spectreSVerilog.spss sweep string "frequency/period"
spectreSVerilog.spss designVar string ""
spectreSVerilog.spss rangeType string "Start-Stop"
spectreSVerilog.spss from string ""
spectreSVerilog.spss to string ""
spectreSVerilog.spss center string ""
spectreSVerilog.spss span string ""
spectreSVerilog.spss incrType string "Linear"
spectreSVerilog.spss stepTypeLin string "Step Size"
spectreSVerilog.spss stepTypeLog string "Points Per Decade"
spectreSVerilog.spss by string ""
spectreSVerilog.spss lin string ""
spectreSVerilog.spss dec string ""
spectreSVerilog.spss log string ""
spectreSVerilog.spss useDiscrete boolean nil
spectreSVerilog.spss values string ""
spectreSVerilog.spss analysisList string ""
spectreSVerilog.spss pacEnable boolean nil
spectreSVerilog.spss pacfund string ""
spectreSVerilog.spss pacRelative boolean nil
spectreSVerilog.spss pacsweeptype string ""
spectreSVerilog.spss pacharmonics string "Zero sideband only"
spectreSVerilog.spss pacnumharmonics string ""
spectreSVerilog.spss pacarrayharmonics string ""
spectreSVerilog.spss pacselFreqFrom string ""
spectreSVerilog.spss pacselFreqTo string ""
spectreSVerilog.spss pacharmsAndFreqsTitle string ""
spectreSVerilog.spss pacharmsAndFreqs string ""
spectreSVerilog.spss pnoiseEnable boolean nil
spectreSVerilog.spss pnoisefund string ""
spectreSVerilog.spss pnoiseRelative boolean nil
spectreSVerilog.spss pnoisesweeptype string ""
spectreSVerilog.spss pnoiseharmonics string "Zero sideband only"
spectreSVerilog.spss pnoisenumharmonics string ""
spectreSVerilog.spss pnoisearrayharmonics string ""
spectreSVerilog.spss pnoiseselFreqFrom string ""
spectreSVerilog.spss pnoiseselFreqTo string ""
spectreSVerilog.spss pnoiseharmsAndFreqsTitle string ""
spectreSVerilog.spss pnoiseharmsAndFreqs string ""
spectreSVerilog.spss pnoiseoutProbeType string "voltage"
spectreSVerilog.spss pnoisenegNode string "/gnd!"
spectreSVerilog.spss pnoiseposNode string ""
spectreSVerilog.spss pnoiseoutVsrc string ""
spectreSVerilog.spss pnoiseinNoiseType string "none"
spectreSVerilog.spss pnoiseinVsrc string ""
spectreSVerilog.spss pnoiseinIsrc string ""
spectreSVerilog.spss pnoiseinPort string ""
spectreSVerilog.spss pnoiserefsideband string ""
spectreSVerilog.spss pxfEnable boolean nil
spectreSVerilog.spss pxffund string ""
spectreSVerilog.spss pxfRelative boolean nil
spectreSVerilog.spss pxfsweeptype string ""
spectreSVerilog.spss pxfharmonics string "Zero sideband only"
spectreSVerilog.spss pxfnumharmonics string ""
spectreSVerilog.spss pxfarrayharmonics string ""
spectreSVerilog.spss pxfselFreqFrom string ""
spectreSVerilog.spss pxfselFreqTo string ""
spectreSVerilog.spss pxfharmsAndFreqsTitle string ""
spectreSVerilog.spss pxfharmsAndFreqs string ""
spectreSVerilog.spss pxfoutProbeType string "voltage"
spectreSVerilog.spss pxfnegNode string "/gnd!"
spectreSVerilog.spss pxfposNode string ""
spectreSVerilog.spss pxfoutVsrc string ""
;spectreSVerilog spssOpts partition variables
spectreSVerilog.spssOpts step string ""
spectreSVerilog.spssOpts maxstep string ""
spectreSVerilog.spssOpts ic string ""
spectreSVerilog.spssOpts skipdc string ""
spectreSVerilog.spssOpts readic string ""
spectreSVerilog.spssOpts readns string ""
spectreSVerilog.spssOpts cmin string ""
spectreSVerilog.spssOpts write string ""
spectreSVerilog.spssOpts writefinal string ""
spectreSVerilog.spssOpts swapfile string ""
spectreSVerilog.spssOpts method string ""
spectreSVerilog.spssOpts relref string ""
spectreSVerilog.spssOpts lteratio string ""
spectreSVerilog.spssOpts steadyratio string ""
spectreSVerilog.spssOpts maxacfreq string ""
spectreSVerilog.spssOpts maxperiods string ""
spectreSVerilog.spssOpts stats string ""
spectreSVerilog.spssOpts annotate string "status"
spectreSVerilog.spssOpts oppoint string ""
spectreSVerilog.spssOpts skipstart string ""
spectreSVerilog.spssOpts skipstop string ""
spectreSVerilog.spssOpts skipcount string ""
spectreSVerilog.spssOpts strobeperiod string ""
spectreSVerilog.spssOpts strobedelay string ""
spectreSVerilog.spssOpts compression string ""
spectreSVerilog.spssOpts maxiters string ""
spectreSVerilog.spssOpts restart string ""
spectreSVerilog.spssOpts tstart string ""
spectreSVerilog.spssOpts tolerance string ""
spectreSVerilog.spssOpts gearorder string ""
spectreSVerilog.spssOpts solver string ""
spectreSVerilog.spssOpts stats2 string ""
spectreSVerilog.spssOpts annotate2 string "status"
spectreSVerilog.spssOpts freqaxis string ""
spectreSVerilog.spssOpts tolerance2 string ""
spectreSVerilog.spssOpts gearorder2 string ""
spectreSVerilog.spssOpts solver2 string ""
spectreSVerilog.spssOpts stats3 string ""
spectreSVerilog.spssOpts annotate3 string "status"
spectreSVerilog.spssOpts stimuli string ""
spectreSVerilog.spssOpts freqaxis2 string ""
spectreSVerilog.spssOpts tolerance3 string ""
spectreSVerilog.spssOpts gearorder3 string ""
spectreSVerilog.spssOpts solver3 string ""
spectreSVerilog.spssOpts stats4 string ""
spectreSVerilog.spssOpts annotate4 string "status"
;spectreSVerilog pss partition variables
spectreSVerilog.pss enable toggle (nil)
spectreSVerilog.pss paramListBox string ""
spectreSVerilog.pss fundListBox string ""
spectreSVerilog.pss stimName string ""
spectreSVerilog.pss freqName string ""
spectreSVerilog.pss freqVal string ""
spectreSVerilog.pss signalLevel string "Moderate"
spectreSVerilog.pss srcId string ""
spectreSVerilog.pss maxHarms string ""
spectreSVerilog.pss freqPeriod string "Fundamental (Beat) Frequency"
spectreSVerilog.pss fund string ""
spectreSVerilog.pss period string ""
spectreSVerilog.pss harmonics string "None"
spectreSVerilog.pss numharmonics string ""
spectreSVerilog.pss arrayharmonics string ""
spectreSVerilog.pss none string "0"
spectreSVerilog.pss selFreqFrom string ""
spectreSVerilog.pss selFreqTo string ""
spectreSVerilog.pss harmsAndFreqsTitle string ""
spectreSVerilog.pss harmsAndFreqs string ""
spectreSVerilog.pss errpreset string ""
spectreSVerilog.pss tstab string ""
spectreSVerilog.pss saveinit string ""
spectreSVerilog.pss oscana boolean nil
spectreSVerilog.pss oscRefNode string "/gnd!"
spectreSVerilog.pss oscNode string ""
spectreSVerilog.pss analysisList string ""
spectreSVerilog.pss pacEnable boolean nil
spectreSVerilog.pss pacRelative boolean nil
spectreSVerilog.pss pacsweeptype string ""
spectreSVerilog.pss pacrangeType string "Start-Stop"
spectreSVerilog.pss pacfrom string ""
spectreSVerilog.pss pacto string ""
spectreSVerilog.pss paccenter string ""
spectreSVerilog.pss pacspan string ""
spectreSVerilog.pss pacincrType string "Automatic"
spectreSVerilog.pss pacstepTypeLin string "Step Size"
spectreSVerilog.pss pacstepTypeLog string "Points Per Decade"
spectreSVerilog.pss pacby string ""
spectreSVerilog.pss paclin string ""
spectreSVerilog.pss pacdec string ""
spectreSVerilog.pss paclog string ""
spectreSVerilog.pss pacuseDiscrete boolean nil
spectreSVerilog.pss pacvalues string ""
spectreSVerilog.pss pacharmonics string "Zero sideband only"
spectreSVerilog.pss pacnumharmonics string ""
spectreSVerilog.pss pacarrayharmonics string ""
spectreSVerilog.pss pacselFreqFrom string ""
spectreSVerilog.pss pacselFreqTo string ""
spectreSVerilog.pss pacharmsAndFreqsTitle string ""
spectreSVerilog.pss pacharmsAndFreqs string ""
spectreSVerilog.pss pnoiseEnable boolean nil
spectreSVerilog.pss pnoiseRelative boolean nil
spectreSVerilog.pss pnoisesweeptype string ""
spectreSVerilog.pss pnoiserangeType string "Start-Stop"
spectreSVerilog.pss pnoisefrom string ""
spectreSVerilog.pss pnoiseto string ""
spectreSVerilog.pss pnoisecenter string ""
spectreSVerilog.pss pnoisespan string ""
spectreSVerilog.pss pnoiseincrType string "Automatic"
spectreSVerilog.pss pnoisestepTypeLin string "Step Size"
spectreSVerilog.pss pnoisestepTypeLog string "Points Per Decade"
spectreSVerilog.pss pnoiseby string ""
spectreSVerilog.pss pnoiselin string ""
spectreSVerilog.pss pnoisedec string ""
spectreSVerilog.pss pnoiselog string ""
spectreSVerilog.pss pnoiseuseDiscrete boolean nil
spectreSVerilog.pss pnoisevalues string ""
spectreSVerilog.pss pnoiseharmonics string "Zero sideband only"
spectreSVerilog.pss pnoisenumharmonics string ""
spectreSVerilog.pss pnoisearrayharmonics string ""
spectreSVerilog.pss pnoiseselFreqFrom string ""
spectreSVerilog.pss pnoiseselFreqTo string ""
spectreSVerilog.pss pnoiseharmsAndFreqsTitle string ""
spectreSVerilog.pss pnoiseharmsAndFreqs string ""
spectreSVerilog.pss pnoiseoutProbeType string "voltage"
spectreSVerilog.pss pnoisenegNode string "/gnd!"
spectreSVerilog.pss pnoiseposNode string ""
spectreSVerilog.pss pnoiseoutVsrc string ""
spectreSVerilog.pss pnoiseinNoiseType string "none"
spectreSVerilog.pss pnoiseinVsrc string ""
spectreSVerilog.pss pnoiseinIsrc string ""
spectreSVerilog.pss pnoiseinPort string ""
spectreSVerilog.pss pnoiserefsideband string ""
spectreSVerilog.pss pxfEnable boolean nil
spectreSVerilog.pss pxfRelative boolean nil
spectreSVerilog.pss pxfsweeptype string ""
spectreSVerilog.pss pxfrangeType string "Start-Stop"
spectreSVerilog.pss pxffrom string ""
spectreSVerilog.pss pxfto string ""
spectreSVerilog.pss pxfcenter string ""
spectreSVerilog.pss pxfspan string ""
spectreSVerilog.pss pxfincrType string "Automatic"
spectreSVerilog.pss pxfstepTypeLin string "Step Size"
spectreSVerilog.pss pxfstepTypeLog string "Points Per Decade"
spectreSVerilog.pss pxfby string ""
spectreSVerilog.pss pxflin string ""
spectreSVerilog.pss pxfdec string ""
spectreSVerilog.pss pxflog string ""
spectreSVerilog.pss pxfuseDiscrete boolean nil
spectreSVerilog.pss pxfvalues string ""
spectreSVerilog.pss pxfharmonics string "Zero sideband only"
spectreSVerilog.pss pxfnumharmonics string ""
spectreSVerilog.pss pxfarrayharmonics string ""
spectreSVerilog.pss pxfselFreqFrom string ""
spectreSVerilog.pss pxfselFreqTo string ""
spectreSVerilog.pss pxfharmsAndFreqsTitle string ""
spectreSVerilog.pss pxfharmsAndFreqs string ""
spectreSVerilog.pss pxfoutProbeType string "voltage"
spectreSVerilog.pss pxfnegNode string "/gnd!"
spectreSVerilog.pss pxfposNode string ""
spectreSVerilog.pss pxfoutVsrc string ""
;spectreSVerilog pssOpts partition variables
spectreSVerilog.pssOpts step string ""
spectreSVerilog.pssOpts maxstep string ""
spectreSVerilog.pssOpts ic string ""
spectreSVerilog.pssOpts skipdc string ""
spectreSVerilog.pssOpts readic string ""
spectreSVerilog.pssOpts readns string ""
spectreSVerilog.pssOpts cmin string ""
spectreSVerilog.pssOpts write string ""
spectreSVerilog.pssOpts writefinal string ""
spectreSVerilog.pssOpts swapfile string ""
spectreSVerilog.pssOpts method string ""
spectreSVerilog.pssOpts relref string ""
spectreSVerilog.pssOpts lteratio string ""
spectreSVerilog.pssOpts steadyratio string ""
spectreSVerilog.pssOpts maxacfreq string ""
spectreSVerilog.pssOpts maxperiods string ""
spectreSVerilog.pssOpts stats string ""
spectreSVerilog.pssOpts annotate string "status"
spectreSVerilog.pssOpts oppoint string ""
spectreSVerilog.pssOpts skipstart string ""
spectreSVerilog.pssOpts skipstop string ""
spectreSVerilog.pssOpts skipcount string ""
spectreSVerilog.pssOpts strobeperiod string ""
spectreSVerilog.pssOpts strobedelay string ""
spectreSVerilog.pssOpts compression string ""
spectreSVerilog.pssOpts maxiters string ""
spectreSVerilog.pssOpts restart string ""
spectreSVerilog.pssOpts tstart string ""
spectreSVerilog.pssOpts tolerance string ""
spectreSVerilog.pssOpts gearorder string ""
spectreSVerilog.pssOpts solver string ""
spectreSVerilog.pssOpts stats2 string ""
spectreSVerilog.pssOpts annotate2 string "status"
spectreSVerilog.pssOpts freqaxis string ""
spectreSVerilog.pssOpts tolerance2 string ""
spectreSVerilog.pssOpts gearorder2 string ""
spectreSVerilog.pssOpts solver2 string ""
spectreSVerilog.pssOpts stats3 string ""
spectreSVerilog.pssOpts annotate3 string "status"
spectreSVerilog.pssOpts stimuli string ""
spectreSVerilog.pssOpts freqaxis2 string ""
spectreSVerilog.pssOpts tolerance3 string ""
spectreSVerilog.pssOpts gearorder3 string ""
spectreSVerilog.pssOpts solver3 string ""
spectreSVerilog.pssOpts stats4 string ""
spectreSVerilog.pssOpts annotate4 string "status"
;spectreSVerilog pdisto partition variables
spectreSVerilog.pdisto enable toggle (nil)
spectreSVerilog.pdisto paramListBox string ""
spectreSVerilog.pdisto fundListBox string ""
spectreSVerilog.pdisto stimName string ""
spectreSVerilog.pdisto freqName string ""
spectreSVerilog.pdisto freqVal string ""
spectreSVerilog.pdisto signalLevel string "Moderate"
spectreSVerilog.pdisto srcId string ""
spectreSVerilog.pdisto maxHarms string ""
spectreSVerilog.pdisto fundsList string ""
spectreSVerilog.pdisto maxHarmsList string ""
spectreSVerilog.pdisto errpreset string ""
spectreSVerilog.pdisto tstab string ""
spectreSVerilog.pdisto saveinit string ""
;spectreSVerilog pdistoOpts partition variables
spectreSVerilog.pdistoOpts step string ""
spectreSVerilog.pdistoOpts maxstep string ""
spectreSVerilog.pdistoOpts ic string ""
spectreSVerilog.pdistoOpts skipdc string ""
spectreSVerilog.pdistoOpts readic string ""
spectreSVerilog.pdistoOpts readns string ""
spectreSVerilog.pdistoOpts cmin string ""
spectreSVerilog.pdistoOpts tolerance string ""
spectreSVerilog.pdistoOpts gearorder string ""
spectreSVerilog.pdistoOpts solver string ""
spectreSVerilog.pdistoOpts write string ""
spectreSVerilog.pdistoOpts writefinal string ""
spectreSVerilog.pdistoOpts swapfile string ""
spectreSVerilog.pdistoOpts method string ""
spectreSVerilog.pdistoOpts relref string ""
spectreSVerilog.pdistoOpts lteratio string ""
spectreSVerilog.pdistoOpts steadyratio string ""
spectreSVerilog.pdistoOpts maxacfreq string ""
spectreSVerilog.pdistoOpts maxperiods string ""
spectreSVerilog.pdistoOpts stats string ""
spectreSVerilog.pdistoOpts annotate string "status"
spectreSVerilog.pdistoOpts oppoint string ""
spectreSVerilog.pdistoOpts skipstart string ""
spectreSVerilog.pdistoOpts skipstop string ""
spectreSVerilog.pdistoOpts skipcount string ""
spectreSVerilog.pdistoOpts strobeperiod string ""
spectreSVerilog.pdistoOpts strobedelay string ""
spectreSVerilog.pdistoOpts compression string ""
spectreSVerilog.pdistoOpts freqaxis string ""
spectreSVerilog.pdistoOpts maxiters string ""
spectreSVerilog.pdistoOpts restart string ""
spectreSVerilog.pdistoOpts tstart string ""
;spectreSVerilog spac partition variables
spectreSVerilog.spac enable toggle (nil)
spectreSVerilog.spac fund string ""
spectreSVerilog.spac Relative boolean nil
spectreSVerilog.spac sweeptype string ""
spectreSVerilog.spac harmonics string "Zero sideband only"
spectreSVerilog.spac numharmonics string ""
spectreSVerilog.spac arrayharmonics string ""
spectreSVerilog.spac selFreqFrom string ""
spectreSVerilog.spac selFreqTo string ""
spectreSVerilog.spac harmsAndFreqsTitle string ""
spectreSVerilog.spac harmsAndFreqs string ""
;spectreSVerilog spacOpts partition variables
spectreSVerilog.spacOpts tolerance string ""
spectreSVerilog.spacOpts gearorder string ""
spectreSVerilog.spacOpts solver string ""
spectreSVerilog.spacOpts stats2 string ""
spectreSVerilog.spacOpts annotate2 string "status"
spectreSVerilog.spacOpts freqaxis string ""
;spectreSVerilog spnoise partition variables
spectreSVerilog.spnoise enable toggle (nil)
spectreSVerilog.spnoise fund string ""
spectreSVerilog.spnoise Relative boolean nil
spectreSVerilog.spnoise sweeptype string ""
spectreSVerilog.spnoise harmonics string "Zero sideband only"
spectreSVerilog.spnoise numharmonics string ""
spectreSVerilog.spnoise arrayharmonics string ""
spectreSVerilog.spnoise selFreqFrom string ""
spectreSVerilog.spnoise selFreqTo string ""
spectreSVerilog.spnoise harmsAndFreqsTitle string ""
spectreSVerilog.spnoise harmsAndFreqs string ""
spectreSVerilog.spnoise outType string "voltage"
spectreSVerilog.spnoise negNode string "/gnd!"
spectreSVerilog.spnoise posNode string ""
spectreSVerilog.spnoise outVsrc string ""
spectreSVerilog.spnoise inNoiseType string "none"
spectreSVerilog.spnoise inVsrc string ""
spectreSVerilog.spnoise inIsrc string ""
spectreSVerilog.spnoise inPort string ""
spectreSVerilog.spnoise refsideband string ""
;spectreSVerilog spnoiseOpts partition variables
spectreSVerilog.spnoiseOpts tolerance3 string ""
spectreSVerilog.spnoiseOpts gearorder3 string ""
spectreSVerilog.spnoiseOpts solver3 string ""
spectreSVerilog.spnoiseOpts stats4 string ""
spectreSVerilog.spnoiseOpts annotate4 string "status"
;spectreSVerilog spxf partition variables
spectreSVerilog.spxf enable toggle (nil)
spectreSVerilog.spxf fund string ""
spectreSVerilog.spxf Relative boolean nil
spectreSVerilog.spxf sweeptype string ""
spectreSVerilog.spxf harmonics string "Zero sideband only"
spectreSVerilog.spxf numharmonics string ""
spectreSVerilog.spxf arrayharmonics string ""
spectreSVerilog.spxf selFreqFrom string ""
spectreSVerilog.spxf selFreqTo string ""
spectreSVerilog.spxf harmsAndFreqsTitle string ""
spectreSVerilog.spxf harmsAndFreqs string ""
spectreSVerilog.spxf outType string "voltage"
spectreSVerilog.spxf negNode string "/gnd!"
spectreSVerilog.spxf posNode string ""
spectreSVerilog.spxf outVsrc string ""
;spectreSVerilog spxfOpts partition variables
spectreSVerilog.spxfOpts tolerance2 string ""
spectreSVerilog.spxfOpts gearorder2 string ""
spectreSVerilog.spxfOpts solver2 string ""
spectreSVerilog.spxfOpts stats3 string ""
spectreSVerilog.spxfOpts annotate3 string "status"
spectreSVerilog.spxfOpts stimuli string ""
spectreSVerilog.spxfOpts freqaxis2 string ""
;spectreSVerilog pac partition variables
spectreSVerilog.pac enable toggle (nil)
spectreSVerilog.pac fund string ""
spectreSVerilog.pac Relative boolean nil
spectreSVerilog.pac sweeptype string ""
spectreSVerilog.pac rangeType string "Start-Stop"
spectreSVerilog.pac from string ""
spectreSVerilog.pac to string ""
spectreSVerilog.pac center string ""
spectreSVerilog.pac span string ""
spectreSVerilog.pac incrType string "Automatic"
spectreSVerilog.pac stepTypeLin string "Step Size"
spectreSVerilog.pac stepTypeLog string "Points Per Decade"
spectreSVerilog.pac by string ""
spectreSVerilog.pac lin string ""
spectreSVerilog.pac dec string ""
spectreSVerilog.pac log string ""
spectreSVerilog.pac useDiscrete boolean nil
spectreSVerilog.pac values string ""
spectreSVerilog.pac harmonics string "Zero sideband only"
spectreSVerilog.pac numharmonics string ""
spectreSVerilog.pac arrayharmonics string ""
spectreSVerilog.pac selFreqFrom string ""
spectreSVerilog.pac selFreqTo string ""
spectreSVerilog.pac harmsAndFreqsTitle string ""
spectreSVerilog.pac harmsAndFreqs string ""
;spectreSVerilog pacOpts partition variables
spectreSVerilog.pacOpts tolerance string ""
spectreSVerilog.pacOpts gearorder string ""
spectreSVerilog.pacOpts solver string ""
spectreSVerilog.pacOpts stats2 string ""
spectreSVerilog.pacOpts annotate2 string "status"
spectreSVerilog.pacOpts freqaxis string ""
;spectreSVerilog pnoise partition variables
spectreSVerilog.pnoise enable toggle (nil)
spectreSVerilog.pnoise fund string ""
spectreSVerilog.pnoise Relative boolean nil
spectreSVerilog.pnoise sweeptype string ""
spectreSVerilog.pnoise rangeType string "Start-Stop"
spectreSVerilog.pnoise from string ""
spectreSVerilog.pnoise to string ""
spectreSVerilog.pnoise center string ""
spectreSVerilog.pnoise span string ""
spectreSVerilog.pnoise incrType string "Automatic"
spectreSVerilog.pnoise stepTypeLin string "Step Size"
spectreSVerilog.pnoise stepTypeLog string "Points Per Decade"
spectreSVerilog.pnoise by string ""
spectreSVerilog.pnoise lin string ""
spectreSVerilog.pnoise dec string ""
spectreSVerilog.pnoise log string ""
spectreSVerilog.pnoise useDiscrete boolean nil
spectreSVerilog.pnoise values string ""
spectreSVerilog.pnoise harmonics string "Zero sideband only"
spectreSVerilog.pnoise numharmonics string ""
spectreSVerilog.pnoise arrayharmonics string ""
spectreSVerilog.pnoise selFreqFrom string ""
spectreSVerilog.pnoise selFreqTo string ""
spectreSVerilog.pnoise harmsAndFreqsTitle string ""
spectreSVerilog.pnoise harmsAndFreqs string ""
spectreSVerilog.pnoise outType string "voltage"
spectreSVerilog.pnoise negNode string "/gnd!"
spectreSVerilog.pnoise posNode string ""
spectreSVerilog.pnoise outVsrc string ""
spectreSVerilog.pnoise inNoiseType string "none"
spectreSVerilog.pnoise inVsrc string ""
spectreSVerilog.pnoise inIsrc string ""
spectreSVerilog.pnoise inPort string ""
spectreSVerilog.pnoise refsideband string ""
;spectreSVerilog pnoiseOpts partition variables
spectreSVerilog.pnoiseOpts tolerance3 string ""
spectreSVerilog.pnoiseOpts gearorder3 string ""
spectreSVerilog.pnoiseOpts solver3 string ""
spectreSVerilog.pnoiseOpts stats4 string ""
spectreSVerilog.pnoiseOpts annotate4 string "status"
;spectreSVerilog pxf partition variables
spectreSVerilog.pxf enable toggle (nil)
spectreSVerilog.pxf fund string ""
spectreSVerilog.pxf Relative boolean nil
spectreSVerilog.pxf sweeptype string ""
spectreSVerilog.pxf rangeType string "Start-Stop"
spectreSVerilog.pxf from string ""
spectreSVerilog.pxf to string ""
spectreSVerilog.pxf center string ""
spectreSVerilog.pxf span string ""
spectreSVerilog.pxf incrType string "Automatic"
spectreSVerilog.pxf stepTypeLin string "Step Size"
spectreSVerilog.pxf stepTypeLog string "Points Per Decade"
spectreSVerilog.pxf by string ""
spectreSVerilog.pxf lin string ""
spectreSVerilog.pxf dec string ""
spectreSVerilog.pxf log string ""
spectreSVerilog.pxf useDiscrete boolean nil
spectreSVerilog.pxf values string ""
spectreSVerilog.pxf harmonics string "Zero sideband only"
spectreSVerilog.pxf numharmonics string ""
spectreSVerilog.pxf arrayharmonics string ""
spectreSVerilog.pxf selFreqFrom string ""
spectreSVerilog.pxf selFreqTo string ""
spectreSVerilog.pxf harmsAndFreqsTitle string ""
spectreSVerilog.pxf harmsAndFreqs string ""
spectreSVerilog.pxf outType string "voltage"
spectreSVerilog.pxf negNode string "/gnd!"
spectreSVerilog.pxf posNode string ""
spectreSVerilog.pxf outVsrc string ""
;spectreSVerilog pxfOpts partition variables
spectreSVerilog.pxfOpts tolerance2 string ""
spectreSVerilog.pxfOpts gearorder2 string ""
spectreSVerilog.pxfOpts solver2 string ""
spectreSVerilog.pxfOpts stats3 string ""
spectreSVerilog.pxfOpts annotate3 string "status"
spectreSVerilog.pxfOpts stimuli string ""
spectreSVerilog.pxfOpts freqaxis2 string ""
;spectreVerilog environment variables
;spectreVerilog opts partition variables
spectreVerilog.opts multithread string ""
spectreVerilog.opts title string ""
spectreVerilog.opts audit string ""
spectreVerilog.opts nthreads string ""
spectreVerilog.opts mos_method string ""
spectreVerilog.opts ckptclock string "1800"
spectreVerilog.opts flow string ""
spectreVerilog.opts cols string "80"
spectreVerilog.opts opptcheck string ""
spectreVerilog.opts maxwarnstologfile string ""
spectreVerilog.opts reltol string "1e-3"
spectreVerilog.opts notation string ""
spectreVerilog.opts senstype string ""
spectreVerilog.opts approx string ""
spectreVerilog.opts warn string ""
spectreVerilog.opts info string ""
spectreVerilog.opts quantities string ""
spectreVerilog.opts sensformat string ""
spectreVerilog.opts pivabs string ""
spectreVerilog.opts compatible string ""
spectreVerilog.opts gmin string "1e-12"
spectreVerilog.opts ignshorts string ""
spectreVerilog.opts rforce string "1"
spectreVerilog.opts homotopy string ""
spectreVerilog.opts note string ""
spectreVerilog.opts iabstol string "1e-12"
spectreVerilog.opts debug string ""
spectreVerilog.opts tempeffects string ""
spectreVerilog.opts maxwarns string "5"
spectreVerilog.opts vabstol string "1e-6"
spectreVerilog.opts macromodels string ""
spectreVerilog.opts tnom string "27"
spectreVerilog.opts temp string "27"
spectreVerilog.opts gmin_check string ""
spectreVerilog.opts value string ""
spectreVerilog.opts narrate string ""
spectreVerilog.opts maxnotes string "5"
spectreVerilog.opts scale string "1.0"
spectreVerilog.opts diagnose string ""
spectreVerilog.opts maxnotestologfile string ""
spectreVerilog.opts digits string "5"
spectreVerilog.opts pivotdc string ""
spectreVerilog.opts pivrel string "1e-3"
spectreVerilog.opts scalem string "1.0"
spectreVerilog.opts limit string ""
spectreVerilog.opts topcheck string ""
spectreVerilog.opts inventory string ""
spectreVerilog.opts error string ""
spectreVerilog.opts sensfile string "../psf/sens.output"
;spectreVerilog outputs partition variables
spectreVerilog.outputs currents string ""
spectreVerilog.outputs subcktprobelvl string ""
spectreVerilog.outputs modelParamInfo boolean t
spectreVerilog.outputs outputParamInfo boolean t
spectreVerilog.outputs allDigitalNV boolean t
spectreVerilog.outputs pwr string ""
spectreVerilog.outputs saveahdlvars string ""
spectreVerilog.outputs nestlvl string ""
spectreVerilog.outputs elementInfo boolean t
spectreVerilog.outputs save string "allpub"
spectreVerilog.outputs useprobes string ""
;spectreVerilog verimixOpts partition variables
spectreVerilog.verimixOpts filename6 string ""
spectreVerilog.verimixOpts maxDCIter int 0
spectreVerilog.verimixOpts scope1 string ""
spectreVerilog.verimixOpts scope10 string ""
spectreVerilog.verimixOpts filename8 string ""
spectreVerilog.verimixOpts dcInterval float 0.0
spectreVerilog.verimixOpts scope3 string ""
spectreVerilog.verimixOpts scope8 string ""
spectreVerilog.verimixOpts scope7 string ""
spectreVerilog.verimixOpts filename7 string ""
spectreVerilog.verimixOpts scope string ""
spectreVerilog.verimixOpts filename4 string ""
spectreVerilog.verimixOpts filename string ""
spectreVerilog.verimixOpts filename1 string ""
spectreVerilog.verimixOpts scope9 string ""
spectreVerilog.verimixOpts importsdfswitch boolean nil
spectreVerilog.verimixOpts filename2 string ""
spectreVerilog.verimixOpts numberofsdffiles int 2
spectreVerilog.verimixOpts scope2 string ""
spectreVerilog.verimixOpts scope6 string ""
spectreVerilog.verimixOpts filename10 string ""
spectreVerilog.verimixOpts delaymodechoice string "Ignore"
spectreVerilog.verimixOpts sdfmixedswitch boolean t
spectreVerilog.verimixOpts filename9 string ""
spectreVerilog.verimixOpts scope5 string ""
spectreVerilog.verimixOpts filename5 string ""
spectreVerilog.verimixOpts filename3 string ""
spectreVerilog.verimixOpts scope4 string ""
;spectreVerilog verilogOpts partition variables
spectreVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
spectreVerilog.verilogOpts optionsFile string ""
spectreVerilog.verilogOpts twinTurbo boolean nil
spectreVerilog.verilogOpts suppressMessages boolean nil
spectreVerilog.verilogOpts libraryFile string ""
spectreVerilog.verilogOpts behaveProfile boolean nil
spectreVerilog.verilogOpts verimixLog string "verilog.log"
spectreVerilog.verilogOpts simVision boolean nil
spectreVerilog.verilogOpts pulseSpec boolean nil
spectreVerilog.verilogOpts commandFile string ""
spectreVerilog.verilogOpts pulseError int 100
spectreVerilog.verilogOpts stopCompile boolean nil
spectreVerilog.verilogOpts keepNodes string "Minimum"
spectreVerilog.verilogOpts accelerationCA boolean nil
spectreVerilog.verilogOpts turboRadio string "Default"
spectreVerilog.verilogOpts libraryDir string ""
spectreVerilog.verilogOpts suppressWarnings boolean nil
spectreVerilog.verilogOpts accelerationSwitches boolean nil
spectreVerilog.verilogOpts accelerationNormal boolean t
spectreVerilog.verilogOpts delayType string "Typical"
spectreVerilog.verilogOpts pulseReject int 100
spectreVerilog.verilogOpts delayMode string "Default"
spectreVerilog.verilogOpts vermixBinary string "verilog.vmx"
;spectreVerilog init partition variables
spectreVerilog.init processPriority int 0
;spectreVerilog envOpts partition variables
spectreVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
spectreVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
spectreVerilog.envOpts outputFormat string "AWD"
spectreVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
spectreVerilog.envOpts mspSetupNetlistEscapeName boolean nil
spectreVerilog.envOpts enableArclength boolean nil
spectreVerilog.envOpts autoDisplay boolean t
spectreVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
spectreVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
spectreVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
spectreVerilog.envOpts simOutputFormat string "psfbin"
spectreVerilog.envOpts spp string ""
spectreVerilog.envOpts mspSetupNetlistPinMap boolean nil
spectreVerilog.envOpts mspSetupNetlistBus boolean t
spectreVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
spectreVerilog.envOpts analysisOrder string ""
spectreVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
spectreVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
spectreVerilog.envOpts mspSetupNetlistExplicit boolean nil
spectreVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
spectreVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
spectreVerilog.envOpts paramRangeCheckFile string ""
spectreVerilog.envOpts printComments boolean nil
spectreVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
spectreVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
spectreVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
spectreVerilog.envOpts mspSetupNetlistSimTimeValue int 1
spectreVerilog.envOpts mspSetupNetlistUseLib boolean nil
spectreVerilog.envOpts firstRun boolean t
spectreVerilog.envOpts mspSetupNetlistNullPort boolean nil
spectreVerilog.envOpts mspSetupNetlistDropPortRange boolean t
spectreVerilog.envOpts userCmdLineOption string ""
spectreVerilog.envOpts mspSetupNetlistUpCase boolean nil
spectreVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;spectreVerilog pz partition variables
spectreVerilog.pz enable toggle (nil)
spectreVerilog.pz outType string "voltage"
spectreVerilog.pz p string ""
spectreVerilog.pz n string ""
spectreVerilog.pz oprobe string ""
spectreVerilog.pz inType string "voltage"
spectreVerilog.pz inVsrc string ""
spectreVerilog.pz inIsrc string ""
spectreVerilog.pz iprobe string ""
spectreVerilog.pz sweep string ""
spectreVerilog.pz freq string "1"
spectreVerilog.pz dev string ""
spectreVerilog.pz deviceParam string ""
spectreVerilog.pz mod string ""
spectreVerilog.pz modelParam string ""
spectreVerilog.pz designVar string ""
spectreVerilog.pz param string ""
spectreVerilog.pz rangeType string "Start-Stop"
spectreVerilog.pz start string ""
spectreVerilog.pz stop string ""
spectreVerilog.pz center string ""
spectreVerilog.pz span string ""
spectreVerilog.pz incrType string "Automatic"
spectreVerilog.pz stepTypeLin string "Step Size"
spectreVerilog.pz stepTypeLog string "Points Per Decade"
spectreVerilog.pz step string ""
spectreVerilog.pz lin string ""
spectreVerilog.pz dec string ""
spectreVerilog.pz log string ""
spectreVerilog.pz useDiscrete boolean nil
spectreVerilog.pz values string ""
spectreVerilog.pz porti string "1"
;spectreVerilog pzOpts partition variables
spectreVerilog.pzOpts readns string ""
spectreVerilog.pzOpts oppoint string ""
spectreVerilog.pzOpts fmax string ""
spectreVerilog.pzOpts zeroonly string ""
spectreVerilog.pzOpts prevoppoint string ""
spectreVerilog.pzOpts restart string ""
spectreVerilog.pzOpts annotate string ""
spectreVerilog.pzOpts stats string ""
;spectreVerilog dcmatch partition variables
spectreVerilog.dcmatch enable toggle (nil)
spectreVerilog.dcmatch outType string "voltage"
spectreVerilog.dcmatch p string ""
spectreVerilog.dcmatch n string ""
spectreVerilog.dcmatch oprobe string ""
spectreVerilog.dcmatch sweep string ""
spectreVerilog.dcmatch dev string ""
spectreVerilog.dcmatch deviceParam string ""
spectreVerilog.dcmatch mod string ""
spectreVerilog.dcmatch modelParam string ""
spectreVerilog.dcmatch designVar string ""
spectreVerilog.dcmatch param string ""
spectreVerilog.dcmatch rangeType string "Start-Stop"
spectreVerilog.dcmatch start string ""
spectreVerilog.dcmatch stop string ""
spectreVerilog.dcmatch center string ""
spectreVerilog.dcmatch span string ""
spectreVerilog.dcmatch incrType string "Automatic"
spectreVerilog.dcmatch stepTypeLin string "Step Size"
spectreVerilog.dcmatch stepTypeLog string "Points Per Decade"
spectreVerilog.dcmatch step string ""
spectreVerilog.dcmatch lin string ""
spectreVerilog.dcmatch dec string ""
spectreVerilog.dcmatch log string ""
spectreVerilog.dcmatch useDiscrete boolean nil
spectreVerilog.dcmatch values string ""
spectreVerilog.dcmatch mth string ""
spectreVerilog.dcmatch porti string "1"
spectreVerilog.dcmatch portv string ""
;spectreVerilog dcmatchOpts partition variables
spectreVerilog.dcmatchOpts readns string ""
spectreVerilog.dcmatchOpts save string ""
spectreVerilog.dcmatchOpts nestlvl string ""
spectreVerilog.dcmatchOpts oppoint string ""
spectreVerilog.dcmatchOpts prevoppoint string ""
spectreVerilog.dcmatchOpts restart string ""
spectreVerilog.dcmatchOpts annotate string "status"
spectreVerilog.dcmatchOpts stats string ""
spectreVerilog.dcmatchOpts where string "rawfile"
;spectreVerilog stb partition variables
spectreVerilog.stb enable toggle (nil)
spectreVerilog.stb sweep string "Frequency"
spectreVerilog.stb freq string ""
spectreVerilog.stb dev string ""
spectreVerilog.stb deviceParam string ""
spectreVerilog.stb mod string ""
spectreVerilog.stb modelParam string ""
spectreVerilog.stb designVar string ""
spectreVerilog.stb param string ""
spectreVerilog.stb rangeType string "Start-Stop"
spectreVerilog.stb start string ""
spectreVerilog.stb stop string ""
spectreVerilog.stb center string ""
spectreVerilog.stb span string ""
spectreVerilog.stb incrType string "Automatic"
spectreVerilog.stb stepTypeLin string "Step Size"
spectreVerilog.stb stepTypeLog string "Points Per Decade"
spectreVerilog.stb step string ""
spectreVerilog.stb lin string ""
spectreVerilog.stb dec string ""
spectreVerilog.stb log string ""
spectreVerilog.stb useDiscrete boolean nil
spectreVerilog.stb values string ""
spectreVerilog.stb probe string ""
;spectreVerilog stbOpts partition variables
spectreVerilog.stbOpts prevoppoint string ""
spectreVerilog.stbOpts readns string ""
spectreVerilog.stbOpts save string ""
spectreVerilog.stbOpts nestlvl string ""
spectreVerilog.stbOpts oppoint string ""
spectreVerilog.stbOpts restart string ""
spectreVerilog.stbOpts annotate string "status"
spectreVerilog.stbOpts stats string ""
;spectreVerilog tran partition variables
spectreVerilog.tran enable toggle (nil)
spectreVerilog.tran stop string ""
spectreVerilog.tran errpreset string ""
;spectreVerilog tranOpts partition variables
spectreVerilog.tranOpts start string ""
spectreVerilog.tranOpts outputstart string ""
spectreVerilog.tranOpts step string ""
spectreVerilog.tranOpts maxstep string ""
spectreVerilog.tranOpts ic string ""
spectreVerilog.tranOpts skipdc string ""
spectreVerilog.tranOpts readic string ""
spectreVerilog.tranOpts readns string ""
spectreVerilog.tranOpts cmin string ""
spectreVerilog.tranOpts write string "spectre.ic"
spectreVerilog.tranOpts writefinal string "spectre.fc"
spectreVerilog.tranOpts ckptperiod string ""
spectreVerilog.tranOpts method string ""
spectreVerilog.tranOpts relref string ""
spectreVerilog.tranOpts lteratio string ""
spectreVerilog.tranOpts stats string ""
spectreVerilog.tranOpts annotate string "status"
spectreVerilog.tranOpts save string ""
spectreVerilog.tranOpts nestlvl string ""
spectreVerilog.tranOpts oppoint string ""
spectreVerilog.tranOpts skipstart string ""
spectreVerilog.tranOpts skipstop string ""
spectreVerilog.tranOpts skipcount string ""
spectreVerilog.tranOpts strobeperiod string ""
spectreVerilog.tranOpts strobedelay string ""
spectreVerilog.tranOpts compression string ""
spectreVerilog.tranOpts infotimes string ""
spectreVerilog.tranOpts flushpoints string ""
spectreVerilog.tranOpts flushtime string ""
spectreVerilog.tranOpts flushofftime string ""
spectreVerilog.tranOpts maxiters string "5"
spectreVerilog.tranOpts restart string ""
spectreVerilog.tranOpts captab boolean nil
spectreVerilog.tranOpts timed boolean nil
spectreVerilog.tranOpts threshold string "0.0"
spectreVerilog.tranOpts detail string "node"
spectreVerilog.tranOpts sort string "name"
;spectreVerilog envlp partition variables
spectreVerilog.envlp enable toggle (nil)
spectreVerilog.envlp clockname string ""
spectreVerilog.envlp stop string ""
spectreVerilog.envlp harmonics string "Number of harmonics"
spectreVerilog.envlp harms string ""
spectreVerilog.envlp harmsvec string ""
spectreVerilog.envlp errpreset string ""
;spectreVerilog envlpOpts partition variables
spectreVerilog.envlpOpts start string ""
spectreVerilog.envlpOpts outputstart string ""
spectreVerilog.envlpOpts tstab string ""
spectreVerilog.envlpOpts modulationbw string ""
spectreVerilog.envlpOpts maxstep string ""
spectreVerilog.envlpOpts envmaxstep string ""
spectreVerilog.envlpOpts ic string ""
spectreVerilog.envlpOpts skipdc string ""
spectreVerilog.envlpOpts readic string ""
spectreVerilog.envlpOpts readns string ""
spectreVerilog.envlpOpts cmin string ""
spectreVerilog.envlpOpts write string ""
spectreVerilog.envlpOpts writefinal string ""
spectreVerilog.envlpOpts swapfile string ""
spectreVerilog.envlpOpts method string ""
spectreVerilog.envlpOpts relref string ""
spectreVerilog.envlpOpts lteratio string ""
spectreVerilog.envlpOpts envlteratio string ""
spectreVerilog.envlpOpts steadyratio string ""
spectreVerilog.envlpOpts stats string ""
spectreVerilog.envlpOpts annotate string "status"
spectreVerilog.envlpOpts save string ""
spectreVerilog.envlpOpts nestlvl string ""
spectreVerilog.envlpOpts compression string ""
spectreVerilog.envlpOpts outputtype string ""
spectreVerilog.envlpOpts strobeperiod string ""
spectreVerilog.envlpOpts maxiters string ""
spectreVerilog.envlpOpts restart string ""
spectreVerilog.envlpOpts envmaxiters string ""
;spectreVerilog ac partition variables
spectreVerilog.ac enable toggle (nil)
spectreVerilog.ac sweep string "Frequency"
spectreVerilog.ac freq string ""
spectreVerilog.ac dev string ""
spectreVerilog.ac deviceParam string ""
spectreVerilog.ac mod string ""
spectreVerilog.ac modelParam string ""
spectreVerilog.ac designVar string ""
spectreVerilog.ac param string ""
spectreVerilog.ac rangeType string "Start-Stop"
spectreVerilog.ac start string ""
spectreVerilog.ac stop string ""
spectreVerilog.ac center string ""
spectreVerilog.ac span string ""
spectreVerilog.ac incrType string "Automatic"
spectreVerilog.ac stepTypeLin string "Step Size"
spectreVerilog.ac stepTypeLog string "Points Per Decade"
spectreVerilog.ac step string ""
spectreVerilog.ac lin string ""
spectreVerilog.ac dec string ""
spectreVerilog.ac log string ""
spectreVerilog.ac useDiscrete boolean nil
spectreVerilog.ac values string ""
;spectreVerilog acOpts partition variables
spectreVerilog.acOpts readns string ""
spectreVerilog.acOpts prevoppoint string ""
spectreVerilog.acOpts save string ""
spectreVerilog.acOpts nestlvl string ""
spectreVerilog.acOpts oppoint string ""
spectreVerilog.acOpts restart string ""
spectreVerilog.acOpts annotate string "status"
spectreVerilog.acOpts stats string ""
;spectreVerilog dc partition variables
spectreVerilog.dc enable toggle (nil)
spectreVerilog.dcop enable toggle (nil)
spectreVerilog.dc saveOppoint boolean nil
spectreVerilog.dc sweep string ""
spectreVerilog.dc dev string ""
spectreVerilog.dc deviceParam string ""
spectreVerilog.dc mod string ""
spectreVerilog.dc modelParam string ""
spectreVerilog.dc designVar string ""
spectreVerilog.dc param string ""
spectreVerilog.dc rangeType string "Start-Stop"
spectreVerilog.dc start string ""
spectreVerilog.dc stop string ""
spectreVerilog.dc center string ""
spectreVerilog.dc span string ""
spectreVerilog.dc incrType string "Automatic"
spectreVerilog.dc stepTypeLin string "Step Size"
spectreVerilog.dc stepTypeLog string "Points Per Decade"
spectreVerilog.dc step string ""
spectreVerilog.dc lin string ""
spectreVerilog.dc dec string ""
spectreVerilog.dc log string ""
spectreVerilog.dc useDiscrete boolean nil
spectreVerilog.dc values string ""
;spectreVerilog dcOpts partition variables
spectreVerilog.dcOpts force string ""
spectreVerilog.dcopOpts force string ""
spectreVerilog.dcOpts readns string ""
spectreVerilog.dcopOpts readns string ""
spectreVerilog.dcOpts readforce string ""
spectreVerilog.dcopOpts readforce string ""
spectreVerilog.dcOpts write string "spectre.dc"
spectreVerilog.dcopOpts write string "spectre.dc"
spectreVerilog.dcOpts writefinal string ""
spectreVerilog.dcopOpts writefinal string ""
spectreVerilog.dcOpts save string ""
spectreVerilog.dcopOpts save string ""
spectreVerilog.dcOpts nestlvl string ""
spectreVerilog.dcopOpts nestlvl string ""
spectreVerilog.dcOpts print string ""
spectreVerilog.dcopOpts print string ""
spectreVerilog.dcOpts check string ""
spectreVerilog.dcopOpts check string ""
spectreVerilog.dcOpts oppoint string "rawfile"
spectreVerilog.dcopOpts oppoint string "rawfile"
spectreVerilog.dcOpts homotopy string ""
spectreVerilog.dcopOpts homotopy string ""
spectreVerilog.dcOpts restart string ""
spectreVerilog.dcopOpts restart string ""
spectreVerilog.dcOpts maxiters string "150"
spectreVerilog.dcopOpts maxiters string "150"
spectreVerilog.dcOpts maxsteps string "10000"
spectreVerilog.dcopOpts maxsteps string "10000"
spectreVerilog.dcOpts annotate string "status"
spectreVerilog.dcopOpts annotate string "status"
spectreVerilog.dcOpts captab boolean nil
spectreVerilog.dcopOpts captab boolean nil
spectreVerilog.dcOpts threshold string "0.0"
spectreVerilog.dcopOpts threshold string "0.0"
spectreVerilog.dcOpts detail string "node"
spectreVerilog.dcopOpts detail string "node"
spectreVerilog.dcOpts sort string "name"
spectreVerilog.dcopOpts sort string "name"
;spectreVerilog noise partition variables
spectreVerilog.noise enable toggle (nil)
spectreVerilog.noise sweep string "Frequency"
spectreVerilog.noise freq string ""
spectreVerilog.noise dev string ""
spectreVerilog.noise deviceParam string ""
spectreVerilog.noise mod string ""
spectreVerilog.noise modelParam string ""
spectreVerilog.noise designVar string ""
spectreVerilog.noise param string ""
spectreVerilog.noise rangeType string "Start-Stop"
spectreVerilog.noise start string ""
spectreVerilog.noise stop string ""
spectreVerilog.noise center string ""
spectreVerilog.noise span string ""
spectreVerilog.noise incrType string "Automatic"
spectreVerilog.noise stepTypeLin string "Step Size"
spectreVerilog.noise stepTypeLog string "Points Per Decade"
spectreVerilog.noise step string ""
spectreVerilog.noise lin string ""
spectreVerilog.noise dec string ""
spectreVerilog.noise log string ""
spectreVerilog.noise useDiscrete boolean nil
spectreVerilog.noise values string ""
spectreVerilog.noise outType string "probe"
spectreVerilog.noise p string ""
spectreVerilog.noise n string ""
spectreVerilog.noise oprobe string ""
spectreVerilog.noise inType string "port"
spectreVerilog.noise inVsrc string ""
spectreVerilog.noise inIsrc string ""
spectreVerilog.noise iprobe string ""
spectreVerilog.noise inPort string ""
;spectreVerilog noiseOpts partition variables
spectreVerilog.noiseOpts readns string ""
spectreVerilog.noiseOpts prevoppoint string ""
spectreVerilog.noiseOpts save string ""
spectreVerilog.noiseOpts nestlvl string ""
spectreVerilog.noiseOpts oppoint string ""
spectreVerilog.noiseOpts restart string ""
spectreVerilog.noiseOpts annotate string "status"
spectreVerilog.noiseOpts stats string ""
;spectreVerilog xf partition variables
spectreVerilog.xf enable toggle (nil)
spectreVerilog.xf sweep string "Frequency"
spectreVerilog.xf freq string ""
spectreVerilog.xf dev string ""
spectreVerilog.xf deviceParam string ""
spectreVerilog.xf mod string ""
spectreVerilog.xf modelParam string ""
spectreVerilog.xf designVar string ""
spectreVerilog.xf param string ""
spectreVerilog.xf rangeType string "Start-Stop"
spectreVerilog.xf start string ""
spectreVerilog.xf stop string ""
spectreVerilog.xf center string ""
spectreVerilog.xf span string ""
spectreVerilog.xf incrType string "Automatic"
spectreVerilog.xf stepTypeLin string "Step Size"
spectreVerilog.xf stepTypeLog string "Points Per Decade"
spectreVerilog.xf step string ""
spectreVerilog.xf lin string ""
spectreVerilog.xf dec string ""
spectreVerilog.xf log string ""
spectreVerilog.xf useDiscrete boolean nil
spectreVerilog.xf values string ""
spectreVerilog.xf outType string "voltage"
spectreVerilog.xf p string ""
spectreVerilog.xf n string ""
spectreVerilog.xf probe string ""
;spectreVerilog xfOpts partition variables
spectreVerilog.xfOpts readns string ""
spectreVerilog.xfOpts prevoppoint string ""
spectreVerilog.xfOpts stimuli string ""
spectreVerilog.xfOpts save string ""
spectreVerilog.xfOpts nestlvl string ""
spectreVerilog.xfOpts oppoint string ""
spectreVerilog.xfOpts restart string ""
spectreVerilog.xfOpts annotate string "status"
spectreVerilog.xfOpts stats string ""
;spectreVerilog sp partition variables
spectreVerilog.sp enable toggle (nil)
spectreVerilog.sp ports string ""
spectreVerilog.sp sweep string "Frequency"
spectreVerilog.sp freq string ""
spectreVerilog.sp dev string ""
spectreVerilog.sp deviceParam string ""
spectreVerilog.sp mod string ""
spectreVerilog.sp modelParam string ""
spectreVerilog.sp designVar string ""
spectreVerilog.sp param string ""
spectreVerilog.sp rangeType string "Start-Stop"
spectreVerilog.sp start string ""
spectreVerilog.sp stop string ""
spectreVerilog.sp center string ""
spectreVerilog.sp span string ""
spectreVerilog.sp incrType string "Automatic"
spectreVerilog.sp stepTypeLin string "Step Size"
spectreVerilog.sp stepTypeLog string "Points Per Decade"
spectreVerilog.sp step string ""
spectreVerilog.sp lin string ""
spectreVerilog.sp dec string ""
spectreVerilog.sp log string ""
spectreVerilog.sp useDiscrete boolean nil
spectreVerilog.sp values string ""
spectreVerilog.sp donoise string "no"
spectreVerilog.sp oprobe string ""
spectreVerilog.sp iprobe string ""
;spectreVerilog spOpts partition variables
spectreVerilog.spOpts readns string ""
spectreVerilog.spOpts prevoppoint string ""
spectreVerilog.spOpts file string ""
spectreVerilog.spOpts datafmt string ""
spectreVerilog.spOpts datatype string ""
spectreVerilog.spOpts noisedata string ""
spectreVerilog.spOpts oppoint string ""
spectreVerilog.spOpts restart string ""
spectreVerilog.spOpts annotate string "status"
spectreVerilog.spOpts stats string ""
;spectreVerilog pss partition variables
spectreVerilog.pss enable toggle (nil)
spectreVerilog.pss paramListBox string ""
spectreVerilog.pss fundListBox string ""
spectreVerilog.pss stimName string ""
spectreVerilog.pss freqName string ""
spectreVerilog.pss freqVal string ""
spectreVerilog.pss signalLevel string "Large"
spectreVerilog.pss srcId string ""
spectreVerilog.pss maxHarms string ""
spectreVerilog.pss freqPeriod string "Beat Frequency"
spectreVerilog.pss fund string ""
spectreVerilog.pss autoCalc boolean nil
spectreVerilog.pss period string ""
spectreVerilog.pss harmonics string "Number of harmonics"
spectreVerilog.pss harms string ""
spectreVerilog.pss indices string ""
spectreVerilog.pss Aindices string ""
spectreVerilog.pss harmsvec string ""
spectreVerilog.pss selFreqFrom string "0"
spectreVerilog.pss selFreqTo string "1e12"
spectreVerilog.pss order string "1"
spectreVerilog.pss harmsAndFreqsTitle string ""
spectreVerilog.pss harmsAndFreqsTitle2 string ""
spectreVerilog.pss harmsAndFreqs string ""
spectreVerilog.pss arrayCoeffs string ""
spectreVerilog.pss harmCoeffs string ""
