3phase BLDC rpm question
moro
Member level 3
i am working on a school project. I want to control a 3 phase BLDC motor.... the software will be managed by a stm32f103 arm device via a 3 phase mosfet bridge with ir2110 drivers
The motor which i have is a 24dc 3 phase star connection motor, with 6 poles and 3 hall sensors
The hall sensors timings are shown here
As i can see for 1 mechanical rotation, on a 3 pole machine i would require acording to the formula "electrical degrees" = 3 x "mechanical degrees", thus for 360 mech degrees i would require a 1080 electrical degrees.
Since every hall event happens at 60e.degrees that means for a complete mechanical rotation i need 18 steps, is this correct?
I said to my self to try this "by hand", so i hooked the 3 hall sensors to a logic analyzer, and try to rotate by hand the motor shaft... indeed it takes 18 hall events to reach a complete mechanical rotation
Now my question is regarding the determination of rpm value.
So suposing every hall event happens at 1ms ( 1000hz), that means my comutation would have a (1/6)/(transition time between 2 hall events), in my case (1/6)/(0.001 second)
Normaly in my case for 1000hz hall event and 18 steps/mech revolution that would yeld 1 rotation every 18ms, that means in a 60second period i would have 60000ms/18ms = 3333 rpm. Is my presumption correct?
What is the formula for determining the rpm value?
Thank you
I said to my self to try this "by hand", so i hooked the 3 hall sensors to a logic analyzer, and try to rotate by hand the motor shaft... indeed it takes 18 hall events to reach a complete mechanical rotation...
So you turn the shaft by 360 deg and observe 18 "hall events", right?
In one turn, each pole passes over all the three sensors producing 3 pulses. There are 6 poles and each of them shall produce 3 pulses in the same way- hence you see a total of 18 "hall events"
I presume that the sensors are going to be used for speed control and not for positioning.
Hence 18 hall pulses in one second corresponds to one rps (or 18 pulses /min corresponds to 1 rpm)
So if every pulse appears every 1ms, there will be 1000 pulses per second and 60,000 pulses per min- this will correspond to 60,000/18 rpm.
I guess your calculation is correct.
You say your motor is a six pole one...
But your calculations are for three pole motors.
So the calculations are correct for a three pole motor, but not for your motor.
what is the formula for calculating rpm value for a six pole?
1 pole --> 1 x 360° electrical
2 pole --> 2 x 360° electrical
3 pole --> 3 x 360° electrical
6 pole --> 6 x 360° electrical
Hello Klaus,
so for 6 pole i understand its 360° mech = 6 x 360° electrical?
From the picture above i see it takes 6 steps to perform 360° electrical, i presume this is defined for 1 pole only.
Like i said earlier, when i rotate the motor shaft manualy, i am reading 18 steps on the hall sensors
If i would to perform the calculations based o "6 x 360° electrical".... that would give 36 steps for 360° mechanical, which is twice what i "measured", why is this?
How did you read this?
We don't know what you measured, we even can't verify if it really is a 6 pole motor.
Can you be bit more detailed? I have difficulty in imagining a 1 pole motor; I always presumed that motor rotor always have even number of poles.
Hello Klaus
the motor has 6 magnets on the rotor side, and 9 coils on the stator side, i presume its a 6 pole. Its also specified in the datasheet its a 6 pole/3 phase bldc motor
i had a logic analyzer conected to the 3 hall sensors ( beside the 5V supply for hall, and pull-up resitor on each hall output).... ok so i had the logic analyzer hooked to the motor sensors.
I marked with some pencil a point on the rotor shaft, and a point on the stator side.. just for visual reference....
Then i started to rotate the rotor by hand 360° ... After that i read on the logic analyzer the following patern
H1 0 1 1 1 0 0 0 1 1 1 0 0 0 1 1 1 0 0 0 0
H2 1 1 0 0 0 1 1 1 0 0 0 1 1 1 0 0 0 1 1 1
H3 0 0 0 1 1 1 0 0 0 1 1 1 0 0 0 1 1 1 1 0
You are very correct.
Speaking of "3 poles" is not exact. The better phrase is "3 pole pairs" or "3 magnets".
Unfortunately I folowed the OP's way of expression of his first post.
From now on I will use "pole pairs".
@OP:
Please post the exact motor type and manufacturer, or datasheet.
bellow i have attached the datasheet of the motor.
Ok, so in the end 360 mech degrees = 3 (pole pairs) x 360 electrical degrees, that would result in 18 steps x 60 electrical degree for 1 mechanical rotation. Which makes sense with my "manual experiment"
And for example if the hall events occur every 1ms(1000hz), that would mean in 18ms i have 1 rotation.
Then for RPM this would be 60000ms/18ms = 3333,33 rpm?
  • motor datasheet.pdf