spectreVerilog.pss harmListMem string ""
spectreVerilog.pss errpreset string ""
spectreVerilog.pss tstab string ""
spectreVerilog.pss saveinit string ""
spectreVerilog.pss oscana boolean nil
spectreVerilog.pss p string ""
spectreVerilog.pss n string ""
spectreVerilog.pss sweepB boolean nil
spectreVerilog.pss sweep string "Variable"
spectreVerilog.pss freqVar string "no"
spectreVerilog.pss designVar string ""
spectreVerilog.pss dev string ""
spectreVerilog.pss deviceParam string ""
spectreVerilog.pss mod string ""
spectreVerilog.pss modelParam string ""
spectreVerilog.pss param string ""
spectreVerilog.pss rangeType string "Start-Stop"
spectreVerilog.pss start string ""
spectreVerilog.pss stop string ""
spectreVerilog.pss center string ""
spectreVerilog.pss span string ""
spectreVerilog.pss incrType string "Linear"
spectreVerilog.pss stepTypeLin string "Step Size"
spectreVerilog.pss stepTypeLog string "Points Per Decade"
spectreVerilog.pss step string ""
spectreVerilog.pss lin string ""
spectreVerilog.pss dec string ""
spectreVerilog.pss log string ""
spectreVerilog.pss useDiscrete boolean nil
spectreVerilog.pss values string ""
;spectreVerilog pssOpts partition variables
spectreVerilog.pssOpts step string ""
spectreVerilog.pssOpts maxstep string ""
spectreVerilog.pssOpts ic string ""
spectreVerilog.pssOpts skipdc string ""
spectreVerilog.pssOpts readic string ""
spectreVerilog.pssOpts readns string ""
spectreVerilog.pssOpts cmin string ""
spectreVerilog.pssOpts write string ""
spectreVerilog.pssOpts writefinal string ""
spectreVerilog.pssOpts swapfile string ""
spectreVerilog.pssOpts writepss string ""
spectreVerilog.pssOpts readpss string ""
spectreVerilog.pssOpts method string ""
spectreVerilog.pssOpts tstabmethod string ""
spectreVerilog.pssOpts relref string ""
spectreVerilog.pssOpts lteratio string ""
spectreVerilog.pssOpts steadyratio string ""
spectreVerilog.pssOpts maxacfreq string ""
spectreVerilog.pssOpts maxperiods string ""
spectreVerilog.pssOpts finitediff string ""
spectreVerilog.pssOpts highorder string ""
spectreVerilog.pssOpts psaratio string ""
spectreVerilog.pssOpts maxorder string ""
spectreVerilog.pssOpts fullpssvec string ""
spectreVerilog.pssOpts stats string ""
spectreVerilog.pssOpts annotate string "status"
spectreVerilog.pssOpts save string ""
spectreVerilog.pssOpts nestlvl string ""
spectreVerilog.pssOpts oppoint string ""
spectreVerilog.pssOpts skipstart string ""
spectreVerilog.pssOpts skipstop string ""
spectreVerilog.pssOpts skipcount string ""
spectreVerilog.pssOpts strobeperiod string ""
spectreVerilog.pssOpts strobedelay string ""
spectreVerilog.pssOpts compression string ""
spectreVerilog.pssOpts outputtype string ""
spectreVerilog.pssOpts maxiters string ""
spectreVerilog.pssOpts restart string ""
spectreVerilog.pssOpts tstart string ""
;spectreVerilog pac partition variables
spectreVerilog.pac enable toggle (nil)
spectreVerilog.pac fund string ""
spectreVerilog.pac period string ""
spectreVerilog.pac modsource string ""
spectreVerilog.pac moduppersideband string "0"
spectreVerilog.pac inmodharmnum string "1"
spectreVerilog.pac outmodharmvec string "1"
spectreVerilog.pac inputType string "SSB"
spectreVerilog.pac modulatedToggle boolean nil
spectreVerilog.pac modulated string ""
spectreVerilog.pac singlePt string "Single-Point []"
spectreVerilog.pac sweeptype string " "
spectreVerilog.pac relharmnum string ""
spectreVerilog.pac rangeType string "Start-Stop"
spectreVerilog.pac start string ""
spectreVerilog.pac stop string ""
spectreVerilog.pac center string ""
spectreVerilog.pac span string ""
spectreVerilog.pac incrType string "Automatic"
spectreVerilog.pac stepTypeLin string "Step Size"
spectreVerilog.pac stepTypeLog string "Points Per Decade"
spectreVerilog.pac step string ""
spectreVerilog.pac lin string ""
spectreVerilog.pac dec string ""
spectreVerilog.pac log string ""
spectreVerilog.pac useDiscrete boolean nil
spectreVerilog.pac values string ""
spectreVerilog.pac harmonics string "Maximum sideband"
spectreVerilog.pac maxsideband string ""
spectreVerilog.pac indices string ""
spectreVerilog.pac Aindices string ""
spectreVerilog.pac sidebands string ""
spectreVerilog.pac side string "upper"
spectreVerilog.pac selFreqFrom string "0"
spectreVerilog.pac selFreqTo string "1e12"
spectreVerilog.pac order string "1"
spectreVerilog.pac harmsAndFreqsTitle string ""
spectreVerilog.pac harmsAndFreqsTitle2 string ""
spectreVerilog.pac harmsAndFreqs string ""
spectreVerilog.pac arrayCoeffs string ""
spectreVerilog.pac harmCoeffs string ""
spectreVerilog.pac harmListMem string ""
;spectreVerilog pacOpts partition variables
spectreVerilog.pacOpts tolerance string ""
spectreVerilog.pacOpts gear_order string ""
spectreVerilog.pacOpts solver string ""
spectreVerilog.pacOpts oscsolver string ""
spectreVerilog.pacOpts stats string ""
spectreVerilog.pacOpts annotate string "status"
spectreVerilog.pacOpts freqaxis string ""
spectreVerilog.pacOpts save string ""
spectreVerilog.pacOpts nestlvl string ""
spectreVerilog.pacOpts outputperiod string ""
;spectreVerilog pnoise partition variables
spectreVerilog.pnoise enable toggle (nil)
spectreVerilog.pnoise fund string ""
spectreVerilog.pnoise period string ""
spectreVerilog.pnoise singlePt string "Single-Point []"
spectreVerilog.pnoise sweeptype string " "
spectreVerilog.pnoise relharmnum string ""
spectreVerilog.pnoise rangeType string "Start-Stop"
spectreVerilog.pnoise start string ""
spectreVerilog.pnoise stop string ""
spectreVerilog.pnoise center string ""
spectreVerilog.pnoise span string ""
spectreVerilog.pnoise incrType string "Automatic"
spectreVerilog.pnoise stepTypeLin string "Step Size"
spectreVerilog.pnoise stepTypeLog string "Points Per Decade"
spectreVerilog.pnoise step string ""
spectreVerilog.pnoise lin string ""
spectreVerilog.pnoise dec string ""
spectreVerilog.pnoise log string ""
spectreVerilog.pnoise useDiscrete boolean nil
spectreVerilog.pnoise values string ""
spectreVerilog.pnoise harmonics string "Maximum sideband"
spectreVerilog.pnoise maxsideband string ""
spectreVerilog.pnoise indices string ""
spectreVerilog.pnoise Aindices string ""
spectreVerilog.pnoise sidebands string ""
spectreVerilog.pnoise side string "upper"
spectreVerilog.pnoise selFreqFrom string "0"
spectreVerilog.pnoise selFreqTo string "1e12"
spectreVerilog.pnoise order string "1"
spectreVerilog.pnoise harmsAndFreqsTitle string ""
spectreVerilog.pnoise harmsAndFreqsTitle2 string ""
spectreVerilog.pnoise harmsAndFreqs string ""
spectreVerilog.pnoise arrayCoeffs string ""
spectreVerilog.pnoise harmCoeffs string ""
spectreVerilog.pnoise harmListMem string ""
spectreVerilog.pnoise outType string "probe"
spectreVerilog.pnoise p string ""
spectreVerilog.pnoise n string ""
spectreVerilog.pnoise oprobe string ""
spectreVerilog.pnoise inType string "port"
spectreVerilog.pnoise inVsrc string ""
spectreVerilog.pnoise inIsrc string ""
spectreVerilog.pnoise iprobe string ""
spectreVerilog.pnoise inPort string ""
spectreVerilog.pnoise refsbSelect string "Enter in field"
spectreVerilog.pnoise refsideband string ""
spectreVerilog.pnoise refsbFreqFrom string "0"
spectreVerilog.pnoise refsbFreqTo string "1e12"
spectreVerilog.pnoise refsbOrder string "1"
spectreVerilog.pnoise refsbTitle string ""
spectreVerilog.pnoise refsbListbox string ""
spectreVerilog.pnoise noisetype string "sources"
spectreVerilog.pnoise tdnoise string "Noise Skip Count"
spectreVerilog.pnoise noiseskipcount string ""
spectreVerilog.pnoise numberofpoints string ""
spectreVerilog.pnoise maxcycles string ""
spectreVerilog.pnoise useDiscreteNoise boolean nil
spectreVerilog.pnoise noisetimepoints string ""
spectreVerilog.pnoise useDiscreteCorr boolean nil
spectreVerilog.pnoise cycles string ""
;spectreVerilog pnoiseOpts partition variables
spectreVerilog.pnoiseOpts tolerance string ""
spectreVerilog.pnoiseOpts gear_order string ""
spectreVerilog.pnoiseOpts solver string ""
spectreVerilog.pnoiseOpts oscsolver string ""
spectreVerilog.pnoiseOpts stats string ""
spectreVerilog.pnoiseOpts annotate string "status"
spectreVerilog.pnoiseOpts save string ""
spectreVerilog.pnoiseOpts nestlvl string ""
spectreVerilog.pnoiseOpts saveallsidebands string ""
;spectreVerilog pxf partition variables
spectreVerilog.pxf enable toggle (nil)
spectreVerilog.pxf fund string ""
spectreVerilog.pxf period string ""
spectreVerilog.pxf moduppersideband string "0"
spectreVerilog.pxf outmodharmnum string "1"
spectreVerilog.pxf inmodharmvec string "1"
spectreVerilog.pxf outputType string "SSB"
spectreVerilog.pxf modulatedToggle boolean nil
spectreVerilog.pxf modulated string ""
spectreVerilog.pxf outType string "voltage"
spectreVerilog.pxf p string ""
spectreVerilog.pxf n string ""
spectreVerilog.pxf probe string ""
spectreVerilog.pxf singlePt string "Single-Point []"
spectreVerilog.pxf sweeptype string " "
spectreVerilog.pxf relharmnum string ""
spectreVerilog.pxf rangeType string "Start-Stop"
spectreVerilog.pxf start string ""
spectreVerilog.pxf stop string ""
spectreVerilog.pxf center string ""
spectreVerilog.pxf span string ""
spectreVerilog.pxf incrType string "Automatic"
spectreVerilog.pxf stepTypeLin string "Step Size"
spectreVerilog.pxf stepTypeLog string "Points Per Decade"
spectreVerilog.pxf step string ""
spectreVerilog.pxf lin string ""
spectreVerilog.pxf dec string ""
spectreVerilog.pxf log string ""
spectreVerilog.pxf useDiscrete boolean nil
spectreVerilog.pxf values string ""
spectreVerilog.pxf harmonics string "Maximum sideband"
spectreVerilog.pxf maxsideband string ""
spectreVerilog.pxf indices string ""
spectreVerilog.pxf Aindices string ""
spectreVerilog.pxf sidebands string ""
spectreVerilog.pxf side string "upper"
spectreVerilog.pxf selFreqFrom string "0"
spectreVerilog.pxf selFreqTo string "1e12"
spectreVerilog.pxf order string "1"
spectreVerilog.pxf harmsAndFreqsTitle string ""
spectreVerilog.pxf harmsAndFreqsTitle2 string ""
spectreVerilog.pxf harmsAndFreqs string ""
spectreVerilog.pxf arrayCoeffs string ""
spectreVerilog.pxf harmCoeffs string ""
spectreVerilog.pxf harmListMem string ""
;spectreVerilog pxfOpts partition variables
spectreVerilog.pxfOpts tolerance string ""
spectreVerilog.pxfOpts gear_order string ""
spectreVerilog.pxfOpts solver string ""
spectreVerilog.pxfOpts oscsolver string ""
spectreVerilog.pxfOpts stats string ""
spectreVerilog.pxfOpts annotate string "status"
spectreVerilog.pxfOpts stimuli string ""
spectreVerilog.pxfOpts freqaxis string ""
spectreVerilog.pxfOpts save string ""
spectreVerilog.pxfOpts nestlvl string ""
;spectreVerilog psp partition variables
spectreVerilog.psp enable toggle (nil)
spectreVerilog.psp singlePt string "Single-Point []"
spectreVerilog.psp sweeptype string " "
spectreVerilog.psp rangeType string "Start-Stop"
spectreVerilog.psp start string ""
spectreVerilog.psp stop string ""
spectreVerilog.psp center string ""
spectreVerilog.psp span string ""
spectreVerilog.psp incrType string "Automatic"
spectreVerilog.psp stepTypeLin string "Step Size"
spectreVerilog.psp stepTypeLog string "Points Per Decade"
spectreVerilog.psp step string ""
spectreVerilog.psp lin string ""
spectreVerilog.psp dec string ""
spectreVerilog.psp log string ""
spectreVerilog.psp useDiscrete boolean nil
spectreVerilog.psp values string ""
spectreVerilog.psp portharmsvec string ""
spectreVerilog.psp ports string ""
spectreVerilog.psp selectPorts boolean t
spectreVerilog.psp harmsvec string ""
spectreVerilog.psp freqRange string ""
spectreVerilog.psp listPortHarm string ""
spectreVerilog.psp listPortName string ""
spectreVerilog.psp listPortNum string ""
spectreVerilog.psp portChoiceList string ""
spectreVerilog.psp portChoiceListHeading string ""
spectreVerilog.psp donoise string "yes"
spectreVerilog.psp maxsideband string ""
;spectreVerilog pspOpts partition variables
spectreVerilog.pspOpts tolerance string ""
spectreVerilog.pspOpts gear_order string ""
spectreVerilog.pspOpts solver string ""
spectreVerilog.pspOpts oscsolver string ""
spectreVerilog.pspOpts annotate string "status"
spectreVerilog.pspOpts stats string ""
spectreVerilog.pspOpts freqaxis string ""
;spectreVerilog qpss partition variables
spectreVerilog.qpss enable toggle (nil)
spectreVerilog.qpss paramListBox string ""
spectreVerilog.qpss fundListBox string ""
spectreVerilog.qpss stimName string ""
spectreVerilog.qpss freqName string ""
spectreVerilog.qpss freqVal string ""
spectreVerilog.qpss signalLevel string "Moderate"
spectreVerilog.qpss srcId string ""
spectreVerilog.qpss maxHarms string ""
spectreVerilog.qpss funds string ""
spectreVerilog.qpss maxharms string ""
spectreVerilog.qpss harmonics boolean nil
spectreVerilog.qpss selFreqFrom string "0"
spectreVerilog.qpss selFreqTo string "1e12"
spectreVerilog.qpss harmsAndFreqsTitle string ""
spectreVerilog.qpss harmsAndFreqs string ""
spectreVerilog.qpss errpreset string ""
spectreVerilog.qpss tstab string ""
spectreVerilog.qpss saveinit string ""
spectreVerilog.qpss sweepB boolean nil
spectreVerilog.qpss sweep string "Variable"
spectreVerilog.qpss freqVar string "no"
spectreVerilog.qpss designVar string ""
spectreVerilog.qpss dev string ""
spectreVerilog.qpss deviceParam string ""
spectreVerilog.qpss mod string ""
spectreVerilog.qpss modelParam string ""
spectreVerilog.qpss param string ""
spectreVerilog.qpss rangeType string "Start-Stop"
spectreVerilog.qpss start string ""
spectreVerilog.qpss stop string ""
spectreVerilog.qpss center string ""
spectreVerilog.qpss span string ""
spectreVerilog.qpss incrType string "Linear"
spectreVerilog.qpss stepTypeLin string "Step Size"
spectreVerilog.qpss stepTypeLog string "Points Per Decade"
spectreVerilog.qpss step string ""
spectreVerilog.qpss lin string ""
spectreVerilog.qpss dec string ""
spectreVerilog.qpss log string ""
spectreVerilog.qpss useDiscrete boolean nil
spectreVerilog.qpss values string ""
;spectreVerilog qpssOpts partition variables
spectreVerilog.qpssOpts step string ""
spectreVerilog.qpssOpts maxstep string ""
spectreVerilog.qpssOpts ic string ""
spectreVerilog.qpssOpts skipdc string ""
spectreVerilog.qpssOpts readic string ""
spectreVerilog.qpssOpts readns string ""
spectreVerilog.qpssOpts cmin string ""
spectreVerilog.qpssOpts write string ""
spectreVerilog.qpssOpts writefinal string ""
spectreVerilog.qpssOpts swapfile string ""
spectreVerilog.qpssOpts writeqpss string ""
spectreVerilog.qpssOpts readqpss string ""
spectreVerilog.qpssOpts method string ""
spectreVerilog.qpssOpts relref string ""
spectreVerilog.qpssOpts lteratio string ""
spectreVerilog.qpssOpts steadyratio string ""
spectreVerilog.qpssOpts maxperiods string ""
spectreVerilog.qpssOpts stats string ""
spectreVerilog.qpssOpts annotate string "status"
spectreVerilog.qpssOpts save string ""
spectreVerilog.qpssOpts nestlvl string ""
spectreVerilog.qpssOpts oppoint string ""
spectreVerilog.qpssOpts skipstart string ""
spectreVerilog.qpssOpts skipstop string ""
spectreVerilog.qpssOpts skipcount string ""
spectreVerilog.qpssOpts strobeperiod string ""
spectreVerilog.qpssOpts strobedelay string ""
spectreVerilog.qpssOpts compression string ""
spectreVerilog.qpssOpts maxiters string ""
spectreVerilog.qpssOpts restart string ""
spectreVerilog.qpssOpts tstart string ""
;spectreVerilog qpac partition variables
spectreVerilog.qpac enable toggle (nil)
spectreVerilog.qpac singlePt string "Single-Point []"
spectreVerilog.qpac sweeptype string " "
spectreVerilog.qpac relharmvec string ""
spectreVerilog.qpac rangeType string "Start-Stop"
spectreVerilog.qpac start string ""
spectreVerilog.qpac stop string ""
spectreVerilog.qpac center string ""
spectreVerilog.qpac span string ""
spectreVerilog.qpac incrType string "Automatic"
spectreVerilog.qpac stepTypeLin string "Step Size"
spectreVerilog.qpac stepTypeLog string "Points Per Decade"
spectreVerilog.qpac step string ""
spectreVerilog.qpac lin string ""
spectreVerilog.qpac dec string ""
spectreVerilog.qpac log string ""
spectreVerilog.qpac useDiscrete boolean nil
spectreVerilog.qpac values string ""
spectreVerilog.qpac sbsm string "Maximum clock order"
spectreVerilog.qpac clockmaxharm string ""
spectreVerilog.qpac selFreqFrom string "0"
spectreVerilog.qpac selFreqTo string "1e12"
spectreVerilog.qpac order string "1"
spectreVerilog.qpac harmsAndFreqsTitle string ""
spectreVerilog.qpac harmsAndFreqsTitle2 string ""
spectreVerilog.qpac harmsAndFreqs string ""
spectreVerilog.qpac arrayCoeffs string ""
spectreVerilog.qpac harmCoeffs string ""
spectreVerilog.qpac harmListMem string ""
spectreVerilog.qpac sidevec string ""
;spectreVerilog qpacOpts partition variables
spectreVerilog.qpacOpts tolerance string ""
spectreVerilog.qpacOpts gear_order string ""
spectreVerilog.qpacOpts solver string ""
spectreVerilog.qpacOpts stats string ""
spectreVerilog.qpacOpts annotate string "status"
spectreVerilog.qpacOpts freqaxis string ""
spectreVerilog.qpacOpts save string ""
spectreVerilog.qpacOpts nestlvl string ""
;spectreVerilog qpnoise partition variables
spectreVerilog.qpnoise enable toggle (nil)
spectreVerilog.qpnoise singlePt string "Single-Point []"
spectreVerilog.qpnoise sweeptype string " "
spectreVerilog.qpnoise relharmvec string ""
spectreVerilog.qpnoise rangeType string "Start-Stop"
spectreVerilog.qpnoise start string ""
spectreVerilog.qpnoise stop string ""
spectreVerilog.qpnoise center string ""
spectreVerilog.qpnoise span string ""
spectreVerilog.qpnoise incrType string "Automatic"
spectreVerilog.qpnoise stepTypeLin string "Step Size"
spectreVerilog.qpnoise stepTypeLog string "Points Per Decade"
spectreVerilog.qpnoise step string ""
spectreVerilog.qpnoise lin string ""
spectreVerilog.qpnoise dec string ""
spectreVerilog.qpnoise log string ""
spectreVerilog.qpnoise useDiscrete boolean nil
spectreVerilog.qpnoise values string ""
spectreVerilog.qpnoise sbsm string "Maximum clock order"
spectreVerilog.qpnoise clockmaxharm string ""
spectreVerilog.qpnoise selFreqFrom string "0"
spectreVerilog.qpnoise selFreqTo string "1e12"
spectreVerilog.qpnoise order string "1"
spectreVerilog.qpnoise harmsAndFreqsTitle string ""
spectreVerilog.qpnoise harmsAndFreqsTitle2 string ""
spectreVerilog.qpnoise harmsAndFreqs string ""
spectreVerilog.qpnoise arrayCoeffs string ""
spectreVerilog.qpnoise harmCoeffs string ""
spectreVerilog.qpnoise harmListMem string ""
spectreVerilog.qpnoise sidevec string ""
spectreVerilog.qpnoise outType string "probe"
spectreVerilog.qpnoise p string ""
spectreVerilog.qpnoise n string ""
spectreVerilog.qpnoise oprobe string ""
spectreVerilog.qpnoise inType string "port"
spectreVerilog.qpnoise inVsrc string ""
spectreVerilog.qpnoise inIsrc string ""
spectreVerilog.qpnoise iprobe string ""
spectreVerilog.qpnoise inPort string ""
spectreVerilog.qpnoise refsbSelect string "Enter in field"
spectreVerilog.qpnoise refsideband string ""
spectreVerilog.qpnoise refsbFreqFrom string "0"
spectreVerilog.qpnoise refsbFreqTo string "1e12"
spectreVerilog.qpnoise refsbOrder string "1"
spectreVerilog.qpnoise refsbTitle string ""
spectreVerilog.qpnoise refsbListbox string ""
;spectreVerilog qpnoiseOpts partition variables
spectreVerilog.qpnoiseOpts tolerance string ""
spectreVerilog.qpnoiseOpts gear_order string ""
spectreVerilog.qpnoiseOpts solver string ""
spectreVerilog.qpnoiseOpts stats string ""
spectreVerilog.qpnoiseOpts annotate string "status"
spectreVerilog.qpnoiseOpts save string ""
spectreVerilog.qpnoiseOpts nestlvl string ""
spectreVerilog.qpnoiseOpts saveallsidebands string ""
;spectreVerilog qpxf partition variables
spectreVerilog.qpxf enable toggle (nil)
spectreVerilog.qpxf singlePt string "Single-Point []"
spectreVerilog.qpxf sweeptype string " "
spectreVerilog.qpxf relharmvec string ""
spectreVerilog.qpxf rangeType string "Start-Stop"
spectreVerilog.qpxf start string ""
spectreVerilog.qpxf stop string ""
spectreVerilog.qpxf center string ""
spectreVerilog.qpxf span string ""
spectreVerilog.qpxf incrType string "Automatic"
spectreVerilog.qpxf stepTypeLin string "Step Size"
spectreVerilog.qpxf stepTypeLog string "Points Per Decade"
spectreVerilog.qpxf step string ""
spectreVerilog.qpxf lin string ""
spectreVerilog.qpxf dec string ""
spectreVerilog.qpxf log string ""
spectreVerilog.qpxf useDiscrete boolean nil
spectreVerilog.qpxf values string ""
spectreVerilog.qpxf sbsm string "Maximum clock order"
spectreVerilog.qpxf clockmaxharm string ""
spectreVerilog.qpxf selFreqFrom string "0"
spectreVerilog.qpxf selFreqTo string "1e12"
spectreVerilog.qpxf order string "1"
spectreVerilog.qpxf harmsAndFreqsTitle string ""
spectreVerilog.qpxf harmsAndFreqsTitle2 string ""
spectreVerilog.qpxf harmsAndFreqs string ""
spectreVerilog.qpxf arrayCoeffs string ""
spectreVerilog.qpxf harmCoeffs string ""
spectreVerilog.qpxf harmListMem string ""
spectreVerilog.qpxf sidevec string ""
spectreVerilog.qpxf outType string "voltage"
spectreVerilog.qpxf p string ""
spectreVerilog.qpxf n string ""
spectreVerilog.qpxf probe string ""
;spectreVerilog qpxfOpts partition variables
spectreVerilog.qpxfOpts tolerance string ""
spectreVerilog.qpxfOpts gear_order string ""
spectreVerilog.qpxfOpts solver string ""
spectreVerilog.qpxfOpts stats string ""
spectreVerilog.qpxfOpts annotate string "status"
spectreVerilog.qpxfOpts stimuli string ""
spectreVerilog.qpxfOpts freqaxis string ""
spectreVerilog.qpxfOpts save string ""
spectreVerilog.qpxfOpts nestlvl string ""
;spectreVerilog qpsp partition variables
spectreVerilog.qpsp enable toggle (nil)
spectreVerilog.qpsp singlePt string "Single-Point []"
spectreVerilog.qpsp sweeptype string " "
spectreVerilog.qpsp rangeType string "Start-Stop"
spectreVerilog.qpsp start string ""
spectreVerilog.qpsp stop string ""
spectreVerilog.qpsp center string ""
spectreVerilog.qpsp span string ""
spectreVerilog.qpsp incrType string "Automatic"
spectreVerilog.qpsp stepTypeLin string "Step Size"
spectreVerilog.qpsp stepTypeLog string "Points Per Decade"
spectreVerilog.qpsp step string ""
spectreVerilog.qpsp lin string ""
spectreVerilog.qpsp dec string ""
spectreVerilog.qpsp log string ""
spectreVerilog.qpsp useDiscrete boolean nil
spectreVerilog.qpsp values string ""
spectreVerilog.qpsp portharmsvec string ""
spectreVerilog.qpsp ports string ""
spectreVerilog.qpsp selectPorts boolean t
spectreVerilog.qpsp harmsvec string ""
spectreVerilog.qpsp freqRange string ""
spectreVerilog.qpsp listPortHarm string ""
spectreVerilog.qpsp listPortName string ""
spectreVerilog.qpsp listPortNum string ""
spectreVerilog.qpsp portChoiceList string ""
spectreVerilog.qpsp portChoiceListHeading string ""
spectreVerilog.qpsp donoise string "yes"
spectreVerilog.qpsp clockmaxharm string ""
;spectreVerilog qpspOpts partition variables
spectreVerilog.qpspOpts tolerance string ""
spectreVerilog.qpspOpts gear_order string ""
spectreVerilog.qpspOpts solver string ""
spectreVerilog.qpspOpts annotate string "status"
spectreVerilog.qpspOpts stats string ""
spectreVerilog.qpspOpts freqaxis string ""
;spectreVerilog sens partition variables
spectreVerilog.sens enable toggle (nil)
spectreVerilog.sens sensType toggle (nil nil nil)
spectreVerilog.sens analyses_list string ""
spectreVerilog.sens outputs string ""
spectreVerilog.sens output_list string ""
spectreVerilog.sens net string ""
spectreVerilog.sens term string ""
;spectreVerilog sensOpts partition variables
;spice3 environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spice3 outputs partition variables
spice3.outputs allAnalogNV boolean t
spice3.outputs allAnalogTC boolean nil
;spice3 envOpts partition variables
spice3.envOpts stopViewList string "spice3"
spice3.envOpts printComments boolean nil
spice3.envOpts autoDisplay boolean t
spice3.envOpts switchViewList string "spice3 cmos_sch cmos.sch schematic veriloga ahdl"
;spice3 init partition variables
;spice3 opts partition variables
spice3.opts ITL5 string "5000"
spice3.opts ITL4 string "10"
spice3.opts DEFAD string "0.0"
spice3.opts RELTOL string "1e-3"
spice3.opts METHOD string ""
spice3.opts DEFAS string "0.0"
spice3.opts CHGTOL string "1e-14"
spice3.opts GMIN string "1e-12"
spice3.opts DEFW string "100.0"
spice3.opts TEMP string "27"
spice3.opts PIVREL string "1e-3"
spice3.opts TRTOL string "7.0"
spice3.opts VNTOL string "1e-6"
spice3.opts DEFL string "100.0"
spice3.opts ITL3 string "4"
spice3.opts ITL2 string "50"
spice3.opts ITL1 string "100"
spice3.opts TNOM string "27"
spice3.opts PIVTOL string "1e-13"
spice3.opts ABSTOL string "1e-12"
;spice3 dc partition variables
spice3.dc enable toggle (nil)
spice3.dc vstart string ""
spice3.dc vstop string ""
spice3.dc vincr string ""
spice3.dc srcnam string ""
;spice3 dcOpts partition variables
;spice3 ac partition variables
spice3.ac enable toggle (nil)
spice3.ac fstart string ""
spice3.ac fstop string ""
spice3.ac incrType string "DEC"
spice3.ac log string ""
spice3.ac lin string ""
;spice3 acOpts partition variables
;spice3 tran partition variables
spice3.tran enable toggle (nil)
spice3.tran tstart string ""
spice3.tran tstop string ""
spice3.tran tstep string ""
spice3.tran tmax string ""
;spice3 tranOpts partition variables
;SCA Extraction Environment Defaults
;FORMAT: tool[.partition] varName type value private {choices, minmax} comment
subx subRunDir string "./SCA"
subx subProcFile string "./sample.proc"
subx subModelName string "substrate"
subx subAccuLevel string "medium"
subx subFreq string "1e9"
subx subSync boolean t
subx subNetexpDefault string "scagnd!"
subx subNetexpProp string ""
subx subMethod string "full"
;User Preference Defaults
ui winPlaceStyle boolean nil
ui setWinTraversal boolean nil
ui showScrollBars boolean nil
ui showPromptLines boolean t
ui showStatusLines boolean t
ui showFixedMenu cyclic "On Left-Side "
ui showFixedMenuLabels boolean t
ui infix boolean nil
ui showOptionForms boolean nil
ui undoLevel int 1
ui nestLimit int 5
ui dblClkTime int 200
ui beepVolume int 0
ui textFont string "-*-courier-medium-r-*-*-12-*-*-*-*-*-iso8859-1"
ui formButtonLocation cyclic "Top "
;Log Filter Defaults
ui menuCmdInput boolean nil
ui promptInput boolean nil
ui userOutput boolean t
ui menuCmdOutput boolean nil
ui progResultsOutput boolean t
ui errorMsg boolean t
ui warningMsg boolean t
ui dragDisplayHint string "normal"
vhdl analyzeMode cyclic "on"
vhdl batchScriptFile string ""
vhdl batchSim cyclic "interactive"
vhdl compareSimDB string "simcmp.log"
vhdl Cosim9404 boolean nil
vhdl createVHDLDir boolean t
vhdl currentSimDB string ""
vhdl dataLocation string ""
vhdl defAttributes string ""
vhdl defBodyViewName string "body"
vhdl defConfigViewName string "configuration"
vhdl defDataDirectory string "vhdllib"
vhdl defEntityViewName string "entity"
vhdl defGenerics string ""
vhdl defGlobals string "(("vdd!" "'1'")("gnd!" "'0'"))"
vhdl defPackageNames string "ieee.std_logic_1164.all"
vhdl defPackageViewName string "package"
vhdl defScalarType string "std_ulogic"
vhdl defVectorType string "std_ulogic_vector"
vhdl defViewName string "vhdl"
vhdl deleteVHDLDir boolean nil
vhdl displaySimCmpResults boolean t
vhdl elaborateMode cyclic "on"
vhdl exportCatFiles boolean t
vhdl exportDirectory string ""
vhdl exportLibNameExt string ".exp"
vhdl exportNetlist cyclic "off"
vhdl generateComponentConfig boolean nil
vhdl goldenSimDB string ""
vhdl ignoreWarnings boolean nil
vhdl importCaseSensitivity boolean t
vhdl importCompatibilityOpt boolean nil
vhdl importCompileAfterImport boolean nil
vhdl importCompilerOptions string ""
vhdl importComponentDensity int 0
vhdl importConfig boolean nil
vhdl importFileFilter string "*.vhd"
vhdl importFontHeight float 0.0625
vhdl importFullPlaceRoute boolean t
vhdl importGenSymbols boolean nil
vhdl importGroundLiterals string "'0'"
vhdl importGroundNetName string "gnd!"
vhdl importGroundType string "std_ulogic"
vhdl importIgnoreContassFunc boolean nil
vhdl importIgnoreExtraPins boolean nil
vhdl importLibName string ""
vhdl importLineComponentSpacing float 0.5
vhdl importLineLineSpacing float 0.2
vhdl importMaxNoCols int 1024
vhdl importMaxNoRows int 1024
vhdl importMinmizeCrossovers boolean t
vhdl importOptimizeLabels boolean t
vhdl importOverwriteExistingView boolean t
vhdl importPinPlacement cyclic "Left and Right Sides"
vhdl importPinPlacementFile string ""
vhdl importPowerLiterals string "'1'"
vhdl importPowerNetName string "vdd!"
vhdl importPowerType string "std_ulogic"
vhdl importReferenceLibraries string "basic US_8ths ieee std sample"
vhdl importRunInBackground boolean t
vhdl importSeparateUnits boolean t
vhdl importSheetBorderSize string ""
vhdl importSquareSchematics boolean t
vhdl importStructuralViewType cyclic "schematic"
vhdl importSummaryFile string "./vhdlin.summary"
vhdl importSymbolViewName string "symbol"
vhdl importv93Opt boolean nil
vhdl importWorkLibName string ""
vhdl invokeLaunchTool boolean nil
vhdl invokeLeapfrogSystemWindow boolean nil
vhdl invokeNCTools boolean t
vhdl libCellViewCaseSensitive boolean t
vhdl maxErrors int 10
vhdl netConfig string "config1"
vhdl netHierSpec cyclic "Simple"
vhdl netIgnoreUnboundCells boolean nil
vhdl netMode cyclic "incremental"
vhdl netScope cyclic "hierarchy"
vhdl overwriteEntity boolean nil
vhdl portMapMode cyclic "named association"
vhdl printCommand string "lpr"
vhdl rangeDir cyclic "default"
vhdl remoteFileAccess cyclic "Automount"
vhdl remoteHostName string "localhost"
vhdl remoteSim cyclic "locally"
vhdl runCheckBeforeSim boolean t
vhdl schHdlParseUsingNcvhdl boolean t
vhdl simCompareLength int 100
vhdl simCompareOffset int 0
vhdl simModel string "SIM"
vhdl simTimeUnits cyclic "ns"
vhdl simTolerance int 0
vhdl stopLibList string "basic sample ieee"
vhdl stopViewList string "symbol"
vhdl switchViewList string "stimulus schematic structure dataflow behavior symbol"
vhdl synergySourceLibrary string ""
vhdl synergySymbolLibraries string "basic US_8ths"
vhdl testBenchCellName string "test"
vhdl testBenchLibName string ""
vhdl testBenchStimulusFile string ""
vhdl testBenchViewName string "stimulus"
vhdl testModeOn boolean nil
vhdl topCellName string ""
vhdl topLevelInstanceName string "dut"
vhdl topLibraryName string ""
vhdl topVersion string ""
vhdl topViewName string "schematic"
vhdl translateMode cyclic "library"
vhdl translateTypes toggle (t t t)
vhdl useUserLibraries boolean nil
vhdl verilogNetlistOpts string ""
vhdl verilogRunDir string ""
vhdl verilogSimOpts string "-q"
vhdl vhdlIdentCaseSensitive boolean t
vhdl whichVLibsFile cyclic "user"
vhdl workCellName string ""
vhdl workLibraryName string ""
vhdl workVersion string ""
vhdl workViewName string "schematic"
vhdlams Cosim9404 boolean nil
vhdlams analyzeMode cyclic "on"
vhdlams batchScriptFile string ""
vhdlams batchSim cyclic "interactive"
vhdlams compareSimDB string "simcmp.log"
vhdlams createVHDLDir boolean t
vhdlams currentSimDB string ""
vhdlams dataLocation string ""
vhdlams defAttributes string ""
vhdlams defBodyViewName string "body"
vhdlams defConfigViewName string "configuration"
vhdlams defDataDirectory string "vhdllib"
vhdlams defEntityViewName string "entity"
vhdlams defGenerics string ""
vhdlams defGlobals string "(("vdd!" "'1'")("gnd!" "'0'"))"
vhdlams defPackageNames string "ieee.std_logic_1164.all ieee.electrical_systems.all"
vhdlams defPackageViewName string "package"
vhdlams defScalarType string "electrical"
vhdlams defVectorType string "std_ulogic_vector"
vhdlams defScalarDomain string "terminal"
vhdlams defVectorDomain string "signal"
vhdlams defViewName string "vhdl"
vhdlams deleteVHDLDir boolean nil
vhdlams displaySimCmpResults boolean t
vhdlams elaborateMode cyclic "on"
vhdlams exportCatFiles boolean t
vhdlams exportDirectory string ""
vhdlams exportLibNameExt string ".exp"
vhdlams exportNetlist cyclic "off"
vhdlams generateComponentConfig boolean nil
vhdlams goldenSimDB string ""
vhdlams ignoreWarnings boolean nil
vhdlams importCaseSensitivity boolean t
vhdlams importCompatibilityOpt boolean nil
vhdlams importCompileAfterImport boolean nil
vhdlams importCompilerOptions string ""
vhdlams importComponentDensity int 0
vhdlams importConfig boolean nil
vhdlams importFileFilter string "*.vhd"
vhdlams importFontHeight float 0.0625
vhdlams importFullPlaceRoute boolean t
vhdlams importGenSymbols boolean nil
vhdlams importGroundLiterals string "'0'"
vhdlams importGroundNetName string "gnd!"
vhdlams importGroundType string "std_ulogic"
vhdlams importIgnoreContassFunc boolean nil
vhdlams importIgnoreExtraPins boolean nil
vhdlams importLibName string ""
vhdlams importLineComponentSpacing float 0.5
vhdlams importLineLineSpacing float 0.2
vhdlams importMaxNoCols int 1024
vhdlams importMaxNoRows int 1024
vhdlams importMinmizeCrossovers boolean t
vhdlams importOptimizeLabels boolean t
vhdlams importOverwriteExistingView boolean t
vhdlams importPinPlacement cyclic "Left and Right Sides"
vhdlams importPinPlacementFile string ""
vhdlams importPowerLiterals string "'1'"
vhdlams importPowerNetName string "vdd!"
vhdlams importPowerType string "std_ulogic"
vhdlams importReferenceLibraries string "basic US_8ths ieee std sample"
vhdlams importRunInBackground boolean t
vhdlams importSeparateUnits boolean t
vhdlams importSheetBorderSize string ""
vhdlams importSquareSchematics boolean t
vhdlams importStructuralViewType cyclic "schematic"
vhdlams importSummaryFile string "./vhdlin.summary"
vhdlams importSymbolViewName string "symbol"
vhdlams importWorkLibName string ""
vhdlams importv93Opt boolean nil
vhdlams invokeLaunchTool boolean nil
vhdlams invokeLeapfrogSystemWindow boolean nil
vhdlams invokeNCTools boolean t
vhdlams libCellViewCaseSensitive boolean t
vhdlams maxErrors int 10
vhdlams netConfig string "config1"
vhdlams netHierSpec cyclic "Simple"
vhdlams netIgnoreUnboundCells boolean nil
vhdlams netMode cyclic "incremental"
vhdlams netScope cyclic "hierarchy"
vhdlams overwriteEntity boolean nil
vhdlams portMapMode cyclic "named association"
vhdlams printCommand string "lpr"
vhdlams rangeDir cyclic "default"
vhdlams remoteFileAccess cyclic "Automount"
vhdlams remoteHostName string "localhost"
vhdlams remoteSim cyclic "locally"
vhdlams runCheckBeforeSim boolean t
vhdlams schHdlParseUsingNcvhdl boolean t
vhdlams simCompareLength int 100
vhdlams simCompareOffset int 0
vhdlams simModel string "SIM"
vhdlams simTimeUnits cyclic "ns"
vhdlams simTolerance int 0
vhdlams stopLibList string "basic sample ieee"
vhdlams stopViewList string "symbol"
vhdlams switchViewList string "stimulus schematic structure dataflow behavior symbol"
vhdlams synergySourceLibrary string ""
vhdlams synergySymbolLibraries string "basic US_8ths"
vhdlams testBenchCellName string "test"
vhdlams testBenchLibName string ""
vhdlams testBenchStimulusFile string ""
vhdlams testBenchViewName string "stimulus"
vhdlams testModeOn boolean nil
vhdlams topCellName string ""
vhdlams topLevelInstanceName string "dut"
vhdlams topLibraryName string ""
vhdlams topVersion string ""
vhdlams topViewName string "schematic"
vhdlams translateMode cyclic "library"
vhdlams translateTypes toggle (t t t)
vhdlams verilogNetlistOpts string ""
vhdlams verilogRunDir string ""
vhdlams verilogSimOpts string "-q"
vhdlams vhdlIdentCaseSensitive boolean t
vhdlams whichVLibsFile cyclic "user"
vhdlams workCellName string ""
vhdlams workLibraryName string ""
vhdlams workVersion string ""
vhdlams workViewName string "schematic"
.cdsinit file for my home directory is:
filepath: <cds_install_dir>/samples/local/cdsinit
dfII version: 4.4
This file should be copied as <cds_install_dir>/local/.cdsinit
and customized as a site startup file. The site startup file is
read and executed when the Design Framework II software starts.
This file can load all the application configuration files and
application bind key files.
It also sets the library search path ( which may be overriden by the
user customization file.
Finally this file transfers control to the user by executing the
The user customization file may be
./.cdsinit - .cdsinit in the working directory
~/.cdsinit - .cdsinit in the user's home directory
This site file checks if a .cdsinit exists in the working directory
and executes it. If .cdsinit does not exist in the user's working
directory then ~/.cdsinit is executed if it exists.
Please read the entire file and the comments before you start
customizing the file. See the section below on File Installation
for a list of sample files supplied.
There are bind key definition files supplied for different
applications. The relevant bind key definitions files must
be loaded if you want bind keys defined for that application.
See section LOAD APPLICATION BIND KEY DEFINITIONS.
In order for any window placements to work correctly the following
X resource must be set in the .Xdefaults or .xresources file
pertaining to your hardware platform.
Mwm*clientAutoPlace: False
After setting the resource read in the resource file with the command
xrdb <resource_filename>
and restart the Motif window manager.
The function
prependInstallPath("string")
adds the installation path to the string argument
For this reason there should NOT be a space at the beginning of the
string.
There SHOULD be a space at the end of the string if more paths are to
follow.
This function is used to make path specification in this file
independant of the exact installation path.
The function let() creates local variables ( example: libPath ).
This makes sure that any global variables are not accidentally modified.
; File Installation
; CONFIGURATION FILES
; The following configuration files are delivered in the 4.4 release:
; <cds_install_dir>/samples/local
; aaConfig.il - analog
; dciConfig.il - Cadence to Synopsys Interface
; metConfig.il - Designing with Composer
; using metric measurements
; sysConfig.il - systems
; uiConfig.il - user interface
; The configuration files are used to initialize parameters and
; forms.
; ENVIRONMENT VARIABLES
; Schematic, Layout and Graphic environment variable defaults are now found in
; <cds_install_dir>/etc/tools/
; layout/.cdsenv
; schematic/.cdsenv
; graphic/.cdsenv
; These can be customized in the user's ./cdsenv and ~/.cdsenv files.
; A .cdsenv file can be created by using CIW->options->save defaults.
; BIND KEY DEFINITION FILES
; The following bind key definition files are delivered in the
; 4.3 release:
; leBindKeys.il - layout editor
; schBindKeys.il - schematic editor
; CUSTOMIZATION FILES
; The following customization files are delivered in the
; 4.3 release:
; <cds_install_dir>/samples/local/cdsinit - site customization
; <cds_install_dir>/cdsuser/.cdsinit - user customization
; ADMINISTRATION
; The site administrator should install the "site" files as follows: ;
; 1. Copy <cds_install_dir>/samples/local/cdsinit
; to <cds_install_dir>/local/.cdsinit
; and modify the file
; (If <cds_install_dir>/local does not exist create it)
; <cds_install_dir>/local is the site customization directory.
; This directory is not sent as part of the software. The site
; administrator must create this directory. Whenever software is
; upgraded the Cadence installation process retains the site
; administration directory if it exists.
; 2. If default configuration needs to be changed copy the
; relevant configuration file
; from: 4.3/samples/local
; to: 4.3/local
; and modify the file(s)
; 3. If default bind key definitions need to be changed copy the
; relevant bind key definition file
; to: 4.3/local
; 4. Copy 4.3/cdsuser/.cdsinit to the user's home or working
; directory - Do this step only if the user does not already
; have a .cdsinit file.
; If after site customization each user wants to customize
; portions of the configuration or bind keys definitions
; they should copy the relevant sections from the files in
; 4.3/samples/local
; into
; the user's customization file
; ./.cdsinit or ~/.cdsinit
; FILE LOADING ORDER
; 1. The configuration files are not automatically loaded.
; Remove the comment on the filename line to load the file.
; The search order for the configuration files is:
; 4.3/local
; 2. The bind key definition files are not automatically loaded.
; The search order for the bind key definition files is:
; 4.3/local
; 4.3/samples/local
; 3. Load user customization file
; ./.cdsinit - load .cdsinit in the working directory if it exists
; else
; ~/.cdsinit - load .cdsinit in the user's home directory
; This file does NOT load both user customization files even if both exist.
;# LOAD APPLICATION CONFIGURATION FILES
;Remove the comment ; if you want to load the specific configuration file
;If you do not load the configuration files the applications will use the
;default configurations.
let( (configFileList file path saveSkillPath)
configFileList = '(
; "aaConfig.il"
; "dciConfig.il"
; "leConfig.il"
; "metConfig.il"
; "schConfig.il"
; "sysConfig.il"
; "uiConfig.il"
; This is the path that is searched for the files
path = strcat(
; If you want to add another path add it here as a string
prependInstallPath("local ")
saveSkillPath=getSkillPath()
setSkillPath(path)
foreach(file configFileList
if(isFile(file) then
loadi(file)
setSkillPath(saveSkillPath)
hiiSetFont("text" "-adobe-courier-bold-r-*-*-12-*")
;# LOAD APPLICATION BIND KEY DEFINITIONS
;Add the comment ; if you do not want to load the specific
;bind key definition file.
;If you do not load the bind key definitions the applications will not
;have any bind keys defined.
;If you load the bind key definition file but the application is not
;registered ( product not licensed or checked out ) then you might get
;a warning that looks like
; *WARNING* "Schematics is not registered yet"
;This warning can be ignored if you know that the product is not
;licensed or checked out.
let( (bindKeyFileList file path saveSkillPath)
bindKeyFileList = '(
"leBindKeys.il"
"schBindKeys.il"
path = strcat(
prependInstallPath("samples/local")
setSkillPath(path)
foreach(file bindKeyFileList
if(isFile(file ) then
loadi(file)
; An individual user may wish to add some bindkeys of his/her own or
; over ride some default loaded bindkeys. For more information about
; bindkeys see the manual "SKILL Reference Manual, Language Fundamentals",
; Chapter 4.
; Here is an example of setting one bindkey on "F2" than prints
; "Hello world" to the CIW when pressed in the CIW.
;hiSetBindKey("Command Interpreter" "<Key>F2" "printf("Hello World")")
; Here is an example of setting keys for more than one application
;let( (app appList)
; appList = '(
; "Command Interpreter"
; "Schematics"
; "Symbol"
; Add other applications here
; foreach(app appList
; hiSetBindKey(app "<Key>F4" "printf("Hello ")")
; hiSetBindKey(app "<Key>F5" "printf("World")")
;# SETTINGS FOR SKILL PATH and SKILL PROGRAMMING
; The function sstatus() sets the status of variables
; The variable writeProtect controls if a SKILL function can be
; redefined or not;
; Any functions defined after writeProtect = t CANNOT be redefined
; Any functions defined after writeProtect = nil CAN be redefined
; If you are going to create SKILL programs and define functions set the
; status of writeProtect to nil at the beginning of your session.
; Set skill search path. The SKILL search path contains directories
; to be searched to locate SKILL programs when program names are
; specified without full path names.
; The operation could be reading, writing or loading a SKILL program.
; Source technology files are considered SKILL files and when loading
; or dumping the technology file SKILL search path will be used.
sstatus(writeProtect nil)
let((skillPath)
skillPath= strcat(
". ~ " ; Current & home directory
prependInstallPath("samples/techfile ") ; sample source technology files
setSkillPath(skillPath)
; VERIFICATION - DIVA/INQUERY/DRACULA ENCAPS #
; There are no configuration variables for these
; applications to be set in the .cdsinit. You may
; need to create a .simrc file, using the example
; in <cds_install_dir>/cdsuser/.simrc
;# PLACE AND ROUTE - CELL3, CE, BE, PREVIEW,GE #
; The geSetProbeNetStopLevel default is zero.
; To probe routing in channels, it must be >= 2.
; geSetProbeNetStopLevel(0) ; 20 is a good number.
;# LAS and COMPACTOR #
; applications to be set in the .cdsinit. You need
; to add information to your technology file. See
; the LAS and COMPACTOR reference manuals for
; details about technology file additions.
;# Customizing the 4.x environment with: #
;# SETTING AmPLD DEFAULTS (Data I/O Abel 4.x) #
; No Setup is required if using the default system shipped from Cadence.
; If you are using your own Abel or need to customize the system Please
; See Appendix A of the Programmable Logic Design System Users Guide.
;# DESIGN FLOWS #
; The design flows can be used with no customization, but customizing
; them for your personal preference can greatly enhance your
; productivity. Please See the Design Flow users guide for details.
; Bring up top flow ...
;amdfTopFlow()
;# MISCELLANEOUS
; Set your own prompt in the CIW. The first argument is the prompt.
; The second argument is not used yet.
; The variable editor defines the text editor to be used when any of
; the applications invoke an editor. For example technology dump and
; edit operation opens an editor window.
; The editor may also be set by
; unix environment variable EDITOR
; setenv EDITOR 'xedit'
; When Design Framework is invoked the SKILL variable editor is set
; to the value of the unix variable EDITOR.
; If EDITOR is not defined the SKILL variable
; editor is set to "vi"
; You may also set the variable to execute a UNIX command
; that invokes an xterm window of given size and location
; and starts an editor program.
; Example:
; editor = "xterm -geometry 80x40 -e emacs"
; Size of xterm in the above example is 80 characters by 40 lines.
; With some editors on certain platforms the variable editor must
; be defined as shown above.
; Some application which require a text editor may be using the UNIX
; variable EDITOR instead of the SKILL variable editor. It is a good
; idea to set the UNIX variable EDITOR to the text editor of your
; choice which will automatically set the SKILL variable editor.
;setPrompts("Ready >" "")
;editor = "xterm -geometry 85x50 -e vi";
printf("END OF SITE CUSTOMIZATION\n")
;# LOAD USER CUSTOMIZATION FILE
;The site customization file is going to load the user
;customization file. In case you have copied this site
;customization file as your user customization file
;comment out or remove the next section to prevent
;recursive loading of ./.cdsinit
load(strcat(getShellEnvVar("MGC_HOME")
"/shared/pkgs/icv.x86/tools/queryskl/calibre.skl"))
load("./leBindKeys.il")
;//# SONNET CADENCE VIRTUOSO INTERFACE SETUP
;END OF THE SITE CUSTOMIZATION FILE
.cdsenv file for my home directory is:
";This is a sample environment variable file containing the default
;values for environment variables in Design Framework II products.
;See the appropriate tool documentation regarding the use and
;choices for each variable.
;To customize your defaults, use this file as a template and place
;a modified version of this file in ../local/.cdsenv. This
;local version should typically reflect the values of your system
;defaults as set by your site coordinator. To specify more personal
;defaults, place a modified version of either this or the
;../local/.cdsenv file into your home directory as .cdsenv.
;Your ../local/.cdsenv file will be loaded first, followed
;by the .cdsenv in your home directory, so any values in ~/.cdsenv
;will override those previously loaded.
;UltraSim environment variables
;UltraSim opts partition variables
UltraSim.opts UsimRAAgeDomain string "loglog"
UltraSim.opts rshort string "1e-6"
UltraSim.opts simSave boolean nil
UltraSim.opts abstoli string "1.00e-12"
UltraSim.opts UsimTAMaxPerTime string ""
UltraSim.opts UsimPAEnabled boolean nil
UltraSim.opts UsimNAOutputSort string "name"
UltraSim.opts simSaveFile string ""
UltraSim.opts UsimTASigNames string ""
UltraSim.opts dc string "Complete DC (1)"
UltraSim.opts TNOMDC string "27"
UltraSim.opts other string ""
UltraSim.opts UsimPADepth string "1"
UltraSim.opts simRestart boolean nil
UltraSim.opts otherSpice string ""
UltraSim.opts wf_tres string "1e-12"
UltraSim.opts UsimPATimeIntervals string ""
UltraSim.opts UsimRAMode string "HCI only"
UltraSim.opts rcr_fmax string "1e9"
UltraSim.opts simTimePoints string ""
UltraSim.opts UsimTASigEdgeType string "rise"
UltraSim.opts UsimRADeltaDToggle boolean t
UltraSim.opts tol string "0.01"
UltraSim.opts wf_reltol string ""
UltraSim.opts wf_abstoli string "1e-12"
UltraSim.opts UsimTARefSigEdgeType string "rise"
UltraSim.opts wf_format string "PSF"
UltraSim.opts UsimRAAgeMethod string "interp"
UltraSim.opts UsimTASigLowThreshold string ""
UltraSim.opts UsimTAEnabled boolean nil
UltraSim.opts UsimTAMinLowTime string ""
UltraSim.opts UsimNA toggle (nil)
UltraSim.opts postl string "No RCR (0)"
UltraSim.opts abstolv string "1.00e-06"
UltraSim.opts diode_method string "Analog Table (A)"
UltraSim.opts UsimRAAgeproc string ""
UltraSim.opts ParasiticRCFile string ""
UltraSim.opts UsimTAMinHighTime string ""
UltraSim.opts UsimOptMethod boolean nil
UltraSim.opts UsimPA toggle (nil)
UltraSim.opts UsimRAMinAge float 0.0
UltraSim.opts UsimTA toggle (nil)
UltraSim.opts UsimTAMaxHighTime string ""
UltraSim.opts wf_abstolv string "1e-6"
UltraSim.opts UsimRADeltaD float 0.1
UltraSim.opts simLoadFile string ""
UltraSim.opts UsimPALimit string ""
UltraSim.opts TEMPDC string "27"
UltraSim.opts UsimTARefSig string ""
UltraSim.opts mos_method string "Analog/MS Table (A)"
UltraSim.opts UsimRANBTIAgeproc string ""
UltraSim.opts wf_filter boolean t
UltraSim.opts UsimTARefSigHighThreshold string ""
UltraSim.opts UsimTANegWindow string ""
UltraSim.opts UsimTASigHighThreshold string ""
UltraSim.opts UsimTAMinPerTime string ""
UltraSim.opts UsimTAReportTitle string ""
UltraSim.opts dump_step string ""
UltraSim.opts speed string "Default (5)"
UltraSim.opts dcut boolean nil
UltraSim.opts UsimPAPort string ""
UltraSim.opts UsimTASubcktName string ""
UltraSim.opts UsimNALimit string ""
UltraSim.opts UsimRAAgingTime string "10y"
UltraSim.opts scale string "1.0"
UltraSim.opts rvshort string "1e-6"
UltraSim.opts UsimPAName string ""
UltraSim.opts analog string "Default (1)"
UltraSim.opts UsimTAMaxLowTime string ""
UltraSim.opts UsimPAOutputSort string "avg"
UltraSim.opts UsimPAPower boolean nil
UltraSim.opts UsimTASetupTime string ""
UltraSim.opts lshort string "0"
UltraSim.opts dcut_field string ""
UltraSim.opts UsimTATrigger string "both"
UltraSim.opts UsimOptMethodHier boolean nil
UltraSim.opts simRepeat string ""
UltraSim.opts sim_mode string "Mixed Signal (MS)"
UltraSim.opts cgndr string "0"
UltraSim.opts UsimTADisplaySetting string ""
UltraSim.opts cgnd string "1e-20"
UltraSim.opts UsimRA toggle (nil)
UltraSim.opts UsimTARefSigLowThreshold string ""
UltraSim.opts UsimTACheckType string "setup"
UltraSim.opts UsimNASortIs string "inc"
UltraSim.opts scalem string "1.0"
UltraSim.opts UsimTADepth string ""
UltraSim.opts UsimPADisplaySetting string ""
UltraSim.opts lvshort string "0"
;UltraSim outputs partition variables
UltraSim.outputs UsimOptionLogicSubckt3 string ""
UltraSim.outputs UsimOptionLogicDepth3 string "1"
UltraSim.outputs UsimOptionProbeAnalog boolean t
UltraSim.outputs UsimOptionAllLogicNV5 boolean nil
UltraSim.outputs UsimOptionLogicLowThreshold string ""
UltraSim.outputs UsimOptionLogicSubckt2 string ""
UltraSim.outputs UsimOptionLogicHighThreshold string ""
UltraSim.outputs UsimOptionLogicIncludeRC boolean nil
UltraSim.outputs UsimOptionLogicSubckt string ""
UltraSim.outputs UsimOptionLogicSubckt5 string ""
UltraSim.outputs UsimOptionLogicDepth4 string "1"
UltraSim.outputs UsimOptionAllAnalogTC boolean nil
UltraSim.outputs UsimOptionAllLogicNV boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC4 boolean nil
UltraSim.outputs UsimOptionLogicDepth string "1"
UltraSim.outputs UsimOptionLogicLowThreshold2 string ""
UltraSim.outputs UsimOptionAllLogicNV2 boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC2 boolean nil
UltraSim.outputs UsimOptionNumberVolThreshold string "1"
UltraSim.outputs UsimOptionLogicSubckt4 string ""
UltraSim.outputs UsimOptionLogicHighThreshold4 string ""
UltraSim.outputs UsimOptionAllAnalogNV boolean nil
UltraSim.outputs UsimOptionLogicLowThreshold5 string ""
UltraSim.outputs UsimOptionIncludeRC boolean nil
UltraSim.outputs UsimOptionDepth string "1"
UltraSim.outputs UsimOptionLogicHighThreshold2 string ""
UltraSim.outputs UsimOptionLogicIncludeRC5 boolean nil
UltraSim.outputs UsimOptionLogicIncludeRC3 boolean nil
UltraSim.outputs UsimOptionLogicHighThreshold3 string ""
UltraSim.outputs UsimOptionLogicDepth5 string "1"
UltraSim.outputs UsimOptionLogicLowThreshold3 string ""
UltraSim.outputs UsimOptionLogicLowThreshold4 string ""
UltraSim.outputs UsimOptionProbeLogic boolean nil
UltraSim.outputs UsimOptionAllLogicNV3 boolean nil
UltraSim.outputs UsimOptionAllLogicNV4 boolean nil
UltraSim.outputs UsimOptionLogicHighThreshold5 string ""
UltraSim.outputs UsimOptionLogicDepth2 string "1"
;UltraSim envOpts partition variables
UltraSim.envOpts stopViewList string "spectre"
UltraSim.envOpts switchViewList string "spectre cmos_sch cmos.sch schematic veriloga"
UltraSim.envOpts netlistFormat string "spectre"
UltraSim.envOpts autoDisplay boolean t
UltraSim.envOpts printComments boolean nil
UltraSim.envOpts UltraSimVectorFile string ""
UltraSim.envOpts UltraSimVcdFile string ""
UltraSim.envOpts userCmdLineOption string ""
UltraSim.envOpts UltraSimVcdInfo string ""
;UltraSim init partition variables
UltraSim.init processPriority int 0
;UltraSim tran partition variables
UltraSim.tran enable toggle (nil)
UltraSim.tran stop string ""
;UltraSim tranOpts partition variables
UltraSim.tranOpts start string ""
UltraSim.tranOpts outputstart string ""
UltraSim.tranOpts step string "1e-9"
UltraSim.tranOpts readic string ""
UltraSim.tranOpts write string "UltraSim.ic"
UltraSim.tranOpts writefinal string "UltraSim.fc"
UltraSim.tranOpts method_new string ""
UltraSim.tranOpts infotimes string ""
UltraSim.tranOpts maxstep string ""
UltraSim.tranOpts max_start string ""
UltraSim.tranOpts max_stop string ""
UltraSim.tranOpts max_subckt string ""
;UltraSimVerilog environment variables
;UltraSimVerilog opts partition variables
UltraSimVerilog.opts rshort string "1e-6"
UltraSimVerilog.opts UsimRAAgeDomain string "loglog"
UltraSimVerilog.opts simSave boolean nil
UltraSimVerilog.opts UsimTAMaxPerTime string ""
UltraSimVerilog.opts abstoli string "1.00e-12"
UltraSimVerilog.opts UsimPAEnabled boolean nil
UltraSimVerilog.opts UsimNAOutputSort string "name"
UltraSimVerilog.opts simSaveFile string ""
UltraSimVerilog.opts UsimTASigNames string ""
UltraSimVerilog.opts TNOMDC string "27"
UltraSimVerilog.opts dc string "Complete DC (1)"
UltraSimVerilog.opts other string ""
UltraSimVerilog.opts otherSpice string ""
UltraSimVerilog.opts simRestart boolean nil
UltraSimVerilog.opts UsimPADepth string "1"
UltraSimVerilog.opts wf_tres string "1e-12"
UltraSimVerilog.opts UsimPATimeIntervals string ""
UltraSimVerilog.opts UsimRAMode string "HCI only"
UltraSimVerilog.opts rcr_fmax string "1e9"
UltraSimVerilog.opts simTimePoints string ""
UltraSimVerilog.opts UsimTASigEdgeType string "rise"
UltraSimVerilog.opts UsimRADeltaDToggle boolean t
UltraSimVerilog.opts tol string "0.01"
UltraSimVerilog.opts wf_reltol string ""
UltraSimVerilog.opts wf_abstoli string "1e-12"
UltraSimVerilog.opts UsimTARefSigEdgeType string "rise"
UltraSimVerilog.opts UsimRAAgeMethod string "interp"
UltraSimVerilog.opts UsimTASigLowThreshold string ""
UltraSimVerilog.opts UsimTAEnabled boolean nil
UltraSimVerilog.opts UsimTAMinLowTime string ""
UltraSimVerilog.opts UsimNA toggle (nil)
UltraSimVerilog.opts postl string "No RCR (0)"
UltraSimVerilog.opts abstolv string "1.00e-06"
UltraSimVerilog.opts diode_method string "Analog Table (A)"
UltraSimVerilog.opts UsimRAAgeproc string ""
UltraSimVerilog.opts ParasiticRCFile string ""
UltraSimVerilog.opts UsimTAMinHighTime string ""
UltraSimVerilog.opts UsimOptMethod boolean nil
UltraSimVerilog.opts UsimPA toggle (nil)
UltraSimVerilog.opts UsimRAMinAge float 0.0
UltraSimVerilog.opts UsimTA toggle (nil)
UltraSimVerilog.opts UsimTAMaxHighTime string ""
UltraSimVerilog.opts wf_abstolv string "1e-6"
UltraSimVerilog.opts UsimRADeltaD float 0.1
UltraSimVerilog.opts simLoadFile string ""
UltraSimVerilog.opts UsimPALimit string ""
UltraSimVerilog.opts TEMPDC string "27"
UltraSimVerilog.opts UsimTARefSig string ""
UltraSimVerilog.opts mos_method string "Analog/MS Table (A)"
UltraSimVerilog.opts UsimRANBTIAgeproc string ""
UltraSimVerilog.opts wf_filter boolean t
UltraSimVerilog.opts UsimTARefSigHighThreshold string ""
UltraSimVerilog.opts UsimTANegWindow string ""
UltraSimVerilog.opts UsimTASigHighThreshold string ""
UltraSimVerilog.opts UsimTAMinPerTime string ""
UltraSimVerilog.opts UsimTAReportTitle string ""
UltraSimVerilog.opts dump_step string ""
UltraSimVerilog.opts speed string "Default (5)"
UltraSimVerilog.opts dcut boolean nil
UltraSimVerilog.opts UsimPAPort string ""
UltraSimVerilog.opts UsimTASubcktName string ""
UltraSimVerilog.opts UsimNALimit string ""
UltraSimVerilog.opts UsimRAAgingTime string "10y"
UltraSimVerilog.opts scale string "1.0"
UltraSimVerilog.opts rvshort string "1e-6"
UltraSimVerilog.opts UsimPAName string ""
UltraSimVerilog.opts analog string "Default (1)"
UltraSimVerilog.opts UsimTAMaxLowTime string ""
UltraSimVerilog.opts UsimPAOutputSort string "avg"
UltraSimVerilog.opts UsimPAPower boolean nil
UltraSimVerilog.opts UsimTASetupTime string ""
UltraSimVerilog.opts lshort string "0"
UltraSimVerilog.opts dcut_field string ""
UltraSimVerilog.opts UsimTATrigger string "both"
UltraSimVerilog.opts UsimOptMethodHier boolean nil
UltraSimVerilog.opts simRepeat string ""
UltraSimVerilog.opts UsimTADisplaySetting string ""
UltraSimVerilog.opts cgndr string "0"
UltraSimVerilog.opts sim_mode string "Mixed Signal (MS)"
UltraSimVerilog.opts cgnd string "1e-20"
UltraSimVerilog.opts UsimRA toggle (nil)
UltraSimVerilog.opts UsimTARefSigLowThreshold string ""
UltraSimVerilog.opts UsimTACheckType string "setup"
UltraSimVerilog.opts UsimNASortIs string "inc"
UltraSimVerilog.opts scalem string "1.0"
UltraSimVerilog.opts UsimPADisplaySetting string ""
UltraSimVerilog.opts UsimTADepth string ""
UltraSimVerilog.opts lvshort string "0"
;UltraSimVerilog outputs partition variables
UltraSimVerilog.outputs UsimOptionLogicSubckt3 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth3 string "1"
UltraSimVerilog.outputs UsimOptionProbeAnalog boolean t
UltraSimVerilog.outputs UsimOptionAllLogicNV5 boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt2 string ""
UltraSimVerilog.outputs UsimOptionLogicHighThreshold string ""
UltraSimVerilog.outputs UsimOptionLogicIncludeRC boolean nil
UltraSimVerilog.outputs UsimOptionLogicSubckt string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt5 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth4 string "1"
UltraSimVerilog.outputs UsimOptionAllAnalogTC boolean nil
UltraSimVerilog.outputs UsimOptionAllLogicNV boolean nil
UltraSimVerilog.outputs UsimOptionLogicIncludeRC4 boolean nil
UltraSimVerilog.outputs UsimOptionLogicDepth string "1"
UltraSimVerilog.outputs UsimOptionLogicLowThreshold2 string ""
UltraSimVerilog.outputs UsimOptionAllLogicNV2 boolean nil
UltraSimVerilog.outputs UsimOptionNumberVolThreshold string "1"
UltraSimVerilog.outputs UsimOptionLogicIncludeRC2 boolean nil
UltraSimVerilog.outputs UsimOptionAllAnalogNV boolean nil
UltraSimVerilog.outputs UsimOptionLogicHighThreshold4 string ""
UltraSimVerilog.outputs UsimOptionLogicSubckt4 string ""
UltraSimVerilog.outputs UsimOptionDepth string "1"
UltraSimVerilog.outputs UsimOptionIncludeRC boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold5 string ""
UltraSimVerilog.outputs allDigitalNV boolean t
UltraSimVerilog.outputs UsimOptionLogicHighThreshold2 string ""
UltraSimVerilog.outputs UsimOptionLogicHighThreshold3 string ""
UltraSimVerilog.outputs UsimOptionLogicIncludeRC3 boolean nil
UltraSimVerilog.outputs UsimOptionLogicIncludeRC5 boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold3 string ""
UltraSimVerilog.outputs UsimOptionLogicDepth5 string "1"
UltraSimVerilog.outputs UsimOptionProbeLogic boolean nil
UltraSimVerilog.outputs UsimOptionLogicLowThreshold4 string ""
UltraSimVerilog.outputs UsimOptionAllLogicNV3 boolean nil
UltraSimVerilog.outputs UsimOptionAllLogicNV4 boolean nil
UltraSimVerilog.outputs UsimOptionLogicDepth2 string "1"
UltraSimVerilog.outputs UsimOptionLogicHighThreshold5 string ""
;UltraSimVerilog verimixOpts partition variables
UltraSimVerilog.verimixOpts filename6 string ""
UltraSimVerilog.verimixOpts maxDCIter int 0
UltraSimVerilog.verimixOpts scope1 string ""
UltraSimVerilog.verimixOpts scope10 string ""
UltraSimVerilog.verimixOpts filename8 string ""
UltraSimVerilog.verimixOpts dcInterval float 0.0
UltraSimVerilog.verimixOpts scope3 string ""
UltraSimVerilog.verimixOpts scope8 string ""
UltraSimVerilog.verimixOpts scope7 string ""
UltraSimVerilog.verimixOpts filename7 string ""
UltraSimVerilog.verimixOpts scope string ""
UltraSimVerilog.verimixOpts filename4 string ""
UltraSimVerilog.verimixOpts filename string ""
UltraSimVerilog.verimixOpts filename1 string ""
UltraSimVerilog.verimixOpts scope9 string ""
UltraSimVerilog.verimixOpts importsdfswitch boolean nil
UltraSimVerilog.verimixOpts filename2 string ""
UltraSimVerilog.verimixOpts numberofsdffiles int 2
UltraSimVerilog.verimixOpts scope2 string ""
UltraSimVerilog.verimixOpts scope6 string ""
UltraSimVerilog.verimixOpts filename10 string ""
UltraSimVerilog.verimixOpts delaymodechoice string "Ignore"
UltraSimVerilog.verimixOpts sdfmixedswitch boolean t
UltraSimVerilog.verimixOpts filename9 string ""
UltraSimVerilog.verimixOpts scope5 string ""
UltraSimVerilog.verimixOpts filename5 string ""
UltraSimVerilog.verimixOpts filename3 string ""
UltraSimVerilog.verimixOpts scope4 string ""
;UltraSimVerilog verilogOpts partition variables
UltraSimVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
UltraSimVerilog.verilogOpts optionsFile string ""
UltraSimVerilog.verilogOpts twinTurbo boolean nil
UltraSimVerilog.verilogOpts suppressMessages boolean nil
UltraSimVerilog.verilogOpts libraryFile string ""
UltraSimVerilog.verilogOpts behaveProfile boolean nil
UltraSimVerilog.verilogOpts verimixLog string "verilog.log"
UltraSimVerilog.verilogOpts simVision boolean nil
UltraSimVerilog.verilogOpts pulseSpec boolean nil
UltraSimVerilog.verilogOpts commandFile string ""
UltraSimVerilog.verilogOpts pulseError int 100
UltraSimVerilog.verilogOpts stopCompile boolean nil
UltraSimVerilog.verilogOpts keepNodes string "Minimum"
UltraSimVerilog.verilogOpts accelerationCA boolean nil
UltraSimVerilog.verilogOpts turboRadio string "Default"
UltraSimVerilog.verilogOpts libraryDir string ""
UltraSimVerilog.verilogOpts suppressWarnings boolean nil
UltraSimVerilog.verilogOpts accelerationSwitches boolean nil
UltraSimVerilog.verilogOpts accelerationNormal boolean t
UltraSimVerilog.verilogOpts delayType string "Typical"
UltraSimVerilog.verilogOpts pulseReject int 100
UltraSimVerilog.verilogOpts delayMode string "Default"
UltraSimVerilog.verilogOpts vermixBinary string "verilog.vmx"
;UltraSimVerilog init partition variables
UltraSimVerilog.init processPriority int 0
;UltraSimVerilog envOpts partition variables
UltraSimVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
UltraSimVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
UltraSimVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
UltraSimVerilog.envOpts outputFormat string "AWD"
UltraSimVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
UltraSimVerilog.envOpts mspSetupNetlistEscapeName boolean nil
UltraSimVerilog.envOpts autoDisplay boolean t
UltraSimVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
UltraSimVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
UltraSimVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
UltraSimVerilog.envOpts mspSetupNetlistPinMap boolean nil
UltraSimVerilog.envOpts mspSetupNetlistBus boolean t
UltraSimVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
UltraSimVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
UltraSimVerilog.envOpts mspSetupNetlistExplicit boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
UltraSimVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
UltraSimVerilog.envOpts printComments boolean nil
UltraSimVerilog.envOpts UltraSimVectorFile string ""
UltraSimVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
UltraSimVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
UltraSimVerilog.envOpts mspSetupNetlistSimTimeValue int 1
UltraSimVerilog.envOpts mspSetupNetlistUseLib boolean nil
UltraSimVerilog.envOpts UltraSimVcdFile string ""
UltraSimVerilog.envOpts mspSetupNetlistNullPort boolean nil
UltraSimVerilog.envOpts mspSetupNetlistDropPortRange boolean t
UltraSimVerilog.envOpts userCmdLineOption string ""
UltraSimVerilog.envOpts mspSetupNetlistUpCase boolean nil
UltraSimVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
UltraSimVerilog.envOpts UltraSimVcdInfo string ""
;UltraSimVerilog tran partition variables
UltraSimVerilog.tran enable toggle (nil)
UltraSimVerilog.tran stop string ""
;UltraSimVerilog tranOpts partition variables
UltraSimVerilog.tranOpts start string ""
UltraSimVerilog.tranOpts outputstart string ""
UltraSimVerilog.tranOpts step string "1e-9"
UltraSimVerilog.tranOpts readic string ""
UltraSimVerilog.tranOpts write string "UltraSim.ic"
UltraSimVerilog.tranOpts writefinal string "UltraSim.fc"
UltraSimVerilog.tranOpts method_new string ""
UltraSimVerilog.tranOpts infotimes string ""
UltraSimVerilog.tranOpts maxstep string ""
UltraSimVerilog.tranOpts max_start string ""
UltraSimVerilog.tranOpts max_stop string ""
UltraSimVerilog.tranOpts max_subckt string ""
;1*******************************************************
;2* DLE/DLR Environment Variables
;3*******************************************************
adle lxLocalAbutment boolean nil
;AMS-Direct Environment Defaults
amsDirect amsCompMode boolean nil
amsDirect amsLSB_MSB boolean nil
amsDirect amsScalarInstances boolean t
amsDirect includeInstCdfParams boolean nil
amsDirect amsVerbose boolean nil
amsDirect amsMaxErrors int 50
amsDirect amsExcludeParams string ""
amsDirect hdlVarFile string ""
amsDirect simRunDirLoc string ""
amsDirect logFileName string "ams_direct.log"
amsDirect initFile string ""
amsDirect amsDefinitionViews string ""
amsDirect amsExpScalingFactor cyclic "no"
amsDirect modifyParamScope cyclic "no"
amsDirect.prep allowUndefParams boolean t
amsDirect.prep detailedDisciplineRes boolean nil
amsDirect.prep forceGlobalSync boolean nil
amsDirect.prep ncsimGUI boolean t
amsDirect.prep ncsimTcl boolean nil
amsDirect.prep runNcelab boolean t
amsDirect.prep runNcsim boolean t
amsDirect.prep use5xForVHDL boolean t
amsDirect.prep ncelabAnnoSimtime boolean nil
amsDirect.prep ncelabCoverage boolean nil
amsDirect.prep ncelabEpulseNeg boolean nil
amsDirect.prep ncelabIeee1634 boolean nil
amsDirect.prep ncelabInterconnmultisrc boolean nil
amsDirect.prep ncelabLibverbose boolean nil
amsDirect.prep ncelabMessages boolean nil
amsDirect.prep ncelabNostdout boolean nil
amsDirect.prep ncelabNoTchkMsg boolean nil
amsDirect.prep ncelabNoTchkXgen boolean nil
amsDirect.prep ncelabNotimingchecks boolean nil
amsDirect.prep ncelabNovitalaccl boolean t
amsDirect.prep ncelabNoVpdmsg boolean nil
amsDirect.prep ncelabNoVpdXgen boolean nil
amsDirect.prep ncelabNtcWarn boolean nil
amsDirect.prep ncelabPathpulse boolean nil
amsDirect.prep ncelabPlinooptwarn boolean nil
amsDirect.prep ncelabPlinowarn boolean nil
amsDirect.prep ncelabPresrvResFn boolean nil
amsDirect.prep ncelabSdfNocheckCelltype boolean nil
amsDirect.prep ncelabSdfNoHeader boolean nil
amsDirect.prep ncelabSdfNoWarnings boolean nil
amsDirect.prep ncelabSdfWorstcaseRounding boolean nil
amsDirect.prep ncelabStatus boolean t
amsDirect.prep ncelabUpdate boolean t
amsDirect.prep ncelabV93 boolean nil
amsDirect.prep ncelabNosource boolean nil
amsDirect.prep ncelabUseAfile boolean nil
amsDirect.prep ncelabUseGenafile boolean nil
amsDirect.prep ncelabExpand boolean nil
amsDirect.prep ncelabRelax boolean nil
amsDirect.prep ncelabDisableenht boolean nil
amsDirect.prep ncelabNonegtchk boolean nil
amsDirect.prep ncelabNoipd boolean nil
amsDirect.prep ncelabSdfverbose boolean nil
amsDirect.prep ncelabNoautosdf boolean nil
amsDirect.prep ncelabNeverwarn boolean nil
amsDirect.prep ncelabNocopyright boolean nil
amsDirect.prep ncelabUseGeneric boolean nil
amsDirect.prep ncelabUsePulseR boolean nil
amsDirect.prep ncelabUsePulseE boolean nil
amsDirect.prep ncelabUsePulseIntR boolean nil
amsDirect.prep ncelabUsePulseIntE boolean nil
amsDirect.prep ncelabUseExtendtcheckdatalimit boolean nil
amsDirect.prep ncelabUseExtendtcheckreferencelimit boolean nil
amsDirect.prep ncelabNonotifier boolean nil
amsDirect.prep ncelabUseSdfprecision boolean nil
amsDirect.prep ncsimEpulseNoMsg boolean nil
amsDirect.prep ncsimExtassertmsg boolean nil
amsDirect.prep ncsimMessages boolean nil
amsDirect.prep ncsimNeverwarn boolean nil
amsDirect.prep ncsimNocifcheck boolean nil
amsDirect.prep ncsimNosource boolean nil
amsDirect.prep ncsimNostdout boolean nil
amsDirect.prep ncsimPlinooptwarn boolean nil
amsDirect.prep ncsimPlinowarn boolean nil
amsDirect.prep ncsimProfile boolean nil
amsDirect.prep ncsimProfthread boolean nil
amsDirect.prep ncsimRedmem boolean nil
amsDirect.prep ncsimStatus boolean nil
amsDirect.prep ncsimUnbuffered boolean nil
amsDirect.prep ncsimUpdate boolean t
amsDirect.prep ncelabUseAddArgs boolean nil
amsDirect.prep ncsimUseAddArgs boolean nil
amsDirect.prep ncelabMaxErrors int 50
amsDirect.prep ncelabPulseE int 100
amsDirect.prep ncelabPulseIntE int 100
amsDirect.prep ncelabPulseIntR int 100
amsDirect.prep ncelabPulseR int 100
amsDirect.prep ncelabExtendtcheckdatalimit int 0
amsDirect.prep ncelabExtendtcheckreferencelimit int 0
amsDirect.prep ncsimMaxErrors int 50
amsDirect.prep analogControlFile string ""
amsDirect.prep cdsGlobalsLib string ""
amsDirect.prep cdsGlobalsView string ""
amsDirect.prep compileExcludeLibs string ""
amsDirect.prep connectRulesCell string "mixedsignal"
amsDirect.prep connectRulesCell2 string "ConnRules_5V_full"
amsDirect.prep connectRulesLib string ""
amsDirect.prep connectRulesView string ""
amsDirect.prep discipline string "logic"
amsDirect.prep language string "verilog"
amsDirect.prep ncelabArguments string ""
amsDirect.prep ncsimArguments string ""
amsDirect.prep simVisScriptFile string ""
amsDirect.prep timescale string "1ns/1ns"
amsDirect.prep vlogGroundSigs string "gnd!"
amsDirect.prep vlogSupply0Sigs string ""
amsDirect.prep vlogSupply1Sigs string ""
amsDirect.prep ncelabAfile string ""
amsDirect.prep ncelabGenafile string ""
amsDirect.prep ncelabLoadpli1 string ""
amsDirect.prep ncelabLoadvpi string ""
amsDirect.prep ncelabSdfCmdFile string ""
amsDirect.prep ncelabTopLvlGeneric string ""
amsDirect.prep ncelabSdfprecision string ""
amsDirect.prep ncelabNowarn string ""
amsDirect.prep ncsimLoadvpi string ""
amsDirect.prep ncsimNowarn string ""
amsDirect.prep ncelabModelFilePaths string ""
amsDirect.prep compileMode cyclic "incremental"
amsDirect.prep netlistMode cyclic "incremental"
amsDirect.prep ncelabAccess cyclic "Read"
amsDirect.prep ncelabDelayMode cyclic "None"
amsDirect.prep ncelabDelayType cyclic "None"
amsDirect.prep ncelabEpulseFiltering cyclic "None"
amsDirect.prep ncelabLogFileAction cyclic "Overwrite log file"
amsDirect.prep ncelabOmichecklvl cyclic "Standard"
amsDirect.prep ncelabVipdelay cyclic "Typical"
amsDirect.prep ncsimLogFileAction cyclic "Overwrite log file"
amsDirect.prep ncsimOmichecklvl cyclic "None"
amsDirect.simcntl scapprox boolean nil
amsDirect.simcntl scdebug boolean nil
amsDirect.simcntl scdiagnose boolean nil
amsDirect.simcntl scerror boolean t
amsDirect.simcntl scignshorts boolean nil
amsDirect.simcntl scinfo boolean t
amsDirect.simcntl scmacromod boolean nil
amsDirect.simcntl scnarrate boolean t
amsDirect.simcntl scnote boolean t
amsDirect.simcntl scopptcheck boolean t
amsDirect.simcntl scpivotdc boolean nil
amsDirect.simcntl scscfusefileflag boolean nil
amsDirect.simcntl scspscflag boolean nil
amsDirect.simcntl scstats boolean nil
amsDirect.simcntl scwarn boolean t
amsDirect.simcntl scfastbreak boolean nil
amsDirect.simcntl scusemodeleval boolean nil
amsDirect.simcntl scdigits int 5
amsDirect.simcntl scmaxiters int 5
amsDirect.simcntl scmaxnotes int 5
amsDirect.simcntl scmaxwarn int 5
amsDirect.simcntl scscale int 1
amsDirect.simcntl scscalem int 1
amsDirect.simcntl scskipcount int 0
amsDirect.simcntl sccmin string "0.0"
amsDirect.simcntl scaddlglblopts string ""
amsDirect.simcntl scaddltranopts string ""
amsDirect.simcntl scgmin string "1e-12"
amsDirect.simcntl sciabstol string "1e-12"
amsDirect.simcntl scicstmt string ""
amsDirect.simcntl sclteratio string ""
amsDirect.simcntl scmaxstep string ""
amsDirect.simcntl scpivabs string "0.0"
amsDirect.simcntl scpivrel string "1e-3"
amsDirect.simcntl screadic string ""
amsDirect.simcntl screadns string ""
amsDirect.simcntl screltol string ""
amsDirect.simcntl scrforce string "1.0"
amsDirect.simcntl scalem string "1.0"
amsDirect.simcntl scale string "1.0"
amsDirect.simcntl scscfincfile string ""
amsDirect.simcntl scscftimestamp string ""
amsDirect.simcntl scskipstart string "0.0"
amsDirect.simcntl scskipstop string "0.0"
amsDirect.simcntl scstep string ""
amsDirect.simcntl scstop string "0.0"
amsDirect.simcntl scstrobedelay string "0.0"
amsDirect.simcntl scstrobeperiod string "0.0"
amsDirect.simcntl sctemp string "27.0"
amsDirect.simcntl sctitle string ""
amsDirect.simcntl sctnom string "27.0"
amsDirect.simcntl scvabstol string "1e-6"
amsDirect.simcntl scwrite string ""
amsDirect.simcntl scwritefinal string ""
amsDirect.simcntl scannotate cyclic "sweep"
amsDirect.simcntl scaudit cyclic "detailed"
amsDirect.simcntl sccheckstmt cyclic "all"
amsDirect.simcntl sccompatible cyclic "spectre"
amsDirect.simcntl scerrpreset cyclic "moderate"
amsDirect.simcntl scgmincheck cyclic "max_v_only"
amsDirect.simcntl schomotopy cyclic "all"
amsDirect.simcntl scic cyclic "all"
amsDirect.simcntl scinventory cyclic "detailed"
amsDirect.simcntl sclimit cyclic "dev"
amsDirect.simcntl scmethod cyclic "<Default value>"
amsDirect.simcntl scnotation cyclic "eng"
amsDirect.simcntl scquantities cyclic "no"
amsDirect.simcntl screlref cyclic "<Default value>"
amsDirect.simcntl scskipdc cyclic "no"
amsDirect.simcntl sctempeffects cyclic "all"
amsDirect.simcntl sctopcheck cyclic "full"
amsDirect.simcntl sctransave cyclic "allpub"
amsDirect.simcntl scmodelevaltype cyclic "s"
amsDirect.vhdl allowNoEntityUpdate boolean nil
amsDirect.vhdl checkAndNetlist boolean nil
amsDirect.vhdl checkOnly boolean nil
amsDirect.vhdl compileAsAMS boolean t
amsDirect.vhdl forceEntitySync boolean nil
amsDirect.vhdl forceInlineCompDecl boolean nil
amsDirect.vhdl netlistAfterCdfChange boolean nil
amsDirect.vhdl prohibitCompile boolean nil
amsDirect.vhdl useProcessViewNamesOnly boolean nil
amsDirect.vhdl lexpragma boolean nil
amsDirect.vhdl messages boolean nil
amsDirect.vhdl neverwarn boolean nil
amsDirect.vhdl nopragmawarn boolean nil
amsDirect.vhdl nostdout boolean nil
amsDirect.vhdl novitalcheck boolean nil
amsDirect.vhdl pragma boolean nil
amsDirect.vhdl relax boolean nil
amsDirect.vhdl status boolean nil
amsDirect.vhdl update boolean t
amsDirect.vhdl v93 boolean t
amsDirect.vhdl vhdllinedebug boolean nil
amsDirect.vhdl ncvhdlUseAddArgs boolean nil
amsDirect.vhdl maxErrors int 50
amsDirect.vhdl amsEligibleViewTypes string "schematic schematicSymbol"
amsDirect.vhdl defaultObject string "quantity"
amsDirect.vhdl defaultScalarNature string "real"
amsDirect.vhdl defaultScalarType string "quantity"
amsDirect.vhdl defaultVectorNature string "real_vector"
amsDirect.vhdl defaultVectorType string "quantity"
amsDirect.vhdl defPackageNames string ""
amsDirect.vhdl excludeViewNames string ""
amsDirect.vhdl ncvhdlArguments string ""
amsDirect.vhdl processViewNames string ""
amsDirect.vhdl templateFile string ""
amsDirect.vhdl templateScript string ""
amsDirect.vhdl logFileAction cyclic "Overwrite log file"
amsDirect.vhdl nowarn string ""
amsDirect.vhdl allowDeviantBuses cyclic "no"
amsDirect.vhdl allowIllegalIdentifiers cyclic "warn"
amsDirect.vhdl allowNameCollisions cyclic "warn"
amsDirect.vhdl allowPortNetMismatches cyclic "no"
amsDirect.vhdl allowSparseBuses cyclic "warn"
amsDirect.vhdl headerText cyclic "none"
amsDirect.vlog checkAndNetlist boolean nil
amsDirect.vlog checkOnly boolean nil
amsDirect.vlog compileAsAMS boolean t
amsDirect.vlog ifdefLanguageExtensions boolean nil
amsDirect.vlog netlistAfterCdfChange boolean nil
amsDirect.vlog prohibitCompile boolean nil
amsDirect.vlog useDefparam boolean nil
amsDirect.vlog useProcessViewNamesOnly boolean nil
amsDirect.vlog checktasks boolean nil
amsDirect.vlog ieee1364 boolean nil
amsDirect.vlog noline boolean nil
amsDirect.vlog lexpragma boolean nil
amsDirect.vlog markcelldefines boolean nil
amsDirect.vlog messages boolean nil
amsDirect.vlog neverwarn boolean nil
amsDirect.vlog nomempack boolean nil
amsDirect.vlog nopragmawarn boolean nil
amsDirect.vlog nostdout boolean nil
amsDirect.vlog pragma boolean nil
amsDirect.vlog status boolean nil
amsDirect.vlog update boolean t
amsDirect.vlog vloglinedebug boolean nil
amsDirect.vlog ncvlogUseAddArgs boolean nil
amsDirect.vlog netlistUDFAsMacro boolean nil
amsDirect.vlog bindCdsAliasLib boolean t
amsDirect.vlog bindCdsAliasView boolean t
amsDirect.vlog maxErrors int 50
amsDirect.vlog amsEligibleViewTypes string "schematic"
amsDirect.vlog excludeViewNames string ""
amsDirect.vlog includeFiles string "(disciplines.vams)"
amsDirect.vlog ncvlogArguments string ""
amsDirect.vlog paramDefVals string ""
amsDirect.vlog paramGlobalDefVal string "0"
amsDirect.vlog processViewNames string ""
amsDirect.vlog templateFile string ""
amsDirect.vlog templateScript string ""
amsDirect.vlog incdir string ""
amsDirect.vlog macro string ""
amsDirect.vlog nowarn string ""
amsDirect.vlog allowDeviantBuses cyclic "no"
amsDirect.vlog allowIllegalIdentifiers cyclic "warn"
amsDirect.vlog allowNameCollisions cyclic "warn"
amsDirect.vlog allowSparseBuses cyclic "warn"
amsDirect.vlog headerText cyclic "none"
amsDirect.vlog logFileAction cyclic "Overwrite log file"
amsDirect.vlog iterInstExpFormat string "%b_%i"
amsDirect.vlog netClashFormat string "%b_netclash"
amsDirect.vlog instClashFormat string "%b_instclash"
amsDirect.vlog aliasInstFormat string "ams_alias_inst_%i"
;Analog Artist Simulation Environment Defaults
;Session Options
asimenv windowBased boolean t
asimenv schematicBased boolean nil
asimenv saveDir string "~/.artist_states"
asimenv saveQuery boolean t
asimenv loadCorners boolean t
asimenv designEditMode boolean nil;edit/read open mode
asimenv showWhatsNew string "yes"
asimenv.startup simulator string "spectre"
asimenv.startup projectDir string "~/simulation"
asimenv.startup hostMode string "local"
asimenv.startup host string ""
asimenv.startup remoteDir string ""
asimenv.startup digitalHostMode string "local"
asimenv.startup digitalHost string ""
;Window Options
asimenv.window x int 1
asimenv.window y int 317
;Load State Dialog
asimenv.loadstate modelSetup boolean t
;when set to nil, loadstate form opens with Model Setup deselected by default
;Plotting Options
asimenv.plotting autoPlot boolean t
asimenv.plotting overlay boolean nil
asimenv.plotting immediatePlot boolean nil
asimenv.plotting designName boolean t
asimenv.plotting simulationDate boolean t
asimenv.plotting temperature boolean nil
asimenv.plotting variables boolean nil
asimenv.plotting scalarOutputs boolean nil
asimenv.plotting icons boolean t
asimenv.plotting fontSize int 11
asimenv.plotting width int 564
asimenv.plotting height int 428
asimenv.plotting x int 577
asimenv.plotting y int 373
asimenv.plotting displayMode cyclic "auto"
asimenv.plotting stripModeType cyclic "auto"
asimenv.plotting immediatePrint boolean t
asimenv.plotting printInlines boolean t
;Command-Type-In Window
asimenv.window width int 650
asimenv.window height int 275
;Miscellaneous
asimenv.misc saveDefaultsToOCEAN boolean nil
asimenv.misc numberOfSavedRuns int 0
asimenv.misc browserCenterMode boolean nil
asimenv.misc updateCDFtermOrder boolean nil
asimenv.misc queryCDFtermOrder boolean t
asimenv.misc oceanScriptFile string "./oceanScript.ocn"
asimenv.userPref printNotation cyclic "suffix"
asimenv.userPref printCommentChar string "#"
;Noise summary options
asimenv.noiseSummary digits int 6
asimenv.noiseSummary percentDecimals int 2
;obsolete simulator startup form variables
asimenv.startup sessionName string "schematic"
asimenv.startup libName string ""
asimenv.startup cellName string ""
asimenv.startup viewName string ""
asimenv.startup versionName string ""
asimenv.netlist obsoleteWarnings int 1
;Distributed Processing
;Please do not add any options other than for Artist Distributed
;below this point.
;asimenv.startup hostMode - value of 'distributed' enables distributed processing
asimenv.distributed externalServer boolean nil
;If set non-nil, the job server is started remotely.
asimenv.distributed autoJobSubmit boolean nil
;If set non-nil, job setup form is NOT presented to user at job submit time.
asimenv.distributed showMessages boolean t
;If set non-nil, a message is displayed in the CIW or OCEAN terminal
;when a job is completed.
asimenv.distributed queueName string ""
;Sets the default queue name. If unspecified, system default is used.
asimenv.distributed hostName string ""
;Sets the default host name. If unspecified, host is automatically selected.
asimenv.distributed startTime string ""
;Sets the default start time for a job (in 24 hr. format). If unspecified, job runs immediately.
asimenv.distributed startDay cyclic "today"
;Sets the default start day for a job. If `today', then job will always run on the same day it is submitted
asimenv.distributed expTime string ""
;Sets the default expiration time for a job (in 24 hr. format). If unspecified, expiration time
;is based on the value of the `timeLimit' variable.
asimenv.distributed expDay cyclic "today"
;Sets the default expiration day for a job. If `today', then job will always run on the same day it is submitted
asimenv.distributed timeLimit cyclic "none"
;Sets the default time limit for a job. If `none', then no time limit is imposed.
;If `unspecified', then expiration time is based on value of `expTime' and `expDay' variables.
asimenv.distributed emailNotify boolean t
;If set non-nil, email notification is provided following job termination.
asimenv.distributed mailTo string ""
;Sets the default list of users who will receive job termination notification email.
;If unspecified, and emailNotify is t, then default value is the user's id.
asimenv.distributed logsInEmail boolean t
;If set non-nil, stdout and stderr logs will be included in the termination email.
asimenv.distributed stateFile string "~/.adpState"
;Sets the filename containing the job server's state.
asimenv.distributed daysBeforeExpire int 3
;Specifies the number of days after which terminated jobs will be deleted from
;the job server.
asimenv.distributed block boolean nil
;If set non-nil, the process will be blocked until the job has completed.
asimenv.distributed copyMode boolean nil
;If set non-nil, the input data for the job is copied to /tmp on the execution host,
;the job is run there locally (i.e. no network read/write), and the output data is
;copied back to the submission host.
asimenv.distributed copyModeDir string "/tmp"
;The directory, relative to the execution host, that will be used for setting up the
;working directory of a copy mode job.
asimenv.distributed loginShell cyclic "none"
;Specifies login shell for the job. If `none', then the user's local environment
;is copied over to the execution host and used as the job's environment.
asimenv.distributed numOfTasks int 0
;Specifies the default number of tasks a job should be broken into.
;This is used by the Monte Carlo tool.
;If zero, then number of tasks is bases on queue and/or host settings
asimenv.distributed jobArgsInOceanScript boolean nil
;Indicates job arguments should be added to run commands when
;OCEAN script is generated.
asimenv.distributed puttogetherqueue string ""
;Used to specify the queue to be used for Put Together Job
asimenv.distributed copyNetlist boolean nil
;Used to specify whether netlist directory needs to be copied from execution
;host to submission host. This may be required if during simulation, some files
;are generated under netlist dir
;Used to specify whether to remove the job from DP database after job completion.
;So that, if set to t, the same job name is used repeatedly.
;Used to specify whether list option for specifying hosts needs to be displayed
;in Job Submit Form. If set to nil the list option will not be displayed.
;Used to specify the default value for Shell_Cmd_at_Finish as available in job
;submit form.
asimenv.distributed logsDir string "/tmp"
;Used to specify the directory where the log files would be generated
asimenv.distributed mailAllLogs boolean nil
;Used to specify whether to send the log files in mail for all the tasks
;If set to t, log files would be mailed for each task and a summary mail would be
;sent after completion of all the tasks. If set to nil just a summary mail would be
asimenv.distributed logFile string "~/cdsDPSetupChk.log"
asimenv.distributed clockSync boolean nil
asimenv.distributed lsfResourceString string ""
;Used to specify the Default LSF Resource String
asimenv.distributed donotCopyCore boolean t
;Used to specify whether DP need to filter the core files while copying the directories
;If set to t then all the files with name starting from core will be filtered out
;If set to nil then all the files will be copied
; Copyright (C) 1991
; Cadence Design Systems, Analog Division
; All Rights Reserved.
; $Source: /cvsrep/group/artist/src/auCdl/cdsenv,v $
; $Author: cvsadm $
; $Revision: 1.1 $
; $Date: 2003/10/06 04:16:43 $
; $State: Exp $
;auCdl Environment Variables
;For cell-view to cell-view:
auCdl.envOpts defaultSubcircuitCall string "ansCdlSubcktCall"
;auCore Environment Variables
;Note: The tool registration file should not be edited.
;Customization should be based on the file in <cdshier>/samples/.cdsenv.
;Tool Filter list of simulators
auCore.toolFilter toolList string "spectre spectreS cdsSpice auCdl auLvs hspiceS hspiceD UltraSim "
;Tool Filter list of simulators selected by default
auCore.toolFilter defaultTools string "spectre spectreS auCdl auLvs"
;Tool Filter variable to enable auto update
auCore.toolFilter autoUpdate boolean nil
;Logic Levels form variables
auCore.voltageLevels highlayer cyclic "y2"
auCore.voltageLevels midlayer cyclic "y4"
auCore.voltageLevels lowlayer cyclic "y6"
auCore.voltageLevels high float 2.0
auCore.voltageLevels low float 0.8
auCore.voltageLevels type string "DC"
auCore.voltageLevels time float 0.0
;The following variable indicates the release to which the Artist cdsenv
;variables are compliant. Set to the current release to disable
;automatic variable detection/conversion of user's .cdsenv file.
auCore artVarVer string ""
; $Source: /cvsrep/group/artist/src/auLvs/cdsenv,v $
; $Author: zhaag $
; $Revision: 1.1.12.1 $
; $Date: 2004/10/13 09:30:08 $
; $State: Exp $
auLvs.envOpts defaultSubcircuitCall string "ansLvsCompPrim"
;Calculator environment variables
;FORMAT: tool[.partition] varName varType default private {choices,min/max}
;calculator modes
calculator mode cyclic "RPN"
calculator uimode cyclic "standard"
calculator eval boolean nil
calculator dstack boolean nil
calculator oldexpr boolean t
calculator browserOldExpr boolean nil
;clip special function variables
calculator.clip from string ""
calculator.clip to string ""
;value special function variables
calculator.value at string ""
;x value at maximum special function variables
calculator.xmax nth string "1"
;x value at minimum special function variables
calculator.xmin nth string "1"
;ipn special function variables
calculator.ipn spurOrder string "3"
calculator.ipn refHarmonic string "1"
calculator.ipn spurHarmonic string "1"
calculator.ipn extPoint string "0"
calculator.ipn refOrder string "1"
;ipnVRI special function variables
calculator.ipnVRI spurHarmonic string ""
calculator.ipnVRI refHarmonic string ""
calculator.ipnVRI ordspur string ""
calculator.ipnVRI epoint string ""
calculator.ipnVRI rport string ""
calculator.ipnVRI measurePrompt cyclic "Input Referred IPN"
calculator.ipnVRI powerSwPrompt cyclic "Variable Sweep"
calculator.ipnVRI measure string ""
calculator.ipnVRI psweep string ""
;phaseNoise special function variables
calculator.phaseNoise nth string "0"
calculator.phaseNoise noiseResNam string "pnoise.pss"
;compression special function variables
calculator.compression nth string "0"
calculator.compression x string "0"
calculator.compression compress string "1"
calculator.compressionVRI harmonic string ""
calculator.compressionVRI epoint string ""
calculator.compressionVRI rport string ""
calculator.compressionVRI gcomp string ""
calculator.compressionVRI measurePrompt cyclic "Input Referred Compression"
calculator.compressionVRI measure string ""
;harmonic special function variable
calculator.harmonic nth string "0"
calculator.harmonic spurHarmonic string "1"
calculator.harmonic refHarmonic string "1"
;harmonicFreq special function variable
calculator.harmonicFreq nth string "1"
;tangent special function variables
calculator.tangent x string "0"
calculator.tangent y string "0"
calculator.tangent slope string "1.0"
;discrete fourier transform special function variables
calculator.dft from string ""
calculator.dft to string ""
calculator.dft samples string "64"
calculator.dft windowName cyclic "Rectangular"
calculator.dft smooth float 1.0
calculator.dft cgtype cyclic "(none)"
calculator.dft cohGain float 1.0
calculator.psd from string ""
calculator.psd to string ""
calculator.psd samples string "512"
calculator.psd windowName cyclic "Hanning"
calculator.psd smooth float 1.0
calculator.psd cgtype cyclic "(none)"
calculator.psd cohGain float 1.0
calculator.psd detrending cyclic "None"
calculator.psd windowSize string "256"
calculator.psdbb from string ""
calculator.psdbb to string ""
calculator.psdbb samples string "512"
calculator.psdbb windowName cyclic "Hanning"
calculator.psdbb smooth float 1.0
calculator.psdbb cgtype cyclic "(none)"
calculator.psdbb cohGain float 1.0
calculator.psdbb detrending cyclic "None"
calculator.psdbb windowSize string "256"
;total harmonic distortion special function variables
calculator.thd from string ""
calculator.thd to string ""
calculator.thd samples string "64"
calculator.thd fundamental string ""
;threshold crossing special function variables
calculator.cross value string "2.5"
calculator.cross nth string "1"
calculator.cross type cyclic "either"
;root value special function variables
calculator.root value string "2.5"
calculator.root nth string "1"
;fourier evaluation special function variables
calculator.fourEval from string ""
calculator.fourEval to string ""
calculator.fourEval by string ""
;convolution special function variables
calculator.convolve from string ""
calculator.convolve to string ""
calculator.convolve incr cyclic "linear"
calculator.convolve by string ""
;threshold delay special function variables
calculator.delay value_a string "2.5"
calculator.delay nth_a string "1"
calculator.delay type_a cyclic "either"
calculator.delay value_b string "2.5"
calculator.delay nth_b string "1"
calculator.delay type_b cyclic "either"
;bandwidth special function variables
calculator.bandwidth db string "3"
calculator.bandwidth type cyclic "low"
;rise time special function variables
calculator.riseTime initial string ""
calculator.riseTime itype cyclic "y at x"
calculator.riseTime final string ""
calculator.riseTime ftype cyclic "y at x"
calculator.riseTime theta_a string "10"
calculator.riseTime theta_b string "90"
;slew rate special function variables
calculator.slewRate initial string ""
calculator.slewRate itype cyclic "y at x"
calculator.slewRate final string ""
calculator.slewRate ftype cyclic "y at x"
calculator.slewRate theta_a string "10"
calculator.slewRate theta_b string "90"
;sample special function variables
calculator.sample from string ""
calculator.sample to string ""
calculator.sample incr cyclic "linear"
calculator.sample by string ""
;settling time special function variables
calculator.settlingTime initial string ""
calculator.settlingTime itype cyclic "y at x"
calculator.settlingTime final string ""
calculator.settlingTime ftype cyclic "y at x"
calculator.settlingTime theta string "5"
;overshoot special function variables
calculator.overshoot initial string ""
calculator.overshoot itype cyclic "y at x"
calculator.overshoot final string ""
calculator.overshoot ftype cyclic "y at x"
;table special function variables
calculator.table filename string ""
calculator.table name string ""
calculator.table xcolumn int 1
calculator.table ycolumn int 2
calculator.table xskip int 0
calculator.table yskip int 0
;left shift special function variables
calculator.lshift delta string "0"
;rms noise special function variables
calculator.rmsNoise from string ""
calculator.rmsNoise to string ""
;eyeDiagram special function variables
calculator.eyeDiagram start string "0"
calculator.eyeDiagram stop string "0"
calculator.eyeDiagram period string "0"
;defInteg special function variables
calculator.integ initial string ""
calculator.integ final string ""
; cdba Environment Variables
; This tool registration file should not be edited
; since customization is done via the file in
; <cdshier>/samples/.cdsenv
cdba dbInstNamingGlobalInc boolean nil
cdba dbNumCPU int 1
cdba dbStatCacheOn boolean nil
cdba.DBUPerUU behavioral int 160
cdba.DBUPerUU graphic int 1000
cdba.DBUPerUU logicModel int 160
cdba.DBUPerUU maskLayout int 1000
cdba.DBUPerUU netlist int 160
cdba.DBUPerUU package int 160
cdba.DBUPerUU PCB int 160
cdba.DBUPerUU schematic int 160
cdba.DBUPerUU schematicSymbol int 160
cdba.DBUPerUU stranger int 1000
cdba.DBUPerUU symbolic int 1000
cdba.DBUPerUU verilogMap int 160
cdba.userUnits behavioral cyclic "inch"
cdba.userUnits graphic cyclic "micron"
cdba.userUnits logicModel cyclic "inch"
cdba.userUnits maskLayout cyclic "micron"
cdba.userUnits netlist cyclic "inch"
cdba.userUnits package cyclic "inch"
cdba.userUnits PCB cyclic "inch"
cdba.userUnits schematic cyclic "inch"
cdba.userUnits schematicSymbol cyclic "inch"
cdba.userUnits stranger cyclic "micron"
cdba.userUnits symbolic cyclic "micron"
cdba.userUnits verilogMap cyclic "inch"
; this file is tools/dfII/etc/tools/cdsLibEditor/.cdsenv, format is:
; tool[.partition] varName varType default private {choices,min/max}
cdsLibEditor.main autoExclEdit boolean nil
cdsLibEditor.main warnExclLock boolean t
; this file is tools/dfII/etc/tools/cdsLibManager/.cdsenv, format is:
cdsLibManager.ckCancel useOptionText string ""
cdsLibManager.ckCancel useOptionsOn boolean nil
cdsLibManager.ckIn selectMatches toggle (t nil nil nil)
cdsLibManager.ckIn useOptionText string ""
cdsLibManager.ckIn useOptionsOn boolean nil
cdsLibManager.ckOut useOptionText string ""
cdsLibManager.ckOut useOptionsOn boolean nil
cdsLibManager.copy addToCategoryName string ""
cdsLibManager.copy addToCategoryOn boolean nil
cdsLibManager.copy addToCellsPattern string "*"
cdsLibManager.copy allViewsOn boolean t
cdsLibManager.copy exactHierOn boolean nil
cdsLibManager.copy extraViews string ""
cdsLibManager.copy hierOn boolean nil
cdsLibManager.copy skipLibsOn boolean t
cdsLibManager.copy skipLibsText string ""
cdsLibManager.copy skipLibsText1 string ""
cdsLibManager.copy skipLibsText10 string ""
cdsLibManager.copy skipLibsText11 string ""
cdsLibManager.copy skipLibsText12 string ""
cdsLibManager.copy skipLibsText13 string ""
cdsLibManager.copy skipLibsText14 string ""
cdsLibManager.copy skipLibsText15 string ""
cdsLibManager.copy skipLibsText2 string ""
cdsLibManager.copy skipLibsText3 string ""
cdsLibManager.copy skipLibsText4 string ""
cdsLibManager.copy skipLibsText5 string ""
cdsLibManager.copy skipLibsText6 string ""
cdsLibManager.copy skipLibsText7 string ""
cdsLibManager.copy skipLibsText8 string ""
cdsLibManager.copy skipLibsText9 string ""
cdsLibManager.copy updateChoice toggle (t nil)
cdsLibManager.copy updateOn boolean nil
cdsLibManager.copy viewsText string ""
cdsLibManager.copy addPropFiles boolean t
cdsLibManager.copyError overwriteAll boolean nil
cdsLibManager.copyGlobals expandRadio toggle (t nil)
cdsLibManager.copyGlobals mpsRadio toggle (t nil)
cdsLibManager.copyGlobals stopMutations boolean t
cdsLibManager.copyGlobals useMonitor boolean t
cdsLibManager.copyGlobals warnRenameDM boolean t
cdsLibManager.copyVersion openView boolean t
cdsLibManager.copyVersion toLibrary string ""
cdsLibManager.copyVersion toView string ""
cdsLibManager.copyVersion useOptionText string ""
cdsLibManager.copyVersion useOptionsOn boolean nil
cdsLibManager.copyWizard addToCategoryName string ""
cdsLibManager.copyWizard addToCategoryOn boolean nil
cdsLibManager.copyWizard addToCellsPattern string "*"
cdsLibManager.copyWizard extraViews string ""
cdsLibManager.copyWizard skipLibsText string ""
cdsLibManager.copyWizard skipLibsText1 string ""
cdsLibManager.copyWizard skipLibsText10 string ""
cdsLibManager.copyWizard skipLibsText11 string ""
cdsLibManager.copyWizard skipLibsText12 string ""
cdsLibManager.copyWizard skipLibsText13 string ""
cdsLibManager.copyWizard skipLibsText14 string ""
cdsLibManager.copyWizard skipLibsText15 string ""
cdsLibManager.copyWizard skipLibsText2 string ""
cdsLibManager.copyWizard skipLibsText3 string ""
cdsLibManager.copyWizard skipLibsText4 string ""
cdsLibManager.copyWizard skipLibsText5 string ""
cdsLibManager.copyWizard skipLibsText6 string ""
cdsLibManager.copyWizard skipLibsText7 string ""
cdsLibManager.copyWizard skipLibsText8 string ""
cdsLibManager.copyWizard skipLibsText9 string ""
cdsLibManager.copyWizard updateChoice toggle (t nil)
cdsLibManager.copyWizard updateOn boolean t
cdsLibManager.customize mapTimeout float 5.0
cdsLibManager.customize showDFIIWarning boolean t
cdsLibManager.customize startupFile string "cdsLibMgr.il"
cdsLibManager.database addDb1 string ""
cdsLibManager.database addDb2 string ""
cdsLibManager.database addDb3 string ""
cdsLibManager.database addDb4 string ""
cdsLibManager.database addDb5 string ""
cdsLibManager.database addDb6 string ""
cdsLibManager.database addDb7 string ""
cdsLibManager.database addDb8 string ""
cdsLibManager.database addDb9 string ""
cdsLibManager.database ddDb string "com.cadence.interfaces.libAccess.cddLib5xDatabase"
cdsLibManager.database server string "com.cadence.interfaces.libAccess.ladLibraryServer"
cdsLibManager.defaults fileRadio toggle (nil t nil)
cdsLibManager.defaults saveAllOn boolean nil
cdsLibManager.defaults saveAsText string ".cdsenv"
cdsLibManager.delete libCheckOn boolean t
cdsLibManager.delete localRadio toggle (t nil)
cdsLibManager.deleteTag overrideRadio toggle (t nil nil nil)
cdsLibManager.deleteView localRadio toggle (t nil)
cdsLibManager.filter cellFilter string ""
cdsLibManager.filter viewFilter string ""
; The log file format is 'baseName[.UID][.host][.PID][.sequence].log'
cdsLibManager.log addHostID boolean nil
cdsLibManager.log addProcID boolean nil
cdsLibManager.log addSequence boolean nil
cdsLibManager.log addUserID boolean nil
cdsLibManager.log baseName string "libManager"
cdsLibManager.main categoryText string ""
cdsLibManager.main cellLevelText string ""
cdsLibManager.main dblClickEditCellView boolean t
cdsLibManager.main libraryText string ""
cdsLibManager.main showCategoriesOn boolean nil
cdsLibManager.main showFilesOn boolean nil
cdsLibManager.main viewLevelText string ""
cdsLibManager.newLib dmRadio toggle (t nil)
cdsLibManager.newLib pathText string ""
cdsLibManager.option forceEnv boolean nil
cdsLibManager.option useDMfilter boolean t
cdsLibManager.option useFastDM boolean t
cdsLibManager.rename updateOn boolean t
cdsLibManager.renameRefLib refreshSessionOn boolean t
cdsLibManager.submit useNameOn boolean nil
cdsLibManager.submit useNameText string ""
cdsLibManager.submit useOptionText string ""
cdsLibManager.submit useOptionsOn boolean nil
cdsLibManager.update useNameOn boolean nil
cdsLibManager.update useNameText string ""
cdsLibManager.update useOptionText string ""
cdsLibManager.update useOptionsOn boolean nil
;cdsSpice environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;cdsSpice opts partition variables
cdsSpice.opts TEMPDC string "25"
cdsSpice.opts NSIG string "4"
cdsSpice.opts TIMSAT string "0"
cdsSpice.opts RELTOL string "1e-3"
cdsSpice.opts MKS string "1"
cdsSpice.opts ITL5 string "999999"
cdsSpice.opts ARTSTR string "0"
cdsSpice.opts GMINON string "2"
cdsSpice.opts LVLTIM string "2"
cdsSpice.opts VCESAT string "0.0"
cdsSpice.opts ITL3 string "4"
cdsSpice.opts SCALEM string "1"
cdsSpice.opts GO2OFF string "0"
cdsSpice.opts ITL4 string "25"
cdsSpice.opts AVSTEP string ".33"
cdsSpice.opts ITL1 string "100"
cdsSpice.opts ITL2 string "100"
cdsSpice.opts METHOD string "1"
cdsSpice.opts CHGTOL string "1e-14"
cdsSpice.opts TNOM string "25"
cdsSpice.opts MORBKP string ".1"
cdsSpice.opts ABSTOL string "1e-12"
cdsSpice.opts UIC string "0"
cdsSpice.opts SINWAV string "1e+6"
cdsSpice.opts GRTEXT string "1"
cdsSpice.opts PRNOTE string "1"
cdsSpice.opts VLIMAX string "50000"
cdsSpice.opts GMIN string "1e-12"
cdsSpice.opts GSAVE string "0"
cdsSpice.opts INTTIM string "0"
cdsSpice.opts CNVREV string "2.4"
cdsSpice.opts DCSAT string "0"
cdsSpice.opts TINIT string ""
cdsSpice.opts VBESAT string "0.6"
cdsSpice.opts QADLIN string "0"
cdsSpice.opts MFNOIS string "0"
cdsSpice.opts TRTOL string "7"
cdsSpice.opts SCALE string "1"
cdsSpice.opts PSFFLG string "1"
cdsSpice.opts SPICE2G string "0"
cdsSpice.opts WRFLAG string "0"
cdsSpice.opts SPTEMP string "1"
cdsSpice.opts RON string "1"
cdsSpice.opts NRAMP string "0"
cdsSpice.opts VNTOL string "1e-6"
cdsSpice.opts NOWARN string "0"
cdsSpice.opts VBCSAT string "0.15"
cdsSpice.opts DCOPPT string "1"
cdsSpice.opts MAXORD string "2"
cdsSpice.opts SPMESS string "1"
;cdsSpice outputs partition variables
cdsSpice.outputs allAnalogNV boolean t
cdsSpice.outputs allAnalogTC boolean nil
;cdsSpice envOpts partition variables
cdsSpice.envOpts updateFile string ""
cdsSpice.envOpts stimulusFile string ""
cdsSpice.envOpts instViewListTable string ""
cdsSpice.envOpts doInstBased boolean nil
cdsSpice.envOpts stopViewList string "cdsSpice spice"
cdsSpice.envOpts includeSyntax string "cdsSpice"
cdsSpice.envOpts initFile string ""
cdsSpice.envOpts printComments boolean nil
cdsSpice.envOpts netlistType string "hierarchical"
cdsSpice.envOpts generateMapFile boolean nil
cdsSpice.envOpts includeFile string ""
cdsSpice.envOpts instStopListTable string ""
cdsSpice.envOpts switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
;cdsSpice init partition variables
cdsSpice.init processPriority int 0
;cdsSpice dc partition variables
cdsSpice.dc enable toggle (nil)
cdsSpice.dc from string ""
cdsSpice.dc to string ""
cdsSpice.dc by string ""
cdsSpice.dc device string ""
;cdsSpice dcOpts partition variables
;cdsSpice noise partition variables
cdsSpice.noise enable toggle (nil)
cdsSpice.noise source string ""
cdsSpice.noise output string ""
cdsSpice.noise listEvery string "1"
;cdsSpice noiseOpts partition variables
;cdsSpice ac partition variables
cdsSpice.ac enable toggle (nil)
cdsSpice.ac from string ""
cdsSpice.ac to string ""
cdsSpice.ac incrType string "Logarithmic"
cdsSpice.ac lin string ""
cdsSpice.ac log string ""
;cdsSpice acOpts partition variables
;cdsSpice tran partition variables
cdsSpice.tran enable toggle (nil)
cdsSpice.tran from string ""
cdsSpice.tran to string ""
cdsSpice.tran by string ""
cdsSpice.tran delmax string ""
cdsSpice.tran continue boolean nil
cdsSpice.tran newParam boolean nil
;cdsSpice tranOpts partition variables
;cdsSpiceVerilog environment variables
;cdsSpiceVerilog opts partition variables
cdsSpiceVerilog.opts TEMPDC string "25"
cdsSpiceVerilog.opts NSIG string "4"
cdsSpiceVerilog.opts TIMSAT string "0"
cdsSpiceVerilog.opts RELTOL string "1e-3"
cdsSpiceVerilog.opts MKS string "1"
cdsSpiceVerilog.opts ITL5 string "999999"
cdsSpiceVerilog.opts ARTSTR string "0"
cdsSpiceVerilog.opts GMINON string "2"
cdsSpiceVerilog.opts LVLTIM string "2"
cdsSpiceVerilog.opts VCESAT string "0.0"
cdsSpiceVerilog.opts ITL3 string "4"
cdsSpiceVerilog.opts SCALEM string "1"
cdsSpiceVerilog.opts GO2OFF string "0"
cdsSpiceVerilog.opts ITL4 string "25"
cdsSpiceVerilog.opts AVSTEP string ".33"
cdsSpiceVerilog.opts ITL1 string "100"
cdsSpiceVerilog.opts ITL2 string "100"
cdsSpiceVerilog.opts METHOD string "1"
cdsSpiceVerilog.opts CHGTOL string "1e-14"
cdsSpiceVerilog.opts TNOM string "25"
cdsSpiceVerilog.opts MORBKP string ".1"
cdsSpiceVerilog.opts ABSTOL string "1e-12"
cdsSpiceVerilog.opts UIC string "0"
cdsSpiceVerilog.opts GRTEXT string "1"
cdsSpiceVerilog.opts SINWAV string "1e+6"
cdsSpiceVerilog.opts PRNOTE string "1"
cdsSpiceVerilog.opts VLIMAX string "50000"
cdsSpiceVerilog.opts INTTIM string "0"
cdsSpiceVerilog.opts GSAVE string "0"
cdsSpiceVerilog.opts GMIN string "1e-12"
cdsSpiceVerilog.opts DCSAT string "0"
cdsSpiceVerilog.opts CNVREV string "2.4"
cdsSpiceVerilog.opts TINIT string ""
cdsSpiceVerilog.opts MFNOIS string "0"
cdsSpiceVerilog.opts QADLIN string "0"
cdsSpiceVerilog.opts VBESAT string "0.6"
cdsSpiceVerilog.opts PSFFLG string "1"
cdsSpiceVerilog.opts SCALE string "1"
cdsSpiceVerilog.opts TRTOL string "7"
cdsSpiceVerilog.opts SPICE2G string "0"
cdsSpiceVerilog.opts SPTEMP string "1"
cdsSpiceVerilog.opts WRFLAG string "0"
cdsSpiceVerilog.opts RON string "1"
cdsSpiceVerilog.opts NRAMP string "0"
cdsSpiceVerilog.opts NOWARN string "0"
cdsSpiceVerilog.opts VNTOL string "1e-6"
cdsSpiceVerilog.opts MAXORD string "2"
cdsSpiceVerilog.opts DCOPPT string "1"
cdsSpiceVerilog.opts VBCSAT string "0.15"
cdsSpiceVerilog.opts SPMESS string "1"
;cdsSpiceVerilog outputs partition variables
cdsSpiceVerilog.outputs allDigitalNV boolean t
cdsSpiceVerilog.outputs allAnalogNV boolean t
cdsSpiceVerilog.outputs allAnalogTC boolean nil
;cdsSpiceVerilog verimixOpts partition variables
cdsSpiceVerilog.verimixOpts filename6 string ""
cdsSpiceVerilog.verimixOpts maxDCIter int 0
cdsSpiceVerilog.verimixOpts scope1 string ""
cdsSpiceVerilog.verimixOpts scope10 string ""
cdsSpiceVerilog.verimixOpts filename8 string ""
cdsSpiceVerilog.verimixOpts dcInterval float 0.0
cdsSpiceVerilog.verimixOpts scope3 string ""
cdsSpiceVerilog.verimixOpts scope8 string ""
cdsSpiceVerilog.verimixOpts scope7 string ""
cdsSpiceVerilog.verimixOpts filename7 string ""
cdsSpiceVerilog.verimixOpts scope string ""
cdsSpiceVerilog.verimixOpts filename4 string ""
cdsSpiceVerilog.verimixOpts filename string ""
cdsSpiceVerilog.verimixOpts filename1 string ""
cdsSpiceVerilog.verimixOpts scope9 string ""
cdsSpiceVerilog.verimixOpts importsdfswitch boolean nil
cdsSpiceVerilog.verimixOpts filename2 string ""
cdsSpiceVerilog.verimixOpts numberofsdffiles int 2
cdsSpiceVerilog.verimixOpts scope2 string ""
cdsSpiceVerilog.verimixOpts scope6 string ""
cdsSpiceVerilog.verimixOpts filename10 string ""
cdsSpiceVerilog.verimixOpts delaymodechoice string "Ignore"
cdsSpiceVerilog.verimixOpts sdfmixedswitch boolean t
cdsSpiceVerilog.verimixOpts filename9 string ""
cdsSpiceVerilog.verimixOpts scope5 string ""
cdsSpiceVerilog.verimixOpts filename5 string ""
cdsSpiceVerilog.verimixOpts filename3 string ""
cdsSpiceVerilog.verimixOpts scope4 string ""
;cdsSpiceVerilog verilogOpts partition variables
cdsSpiceVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
cdsSpiceVerilog.verilogOpts optionsFile string ""
cdsSpiceVerilog.verilogOpts twinTurbo boolean nil
cdsSpiceVerilog.verilogOpts suppressMessages boolean nil
cdsSpiceVerilog.verilogOpts libraryFile string ""
cdsSpiceVerilog.verilogOpts behaveProfile boolean nil
cdsSpiceVerilog.verilogOpts verimixLog string "verilog.log"
cdsSpiceVerilog.verilogOpts simVision boolean nil
cdsSpiceVerilog.verilogOpts pulseSpec boolean nil
cdsSpiceVerilog.verilogOpts commandFile string ""
cdsSpiceVerilog.verilogOpts pulseError int 100
cdsSpiceVerilog.verilogOpts stopCompile boolean nil
cdsSpiceVerilog.verilogOpts keepNodes string "Minimum"
cdsSpiceVerilog.verilogOpts accelerationCA boolean nil
cdsSpiceVerilog.verilogOpts turboRadio string "Default"
cdsSpiceVerilog.verilogOpts libraryDir string ""
cdsSpiceVerilog.verilogOpts suppressWarnings boolean nil
cdsSpiceVerilog.verilogOpts accelerationSwitches boolean nil
cdsSpiceVerilog.verilogOpts accelerationNormal boolean t
cdsSpiceVerilog.verilogOpts delayType string "Typical"
cdsSpiceVerilog.verilogOpts pulseReject int 100
cdsSpiceVerilog.verilogOpts delayMode string "Default"
cdsSpiceVerilog.verilogOpts vermixBinary string "verilog.vmx"
;cdsSpiceVerilog init partition variables
cdsSpiceVerilog.init processPriority int 0
;cdsSpiceVerilog envOpts partition variables
cdsSpiceVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
cdsSpiceVerilog.envOpts mspNetlistMode string "Flat"
cdsSpiceVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistEscapeName boolean nil
cdsSpiceVerilog.envOpts updateFile string ""
cdsSpiceVerilog.envOpts stimulusFile string ""
cdsSpiceVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
cdsSpiceVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
cdsSpiceVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
cdsSpiceVerilog.envOpts includeSyntax string "cdsSpice"
cdsSpiceVerilog.envOpts mspSetupNetlistPinMap boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistBus boolean t
cdsSpiceVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
cdsSpiceVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
cdsSpiceVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
cdsSpiceVerilog.envOpts mspSetupNetlistExplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
cdsSpiceVerilog.envOpts initFile string ""
cdsSpiceVerilog.envOpts printComments boolean nil
cdsSpiceVerilog.envOpts includeFile string ""
cdsSpiceVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
cdsSpiceVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
cdsSpiceVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistSimTimeValue int 1
cdsSpiceVerilog.envOpts mspSetupNetlistUseLib boolean nil
cdsSpiceVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistNullPort boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistDropPortRange boolean t
cdsSpiceVerilog.envOpts mspSetupNetlistUpCase boolean nil
cdsSpiceVerilog.envOpts generateMapFile boolean nil
cdsSpiceVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;cdsSpiceVerilog dc partition variables
cdsSpiceVerilog.dc enable toggle (nil)
cdsSpiceVerilog.dc from string ""
cdsSpiceVerilog.dc to string ""
cdsSpiceVerilog.dc by string ""
cdsSpiceVerilog.dc device string ""
;cdsSpiceVerilog dcOpts partition variables
;cdsSpiceVerilog noise partition variables
cdsSpiceVerilog.noise enable toggle (nil)
cdsSpiceVerilog.noise source string ""
cdsSpiceVerilog.noise output string ""
cdsSpiceVerilog.noise listEvery string "1"
;cdsSpiceVerilog noiseOpts partition variables
;cdsSpiceVerilog ac partition variables
cdsSpiceVerilog.ac enable toggle (nil)
cdsSpiceVerilog.ac from string ""
cdsSpiceVerilog.ac to string ""
cdsSpiceVerilog.ac incrType string "Logarithmic"
cdsSpiceVerilog.ac lin string ""
cdsSpiceVerilog.ac log string ""
;cdsSpiceVerilog acOpts partition variables
;cdsSpiceVerilog tran partition variables
cdsSpiceVerilog.tran enable toggle (nil)
cdsSpiceVerilog.tran from string ""
cdsSpiceVerilog.tran to string ""
cdsSpiceVerilog.tran by string ""
cdsSpiceVerilog.tran delmax string ""
cdsSpiceVerilog.tran continue boolean nil
cdsSpiceVerilog.tran newParam boolean nil
;cdsSpiceVerilog tranOpts partition variables
; CMX CONSTRAINT MANAGER - ENVIRONMENT VARIABLES (FACTORY DEFAULTS)
; This tool registration file should not be edited since customization
; is done via the file in <cdshier>/samples/.cdsenv
;FACTORY DEFAULTS FOR NET-BASED SUPER CATEGORY (cmxNetBasedSuperCat)
;Net Class To Net Category (cmxClassToNetCat)
;default weight for constraints
cmx.cmxClassToNetCat defaultWeight int 200
;inter-layer clearance
cmx.cmxClassToNetCat defVal_ilc float 0.0
cmx.cmxClassToNetCat minVal_ilc float 0.0
cmx.cmxClassToNetCat maxVal_ilc float 0.0
;layer depth
cmx.cmxClassToNetCat defVal_depth int 0
cmx.cmxClassToNetCat minVal_depth int 0
cmx.cmxClassToNetCat maxVal_depth int 0
;Net-Class To Net-Class Category (cmxClassToClassCat)
cmx.cmxClassToClassCat defaultWeight int 200
cmx.cmxClassToClassCat defVal_ilc float 0.0
cmx.cmxClassToClassCat minVal_ilc float 0.0
cmx.cmxClassToClassCat maxVal_ilc float 0.0
;layer depth
cmx.cmxClassToClassCat defVal_depth int 0
cmx.cmxClassToClassCat minVal_depth int 0
cmx.cmxClassToClassCat maxVal_depth int 0
;Net To Net Category (cmxNetToNetCat)
cmx.cmxNetToNetCat defaultWeight int 200
cmx.cmxNetToNetCat defVal_ilc float 0.0
cmx.cmxNetToNetCat minVal_ilc float 0.0
cmx.cmxNetToNetCat maxVal_ilc float 0.0
;layer depth
cmx.cmxNetToNetCat defVal_depth int 0
cmx.cmxNetToNetCat minVal_depth int 0
cmx.cmxNetToNetCat maxVal_depth int 0
;differential pair gap
cmx.cmxNetToNetCat defVal_diffgap float 0.0
cmx.cmxNetToNetCat minVal_diffgap float 0.0
cmx.cmxNetToNetCat maxVal_diffgap float 0.0
;tandem shield overhang
cmx.cmxNetToNetCat defVal_tanhang float 0.0
cmx.cmxNetToNetCat minVal_tanhang float 0.0
cmx.cmxNetToNetCat maxVal_tanhang float 0.0
;parallel shield gap
cmx.cmxNetToNetCat defVal_pargap float 0.0
cmx.cmxNetToNetCat minVal_pargap float 0.0
cmx.cmxNetToNetCat maxVal_pargap float 0.0
;parallel shield width
cmx.cmxNetToNetCat defVal_parwidth float 0.0
cmx.cmxNetToNetCat minVal_parwidth float 0.0
cmx.cmxNetToNetCat maxVal_parwidth float 0.0
;Net/Net-Class Category (cmxNetCat)
cmx.cmxNetCat defaultWeight int 200
;net priority
cmx.cmxNetCat defVal_pri int 0
cmx.cmxNetCat minVal_pri int 0
cmx.cmxNetCat maxVal_pri int 255
;net width
cmx.cmxNetCat defVal_width float 0.0
cmx.cmxNetCat minVal_width float 0.0
cmx.cmxNetCat maxVal_width float 0.0
;minimum IR drop
cmx.cmxNetCat defVal_minird float 0.0
cmx.cmxNetCat minVal_minird float 0.0
cmx.cmxNetCat maxVal_minird float 0.0
;maximum IR drop
cmx.cmxNetCat defVal_maxird float 0.0
cmx.cmxNetCat minVal_maxird float 0.0
cmx.cmxNetCat maxVal_maxird float 0.0
;FACTORY DEFAULTS FOR GEOMETRIC SUPER CATEGORY (cmxGeometricSuperCat)
;Symmetry Category (cmxSymCat)
cmx.cmxSymCat defaultWeight int 200
;axis name
cmx.cmxSymCat defVal_axis string ""
;Grouping Category (cmxGroupingCat)
cmx.cmxGroupingCat defaultWeight int 200
;preserve relative position
cmx.cmxGroupingCat defVal_prPos boolean t
;no fence needed
cmx.cmxGroupingCat defVal_noFence boolean t
;fence shape name
cmx.cmxGroupingCat defVal_fence string ""
;exclude all
cmx.cmxGroupingCat defVal_exclAll boolean nil
;Alignment Category (cmxAlignCat)
cmx.cmxAlignCat defaultWeight int 200
;orientation
cmx.cmxAlignCat defVal_orient string "NO_CARE"
;alignment reference
cmx.cmxAlignCat defVal_alignRef string "NO_CARE"
;reference segment
cmx.cmxAlignCat defVal_segment int 0
;inner or outer edge
cmx.cmxAlignCat defVal_inner boolean t
;alignment layer
cmx.cmxAlignCat defVal_alignLayer string "bBox"
;check ordering
cmx.cmxAlignCat defVal_order boolean t
;compactor direction (for Compactor only)
cmx.cmxAlignCat defVal_compactDir boolean nil
;Fixed Category (cmxFixedCat)
cmx.cmxFixedCat defaultWeight int 200
;check x position
cmx.cmxFixedCat defVal_x boolean t
;default x value
cmx.cmxFixedCat defVal_xVal float 0.0
;check y position
cmx.cmxFixedCat defVal_y boolean t
;default y value
cmx.cmxFixedCat defVal_yVal float 0.0
;default orientation
cmx.cmxFixedCat defVal_orient string "AS_IS"
;default reference
cmx.cmxFixedCat defVal_refer string "CENTER"
;default user movable
cmx.cmxFixedCat defVal_userMovable boolean nil
;Distance Category (cmxDistCat)
cmx.cmxDistCat defaultWeight int 200
;check minimum manhattan x distance
cmx.cmxDistCat defVal_minX boolean t
;minimum manhattan x distance value
cmx.cmxDistCat defVal_minXVal float 0.0
;check maximum manhattan x distance
cmx.cmxDistCat defVal_maxX boolean t
;maximum manhattan x distance value
cmx.cmxDistCat defVal_maxXVal float 0.0
;check minimum manhattan y distance
cmx.cmxDistCat defVal_minY boolean t
;minimum manhattan y distance value
cmx.cmxDistCat defVal_minYVal float 0.0
;check maximum manhattan y distance
cmx.cmxDistCat defVal_maxY boolean t
;maximum manhattan y distance
cmx.cmxDistCat defVal_maxYVal float 0.0
;reference for measurement on x-axis
cmx.cmxDistCat defVal_referX string "CENTER"
;reference for measurement on y-axis
cmx.cmxDistCat defVal_referY string "CENTER"
;ROD Alignment Category (cmxRodAlignCat)
;default name for ROD object 1
;default handle name for ROD object 1
;default name for ROD object 2
;default handle name for ROD object 2
compactor hilite1LPP string "hilite drawing"
compactor hilite2LPP string "marker error"
compactor hilite3LPP string "hilite drawing1"
compactor hilite4LPP string "hilite drawing2"
compactor cpCpathLPP string "annotate drawing7"
compactor cpAuxLPP string "annotate drawing8"
compactor cpOutlineLPP string "annotate drawing9"
compactor useDBox boolean t
compactor arrowScale float 1.0
compactor zoomScale float 1.2
compactor checkSaved boolean t
conn2sch src_sch_lib string ""
conn2sch src_cell_name string ""
conn2sch src_view_name string ""
conn2sch dest_sch_lib string ""
conn2sch dest_view_name string "schematic"
conn2sch dest_cell_name string ""
conn2sch dest_symbol_view_name string "symbol"
conn2sch ref_lib_list string "analogLib basic sample"
conn2sch log_file_name string "./conn2sch.log"
conn2sch import_if_exists int 0
conn2sch sheet_symbol string "none "
conn2sch line_line_spacing float 0.2
conn2sch line_component_spacing float 0.5
conn2sch density_level int 0
conn2sch label_height int 10
conn2sch pin_placement string "left_and_right_sides"
conn2sch page_col_limit int 1024
conn2sch page_row_limit int 1024
conn2sch full_place_and_route boolean t
conn2sch optimize_wire_label_locn boolean nil
conn2sch minimize_crossovers boolean nil
conn2sch generate_square_schematic boolean t
conn2sch extract_schematic boolean t
conn2sch verbose boolean nil
;Digital Ciruit Design Flow Environment Defaults
;FORMAT: tool[.partition] varName type value private {choices, minmax} comment
;Session Options
dcdf dcdfNoDirectNetlister boolean nil
dcdf dcdfDefaultFileDir string ""
; ddserv Environment Variables
ddserv.browser onOpen boolean nil
ddserv.browser onOther boolean nil
ddserv.browser onPlace boolean nil
ddserv.ciw promptOnExit boolean t
ddserv.he objectFilter string "same"
ddserv.he objectScope string "current instance"
ddserv.lib dmChoice string "No DM"
ddserv.lib enableCopyInDFII boolean nil
ddserv.lib newLibDir string ""
ddserv.lib techChoice cyclic "compile"
ddserv showWhatsNew string "yes"
; Graphics Editor and Design Editor Environment Variables
; Installation-wide customizations should be made to the
; to the .cdsenv file in $CDS_INST_DIR/tools/dfII/samples
; directory. Make user-specific customizations to the
; .cdsenv file in your home directory.
graphic accessEdgesOn boolean nil
graphic arrayDisplay string "Full"
graphic askSaveOnReturn boolean t
graphic coalesceLimit int 10
graphic coalesceRatio int 10
graphic defaultNewCellName string ""
graphic defaultNewLibName string ""
graphic defaultNewViewName string ""
graphic defaultOpenCellName string ""
graphic defaultOpenLibName string ""
graphic defaultOpenViewName string ""
graphic defaultToolName string ""
graphic displayPinNames boolean t
graphic displayStretchHandles boolean t
graphic displaySchDashText boolean nil
graphic dotsOn boolean t
graphic drawAxesOn boolean t
graphic drawDottedGridOn boolean t
graphic drawGridOn boolean t
graphic drawInstancePins boolean t
graphic drawPRBoundary boolean nil
graphic drawSurroundingOn boolean t
graphic drfPath string ""
graphic dynamicHilightOn boolean t
graphic eipRedraw boolean t
graphic filterSize float 1.0
graphic filterSizeDrawingStyle string "filled"
graphic gridMultiple int 5
graphic gridSpacing float 1.0
graphic iconsOn boolean t
graphic instLabel string "master"
graphic iterNum int 500
graphic jumpersOn boolean t
graphic leCheckMissingLayers boolean nil
graphic leCheckMissingMasters boolean nil
graphic leDispNetExpr boolean t
graphic markerZoom boolean nil
graphic markerShowIgnore boolean t
graphic markerSeverity string "all"
graphic markerZoomScale int 4
graphic maxDragFig int 500
graphic minLabelSize float 1.0
graphic minRefreshArea int 500
graphic minStippleSize float 1.0
graphic netsOn boolean t
graphic originMarkersOn boolean t
graphic outlineOnly boolean t
graphic packetDialogBoxes boolean t
graphic partialSelect boolean t
graphic pathCL string "yes"
graphic netExprDisplay string "expression only"
graphic pathWidth float 5.0
graphic probeTextOn boolean t
graphic pruneSize float 10
graphic segSnapMode string "anyAngle"
graphic selectionAperture int 5
graphic snapMode string "anyAngle"
graphic snapToGrid boolean t
graphic startLevel int 0
graphic stopLevel int 0
graphic stretchHandlesLayer string "y0 drawing"
graphic textJustificationOn boolean t
graphic tinyInstDetail boolean nil
graphic transformMarkersOn boolean t
graphic useTrueBBox boolean t
graphic viewNameList string ""
graphic viewNameToTypeList string ""
graphic xSnapSpacing float 1.0
graphic ySnapSpacing float 1.0
graphic cursorShape boolean nil
graphic drawEngine int 0
graphic openToStopLevel boolean nil
graphic displayViaShapes boolean nil
;hspiceD environment variables
;hspiceD opts partition variables
hspiceD.opts PARHIER string "LOCAL"
hspiceD.opts GENK boolean nil
hspiceD.opts RISETIME string "0"
hspiceD.opts RELQ string "1e-2"
hspiceD.opts FFTOUT boolean nil
hspiceD.opts LVLTIM string "DVDT (1)"
hspiceD.opts ARTIST string "On (2)"
hspiceD.opts NEWTOL boolean nil
hspiceD.opts ABSMOS string "1e-6"
hspiceD.opts DIAGNOSTIC boolean nil
hspiceD.opts MODMONTE boolean nil
hspiceD.opts VFLOOR string "0"
hspiceD.opts FS string "25e-2"
hspiceD.opts CO string "Narrow (80)"
hspiceD.opts DEFAS string "0"
hspiceD.opts RESMIN string "1e-5"
hspiceD.opts WARNLIMIT string "1"
hspiceD.opts TRCON string "On (1)"
hspiceD.opts PSF string "ASCII (2)"
hspiceD.opts BRIEF boolean nil
hspiceD.opts ICSWEEP boolean nil
hspiceD.opts DCFOR string "0"
hspiceD.opts DCHOLD string "1"
hspiceD.opts GMIN string "1e-12"
hspiceD.opts INGOLD string "SPICE (2)"
hspiceD.opts NODE boolean nil
hspiceD.opts DCSTEP string "0"
hspiceD.opts ZUKEN string "Off (1)"
hspiceD.opts TRTOL string "7"
hspiceD.opts BYTOL string "5e-5"
hspiceD.opts AUTOSTOP boolean nil
hspiceD.opts LIMTIM string "2.0"
hspiceD.opts EXPMAX string "8e+1"
hspiceD.opts DVDT string "Balance (3)"
hspiceD.opts PUTMEAS boolean nil
hspiceD.opts NOWARN boolean nil
hspiceD.opts MONTECON boolean nil
hspiceD.opts BEEP string "Off (0)"
hspiceD.opts MEASSORT boolean nil
hspiceD.opts NUMDGT string "4"
hspiceD.opts ITL5 string "0"
hspiceD.opts BADCHR boolean nil
hspiceD.opts PIVTOL string "1e-15"
hspiceD.opts METHOD string "TRAP"
hspiceD.opts LIMPTS string "2001"
hspiceD.opts CHGTOL string "1e-15"
hspiceD.opts GSHUNT string "0"
hspiceD.opts DVTR string "1e+3"
hspiceD.opts DI string "0"
hspiceD.opts HIER_SCALE string "None ()"
hspiceD.opts CSHDC string "1e-12"
hspiceD.opts RELI string "1e-2"
hspiceD.opts PATHNUM boolean nil
hspiceD.opts DEFW string "1e-4"
hspiceD.opts POST_VERSION string "2001"
hspiceD.opts DCON string "Auto (0)"
hspiceD.opts DEFL string "1e-4"
hspiceD.opts DEFNRS string "0"
hspiceD.opts ABSV string "5e-5"
hspiceD.opts CONVERGE string "Autoconvergance (0)"
hspiceD.opts NOPIV boolean nil
hspiceD.opts LENNAM string "8"
hspiceD.opts DCAP string "2"
hspiceD.opts DLENCSDF string "5"
hspiceD.opts ITLPZ string "100"
hspiceD.opts MBYPASS string "1"
hspiceD.opts GMINDC string "1e-12"
hspiceD.opts RELV string "1e-3"
hspiceD.opts GRAMP string "0"
hspiceD.opts ASPEC boolean nil
hspiceD.opts DV string "1e+3"
hspiceD.opts SEED string "259200"
hspiceD.opts RMIN string "1e-9"
hspiceD.opts RELVDC string "1e-3"
hspiceD.opts ACCT string "Enabled (1)"
hspiceD.opts RELMOS string "5e-2"
hspiceD.opts TEMPDC string "25"
hspiceD.opts ACCURATE boolean nil
hspiceD.opts CSDF boolean nil
hspiceD.opts SEARCH boolean nil
hspiceD.opts MAXAMP string "0"
hspiceD.opts NOMOD boolean nil
hspiceD.opts PIVREF string "1e8"
hspiceD.opts NOPAGE boolean nil
hspiceD.opts ALT9999 boolean nil
hspiceD.opts CAPTAB boolean nil
hspiceD.opts ITL1 string "2e+2"
hspiceD.opts ITL2 string "5e+1"
hspiceD.opts POST string "Binary (1)"
hspiceD.opts PIVREL string "1e-20"
hspiceD.opts ALT999 boolean nil
hspiceD.opts MEASFAIL boolean nil
hspiceD.opts STATFL string "Create .st0 (0)"
hspiceD.opts BKPSIZ string "5000"
hspiceD.opts ABSVAR string ".5"
hspiceD.opts ITRPRT boolean nil
hspiceD.opts SPICE boolean nil
hspiceD.opts GMAX string "1e+2"
hspiceD.opts RMAX string "2"
hspiceD.opts OFF boolean nil
hspiceD.opts BYPASS string "1"
hspiceD.opts OPTS boolean nil
hspiceD.opts IMIN string "3"
hspiceD.opts KCLTEST boolean nil
hspiceD.opts CDS string "Off (0)"
hspiceD.opts RELH string "5e-2"
hspiceD.opts ALTCHK string "On (1)"
hspiceD.opts ACOUT string "Star-Hspice Method (1)"
hspiceD.opts FT string "25e-2"
hspiceD.opts WL boolean nil
hspiceD.opts LIST boolean nil
hspiceD.opts RELVAR string ".30"
hspiceD.opts MAXORD string "Normal (2)"
hspiceD.opts DEFPS string "0"
hspiceD.opts MEASOUT boolean nil
hspiceD.opts FAST boolean nil
hspiceD.opts CPTIME string "1e+7"
hspiceD.opts IMAX string "8"
hspiceD.opts DEFNRD string "0"
hspiceD.opts OPTLST string "No Info (0)"
hspiceD.opts ABSVDC string "5e-5"
hspiceD.opts INTERP boolean nil
hspiceD.opts PROBE boolean nil
hspiceD.opts DCCAP boolean nil
hspiceD.opts DEFAD string "0"
hspiceD.opts TIMERES string "1e-15"
hspiceD.opts SCALM string "1"
hspiceD.opts TNOM string "25"
hspiceD.opts POSTTOP string "0"
hspiceD.opts MODSRH boolean nil
hspiceD.opts KLIM string "1e-2"
hspiceD.opts H9007 boolean nil
hspiceD.opts UNWRAP boolean nil
hspiceD.opts CVTOL string ".2"
hspiceD.opts PLIM string "SPICE (1)"
hspiceD.opts MENTOR string "Off (0)"
hspiceD.opts MEASDGT string "4"
hspiceD.opts NOTOP boolean nil
hspiceD.opts MU string ".5"
hspiceD.opts DEFPD string "0"
hspiceD.opts SLOPETOL string ".5"
hspiceD.opts SCALE string "1"
hspiceD.opts CSHUNT string "0"
hspiceD.opts EPSMIN string "1e-28"
hspiceD.opts EXPLI string "0"
hspiceD.opts NOELCK boolean nil
hspiceD.opts ABSI string "1e-9"
hspiceD.opts BINPRINT boolean nil
hspiceD.opts PIVOT string "Fast, non-pivoting (10)"
hspiceD.opts ITLPTRAN string "30"
hspiceD.opts PURETP boolean nil
hspiceD.opts ABSH string "0"
;hspiceD outputs partition variables
hspiceD.outputs allAnalogNV boolean t
hspiceD.outputs allAnalogTC boolean nil
;hspiceD envOpts partition variables
hspiceD.envOpts autoDisplay boolean t
hspiceD.envOpts stopViewList string "hspiceD spice"
hspiceD.envOpts printComments boolean nil
hspiceD.envOpts switchViewList string "hspiceD spice cmos_sch cmos.sch schematic"
;hspiceD init partition variables
hspiceD.init processPriority int 0
;hspiceD ac partition variables
hspiceD.ac enable toggle (nil)
hspiceD.ac sweepType string "decade"
hspiceD.ac numPoints string "10"
hspiceD.ac fstart string ""
hspiceD.ac fstop string ""
hspiceD.ac points string ""
;hspiceD acOpts partition variables
;hspiceD dc partition variables
hspiceD.dc enable toggle (nil)
hspiceD.dc sweep string "Source"
hspiceD.dc designVar string ""
hspiceD.dc source string ""
hspiceD.dc sweepType string "Automatic"
hspiceD.dc start string ""
hspiceD.dc stop string ""
hspiceD.dc stepSize string ""
hspiceD.dc numPoints string ""
hspiceD.dc poiNumPoints string ""
hspiceD.dc points string ""
;hspiceD dcOpts partition variables
;hspiceD noise partition variables
hspiceD.noise enable toggle (nil)
hspiceD.noise node string ""
hspiceD.noise insrc string ""
hspiceD.noise nums string "0"
;hspiceD noiseOpts partition variables
;hspiceD op partition variables
hspiceD.op enable toggle (nil)
hspiceD.op format string "all"
hspiceD.op time string ""
;hspiceD opOpts partition variables
;hspiceD tran partition variables
hspiceD.tran enable toggle (nil)
hspiceD.tran start string ""
hspiceD.tran stop string ""
hspiceD.tran step string ""
hspiceD.tran uic boolean nil
;hspiceD tranOpts partition variables
;hspiceS environment variables
;hspiceS opts partition variables
hspiceS.opts PARHIER string "GLOBAL"
hspiceS.opts GENK string "1"
hspiceS.opts RELQ string "1e-2"
hspiceS.opts LVLTIM string "default ( 1 )"
hspiceS.opts BKPSZE string "5000"
hspiceS.opts ARTIST string "artistdefault ( 2 )"
hspiceS.opts ABSMOS string "1e-6"
hspiceS.opts NEWTOL string "off"
hspiceS.opts RMAXDC string "1e+2"
hspiceS.opts DIAGNOSTIC string "off"
hspiceS.opts VFLOOR string "0"
hspiceS.opts FS string "25e-2"
hspiceS.opts CO string "78"
hspiceS.opts DEFAS string "0"
hspiceS.opts UIC string "off"
hspiceS.opts RESMIN string "1e-5"
hspiceS.opts WARNLIMIT string "1"
hspiceS.opts PSF string "artistdefault ( 2 )"
hspiceS.opts BRIEF string "off"
hspiceS.opts ICSWEEP string "default ( 1 )"
hspiceS.opts DCFOR string "0"
hspiceS.opts DCHOLD string "1"
hspiceS.opts GMIN string "1e-12"
hspiceS.opts INGOLD string "artistdefault ( 2 )"
hspiceS.opts DCSTEP string "0"
hspiceS.opts NODE string "off"
hspiceS.opts TRTOL string "7"
hspiceS.opts LIMTIM string "2.0"
hspiceS.opts EXPMAX string "8e+1"
hspiceS.opts DVDT string "default ( 3 )"
hspiceS.opts NOWARN string "off"
hspiceS.opts ITL5 string "0"
hspiceS.opts NUMDGT string "default ( 4 )"
hspiceS.opts BADCHR string "off"
hspiceS.opts PIVTOL string "1e-15"
hspiceS.opts LIMPTS string "2001"
hspiceS.opts METHOD string "TRAP"
hspiceS.opts CHGTOL string "1e-15"
hspiceS.opts GSHUNT string "0"
hspiceS.opts DVTR string "1e+3"
hspiceS.opts DI string "1e+2"
hspiceS.opts CSHDC string "1e-12"
hspiceS.opts RELI string "1e-2"
hspiceS.opts PATHNUM string "off"
hspiceS.opts DEFW string "1e-4"
hspiceS.opts DCON string "default ( 0 )"
hspiceS.opts DEFL string "1e-4"
hspiceS.opts DEFNRS string "0"
hspiceS.opts TIMRES string "1E-12"
hspiceS.opts CONVERGE string "default ( 1 )"
hspiceS.opts ABSV string "5e-5"
hspiceS.opts LENNAM string "8"
hspiceS.opts NOPIV string "off"
hspiceS.opts DCAP string "default ( 2 )"
hspiceS.opts GMINDC string "1e-12"
hspiceS.opts RELV string "1e-3"
hspiceS.opts GRAMP string "0"
hspiceS.opts ASPEC string "off"
hspiceS.opts DV string "1e+3"
hspiceS.opts RMIN string "1e-9"
hspiceS.opts RELVDC string "1e-3"
hspiceS.opts ACCT string "default ( 1 )"
hspiceS.opts SPMESS string "default ( 1 )"
hspiceS.opts RELMOS string "5e-2"
hspiceS.opts TEMPDC string "25"
hspiceS.opts CSDF string "off"
hspiceS.opts ACCURA string "off"
hspiceS.opts MAXAMP string "0"
hspiceS.opts NOMOD string "off"
hspiceS.opts PIVREF string "1e8"
hspiceS.opts NOPAGE string "off"
hspiceS.opts CAPTAB string "off"
hspiceS.opts ITL1 string "2e+2"
hspiceS.opts ITL2 string "5e+1"
hspiceS.opts POST string "default ( 0 )"
hspiceS.opts PIVREL string "1e-4"
hspiceS.opts ABSVAR string ".5"
hspiceS.opts ITRPRT string "off"
hspiceS.opts SPICE string "off"
hspiceS.opts GMAX string "1e+2"
hspiceS.opts RMAX string "2"
hspiceS.opts BYPASS string "default ( 0 )"
hspiceS.opts OFF string "0"
hspiceS.opts IMIN string "3"
hspiceS.opts KCLTEST string "off"
hspiceS.opts OPTS string "off"
hspiceS.opts RELH string "5e-2"
hspiceS.opts ACOUT string "default ( 1 )"
hspiceS.opts FT string "25e-2"
hspiceS.opts WL string "default ( 0 )"
hspiceS.opts LIST string "on"
hspiceS.opts RELVAR string ".30"
hspiceS.opts DCOPPT string "1"
hspiceS.opts MAXORD string "default ( 2 )"
hspiceS.opts DEFPS string "0"
hspiceS.opts MEASOUT string "on"
hspiceS.opts FAST string "off"
hspiceS.opts CPTIME string "1e+7"
hspiceS.opts IMAX string "8"
hspiceS.opts DEFNRD string "0"
hspiceS.opts OPTLST string "default ( 0 )"
hspiceS.opts ABSVDC string "5e-5"
hspiceS.opts INTERP string "0"
hspiceS.opts DCCAP string "off"
hspiceS.opts DEFAD string "0"
hspiceS.opts SCALM string "1"
hspiceS.opts TNOM string "25"
hspiceS.opts DOIRSCAL string "0"
hspiceS.opts KLIM string "1e-2"
hspiceS.opts AUTOST string "off"
hspiceS.opts H9007 string "off"
hspiceS.opts UNWRAP string "off"
hspiceS.opts CVTOL string ".2"
hspiceS.opts PLIM string "default ( 1 )"
hspiceS.opts K2LIM string "0"
hspiceS.opts MBYPAS string "1"
hspiceS.opts MEASDGT string "default ( 4 )"
hspiceS.opts DEFPD string "0"
hspiceS.opts MU string ".5"
hspiceS.opts NOTOP string "off"
hspiceS.opts SCALE string "1"
hspiceS.opts CSHUNT string "0"
hspiceS.opts EPSMIN string "1e-28"
hspiceS.opts SDA string "default ( 0 )"
hspiceS.opts ABSI string "1e-9"
hspiceS.opts NOELCK string "off"
hspiceS.opts PIVOT string "default ( 10 )"
hspiceS.opts ABSH string "0"
;hspiceS outputs partition variables
hspiceS.outputs allAnalogNV boolean t
;hspiceS envOpts partition variables
hspiceS.envOpts updateFile string ""
hspiceS.envOpts stimulusFile string ""
hspiceS.envOpts instViewListTable string ""
hspiceS.envOpts doInstBased boolean nil
hspiceS.envOpts stopViewList string "hspiceS spice"
hspiceS.envOpts reNetlist boolean nil
hspiceS.envOpts includeSyntax string "cdsSpice"
hspiceS.envOpts initFile string ""
hspiceS.envOpts printComments boolean nil
hspiceS.envOpts netlistType string "hierarchical"
hspiceS.envOpts generateMapFile boolean nil
hspiceS.envOpts includeFile string ""
hspiceS.envOpts instStopListTable string ""
hspiceS.envOpts switchViewList string "hspiceS spice cmos_sch cmos.sch schematic"
;hspiceS init partition variables
hspiceS.init processPriority int 0
;hspiceS dc partition variables
hspiceS.dc enable toggle (nil)
hspiceS.dc from string ""
hspiceS.dc to string ""
hspiceS.dc by string ""
hspiceS.dc device string ""
;hspiceS dcOpts partition variables
;hspiceS noise partition variables
hspiceS.noise enable toggle (nil)
hspiceS.noise source string ""
hspiceS.noise output string ""
hspiceS.noise listEvery string "1"
;hspiceS noiseOpts partition variables
;hspiceS ac partition variables
hspiceS.ac enable toggle (nil)
hspiceS.ac from string ""
hspiceS.ac to string ""
hspiceS.ac incrType string "Logarithmic"
hspiceS.ac lin string ""
hspiceS.ac log string ""
;hspiceS acOpts partition variables
;hspiceS tran partition variables
hspiceS.tran enable toggle (nil)
hspiceS.tran from string ""
hspiceS.tran to string ""
hspiceS.tran by string ""
hspiceS.tran delmax string ""
;hspiceS tranOpts partition variables
;hspiceSVerilog environment variables
;hspiceSVerilog opts partition variables
hspiceSVerilog.opts GENK string "1"
hspiceSVerilog.opts PARHIER string "GLOBAL"
hspiceSVerilog.opts RELQ string "1e-2"
hspiceSVerilog.opts LVLTIM string "default ( 1 )"
hspiceSVerilog.opts ARTIST string "artistdefault ( 2 )"
hspiceSVerilog.opts BKPSZE string "5000"
hspiceSVerilog.opts NEWTOL string "off"
hspiceSVerilog.opts ABSMOS string "1e-6"
hspiceSVerilog.opts RMAXDC string "1e+2"
hspiceSVerilog.opts DIAGNOSTIC string "off"
hspiceSVerilog.opts VFLOOR string "0"
hspiceSVerilog.opts FS string "25e-2"
hspiceSVerilog.opts CO string "78"
hspiceSVerilog.opts DEFAS string "0"
hspiceSVerilog.opts RESMIN string "1e-5"
hspiceSVerilog.opts UIC string "off"
hspiceSVerilog.opts PSF string "artistdefault ( 2 )"
hspiceSVerilog.opts WARNLIMIT string "1"
hspiceSVerilog.opts ICSWEEP string "default ( 1 )"
hspiceSVerilog.opts BRIEF string "off"
hspiceSVerilog.opts DCFOR string "0"
hspiceSVerilog.opts GMIN string "1e-12"
hspiceSVerilog.opts DCHOLD string "1"
hspiceSVerilog.opts INGOLD string "artistdefault ( 2 )"
hspiceSVerilog.opts DCSTEP string "0"
hspiceSVerilog.opts NODE string "off"
hspiceSVerilog.opts TRTOL string "7"
hspiceSVerilog.opts LIMTIM string "2.0"
hspiceSVerilog.opts EXPMAX string "8e+1"
hspiceSVerilog.opts DVDT string "default ( 3 )"
hspiceSVerilog.opts NOWARN string "off"
hspiceSVerilog.opts ITL5 string "0"
hspiceSVerilog.opts NUMDGT string "default ( 4 )"
hspiceSVerilog.opts BADCHR string "off"
hspiceSVerilog.opts PIVTOL string "1e-15"
hspiceSVerilog.opts LIMPTS string "2001"
hspiceSVerilog.opts METHOD string "TRAP"
hspiceSVerilog.opts CHGTOL string "1e-15"
hspiceSVerilog.opts GSHUNT string "0"
hspiceSVerilog.opts DVTR string "1e+3"
hspiceSVerilog.opts DI string "1e+2"
hspiceSVerilog.opts CSHDC string "1e-12"
hspiceSVerilog.opts RELI string "1e-2"
hspiceSVerilog.opts PATHNUM string "off"
hspiceSVerilog.opts DEFW string "1e-4"
hspiceSVerilog.opts DCON string "default ( 0 )"
hspiceSVerilog.opts DEFL string "1e-4"
hspiceSVerilog.opts DEFNRS string "0"
hspiceSVerilog.opts TIMRES string "1E-12"
hspiceSVerilog.opts CONVERGE string "default ( 1 )"
hspiceSVerilog.opts ABSV string "5e-5"
hspiceSVerilog.opts LENNAM string "8"
hspiceSVerilog.opts NOPIV string "off"
hspiceSVerilog.opts DCAP string "default ( 2 )"
hspiceSVerilog.opts GMINDC string "1e-12"
hspiceSVerilog.opts RELV string "1e-3"
hspiceSVerilog.opts GRAMP string "0"
hspiceSVerilog.opts ASPEC string "off"
hspiceSVerilog.opts DV string "1e+3"
hspiceSVerilog.opts RMIN string "1e-9"
hspiceSVerilog.opts RELVDC string "1e-3"
hspiceSVerilog.opts ACCT string "default ( 1 )"
hspiceSVerilog.opts SPMESS string "default ( 1 )"
hspiceSVerilog.opts RELMOS string "5e-2"
hspiceSVerilog.opts TEMPDC string "25"
hspiceSVerilog.opts CSDF string "off"
hspiceSVerilog.opts ACCURA string "off"
hspiceSVerilog.opts MAXAMP string "0"
hspiceSVerilog.opts NOMOD string "off"
hspiceSVerilog.opts PIVREF string "1e8"
hspiceSVerilog.opts NOPAGE string "off"
hspiceSVerilog.opts CAPTAB string "off"
hspiceSVerilog.opts ITL1 string "2e+2"
hspiceSVerilog.opts ITL2 string "5e+1"
hspiceSVerilog.opts POST string "default ( 0 )"
hspiceSVerilog.opts PIVREL string "1e-4"
hspiceSVerilog.opts ABSVAR string ".5"
hspiceSVerilog.opts ITRPRT string "off"
hspiceSVerilog.opts SPICE string "off"
hspiceSVerilog.opts GMAX string "1e+2"
hspiceSVerilog.opts RMAX string "2"
hspiceSVerilog.opts BYPASS string "default ( 0 )"
hspiceSVerilog.opts OFF string "0"
hspiceSVerilog.opts IMIN string "3"
hspiceSVerilog.opts KCLTEST string "off"
hspiceSVerilog.opts OPTS string "off"
hspiceSVerilog.opts ACOUT string "default ( 1 )"
hspiceSVerilog.opts RELH string "5e-2"
hspiceSVerilog.opts FT string "25e-2"
hspiceSVerilog.opts LIST string "on"
hspiceSVerilog.opts WL string "default ( 0 )"
hspiceSVerilog.opts RELVAR string ".30"
hspiceSVerilog.opts MAXORD string "default ( 2 )"
hspiceSVerilog.opts DCOPPT string "1"
hspiceSVerilog.opts MEASOUT string "on"
hspiceSVerilog.opts DEFPS string "0"
hspiceSVerilog.opts FAST string "off"
hspiceSVerilog.opts IMAX string "8"
hspiceSVerilog.opts CPTIME string "1e+7"
hspiceSVerilog.opts DEFNRD string "0"
hspiceSVerilog.opts OPTLST string "default ( 0 )"
hspiceSVerilog.opts INTERP string "0"
hspiceSVerilog.opts ABSVDC string "5e-5"
hspiceSVerilog.opts DEFAD string "0"
hspiceSVerilog.opts DCCAP string "off"
hspiceSVerilog.opts SCALM string "1"
hspiceSVerilog.opts DOIRSCAL string "0"
hspiceSVerilog.opts TNOM string "25"
hspiceSVerilog.opts KLIM string "1e-2"
hspiceSVerilog.opts H9007 string "off"
hspiceSVerilog.opts AUTOST string "off"
hspiceSVerilog.opts CVTOL string ".2"
hspiceSVerilog.opts UNWRAP string "off"
hspiceSVerilog.opts K2LIM string "0"
hspiceSVerilog.opts PLIM string "default ( 1 )"
hspiceSVerilog.opts MEASDGT string "default ( 4 )"
hspiceSVerilog.opts MBYPAS string "1"
hspiceSVerilog.opts NOTOP string "off"
hspiceSVerilog.opts MU string ".5"
hspiceSVerilog.opts DEFPD string "0"
hspiceSVerilog.opts EPSMIN string "1e-28"
hspiceSVerilog.opts CSHUNT string "0"
hspiceSVerilog.opts SCALE string "1"
hspiceSVerilog.opts NOELCK string "off"
hspiceSVerilog.opts ABSI string "1e-9"
hspiceSVerilog.opts SDA string "default ( 0 )"
hspiceSVerilog.opts PIVOT string "default ( 10 )"
hspiceSVerilog.opts ABSH string "0"
;hspiceSVerilog outputs partition variables
hspiceSVerilog.outputs allDigitalNV boolean t
hspiceSVerilog.outputs allAnalogNV boolean t
;hspiceSVerilog verimixOpts partition variables
hspiceSVerilog.verimixOpts filename6 string ""
hspiceSVerilog.verimixOpts maxDCIter int 0
hspiceSVerilog.verimixOpts scope1 string ""
hspiceSVerilog.verimixOpts scope10 string ""
hspiceSVerilog.verimixOpts filename8 string ""
hspiceSVerilog.verimixOpts dcInterval float 0.0
hspiceSVerilog.verimixOpts scope3 string ""
hspiceSVerilog.verimixOpts scope8 string ""
hspiceSVerilog.verimixOpts scope7 string ""
hspiceSVerilog.verimixOpts filename7 string ""
hspiceSVerilog.verimixOpts scope string ""
hspiceSVerilog.verimixOpts filename4 string ""
hspiceSVerilog.verimixOpts filename string ""
hspiceSVerilog.verimixOpts filename1 string ""
hspiceSVerilog.verimixOpts scope9 string ""
hspiceSVerilog.verimixOpts importsdfswitch boolean nil
hspiceSVerilog.verimixOpts filename2 string ""
hspiceSVerilog.verimixOpts numberofsdffiles int 2
hspiceSVerilog.verimixOpts scope2 string ""
hspiceSVerilog.verimixOpts scope6 string ""
hspiceSVerilog.verimixOpts filename10 string ""
hspiceSVerilog.verimixOpts delaymodechoice string "Ignore"
hspiceSVerilog.verimixOpts sdfmixedswitch boolean t
hspiceSVerilog.verimixOpts filename9 string ""
hspiceSVerilog.verimixOpts scope5 string ""
hspiceSVerilog.verimixOpts filename5 string ""
hspiceSVerilog.verimixOpts filename3 string ""
hspiceSVerilog.verimixOpts scope4 string ""
;hspiceSVerilog verilogOpts partition variables
hspiceSVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
hspiceSVerilog.verilogOpts optionsFile string ""
hspiceSVerilog.verilogOpts twinTurbo boolean nil
hspiceSVerilog.verilogOpts suppressMessages boolean nil
hspiceSVerilog.verilogOpts libraryFile string ""
hspiceSVerilog.verilogOpts behaveProfile boolean nil
hspiceSVerilog.verilogOpts verimixLog string "verilog.log"
hspiceSVerilog.verilogOpts simVision boolean nil
hspiceSVerilog.verilogOpts pulseSpec boolean nil
hspiceSVerilog.verilogOpts commandFile string ""
hspiceSVerilog.verilogOpts pulseError int 100
hspiceSVerilog.verilogOpts stopCompile boolean nil
hspiceSVerilog.verilogOpts keepNodes string "Minimum"
hspiceSVerilog.verilogOpts accelerationCA boolean nil
hspiceSVerilog.verilogOpts turboRadio string "Default"
hspiceSVerilog.verilogOpts libraryDir string ""
hspiceSVerilog.verilogOpts suppressWarnings boolean nil
hspiceSVerilog.verilogOpts accelerationSwitches boolean nil
hspiceSVerilog.verilogOpts accelerationNormal boolean t
hspiceSVerilog.verilogOpts delayType string "Typical"
hspiceSVerilog.verilogOpts pulseReject int 100
hspiceSVerilog.verilogOpts delayMode string "Default"
hspiceSVerilog.verilogOpts vermixBinary string "verilog.vmx"
;hspiceSVerilog init partition variables
hspiceSVerilog.init processPriority int 0
;hspiceSVerilog envOpts partition variables
hspiceSVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
hspiceSVerilog.envOpts mspNetlistMode string "Flat"
hspiceSVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
hspiceSVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
hspiceSVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
hspiceSVerilog.envOpts mspSetupNetlistEscapeName boolean nil
hspiceSVerilog.envOpts updateFile string ""
hspiceSVerilog.envOpts stimulusFile string ""
hspiceSVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
hspiceSVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
hspiceSVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
hspiceSVerilog.envOpts reNetlist boolean nil
hspiceSVerilog.envOpts includeSyntax string "cdsSpice"
hspiceSVerilog.envOpts mspSetupNetlistPinMap boolean nil
hspiceSVerilog.envOpts mspSetupNetlistBus boolean t
hspiceSVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
hspiceSVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
hspiceSVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
hspiceSVerilog.envOpts mspSetupNetlistExplicit boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
hspiceSVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
hspiceSVerilog.envOpts initFile string ""
hspiceSVerilog.envOpts printComments boolean nil
hspiceSVerilog.envOpts includeFile string ""
hspiceSVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
hspiceSVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
hspiceSVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
hspiceSVerilog.envOpts mspSetupNetlistSimTimeValue int 1
hspiceSVerilog.envOpts mspSetupNetlistUseLib boolean nil
hspiceSVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
hspiceSVerilog.envOpts mspSetupNetlistNullPort boolean nil
hspiceSVerilog.envOpts mspSetupNetlistDropPortRange boolean t
hspiceSVerilog.envOpts mspSetupNetlistUpCase boolean nil
hspiceSVerilog.envOpts generateMapFile boolean nil
hspiceSVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;hspiceSVerilog dc partition variables
hspiceSVerilog.dc enable toggle (nil)
hspiceSVerilog.dc from string ""
hspiceSVerilog.dc to string ""
hspiceSVerilog.dc by string ""
hspiceSVerilog.dc device string ""
;hspiceSVerilog dcOpts partition variables
;hspiceSVerilog noise partition variables
hspiceSVerilog.noise enable toggle (nil)
hspiceSVerilog.noise source string ""
hspiceSVerilog.noise output string ""
hspiceSVerilog.noise listEvery string "1"
;hspiceSVerilog noiseOpts partition variables
;hspiceSVerilog ac partition variables
hspiceSVerilog.ac enable toggle (nil)
hspiceSVerilog.ac from string ""
hspiceSVerilog.ac to string ""
hspiceSVerilog.ac incrType string "Logarithmic"
hspiceSVerilog.ac lin string ""
hspiceSVerilog.ac log string ""
;hspiceSVerilog acOpts partition variables
;hspiceSVerilog tran partition variables
hspiceSVerilog.tran enable toggle (nil)
hspiceSVerilog.tran from string ""
hspiceSVerilog.tran to string ""
hspiceSVerilog.tran by string ""
hspiceSVerilog.tran delmax string ""
;hspiceSVerilog tranOpts partition variables
; Copyright (C) 1997
; Cadence Design Systems Inc. All Rights Reserved.
; $Author: cvsadm $
; $Revision: 1.3.4.1 $
; $Date: 2004/06/16 16:42:51 $
; $State: Exp $
iccTranslator enableProbing boolean t
iccTranslator enableComponentUpdate boolean t
iccTranslator enableAutoImport boolean t
iccTranslator exportCommand string "cdba2icc"
iccTranslator importCommand string "icc2cdba"
iccTranslator iccCommand string "ic_craft"
iccTranslator iccDirectory string ""
iccTranslator exportDirectory string ""
iccTranslator rulesDirectory string ""
iccTranslator logOpPointLimit int 0
iccTranslator oversizePins boolean t
iccTranslator singleImageClusters boolean nil
iccTranslator exportVersion int 11
iccTranslator iccMajorSubVersion int 1
iccTranslator iccMinorSubVersion int 33
iccTranslator permutablePins boolean t
iccTranslator caseSensitive boolean t
iccTranslator schematicStrict boolean nil
iccTranslator keepViaImageOrigin boolean nil
iccTranslator exportTo string "VCR"
iccTranslator pinByPinModelEvaluate boolean nil
iccTranslator alwaysPinModelEvaluate boolean nil
iccTranslator autoTrimPins boolean t
iccTranslator makeVariantViasSpare boolean nil
iccTranslator hierIncrementUpdate boolean nil
iccTranslator MPPAsPolygons boolean nil
iccTranslator noIoPorts boolean nil
iccTranslator findKeepoutWidth boolean nil
iccTranslator.ExportEditor layoutLibrary string ""
iccTranslator.ExportEditor layoutCell string ""
iccTranslator.ExportEditor layoutView string ""
iccTranslator.ExportEditor layoutArea string ""
iccTranslator.ExportEditor netlistSource string "layoutCellview"
iccTranslator.ExportEditor netlistLibrary string ""
iccTranslator.ExportEditor netlistCell string ""
iccTranslator.ExportEditor netlistView string ""
iccTranslator.ExportEditor netlistFile string ""
iccTranslator.ExportEditor useAlternateViews boolean nil
iccTranslator.ExportEditor alternateViews string ""
iccTranslator.ExportEditor conductorDepth int 32
iccTranslator.ExportEditor keepoutDepth int 32
iccTranslator.ExportEditor pinConnection string "strong"
iccTranslator.ExportEditor useMarker boolean nil
iccTranslator.ExportEditor exportMode string "foreground"
iccTranslator.ExportEditor fullConnectivity boolean t
iccTranslator.ExportEditor cutToEdge boolean nil
iccTranslator.ExportEditor interLayer boolean t
iccTranslator.ExportEditor incrementalUpdate boolean t
iccTranslator.ExportEditor useRulesFile boolean nil
iccTranslator.ExportEditor rulesFile string ""
iccTranslator.ExportEditor routerOption string "vcr"
iccTranslator.ExportEditor startICC boolean t
iccTranslator.ExportEditor iccOptions string ""
iccTranslator.ImportEditor importFile string ""
iccTranslator.ImportEditor importFileType string "session"
iccTranslator.ImportEditor importLibrary string ""
iccTranslator.ImportEditor importCell string ""
iccTranslator.ImportEditor importView string ""
iccTranslator.ImportEditor boundary boolean t
iccTranslator.ImportEditor placement boolean t
iccTranslator.ImportEditor routes boolean t
iccTranslator.ImportEditor importMode string "foreground"
iccTranslator.ImportEditor segmentedPath boolean nil
iccTranslator.ImportEditor usePinPurpose boolean nil
ihdl ihdlLoadFileName string "~/.ihdlEnvFile";Load file name
ihdl pin_master_basic_lib boolean t
ihdl pin_master_cells string "ipin opin iopin"
;1************************************************************************
;2* Layout Environment Variables
;3* There are three categories in this file. Public env, wire editor env
;4* and private env. Privat envs should never be touched by customers.
;5************************************************************************
;* The following layout editor environment variables are for customer
;* use. Refer to the documentation for complete information.
layout abutServerOn boolean t
layout accessEdgesOn boolean nil
layout acuteAnglePath boolean t
layout alignApplySeparation boolean t
layout alignApplySpacings string "Component Space"
layout alignDirection string "vertical"
layout alignLayer string ""
layout alignMethod string "Component Origin"
layout alignSelectionMode string "preselect"
layout alignSeparation float 1.0
layout applyBounce boolean nil
layout arrayDisplay string "Full"
layout autoContact boolean nil
layout autoExtractEnabled boolean t
layout autoInstPin boolean nil
layout autoNetName boolean t
layout autoPermutePins boolean t
layout autoRefresh boolean nil
layout autoSetRefPoint boolean t
layout chopShape cyclic "rectangle"
layout confirmDelete boolean nil
layout contactColumns int 1
layout contactDefFromTechfile boolean t
layout contactDelX float 0.0
layout contactDelY float 0.0
layout contactJustify cyclic "centerCenter"
layout contactLength float 0.8
layout contactName string ""
layout contactResetDelXY boolean t
layout contactResetXYBias boolean t
layout contactResetRowCol boolean t
layout contactRows int 1
layout contactWidth float 0.8
layout copyColumns int 1
layout copyResetRowCol boolean nil
layout copyRows int 1
layout copyToLayer boolean nil
layout createPinLabel boolean nil
layout cursorShape boolean nil
layout deleteTarget cyclic "selected"
layout descendPromptForView boolean nil
layout devClass string ""
layout devType string ""
layout displayPinNames boolean nil
layout displayRefPoint boolean nil
layout displayStartLevel int 0
layout displayStopLevel int 0
layout displayStretchHandles boolean nil
layout dotsOn boolean nil
layout drawAxesOn boolean t
layout drawDottedGridOn boolean t
layout drawGridOn boolean t
layout drawInstancePins boolean nil
layout drawSurroundingOn boolean t
layout drdEditMode cyclic "off"
layout drdEditHierDepth int 0
layout drdEditDisplayMarkers boolean nil
layout drdEditDisplayHalo boolean nil
layout drdEditDisplayText boolean t
layout drdEditDisplayArrows boolean t
layout drdEditDisplayEdges boolean nil
layout dynamicHilightOn boolean t
layout extractCheckAll boolean nil
layout extractEnabled boolean t
layout extractStopLevel int 0
layout filterSize float 6.0
layout filterSizeDrawingStyle string "empty"
layout fixedWidthPaths boolean nil
layout flattenMode cyclic "one level"
layout flattenPCells boolean nil
layout gravityAperture float 0.3
layout gravityBounceX float 0.0
layout gravityBounceY float 0.0
layout gravityDepth int 0
layout gravityOn boolean nil
layout gravityType string "pin edge midpoint nexus vertex end centerline"
layout gridMultiple int 5
layout gridSpacing float 1.0
layout iconsOn boolean nil
layout ignoreBounce boolean nil
layout instCellName string ""
layout instColumns int 1
layout instDelX float 0.0
layout instDelY float 0.0
layout instLabel string "master"
layout instLibName string ""
layout instName string ""
layout instRows int 1
layout instViewName string "layout"
layout keepFirstTermName boolean nil
layout keepRuler boolean t
layout labelAttach boolean nil
layout labelDrafting boolean t
layout labelFontStyle cyclic "stick"
layout labelHeight float 1.0
layout labelJustify cyclic "centerCenter"
layout labelOverbar boolean nil
layout layerTapCycle boolean nil
layout leDispNetExpr boolean t
layout leWindowBBox string "((120 185) (1020 875))"
layout lockAngles boolean t
layout magnification float 1.0
layout maintainConnections boolean nil
layout markerZoomScale int 1
layout maxDragFig int 500
layout modCornerRadius float 1.0
layout modCornerType cyclic "radial"
layout modalCommands boolean t
layout moveToLayer boolean nil
layout mppASCIIFileName string ""
layout mppTemplate string "New"
layout multiSegRuler boolean nil
layout nPtsToTaper int 20
layout allowLockedRoutes boolean nil
layout netsOn boolean nil
layout numLevels int 32
layout numSides int 20
layout openToStopLevel boolean t
layout orientation cyclic "R0"
layout resetOrientation boolean t
layout originMarkersOn boolean nil
layout partialSelect boolean nil
layout pathBeginExt float 0.0
layout pathCL cyclic "yes"
layout pathEndExt float 0.0
layout pathJustify cyclic "center"
layout pathOffset float 0.0
layout pathStyle cyclic "truncateExtend"
layout pathWidth float 0.6
layout pinAccessDir string "left right top bottom"
layout pinLength float 0.6
layout pinSelectionMode cyclic "ignoreLPP"
layout pinShape cyclic "rectangle"
layout pinTextLayer string "text"
layout pinTextPurpose string "drawing"
layout pinTextSameLayer boolean nil
layout pinType string ""
layout pinWidth float 0.6
layout pinXPitch float 0.0
layout pinYPitch float 0.0
layout pinsAreSymbolic boolean t
layout pinLayerPurpose string ""
layout polygonArc boolean nil
layout preservePins boolean nil
layout preserveRodObjects boolean nil
layout preserveTerminalContacts boolean nil
layout propClass cyclic "attributes"
layout recursionCheck boolean t
layout removeChopShape boolean t
layout replaceFigs boolean t
layout reshapeType cyclic "rectangle"
layout rodAutoName string ""
layout segSnapMode string "orthogonal"
layout selectOnlyInstWithSelectableShapes boolean nil
layout selectionAperture int 5
layout showLPPFullName boolean nil
layout showWhatsNew string "yes"
layout snapMode string "orthogonal"
layout snapToGrid boolean nil
layout startLevel int 0
layout stopLevel int 0
layout stretchPCellApplyToName boolean t
layout taperStyle cyclic "linear"
layout termDirection cyclic "inputOutput"
layout termName string ""
layout textJustificationOn boolean t
layout tinyInstDetail boolean nil
layout trlBendFac float 1.0
layout trlBendStyle cyclic "bend"
layout trlChamFac float 0.6
layout trlNPtsToPI int 20
layout trlRadFac float 3.0
layout trlWidth1 float 20.0
layout trlWidth2 float 20.0
layout updatePCellIncrement float -1.0
layout useDefaultVia boolean t
layout useEditorBackgroundColorForLSW boolean t
layout useTrueBBox boolean nil
layout userVia string ""
layout xSnapSpacing float 0.1
layout ySnapSpacing float 0.1
layout yankShape cyclic "rectangle"
layout zoomToFig boolean nil
layout cdsViaXcutSpacing float 0.0
layout cdsViaYcutSpacing float 0.0
layout cdsViaLayer1XEnclosure float 0.0
layout cdsViaLayer1YEnclosure float 0.0
layout cdsViaLayer2XEnclosure float 0.0
layout cdsViaLayer2YEnclosure float 0.0
layout cdsViaLayer1XDirEnclosure float 0.0
layout cdsViaLayer1YDirEnclosure float 0.0
layout cdsViaLayer2XDirEnclosure float 0.0
layout cdsViaLayer2YDirEnclosure float 0.0
layout cdsViaLayer1Direction string ""
layout cdsViaLayer2Direction string ""
layout cdsViaStackedVias boolean nil
layout cdsViaResetXYCutSpacing boolean t
layout cdsViaResetLayer1XYEnclosure boolean t
layout cdsViaResetLayer2XYEnclosure boolean t
layout cdsViaResetLayer1XYDirEnclosure boolean t
layout cdsViaResetLayer2XYDirEnclosure boolean t
layout cdsViaResetLayerDirection boolean t
layout cdsViaResetOrigin boolean t
layout displayViaShapes boolean nil
layout tapType string "layer"
layout remasterInstCheckTerms boolean nil
layout remasterInstSearchLibText string ""
layout remasterInstSearchCellText string ""
layout remasterInstSearchViewText string ""
layout remasterInstUpdateLibText string ""
layout remasterInstUpdateCellText string ""
layout remasterInstUpdateViewText string ""
layout chainMode cyclic "selected"
layout anchor cyclic "left"
layout shortEnhContactForm boolean nil
layout markNetRange cyclic "Top to bottom"
layout markNetStartLevel int 0
layout markNetStopLevel int 0
layout markNetAutoColorCycle boolean t
layout markNetDumpNetObj boolean nil
layout measurementDisplayOn boolean nil
layout measurementTextHeight int 10
layout measurementDisplayTypes string "deltaXY distance radius area length"
;* The following layout editor environment variables are for customer use
;* with the wire editor functionality in Virtuoso XL Layout Editor only.
;* Refer to the documentation for complete information.
layout allowFloatingNets boolean nil
layout allowJogs boolean t
layout allowRedundantWiring boolean t
layout autoAdjustLength boolean nil
layout autoShield boolean nil
layout busOverride cyclic "ignore"
layout busOverrideValue float 1.0
layout busWireSpacing float 0.0
layout busWireSpacingType cyclic "wirewire"
layout checkConflict boolean t
layout checkCornerCorner boolean nil
layout checkCrossTalk boolean t
layout checkLength boolean t
layout checkLimitWay boolean nil
layout checkMaxProcessWireWidth boolean nil
layout checkMaxStackViaDepth boolean nil
layout checkMaxTotalVia boolean nil
layout checkMinMaskEdgeLength boolean nil
layout checkMinProcessWireWidth boolean t
layout checkMiter boolean nil
layout checkNetOrder boolean nil
layout checkOffManGridPin boolean nil
layout checkOffWireGridPin boolean nil
layout checkPinSpacing boolean t
layout checkPolygonWire boolean t
layout checkProtected boolean nil
layout checkReentrantPath boolean t
layout checkRegion boolean t
layout checkSameNet boolean nil
layout checkSegment boolean nil
layout checkStub boolean nil
layout checkUseLayers boolean nil
layout checkUseVias boolean nil
layout checkWireExtension boolean nil
layout doFile string ""
layout enableBusRouting boolean t
layout enableTandemPair boolean nil
layout fitViaPattern boolean nil
layout gatherBusWires boolean nil
layout inaccessiblePin boolean t
layout interactiveChecking boolean t
layout matchPinWidth boolean nil
layout matchPinWidthValue cyclic "narrow"
layout matchWireWidth boolean nil
layout multiplePinsConnection boolean t
layout pinLargerMaxProcessWidth boolean nil
layout pinSmallerMinProcessWidth boolean t
layout pushComponent boolean nil
layout pushRouting boolean t
layout routeAsManyAsPossible boolean nil
layout routeToCursor boolean nil
layout routeToCursorStyle cyclic "singleLayer"
layout sameNetChecking boolean nil
layout showTimingMeter boolean nil
layout showTimingOctagon boolean nil
layout snapToPinOrigin boolean nil
layout useDoFile boolean nil
layout viaAssistance cyclic "snap"
layout viaPattern cyclic "diag_1"
layout allowViaOnCurrentLayer boolean t
;* The following layout editor environment variables are for internal Cadence
;* use only. Changing the values of these variables my cause the layout editor
;* or other Cadence software to behave improperly or quit.
layout abutPerpSnapOn boolean t
layout coalesceLimit int 16
layout coalesceRatio int 50
layout connStatus cyclic "needToConnect"
layout contactInstLibName string ""
layout criticality int 10
layout eipRedraw boolean nil
layout figOrder cyclic "current"
layout iterNum int 0
layout jumpersOn boolean nil
layout minLabelSize float 1.0
layout minRefreshArea int 10
layout minStippleSize float 1.0
layout moreDialogs boolean t
layout netName string ""
layout outlineOnly boolean t
layout pickNCreate boolean nil
layout pinInstLibName string ""
layout probeTextOn boolean t
layout pruneSize float 1.0
layout routeMenuOn boolean t
layout toggle boolean nil
layout transformMarkersOn boolean t
layout viewNameList string ""
;3* There are three categories in this file. Public env, LO env
;4* and private env. Private envs should never be touched by customers.
layoutMigrate priorityUserDefined int 10
layoutMigrate priorityUser int 9
layoutMigrate priorityAreaHole int 8
layoutMigrate priorityScale int 7
layoutMigrate prioritySpace int 6
layoutMigrate priorityEnclose int 5
layoutMigrate priorityExtend int 4
layoutMigrate priorityWidth int 3
layoutMigrate priorityNoJog int 2
layoutMigrate priorityAlign int 1
layoutMigrate addToSelection boolean t
layoutMigrate visibleLayer boolean t
layoutMigrate selectableLayer boolean nil
layoutMigrate exclusiveLayer boolean nil
layoutMigrate exclusiveArea boolean nil
layoutMigrate migrateLibraries boolean nil
layoutMigrate mapPcellParams boolean nil
layoutMigrate useSchematicLinks boolean nil
layoutMigrate debugMode boolean t
layoutMigrate doPreProcess boolean t
layoutMigrate preprocessScript string "preprocess.qts"
layoutMigrate doAstractSource boolean nil
layoutMigrate abstractSourceScript string "abstractsource.qts"
layoutMigrate doAbstractTarget boolean nil
layoutMigrate abstractTargetScript string "abstracttarget.qts"
layoutMigrate doPremigrate boolean nil
layoutMigrate premigrateScript string "premigrate.qts"
layoutMigrate doNetlistBinding boolean nil
layoutMigrate netlistFile string "netlist.cdl"
layoutMigrate useConstraintScript boolean nil
layoutMigrate constraintScript string "constraints.qts"
layoutMigrate doPostprocess boolean t
layoutMigrate postprocessScript string "postprocess.qts"
layoutMigrate lastScript string ""
layoutMigrate optimizeX boolean t
layoutMigrate optimizeY boolean t
layoutMigrate allowZeroEdges boolean t
layoutMigrate allow45Edges boolean t
layoutMigrate scaleDevicesWires boolean t
layoutMigrate sumDeviceLegs boolean t
layoutMigrate lockPcells boolean nil
layoutMigrate useQuickSolver boolean nil
layoutMigrate centerLabels boolean nil
layoutMigrate minimizeMemory boolean nil
layoutMigrate keepResultsOnDisk boolean t
layoutMigrate expandSingletons boolean nil
layoutMigrate optimizeEnclose boolean nil
layoutMigrate genConstraintStats boolean nil
layoutMigrate optimizeEffort int 1
layoutMigrate autoRelaxDevices boolean nil
layoutMigrate autorelaxMaxConstraints boolean nil
layoutMigrate autorelaxConstraintsByType boolean nil
layoutMigrate autoRelaxTolerance float 50.0
layoutMigrate autoJogEdges boolean nil
layoutMigrate autoJogWires boolean nil
layoutMigrate autoJogLimit int 1000
layoutMigrate autoJogThreshold float 100.0
layoutMigrate revisitOneByOne2D boolean nil
layoutMigrate revisit2DCost float 100.0
layoutMigrate revisitFlash2D boolean t
layoutMigrate manufGrid2D boolean t
layoutMigrate changeEndOfLine boolean t
layoutMigrate changeCommonRun boolean t
layoutMigrate changeCornerCorner boolean t
layoutMigrate manufGridEnable boolean t
layoutMigrate manufGridPercent float 0.1
layoutMigrate manufGridIteration int 500
layoutMigrate manufGridCPUTime int 10000
layoutMigrate manufGridNoQuickSolver boolean t
layoutMigrate ioGridEnable boolean t
layoutMigrate ioGridPercent float 1.0
layoutMigrate ioGridIteration int 500
layoutMigrate ioGridCPUTime int 10000
layoutMigrate collapseVirtuals boolean t
layoutMigrate ignoreLengthsNetlistBinding boolean nil
layoutMigrate ignoreLengthsLayoutExtraction boolean nil
layoutMigrate propagateTieoffs boolean t
layoutMigrate remoteHost string ""
layoutMigrate remoteWorkingDir string ""
layoutMigrate useRemoteHost boolean nil
layoutMigrate remoteVirtuosoDir string ""
layoutMigrate RemoteQtkDir string ""
layoutMigrate remoteExecPath string ""
layoutMigrate processPriority int 15
layoutMigrate justFixMode boolean nil
layoutOptimize priorityUserDefined int 10
layoutOptimize priorityUser int 9
layoutOptimize priorityAreaHole int 8
layoutOptimize priorityScale int 7
layoutOptimize prioritySpace int 6
layoutOptimize priorityEnclose int 5
layoutOptimize priorityExtend int 4
layoutOptimize priorityWidth int 3
layoutOptimize priorityNoJog int 2
layoutOptimize priorityAlign int 1
layoutOptimize addToSelection boolean t
layoutOptimize visibleLayer boolean t
layoutOptimize selectableLayer boolean nil
layoutOptimize exclusiveLayer boolean nil
layoutOptimize exclusiveArea boolean nil
layoutOptimize migrateLibraries boolean nil
layoutOptimize mapPcellParams boolean nil
layoutOptimize useSchematicLinks boolean nil
layoutOptimize debugMode boolean t
layoutOptimize doPreProcess boolean nil
layoutOptimize preprocessScript string "preprocess.qts"
layoutOptimize doAstractSource boolean nil
layoutOptimize abstractSourceScript string "abstractsource.qts"
layoutOptimize doAbstractTarget boolean nil
layoutOptimize abstractTargetScript string "abstracttarget.qts"
layoutOptimize doPremigrate boolean nil
layoutOptimize premigrateScript string "premigrate.qts"
layoutOptimize doNetlistBinding boolean nil
layoutOptimize netlistFile string "netlist.cdl"
layoutOptimize useConstraintScript boolean nil
layoutOptimize constraintScript string "constraints.qts"
layoutOptimize doPostprocess boolean nil
layoutOptimize postprocessScript string "postprocess.qts"
layoutOptimize lastScript string ""
layoutOptimize optimizeX boolean t
layoutOptimize optimizeY boolean t
layoutOptimize allowZeroEdges boolean t
layoutOptimize allow45Edges boolean t
layoutOptimize scaleDevicesWires boolean nil
layoutOptimize sumDeviceLegs boolean nil
layoutOptimize lockPcells boolean nil
layoutOptimize useQuickSolver boolean nil
layoutOptimize centerLabels boolean nil
layoutOptimize minimizeMemory boolean nil
layoutOptimize keepResultsOnDisk boolean nil
layoutOptimize expandSingletons boolean nil
layoutOptimize optimizeEnclose boolean nil
layoutOptimize genConstraintStats boolean nil
layoutOptimize optimizeEffort int 1
layoutOptimize autoRelaxDevices boolean nil
layoutOptimize autorelaxMaxConstraints boolean nil
layoutOptimize autorelaxConstraintsByType boolean nil
layoutOptimize autoRelaxTolerance float 50.0
layoutOptimize autoJogEdges boolean nil
layoutOptimize autoJogWires boolean nil
layoutOptimize autoJogLimit int 1000
layoutOptimize autoJogThreshold float 100.0
layoutOptimize revisitOneByOne2D boolean nil
layoutOptimize revisit2DCost float 100.0
layoutOptimize revisitFlash2D boolean t
layoutOptimize manufGrid2D boolean nil
layoutOptimize changeEndOfLine boolean t
layoutOptimize changeCommonRun boolean t
layoutOptimize changeCornerCorner boolean t
layoutOptimize manufGridEnable boolean t
layoutOptimize manufGridPercent float 0.1
layoutOptimize manufGridIteration int 500
layoutOptimize manufGridCPUTime int 500
layoutOptimize manufGridNoQuickSolver boolean t
layoutOptimize ioGridEnable boolean t
layoutOptimize ioGridPercent float 1.0
layoutOptimize ioGridIteration int 500
layoutOptimize ioGridCPUTime int 1000
layoutOptimize collapseVirtuals boolean t
layoutOptimize ignoreLengthsNetlistBinding boolean nil
layoutOptimize ignoreLengthsLayoutExtraction boolean nil
layoutOptimize propagateTieoffs boolean t
layoutOptimize remoteHost string ""
layoutOptimize remoteWorkingDir string ""
layoutOptimize useRemoteHost boolean nil
layoutOptimize remoteVirtuosoDir string ""
layoutOptimize RemoteQtkDir string ""
layoutOptimize remoteExecPath string ""
layoutOptimize processPriority int 15
layoutOptimize justFixMode boolean nil
layoutOptimize.state menuState string "Migrate"
;2* Layout XL Environment Variables
;3* Note: entries in this file must be in alphabetical order.
;4************************************************************
layoutXL autoAbutment boolean t
layoutXL autoArrange boolean t
layoutXL autoSpace boolean t
layoutXL checkTimeStamps boolean t
layoutXL ciwWindow string "((0 0) (0 0))"
layoutXL constraintAssistedMode boolean nil
layoutXL createBoundaryLabel boolean nil
layoutXL crossSelect boolean t
layoutXL ignoredParams string "lxIgnoredParams dleIgnoredParams lxStopList dleStopList lxUseCell dleUseCell maskLayoutViewName posi instancesLastChanged instNamePrefix pin# lxTimeStamp dleSchExtractPath lxPlacementStatus"
layoutXL ignoreParamsForCAS string ""
layoutXL dlrNetConstNetClass string "neutral"
layoutXL dlrNetConstNetWeight string "normal"
layoutXL dlrRoutingBoundaryOption string "auto boundary"
layoutXL flightLineEnable boolean t
layoutXL ignoreNames string "lvsIgnore ignore nlAction"
layoutXL incNetCycleHilite boolean t
layoutXL incNetHiliteLayer string "y0 drawing"
layoutXL initAspectRatio float 1.0
layoutXL initAspectRatioOption string "Aspect Ratio W/H"
layoutXL initBoundaryLayer string "prBoundary drawing"
layoutXL initEstimateArea boolean t
layoutXL initIOLabelType string "Label"
layoutXL initIOPinLayer string ""
layoutXL initIOPinName string ""
layoutXL initPinHeight float 0.0
layoutXL initPinWidth float 0.0
layoutXL initPinMultiplicity int 1
layoutXL initPrBoundaryH float 0.0
layoutXL initPrBoundaryW float 0.0
layoutXL initSymbolicPins boolean nil
layoutXL initUtilization float 25.0
layoutXL initGlobalNetPins boolean t
layoutXL initCreatePins boolean t
layoutXL initCreateInstances boolean t
layoutXL initCreateBoundary boolean t
layoutXL initDoStacking boolean nil
layoutXL initDoFolding boolean nil
layoutXL layoutWindow string "((0 0) (0 0))"
layoutXL lswWindow string "((0 0) (0 0))"
layoutXL lxAllowPseudoParallelNets boolean nil
layoutXL lxDeltaWidth float 0.0
layoutXL lxDoNotCheck boolean nil
layoutXL lxLocalAbutment boolean nil
layoutXL lxSchExtractTopLevelOnly boolean nil
layoutXL lxStackPartitionParameters string "(1 8)"
layoutXL lxWidthTolerance string "(0.0 0.0)"
layoutXL mfactorNames string "m M"
layoutXL mfactorSplit boolean t
layoutXL moveAsGroup boolean t
layoutXL orientation string "R0"
layoutXL paramTolerance float 1e-06
layoutXL pathLayerFilter string ""
layoutXL pathProbe boolean t
layoutXL pathPurposeList string "drawing net pin"
layoutXL pathSwitchLayer boolean t
layoutXL pathSwitchPurpose boolean t
layoutXL pinTextSamePurpose boolean nil
layoutXL preserveTerminalContacts boolean nil
layoutXL probeCycleHilite boolean t
layoutXL probeDevice boolean t
layoutXL probeHiliteLayer string "hilite drawing"
layoutXL probeNet boolean t
layoutXL probePin boolean t
layoutXL probeInfoInCIW boolean nil
layoutXL infoWindow boolean t
layoutXL schematicWindow string "((0 0) (0 0))"
layoutXL showIncNetEnable boolean nil
layoutXL stopList string "layout compacted symbolic"
layoutXL templateFileName string ""
layoutXL updateReplacesMasters boolean t
layoutXL updateWithMarkers boolean t
layoutXL viewList string "schematic netlist symbol layout compacted symbolic"
layoutXL vxlDebugLog boolean nil
layoutXL vxlDebugLogFileName string "/tmp/vxl.log"
layoutXL initCreateMTM boolean nil
layoutXL sfactorNames string "s S"
layoutXL sfactorParam string "r R c C l L"
layoutXL mfactorSplitParamNames string "w"
layoutXL setPPConn boolean t
layoutXL lxSupplyNetNames string "vcc vcc! vcc: vdd vdd! vdd:"
layoutXL lxGroundNetNames string "gnd gnd! gnd: vss vss! vss:"
layoutXL lxGenerationOrientation string "preserve"
layoutXL lxGenerationTopLevelOnly boolean nil
layoutXL lxInitResetSource boolean nil
layoutXL compTypeRefLibs string "NONE"
layoutXL traverseMixedHierarchies boolean nil
layoutXL lxEvalCDFCallbacks boolean nil
layoutXL cloningDoExactMatch boolean nil
layoutXL.placement allowRotation boolean t
layoutXL.placement globalPlacement boolean t
layoutXL.placement openWindow boolean nil
layoutXL.placement optimizePlacement boolean nil
layoutXL.placement rulesFile string ""
layoutXL.placement runTime cyclic "moderate"
layoutXL.placement saveAs boolean nil
layoutXL.placement saveAsCellName string ""
layoutXL.placement saveAsLibName string ""
layoutXL.placement saveAsViewName string ""
layoutXL.placement vcpConductorDepth int 2
layoutXL.placement vcpKeepoutDepth int 2
layoutXL lxStackMinimalFolding boolean nil
layoutXL lxFingeringNames string "fingers finger"
layoutXL.placement rowGroundLayer string ""
layoutXL.placement rowGroundName string ""
layoutXL.placement rowGroundWidth float 1.0
layoutXL.placement rowPowerLayer string ""
layoutXL.placement rowPowerName string ""
layoutXL.placement rowPowerWidth float 1.0
layoutXL.placement rowSupplySpacing string ""
layoutXL.placement rowSupplyPosition cyclic "Outside"
layoutXL.placement rowSTDAllowFlip boolean t
layoutXL.placement rowMOSSupplyPattern cyclic "N-P-P-N"
layoutXL.placement rowSTDSupplyPattern cyclic "G-P-P-G"
layoutXL.placement congestionMapLayers string "((designFlow drawing) (designFlow drawing1) (designFlow drawing2) (designFlow drawing3) (designFlow drawing4) (designFlow drawing5) (designFlow drawing6) (designFlow drawing7) (designFlow drawing8) (designFlow drawing9))"
layoutXL.placement vcpGlobalPathScript string ""
layoutXL.placement vcpVerboseLevel int 1
layoutXL.placement vcpWriteToCIW boolean nil
;mmsimenv environment variables
;FORMAT: tool.partition varName type value private {choices, minmax} comment
;mmsimenv configuration defaults
mmsimenv.conf analogStopViewSet string "spectreS cdsSpice spice veriloga ahdl auLvs spectre"
mmsimenv.conf digitalStopViewSet string "verilog behavioral functional hdl system verilogNetlist msps"
modelwriter path string ""
modelwriter nodefault boolean nil
; Copyright (C) 2001 Cadence Design Systems, Inc. All Rights Reserved.
; $Revision: 1.1.8.1.2.1 $
;Mixed Signal Parasitic Simulation (MSPS) Environment Defaults
;Globals
msps schematicLibName string ""
msps schematicCellName string ""
msps schematicViewName string "schematic"
msps extractedLibName string ""
msps extractedCellName string ""
msps extractedViewName string "extracted"
msps switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
msps stopViewList string "cdsSpice spice"
msps instViewListTable string ""
;Parasitic Probing
msps.parProbe maxListSize int 20
msps.parProbe sortBy string "C"
;Back Annotation
msps.backAnnotate fontSize float 0.05
msps.backAnnotate xOffset float 0.01
msps.backAnnotate yOffset float 0.01
msps.backAnnotate sortBy string "C"
msps.backAnnotate parasiticFile string "parasitic_file"
;Build Analog
msps.buildAnalog setParasitics string "Include All"
msps.buildAnalog analogExtractedViewName string "analog_extracted"
; Copyright (C) 2000 Cadence Design Systems, Inc. All Rights Reserved.
; $Revision: 1.2.8.1.2.1 $
;Mixed Signal Parasitic Simulation for Assura Verification (MSPS-AV) Environment Defaults
;Globals
mspsAv schematicLibName string ""
mspsAv schematicCellName string ""
mspsAv schematicViewName string "schematic"
mspsAv extractedLibName string ""
mspsAv extractedCellName string ""
mspsAv extractedViewName string "av_extracted"
mspsAv switchViewList string "cdsSpice spice cmos_sch cmos.sch schematic"
mspsAv stopViewList string "cdsSpice spice"
mspsAv instViewListTable string ""
mspsAv backAnnotateR boolean t
;Parasitic Probing
mspsAv.parProbe maxListSize int 20
mspsAv.parProbe sortBy string "C"
mspsAv.parProbe parasiticProbeFile string "parasitic_probing"
mspsAv.pwbCore schematicOpenReadOnly boolean t
mspsAv.backAnnotate fontSize float 0.05
mspsAv.backAnnotate Xoffset float 0.01
mspsAv.backAnnotate Yoffset float 0.01
mspsAv.backAnnotate sortBy string "C"
mspsAv.backAnnotate parasiticFile string "parasitic_file"
;Build Analog
mspsAv.buildAnalog setParasitics string "Include All"
mspsAv.buildAnalog analogExtractedViewName string "av_analog_extracted"
; Neocell Environment Variables
neocell ArchFile string ""
neocell MapFile string ""
neocell DefaultFile string ""
neocell UseBlockRules boolean nil
neocell BlockRulesFile string ""
neocell ExportDir string ""
neocell StartNeoCell boolean t
neocell ImportViewName string "layout"
neocell ImportTextDisplay boolean nil
neocell ImportBoundary boolean t
neocell ExportOptions string ""
neocell SymViewList string "symbolic layout"
neocell IgnoreParamTolerance boolean t
neocell VariantParamTolerance int 10
neocell VerboseWarn boolean t
neocell InitDFIIlib string ""
neocell NewDFIIlib string ""
neocell TempDir string ""
neocell TechPath string ""
neocell IgnorePinAccess boolean nil
neocell ImportPinLabelFont string "stick"
neocell ImportPinLabelSize float -1.0
neocell DisableSchExtract boolean nil
neocell TechFile string ""
neocell DisplayFile string ""
neocell pinConnection string "full"
neocell CEDefaultTab string "DevStyle"
neocell overridePinPurpose string ""
; ROD Environment Variables
rod evalILExprOn boolean t
rod minWidthCheckingOn boolean t
rod minSpacingCheckingOn boolean t
rod minEnclosureCheckingOn boolean t
rod preserveAlignInfoOn boolean t
; Composer Schematic Editor Environment Variables
; NOTE: This file should NOT be edited because it is automatically
; generated; customizations should be made to the file in
; <install_dir>/tools/dfII/samples/.cdsenv.
schematic autoDot boolean t
schematic blockDirRules cyclic "edge"
schematic broadcast boolean nil
schematic browserType string "library"
schematic checkAlways boolean nil
schematic checkBeepOn boolean t
schematic checkHierSave boolean t
schematic checkSupportAMS boolean nil
schematic checkSymTime int 1
schematic compBackTrace boolean t
schematic condOp cyclic "=="
schematic createCvOptions boolean t
schematic createInstResetCDF boolean t
schematic createInstShowCDF boolean t
schematic createLabelFontHeight float 0.0625
schematic createLabelFontStyle cyclic "stick"
schematic createLabelHorzOffset float 0.045
schematic createLabelHorzPosition cyclic "above"
schematic createLabelHorzRotation cyclic "R0"
schematic createLabelJustify cyclic "lowerCenter"
schematic createLabelOffsetMode boolean t
schematic createLabelVertOffset float 0.045
schematic createLabelVertPosition cyclic "left"
schematic createLabelVertRotation cyclic "R90"
schematic cvDisplay boolean t
schematic defWideWireWidth float 0.0625
schematic defaultsFile string ""
schematic deleteInstPinsWire boolean t
schematic descendSheet string "sheet"
schematic descendTarget string "query user"
schematic differential boolean nil
schematic dotOverlap float 0.03125
schematic drawMode string "anyAngle"
schematic drawModeRoute string "route"
schematic echoToCIW boolean t
schematic editPropCDFParamView string "Use Tools Filter"
schematic editPropShowCDF boolean t
schematic editPropShowSystem boolean nil
schematic editPropShowUser boolean t
schematic findAccessMode string "edit"
schematic findZoomButton boolean nil
schematic flightWidth float 0.0
schematic gravityOn boolean t
schematic invokeKanjiEditor string "kterm -km euc -e vi"
schematic libList string ""
schematic markerSeverity string "all"
schematic markerShowIgnore boolean t
schematic markerSource toggle (t t t t)
schematic markerType toggle (t t)
schematic markerZoom boolean nil
schematic maxLabelOffsetUU float 0.045
schematic minMarkerSize float 0.05
schematic modalCommands boolean t
schematic netExprDisplay cyclic "value only"
schematic netNameMethod cyclic "prefix"
schematic netNamePrefix string "net"
schematic netNameRangeDescend boolean nil
schematic netNameSeparator string "_"
schematic noteFontHeight float 0.0625
schematic noteFontStyle cyclic "stick"
schematic noteJustify cyclic "lowerCenter"
schematic noteShape cyclic "line"
schematic noteShapeLineStyle cyclic "solid"
schematic noteType cyclic "normalLabel"
schematic pinBackTrace boolean t
schematic pinNameSeed string "pin"
schematic pinRefDuplicates boolean nil
schematic pinRefFormat string "<sheetNumber><zone><referenceName>"
schematic pinRefSorting string "Sheet Number"
schematic replSaveChanges boolean nil
schematic runSRC boolean t
schematic runVIC boolean t
schematic saveAction cyclic "Ask Me"
schematic schCoalesceLimit int 2
schematic schDisplayDepth int 3
schematic schDrawAxesOn boolean nil
schematic schDynamicHilightOn boolean t
schematic schFilterSize float 0.3
schematic schGridMultiple int 8
schematic schGridSpacing float 0.125
schematic schGridType cyclic "dotted"
schematic schHdlCrossViewCheck boolean t
schematic schHdlCrossViewString string ""
schematic schHdlEditAfterError boolean t
schematic schHdlNetToInoutPort toggle (t t t t t t t)
schematic schHdlNetToInputPort toggle (t t t t t t t)
schematic schHdlNoHierarchy boolean nil
schematic schHdlPrintCommand string "lpr"
schematic schHdlVerbose boolean nil
schematic schMaxDragFig int 100
schematic schPathType cyclic "full"
schematic schShowDirectConnects boolean nil
schematic schShowLabelOrigin boolean nil
schematic schSnapSpacing float 0.0625
schematic schWindowBBox string "((120 185) (1020 875))"
schematic schematicAreaPartialSelect boolean nil
schematic schematicSelectFilter string "allSchObj instancePin"
schematic sensitiveMenu boolean t
schematic shapeLineType cyclic "narrow"
schematic shapeLineWidth float 0.0625
schematic simProbeAutoPlace boolean nil
schematic simProbeFormat string "<state>"
schematic simProbeType string "monitor"
schematic snapEnabled boolean t
schematic spanLib string "do not check"
schematic srcConnByName cyclic "ignored"
schematic srcFloatingBIDIR cyclic "warning"
schematic srcFloatingIO cyclic "warning"
schematic srcFloatingInput cyclic "warning"
schematic srcFloatingNets cyclic "warning"
schematic srcFloatingOutput cyclic "warning"
schematic srcInhPinNetCollision cyclic "ignored"
schematic srcInheritedConn cyclic "ignored"
schematic srcInstNameExpr string ""
schematic srcInstNameSyntax cyclic "ignored"
schematic srcInstOverlap cyclic "warning"
schematic srcInstOverlapValue int 10
schematic srcMaxLabelOffset cyclic "ignored"
schematic srcNameCollision cyclic "warning"
schematic srcNetNameExpr string ""
schematic srcNetNameSyntax cyclic "ignored"
schematic srcNoOverrideNet cyclic "warning"
schematic srcOffsheetConnCheck cyclic "ignored"
schematic srcPinNetCollision cyclic "ignored"
schematic srcShortedOutputs cyclic "warning"
schematic srcSolderOnCrossover cyclic "warning"
schematic srcSparseIndexBus cyclic "ignored"
schematic srcTermNameExpr string ""
schematic srcTermNameSyntax cyclic "ignored"
schematic srcUnconnectedWires cyclic "ignored"
schematic srcVHDLSyntax cyclic "ignored"
schematic srcVerilogSyntax cyclic "ignored"
schematic ssgPackageLabels cyclic "none"
schematic ssgSortPins cyclic "alphanumeric"
schematic statusBanner boolean t
schematic statusBannerXY boolean nil
schematic stickyWireLabelRange float 0.3125
schematic symCoalesceLimit int 2
schematic symDisplayDepth int 3
schematic symDrawAxesOn boolean nil
schematic symDynamicHilightOn boolean t
schematic symFilterSize float 0.3
schematic symGridMultiple int 8
schematic symGridSpacing float 0.125
schematic symGridType cyclic "dotted"
schematic symMaxDragFig int 100
schematic symPathType cyclic "full"
schematic symShowDirectConnects boolean nil
schematic symShowLabelOrigin boolean nil
schematic symSnapSpacing float 0.0625
schematic symWindowBBox string "((120 185) (1020 875))"
schematic symbolAreaPartialSelect boolean nil
schematic symbolLabelChoice cyclic "instance label"
schematic symbolLabelChoiceText string ""
schematic symbolLabelFontHeight float 0.0625
schematic symbolLabelFontStyle cyclic "stick"
schematic symbolLabelJustify cyclic "lowerCenter"
schematic symbolLabelType cyclic "NLPLabel"
schematic symbolPinFlatten boolean t
schematic symbolPinIncrCount int 1
schematic symbolPinLocate cyclic "left"
schematic symbolPinUsage string ""
schematic symbolSelectFilter string "allSymObj"
schematic symbolShape cyclic "line"
schematic symbolShapeFillStyle cyclic "outline"
schematic transToSheetType string "single"
schematic tsgTemplateType string "digital"
schematic updateConn boolean t
schematic updateInstResetCDF boolean t
schematic vicExactPinMatch boolean nil
schematic vicIgnoreInhTermAll boolean t
schematic vicIgnoreInhTermList string ""
schematic vicIgnoreInhTermViewList string ""
schematic vicInheritedPinMatch boolean t
schematic vicInheritedPins boolean t
schematic vicSeverity cyclic "warning"
schematic vicViewList string "symbol schematic functional behavioral system opt_sch opt_net"
schematic viewNameList string "schematic symbol"
schematic wireBackTrace boolean nil
schematic zoomOutButton boolean nil
;spectre environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spectre opts partition variables
spectre.opts multithread string ""
spectre.opts title string ""
spectre.opts audit string ""
spectre.opts nthreads string ""
spectre.opts mos_method string ""
spectre.opts ckptclock string "1800"
spectre.opts flow string ""
spectre.opts cols string "80"
spectre.opts opptcheck string ""
spectre.opts maxwarnstologfile string ""
spectre.opts reltol string "1e-3"
spectre.opts notation string ""
spectre.opts senstype string ""
spectre.opts warn string ""
spectre.opts approx string ""
spectre.opts info string ""
spectre.opts sensformat string ""
spectre.opts quantities string ""
spectre.opts pivabs string ""
spectre.opts compatible string ""
spectre.opts ignshorts string ""
spectre.opts gmin string "1e-12"
spectre.opts rforce string "1"
spectre.opts note string ""
spectre.opts homotopy string ""
spectre.opts debug string ""
spectre.opts iabstol string "1e-12"
spectre.opts maxwarns string "5"
spectre.opts tempeffects string ""
spectre.opts vabstol string "1e-6"
spectre.opts macromodels string ""
spectre.opts temp string "27"
spectre.opts tnom string "27"
spectre.opts maxnotes string "5"
spectre.opts narrate string ""
spectre.opts value string ""
spectre.opts gmin_check string ""
spectre.opts pivrel string "1e-3"
spectre.opts pivotdc string ""
spectre.opts digits string "5"
spectre.opts maxnotestologfile string ""
spectre.opts diagnose string ""
spectre.opts scale string "1.0"
spectre.opts scalem string "1.0"
spectre.opts error string ""
spectre.opts inventory string ""
spectre.opts topcheck string ""
spectre.opts limit string ""
spectre.opts sensfile string "../psf/sens.output"
;spectre outputs partition variables
spectre.outputs currents string ""
spectre.outputs outputParamInfo boolean t
spectre.outputs modelParamInfo boolean t
spectre.outputs subcktprobelvl string ""
spectre.outputs saveahdlvars string ""
spectre.outputs pwr string ""
spectre.outputs nestlvl string ""
spectre.outputs elementInfo boolean t
spectre.outputs useprobes string ""
spectre.outputs save string "allpub"
;spectre envOpts partition variables
spectre.envOpts stopViewList string "spectre"
spectre.envOpts switchViewList string "spectre cmos_sch cmos.sch schematic veriloga ahdl"
spectre.envOpts enableArclength boolean nil
spectre.envOpts autoDisplay boolean t
spectre.envOpts simOutputFormat string "psfbin"
spectre.envOpts spp string ""
spectre.envOpts analysisOrder string ""
spectre.envOpts paramRangeCheckFile string ""
spectre.envOpts printComments boolean nil
spectre.envOpts checkpoint string ""
spectre.envOpts recover string ""
spectre.envOpts firstRun boolean t
spectre.envOpts userCmdLineOption string ""
;spectre init partition variables
spectre.init processPriority int 0
;spectre pz partition variables
spectre.pz enable toggle (nil)
spectre.pz outType string "voltage"
spectre.pz p string ""
spectre.pz n string ""
spectre.pz oprobe string ""
spectre.pz inType string "voltage"
spectre.pz inVsrc string ""
spectre.pz inIsrc string ""
spectre.pz iprobe string ""
spectre.pz sweep string ""
spectre.pz freq string "1"
spectre.pz dev string ""
spectre.pz deviceParam string ""
spectre.pz mod string ""
spectre.pz modelParam string ""
spectre.pz designVar string ""
spectre.pz param string ""
spectre.pz rangeType string "Start-Stop"
spectre.pz start string ""
spectre.pz stop string ""
spectre.pz center string ""
spectre.pz span string ""
spectre.pz incrType string "Automatic"
spectre.pz stepTypeLin string "Step Size"
spectre.pz stepTypeLog string "Points Per Decade"
spectre.pz step string ""
spectre.pz lin string ""
spectre.pz dec string ""
spectre.pz log string ""
spectre.pz useDiscrete boolean nil
spectre.pz values string ""
spectre.pz porti string "1"
;spectre pzOpts partition variables
spectre.pzOpts readns string ""
spectre.pzOpts oppoint string ""
spectre.pzOpts fmax string ""
spectre.pzOpts zeroonly string ""
spectre.pzOpts prevoppoint string ""
spectre.pzOpts restart string ""
spectre.pzOpts annotate string ""
spectre.pzOpts stats string ""
;spectre dcmatch partition variables
spectre.dcmatch enable toggle (nil)
spectre.dcmatch outType string "voltage"
spectre.dcmatch p string ""
spectre.dcmatch n string ""
spectre.dcmatch oprobe string ""
spectre.dcmatch sweep string ""
spectre.dcmatch dev string ""
spectre.dcmatch deviceParam string ""
spectre.dcmatch mod string ""
spectre.dcmatch modelParam string ""
spectre.dcmatch designVar string ""
spectre.dcmatch param string ""
spectre.dcmatch rangeType string "Start-Stop"
spectre.dcmatch start string ""
spectre.dcmatch stop string ""
spectre.dcmatch center string ""
spectre.dcmatch span string ""
spectre.dcmatch incrType string "Automatic"
spectre.dcmatch stepTypeLin string "Step Size"
spectre.dcmatch stepTypeLog string "Points Per Decade"
spectre.dcmatch step string ""
spectre.dcmatch lin string ""
spectre.dcmatch dec string ""
spectre.dcmatch log string ""
spectre.dcmatch useDiscrete boolean nil
spectre.dcmatch values string ""
spectre.dcmatch mth string ""
spectre.dcmatch porti string "1"
spectre.dcmatch portv string ""
;spectre dcmatchOpts partition variables
spectre.dcmatchOpts readns string ""
spectre.dcmatchOpts save string ""
spectre.dcmatchOpts nestlvl string ""
spectre.dcmatchOpts oppoint string ""
spectre.dcmatchOpts prevoppoint string ""
spectre.dcmatchOpts restart string ""
spectre.dcmatchOpts annotate string "status"
spectre.dcmatchOpts stats string ""
spectre.dcmatchOpts where string "rawfile"
;spectre stb partition variables
spectre.stb enable toggle (nil)
spectre.stb sweep string "Frequency"
spectre.stb freq string ""
spectre.stb dev string ""
spectre.stb deviceParam string ""
spectre.stb mod string ""
spectre.stb modelParam string ""
spectre.stb designVar string ""
spectre.stb param string ""
spectre.stb rangeType string "Start-Stop"
spectre.stb start string ""
spectre.stb stop string ""
spectre.stb center string ""
spectre.stb span string ""
spectre.stb incrType string "Automatic"
spectre.stb stepTypeLin string "Step Size"
spectre.stb stepTypeLog string "Points Per Decade"
spectre.stb step string ""
spectre.stb lin string ""
spectre.stb dec string ""
spectre.stb log string ""
spectre.stb useDiscrete boolean nil
spectre.stb values string ""
spectre.stb probe string ""
;spectre stbOpts partition variables
spectre.stbOpts prevoppoint string ""
spectre.stbOpts readns string ""
spectre.stbOpts save string ""
spectre.stbOpts nestlvl string ""
spectre.stbOpts oppoint string ""
spectre.stbOpts restart string ""
spectre.stbOpts annotate string "status"
spectre.stbOpts stats string ""
;spectre tran partition variables
spectre.tran enable toggle (nil)
spectre.tran stop string ""
spectre.tran errpreset string ""
;spectre tranOpts partition variables
spectre.tranOpts start string ""
spectre.tranOpts outputstart string ""
spectre.tranOpts step string ""
spectre.tranOpts maxstep string ""
spectre.tranOpts ic string ""
spectre.tranOpts skipdc string ""
spectre.tranOpts readic string ""
spectre.tranOpts readns string ""
spectre.tranOpts cmin string ""
spectre.tranOpts write string "spectre.ic"
spectre.tranOpts writefinal string "spectre.fc"
spectre.tranOpts ckptperiod string ""
spectre.tranOpts method string ""
spectre.tranOpts relref string ""
spectre.tranOpts lteratio string ""
spectre.tranOpts stats string ""
spectre.tranOpts annotate string "status"
spectre.tranOpts save string ""
spectre.tranOpts nestlvl string ""
spectre.tranOpts oppoint string ""
spectre.tranOpts skipstart string ""
spectre.tranOpts skipstop string ""
spectre.tranOpts skipcount string ""
spectre.tranOpts strobeperiod string ""
spectre.tranOpts strobedelay string ""
spectre.tranOpts compression string ""
spectre.tranOpts infotimes string ""
spectre.tranOpts flushpoints string ""
spectre.tranOpts flushtime string ""
spectre.tranOpts flushofftime string ""
spectre.tranOpts maxiters string "5"
spectre.tranOpts restart string ""
spectre.tranOpts captab boolean nil
spectre.tranOpts timed boolean nil
spectre.tranOpts threshold string "0.0"
spectre.tranOpts detail string "node"
spectre.tranOpts sort string "name"
;spectre envlp partition variables
spectre.envlp enable toggle (nil)
spectre.envlp clockname string ""
spectre.envlp stop string ""
spectre.envlp harmonics string "Number of harmonics"
spectre.envlp harms string ""
spectre.envlp harmsvec string ""
spectre.envlp errpreset string ""
;spectre envlpOpts partition variables
spectre.envlpOpts start string ""
spectre.envlpOpts outputstart string ""
spectre.envlpOpts tstab string ""
spectre.envlpOpts modulationbw string ""
spectre.envlpOpts maxstep string ""
spectre.envlpOpts envmaxstep string ""
spectre.envlpOpts ic string ""
spectre.envlpOpts skipdc string ""
spectre.envlpOpts readic string ""
spectre.envlpOpts readns string ""
spectre.envlpOpts cmin string ""
spectre.envlpOpts write string ""
spectre.envlpOpts writefinal string ""
spectre.envlpOpts swapfile string ""
spectre.envlpOpts method string ""
spectre.envlpOpts relref string ""
spectre.envlpOpts lteratio string ""
spectre.envlpOpts envlteratio string ""
spectre.envlpOpts steadyratio string ""
spectre.envlpOpts stats string ""
spectre.envlpOpts annotate string "status"
spectre.envlpOpts save string ""
spectre.envlpOpts nestlvl string ""
spectre.envlpOpts compression string ""
spectre.envlpOpts outputtype string ""
spectre.envlpOpts strobeperiod string ""
spectre.envlpOpts maxiters string ""
spectre.envlpOpts restart string ""
spectre.envlpOpts envmaxiters string ""
;spectre ac partition variables
spectre.ac enable toggle (nil)
spectre.ac sweep string "Frequency"
spectre.ac freq string ""
spectre.ac dev string ""
spectre.ac deviceParam string ""
spectre.ac mod string ""
spectre.ac modelParam string ""
spectre.ac designVar string ""
spectre.ac param string ""
spectre.ac rangeType string "Start-Stop"
spectre.ac start string ""
spectre.ac stop string ""
spectre.ac center string ""
spectre.ac span string ""
spectre.ac incrType string "Automatic"
spectre.ac stepTypeLin string "Step Size"
spectre.ac stepTypeLog string "Points Per Decade"
spectre.ac step string ""
spectre.ac lin string ""
spectre.ac dec string ""
spectre.ac log string ""
spectre.ac useDiscrete boolean nil
spectre.ac values string ""
;spectre acOpts partition variables
spectre.acOpts readns string ""
spectre.acOpts prevoppoint string ""
spectre.acOpts save string ""
spectre.acOpts nestlvl string ""
spectre.acOpts oppoint string ""
spectre.acOpts restart string ""
spectre.acOpts annotate string "status"
spectre.acOpts stats string ""
;spectre dc partition variables
spectre.dc enable toggle (nil)
spectre.dcop enable toggle (nil)
spectre.dc saveOppoint boolean nil
spectre.dc sweep string ""
spectre.dc dev string ""
spectre.dc deviceParam string ""
spectre.dc mod string ""
spectre.dc modelParam string ""
spectre.dc designVar string ""
spectre.dc param string ""
spectre.dc rangeType string "Start-Stop"
spectre.dc start string ""
spectre.dc stop string ""
spectre.dc center string ""
spectre.dc span string ""
spectre.dc incrType string "Automatic"
spectre.dc stepTypeLin string "Step Size"
spectre.dc stepTypeLog string "Points Per Decade"
spectre.dc step string ""
spectre.dc lin string ""
spectre.dc dec string ""
spectre.dc log string ""
spectre.dc useDiscrete boolean nil
spectre.dc values string ""
;spectre dcOpts partition variables
spectre.dcOpts force string ""
spectre.dcopOpts force string ""
spectre.dcOpts readns string ""
spectre.dcopOpts readns string ""
spectre.dcOpts readforce string ""
spectre.dcopOpts readforce string ""
spectre.dcOpts write string "spectre.dc"
spectre.dcopOpts write string "spectre.dc"
spectre.dcOpts writefinal string ""
spectre.dcopOpts writefinal string ""
spectre.dcOpts save string ""
spectre.dcopOpts save string ""
spectre.dcOpts nestlvl string ""
spectre.dcopOpts nestlvl string ""
spectre.dcOpts print string ""
spectre.dcopOpts print string ""
spectre.dcOpts check string ""
spectre.dcopOpts check string ""
spectre.dcOpts oppoint string "rawfile"
spectre.dcopOpts oppoint string "rawfile"
spectre.dcOpts homotopy string ""
spectre.dcopOpts homotopy string ""
spectre.dcOpts restart string ""
spectre.dcopOpts restart string ""
spectre.dcOpts maxiters string "150"
spectre.dcopOpts maxiters string "150"
spectre.dcOpts maxsteps string "10000"
spectre.dcopOpts maxsteps string "10000"
spectre.dcOpts annotate string "status"
spectre.dcopOpts annotate string "status"
spectre.dcOpts captab boolean nil
spectre.dcopOpts captab boolean nil
spectre.dcOpts threshold string "0.0"
spectre.dcopOpts threshold string "0.0"
spectre.dcOpts detail string "node"
spectre.dcopOpts detail string "node"
spectre.dcOpts sort string "name"
spectre.dcopOpts sort string "name"
;spectre noise partition variables
spectre.noise enable toggle (nil)
spectre.noise sweep string "Frequency"
spectre.noise freq string ""
spectre.noise dev string ""
spectre.noise deviceParam string ""
spectre.noise mod string ""
spectre.noise modelParam string ""
spectre.noise designVar string ""
spectre.noise param string ""
spectre.noise rangeType string "Start-Stop"
spectre.noise start string ""
spectre.noise stop string ""
spectre.noise center string ""
spectre.noise span string ""
spectre.noise incrType string "Automatic"
spectre.noise stepTypeLin string "Step Size"
spectre.noise stepTypeLog string "Points Per Decade"
spectre.noise step string ""
spectre.noise lin string ""
spectre.noise dec string ""
spectre.noise log string ""
spectre.noise useDiscrete boolean nil
spectre.noise values string ""
spectre.noise outType string "probe"
spectre.noise p string ""
spectre.noise n string ""
spectre.noise oprobe string ""
spectre.noise inType string "port"
spectre.noise inVsrc string ""
spectre.noise inIsrc string ""
spectre.noise iprobe string ""
spectre.noise inPort string ""
;spectre noiseOpts partition variables
spectre.noiseOpts readns string ""
spectre.noiseOpts prevoppoint string ""
spectre.noiseOpts save string ""
spectre.noiseOpts nestlvl string ""
spectre.noiseOpts oppoint string ""
spectre.noiseOpts restart string ""
spectre.noiseOpts annotate string "status"
spectre.noiseOpts stats string ""
;spectre xf partition variables
spectre.xf enable toggle (nil)
spectre.xf sweep string "Frequency"
spectre.xf freq string ""
spectre.xf dev string ""
spectre.xf deviceParam string ""
spectre.xf mod string ""
spectre.xf modelParam string ""
spectre.xf designVar string ""
spectre.xf param string ""
spectre.xf rangeType string "Start-Stop"
spectre.xf start string ""
spectre.xf stop string ""
spectre.xf center string ""
spectre.xf span string ""
spectre.xf incrType string "Automatic"
spectre.xf stepTypeLin string "Step Size"
spectre.xf stepTypeLog string "Points Per Decade"
spectre.xf step string ""
spectre.xf lin string ""
spectre.xf dec string ""
spectre.xf log string ""
spectre.xf useDiscrete boolean nil
spectre.xf values string ""
spectre.xf outType string "voltage"
spectre.xf p string ""
spectre.xf n string ""
spectre.xf probe string ""
;spectre xfOpts partition variables
spectre.xfOpts readns string ""
spectre.xfOpts prevoppoint string ""
spectre.xfOpts stimuli string ""
spectre.xfOpts save string ""
spectre.xfOpts nestlvl string ""
spectre.xfOpts oppoint string ""
spectre.xfOpts restart string ""
spectre.xfOpts annotate string "status"
spectre.xfOpts stats string ""
;spectre sp partition variables
spectre.sp enable toggle (nil)
spectre.sp ports string ""
spectre.sp sweep string "Frequency"
spectre.sp freq string ""
spectre.sp dev string ""
spectre.sp deviceParam string ""
spectre.sp mod string ""
spectre.sp modelParam string ""
spectre.sp designVar string ""
spectre.sp param string ""
spectre.sp rangeType string "Start-Stop"
spectre.sp start string ""
spectre.sp stop string ""
spectre.sp center string ""
spectre.sp span string ""
spectre.sp incrType string "Automatic"
spectre.sp stepTypeLin string "Step Size"
spectre.sp stepTypeLog string "Points Per Decade"
spectre.sp step string ""
spectre.sp lin string ""
spectre.sp dec string ""
spectre.sp log string ""
spectre.sp useDiscrete boolean nil
spectre.sp values string ""
spectre.sp donoise string "no"
spectre.sp oprobe string ""
spectre.sp iprobe string ""
;spectre spOpts partition variables
spectre.spOpts readns string ""
spectre.spOpts prevoppoint string ""
spectre.spOpts file string ""
spectre.spOpts datafmt string ""
spectre.spOpts datatype string ""
spectre.spOpts noisedata string ""
spectre.spOpts oppoint string ""
spectre.spOpts restart string ""
spectre.spOpts annotate string "status"
spectre.spOpts stats string ""
;spectre pss partition variables
spectre.pss enable toggle (nil)
spectre.pss paramListBox string ""
spectre.pss fundListBox string ""
spectre.pss stimName string ""
spectre.pss freqName string ""
spectre.pss freqVal string ""
spectre.pss signalLevel string "Large"
spectre.pss srcId string ""
spectre.pss maxHarms string ""
spectre.pss freqPeriod string "Beat Frequency"
spectre.pss fund string ""
spectre.pss autoCalc boolean nil
spectre.pss period string ""
spectre.pss harmonics string "Number of harmonics"
spectre.pss harms string ""
spectre.pss indices string ""
spectre.pss Aindices string ""
spectre.pss harmsvec string ""
spectre.pss selFreqFrom string "0"
spectre.pss selFreqTo string "1e12"
spectre.pss order string "1"
spectre.pss harmsAndFreqsTitle string ""
spectre.pss harmsAndFreqsTitle2 string ""
spectre.pss harmsAndFreqs string ""
spectre.pss arrayCoeffs string ""
spectre.pss harmCoeffs string ""
spectre.pss harmListMem string ""
spectre.pss errpreset string ""
spectre.pss tstab string ""
spectre.pss saveinit string ""
spectre.pss oscana boolean nil
spectre.pss p string ""
spectre.pss n string ""
spectre.pss sweepB boolean nil
spectre.pss sweep string "Variable"
spectre.pss freqVar string "no"
spectre.pss designVar string ""
spectre.pss dev string ""
spectre.pss deviceParam string ""
spectre.pss mod string ""
spectre.pss modelParam string ""
spectre.pss param string ""
spectre.pss rangeType string "Start-Stop"
spectre.pss start string ""
spectre.pss stop string ""
spectre.pss center string ""
spectre.pss span string ""
spectre.pss incrType string "Linear"
spectre.pss stepTypeLin string "Step Size"
spectre.pss stepTypeLog string "Points Per Decade"
spectre.pss step string ""
spectre.pss lin string ""
spectre.pss dec string ""
spectre.pss log string ""
spectre.pss useDiscrete boolean nil
spectre.pss values string ""
;spectre pssOpts partition variables
spectre.pssOpts step string ""
spectre.pssOpts maxstep string ""
spectre.pssOpts ic string ""
spectre.pssOpts skipdc string ""
spectre.pssOpts readic string ""
spectre.pssOpts readns string ""
spectre.pssOpts cmin string ""
spectre.pssOpts write string ""
spectre.pssOpts writefinal string ""
spectre.pssOpts swapfile string ""
spectre.pssOpts writepss string ""
spectre.pssOpts readpss string ""
spectre.pssOpts method string ""
spectre.pssOpts tstabmethod string ""
spectre.pssOpts relref string ""
spectre.pssOpts lteratio string ""
spectre.pssOpts steadyratio string ""
spectre.pssOpts maxacfreq string ""
spectre.pssOpts maxperiods string ""
spectre.pssOpts finitediff string ""
spectre.pssOpts highorder string ""
spectre.pssOpts psaratio string ""
spectre.pssOpts maxorder string ""
spectre.pssOpts fullpssvec string ""
spectre.pssOpts stats string ""
spectre.pssOpts annotate string "status"
spectre.pssOpts save string ""
spectre.pssOpts nestlvl string ""
spectre.pssOpts oppoint string ""
spectre.pssOpts skipstart string ""
spectre.pssOpts skipstop string ""
spectre.pssOpts skipcount string ""
spectre.pssOpts strobeperiod string ""
spectre.pssOpts strobedelay string ""
spectre.pssOpts compression string ""
spectre.pssOpts outputtype string ""
spectre.pssOpts maxiters string ""
spectre.pssOpts restart string ""
spectre.pssOpts tstart string ""
;spectre pac partition variables
spectre.pac enable toggle (nil)
spectre.pac fund string ""
spectre.pac period string ""
spectre.pac modsource string ""
spectre.pac moduppersideband string "0"
spectre.pac inmodharmnum string "1"
spectre.pac outmodharmvec string "1"
spectre.pac inputType string "SSB"
spectre.pac modulatedToggle boolean nil
spectre.pac modulated string ""
spectre.pac singlePt string "Single-Point []"
spectre.pac sweeptype string " "
spectre.pac relharmnum string ""
spectre.pac rangeType string "Start-Stop"
spectre.pac start string ""
spectre.pac stop string ""
spectre.pac center string ""
spectre.pac span string ""
spectre.pac incrType string "Automatic"
spectre.pac stepTypeLin string "Step Size"
spectre.pac stepTypeLog string "Points Per Decade"
spectre.pac step string ""
spectre.pac lin string ""
spectre.pac dec string ""
spectre.pac log string ""
spectre.pac useDiscrete boolean nil
spectre.pac values string ""
spectre.pac harmonics string "Maximum sideband"
spectre.pac maxsideband string ""
spectre.pac indices string ""
spectre.pac Aindices string ""
spectre.pac sidebands string ""
spectre.pac side string "upper"
spectre.pac selFreqFrom string "0"
spectre.pac selFreqTo string "1e12"
spectre.pac order string "1"
spectre.pac harmsAndFreqsTitle string ""
spectre.pac harmsAndFreqsTitle2 string ""
spectre.pac harmsAndFreqs string ""
spectre.pac arrayCoeffs string ""
spectre.pac harmCoeffs string ""
spectre.pac harmListMem string ""
;spectre pacOpts partition variables
spectre.pacOpts tolerance string ""
spectre.pacOpts gear_order string ""
spectre.pacOpts solver string ""
spectre.pacOpts oscsolver string ""
spectre.pacOpts stats string ""
spectre.pacOpts annotate string "status"
spectre.pacOpts freqaxis string ""
spectre.pacOpts save string ""
spectre.pacOpts nestlvl string ""
spectre.pacOpts outputperiod string ""
;spectre pnoise partition variables
spectre.pnoise enable toggle (nil)
spectre.pnoise fund string ""
spectre.pnoise period string ""
spectre.pnoise singlePt string "Single-Point []"
spectre.pnoise sweeptype string " "
spectre.pnoise relharmnum string ""
spectre.pnoise rangeType string "Start-Stop"
spectre.pnoise start string ""
spectre.pnoise stop string ""
spectre.pnoise center string ""
spectre.pnoise span string ""
spectre.pnoise incrType string "Automatic"
spectre.pnoise stepTypeLin string "Step Size"
spectre.pnoise stepTypeLog string "Points Per Decade"
spectre.pnoise step string ""
spectre.pnoise lin string ""
spectre.pnoise dec string ""
spectre.pnoise log string ""
spectre.pnoise useDiscrete boolean nil
spectre.pnoise values string ""
spectre.pnoise harmonics string "Maximum sideband"
spectre.pnoise maxsideband string ""
spectre.pnoise indices string ""
spectre.pnoise Aindices string ""
spectre.pnoise sidebands string ""
spectre.pnoise side string "upper"
spectre.pnoise selFreqFrom string "0"
spectre.pnoise selFreqTo string "1e12"
spectre.pnoise order string "1"
spectre.pnoise harmsAndFreqsTitle string ""
spectre.pnoise harmsAndFreqsTitle2 string ""
spectre.pnoise harmsAndFreqs string ""
spectre.pnoise arrayCoeffs string ""
spectre.pnoise harmCoeffs string ""
spectre.pnoise harmListMem string ""
spectre.pnoise outType string "probe"
spectre.pnoise p string ""
spectre.pnoise n string ""
spectre.pnoise oprobe string ""
spectre.pnoise inType string "port"
spectre.pnoise inVsrc string ""
spectre.pnoise inIsrc string ""
spectre.pnoise iprobe string ""
spectre.pnoise inPort string ""
spectre.pnoise refsbSelect string "Enter in field"
spectre.pnoise refsideband string ""
spectre.pnoise refsbFreqFrom string "0"
spectre.pnoise refsbFreqTo string "1e12"
spectre.pnoise refsbOrder string "1"
spectre.pnoise refsbTitle string ""
spectre.pnoise refsbListbox string ""
spectre.pnoise noisetype string "sources"
spectre.pnoise tdnoise string "Noise Skip Count"
spectre.pnoise noiseskipcount string ""
spectre.pnoise numberofpoints string ""
spectre.pnoise maxcycles string ""
spectre.pnoise useDiscreteNoise boolean nil
spectre.pnoise noisetimepoints string ""
spectre.pnoise useDiscreteCorr boolean nil
spectre.pnoise cycles string ""
;spectre pnoiseOpts partition variables
spectre.pnoiseOpts tolerance string ""
spectre.pnoiseOpts gear_order string ""
spectre.pnoiseOpts solver string ""
spectre.pnoiseOpts oscsolver string ""
spectre.pnoiseOpts stats string ""
spectre.pnoiseOpts annotate string "status"
spectre.pnoiseOpts save string ""
spectre.pnoiseOpts nestlvl string ""
spectre.pnoiseOpts saveallsidebands string ""
;spectre pxf partition variables
spectre.pxf enable toggle (nil)
spectre.pxf fund string ""
spectre.pxf period string ""
spectre.pxf moduppersideband string "0"
spectre.pxf outmodharmnum string "1"
spectre.pxf inmodharmvec string "1"
spectre.pxf outputType string "SSB"
spectre.pxf modulatedToggle boolean nil
spectre.pxf modulated string ""
spectre.pxf outType string "voltage"
spectre.pxf p string ""
spectre.pxf n string ""
spectre.pxf probe string ""
spectre.pxf singlePt string "Single-Point []"
spectre.pxf sweeptype string " "
spectre.pxf relharmnum string ""
spectre.pxf rangeType string "Start-Stop"
spectre.pxf start string ""
spectre.pxf stop string ""
spectre.pxf center string ""
spectre.pxf span string ""
spectre.pxf incrType string "Automatic"
spectre.pxf stepTypeLin string "Step Size"
spectre.pxf stepTypeLog string "Points Per Decade"
spectre.pxf step string ""
spectre.pxf lin string ""
spectre.pxf dec string ""
spectre.pxf log string ""
spectre.pxf useDiscrete boolean nil
spectre.pxf values string ""
spectre.pxf harmonics string "Maximum sideband"
spectre.pxf maxsideband string ""
spectre.pxf indices string ""
spectre.pxf Aindices string ""
spectre.pxf sidebands string ""
spectre.pxf side string "upper"
spectre.pxf selFreqFrom string "0"
spectre.pxf selFreqTo string "1e12"
spectre.pxf order string "1"
spectre.pxf harmsAndFreqsTitle string ""
spectre.pxf harmsAndFreqsTitle2 string ""
spectre.pxf harmsAndFreqs string ""
spectre.pxf arrayCoeffs string ""
spectre.pxf harmCoeffs string ""
spectre.pxf harmListMem string ""
;spectre pxfOpts partition variables
spectre.pxfOpts tolerance string ""
spectre.pxfOpts gear_order string ""
spectre.pxfOpts solver string ""
spectre.pxfOpts oscsolver string ""
spectre.pxfOpts stats string ""
spectre.pxfOpts annotate string "status"
spectre.pxfOpts stimuli string ""
spectre.pxfOpts freqaxis string ""
spectre.pxfOpts save string ""
spectre.pxfOpts nestlvl string ""
;spectre psp partition variables
spectre.psp enable toggle (nil)
spectre.psp singlePt string "Single-Point []"
spectre.psp sweeptype string " "
spectre.psp rangeType string "Start-Stop"
spectre.psp start string ""
spectre.psp stop string ""
spectre.psp center string ""
spectre.psp span string ""
spectre.psp incrType string "Automatic"
spectre.psp stepTypeLin string "Step Size"
spectre.psp stepTypeLog string "Points Per Decade"
spectre.psp step string ""
spectre.psp lin string ""
spectre.psp dec string ""
spectre.psp log string ""
spectre.psp useDiscrete boolean nil
spectre.psp values string ""
spectre.psp portharmsvec string ""
spectre.psp ports string ""
spectre.psp selectPorts boolean t
spectre.psp harmsvec string ""
spectre.psp freqRange string ""
spectre.psp listPortHarm string ""
spectre.psp listPortName string ""
spectre.psp listPortNum string ""
spectre.psp portChoiceList string ""
spectre.psp portChoiceListHeading string ""
spectre.psp donoise string "yes"
spectre.psp maxsideband string ""
;spectre pspOpts partition variables
spectre.pspOpts tolerance string ""
spectre.pspOpts gear_order string ""
spectre.pspOpts solver string ""
spectre.pspOpts oscsolver string ""
spectre.pspOpts annotate string "status"
spectre.pspOpts stats string ""
spectre.pspOpts freqaxis string ""
;spectre qpss partition variables
spectre.qpss enable toggle (nil)
spectre.qpss paramListBox string ""
spectre.qpss fundListBox string ""
spectre.qpss stimName string ""
spectre.qpss freqName string ""
spectre.qpss freqVal string ""
spectre.qpss signalLevel string "Moderate"
spectre.qpss srcId string ""
spectre.qpss maxHarms string ""
spectre.qpss funds string ""
spectre.qpss maxharms string ""
spectre.qpss harmonics boolean nil
spectre.qpss selFreqFrom string "0"
spectre.qpss selFreqTo string "1e12"
spectre.qpss harmsAndFreqsTitle string ""
spectre.qpss harmsAndFreqs string ""
spectre.qpss errpreset string ""
spectre.qpss tstab string ""
spectre.qpss saveinit string ""
spectre.qpss sweepB boolean nil
spectre.qpss sweep string "Variable"
spectre.qpss freqVar string "no"
spectre.qpss designVar string ""
spectre.qpss dev string ""
spectre.qpss deviceParam string ""
spectre.qpss mod string ""
spectre.qpss modelParam string ""
spectre.qpss param string ""
spectre.qpss rangeType string "Start-Stop"
spectre.qpss start string ""
spectre.qpss stop string ""
spectre.qpss center string ""
spectre.qpss span string ""
spectre.qpss incrType string "Linear"
spectre.qpss stepTypeLin string "Step Size"
spectre.qpss stepTypeLog string "Points Per Decade"
spectre.qpss step string ""
spectre.qpss lin string ""
spectre.qpss dec string ""
spectre.qpss log string ""
spectre.qpss useDiscrete boolean nil
spectre.qpss values string ""
;spectre qpssOpts partition variables
spectre.qpssOpts step string ""
spectre.qpssOpts maxstep string ""
spectre.qpssOpts ic string ""
spectre.qpssOpts skipdc string ""
spectre.qpssOpts readic string ""
spectre.qpssOpts readns string ""
spectre.qpssOpts cmin string ""
spectre.qpssOpts write string ""
spectre.qpssOpts writefinal string ""
spectre.qpssOpts swapfile string ""
spectre.qpssOpts writeqpss string ""
spectre.qpssOpts readqpss string ""
spectre.qpssOpts method string ""
spectre.qpssOpts relref string ""
spectre.qpssOpts lteratio string ""
spectre.qpssOpts steadyratio string ""
spectre.qpssOpts maxperiods string ""
spectre.qpssOpts stats string ""
spectre.qpssOpts annotate string "status"
spectre.qpssOpts save string ""
spectre.qpssOpts nestlvl string ""
spectre.qpssOpts oppoint string ""
spectre.qpssOpts skipstart string ""
spectre.qpssOpts skipstop string ""
spectre.qpssOpts skipcount string ""
spectre.qpssOpts strobeperiod string ""
spectre.qpssOpts strobedelay string ""
spectre.qpssOpts compression string ""
spectre.qpssOpts maxiters string ""
spectre.qpssOpts restart string ""
spectre.qpssOpts tstart string ""
;spectre qpac partition variables
spectre.qpac enable toggle (nil)
spectre.qpac singlePt string "Single-Point []"
spectre.qpac sweeptype string " "
spectre.qpac relharmvec string ""
spectre.qpac rangeType string "Start-Stop"
spectre.qpac start string ""
spectre.qpac stop string ""
spectre.qpac center string ""
spectre.qpac span string ""
spectre.qpac incrType string "Automatic"
spectre.qpac stepTypeLin string "Step Size"
spectre.qpac stepTypeLog string "Points Per Decade"
spectre.qpac step string ""
spectre.qpac lin string ""
spectre.qpac dec string ""
spectre.qpac log string ""
spectre.qpac useDiscrete boolean nil
spectre.qpac values string ""
spectre.qpac sbsm string "Maximum clock order"
spectre.qpac clockmaxharm string ""
spectre.qpac selFreqFrom string "0"
spectre.qpac selFreqTo string "1e12"
spectre.qpac order string "1"
spectre.qpac harmsAndFreqsTitle string ""
spectre.qpac harmsAndFreqsTitle2 string ""
spectre.qpac harmsAndFreqs string ""
spectre.qpac arrayCoeffs string ""
spectre.qpac harmCoeffs string ""
spectre.qpac harmListMem string ""
spectre.qpac sidevec string ""
;spectre qpacOpts partition variables
spectre.qpacOpts tolerance string ""
spectre.qpacOpts gear_order string ""
spectre.qpacOpts solver string ""
spectre.qpacOpts stats string ""
spectre.qpacOpts annotate string "status"
spectre.qpacOpts freqaxis string ""
spectre.qpacOpts save string ""
spectre.qpacOpts nestlvl string ""
;spectre qpnoise partition variables
spectre.qpnoise enable toggle (nil)
spectre.qpnoise singlePt string "Single-Point []"
spectre.qpnoise sweeptype string " "
spectre.qpnoise relharmvec string ""
spectre.qpnoise rangeType string "Start-Stop"
spectre.qpnoise start string ""
spectre.qpnoise stop string ""
spectre.qpnoise center string ""
spectre.qpnoise span string ""
spectre.qpnoise incrType string "Automatic"
spectre.qpnoise stepTypeLin string "Step Size"
spectre.qpnoise stepTypeLog string "Points Per Decade"
spectre.qpnoise step string ""
spectre.qpnoise lin string ""
spectre.qpnoise dec string ""
spectre.qpnoise log string ""
spectre.qpnoise useDiscrete boolean nil
spectre.qpnoise values string ""
spectre.qpnoise sbsm string "Maximum clock order"
spectre.qpnoise clockmaxharm string ""
spectre.qpnoise selFreqFrom string "0"
spectre.qpnoise selFreqTo string "1e12"
spectre.qpnoise order string "1"
spectre.qpnoise harmsAndFreqsTitle string ""
spectre.qpnoise harmsAndFreqsTitle2 string ""
spectre.qpnoise harmsAndFreqs string ""
spectre.qpnoise arrayCoeffs string ""
spectre.qpnoise harmCoeffs string ""
spectre.qpnoise harmListMem string ""
spectre.qpnoise sidevec string ""
spectre.qpnoise outType string "probe"
spectre.qpnoise p string ""
spectre.qpnoise n string ""
spectre.qpnoise oprobe string ""
spectre.qpnoise inType string "port"
spectre.qpnoise inVsrc string ""
spectre.qpnoise inIsrc string ""
spectre.qpnoise iprobe string ""
spectre.qpnoise inPort string ""
spectre.qpnoise refsbSelect string "Enter in field"
spectre.qpnoise refsideband string ""
spectre.qpnoise refsbFreqFrom string "0"
spectre.qpnoise refsbFreqTo string "1e12"
spectre.qpnoise refsbOrder string "1"
spectre.qpnoise refsbTitle string ""
spectre.qpnoise refsbListbox string ""
;spectre qpnoiseOpts partition variables
spectre.qpnoiseOpts tolerance string ""
spectre.qpnoiseOpts gear_order string ""
spectre.qpnoiseOpts solver string ""
spectre.qpnoiseOpts stats string ""
spectre.qpnoiseOpts annotate string "status"
spectre.qpnoiseOpts save string ""
spectre.qpnoiseOpts nestlvl string ""
spectre.qpnoiseOpts saveallsidebands string ""
;spectre qpxf partition variables
spectre.qpxf enable toggle (nil)
spectre.qpxf singlePt string "Single-Point []"
spectre.qpxf sweeptype string " "
spectre.qpxf relharmvec string ""
spectre.qpxf rangeType string "Start-Stop"
spectre.qpxf start string ""
spectre.qpxf stop string ""
spectre.qpxf center string ""
spectre.qpxf span string ""
spectre.qpxf incrType string "Automatic"
spectre.qpxf stepTypeLin string "Step Size"
spectre.qpxf stepTypeLog string "Points Per Decade"
spectre.qpxf step string ""
spectre.qpxf lin string ""
spectre.qpxf dec string ""
spectre.qpxf log string ""
spectre.qpxf useDiscrete boolean nil
spectre.qpxf values string ""
spectre.qpxf sbsm string "Maximum clock order"
spectre.qpxf clockmaxharm string ""
spectre.qpxf selFreqFrom string "0"
spectre.qpxf selFreqTo string "1e12"
spectre.qpxf order string "1"
spectre.qpxf harmsAndFreqsTitle string ""
spectre.qpxf harmsAndFreqsTitle2 string ""
spectre.qpxf harmsAndFreqs string ""
spectre.qpxf arrayCoeffs string ""
spectre.qpxf harmCoeffs string ""
spectre.qpxf harmListMem string ""
spectre.qpxf sidevec string ""
spectre.qpxf outType string "voltage"
spectre.qpxf p string ""
spectre.qpxf n string ""
spectre.qpxf probe string ""
;spectre qpxfOpts partition variables
spectre.qpxfOpts tolerance string ""
spectre.qpxfOpts gear_order string ""
spectre.qpxfOpts solver string ""
spectre.qpxfOpts stats string ""
spectre.qpxfOpts annotate string "status"
spectre.qpxfOpts stimuli string ""
spectre.qpxfOpts freqaxis string ""
spectre.qpxfOpts save string ""
spectre.qpxfOpts nestlvl string ""
;spectre qpsp partition variables
spectre.qpsp enable toggle (nil)
spectre.qpsp singlePt string "Single-Point []"
spectre.qpsp sweeptype string " "
spectre.qpsp rangeType string "Start-Stop"
spectre.qpsp start string ""
spectre.qpsp stop string ""
spectre.qpsp center string ""
spectre.qpsp span string ""
spectre.qpsp incrType string "Automatic"
spectre.qpsp stepTypeLin string "Step Size"
spectre.qpsp stepTypeLog string "Points Per Decade"
spectre.qpsp step string ""
spectre.qpsp lin string ""
spectre.qpsp dec string ""
spectre.qpsp log string ""
spectre.qpsp useDiscrete boolean nil
spectre.qpsp values string ""
spectre.qpsp portharmsvec string ""
spectre.qpsp ports string ""
spectre.qpsp selectPorts boolean t
spectre.qpsp harmsvec string ""
spectre.qpsp freqRange string ""
spectre.qpsp listPortHarm string ""
spectre.qpsp listPortName string ""
spectre.qpsp listPortNum string ""
spectre.qpsp portChoiceList string ""
spectre.qpsp portChoiceListHeading string ""
spectre.qpsp donoise string "yes"
spectre.qpsp clockmaxharm string ""
;spectre qpspOpts partition variables
spectre.qpspOpts tolerance string ""
spectre.qpspOpts gear_order string ""
spectre.qpspOpts solver string ""
spectre.qpspOpts annotate string "status"
spectre.qpspOpts stats string ""
spectre.qpspOpts freqaxis string ""
;spectre sens partition variables
spectre.sens enable toggle (nil)
spectre.sens sensType toggle (nil nil nil)
spectre.sens analyses_list string ""
spectre.sens outputs string ""
spectre.sens output_list string ""
spectre.sens net string ""
spectre.sens term string ""
;spectre sensOpts partition variables
;spectreS environment variables
;spectreS opts partition variables
spectreS.opts title string ""
spectreS.opts audit string ""
spectreS.opts ckptclock string "1800"
spectreS.opts flow string ""
spectreS.opts cols string "80"
spectreS.opts opptcheck string ""
spectreS.opts reltol string "1e-3"
spectreS.opts notation string ""
spectreS.opts warn string ""
spectreS.opts approx string ""
spectreS.opts info string ""
spectreS.opts quantities string ""
spectreS.opts pivabs string ""
spectreS.opts compatible string ""
spectreS.opts ignshorts string ""
spectreS.opts gmin string "1e-12"
spectreS.opts rforce string "1"
spectreS.opts homotopy string ""
spectreS.opts debug string ""
spectreS.opts iabstol string "1e-12"
spectreS.opts maxwarns string "5"
spectreS.opts tempeffects string ""
spectreS.opts vabstol string "1e-6"
spectreS.opts temp string "27"
spectreS.opts tnom string "27"
spectreS.opts narrate string ""
spectreS.opts value string ""
spectreS.opts gmin_check string ""
spectreS.opts pivrel string "1e-3"
spectreS.opts pivotdc string ""
spectreS.opts digits string "5"
spectreS.opts diagnose string ""
spectreS.opts scale string "1.0"
spectreS.opts scalem string "1.0"
spectreS.opts error string ""
spectreS.opts inventory string ""
spectreS.opts topcheck string ""
spectreS.opts limit string ""
;spectreS outputs partition variables
spectreS.outputs allAnalogACTC boolean nil
spectreS.outputs allAhdlVars boolean nil
spectreS.outputs allAnalogNV boolean t
spectreS.outputs allAnalogTC boolean nil
;spectreS envOpts partition variables
spectreS.envOpts updateFile string ""
spectreS.envOpts stimulusFile string ""
spectreS.envOpts instViewListTable string ""
spectreS.envOpts doInstBased boolean nil
spectreS.envOpts stopViewList string "spectreS spice"
spectreS.envOpts paramRangeCheckFile string ""
spectreS.envOpts includeSyntax string "cdsSpice"
spectreS.envOpts initFile string ""
spectreS.envOpts printComments boolean nil
spectreS.envOpts netlistType string "hierarchical"
spectreS.envOpts generateMapFile boolean nil
spectreS.envOpts includeFile string ""
spectreS.envOpts recover boolean nil
spectreS.envOpts instStopListTable string ""
spectreS.envOpts switchViewList string "spectreS spice cmos_sch cmos.sch schematic veriloga ahdl"
;spectreS init partition variables
spectreS.init processPriority int 0
;spectreS tran partition variables
spectreS.tran enable toggle (nil)
spectreS.tran to string ""
spectreS.tran errpreset string ""
;spectreS tranOpts partition variables
spectreS.tranOpts start string ""
spectreS.tranOpts outputstart string ""
spectreS.tranOpts step string ""
spectreS.tranOpts maxstep string ""
spectreS.tranOpts ic string ""
spectreS.tranOpts skipdc string ""
spectreS.tranOpts readic string ""
spectreS.tranOpts readns string ""
spectreS.tranOpts cmin string ""
spectreS.tranOpts write string "spectre.ic"
spectreS.tranOpts writefinal string "spectre.fc"
spectreS.tranOpts ckptperiod string ""
spectreS.tranOpts method string "default"
spectreS.tranOpts relref string "default"
spectreS.tranOpts lteratio string ""
spectreS.tranOpts stats string ""
spectreS.tranOpts annotate string "status"
spectreS.tranOpts oppoint string ""
spectreS.tranOpts skipstart string ""
spectreS.tranOpts skipstop string ""
spectreS.tranOpts skipcount string ""
spectreS.tranOpts strobeperiod string ""
spectreS.tranOpts strobedelay string ""
spectreS.tranOpts compression string "no"
spectreS.tranOpts maxiters string "5"
spectreS.tranOpts restart string ""
;spectreS ac partition variables
spectreS.ac enable toggle (nil)
spectreS.ac sweep string "Frequency"
spectreS.ac freq string ""
spectreS.ac device string ""
spectreS.ac deviceParam string ""
spectreS.ac model string ""
spectreS.ac modelParam string ""
spectreS.ac temperature string "temp"
spectreS.ac rangeType string "Start-Stop"
spectreS.ac from string ""
spectreS.ac to string ""
spectreS.ac center string ""
spectreS.ac span string ""
spectreS.ac incrType string "Automatic"
spectreS.ac stepTypeLin string "Step Size"
spectreS.ac stepTypeLog string "Points Per Decade"
spectreS.ac by string ""
spectreS.ac lin string ""
spectreS.ac dec string ""
spectreS.ac log string ""
spectreS.ac useDiscrete boolean nil
spectreS.ac values string ""
;spectreS acOpts partition variables
spectreS.acOpts readns string ""
spectreS.acOpts oppoint string ""
spectreS.acOpts restart string ""
spectreS.acOpts annotate string "status"
spectreS.acOpts stats string ""
;spectreS dc partition variables
spectreS.dc enable toggle (nil)
spectreS.dcop enable toggle (nil)
spectreS.dc saveOppoint boolean nil
spectreS.dc oppoint string "rawfile"
spectreS.dc save string "allpub"
spectreS.dc sweep string ""
spectreS.dc device string ""
spectreS.dc deviceParam string ""
spectreS.dc model string ""
spectreS.dc modelParam string ""
spectreS.dc temperature string "temp"
spectreS.dc rangeType string "Start-Stop"
spectreS.dc from string ""
spectreS.dc to string ""
spectreS.dc center string ""
spectreS.dc span string ""
spectreS.dc incrType string "Automatic"
spectreS.dc stepTypeLin string "Step Size"
spectreS.dc stepTypeLog string "Points Per Decade"
spectreS.dc by string ""
spectreS.dc lin string ""
spectreS.dc dec string ""
spectreS.dc log string ""
spectreS.dc useDiscrete boolean nil
spectreS.dc values string ""
;spectreS dcOpts partition variables
spectreS.dcOpts force string ""
spectreS.dcopOpts force string ""
spectreS.dcOpts readns string ""
spectreS.dcopOpts readns string ""
spectreS.dcOpts readforce string ""
spectreS.dcopOpts readforce string ""
spectreS.dcOpts write string "spectre.dc"
spectreS.dcopOpts write string "spectre.dc"
spectreS.dcOpts writefinal string ""
spectreS.dcopOpts writefinal string ""
spectreS.dcOpts print string ""
spectreS.dcopOpts print string ""
spectreS.dcOpts check string ""
spectreS.dcopOpts check string ""
spectreS.dcOpts homotopy string ""
spectreS.dcopOpts homotopy string ""
spectreS.dcOpts restart string ""
spectreS.dcopOpts restart string ""
spectreS.dcOpts maxiters string "150"
spectreS.dcopOpts maxiters string "150"
spectreS.dcOpts maxsteps string "10000"
spectreS.dcopOpts maxsteps string "10000"
spectreS.dcOpts annotate string "status"
spectreS.dcopOpts annotate string "status"
;spectreS noise partition variables
spectreS.noise enable toggle (nil)
spectreS.noise sweep string "Frequency"
spectreS.noise freq string ""
spectreS.noise device string ""
spectreS.noise deviceParam string ""
spectreS.noise model string ""
spectreS.noise modelParam string ""
spectreS.noise temperature string "temp"
spectreS.noise rangeType string "Start-Stop"
spectreS.noise from string ""
spectreS.noise to string ""
spectreS.noise center string ""
spectreS.noise span string ""
spectreS.noise incrType string "Automatic"
spectreS.noise stepTypeLin string "Step Size"
spectreS.noise stepTypeLog string "Points Per Decade"
spectreS.noise by string ""
spectreS.noise lin string ""
spectreS.noise dec string ""
spectreS.noise log string ""
spectreS.noise useDiscrete boolean nil
spectreS.noise values string ""
spectreS.noise outNoiseType string "voltage"
spectreS.noise negNode string "/gnd!"
spectreS.noise posNode string ""
spectreS.noise outVsrc string ""
spectreS.noise inNoiseType string "voltage"
spectreS.noise inVsrc string ""
spectreS.noise inIsrc string ""
spectreS.noise inPort string ""
;spectreS noiseOpts partition variables
spectreS.noiseOpts readns string ""
spectreS.noiseOpts oppoint string ""
spectreS.noiseOpts restart string ""
spectreS.noiseOpts annotate string "status"
spectreS.noiseOpts stats string ""
;spectreS xf partition variables
spectreS.xf enable toggle (nil)
spectreS.xf sweep string "Frequency"
spectreS.xf freq string ""
spectreS.xf device string ""
spectreS.xf deviceParam string ""
spectreS.xf model string ""
spectreS.xf modelParam string ""
spectreS.xf temperature string "temp"
spectreS.xf rangeType string "Start-Stop"
spectreS.xf from string ""
spectreS.xf to string ""
spectreS.xf center string ""
spectreS.xf span string ""
spectreS.xf incrType string "Automatic"
spectreS.xf stepTypeLin string "Step Size"
spectreS.xf stepTypeLog string "Points Per Decade"
spectreS.xf by string ""
spectreS.xf lin string ""
spectreS.xf dec string ""
spectreS.xf log string ""
spectreS.xf useDiscrete boolean nil
spectreS.xf values string ""
spectreS.xf outXfType string "voltage"
spectreS.xf negNode string "/gnd!"
spectreS.xf posNode string ""
spectreS.xf outVsrc string ""
;spectreS xfOpts partition variables
spectreS.xfOpts readns string ""
spectreS.xfOpts stimuli string ""
spectreS.xfOpts oppoint string ""
spectreS.xfOpts restart string ""
spectreS.xfOpts annotate string "status"
spectreS.xfOpts stats string ""
;spectreS sp partition variables
spectreS.sp enable toggle (nil)
spectreS.sp sweep string "Frequency"
spectreS.sp frequency string ""
spectreS.sp device string ""
spectreS.sp deviceParam string ""
spectreS.sp model string ""
spectreS.sp modelParam string ""
spectreS.sp temperature string "temp"
spectreS.sp rangeType string "Start-Stop"
spectreS.sp from string ""
spectreS.sp to string ""
spectreS.sp center string ""
spectreS.sp span string ""
spectreS.sp incrType string "Automatic"
spectreS.sp stepTypeLin string "Step Size"
spectreS.sp stepTypeLog string "Points Per Decade"
spectreS.sp by string ""
spectreS.sp lin string ""
spectreS.sp dec string ""
spectreS.sp log string ""
spectreS.sp useDiscrete boolean nil
spectreS.sp values string ""
spectreS.sp donoise boolean nil
spectreS.sp oprobe string ""
spectreS.sp iprobe string ""
;spectreS spOpts partition variables
spectreS.spOpts readns string ""
spectreS.spOpts file string ""
spectreS.spOpts oppoint string ""
spectreS.spOpts reftemp string ""
spectreS.spOpts restart string ""
spectreS.spOpts annotate string "status"
spectreS.spOpts stats string ""
;spectreS spss partition variables
spectreS.spss enable toggle (nil)
spectreS.spss paramListBox string ""
spectreS.spss fundListBox string ""
spectreS.spss stimName string ""
spectreS.spss freqName string ""
spectreS.spss freqVal string ""
spectreS.spss signalLevel string "Moderate"
spectreS.spss srcId string ""
spectreS.spss maxHarms string ""
spectreS.spss freqPeriod string "Fundamental (Beat) Frequency"
spectreS.spss fund string ""
spectreS.spss period string ""
spectreS.spss harmonics string "None"
spectreS.spss numharmonics string ""
spectreS.spss arrayharmonics string ""
spectreS.spss none string "0"
spectreS.spss selFreqFrom string ""
spectreS.spss selFreqTo string ""
spectreS.spss harmsAndFreqsTitle string ""
spectreS.spss harmsAndFreqs string ""
spectreS.spss errpreset string ""
spectreS.spss tstab string ""
spectreS.spss saveinit string ""
spectreS.spss oscana boolean nil
spectreS.spss oscRefNode string "/gnd!"
spectreS.spss oscNode string ""
spectreS.spss sweep string "frequency/period"
spectreS.spss designVar string ""
spectreS.spss rangeType string "Start-Stop"
spectreS.spss from string ""
spectreS.spss to string ""
spectreS.spss center string ""
spectreS.spss span string ""
spectreS.spss incrType string "Linear"
spectreS.spss stepTypeLin string "Step Size"
spectreS.spss stepTypeLog string "Points Per Decade"
spectreS.spss by string ""
spectreS.spss lin string ""
spectreS.spss dec string ""
spectreS.spss log string ""
spectreS.spss useDiscrete boolean nil
spectreS.spss values string ""
spectreS.spss analysisList string ""
spectreS.spss pacEnable boolean nil
spectreS.spss pacfund string ""
spectreS.spss pacRelative boolean nil
spectreS.spss pacsweeptype string ""
spectreS.spss pacharmonics string "Zero sideband only"
spectreS.spss pacnumharmonics string ""
spectreS.spss pacarrayharmonics string ""
spectreS.spss pacselFreqFrom string ""
spectreS.spss pacselFreqTo string ""
spectreS.spss pacharmsAndFreqsTitle string ""
spectreS.spss pacharmsAndFreqs string ""
spectreS.spss pnoiseEnable boolean nil
spectreS.spss pnoisefund string ""
spectreS.spss pnoiseRelative boolean nil
spectreS.spss pnoisesweeptype string ""
spectreS.spss pnoiseharmonics string "Zero sideband only"
spectreS.spss pnoisenumharmonics string ""
spectreS.spss pnoisearrayharmonics string ""
spectreS.spss pnoiseselFreqFrom string ""
spectreS.spss pnoiseselFreqTo string ""
spectreS.spss pnoiseharmsAndFreqsTitle string ""
spectreS.spss pnoiseharmsAndFreqs string ""
spectreS.spss pnoiseoutProbeType string "voltage"
spectreS.spss pnoisenegNode string "/gnd!"
spectreS.spss pnoiseposNode string ""
spectreS.spss pnoiseoutVsrc string ""
spectreS.spss pnoiseinNoiseType string "none"
spectreS.spss pnoiseinVsrc string ""
spectreS.spss pnoiseinIsrc string ""
spectreS.spss pnoiseinPort string ""
spectreS.spss pnoiserefsideband string ""
spectreS.spss pxfEnable boolean nil
spectreS.spss pxffund string ""
spectreS.spss pxfRelative boolean nil
spectreS.spss pxfsweeptype string ""
spectreS.spss pxfharmonics string "Zero sideband only"
spectreS.spss pxfnumharmonics string ""
spectreS.spss pxfarrayharmonics string ""
spectreS.spss pxfselFreqFrom string ""
spectreS.spss pxfselFreqTo string ""
spectreS.spss pxfharmsAndFreqsTitle string ""
spectreS.spss pxfharmsAndFreqs string ""
spectreS.spss pxfoutProbeType string "voltage"
spectreS.spss pxfnegNode string "/gnd!"
spectreS.spss pxfposNode string ""
spectreS.spss pxfoutVsrc string ""
;spectreS spssOpts partition variables
spectreS.spssOpts step string ""
spectreS.spssOpts maxstep string ""
spectreS.spssOpts ic string ""
spectreS.spssOpts skipdc string ""
spectreS.spssOpts readic string ""
spectreS.spssOpts readns string ""
spectreS.spssOpts cmin string ""
spectreS.spssOpts write string ""
spectreS.spssOpts writefinal string ""
spectreS.spssOpts swapfile string ""
spectreS.spssOpts method string ""
spectreS.spssOpts relref string ""
spectreS.spssOpts lteratio string ""
spectreS.spssOpts steadyratio string ""
spectreS.spssOpts maxacfreq string ""
spectreS.spssOpts maxperiods string ""
spectreS.spssOpts stats string ""
spectreS.spssOpts annotate string "status"
spectreS.spssOpts oppoint string ""
spectreS.spssOpts skipstart string ""
spectreS.spssOpts skipstop string ""
spectreS.spssOpts skipcount string ""
spectreS.spssOpts strobeperiod string ""
spectreS.spssOpts strobedelay string ""
spectreS.spssOpts compression string ""
spectreS.spssOpts maxiters string ""
spectreS.spssOpts restart string ""
spectreS.spssOpts tstart string ""
spectreS.spssOpts tolerance string ""
spectreS.spssOpts gearorder string ""
spectreS.spssOpts solver string ""
spectreS.spssOpts stats2 string ""
spectreS.spssOpts annotate2 string "status"
spectreS.spssOpts freqaxis string ""
spectreS.spssOpts tolerance2 string ""
spectreS.spssOpts gearorder2 string ""
spectreS.spssOpts solver2 string ""
spectreS.spssOpts stats3 string ""
spectreS.spssOpts annotate3 string "status"
spectreS.spssOpts stimuli string ""
spectreS.spssOpts freqaxis2 string ""
spectreS.spssOpts tolerance3 string ""
spectreS.spssOpts gearorder3 string ""
spectreS.spssOpts solver3 string ""
spectreS.spssOpts stats4 string ""
spectreS.spssOpts annotate4 string "status"
;spectreS pss partition variables
spectreS.pss enable toggle (nil)
spectreS.pss paramListBox string ""
spectreS.pss fundListBox string ""
spectreS.pss stimName string ""
spectreS.pss freqName string ""
spectreS.pss freqVal string ""
spectreS.pss signalLevel string "Moderate"
spectreS.pss srcId string ""
spectreS.pss maxHarms string ""
spectreS.pss freqPeriod string "Fundamental (Beat) Frequency"
spectreS.pss fund string ""
spectreS.pss period string ""
spectreS.pss harmonics string "None"
spectreS.pss numharmonics string ""
spectreS.pss arrayharmonics string ""
spectreS.pss none string "0"
spectreS.pss selFreqFrom string ""
spectreS.pss selFreqTo string ""
spectreS.pss harmsAndFreqsTitle string ""
spectreS.pss harmsAndFreqs string ""
spectreS.pss errpreset string ""
spectreS.pss tstab string ""
spectreS.pss saveinit string ""
spectreS.pss oscana boolean nil
spectreS.pss oscRefNode string "/gnd!"
spectreS.pss oscNode string ""
spectreS.pss analysisList string ""
spectreS.pss pacEnable boolean nil
spectreS.pss pacRelative boolean nil
spectreS.pss pacsweeptype string ""
spectreS.pss pacrangeType string "Start-Stop"
spectreS.pss pacfrom string ""
spectreS.pss pacto string ""
spectreS.pss paccenter string ""
spectreS.pss pacspan string ""
spectreS.pss pacincrType string "Automatic"
spectreS.pss pacstepTypeLin string "Step Size"
spectreS.pss pacstepTypeLog string "Points Per Decade"
spectreS.pss pacby string ""
spectreS.pss paclin string ""
spectreS.pss pacdec string ""
spectreS.pss paclog string ""
spectreS.pss pacuseDiscrete boolean nil
spectreS.pss pacvalues string ""
spectreS.pss pacharmonics string "Zero sideband only"
spectreS.pss pacnumharmonics string ""
spectreS.pss pacarrayharmonics string ""
spectreS.pss pacselFreqFrom string ""
spectreS.pss pacselFreqTo string ""
spectreS.pss pacharmsAndFreqsTitle string ""
spectreS.pss pacharmsAndFreqs string ""
spectreS.pss pnoiseEnable boolean nil
spectreS.pss pnoiseRelative boolean nil
spectreS.pss pnoisesweeptype string ""
spectreS.pss pnoiserangeType string "Start-Stop"
spectreS.pss pnoisefrom string ""
spectreS.pss pnoiseto string ""
spectreS.pss pnoisecenter string ""
spectreS.pss pnoisespan string ""
spectreS.pss pnoiseincrType string "Automatic"
spectreS.pss pnoisestepTypeLin string "Step Size"
spectreS.pss pnoisestepTypeLog string "Points Per Decade"
spectreS.pss pnoiseby string ""
spectreS.pss pnoiselin string ""
spectreS.pss pnoisedec string ""
spectreS.pss pnoiselog string ""
spectreS.pss pnoiseuseDiscrete boolean nil
spectreS.pss pnoisevalues string ""
spectreS.pss pnoiseharmonics string "Zero sideband only"
spectreS.pss pnoisenumharmonics string ""
spectreS.pss pnoisearrayharmonics string ""
spectreS.pss pnoiseselFreqFrom string ""
spectreS.pss pnoiseselFreqTo string ""
spectreS.pss pnoiseharmsAndFreqsTitle string ""
spectreS.pss pnoiseharmsAndFreqs string ""
spectreS.pss pnoiseoutProbeType string "voltage"
spectreS.pss pnoisenegNode string "/gnd!"
spectreS.pss pnoiseposNode string ""
spectreS.pss pnoiseoutVsrc string ""
spectreS.pss pnoiseinNoiseType string "none"
spectreS.pss pnoiseinVsrc string ""
spectreS.pss pnoiseinIsrc string ""
spectreS.pss pnoiseinPort string ""
spectreS.pss pnoiserefsideband string ""
spectreS.pss pxfEnable boolean nil
spectreS.pss pxfRelative boolean nil
spectreS.pss pxfsweeptype string ""
spectreS.pss pxfrangeType string "Start-Stop"
spectreS.pss pxffrom string ""
spectreS.pss pxfto string ""
spectreS.pss pxfcenter string ""
spectreS.pss pxfspan string ""
spectreS.pss pxfincrType string "Automatic"
spectreS.pss pxfstepTypeLin string "Step Size"
spectreS.pss pxfstepTypeLog string "Points Per Decade"
spectreS.pss pxfby string ""
spectreS.pss pxflin string ""
spectreS.pss pxfdec string ""
spectreS.pss pxflog string ""
spectreS.pss pxfuseDiscrete boolean nil
spectreS.pss pxfvalues string ""
spectreS.pss pxfharmonics string "Zero sideband only"
spectreS.pss pxfnumharmonics string ""
spectreS.pss pxfarrayharmonics string ""
spectreS.pss pxfselFreqFrom string ""
spectreS.pss pxfselFreqTo string ""
spectreS.pss pxfharmsAndFreqsTitle string ""
spectreS.pss pxfharmsAndFreqs string ""
spectreS.pss pxfoutProbeType string "voltage"
spectreS.pss pxfnegNode string "/gnd!"
spectreS.pss pxfposNode string ""
spectreS.pss pxfoutVsrc string ""
;spectreS pssOpts partition variables
spectreS.pssOpts step string ""
spectreS.pssOpts maxstep string ""
spectreS.pssOpts ic string ""
spectreS.pssOpts skipdc string ""
spectreS.pssOpts readic string ""
spectreS.pssOpts readns string ""
spectreS.pssOpts cmin string ""
spectreS.pssOpts write string ""
spectreS.pssOpts writefinal string ""
spectreS.pssOpts swapfile string ""
spectreS.pssOpts method string ""
spectreS.pssOpts relref string ""
spectreS.pssOpts lteratio string ""
spectreS.pssOpts steadyratio string ""
spectreS.pssOpts maxacfreq string ""
spectreS.pssOpts maxperiods string ""
spectreS.pssOpts stats string ""
spectreS.pssOpts annotate string "status"
spectreS.pssOpts oppoint string ""
spectreS.pssOpts skipstart string ""
spectreS.pssOpts skipstop string ""
spectreS.pssOpts skipcount string ""
spectreS.pssOpts strobeperiod string ""
spectreS.pssOpts strobedelay string ""
spectreS.pssOpts compression string ""
spectreS.pssOpts maxiters string ""
spectreS.pssOpts restart string ""
spectreS.pssOpts tstart string ""
spectreS.pssOpts tolerance string ""
spectreS.pssOpts gearorder string ""
spectreS.pssOpts solver string ""
spectreS.pssOpts stats2 string ""
spectreS.pssOpts annotate2 string "status"
spectreS.pssOpts freqaxis string ""
spectreS.pssOpts tolerance2 string ""
spectreS.pssOpts gearorder2 string ""
spectreS.pssOpts solver2 string ""
spectreS.pssOpts stats3 string ""
spectreS.pssOpts annotate3 string "status"
spectreS.pssOpts stimuli string ""
spectreS.pssOpts freqaxis2 string ""
spectreS.pssOpts tolerance3 string ""
spectreS.pssOpts gearorder3 string ""
spectreS.pssOpts solver3 string ""
spectreS.pssOpts stats4 string ""
spectreS.pssOpts annotate4 string "status"
;spectreS pdisto partition variables
spectreS.pdisto enable toggle (nil)
spectreS.pdisto paramListBox string ""
spectreS.pdisto fundListBox string ""
spectreS.pdisto stimName string ""
spectreS.pdisto freqName string ""
spectreS.pdisto freqVal string ""
spectreS.pdisto signalLevel string "Moderate"
spectreS.pdisto srcId string ""
spectreS.pdisto maxHarms string ""
spectreS.pdisto fundsList string ""
spectreS.pdisto maxHarmsList string ""
spectreS.pdisto errpreset string ""
spectreS.pdisto tstab string ""
spectreS.pdisto saveinit string ""
;spectreS pdistoOpts partition variables
spectreS.pdistoOpts step string ""
spectreS.pdistoOpts maxstep string ""
spectreS.pdistoOpts ic string ""
spectreS.pdistoOpts skipdc string ""
spectreS.pdistoOpts readic string ""
spectreS.pdistoOpts readns string ""
spectreS.pdistoOpts cmin string ""
spectreS.pdistoOpts tolerance string ""
spectreS.pdistoOpts gearorder string ""
spectreS.pdistoOpts solver string ""
spectreS.pdistoOpts write string ""
spectreS.pdistoOpts writefinal string ""
spectreS.pdistoOpts swapfile string ""
spectreS.pdistoOpts method string ""
spectreS.pdistoOpts relref string ""
spectreS.pdistoOpts lteratio string ""
spectreS.pdistoOpts steadyratio string ""
spectreS.pdistoOpts maxacfreq string ""
spectreS.pdistoOpts maxperiods string ""
spectreS.pdistoOpts stats string ""
spectreS.pdistoOpts annotate string "status"
spectreS.pdistoOpts oppoint string ""
spectreS.pdistoOpts skipstart string ""
spectreS.pdistoOpts skipstop string ""
spectreS.pdistoOpts skipcount string ""
spectreS.pdistoOpts strobeperiod string ""
spectreS.pdistoOpts strobedelay string ""
spectreS.pdistoOpts compression string ""
spectreS.pdistoOpts freqaxis string ""
spectreS.pdistoOpts maxiters string ""
spectreS.pdistoOpts restart string ""
spectreS.pdistoOpts tstart string ""
;spectreS spac partition variables
spectreS.spac enable toggle (nil)
spectreS.spac fund string ""
spectreS.spac Relative boolean nil
spectreS.spac sweeptype string ""
spectreS.spac harmonics string "Zero sideband only"
spectreS.spac numharmonics string ""
spectreS.spac arrayharmonics string ""
spectreS.spac selFreqFrom string ""
spectreS.spac selFreqTo string ""
spectreS.spac harmsAndFreqsTitle string ""
spectreS.spac harmsAndFreqs string ""
;spectreS spacOpts partition variables
spectreS.spacOpts tolerance string ""
spectreS.spacOpts gearorder string ""
spectreS.spacOpts solver string ""
spectreS.spacOpts stats2 string ""
spectreS.spacOpts annotate2 string "status"
spectreS.spacOpts freqaxis string ""
;spectreS spnoise partition variables
spectreS.spnoise enable toggle (nil)
spectreS.spnoise fund string ""
spectreS.spnoise Relative boolean nil
spectreS.spnoise sweeptype string ""
spectreS.spnoise harmonics string "Zero sideband only"
spectreS.spnoise numharmonics string ""
spectreS.spnoise arrayharmonics string ""
spectreS.spnoise selFreqFrom string ""
spectreS.spnoise selFreqTo string ""
spectreS.spnoise harmsAndFreqsTitle string ""
spectreS.spnoise harmsAndFreqs string ""
spectreS.spnoise outType string "voltage"
spectreS.spnoise negNode string "/gnd!"
spectreS.spnoise posNode string ""
spectreS.spnoise outVsrc string ""
spectreS.spnoise inNoiseType string "none"
spectreS.spnoise inVsrc string ""
spectreS.spnoise inIsrc string ""
spectreS.spnoise inPort string ""
spectreS.spnoise refsideband string ""
;spectreS spnoiseOpts partition variables
spectreS.spnoiseOpts tolerance3 string ""
spectreS.spnoiseOpts gearorder3 string ""
spectreS.spnoiseOpts solver3 string ""
spectreS.spnoiseOpts stats4 string ""
spectreS.spnoiseOpts annotate4 string "status"
;spectreS spxf partition variables
spectreS.spxf enable toggle (nil)
spectreS.spxf fund string ""
spectreS.spxf Relative boolean nil
spectreS.spxf sweeptype string ""
spectreS.spxf harmonics string "Zero sideband only"
spectreS.spxf numharmonics string ""
spectreS.spxf arrayharmonics string ""
spectreS.spxf selFreqFrom string ""
spectreS.spxf selFreqTo string ""
spectreS.spxf harmsAndFreqsTitle string ""
spectreS.spxf harmsAndFreqs string ""
spectreS.spxf outType string "voltage"
spectreS.spxf negNode string "/gnd!"
spectreS.spxf posNode string ""
spectreS.spxf outVsrc string ""
;spectreS spxfOpts partition variables
spectreS.spxfOpts tolerance2 string ""
spectreS.spxfOpts gearorder2 string ""
spectreS.spxfOpts solver2 string ""
spectreS.spxfOpts stats3 string ""
spectreS.spxfOpts annotate3 string "status"
spectreS.spxfOpts stimuli string ""
spectreS.spxfOpts freqaxis2 string ""
;spectreS pac partition variables
spectreS.pac enable toggle (nil)
spectreS.pac fund string ""
spectreS.pac Relative boolean nil
spectreS.pac sweeptype string ""
spectreS.pac rangeType string "Start-Stop"
spectreS.pac from string ""
spectreS.pac to string ""
spectreS.pac center string ""
spectreS.pac span string ""
spectreS.pac incrType string "Automatic"
spectreS.pac stepTypeLin string "Step Size"
spectreS.pac stepTypeLog string "Points Per Decade"
spectreS.pac by string ""
spectreS.pac lin string ""
spectreS.pac dec string ""
spectreS.pac log string ""
spectreS.pac useDiscrete boolean nil
spectreS.pac values string ""
spectreS.pac harmonics string "Zero sideband only"
spectreS.pac numharmonics string ""
spectreS.pac arrayharmonics string ""
spectreS.pac selFreqFrom string ""
spectreS.pac selFreqTo string ""
spectreS.pac harmsAndFreqsTitle string ""
spectreS.pac harmsAndFreqs string ""
;spectreS pacOpts partition variables
spectreS.pacOpts tolerance string ""
spectreS.pacOpts gearorder string ""
spectreS.pacOpts solver string ""
spectreS.pacOpts stats2 string ""
spectreS.pacOpts annotate2 string "status"
spectreS.pacOpts freqaxis string ""
;spectreS pnoise partition variables
spectreS.pnoise enable toggle (nil)
spectreS.pnoise fund string ""
spectreS.pnoise Relative boolean nil
spectreS.pnoise sweeptype string ""
spectreS.pnoise rangeType string "Start-Stop"
spectreS.pnoise from string ""
spectreS.pnoise to string ""
spectreS.pnoise center string ""
spectreS.pnoise span string ""
spectreS.pnoise incrType string "Automatic"
spectreS.pnoise stepTypeLin string "Step Size"
spectreS.pnoise stepTypeLog string "Points Per Decade"
spectreS.pnoise by string ""
spectreS.pnoise lin string ""
spectreS.pnoise dec string ""
spectreS.pnoise log string ""
spectreS.pnoise useDiscrete boolean nil
spectreS.pnoise values string ""
spectreS.pnoise harmonics string "Zero sideband only"
spectreS.pnoise numharmonics string ""
spectreS.pnoise arrayharmonics string ""
spectreS.pnoise selFreqFrom string ""
spectreS.pnoise selFreqTo string ""
spectreS.pnoise harmsAndFreqsTitle string ""
spectreS.pnoise harmsAndFreqs string ""
spectreS.pnoise outType string "voltage"
spectreS.pnoise negNode string "/gnd!"
spectreS.pnoise posNode string ""
spectreS.pnoise outVsrc string ""
spectreS.pnoise inNoiseType string "none"
spectreS.pnoise inVsrc string ""
spectreS.pnoise inIsrc string ""
spectreS.pnoise inPort string ""
spectreS.pnoise refsideband string ""
;spectreS pnoiseOpts partition variables
spectreS.pnoiseOpts tolerance3 string ""
spectreS.pnoiseOpts gearorder3 string ""
spectreS.pnoiseOpts solver3 string ""
spectreS.pnoiseOpts stats4 string ""
spectreS.pnoiseOpts annotate4 string "status"
;spectreS pxf partition variables
spectreS.pxf enable toggle (nil)
spectreS.pxf fund string ""
spectreS.pxf Relative boolean nil
spectreS.pxf sweeptype string ""
spectreS.pxf rangeType string "Start-Stop"
spectreS.pxf from string ""
spectreS.pxf to string ""
spectreS.pxf center string ""
spectreS.pxf span string ""
spectreS.pxf incrType string "Automatic"
spectreS.pxf stepTypeLin string "Step Size"
spectreS.pxf stepTypeLog string "Points Per Decade"
spectreS.pxf by string ""
spectreS.pxf lin string ""
spectreS.pxf dec string ""
spectreS.pxf log string ""
spectreS.pxf useDiscrete boolean nil
spectreS.pxf values string ""
spectreS.pxf harmonics string "Zero sideband only"
spectreS.pxf numharmonics string ""
spectreS.pxf arrayharmonics string ""
spectreS.pxf selFreqFrom string ""
spectreS.pxf selFreqTo string ""
spectreS.pxf harmsAndFreqsTitle string ""
spectreS.pxf harmsAndFreqs string ""
spectreS.pxf outType string "voltage"
spectreS.pxf negNode string "/gnd!"
spectreS.pxf posNode string ""
spectreS.pxf outVsrc string ""
;spectreS pxfOpts partition variables
spectreS.pxfOpts tolerance2 string ""
spectreS.pxfOpts gearorder2 string ""
spectreS.pxfOpts solver2 string ""
spectreS.pxfOpts stats3 string ""
spectreS.pxfOpts annotate3 string "status"
spectreS.pxfOpts stimuli string ""
spectreS.pxfOpts freqaxis2 string ""
;spectreSVerilog environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spectreSVerilog opts partition variables
spectreSVerilog.opts title string ""
spectreSVerilog.opts audit string ""
spectreSVerilog.opts ckptclock string "1800"
spectreSVerilog.opts flow string ""
spectreSVerilog.opts cols string "80"
spectreSVerilog.opts opptcheck string ""
spectreSVerilog.opts reltol string "1e-3"
spectreSVerilog.opts notation string ""
spectreSVerilog.opts warn string ""
spectreSVerilog.opts approx string ""
spectreSVerilog.opts info string ""
spectreSVerilog.opts quantities string ""
spectreSVerilog.opts pivabs string ""
spectreSVerilog.opts compatible string ""
spectreSVerilog.opts ignshorts string ""
spectreSVerilog.opts gmin string "1e-12"
spectreSVerilog.opts rforce string "1"
spectreSVerilog.opts homotopy string ""
spectreSVerilog.opts iabstol string "1e-12"
spectreSVerilog.opts debug string ""
spectreSVerilog.opts tempeffects string ""
spectreSVerilog.opts maxwarns string "5"
spectreSVerilog.opts vabstol string "1e-6"
spectreSVerilog.opts tnom string "27"
spectreSVerilog.opts temp string "27"
spectreSVerilog.opts gmin_check string ""
spectreSVerilog.opts value string ""
spectreSVerilog.opts narrate string ""
spectreSVerilog.opts scale string "1.0"
spectreSVerilog.opts diagnose string ""
spectreSVerilog.opts digits string "5"
spectreSVerilog.opts pivotdc string ""
spectreSVerilog.opts pivrel string "1e-3"
spectreSVerilog.opts scalem string "1.0"
spectreSVerilog.opts limit string ""
spectreSVerilog.opts topcheck string ""
spectreSVerilog.opts inventory string ""
spectreSVerilog.opts error string ""
;spectreSVerilog outputs partition variables
spectreSVerilog.outputs allAnalogACTC boolean nil
spectreSVerilog.outputs allDigitalNV boolean t
spectreSVerilog.outputs allAnalogNV boolean t
spectreSVerilog.outputs allAhdlVars boolean nil
spectreSVerilog.outputs allAnalogTC boolean nil
;spectreSVerilog verimixOpts partition variables
spectreSVerilog.verimixOpts filename6 string ""
spectreSVerilog.verimixOpts maxDCIter int 0
spectreSVerilog.verimixOpts scope1 string ""
spectreSVerilog.verimixOpts scope10 string ""
spectreSVerilog.verimixOpts filename8 string ""
spectreSVerilog.verimixOpts dcInterval float 0.0
spectreSVerilog.verimixOpts scope3 string ""
spectreSVerilog.verimixOpts scope8 string ""
spectreSVerilog.verimixOpts scope7 string ""
spectreSVerilog.verimixOpts filename7 string ""
spectreSVerilog.verimixOpts scope string ""
spectreSVerilog.verimixOpts filename4 string ""
spectreSVerilog.verimixOpts filename string ""
spectreSVerilog.verimixOpts filename1 string ""
spectreSVerilog.verimixOpts scope9 string ""
spectreSVerilog.verimixOpts importsdfswitch boolean nil
spectreSVerilog.verimixOpts filename2 string ""
spectreSVerilog.verimixOpts numberofsdffiles int 2
spectreSVerilog.verimixOpts scope2 string ""
spectreSVerilog.verimixOpts scope6 string ""
spectreSVerilog.verimixOpts filename10 string ""
spectreSVerilog.verimixOpts delaymodechoice string "Ignore"
spectreSVerilog.verimixOpts sdfmixedswitch boolean t
spectreSVerilog.verimixOpts filename9 string ""
spectreSVerilog.verimixOpts scope5 string ""
spectreSVerilog.verimixOpts filename5 string ""
spectreSVerilog.verimixOpts filename3 string ""
spectreSVerilog.verimixOpts scope4 string ""
;spectreSVerilog verilogOpts partition variables
spectreSVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
spectreSVerilog.verilogOpts optionsFile string ""
spectreSVerilog.verilogOpts twinTurbo boolean nil
spectreSVerilog.verilogOpts suppressMessages boolean nil
spectreSVerilog.verilogOpts libraryFile string ""
spectreSVerilog.verilogOpts behaveProfile boolean nil
spectreSVerilog.verilogOpts verimixLog string "verilog.log"
spectreSVerilog.verilogOpts simVision boolean nil
spectreSVerilog.verilogOpts pulseSpec boolean nil
spectreSVerilog.verilogOpts commandFile string ""
spectreSVerilog.verilogOpts pulseError int 100
spectreSVerilog.verilogOpts stopCompile boolean nil
spectreSVerilog.verilogOpts keepNodes string "Minimum"
spectreSVerilog.verilogOpts accelerationCA boolean nil
spectreSVerilog.verilogOpts turboRadio string "Default"
spectreSVerilog.verilogOpts libraryDir string ""
spectreSVerilog.verilogOpts suppressWarnings boolean nil
spectreSVerilog.verilogOpts accelerationSwitches boolean nil
spectreSVerilog.verilogOpts accelerationNormal boolean t
spectreSVerilog.verilogOpts delayType string "Typical"
spectreSVerilog.verilogOpts pulseReject int 100
spectreSVerilog.verilogOpts delayMode string "Default"
spectreSVerilog.verilogOpts vermixBinary string "verilog.vmx"
;spectreSVerilog init partition variables
spectreSVerilog.init processPriority int 0
;spectreSVerilog envOpts partition variables
spectreSVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreSVerilog.envOpts mspNetlistMode string "Flat"
spectreSVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistMakePrimHNL boolean nil
spectreSVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
spectreSVerilog.envOpts outputFormat string "AWD"
spectreSVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
spectreSVerilog.envOpts mspSetupNetlistEscapeName boolean nil
spectreSVerilog.envOpts updateFile string ""
spectreSVerilog.envOpts stimulusFile string ""
spectreSVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
spectreSVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
spectreSVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
spectreSVerilog.envOpts includeSyntax string "cdsSpice"
spectreSVerilog.envOpts mspSetupNetlistPinMap boolean nil
spectreSVerilog.envOpts mspSetupNetlistBus boolean t
spectreSVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
spectreSVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
spectreSVerilog.envOpts mspSetupFNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! vssa! veed!"
spectreSVerilog.envOpts mspSetupNetlistExplicit boolean nil
spectreSVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistSwitchRC boolean nil
spectreSVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
spectreSVerilog.envOpts paramRangeCheckFile string ""
spectreSVerilog.envOpts initFile string ""
spectreSVerilog.envOpts printComments boolean nil
spectreSVerilog.envOpts includeFile string ""
spectreSVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
spectreSVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
spectreSVerilog.envOpts recover boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreSVerilog.envOpts mspSetupFNLNetlistExplicit boolean nil
spectreSVerilog.envOpts mspSetupNetlistSimTimeValue int 1
spectreSVerilog.envOpts mspSetupNetlistUseLib boolean nil
spectreSVerilog.envOpts mspSetupFNLNetlistProcessNullPort boolean nil
spectreSVerilog.envOpts mspSetupNetlistNullPort boolean nil
spectreSVerilog.envOpts mspSetupNetlistDropPortRange boolean t
spectreSVerilog.envOpts mspSetupNetlistUpCase boolean nil
spectreSVerilog.envOpts generateMapFile boolean nil
spectreSVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;spectreSVerilog tran partition variables
spectreSVerilog.tran enable toggle (nil)
spectreSVerilog.tran to string ""
spectreSVerilog.tran errpreset string ""
;spectreSVerilog tranOpts partition variables
spectreSVerilog.tranOpts start string ""
spectreSVerilog.tranOpts outputstart string ""
spectreSVerilog.tranOpts step string ""
spectreSVerilog.tranOpts maxstep string ""
spectreSVerilog.tranOpts ic string ""
spectreSVerilog.tranOpts skipdc string ""
spectreSVerilog.tranOpts readic string ""
spectreSVerilog.tranOpts readns string ""
spectreSVerilog.tranOpts cmin string ""
spectreSVerilog.tranOpts write string "spectre.ic"
spectreSVerilog.tranOpts writefinal string "spectre.fc"
spectreSVerilog.tranOpts ckptperiod string ""
spectreSVerilog.tranOpts method string "default"
spectreSVerilog.tranOpts relref string "default"
spectreSVerilog.tranOpts lteratio string ""
spectreSVerilog.tranOpts stats string ""
spectreSVerilog.tranOpts annotate string "status"
spectreSVerilog.tranOpts oppoint string ""
spectreSVerilog.tranOpts skipstart string ""
spectreSVerilog.tranOpts skipstop string ""
spectreSVerilog.tranOpts skipcount string ""
spectreSVerilog.tranOpts strobeperiod string ""
spectreSVerilog.tranOpts strobedelay string ""
spectreSVerilog.tranOpts compression string "no"
spectreSVerilog.tranOpts maxiters string "5"
spectreSVerilog.tranOpts restart string ""
;spectreSVerilog ac partition variables
spectreSVerilog.ac enable toggle (nil)
spectreSVerilog.ac sweep string "Frequency"
spectreSVerilog.ac freq string ""
spectreSVerilog.ac device string ""
spectreSVerilog.ac deviceParam string ""
spectreSVerilog.ac model string ""
spectreSVerilog.ac modelParam string ""
spectreSVerilog.ac temperature string "temp"
spectreSVerilog.ac rangeType string "Start-Stop"
spectreSVerilog.ac from string ""
spectreSVerilog.ac to string ""
spectreSVerilog.ac center string ""
spectreSVerilog.ac span string ""
spectreSVerilog.ac incrType string "Automatic"
spectreSVerilog.ac stepTypeLin string "Step Size"
spectreSVerilog.ac stepTypeLog string "Points Per Decade"
spectreSVerilog.ac by string ""
spectreSVerilog.ac lin string ""
spectreSVerilog.ac dec string ""
spectreSVerilog.ac log string ""
spectreSVerilog.ac useDiscrete boolean nil
spectreSVerilog.ac values string ""
;spectreSVerilog acOpts partition variables
spectreSVerilog.acOpts readns string ""
spectreSVerilog.acOpts oppoint string ""
spectreSVerilog.acOpts restart string ""
spectreSVerilog.acOpts annotate string "status"
spectreSVerilog.acOpts stats string ""
;spectreSVerilog dc partition variables
spectreSVerilog.dc enable toggle (nil)
spectreSVerilog.dcop enable toggle (nil)
spectreSVerilog.dc saveOppoint boolean nil
spectreSVerilog.dc oppoint string "rawfile"
spectreSVerilog.dc save string "allpub"
spectreSVerilog.dc sweep string ""
spectreSVerilog.dc device string ""
spectreSVerilog.dc deviceParam string ""
spectreSVerilog.dc model string ""
spectreSVerilog.dc modelParam string ""
spectreSVerilog.dc temperature string "temp"
spectreSVerilog.dc rangeType string "Start-Stop"
spectreSVerilog.dc from string ""
spectreSVerilog.dc to string ""
spectreSVerilog.dc center string ""
spectreSVerilog.dc span string ""
spectreSVerilog.dc incrType string "Automatic"
spectreSVerilog.dc stepTypeLin string "Step Size"
spectreSVerilog.dc stepTypeLog string "Points Per Decade"
spectreSVerilog.dc by string ""
spectreSVerilog.dc lin string ""
spectreSVerilog.dc dec string ""
spectreSVerilog.dc log string ""
spectreSVerilog.dc useDiscrete boolean nil
spectreSVerilog.dc values string ""
;spectreSVerilog dcOpts partition variables
spectreSVerilog.dcOpts force string ""
spectreSVerilog.dcopOpts force string ""
spectreSVerilog.dcOpts readns string ""
spectreSVerilog.dcopOpts readns string ""
spectreSVerilog.dcOpts readforce string ""
spectreSVerilog.dcopOpts readforce string ""
spectreSVerilog.dcOpts write string "spectre.dc"
spectreSVerilog.dcopOpts write string "spectre.dc"
spectreSVerilog.dcOpts writefinal string ""
spectreSVerilog.dcopOpts writefinal string ""
spectreSVerilog.dcOpts print string ""
spectreSVerilog.dcopOpts print string ""
spectreSVerilog.dcOpts check string ""
spectreSVerilog.dcopOpts check string ""
spectreSVerilog.dcOpts homotopy string ""
spectreSVerilog.dcopOpts homotopy string ""
spectreSVerilog.dcOpts restart string ""
spectreSVerilog.dcopOpts restart string ""
spectreSVerilog.dcOpts maxiters string "150"
spectreSVerilog.dcopOpts maxiters string "150"
spectreSVerilog.dcOpts maxsteps string "10000"
spectreSVerilog.dcopOpts maxsteps string "10000"
spectreSVerilog.dcOpts annotate string "status"
spectreSVerilog.dcopOpts annotate string "status"
;spectreSVerilog noise partition variables
spectreSVerilog.noise enable toggle (nil)
spectreSVerilog.noise sweep string "Frequency"
spectreSVerilog.noise freq string ""
spectreSVerilog.noise device string ""
spectreSVerilog.noise deviceParam string ""
spectreSVerilog.noise model string ""
spectreSVerilog.noise modelParam string ""
spectreSVerilog.noise temperature string "temp"
spectreSVerilog.noise rangeType string "Start-Stop"
spectreSVerilog.noise from string ""
spectreSVerilog.noise to string ""
spectreSVerilog.noise center string ""
spectreSVerilog.noise span string ""
spectreSVerilog.noise incrType string "Automatic"
spectreSVerilog.noise stepTypeLin string "Step Size"
spectreSVerilog.noise stepTypeLog string "Points Per Decade"
spectreSVerilog.noise by string ""
spectreSVerilog.noise lin string ""
spectreSVerilog.noise dec string ""
spectreSVerilog.noise log string ""
spectreSVerilog.noise useDiscrete boolean nil
spectreSVerilog.noise values string ""
spectreSVerilog.noise outNoiseType string "voltage"
spectreSVerilog.noise negNode string "/gnd!"
spectreSVerilog.noise posNode string ""
spectreSVerilog.noise outVsrc string ""
spectreSVerilog.noise inNoiseType string "voltage"
spectreSVerilog.noise inVsrc string ""
spectreSVerilog.noise inIsrc string ""
spectreSVerilog.noise inPort string ""
;spectreSVerilog noiseOpts partition variables
spectreSVerilog.noiseOpts readns string ""
spectreSVerilog.noiseOpts oppoint string ""
spectreSVerilog.noiseOpts restart string ""
spectreSVerilog.noiseOpts annotate string "status"
spectreSVerilog.noiseOpts stats string ""
;spectreSVerilog xf partition variables
spectreSVerilog.xf enable toggle (nil)
spectreSVerilog.xf sweep string "Frequency"
spectreSVerilog.xf freq string ""
spectreSVerilog.xf device string ""
spectreSVerilog.xf deviceParam string ""
spectreSVerilog.xf model string ""
spectreSVerilog.xf modelParam string ""
spectreSVerilog.xf temperature string "temp"
spectreSVerilog.xf rangeType string "Start-Stop"
spectreSVerilog.xf from string ""
spectreSVerilog.xf to string ""
spectreSVerilog.xf center string ""
spectreSVerilog.xf span string ""
spectreSVerilog.xf incrType string "Automatic"
spectreSVerilog.xf stepTypeLin string "Step Size"
spectreSVerilog.xf stepTypeLog string "Points Per Decade"
spectreSVerilog.xf by string ""
spectreSVerilog.xf lin string ""
spectreSVerilog.xf dec string ""
spectreSVerilog.xf log string ""
spectreSVerilog.xf useDiscrete boolean nil
spectreSVerilog.xf values string ""
spectreSVerilog.xf outXfType string "voltage"
spectreSVerilog.xf negNode string "/gnd!"
spectreSVerilog.xf posNode string ""
spectreSVerilog.xf outVsrc string ""
;spectreSVerilog xfOpts partition variables
spectreSVerilog.xfOpts readns string ""
spectreSVerilog.xfOpts stimuli string ""
spectreSVerilog.xfOpts oppoint string ""
spectreSVerilog.xfOpts restart string ""
spectreSVerilog.xfOpts annotate string "status"
spectreSVerilog.xfOpts stats string ""
;spectreSVerilog sp partition variables
spectreSVerilog.sp enable toggle (nil)
spectreSVerilog.sp sweep string "Frequency"
spectreSVerilog.sp frequency string ""
spectreSVerilog.sp device string ""
spectreSVerilog.sp deviceParam string ""
spectreSVerilog.sp model string ""
spectreSVerilog.sp modelParam string ""
spectreSVerilog.sp temperature string "temp"
spectreSVerilog.sp rangeType string "Start-Stop"
spectreSVerilog.sp from string ""
spectreSVerilog.sp to string ""
spectreSVerilog.sp center string ""
spectreSVerilog.sp span string ""
spectreSVerilog.sp incrType string "Automatic"
spectreSVerilog.sp stepTypeLin string "Step Size"
spectreSVerilog.sp stepTypeLog string "Points Per Decade"
spectreSVerilog.sp by string ""
spectreSVerilog.sp lin string ""
spectreSVerilog.sp dec string ""
spectreSVerilog.sp log string ""
spectreSVerilog.sp useDiscrete boolean nil
spectreSVerilog.sp values string ""
spectreSVerilog.sp donoise boolean nil
spectreSVerilog.sp oprobe string ""
spectreSVerilog.sp iprobe string ""
;spectreSVerilog spOpts partition variables
spectreSVerilog.spOpts readns string ""
spectreSVerilog.spOpts file string ""
spectreSVerilog.spOpts oppoint string ""
spectreSVerilog.spOpts reftemp string ""
spectreSVerilog.spOpts restart string ""
spectreSVerilog.spOpts annotate string "status"
spectreSVerilog.spOpts stats string ""
;spectreSVerilog spss partition variables
spectreSVerilog.spss enable toggle (nil)
spectreSVerilog.spss paramListBox string ""
spectreSVerilog.spss fundListBox string ""
spectreSVerilog.spss stimName string ""
spectreSVerilog.spss freqName string ""
spectreSVerilog.spss freqVal string ""
spectreSVerilog.spss signalLevel string "Moderate"
spectreSVerilog.spss srcId string ""
spectreSVerilog.spss maxHarms string ""
spectreSVerilog.spss freqPeriod string "Fundamental (Beat) Frequency"
spectreSVerilog.spss fund string ""
spectreSVerilog.spss period string ""
spectreSVerilog.spss harmonics string "None"
spectreSVerilog.spss numharmonics string ""
spectreSVerilog.spss arrayharmonics string ""
spectreSVerilog.spss none string "0"
spectreSVerilog.spss selFreqFrom string ""
spectreSVerilog.spss selFreqTo string ""
spectreSVerilog.spss harmsAndFreqsTitle string ""
spectreSVerilog.spss harmsAndFreqs string ""
spectreSVerilog.spss errpreset string ""
spectreSVerilog.spss tstab string ""
spectreSVerilog.spss saveinit string ""
spectreSVerilog.spss oscana boolean nil
spectreSVerilog.spss oscRefNode string "/gnd!"
spectreSVerilog.spss oscNode string ""
spectreSVerilog.spss sweep string "frequency/period"
spectreSVerilog.spss designVar string ""
spectreSVerilog.spss rangeType string "Start-Stop"
spectreSVerilog.spss from string ""
spectreSVerilog.spss to string ""
spectreSVerilog.spss center string ""
spectreSVerilog.spss span string ""
spectreSVerilog.spss incrType string "Linear"
spectreSVerilog.spss stepTypeLin string "Step Size"
spectreSVerilog.spss stepTypeLog string "Points Per Decade"
spectreSVerilog.spss by string ""
spectreSVerilog.spss lin string ""
spectreSVerilog.spss dec string ""
spectreSVerilog.spss log string ""
spectreSVerilog.spss useDiscrete boolean nil
spectreSVerilog.spss values string ""
spectreSVerilog.spss analysisList string ""
spectreSVerilog.spss pacEnable boolean nil
spectreSVerilog.spss pacfund string ""
spectreSVerilog.spss pacRelative boolean nil
spectreSVerilog.spss pacsweeptype string ""
spectreSVerilog.spss pacharmonics string "Zero sideband only"
spectreSVerilog.spss pacnumharmonics string ""
spectreSVerilog.spss pacarrayharmonics string ""
spectreSVerilog.spss pacselFreqFrom string ""
spectreSVerilog.spss pacselFreqTo string ""
spectreSVerilog.spss pacharmsAndFreqsTitle string ""
spectreSVerilog.spss pacharmsAndFreqs string ""
spectreSVerilog.spss pnoiseEnable boolean nil
spectreSVerilog.spss pnoisefund string ""
spectreSVerilog.spss pnoiseRelative boolean nil
spectreSVerilog.spss pnoisesweeptype string ""
spectreSVerilog.spss pnoiseharmonics string "Zero sideband only"
spectreSVerilog.spss pnoisenumharmonics string ""
spectreSVerilog.spss pnoisearrayharmonics string ""
spectreSVerilog.spss pnoiseselFreqFrom string ""
spectreSVerilog.spss pnoiseselFreqTo string ""
spectreSVerilog.spss pnoiseharmsAndFreqsTitle string ""
spectreSVerilog.spss pnoiseharmsAndFreqs string ""
spectreSVerilog.spss pnoiseoutProbeType string "voltage"
spectreSVerilog.spss pnoisenegNode string "/gnd!"
spectreSVerilog.spss pnoiseposNode string ""
spectreSVerilog.spss pnoiseoutVsrc string ""
spectreSVerilog.spss pnoiseinNoiseType string "none"
spectreSVerilog.spss pnoiseinVsrc string ""
spectreSVerilog.spss pnoiseinIsrc string ""
spectreSVerilog.spss pnoiseinPort string ""
spectreSVerilog.spss pnoiserefsideband string ""
spectreSVerilog.spss pxfEnable boolean nil
spectreSVerilog.spss pxffund string ""
spectreSVerilog.spss pxfRelative boolean nil
spectreSVerilog.spss pxfsweeptype string ""
spectreSVerilog.spss pxfharmonics string "Zero sideband only"
spectreSVerilog.spss pxfnumharmonics string ""
spectreSVerilog.spss pxfarrayharmonics string ""
spectreSVerilog.spss pxfselFreqFrom string ""
spectreSVerilog.spss pxfselFreqTo string ""
spectreSVerilog.spss pxfharmsAndFreqsTitle string ""
spectreSVerilog.spss pxfharmsAndFreqs string ""
spectreSVerilog.spss pxfoutProbeType string "voltage"
spectreSVerilog.spss pxfnegNode string "/gnd!"
spectreSVerilog.spss pxfposNode string ""
spectreSVerilog.spss pxfoutVsrc string ""
;spectreSVerilog spssOpts partition variables
spectreSVerilog.spssOpts step string ""
spectreSVerilog.spssOpts maxstep string ""
spectreSVerilog.spssOpts ic string ""
spectreSVerilog.spssOpts skipdc string ""
spectreSVerilog.spssOpts readic string ""
spectreSVerilog.spssOpts readns string ""
spectreSVerilog.spssOpts cmin string ""
spectreSVerilog.spssOpts write string ""
spectreSVerilog.spssOpts writefinal string ""
spectreSVerilog.spssOpts swapfile string ""
spectreSVerilog.spssOpts method string ""
spectreSVerilog.spssOpts relref string ""
spectreSVerilog.spssOpts lteratio string ""
spectreSVerilog.spssOpts steadyratio string ""
spectreSVerilog.spssOpts maxacfreq string ""
spectreSVerilog.spssOpts maxperiods string ""
spectreSVerilog.spssOpts stats string ""
spectreSVerilog.spssOpts annotate string "status"
spectreSVerilog.spssOpts oppoint string ""
spectreSVerilog.spssOpts skipstart string ""
spectreSVerilog.spssOpts skipstop string ""
spectreSVerilog.spssOpts skipcount string ""
spectreSVerilog.spssOpts strobeperiod string ""
spectreSVerilog.spssOpts strobedelay string ""
spectreSVerilog.spssOpts compression string ""
spectreSVerilog.spssOpts maxiters string ""
spectreSVerilog.spssOpts restart string ""
spectreSVerilog.spssOpts tstart string ""
spectreSVerilog.spssOpts tolerance string ""
spectreSVerilog.spssOpts gearorder string ""
spectreSVerilog.spssOpts solver string ""
spectreSVerilog.spssOpts stats2 string ""
spectreSVerilog.spssOpts annotate2 string "status"
spectreSVerilog.spssOpts freqaxis string ""
spectreSVerilog.spssOpts tolerance2 string ""
spectreSVerilog.spssOpts gearorder2 string ""
spectreSVerilog.spssOpts solver2 string ""
spectreSVerilog.spssOpts stats3 string ""
spectreSVerilog.spssOpts annotate3 string "status"
spectreSVerilog.spssOpts stimuli string ""
spectreSVerilog.spssOpts freqaxis2 string ""
spectreSVerilog.spssOpts tolerance3 string ""
spectreSVerilog.spssOpts gearorder3 string ""
spectreSVerilog.spssOpts solver3 string ""
spectreSVerilog.spssOpts stats4 string ""
spectreSVerilog.spssOpts annotate4 string "status"
;spectreSVerilog pss partition variables
spectreSVerilog.pss enable toggle (nil)
spectreSVerilog.pss paramListBox string ""
spectreSVerilog.pss fundListBox string ""
spectreSVerilog.pss stimName string ""
spectreSVerilog.pss freqName string ""
spectreSVerilog.pss freqVal string ""
spectreSVerilog.pss signalLevel string "Moderate"
spectreSVerilog.pss srcId string ""
spectreSVerilog.pss maxHarms string ""
spectreSVerilog.pss freqPeriod string "Fundamental (Beat) Frequency"
spectreSVerilog.pss fund string ""
spectreSVerilog.pss period string ""
spectreSVerilog.pss harmonics string "None"
spectreSVerilog.pss numharmonics string ""
spectreSVerilog.pss arrayharmonics string ""
spectreSVerilog.pss none string "0"
spectreSVerilog.pss selFreqFrom string ""
spectreSVerilog.pss selFreqTo string ""
spectreSVerilog.pss harmsAndFreqsTitle string ""
spectreSVerilog.pss harmsAndFreqs string ""
spectreSVerilog.pss errpreset string ""
spectreSVerilog.pss tstab string ""
spectreSVerilog.pss saveinit string ""
spectreSVerilog.pss oscana boolean nil
spectreSVerilog.pss oscRefNode string "/gnd!"
spectreSVerilog.pss oscNode string ""
spectreSVerilog.pss analysisList string ""
spectreSVerilog.pss pacEnable boolean nil
spectreSVerilog.pss pacRelative boolean nil
spectreSVerilog.pss pacsweeptype string ""
spectreSVerilog.pss pacrangeType string "Start-Stop"
spectreSVerilog.pss pacfrom string ""
spectreSVerilog.pss pacto string ""
spectreSVerilog.pss paccenter string ""
spectreSVerilog.pss pacspan string ""
spectreSVerilog.pss pacincrType string "Automatic"
spectreSVerilog.pss pacstepTypeLin string "Step Size"
spectreSVerilog.pss pacstepTypeLog string "Points Per Decade"
spectreSVerilog.pss pacby string ""
spectreSVerilog.pss paclin string ""
spectreSVerilog.pss pacdec string ""
spectreSVerilog.pss paclog string ""
spectreSVerilog.pss pacuseDiscrete boolean nil
spectreSVerilog.pss pacvalues string ""
spectreSVerilog.pss pacharmonics string "Zero sideband only"
spectreSVerilog.pss pacnumharmonics string ""
spectreSVerilog.pss pacarrayharmonics string ""
spectreSVerilog.pss pacselFreqFrom string ""
spectreSVerilog.pss pacselFreqTo string ""
spectreSVerilog.pss pacharmsAndFreqsTitle string ""
spectreSVerilog.pss pacharmsAndFreqs string ""
spectreSVerilog.pss pnoiseEnable boolean nil
spectreSVerilog.pss pnoiseRelative boolean nil
spectreSVerilog.pss pnoisesweeptype string ""
spectreSVerilog.pss pnoiserangeType string "Start-Stop"
spectreSVerilog.pss pnoisefrom string ""
spectreSVerilog.pss pnoiseto string ""
spectreSVerilog.pss pnoisecenter string ""
spectreSVerilog.pss pnoisespan string ""
spectreSVerilog.pss pnoiseincrType string "Automatic"
spectreSVerilog.pss pnoisestepTypeLin string "Step Size"
spectreSVerilog.pss pnoisestepTypeLog string "Points Per Decade"
spectreSVerilog.pss pnoiseby string ""
spectreSVerilog.pss pnoiselin string ""
spectreSVerilog.pss pnoisedec string ""
spectreSVerilog.pss pnoiselog string ""
spectreSVerilog.pss pnoiseuseDiscrete boolean nil
spectreSVerilog.pss pnoisevalues string ""
spectreSVerilog.pss pnoiseharmonics string "Zero sideband only"
spectreSVerilog.pss pnoisenumharmonics string ""
spectreSVerilog.pss pnoisearrayharmonics string ""
spectreSVerilog.pss pnoiseselFreqFrom string ""
spectreSVerilog.pss pnoiseselFreqTo string ""
spectreSVerilog.pss pnoiseharmsAndFreqsTitle string ""
spectreSVerilog.pss pnoiseharmsAndFreqs string ""
spectreSVerilog.pss pnoiseoutProbeType string "voltage"
spectreSVerilog.pss pnoisenegNode string "/gnd!"
spectreSVerilog.pss pnoiseposNode string ""
spectreSVerilog.pss pnoiseoutVsrc string ""
spectreSVerilog.pss pnoiseinNoiseType string "none"
spectreSVerilog.pss pnoiseinVsrc string ""
spectreSVerilog.pss pnoiseinIsrc string ""
spectreSVerilog.pss pnoiseinPort string ""
spectreSVerilog.pss pnoiserefsideband string ""
spectreSVerilog.pss pxfEnable boolean nil
spectreSVerilog.pss pxfRelative boolean nil
spectreSVerilog.pss pxfsweeptype string ""
spectreSVerilog.pss pxfrangeType string "Start-Stop"
spectreSVerilog.pss pxffrom string ""
spectreSVerilog.pss pxfto string ""
spectreSVerilog.pss pxfcenter string ""
spectreSVerilog.pss pxfspan string ""
spectreSVerilog.pss pxfincrType string "Automatic"
spectreSVerilog.pss pxfstepTypeLin string "Step Size"
spectreSVerilog.pss pxfstepTypeLog string "Points Per Decade"
spectreSVerilog.pss pxfby string ""
spectreSVerilog.pss pxflin string ""
spectreSVerilog.pss pxfdec string ""
spectreSVerilog.pss pxflog string ""
spectreSVerilog.pss pxfuseDiscrete boolean nil
spectreSVerilog.pss pxfvalues string ""
spectreSVerilog.pss pxfharmonics string "Zero sideband only"
spectreSVerilog.pss pxfnumharmonics string ""
spectreSVerilog.pss pxfarrayharmonics string ""
spectreSVerilog.pss pxfselFreqFrom string ""
spectreSVerilog.pss pxfselFreqTo string ""
spectreSVerilog.pss pxfharmsAndFreqsTitle string ""
spectreSVerilog.pss pxfharmsAndFreqs string ""
spectreSVerilog.pss pxfoutProbeType string "voltage"
spectreSVerilog.pss pxfnegNode string "/gnd!"
spectreSVerilog.pss pxfposNode string ""
spectreSVerilog.pss pxfoutVsrc string ""
;spectreSVerilog pssOpts partition variables
spectreSVerilog.pssOpts step string ""
spectreSVerilog.pssOpts maxstep string ""
spectreSVerilog.pssOpts ic string ""
spectreSVerilog.pssOpts skipdc string ""
spectreSVerilog.pssOpts readic string ""
spectreSVerilog.pssOpts readns string ""
spectreSVerilog.pssOpts cmin string ""
spectreSVerilog.pssOpts write string ""
spectreSVerilog.pssOpts writefinal string ""
spectreSVerilog.pssOpts swapfile string ""
spectreSVerilog.pssOpts method string ""
spectreSVerilog.pssOpts relref string ""
spectreSVerilog.pssOpts lteratio string ""
spectreSVerilog.pssOpts steadyratio string ""
spectreSVerilog.pssOpts maxacfreq string ""
spectreSVerilog.pssOpts maxperiods string ""
spectreSVerilog.pssOpts stats string ""
spectreSVerilog.pssOpts annotate string "status"
spectreSVerilog.pssOpts oppoint string ""
spectreSVerilog.pssOpts skipstart string ""
spectreSVerilog.pssOpts skipstop string ""
spectreSVerilog.pssOpts skipcount string ""
spectreSVerilog.pssOpts strobeperiod string ""
spectreSVerilog.pssOpts strobedelay string ""
spectreSVerilog.pssOpts compression string ""
spectreSVerilog.pssOpts maxiters string ""
spectreSVerilog.pssOpts restart string ""
spectreSVerilog.pssOpts tstart string ""
spectreSVerilog.pssOpts tolerance string ""
spectreSVerilog.pssOpts gearorder string ""
spectreSVerilog.pssOpts solver string ""
spectreSVerilog.pssOpts stats2 string ""
spectreSVerilog.pssOpts annotate2 string "status"
spectreSVerilog.pssOpts freqaxis string ""
spectreSVerilog.pssOpts tolerance2 string ""
spectreSVerilog.pssOpts gearorder2 string ""
spectreSVerilog.pssOpts solver2 string ""
spectreSVerilog.pssOpts stats3 string ""
spectreSVerilog.pssOpts annotate3 string "status"
spectreSVerilog.pssOpts stimuli string ""
spectreSVerilog.pssOpts freqaxis2 string ""
spectreSVerilog.pssOpts tolerance3 string ""
spectreSVerilog.pssOpts gearorder3 string ""
spectreSVerilog.pssOpts solver3 string ""
spectreSVerilog.pssOpts stats4 string ""
spectreSVerilog.pssOpts annotate4 string "status"
;spectreSVerilog pdisto partition variables
spectreSVerilog.pdisto enable toggle (nil)
spectreSVerilog.pdisto paramListBox string ""
spectreSVerilog.pdisto fundListBox string ""
spectreSVerilog.pdisto stimName string ""
spectreSVerilog.pdisto freqName string ""
spectreSVerilog.pdisto freqVal string ""
spectreSVerilog.pdisto signalLevel string "Moderate"
spectreSVerilog.pdisto srcId string ""
spectreSVerilog.pdisto maxHarms string ""
spectreSVerilog.pdisto fundsList string ""
spectreSVerilog.pdisto maxHarmsList string ""
spectreSVerilog.pdisto errpreset string ""
spectreSVerilog.pdisto tstab string ""
spectreSVerilog.pdisto saveinit string ""
;spectreSVerilog pdistoOpts partition variables
spectreSVerilog.pdistoOpts step string ""
spectreSVerilog.pdistoOpts maxstep string ""
spectreSVerilog.pdistoOpts ic string ""
spectreSVerilog.pdistoOpts skipdc string ""
spectreSVerilog.pdistoOpts readic string ""
spectreSVerilog.pdistoOpts readns string ""
spectreSVerilog.pdistoOpts cmin string ""
spectreSVerilog.pdistoOpts tolerance string ""
spectreSVerilog.pdistoOpts gearorder string ""
spectreSVerilog.pdistoOpts solver string ""
spectreSVerilog.pdistoOpts write string ""
spectreSVerilog.pdistoOpts writefinal string ""
spectreSVerilog.pdistoOpts swapfile string ""
spectreSVerilog.pdistoOpts method string ""
spectreSVerilog.pdistoOpts relref string ""
spectreSVerilog.pdistoOpts lteratio string ""
spectreSVerilog.pdistoOpts steadyratio string ""
spectreSVerilog.pdistoOpts maxacfreq string ""
spectreSVerilog.pdistoOpts maxperiods string ""
spectreSVerilog.pdistoOpts stats string ""
spectreSVerilog.pdistoOpts annotate string "status"
spectreSVerilog.pdistoOpts oppoint string ""
spectreSVerilog.pdistoOpts skipstart string ""
spectreSVerilog.pdistoOpts skipstop string ""
spectreSVerilog.pdistoOpts skipcount string ""
spectreSVerilog.pdistoOpts strobeperiod string ""
spectreSVerilog.pdistoOpts strobedelay string ""
spectreSVerilog.pdistoOpts compression string ""
spectreSVerilog.pdistoOpts freqaxis string ""
spectreSVerilog.pdistoOpts maxiters string ""
spectreSVerilog.pdistoOpts restart string ""
spectreSVerilog.pdistoOpts tstart string ""
;spectreSVerilog spac partition variables
spectreSVerilog.spac enable toggle (nil)
spectreSVerilog.spac fund string ""
spectreSVerilog.spac Relative boolean nil
spectreSVerilog.spac sweeptype string ""
spectreSVerilog.spac harmonics string "Zero sideband only"
spectreSVerilog.spac numharmonics string ""
spectreSVerilog.spac arrayharmonics string ""
spectreSVerilog.spac selFreqFrom string ""
spectreSVerilog.spac selFreqTo string ""
spectreSVerilog.spac harmsAndFreqsTitle string ""
spectreSVerilog.spac harmsAndFreqs string ""
;spectreSVerilog spacOpts partition variables
spectreSVerilog.spacOpts tolerance string ""
spectreSVerilog.spacOpts gearorder string ""
spectreSVerilog.spacOpts solver string ""
spectreSVerilog.spacOpts stats2 string ""
spectreSVerilog.spacOpts annotate2 string "status"
spectreSVerilog.spacOpts freqaxis string ""
;spectreSVerilog spnoise partition variables
spectreSVerilog.spnoise enable toggle (nil)
spectreSVerilog.spnoise fund string ""
spectreSVerilog.spnoise Relative boolean nil
spectreSVerilog.spnoise sweeptype string ""
spectreSVerilog.spnoise harmonics string "Zero sideband only"
spectreSVerilog.spnoise numharmonics string ""
spectreSVerilog.spnoise arrayharmonics string ""
spectreSVerilog.spnoise selFreqFrom string ""
spectreSVerilog.spnoise selFreqTo string ""
spectreSVerilog.spnoise harmsAndFreqsTitle string ""
spectreSVerilog.spnoise harmsAndFreqs string ""
spectreSVerilog.spnoise outType string "voltage"
spectreSVerilog.spnoise negNode string "/gnd!"
spectreSVerilog.spnoise posNode string ""
spectreSVerilog.spnoise outVsrc string ""
spectreSVerilog.spnoise inNoiseType string "none"
spectreSVerilog.spnoise inVsrc string ""
spectreSVerilog.spnoise inIsrc string ""
spectreSVerilog.spnoise inPort string ""
spectreSVerilog.spnoise refsideband string ""
;spectreSVerilog spnoiseOpts partition variables
spectreSVerilog.spnoiseOpts tolerance3 string ""
spectreSVerilog.spnoiseOpts gearorder3 string ""
spectreSVerilog.spnoiseOpts solver3 string ""
spectreSVerilog.spnoiseOpts stats4 string ""
spectreSVerilog.spnoiseOpts annotate4 string "status"
;spectreSVerilog spxf partition variables
spectreSVerilog.spxf enable toggle (nil)
spectreSVerilog.spxf fund string ""
spectreSVerilog.spxf Relative boolean nil
spectreSVerilog.spxf sweeptype string ""
spectreSVerilog.spxf harmonics string "Zero sideband only"
spectreSVerilog.spxf numharmonics string ""
spectreSVerilog.spxf arrayharmonics string ""
spectreSVerilog.spxf selFreqFrom string ""
spectreSVerilog.spxf selFreqTo string ""
spectreSVerilog.spxf harmsAndFreqsTitle string ""
spectreSVerilog.spxf harmsAndFreqs string ""
spectreSVerilog.spxf outType string "voltage"
spectreSVerilog.spxf negNode string "/gnd!"
spectreSVerilog.spxf posNode string ""
spectreSVerilog.spxf outVsrc string ""
;spectreSVerilog spxfOpts partition variables
spectreSVerilog.spxfOpts tolerance2 string ""
spectreSVerilog.spxfOpts gearorder2 string ""
spectreSVerilog.spxfOpts solver2 string ""
spectreSVerilog.spxfOpts stats3 string ""
spectreSVerilog.spxfOpts annotate3 string "status"
spectreSVerilog.spxfOpts stimuli string ""
spectreSVerilog.spxfOpts freqaxis2 string ""
;spectreSVerilog pac partition variables
spectreSVerilog.pac enable toggle (nil)
spectreSVerilog.pac fund string ""
spectreSVerilog.pac Relative boolean nil
spectreSVerilog.pac sweeptype string ""
spectreSVerilog.pac rangeType string "Start-Stop"
spectreSVerilog.pac from string ""
spectreSVerilog.pac to string ""
spectreSVerilog.pac center string ""
spectreSVerilog.pac span string ""
spectreSVerilog.pac incrType string "Automatic"
spectreSVerilog.pac stepTypeLin string "Step Size"
spectreSVerilog.pac stepTypeLog string "Points Per Decade"
spectreSVerilog.pac by string ""
spectreSVerilog.pac lin string ""
spectreSVerilog.pac dec string ""
spectreSVerilog.pac log string ""
spectreSVerilog.pac useDiscrete boolean nil
spectreSVerilog.pac values string ""
spectreSVerilog.pac harmonics string "Zero sideband only"
spectreSVerilog.pac numharmonics string ""
spectreSVerilog.pac arrayharmonics string ""
spectreSVerilog.pac selFreqFrom string ""
spectreSVerilog.pac selFreqTo string ""
spectreSVerilog.pac harmsAndFreqsTitle string ""
spectreSVerilog.pac harmsAndFreqs string ""
;spectreSVerilog pacOpts partition variables
spectreSVerilog.pacOpts tolerance string ""
spectreSVerilog.pacOpts gearorder string ""
spectreSVerilog.pacOpts solver string ""
spectreSVerilog.pacOpts stats2 string ""
spectreSVerilog.pacOpts annotate2 string "status"
spectreSVerilog.pacOpts freqaxis string ""
;spectreSVerilog pnoise partition variables
spectreSVerilog.pnoise enable toggle (nil)
spectreSVerilog.pnoise fund string ""
spectreSVerilog.pnoise Relative boolean nil
spectreSVerilog.pnoise sweeptype string ""
spectreSVerilog.pnoise rangeType string "Start-Stop"
spectreSVerilog.pnoise from string ""
spectreSVerilog.pnoise to string ""
spectreSVerilog.pnoise center string ""
spectreSVerilog.pnoise span string ""
spectreSVerilog.pnoise incrType string "Automatic"
spectreSVerilog.pnoise stepTypeLin string "Step Size"
spectreSVerilog.pnoise stepTypeLog string "Points Per Decade"
spectreSVerilog.pnoise by string ""
spectreSVerilog.pnoise lin string ""
spectreSVerilog.pnoise dec string ""
spectreSVerilog.pnoise log string ""
spectreSVerilog.pnoise useDiscrete boolean nil
spectreSVerilog.pnoise values string ""
spectreSVerilog.pnoise harmonics string "Zero sideband only"
spectreSVerilog.pnoise numharmonics string ""
spectreSVerilog.pnoise arrayharmonics string ""
spectreSVerilog.pnoise selFreqFrom string ""
spectreSVerilog.pnoise selFreqTo string ""
spectreSVerilog.pnoise harmsAndFreqsTitle string ""
spectreSVerilog.pnoise harmsAndFreqs string ""
spectreSVerilog.pnoise outType string "voltage"
spectreSVerilog.pnoise negNode string "/gnd!"
spectreSVerilog.pnoise posNode string ""
spectreSVerilog.pnoise outVsrc string ""
spectreSVerilog.pnoise inNoiseType string "none"
spectreSVerilog.pnoise inVsrc string ""
spectreSVerilog.pnoise inIsrc string ""
spectreSVerilog.pnoise inPort string ""
spectreSVerilog.pnoise refsideband string ""
;spectreSVerilog pnoiseOpts partition variables
spectreSVerilog.pnoiseOpts tolerance3 string ""
spectreSVerilog.pnoiseOpts gearorder3 string ""
spectreSVerilog.pnoiseOpts solver3 string ""
spectreSVerilog.pnoiseOpts stats4 string ""
spectreSVerilog.pnoiseOpts annotate4 string "status"
;spectreSVerilog pxf partition variables
spectreSVerilog.pxf enable toggle (nil)
spectreSVerilog.pxf fund string ""
spectreSVerilog.pxf Relative boolean nil
spectreSVerilog.pxf sweeptype string ""
spectreSVerilog.pxf rangeType string "Start-Stop"
spectreSVerilog.pxf from string ""
spectreSVerilog.pxf to string ""
spectreSVerilog.pxf center string ""
spectreSVerilog.pxf span string ""
spectreSVerilog.pxf incrType string "Automatic"
spectreSVerilog.pxf stepTypeLin string "Step Size"
spectreSVerilog.pxf stepTypeLog string "Points Per Decade"
spectreSVerilog.pxf by string ""
spectreSVerilog.pxf lin string ""
spectreSVerilog.pxf dec string ""
spectreSVerilog.pxf log string ""
spectreSVerilog.pxf useDiscrete boolean nil
spectreSVerilog.pxf values string ""
spectreSVerilog.pxf harmonics string "Zero sideband only"
spectreSVerilog.pxf numharmonics string ""
spectreSVerilog.pxf arrayharmonics string ""
spectreSVerilog.pxf selFreqFrom string ""
spectreSVerilog.pxf selFreqTo string ""
spectreSVerilog.pxf harmsAndFreqsTitle string ""
spectreSVerilog.pxf harmsAndFreqs string ""
spectreSVerilog.pxf outType string "voltage"
spectreSVerilog.pxf negNode string "/gnd!"
spectreSVerilog.pxf posNode string ""
spectreSVerilog.pxf outVsrc string ""
;spectreSVerilog pxfOpts partition variables
spectreSVerilog.pxfOpts tolerance2 string ""
spectreSVerilog.pxfOpts gearorder2 string ""
spectreSVerilog.pxfOpts solver2 string ""
spectreSVerilog.pxfOpts stats3 string ""
spectreSVerilog.pxfOpts annotate3 string "status"
spectreSVerilog.pxfOpts stimuli string ""
spectreSVerilog.pxfOpts freqaxis2 string ""
;spectreVerilog environment variables
;spectreVerilog opts partition variables
spectreVerilog.opts multithread string ""
spectreVerilog.opts title string ""
spectreVerilog.opts audit string ""
spectreVerilog.opts nthreads string ""
spectreVerilog.opts mos_method string ""
spectreVerilog.opts ckptclock string "1800"
spectreVerilog.opts flow string ""
spectreVerilog.opts cols string "80"
spectreVerilog.opts opptcheck string ""
spectreVerilog.opts maxwarnstologfile string ""
spectreVerilog.opts reltol string "1e-3"
spectreVerilog.opts notation string ""
spectreVerilog.opts senstype string ""
spectreVerilog.opts approx string ""
spectreVerilog.opts warn string ""
spectreVerilog.opts info string ""
spectreVerilog.opts quantities string ""
spectreVerilog.opts sensformat string ""
spectreVerilog.opts pivabs string ""
spectreVerilog.opts compatible string ""
spectreVerilog.opts gmin string "1e-12"
spectreVerilog.opts ignshorts string ""
spectreVerilog.opts rforce string "1"
spectreVerilog.opts homotopy string ""
spectreVerilog.opts note string ""
spectreVerilog.opts iabstol string "1e-12"
spectreVerilog.opts debug string ""
spectreVerilog.opts tempeffects string ""
spectreVerilog.opts maxwarns string "5"
spectreVerilog.opts vabstol string "1e-6"
spectreVerilog.opts macromodels string ""
spectreVerilog.opts tnom string "27"
spectreVerilog.opts temp string "27"
spectreVerilog.opts gmin_check string ""
spectreVerilog.opts value string ""
spectreVerilog.opts narrate string ""
spectreVerilog.opts maxnotes string "5"
spectreVerilog.opts scale string "1.0"
spectreVerilog.opts diagnose string ""
spectreVerilog.opts maxnotestologfile string ""
spectreVerilog.opts digits string "5"
spectreVerilog.opts pivotdc string ""
spectreVerilog.opts pivrel string "1e-3"
spectreVerilog.opts scalem string "1.0"
spectreVerilog.opts limit string ""
spectreVerilog.opts topcheck string ""
spectreVerilog.opts inventory string ""
spectreVerilog.opts error string ""
spectreVerilog.opts sensfile string "../psf/sens.output"
;spectreVerilog outputs partition variables
spectreVerilog.outputs currents string ""
spectreVerilog.outputs subcktprobelvl string ""
spectreVerilog.outputs modelParamInfo boolean t
spectreVerilog.outputs outputParamInfo boolean t
spectreVerilog.outputs allDigitalNV boolean t
spectreVerilog.outputs pwr string ""
spectreVerilog.outputs saveahdlvars string ""
spectreVerilog.outputs nestlvl string ""
spectreVerilog.outputs elementInfo boolean t
spectreVerilog.outputs save string "allpub"
spectreVerilog.outputs useprobes string ""
;spectreVerilog verimixOpts partition variables
spectreVerilog.verimixOpts filename6 string ""
spectreVerilog.verimixOpts maxDCIter int 0
spectreVerilog.verimixOpts scope1 string ""
spectreVerilog.verimixOpts scope10 string ""
spectreVerilog.verimixOpts filename8 string ""
spectreVerilog.verimixOpts dcInterval float 0.0
spectreVerilog.verimixOpts scope3 string ""
spectreVerilog.verimixOpts scope8 string ""
spectreVerilog.verimixOpts scope7 string ""
spectreVerilog.verimixOpts filename7 string ""
spectreVerilog.verimixOpts scope string ""
spectreVerilog.verimixOpts filename4 string ""
spectreVerilog.verimixOpts filename string ""
spectreVerilog.verimixOpts filename1 string ""
spectreVerilog.verimixOpts scope9 string ""
spectreVerilog.verimixOpts importsdfswitch boolean nil
spectreVerilog.verimixOpts filename2 string ""
spectreVerilog.verimixOpts numberofsdffiles int 2
spectreVerilog.verimixOpts scope2 string ""
spectreVerilog.verimixOpts scope6 string ""
spectreVerilog.verimixOpts filename10 string ""
spectreVerilog.verimixOpts delaymodechoice string "Ignore"
spectreVerilog.verimixOpts sdfmixedswitch boolean t
spectreVerilog.verimixOpts filename9 string ""
spectreVerilog.verimixOpts scope5 string ""
spectreVerilog.verimixOpts filename5 string ""
spectreVerilog.verimixOpts filename3 string ""
spectreVerilog.verimixOpts scope4 string ""
;spectreVerilog verilogOpts partition variables
spectreVerilog.verilogOpts otherOptions string "+libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype"
spectreVerilog.verilogOpts optionsFile string ""
spectreVerilog.verilogOpts twinTurbo boolean nil
spectreVerilog.verilogOpts suppressMessages boolean nil
spectreVerilog.verilogOpts libraryFile string ""
spectreVerilog.verilogOpts behaveProfile boolean nil
spectreVerilog.verilogOpts verimixLog string "verilog.log"
spectreVerilog.verilogOpts simVision boolean nil
spectreVerilog.verilogOpts pulseSpec boolean nil
spectreVerilog.verilogOpts commandFile string ""
spectreVerilog.verilogOpts pulseError int 100
spectreVerilog.verilogOpts stopCompile boolean nil
spectreVerilog.verilogOpts keepNodes string "Minimum"
spectreVerilog.verilogOpts accelerationCA boolean nil
spectreVerilog.verilogOpts turboRadio string "Default"
spectreVerilog.verilogOpts libraryDir string ""
spectreVerilog.verilogOpts suppressWarnings boolean nil
spectreVerilog.verilogOpts accelerationSwitches boolean nil
spectreVerilog.verilogOpts accelerationNormal boolean t
spectreVerilog.verilogOpts delayType string "Typical"
spectreVerilog.verilogOpts pulseReject int 100
spectreVerilog.verilogOpts delayMode string "Default"
spectreVerilog.verilogOpts vermixBinary string "verilog.vmx"
;spectreVerilog init partition variables
spectreVerilog.init processPriority int 0
;spectreVerilog envOpts partition variables
spectreVerilog.envOpts mspSetupHNLNetlistPwrNets string "vdd! vdda! vddd! vcc! vcca! vccd!"
spectreVerilog.envOpts mspSetupNetlistStopSymbolImplicit boolean nil
spectreVerilog.envOpts mspSetupNetlistOverWriteSchTimeScale boolean nil
spectreVerilog.envOpts outputFormat string "AWD"
spectreVerilog.envOpts mspSetupNetlistAssignForAlias boolean nil
spectreVerilog.envOpts mspSetupNetlistEscapeName boolean nil
spectreVerilog.envOpts enableArclength boolean nil
spectreVerilog.envOpts autoDisplay boolean t
spectreVerilog.envOpts mspSetupNetlistSimPrecisionUnit string "ns"
spectreVerilog.envOpts mspSetupHNLNetlistGndNets string "gnd! gnda! gndd! vss! vssa! vssd! vee! veea! veed!"
spectreVerilog.envOpts mspSetupNetlistOverWriteVerimix boolean nil
spectreVerilog.envOpts simOutputFormat string "psfbin"
spectreVerilog.envOpts spp string ""
spectreVerilog.envOpts mspSetupNetlistPinMap boolean nil
spectreVerilog.envOpts mspSetupNetlistBus boolean t
spectreVerilog.envOpts mspSetupNetlistDeclareGlobalLocally boolean nil
spectreVerilog.envOpts analysisOrder string ""
spectreVerilog.envOpts mspSetupNetlistSimTimeUnit string "ns"
spectreVerilog.envOpts mspSetupNetlistTemplate string "Verimix"
spectreVerilog.envOpts mspSetupNetlistExplicit boolean nil
spectreVerilog.envOpts mspSetupNetlistSkipTimingInfo boolean nil
spectreVerilog.envOpts mspSetupNetlistUseTestfixture boolean t
spectreVerilog.envOpts paramRangeCheckFile string ""
spectreVerilog.envOpts printComments boolean nil
spectreVerilog.envOpts mspSetupNetlistLaiLmsi boolean nil
spectreVerilog.envOpts mspSetupNetlistSimPrecisionValue int 1
spectreVerilog.envOpts mspSetupNetlistSwitchRC boolean nil
spectreVerilog.envOpts mspSetupNetlistSimTimeValue int 1
spectreVerilog.envOpts mspSetupNetlistUseLib boolean nil
spectreVerilog.envOpts firstRun boolean t
spectreVerilog.envOpts mspSetupNetlistNullPort boolean nil
spectreVerilog.envOpts mspSetupNetlistDropPortRange boolean t
spectreVerilog.envOpts userCmdLineOption string ""
spectreVerilog.envOpts mspSetupNetlistUpCase boolean nil
spectreVerilog.envOpts mspSetupNetlistIncreNetlistConfig boolean nil
;spectreVerilog pz partition variables
spectreVerilog.pz enable toggle (nil)
spectreVerilog.pz outType string "voltage"
spectreVerilog.pz p string ""
spectreVerilog.pz n string ""
spectreVerilog.pz oprobe string ""
spectreVerilog.pz inType string "voltage"
spectreVerilog.pz inVsrc string ""
spectreVerilog.pz inIsrc string ""
spectreVerilog.pz iprobe string ""
spectreVerilog.pz sweep string ""
spectreVerilog.pz freq string "1"
spectreVerilog.pz dev string ""
spectreVerilog.pz deviceParam string ""
spectreVerilog.pz mod string ""
spectreVerilog.pz modelParam string ""
spectreVerilog.pz designVar string ""
spectreVerilog.pz param string ""
spectreVerilog.pz rangeType string "Start-Stop"
spectreVerilog.pz start string ""
spectreVerilog.pz stop string ""
spectreVerilog.pz center string ""
spectreVerilog.pz span string ""
spectreVerilog.pz incrType string "Automatic"
spectreVerilog.pz stepTypeLin string "Step Size"
spectreVerilog.pz stepTypeLog string "Points Per Decade"
spectreVerilog.pz step string ""
spectreVerilog.pz lin string ""
spectreVerilog.pz dec string ""
spectreVerilog.pz log string ""
spectreVerilog.pz useDiscrete boolean nil
spectreVerilog.pz values string ""
spectreVerilog.pz porti string "1"
;spectreVerilog pzOpts partition variables
spectreVerilog.pzOpts readns string ""
spectreVerilog.pzOpts oppoint string ""
spectreVerilog.pzOpts fmax string ""
spectreVerilog.pzOpts zeroonly string ""
spectreVerilog.pzOpts prevoppoint string ""
spectreVerilog.pzOpts restart string ""
spectreVerilog.pzOpts annotate string ""
spectreVerilog.pzOpts stats string ""
;spectreVerilog dcmatch partition variables
spectreVerilog.dcmatch enable toggle (nil)
spectreVerilog.dcmatch outType string "voltage"
spectreVerilog.dcmatch p string ""
spectreVerilog.dcmatch n string ""
spectreVerilog.dcmatch oprobe string ""
spectreVerilog.dcmatch sweep string ""
spectreVerilog.dcmatch dev string ""
spectreVerilog.dcmatch deviceParam string ""
spectreVerilog.dcmatch mod string ""
spectreVerilog.dcmatch modelParam string ""
spectreVerilog.dcmatch designVar string ""
spectreVerilog.dcmatch param string ""
spectreVerilog.dcmatch rangeType string "Start-Stop"
spectreVerilog.dcmatch start string ""
spectreVerilog.dcmatch stop string ""
spectreVerilog.dcmatch center string ""
spectreVerilog.dcmatch span string ""
spectreVerilog.dcmatch incrType string "Automatic"
spectreVerilog.dcmatch stepTypeLin string "Step Size"
spectreVerilog.dcmatch stepTypeLog string "Points Per Decade"
spectreVerilog.dcmatch step string ""
spectreVerilog.dcmatch lin string ""
spectreVerilog.dcmatch dec string ""
spectreVerilog.dcmatch log string ""
spectreVerilog.dcmatch useDiscrete boolean nil
spectreVerilog.dcmatch values string ""
spectreVerilog.dcmatch mth string ""
spectreVerilog.dcmatch porti string "1"
spectreVerilog.dcmatch portv string ""
;spectreVerilog dcmatchOpts partition variables
spectreVerilog.dcmatchOpts readns string ""
spectreVerilog.dcmatchOpts save string ""
spectreVerilog.dcmatchOpts nestlvl string ""
spectreVerilog.dcmatchOpts oppoint string ""
spectreVerilog.dcmatchOpts prevoppoint string ""
spectreVerilog.dcmatchOpts restart string ""
spectreVerilog.dcmatchOpts annotate string "status"
spectreVerilog.dcmatchOpts stats string ""
spectreVerilog.dcmatchOpts where string "rawfile"
;spectreVerilog stb partition variables
spectreVerilog.stb enable toggle (nil)
spectreVerilog.stb sweep string "Frequency"
spectreVerilog.stb freq string ""
spectreVerilog.stb dev string ""
spectreVerilog.stb deviceParam string ""
spectreVerilog.stb mod string ""
spectreVerilog.stb modelParam string ""
spectreVerilog.stb designVar string ""
spectreVerilog.stb param string ""
spectreVerilog.stb rangeType string "Start-Stop"
spectreVerilog.stb start string ""
spectreVerilog.stb stop string ""
spectreVerilog.stb center string ""
spectreVerilog.stb span string ""
spectreVerilog.stb incrType string "Automatic"
spectreVerilog.stb stepTypeLin string "Step Size"
spectreVerilog.stb stepTypeLog string "Points Per Decade"
spectreVerilog.stb step string ""
spectreVerilog.stb lin string ""
spectreVerilog.stb dec string ""
spectreVerilog.stb log string ""
spectreVerilog.stb useDiscrete boolean nil
spectreVerilog.stb values string ""
spectreVerilog.stb probe string ""
;spectreVerilog stbOpts partition variables
spectreVerilog.stbOpts prevoppoint string ""
spectreVerilog.stbOpts readns string ""
spectreVerilog.stbOpts save string ""
spectreVerilog.stbOpts nestlvl string ""
spectreVerilog.stbOpts oppoint string ""
spectreVerilog.stbOpts restart string ""
spectreVerilog.stbOpts annotate string "status"
spectreVerilog.stbOpts stats string ""
;spectreVerilog tran partition variables
spectreVerilog.tran enable toggle (nil)
spectreVerilog.tran stop string ""
spectreVerilog.tran errpreset string ""
;spectreVerilog tranOpts partition variables
spectreVerilog.tranOpts start string ""
spectreVerilog.tranOpts outputstart string ""
spectreVerilog.tranOpts step string ""
spectreVerilog.tranOpts maxstep string ""
spectreVerilog.tranOpts ic string ""
spectreVerilog.tranOpts skipdc string ""
spectreVerilog.tranOpts readic string ""
spectreVerilog.tranOpts readns string ""
spectreVerilog.tranOpts cmin string ""
spectreVerilog.tranOpts write string "spectre.ic"
spectreVerilog.tranOpts writefinal string "spectre.fc"
spectreVerilog.tranOpts ckptperiod string ""
spectreVerilog.tranOpts method string ""
spectreVerilog.tranOpts relref string ""
spectreVerilog.tranOpts lteratio string ""
spectreVerilog.tranOpts stats string ""
spectreVerilog.tranOpts annotate string "status"
spectreVerilog.tranOpts save string ""
spectreVerilog.tranOpts nestlvl string ""
spectreVerilog.tranOpts oppoint string ""
spectreVerilog.tranOpts skipstart string ""
spectreVerilog.tranOpts skipstop string ""
spectreVerilog.tranOpts skipcount string ""
spectreVerilog.tranOpts strobeperiod string ""
spectreVerilog.tranOpts strobedelay string ""
spectreVerilog.tranOpts compression string ""
spectreVerilog.tranOpts infotimes string ""
spectreVerilog.tranOpts flushpoints string ""
spectreVerilog.tranOpts flushtime string ""
spectreVerilog.tranOpts flushofftime string ""
spectreVerilog.tranOpts maxiters string "5"
spectreVerilog.tranOpts restart string ""
spectreVerilog.tranOpts captab boolean nil
spectreVerilog.tranOpts timed boolean nil
spectreVerilog.tranOpts threshold string "0.0"
spectreVerilog.tranOpts detail string "node"
spectreVerilog.tranOpts sort string "name"
;spectreVerilog envlp partition variables
spectreVerilog.envlp enable toggle (nil)
spectreVerilog.envlp clockname string ""
spectreVerilog.envlp stop string ""
spectreVerilog.envlp harmonics string "Number of harmonics"
spectreVerilog.envlp harms string ""
spectreVerilog.envlp harmsvec string ""
spectreVerilog.envlp errpreset string ""
;spectreVerilog envlpOpts partition variables
spectreVerilog.envlpOpts start string ""
spectreVerilog.envlpOpts outputstart string ""
spectreVerilog.envlpOpts tstab string ""
spectreVerilog.envlpOpts modulationbw string ""
spectreVerilog.envlpOpts maxstep string ""
spectreVerilog.envlpOpts envmaxstep string ""
spectreVerilog.envlpOpts ic string ""
spectreVerilog.envlpOpts skipdc string ""
spectreVerilog.envlpOpts readic string ""
spectreVerilog.envlpOpts readns string ""
spectreVerilog.envlpOpts cmin string ""
spectreVerilog.envlpOpts write string ""
spectreVerilog.envlpOpts writefinal string ""
spectreVerilog.envlpOpts swapfile string ""
spectreVerilog.envlpOpts method string ""
spectreVerilog.envlpOpts relref string ""
spectreVerilog.envlpOpts lteratio string ""
spectreVerilog.envlpOpts envlteratio string ""
spectreVerilog.envlpOpts steadyratio string ""
spectreVerilog.envlpOpts stats string ""
spectreVerilog.envlpOpts annotate string "status"
spectreVerilog.envlpOpts save string ""
spectreVerilog.envlpOpts nestlvl string ""
spectreVerilog.envlpOpts compression string ""
spectreVerilog.envlpOpts outputtype string ""
spectreVerilog.envlpOpts strobeperiod string ""
spectreVerilog.envlpOpts maxiters string ""
spectreVerilog.envlpOpts restart string ""
spectreVerilog.envlpOpts envmaxiters string ""
;spectreVerilog ac partition variables
spectreVerilog.ac enable toggle (nil)
spectreVerilog.ac sweep string "Frequency"
spectreVerilog.ac freq string ""
spectreVerilog.ac dev string ""
spectreVerilog.ac deviceParam string ""
spectreVerilog.ac mod string ""
spectreVerilog.ac modelParam string ""
spectreVerilog.ac designVar string ""
spectreVerilog.ac param string ""
spectreVerilog.ac rangeType string "Start-Stop"
spectreVerilog.ac start string ""
spectreVerilog.ac stop string ""
spectreVerilog.ac center string ""
spectreVerilog.ac span string ""
spectreVerilog.ac incrType string "Automatic"
spectreVerilog.ac stepTypeLin string "Step Size"
spectreVerilog.ac stepTypeLog string "Points Per Decade"
spectreVerilog.ac step string ""
spectreVerilog.ac lin string ""
spectreVerilog.ac dec string ""
spectreVerilog.ac log string ""
spectreVerilog.ac useDiscrete boolean nil
spectreVerilog.ac values string ""
;spectreVerilog acOpts partition variables
spectreVerilog.acOpts readns string ""
spectreVerilog.acOpts prevoppoint string ""
spectreVerilog.acOpts save string ""
spectreVerilog.acOpts nestlvl string ""
spectreVerilog.acOpts oppoint string ""
spectreVerilog.acOpts restart string ""
spectreVerilog.acOpts annotate string "status"
spectreVerilog.acOpts stats string ""
;spectreVerilog dc partition variables
spectreVerilog.dc enable toggle (nil)
spectreVerilog.dcop enable toggle (nil)
spectreVerilog.dc saveOppoint boolean nil
spectreVerilog.dc sweep string ""
spectreVerilog.dc dev string ""
spectreVerilog.dc deviceParam string ""
spectreVerilog.dc mod string ""
spectreVerilog.dc modelParam string ""
spectreVerilog.dc designVar string ""
spectreVerilog.dc param string ""
spectreVerilog.dc rangeType string "Start-Stop"
spectreVerilog.dc start string ""
spectreVerilog.dc stop string ""
spectreVerilog.dc center string ""
spectreVerilog.dc span string ""
spectreVerilog.dc incrType string "Automatic"
spectreVerilog.dc stepTypeLin string "Step Size"
spectreVerilog.dc stepTypeLog string "Points Per Decade"
spectreVerilog.dc step string ""
spectreVerilog.dc lin string ""
spectreVerilog.dc dec string ""
spectreVerilog.dc log string ""
spectreVerilog.dc useDiscrete boolean nil
spectreVerilog.dc values string ""
;spectreVerilog dcOpts partition variables
spectreVerilog.dcOpts force string ""
spectreVerilog.dcopOpts force string ""
spectreVerilog.dcOpts readns string ""
spectreVerilog.dcopOpts readns string ""
spectreVerilog.dcOpts readforce string ""
spectreVerilog.dcopOpts readforce string ""
spectreVerilog.dcOpts write string "spectre.dc"
spectreVerilog.dcopOpts write string "spectre.dc"
spectreVerilog.dcOpts writefinal string ""
spectreVerilog.dcopOpts writefinal string ""
spectreVerilog.dcOpts save string ""
spectreVerilog.dcopOpts save string ""
spectreVerilog.dcOpts nestlvl string ""
spectreVerilog.dcopOpts nestlvl string ""
spectreVerilog.dcOpts print string ""
spectreVerilog.dcopOpts print string ""
spectreVerilog.dcOpts check string ""
spectreVerilog.dcopOpts check string ""
spectreVerilog.dcOpts oppoint string "rawfile"
spectreVerilog.dcopOpts oppoint string "rawfile"
spectreVerilog.dcOpts homotopy string ""
spectreVerilog.dcopOpts homotopy string ""
spectreVerilog.dcOpts restart string ""
spectreVerilog.dcopOpts restart string ""
spectreVerilog.dcOpts maxiters string "150"
spectreVerilog.dcopOpts maxiters string "150"
spectreVerilog.dcOpts maxsteps string "10000"
spectreVerilog.dcopOpts maxsteps string "10000"
spectreVerilog.dcOpts annotate string "status"
spectreVerilog.dcopOpts annotate string "status"
spectreVerilog.dcOpts captab boolean nil
spectreVerilog.dcopOpts captab boolean nil
spectreVerilog.dcOpts threshold string "0.0"
spectreVerilog.dcopOpts threshold string "0.0"
spectreVerilog.dcOpts detail string "node"
spectreVerilog.dcopOpts detail string "node"
spectreVerilog.dcOpts sort string "name"
spectreVerilog.dcopOpts sort string "name"
;spectreVerilog noise partition variables
spectreVerilog.noise enable toggle (nil)
spectreVerilog.noise sweep string "Frequency"
spectreVerilog.noise freq string ""
spectreVerilog.noise dev string ""
spectreVerilog.noise deviceParam string ""
spectreVerilog.noise mod string ""
spectreVerilog.noise modelParam string ""
spectreVerilog.noise designVar string ""
spectreVerilog.noise param string ""
spectreVerilog.noise rangeType string "Start-Stop"
spectreVerilog.noise start string ""
spectreVerilog.noise stop string ""
spectreVerilog.noise center string ""
spectreVerilog.noise span string ""
spectreVerilog.noise incrType string "Automatic"
spectreVerilog.noise stepTypeLin string "Step Size"
spectreVerilog.noise stepTypeLog string "Points Per Decade"
spectreVerilog.noise step string ""
spectreVerilog.noise lin string ""
spectreVerilog.noise dec string ""
spectreVerilog.noise log string ""
spectreVerilog.noise useDiscrete boolean nil
spectreVerilog.noise values string ""
spectreVerilog.noise outType string "probe"
spectreVerilog.noise p string ""
spectreVerilog.noise n string ""
spectreVerilog.noise oprobe string ""
spectreVerilog.noise inType string "port"
spectreVerilog.noise inVsrc string ""
spectreVerilog.noise inIsrc string ""
spectreVerilog.noise iprobe string ""
spectreVerilog.noise inPort string ""
;spectreVerilog noiseOpts partition variables
spectreVerilog.noiseOpts readns string ""
spectreVerilog.noiseOpts prevoppoint string ""
spectreVerilog.noiseOpts save string ""
spectreVerilog.noiseOpts nestlvl string ""
spectreVerilog.noiseOpts oppoint string ""
spectreVerilog.noiseOpts restart string ""
spectreVerilog.noiseOpts annotate string "status"
spectreVerilog.noiseOpts stats string ""
;spectreVerilog xf partition variables
spectreVerilog.xf enable toggle (nil)
spectreVerilog.xf sweep string "Frequency"
spectreVerilog.xf freq string ""
spectreVerilog.xf dev string ""
spectreVerilog.xf deviceParam string ""
spectreVerilog.xf mod string ""
spectreVerilog.xf modelParam string ""
spectreVerilog.xf designVar string ""
spectreVerilog.xf param string ""
spectreVerilog.xf rangeType string "Start-Stop"
spectreVerilog.xf start string ""
spectreVerilog.xf stop string ""
spectreVerilog.xf center string ""
spectreVerilog.xf span string ""
spectreVerilog.xf incrType string "Automatic"
spectreVerilog.xf stepTypeLin string "Step Size"
spectreVerilog.xf stepTypeLog string "Points Per Decade"
spectreVerilog.xf step string ""
spectreVerilog.xf lin string ""
spectreVerilog.xf dec string ""
spectreVerilog.xf log string ""
spectreVerilog.xf useDiscrete boolean nil
spectreVerilog.xf values string ""
spectreVerilog.xf outType string "voltage"
spectreVerilog.xf p string ""
spectreVerilog.xf n string ""
spectreVerilog.xf probe string ""
;spectreVerilog xfOpts partition variables
spectreVerilog.xfOpts readns string ""
spectreVerilog.xfOpts prevoppoint string ""
spectreVerilog.xfOpts stimuli string ""
spectreVerilog.xfOpts save string ""
spectreVerilog.xfOpts nestlvl string ""
spectreVerilog.xfOpts oppoint string ""
spectreVerilog.xfOpts restart string ""
spectreVerilog.xfOpts annotate string "status"
spectreVerilog.xfOpts stats string ""
;spectreVerilog sp partition variables
spectreVerilog.sp enable toggle (nil)
spectreVerilog.sp ports string ""
spectreVerilog.sp sweep string "Frequency"
spectreVerilog.sp freq string ""
spectreVerilog.sp dev string ""
spectreVerilog.sp deviceParam string ""
spectreVerilog.sp mod string ""
spectreVerilog.sp modelParam string ""
spectreVerilog.sp designVar string ""
spectreVerilog.sp param string ""
spectreVerilog.sp rangeType string "Start-Stop"
spectreVerilog.sp start string ""
spectreVerilog.sp stop string ""
spectreVerilog.sp center string ""
spectreVerilog.sp span string ""
spectreVerilog.sp incrType string "Automatic"
spectreVerilog.sp stepTypeLin string "Step Size"
spectreVerilog.sp stepTypeLog string "Points Per Decade"
spectreVerilog.sp step string ""
spectreVerilog.sp lin string ""
spectreVerilog.sp dec string ""
spectreVerilog.sp log string ""
spectreVerilog.sp useDiscrete boolean nil
spectreVerilog.sp values string ""
spectreVerilog.sp donoise string "no"
spectreVerilog.sp oprobe string ""
spectreVerilog.sp iprobe string ""
;spectreVerilog spOpts partition variables
spectreVerilog.spOpts readns string ""
spectreVerilog.spOpts prevoppoint string ""
spectreVerilog.spOpts file string ""
spectreVerilog.spOpts datafmt string ""
spectreVerilog.spOpts datatype string ""
spectreVerilog.spOpts noisedata string ""
spectreVerilog.spOpts oppoint string ""
spectreVerilog.spOpts restart string ""
spectreVerilog.spOpts annotate string "status"
spectreVerilog.spOpts stats string ""
;spectreVerilog pss partition variables
spectreVerilog.pss enable toggle (nil)
spectreVerilog.pss paramListBox string ""
spectreVerilog.pss fundListBox string ""
spectreVerilog.pss stimName string ""
spectreVerilog.pss freqName string ""
spectreVerilog.pss freqVal string ""
spectreVerilog.pss signalLevel string "Large"
spectreVerilog.pss srcId string ""
spectreVerilog.pss maxHarms string ""
spectreVerilog.pss freqPeriod string "Beat Frequency"
spectreVerilog.pss fund string ""
spectreVerilog.pss autoCalc boolean nil
spectreVerilog.pss period string ""
spectreVerilog.pss harmonics string "Number of harmonics"
spectreVerilog.pss harms string ""
spectreVerilog.pss indices string ""
spectreVerilog.pss Aindices string ""
spectreVerilog.pss harmsvec string ""
spectreVerilog.pss selFreqFrom string "0"
spectreVerilog.pss selFreqTo string "1e12"
spectreVerilog.pss order string "1"
spectreVerilog.pss harmsAndFreqsTitle string ""
spectreVerilog.pss harmsAndFreqsTitle2 string ""
spectreVerilog.pss harmsAndFreqs string ""
spectreVerilog.pss arrayCoeffs string ""
spectreVerilog.pss harmCoeffs string ""
spectreVerilog.pss harmListMem string ""
spectreVerilog.pss errpreset string ""
spectreVerilog.pss tstab string ""
spectreVerilog.pss saveinit string ""
spectreVerilog.pss oscana boolean nil
spectreVerilog.pss p string ""
spectreVerilog.pss n string ""
spectreVerilog.pss sweepB boolean nil
spectreVerilog.pss sweep string "Variable"
spectreVerilog.pss freqVar string "no"
spectreVerilog.pss designVar string ""
spectreVerilog.pss dev string ""
spectreVerilog.pss deviceParam string ""
spectreVerilog.pss mod string ""
spectreVerilog.pss modelParam string ""
spectreVerilog.pss param string ""
spectreVerilog.pss rangeType string "Start-Stop"
spectreVerilog.pss start string ""
spectreVerilog.pss stop string ""
spectreVerilog.pss center string ""
spectreVerilog.pss span string ""
spectreVerilog.pss incrType string "Linear"
spectreVerilog.pss stepTypeLin string "Step Size"
spectreVerilog.pss stepTypeLog string "Points Per Decade"
spectreVerilog.pss step string ""
spectreVerilog.pss lin string ""
spectreVerilog.pss dec string ""
spectreVerilog.pss log string ""
spectreVerilog.pss useDiscrete boolean nil
spectreVerilog.pss values string ""
;spectreVerilog pssOpts partition variables
spectreVerilog.pssOpts step string ""
spectreVerilog.pssOpts maxstep string ""
spectreVerilog.pssOpts ic string ""
spectreVerilog.pssOpts skipdc string ""
spectreVerilog.pssOpts readic string ""
spectreVerilog.pssOpts readns string ""
spectreVerilog.pssOpts cmin string ""
spectreVerilog.pssOpts write string ""
spectreVerilog.pssOpts writefinal string ""
spectreVerilog.pssOpts swapfile string ""
spectreVerilog.pssOpts writepss string ""
spectreVerilog.pssOpts readpss string ""
spectreVerilog.pssOpts method string ""
spectreVerilog.pssOpts tstabmethod string ""
spectreVerilog.pssOpts relref string ""
spectreVerilog.pssOpts lteratio string ""
spectreVerilog.pssOpts steadyratio string ""
spectreVerilog.pssOpts maxacfreq string ""
spectreVerilog.pssOpts maxperiods string ""
spectreVerilog.pssOpts finitediff string ""
spectreVerilog.pssOpts highorder string ""
spectreVerilog.pssOpts psaratio string ""
spectreVerilog.pssOpts maxorder string ""
spectreVerilog.pssOpts fullpssvec string ""
spectreVerilog.pssOpts stats string ""
spectreVerilog.pssOpts annotate string "status"
spectreVerilog.pssOpts save string ""
spectreVerilog.pssOpts nestlvl string ""
spectreVerilog.pssOpts oppoint string ""
spectreVerilog.pssOpts skipstart string ""
spectreVerilog.pssOpts skipstop string ""
spectreVerilog.pssOpts skipcount string ""
spectreVerilog.pssOpts strobeperiod string ""
spectreVerilog.pssOpts strobedelay string ""
spectreVerilog.pssOpts compression string ""
spectreVerilog.pssOpts outputtype string ""
spectreVerilog.pssOpts maxiters string ""
spectreVerilog.pssOpts restart string ""
spectreVerilog.pssOpts tstart string ""
;spectreVerilog pac partition variables
spectreVerilog.pac enable toggle (nil)
spectreVerilog.pac fund string ""
spectreVerilog.pac period string ""
spectreVerilog.pac modsource string ""
spectreVerilog.pac moduppersideband string "0"
spectreVerilog.pac inmodharmnum string "1"
spectreVerilog.pac outmodharmvec string "1"
spectreVerilog.pac inputType string "SSB"
spectreVerilog.pac modulatedToggle boolean nil
spectreVerilog.pac modulated string ""
spectreVerilog.pac singlePt string "Single-Point []"
spectreVerilog.pac sweeptype string " "
spectreVerilog.pac relharmnum string ""
spectreVerilog.pac rangeType string "Start-Stop"
spectreVerilog.pac start string ""
spectreVerilog.pac stop string ""
spectreVerilog.pac center string ""
spectreVerilog.pac span string ""
spectreVerilog.pac incrType string "Automatic"
spectreVerilog.pac stepTypeLin string "Step Size"
spectreVerilog.pac stepTypeLog string "Points Per Decade"
spectreVerilog.pac step string ""
spectreVerilog.pac lin string ""
spectreVerilog.pac dec string ""
spectreVerilog.pac log string ""
spectreVerilog.pac useDiscrete boolean nil
spectreVerilog.pac values string ""
spectreVerilog.pac harmonics string "Maximum sideband"
spectreVerilog.pac maxsideband string ""
spectreVerilog.pac indices string ""
spectreVerilog.pac Aindices string ""
spectreVerilog.pac sidebands string ""
spectreVerilog.pac side string "upper"
spectreVerilog.pac selFreqFrom string "0"
spectreVerilog.pac selFreqTo string "1e12"
spectreVerilog.pac order string "1"
spectreVerilog.pac harmsAndFreqsTitle string ""
spectreVerilog.pac harmsAndFreqsTitle2 string ""
spectreVerilog.pac harmsAndFreqs string ""
spectreVerilog.pac arrayCoeffs string ""
spectreVerilog.pac harmCoeffs string ""
spectreVerilog.pac harmListMem string ""
;spectreVerilog pacOpts partition variables
spectreVerilog.pacOpts tolerance string ""
spectreVerilog.pacOpts gear_order string ""
spectreVerilog.pacOpts solver string ""
spectreVerilog.pacOpts oscsolver string ""
spectreVerilog.pacOpts stats string ""
spectreVerilog.pacOpts annotate string "status"
spectreVerilog.pacOpts freqaxis string ""
spectreVerilog.pacOpts save string ""
spectreVerilog.pacOpts nestlvl string ""
spectreVerilog.pacOpts outputperiod string ""
;spectreVerilog pnoise partition variables
spectreVerilog.pnoise enable toggle (nil)
spectreVerilog.pnoise fund string ""
spectreVerilog.pnoise period string ""
spectreVerilog.pnoise singlePt string "Single-Point []"
spectreVerilog.pnoise sweeptype string " "
spectreVerilog.pnoise relharmnum string ""
spectreVerilog.pnoise rangeType string "Start-Stop"
spectreVerilog.pnoise start string ""
spectreVerilog.pnoise stop string ""
spectreVerilog.pnoise center string ""
spectreVerilog.pnoise span string ""
spectreVerilog.pnoise incrType string "Automatic"
spectreVerilog.pnoise stepTypeLin string "Step Size"
spectreVerilog.pnoise stepTypeLog string "Points Per Decade"
spectreVerilog.pnoise step string ""
spectreVerilog.pnoise lin string ""
spectreVerilog.pnoise dec string ""
spectreVerilog.pnoise log string ""
spectreVerilog.pnoise useDiscrete boolean nil
spectreVerilog.pnoise values string ""
spectreVerilog.pnoise harmonics string "Maximum sideband"
spectreVerilog.pnoise maxsideband string ""
spectreVerilog.pnoise indices string ""
spectreVerilog.pnoise Aindices string ""
spectreVerilog.pnoise sidebands string ""
spectreVerilog.pnoise side string "upper"
spectreVerilog.pnoise selFreqFrom string "0"
spectreVerilog.pnoise selFreqTo string "1e12"
spectreVerilog.pnoise order string "1"
spectreVerilog.pnoise harmsAndFreqsTitle string ""
spectreVerilog.pnoise harmsAndFreqsTitle2 string ""
spectreVerilog.pnoise harmsAndFreqs string ""
spectreVerilog.pnoise arrayCoeffs string ""
spectreVerilog.pnoise harmCoeffs string ""
spectreVerilog.pnoise harmListMem string ""
spectreVerilog.pnoise outType string "probe"
spectreVerilog.pnoise p string ""
spectreVerilog.pnoise n string ""
spectreVerilog.pnoise oprobe string ""
spectreVerilog.pnoise inType string "port"
spectreVerilog.pnoise inVsrc string ""
spectreVerilog.pnoise inIsrc string ""
spectreVerilog.pnoise iprobe string ""
spectreVerilog.pnoise inPort string ""
spectreVerilog.pnoise refsbSelect string "Enter in field"
spectreVerilog.pnoise refsideband string ""
spectreVerilog.pnoise refsbFreqFrom string "0"
spectreVerilog.pnoise refsbFreqTo string "1e12"
spectreVerilog.pnoise refsbOrder string "1"
spectreVerilog.pnoise refsbTitle string ""
spectreVerilog.pnoise refsbListbox string ""
spectreVerilog.pnoise noisetype string "sources"
spectreVerilog.pnoise tdnoise string "Noise Skip Count"
spectreVerilog.pnoise noiseskipcount string ""
spectreVerilog.pnoise numberofpoints string ""
spectreVerilog.pnoise maxcycles string ""
spectreVerilog.pnoise useDiscreteNoise boolean nil
spectreVerilog.pnoise noisetimepoints string ""
spectreVerilog.pnoise useDiscreteCorr boolean nil
spectreVerilog.pnoise cycles string ""
;spectreVerilog pnoiseOpts partition variables
spectreVerilog.pnoiseOpts tolerance string ""
spectreVerilog.pnoiseOpts gear_order string ""
spectreVerilog.pnoiseOpts solver string ""
spectreVerilog.pnoiseOpts oscsolver string ""
spectreVerilog.pnoiseOpts stats string ""
spectreVerilog.pnoiseOpts annotate string "status"
spectreVerilog.pnoiseOpts save string ""
spectreVerilog.pnoiseOpts nestlvl string ""
spectreVerilog.pnoiseOpts saveallsidebands string ""
;spectreVerilog pxf partition variables
spectreVerilog.pxf enable toggle (nil)
spectreVerilog.pxf fund string ""
spectreVerilog.pxf period string ""
spectreVerilog.pxf moduppersideband string "0"
spectreVerilog.pxf outmodharmnum string "1"
spectreVerilog.pxf inmodharmvec string "1"
spectreVerilog.pxf outputType string "SSB"
spectreVerilog.pxf modulatedToggle boolean nil
spectreVerilog.pxf modulated string ""
spectreVerilog.pxf outType string "voltage"
spectreVerilog.pxf p string ""
spectreVerilog.pxf n string ""
spectreVerilog.pxf probe string ""
spectreVerilog.pxf singlePt string "Single-Point []"
spectreVerilog.pxf sweeptype string " "
spectreVerilog.pxf relharmnum string ""
spectreVerilog.pxf rangeType string "Start-Stop"
spectreVerilog.pxf start string ""
spectreVerilog.pxf stop string ""
spectreVerilog.pxf center string ""
spectreVerilog.pxf span string ""
spectreVerilog.pxf incrType string "Automatic"
spectreVerilog.pxf stepTypeLin string "Step Size"
spectreVerilog.pxf stepTypeLog string "Points Per Decade"
spectreVerilog.pxf step string ""
spectreVerilog.pxf lin string ""
spectreVerilog.pxf dec string ""
spectreVerilog.pxf log string ""
spectreVerilog.pxf useDiscrete boolean nil
spectreVerilog.pxf values string ""
spectreVerilog.pxf harmonics string "Maximum sideband"
spectreVerilog.pxf maxsideband string ""
spectreVerilog.pxf indices string ""
spectreVerilog.pxf Aindices string ""
spectreVerilog.pxf sidebands string ""
spectreVerilog.pxf side string "upper"
spectreVerilog.pxf selFreqFrom string "0"
spectreVerilog.pxf selFreqTo string "1e12"
spectreVerilog.pxf order string "1"
spectreVerilog.pxf harmsAndFreqsTitle string ""
spectreVerilog.pxf harmsAndFreqsTitle2 string ""
spectreVerilog.pxf harmsAndFreqs string ""
spectreVerilog.pxf arrayCoeffs string ""
spectreVerilog.pxf harmCoeffs string ""
spectreVerilog.pxf harmListMem string ""
;spectreVerilog pxfOpts partition variables
spectreVerilog.pxfOpts tolerance string ""
spectreVerilog.pxfOpts gear_order string ""
spectreVerilog.pxfOpts solver string ""
spectreVerilog.pxfOpts oscsolver string ""
spectreVerilog.pxfOpts stats string ""
spectreVerilog.pxfOpts annotate string "status"
spectreVerilog.pxfOpts stimuli string ""
spectreVerilog.pxfOpts freqaxis string ""
spectreVerilog.pxfOpts save string ""
spectreVerilog.pxfOpts nestlvl string ""
;spectreVerilog psp partition variables
spectreVerilog.psp enable toggle (nil)
spectreVerilog.psp singlePt string "Single-Point []"
spectreVerilog.psp sweeptype string " "
spectreVerilog.psp rangeType string "Start-Stop"
spectreVerilog.psp start string ""
spectreVerilog.psp stop string ""
spectreVerilog.psp center string ""
spectreVerilog.psp span string ""
spectreVerilog.psp incrType string "Automatic"
spectreVerilog.psp stepTypeLin string "Step Size"
spectreVerilog.psp stepTypeLog string "Points Per Decade"
spectreVerilog.psp step string ""
spectreVerilog.psp lin string ""
spectreVerilog.psp dec string ""
spectreVerilog.psp log string ""
spectreVerilog.psp useDiscrete boolean nil
spectreVerilog.psp values string ""
spectreVerilog.psp portharmsvec string ""
spectreVerilog.psp ports string ""
spectreVerilog.psp selectPorts boolean t
spectreVerilog.psp harmsvec string ""
spectreVerilog.psp freqRange string ""
spectreVerilog.psp listPortHarm string ""
spectreVerilog.psp listPortName string ""
spectreVerilog.psp listPortNum string ""
spectreVerilog.psp portChoiceList string ""
spectreVerilog.psp portChoiceListHeading string ""
spectreVerilog.psp donoise string "yes"
spectreVerilog.psp maxsideband string ""
;spectreVerilog pspOpts partition variables
spectreVerilog.pspOpts tolerance string ""
spectreVerilog.pspOpts gear_order string ""
spectreVerilog.pspOpts solver string ""
spectreVerilog.pspOpts oscsolver string ""
spectreVerilog.pspOpts annotate string "status"
spectreVerilog.pspOpts stats string ""
spectreVerilog.pspOpts freqaxis string ""
;spectreVerilog qpss partition variables
spectreVerilog.qpss enable toggle (nil)
spectreVerilog.qpss paramListBox string ""
spectreVerilog.qpss fundListBox string ""
spectreVerilog.qpss stimName string ""
spectreVerilog.qpss freqName string ""
spectreVerilog.qpss freqVal string ""
spectreVerilog.qpss signalLevel string "Moderate"
spectreVerilog.qpss srcId string ""
spectreVerilog.qpss maxHarms string ""
spectreVerilog.qpss funds string ""
spectreVerilog.qpss maxharms string ""
spectreVerilog.qpss harmonics boolean nil
spectreVerilog.qpss selFreqFrom string "0"
spectreVerilog.qpss selFreqTo string "1e12"
spectreVerilog.qpss harmsAndFreqsTitle string ""
spectreVerilog.qpss harmsAndFreqs string ""
spectreVerilog.qpss errpreset string ""
spectreVerilog.qpss tstab string ""
spectreVerilog.qpss saveinit string ""
spectreVerilog.qpss sweepB boolean nil
spectreVerilog.qpss sweep string "Variable"
spectreVerilog.qpss freqVar string "no"
spectreVerilog.qpss designVar string ""
spectreVerilog.qpss dev string ""
spectreVerilog.qpss deviceParam string ""
spectreVerilog.qpss mod string ""
spectreVerilog.qpss modelParam string ""
spectreVerilog.qpss param string ""
spectreVerilog.qpss rangeType string "Start-Stop"
spectreVerilog.qpss start string ""
spectreVerilog.qpss stop string ""
spectreVerilog.qpss center string ""
spectreVerilog.qpss span string ""
spectreVerilog.qpss incrType string "Linear"
spectreVerilog.qpss stepTypeLin string "Step Size"
spectreVerilog.qpss stepTypeLog string "Points Per Decade"
spectreVerilog.qpss step string ""
spectreVerilog.qpss lin string ""
spectreVerilog.qpss dec string ""
spectreVerilog.qpss log string ""
spectreVerilog.qpss useDiscrete boolean nil
spectreVerilog.qpss values string ""
;spectreVerilog qpssOpts partition variables
spectreVerilog.qpssOpts step string ""
spectreVerilog.qpssOpts maxstep string ""
spectreVerilog.qpssOpts ic string ""
spectreVerilog.qpssOpts skipdc string ""
spectreVerilog.qpssOpts readic string ""
spectreVerilog.qpssOpts readns string ""
spectreVerilog.qpssOpts cmin string ""
spectreVerilog.qpssOpts write string ""
spectreVerilog.qpssOpts writefinal string ""
spectreVerilog.qpssOpts swapfile string ""
spectreVerilog.qpssOpts writeqpss string ""
spectreVerilog.qpssOpts readqpss string ""
spectreVerilog.qpssOpts method string ""
spectreVerilog.qpssOpts relref string ""
spectreVerilog.qpssOpts lteratio string ""
spectreVerilog.qpssOpts steadyratio string ""
spectreVerilog.qpssOpts maxperiods string ""
spectreVerilog.qpssOpts stats string ""
spectreVerilog.qpssOpts annotate string "status"
spectreVerilog.qpssOpts save string ""
spectreVerilog.qpssOpts nestlvl string ""
spectreVerilog.qpssOpts oppoint string ""
spectreVerilog.qpssOpts skipstart string ""
spectreVerilog.qpssOpts skipstop string ""
spectreVerilog.qpssOpts skipcount string ""
spectreVerilog.qpssOpts strobeperiod string ""
spectreVerilog.qpssOpts strobedelay string ""
spectreVerilog.qpssOpts compression string ""
spectreVerilog.qpssOpts maxiters string ""
spectreVerilog.qpssOpts restart string ""
spectreVerilog.qpssOpts tstart string ""
;spectreVerilog qpac partition variables
spectreVerilog.qpac enable toggle (nil)
spectreVerilog.qpac singlePt string "Single-Point []"
spectreVerilog.qpac sweeptype string " "
spectreVerilog.qpac relharmvec string ""
spectreVerilog.qpac rangeType string "Start-Stop"
spectreVerilog.qpac start string ""
spectreVerilog.qpac stop string ""
spectreVerilog.qpac center string ""
spectreVerilog.qpac span string ""
spectreVerilog.qpac incrType string "Automatic"
spectreVerilog.qpac stepTypeLin string "Step Size"
spectreVerilog.qpac stepTypeLog string "Points Per Decade"
spectreVerilog.qpac step string ""
spectreVerilog.qpac lin string ""
spectreVerilog.qpac dec string ""
spectreVerilog.qpac log string ""
spectreVerilog.qpac useDiscrete boolean nil
spectreVerilog.qpac values string ""
spectreVerilog.qpac sbsm string "Maximum clock order"
spectreVerilog.qpac clockmaxharm string ""
spectreVerilog.qpac selFreqFrom string "0"
spectreVerilog.qpac selFreqTo string "1e12"
spectreVerilog.qpac order string "1"
spectreVerilog.qpac harmsAndFreqsTitle string ""
spectreVerilog.qpac harmsAndFreqsTitle2 string ""
spectreVerilog.qpac harmsAndFreqs string ""
spectreVerilog.qpac arrayCoeffs string ""
spectreVerilog.qpac harmCoeffs string ""
spectreVerilog.qpac harmListMem string ""
spectreVerilog.qpac sidevec string ""
;spectreVerilog qpacOpts partition variables
spectreVerilog.qpacOpts tolerance string ""
spectreVerilog.qpacOpts gear_order string ""
spectreVerilog.qpacOpts solver string ""
spectreVerilog.qpacOpts stats string ""
spectreVerilog.qpacOpts annotate string "status"
spectreVerilog.qpacOpts freqaxis string ""
spectreVerilog.qpacOpts save string ""
spectreVerilog.qpacOpts nestlvl string ""
;spectreVerilog qpnoise partition variables
spectreVerilog.qpnoise enable toggle (nil)
spectreVerilog.qpnoise singlePt string "Single-Point []"
spectreVerilog.qpnoise sweeptype string " "
spectreVerilog.qpnoise relharmvec string ""
spectreVerilog.qpnoise rangeType string "Start-Stop"
spectreVerilog.qpnoise start string ""
spectreVerilog.qpnoise stop string ""
spectreVerilog.qpnoise center string ""
spectreVerilog.qpnoise span string ""
spectreVerilog.qpnoise incrType string "Automatic"
spectreVerilog.qpnoise stepTypeLin string "Step Size"
spectreVerilog.qpnoise stepTypeLog string "Points Per Decade"
spectreVerilog.qpnoise step string ""
spectreVerilog.qpnoise lin string ""
spectreVerilog.qpnoise dec string ""
spectreVerilog.qpnoise log string ""
spectreVerilog.qpnoise useDiscrete boolean nil
spectreVerilog.qpnoise values string ""
spectreVerilog.qpnoise sbsm string "Maximum clock order"
spectreVerilog.qpnoise clockmaxharm string ""
spectreVerilog.qpnoise selFreqFrom string "0"
spectreVerilog.qpnoise selFreqTo string "1e12"
spectreVerilog.qpnoise order string "1"
spectreVerilog.qpnoise harmsAndFreqsTitle string ""
spectreVerilog.qpnoise harmsAndFreqsTitle2 string ""
spectreVerilog.qpnoise harmsAndFreqs string ""
spectreVerilog.qpnoise arrayCoeffs string ""
spectreVerilog.qpnoise harmCoeffs string ""
spectreVerilog.qpnoise harmListMem string ""
spectreVerilog.qpnoise sidevec string ""
spectreVerilog.qpnoise outType string "probe"
spectreVerilog.qpnoise p string ""
spectreVerilog.qpnoise n string ""
spectreVerilog.qpnoise oprobe string ""
spectreVerilog.qpnoise inType string "port"
spectreVerilog.qpnoise inVsrc string ""
spectreVerilog.qpnoise inIsrc string ""
spectreVerilog.qpnoise iprobe string ""
spectreVerilog.qpnoise inPort string ""
spectreVerilog.qpnoise refsbSelect string "Enter in field"
spectreVerilog.qpnoise refsideband string ""
spectreVerilog.qpnoise refsbFreqFrom string "0"
spectreVerilog.qpnoise refsbFreqTo string "1e12"
spectreVerilog.qpnoise refsbOrder string "1"
spectreVerilog.qpnoise refsbTitle string ""
spectreVerilog.qpnoise refsbListbox string ""
;spectreVerilog qpnoiseOpts partition variables
spectreVerilog.qpnoiseOpts tolerance string ""
spectreVerilog.qpnoiseOpts gear_order string ""
spectreVerilog.qpnoiseOpts solver string ""
spectreVerilog.qpnoiseOpts stats string ""
spectreVerilog.qpnoiseOpts annotate string "status"
spectreVerilog.qpnoiseOpts save string ""
spectreVerilog.qpnoiseOpts nestlvl string ""
spectreVerilog.qpnoiseOpts saveallsidebands string ""
;spectreVerilog qpxf partition variables
spectreVerilog.qpxf enable toggle (nil)
spectreVerilog.qpxf singlePt string "Single-Point []"
spectreVerilog.qpxf sweeptype string " "
spectreVerilog.qpxf relharmvec string ""
spectreVerilog.qpxf rangeType string "Start-Stop"
spectreVerilog.qpxf start string ""
spectreVerilog.qpxf stop string ""
spectreVerilog.qpxf center string ""
spectreVerilog.qpxf span string ""
spectreVerilog.qpxf incrType string "Automatic"
spectreVerilog.qpxf stepTypeLin string "Step Size"
spectreVerilog.qpxf stepTypeLog string "Points Per Decade"
spectreVerilog.qpxf step string ""
spectreVerilog.qpxf lin string ""
spectreVerilog.qpxf dec string ""
spectreVerilog.qpxf log string ""
spectreVerilog.qpxf useDiscrete boolean nil
spectreVerilog.qpxf values string ""
spectreVerilog.qpxf sbsm string "Maximum clock order"
spectreVerilog.qpxf clockmaxharm string ""
spectreVerilog.qpxf selFreqFrom string "0"
spectreVerilog.qpxf selFreqTo string "1e12"
spectreVerilog.qpxf order string "1"
spectreVerilog.qpxf harmsAndFreqsTitle string ""
spectreVerilog.qpxf harmsAndFreqsTitle2 string ""
spectreVerilog.qpxf harmsAndFreqs string ""
spectreVerilog.qpxf arrayCoeffs string ""
spectreVerilog.qpxf harmCoeffs string ""
spectreVerilog.qpxf harmListMem string ""
spectreVerilog.qpxf sidevec string ""
spectreVerilog.qpxf outType string "voltage"
spectreVerilog.qpxf p string ""
spectreVerilog.qpxf n string ""
spectreVerilog.qpxf probe string ""
;spectreVerilog qpxfOpts partition variables
spectreVerilog.qpxfOpts tolerance string ""
spectreVerilog.qpxfOpts gear_order string ""
spectreVerilog.qpxfOpts solver string ""
spectreVerilog.qpxfOpts stats string ""
spectreVerilog.qpxfOpts annotate string "status"
spectreVerilog.qpxfOpts stimuli string ""
spectreVerilog.qpxfOpts freqaxis string ""
spectreVerilog.qpxfOpts save string ""
spectreVerilog.qpxfOpts nestlvl string ""
;spectreVerilog qpsp partition variables
spectreVerilog.qpsp enable toggle (nil)
spectreVerilog.qpsp singlePt string "Single-Point []"
spectreVerilog.qpsp sweeptype string " "
spectreVerilog.qpsp rangeType string "Start-Stop"
spectreVerilog.qpsp start string ""
spectreVerilog.qpsp stop string ""
spectreVerilog.qpsp center string ""
spectreVerilog.qpsp span string ""
spectreVerilog.qpsp incrType string "Automatic"
spectreVerilog.qpsp stepTypeLin string "Step Size"
spectreVerilog.qpsp stepTypeLog string "Points Per Decade"
spectreVerilog.qpsp step string ""
spectreVerilog.qpsp lin string ""
spectreVerilog.qpsp dec string ""
spectreVerilog.qpsp log string ""
spectreVerilog.qpsp useDiscrete boolean nil
spectreVerilog.qpsp values string ""
spectreVerilog.qpsp portharmsvec string ""
spectreVerilog.qpsp ports string ""
spectreVerilog.qpsp selectPorts boolean t
spectreVerilog.qpsp harmsvec string ""
spectreVerilog.qpsp freqRange string ""
spectreVerilog.qpsp listPortHarm string ""
spectreVerilog.qpsp listPortName string ""
spectreVerilog.qpsp listPortNum string ""
spectreVerilog.qpsp portChoiceList string ""
spectreVerilog.qpsp portChoiceListHeading string ""
spectreVerilog.qpsp donoise string "yes"
spectreVerilog.qpsp clockmaxharm string ""
;spectreVerilog qpspOpts partition variables
spectreVerilog.qpspOpts tolerance string ""
spectreVerilog.qpspOpts gear_order string ""
spectreVerilog.qpspOpts solver string ""
spectreVerilog.qpspOpts annotate string "status"
spectreVerilog.qpspOpts stats string ""
spectreVerilog.qpspOpts freqaxis string ""
;spectreVerilog sens partition variables
spectreVerilog.sens enable toggle (nil)
spectreVerilog.sens sensType toggle (nil nil nil)
spectreVerilog.sens analyses_list string ""
spectreVerilog.sens outputs string ""
spectreVerilog.sens output_list string ""
spectreVerilog.sens net string ""
spectreVerilog.sens term string ""
;spectreVerilog sensOpts partition variables
;spice3 environment variables
;This file was generated by `asiCreateEnvFile()'
;FORMAT: tool.partition name type value private {choices, minmax} comment
;spice3 outputs partition variables
spice3.outputs allAnalogNV boolean t
spice3.outputs allAnalogTC boolean nil
;spice3 envOpts partition variables
spice3.envOpts stopViewList string "spice3"
spice3.envOpts printComments boolean nil
spice3.envOpts autoDisplay boolean t
spice3.envOpts switchViewList string "spice3 cmos_sch cmos.sch schematic veriloga ahdl"
;spice3 init partition variables
;spice3 opts partition variables
spice3.opts ITL5 string "5000"
spice3.opts ITL4 string "10"
spice3.opts DEFAD string "0.0"
spice3.opts RELTOL string "1e-3"
spice3.opts METHOD string ""
spice3.opts DEFAS string "0.0"
spice3.opts CHGTOL string "1e-14"
spice3.opts GMIN string "1e-12"
spice3.opts DEFW string "100.0"
spice3.opts TEMP string "27"
spice3.opts PIVREL string "1e-3"
spice3.opts TRTOL string "7.0"
spice3.opts VNTOL string "1e-6"
spice3.opts DEFL string "100.0"
spice3.opts ITL3 string "4"
spice3.opts ITL2 string "50"
spice3.opts ITL1 string "100"
spice3.opts TNOM string "27"
spice3.opts PIVTOL string "1e-13"
spice3.opts ABSTOL string "1e-12"
;spice3 dc partition variables
spice3.dc enable toggle (nil)
spice3.dc vstart string ""
spice3.dc vstop string ""
spice3.dc vincr string ""
spice3.dc srcnam string ""
;spice3 dcOpts partition variables
;spice3 ac partition variables
spice3.ac enable toggle (nil)
spice3.ac fstart string ""
spice3.ac fstop string ""
spice3.ac incrType string "DEC"
spice3.ac log string ""
spice3.ac lin string ""
;spice3 acOpts partition variables
;spice3 tran partition variables
spice3.tran enable toggle (nil)
spice3.tran tstart string ""
spice3.tran tstop string ""
spice3.tran tstep string ""
spice3.tran tmax string ""
;spice3 tranOpts partition variables
;SCA Extraction Environment Defaults
;FORMAT: tool[.partition] varName type value private {choices, minmax} comment
subx subRunDir string "./SCA"
subx subProcFile string "./sample.proc"
subx subModelName string "substrate"
subx subAccuLevel string "medium"
subx subFreq string "1e9"
subx subSync boolean t
subx subNetexpDefault string "scagnd!"
subx subNetexpProp string ""
subx subMethod string "full"
;User Preference Defaults
ui winPlaceStyle boolean nil
ui setWinTraversal boolean nil
ui showScrollBars boolean nil
ui showPromptLines boolean t
ui showStatusLines boolean t
ui showFixedMenu cyclic "On Left-Side "
ui showFixedMenuLabels boolean t
ui infix boolean nil
ui showOptionForms boolean nil
ui undoLevel int 1
ui nestLimit int 5
ui dblClkTime int 200
ui beepVolume int 0
ui textFont string "-*-courier-medium-r-*-*-12-*-*-*-*-*-iso8859-1"
ui formButtonLocation cyclic "Top "
;Log Filter Defaults
ui menuCmdInput boolean nil
ui promptInput boolean nil
ui userOutput boolean t
ui menuCmdOutput boolean nil
ui progResultsOutput boolean t
ui errorMsg boolean t
ui warningMsg boolean t
ui dragDisplayHint string "normal"
vhdl analyzeMode cyclic "on"
vhdl batchScriptFile string ""
vhdl batchSim cyclic "interactive"
vhdl compareSimDB string "simcmp.log"
vhdl Cosim9404 boolean nil
vhdl createVHDLDir boolean t
vhdl currentSimDB string ""
vhdl dataLocation string ""
vhdl defAttributes string ""
vhdl defBodyViewName string "body"
vhdl defConfigViewName string "configuration"
vhdl defDataDirectory string "vhdllib"
vhdl defEntityViewName string "entity"
vhdl defGenerics string ""
vhdl defGlobals string "(("vdd!" "'1'")("gnd!" "'0'"))"
vhdl defPackageNames string "ieee.std_logic_1164.all"
vhdl defPackageViewName string "package"
vhdl defScalarType string "std_ulogic"
vhdl defVectorType string "std_ulogic_vector"
vhdl defViewName string "vhdl"
vhdl deleteVHDLDir boolean nil
vhdl displaySimCmpResults boolean t
vhdl elaborateMode cyclic "on"
vhdl exportCatFiles boolean t
vhdl exportDirectory string ""
vhdl exportLibNameExt string ".exp"
vhdl exportNetlist cyclic "off"
vhdl generateComponentConfig boolean nil
vhdl goldenSimDB string ""
vhdl ignoreWarnings boolean nil
vhdl importCaseSensitivity boolean t
vhdl importCompatibilityOpt boolean nil
vhdl importCompileAfterImport boolean nil
vhdl importCompilerOptions string ""
vhdl importComponentDensity int 0
vhdl importConfig boolean nil
vhdl importFileFilter string "*.vhd"
vhdl importFontHeight float 0.0625
vhdl importFullPlaceRoute boolean t
vhdl importGenSymbols boolean nil
vhdl importGroundLiterals string "'0'"
vhdl importGroundNetName string "gnd!"
vhdl importGroundType string "std_ulogic"
vhdl importIgnoreContassFunc boolean nil
vhdl importIgnoreExtraPins boolean nil
vhdl importLibName string ""
vhdl importLineComponentSpacing float 0.5
vhdl importLineLineSpacing float 0.2
vhdl importMaxNoCols int 1024
vhdl importMaxNoRows int 1024
vhdl importMinmizeCrossovers boolean t
vhdl importOptimizeLabels boolean t
vhdl importOverwriteExistingView boolean t
vhdl importPinPlacement cyclic "Left and Right Sides"
vhdl importPinPlacementFile string ""
vhdl importPowerLiterals string "'1'"
vhdl importPowerNetName string "vdd!"
vhdl importPowerType string "std_ulogic"
vhdl importReferenceLibraries string "basic US_8ths ieee std sample"
vhdl importRunInBackground boolean t
vhdl importSeparateUnits boolean t
vhdl importSheetBorderSize string ""
vhdl importSquareSchematics boolean t
vhdl importStructuralViewType cyclic "schematic"
vhdl importSummaryFile string "./vhdlin.summary"
vhdl importSymbolViewName string "symbol"
vhdl importv93Opt boolean nil
vhdl importWorkLibName string ""
vhdl invokeLaunchTool boolean nil
vhdl invokeLeapfrogSystemWindow boolean nil
vhdl invokeNCTools boolean t
vhdl libCellViewCaseSensitive boolean t
vhdl maxErrors int 10
vhdl netConfig string "config1"
vhdl netHierSpec cyclic "Simple"
vhdl netIgnoreUnboundCells boolean nil
vhdl netMode cyclic "incremental"
vhdl netScope cyclic "hierarchy"
vhdl overwriteEntity boolean nil
vhdl portMapMode cyclic "named association"
vhdl printCommand string "lpr"
vhdl rangeDir cyclic "default"
vhdl remoteFileAccess cyclic "Automount"
vhdl remoteHostName string "localhost"
vhdl remoteSim cyclic "locally"
vhdl runCheckBeforeSim boolean t
vhdl schHdlParseUsingNcvhdl boolean t
vhdl simCompareLength int 100
vhdl simCompareOffset int 0
vhdl simModel string "SIM"
vhdl simTimeUnits cyclic "ns"
vhdl simTolerance int 0
vhdl stopLibList string "basic sample ieee"
vhdl stopViewList string "symbol"
vhdl switchViewList string "stimulus schematic structure dataflow behavior symbol"
vhdl synergySourceLibrary string ""
vhdl synergySymbolLibraries string "basic US_8ths"
vhdl testBenchCellName string "test"
vhdl testBenchLibName string ""
vhdl testBenchStimulusFile string ""
vhdl testBenchViewName string "stimulus"
vhdl testModeOn boolean nil
vhdl topCellName string ""
vhdl topLevelInstanceName string "dut"
vhdl topLibraryName string ""
vhdl topVersion string ""
vhdl topViewName string "schematic"
vhdl translateMode cyclic "library"
vhdl translateTypes toggle (t t t)
vhdl useUserLibraries boolean nil
vhdl verilogNetlistOpts string ""
vhdl verilogRunDir string ""
vhdl verilogSimOpts string "-q"
vhdl vhdlIdentCaseSensitive boolean t
vhdl whichVLibsFile cyclic "user"
vhdl workCellName string ""
vhdl workLibraryName string ""
vhdl workVersion string ""
vhdl workViewName string "schematic"
vhdlams Cosim9404 boolean nil
vhdlams analyzeMode cyclic "on"
vhdlams batchScriptFile string ""
vhdlams batchSim cyclic "interactive"
vhdlams compareSimDB string "simcmp.log"
vhdlams createVHDLDir boolean t
vhdlams currentSimDB string ""
vhdlams dataLocation string ""
vhdlams defAttributes string ""
vhdlams defBodyViewName string "body"
vhdlams defConfigViewName string "configuration"
vhdlams defDataDirectory string "vhdllib"
vhdlams defEntityViewName string "entity"
vhdlams defGenerics string ""
vhdlams defGlobals string "(("vdd!" "'1'")("gnd!" "'0'"))"
vhdlams defPackageNames string "ieee.std_logic_1164.all ieee.electrical_systems.all"
vhdlams defPackageViewName string "package"
vhdlams defScalarType string "electrical"
vhdlams defVectorType string "std_ulogic_vector"
vhdlams defScalarDomain string "terminal"
vhdlams defVectorDomain string "signal"
vhdlams defViewName string "vhdl"
vhdlams deleteVHDLDir boolean nil
vhdlams displaySimCmpResults boolean t
vhdlams elaborateMode cyclic "on"
vhdlams exportCatFiles boolean t
vhdlams exportDirectory string ""
vhdlams exportLibNameExt string ".exp"
vhdlams exportNetlist cyclic "off"
vhdlams generateComponentConfig boolean nil
vhdlams goldenSimDB string ""
vhdlams ignoreWarnings boolean nil
vhdlams importCaseSensitivity boolean t
vhdlams importCompatibilityOpt boolean nil
vhdlams importCompileAfterImport boolean nil
vhdlams importCompilerOptions string ""
vhdlams importComponentDensity int 0
vhdlams importConfig boolean nil
vhdlams importFileFilter string "*.vhd"
vhdlams importFontHeight float 0.0625
vhdlams importFullPlaceRoute boolean t
vhdlams importGenSymbols boolean nil
vhdlams importGroundLiterals string "'0'"
vhdlams importGroundNetName string "gnd!"
vhdlams importGroundType string "std_ulogic"
vhdlams importIgnoreContassFunc boolean nil
vhdlams importIgnoreExtraPins boolean nil
vhdlams importLibName string ""
vhdlams importLineComponentSpacing float 0.5
vhdlams importLineLineSpacing float 0.2
vhdlams importMaxNoCols int 1024
vhdlams importMaxNoRows int 1024
vhdlams importMinmizeCrossovers boolean t
vhdlams importOptimizeLabels boolean t
vhdlams importOverwriteExistingView boolean t
vhdlams importPinPlacement cyclic "Left and Right Sides"
vhdlams importPinPlacementFile string ""
vhdlams importPowerLiterals string "'1'"
vhdlams importPowerNetName string "vdd!"
vhdlams importPowerType string "std_ulogic"
vhdlams importReferenceLibraries string "basic US_8ths ieee std sample"
vhdlams importRunInBackground boolean t
vhdlams importSeparateUnits boolean t
vhdlams importSheetBorderSize string ""
vhdlams importSquareSchematics boolean t
vhdlams importStructuralViewType cyclic "schematic"
vhdlams importSummaryFile string "./vhdlin.summary"
vhdlams importSymbolViewName string "symbol"
vhdlams importWorkLibName string ""
vhdlams importv93Opt boolean nil
vhdlams invokeLaunchTool boolean nil
vhdlams invokeLeapfrogSystemWindow boolean nil
vhdlams invokeNCTools boolean t
vhdlams libCellViewCaseSensitive boolean t
vhdlams maxErrors int 10
vhdlams netConfig string "config1"
vhdlams netHierSpec cyclic "Simple"
vhdlams netIgnoreUnboundCells boolean nil
vhdlams netMode cyclic "incremental"
vhdlams netScope cyclic "hierarchy"
vhdlams overwriteEntity boolean nil
vhdlams portMapMode cyclic "named association"
vhdlams printCommand string "lpr"
vhdlams rangeDir cyclic "default"
vhdlams remoteFileAccess cyclic "Automount"
vhdlams remoteHostName string "localhost"
vhdlams remoteSim cyclic "locally"
vhdlams runCheckBeforeSim boolean t
vhdlams schHdlParseUsingNcvhdl boolean t
vhdlams simCompareLength int 100
vhdlams simCompareOffset int 0
vhdlams simModel string "SIM"
vhdlams simTimeUnits cyclic "ns"
vhdlams simTolerance int 0
vhdlams stopLibList string "basic sample ieee"
vhdlams stopViewList string "symbol"
vhdlams switchViewList string "stimulus schematic structure dataflow behavior symbol"
vhdlams synergySourceLibrary string ""
vhdlams synergySymbolLibraries string "basic US_8ths"
vhdlams testBenchCellName string "test"
vhdlams testBenchLibName string ""
vhdlams testBenchStimulusFile string ""
vhdlams testBenchViewName string "stimulus"
vhdlams testModeOn boolean nil
vhdlams topCellName string ""
vhdlams topLevelInstanceName string "dut"
vhdlams topLibraryName string ""
vhdlams topVersion string ""
vhdlams topViewName string "schematic"
vhdlams translateMode cyclic "library"
vhdlams translateTypes toggle (t t t)
vhdlams verilogNetlistOpts string ""
vhdlams verilogRunDir string ""
vhdlams verilogSimOpts string "-q"
vhdlams vhdlIdentCaseSensitive boolean t
vhdlams whichVLibsFile cyclic "user"
vhdlams workCellName string ""
vhdlams workLibraryName string ""
vhdlams workVersion string ""
vhdlams workViewName string "schematic"
Re: importing folders &amp; files to icfb
Describe correctly.
State folder don't exist in the simulation folder.
Simulation states exist in test bench cell view or state directory.
Which one do you use ?
Answer my question surely.
I don't know what enviornment which you showed.
However your environments are following.
asimenv.startup projectDir string "~/simulation"
asimenv saveDir string "~/.artist_states"
asimenv saveAsCellview boolean nil
So your simulation states have to be in "~/.artist_states", if you use Directory Analysis State Type.
And your default Analysis State Type is Directory not Cellview.
When I open the .artist_states, I see some folders with my built library and inside of it, I can see the cellview's name and one file that is .sevSaveDir.
but I don't know what I do.
It seems empty.
Do you surely use state directory at university lab ?
I don't use state directory.
Almost all current user use cell view state.
Surely confirm your environment at university lab.
Describe correctly.
Surely answer my question.
Which one do you use at Univeristy Lab ?
I think you use cellview state at university lab,
however you set state directory type as default in your PC.
Again surely confirm your environment at university lab.
See https://www.designers-guide.org/Forum/YaBB.pl?num=1314177463
Changing ADE Default Load / Save Option to “Cellview”
Default is “Directory” but saving states as cellviews is the preferred method (keeps everything organized by having your test bench schematic and simulation setup together); even Cadence recommends storing ADE states as cellviews and that the directory option is just for backward compatibility.
To make “cellview” the default option when you go to load or save a state in ADE L, in the directory in which you run Virtuoso edit (or create) the .cdsinit file and somewhere (usually put all of your customizations at the end) add these lines (the first is just a comment reminding you what the next line does):
; make ADE L save / load state option default to cellview
envSetVal("asimenv" "saveAsCellview" 'boolean t)
It seems empty.
So if I change directory mode to cellview, Can I load states that I save them in the lab PC?
