+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Member level 3
    Points: 641, Level: 5
    Join Date
    Feb 2017
    Posts
    64
    Points
    641
    Level
    Problem with unbalance detection in three phase system
    Hello! I want to check voltage unbalance in a three phase system. I have used the below circuit for checking unbalance. But in normal operation that all three phase are approximately equal there is'nt zero voltage difference between points N and N'. I have near 5 Vrms in normal operation, while in some weeks ago there was near 0 voltage difference. Do anyone know what is the problem??
    •   AltAdvertisement
  2. #2
    Super Moderator
    Points: 256,119, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    44,661
    Points
    256,119
    Level
    100
    Re: Problem with unbalance detection in three phase system
    No problem. Just asymmetrically loaded power grid.
    1 members found this post helpful.
    •   AltAdvertisement
  3. #3
    Member level 3
    Join Date
    Feb 2017
    Posts
    64
    Points
    641
    Level
    Do you mean the problem is with power grid that supplies 3 phase?! When I measure phase voltages there is little difference between them! and 3 resistors also are equal.
    •   AltAdvertisement
  4. #4
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    44,661
    Points
    256,119
    Level
    100
    Phase voltage isn't the full information. You should also measure phase-to-phase voltage.
  5. #5
    Advanced Member level 5
    Points: 16,347, Level: 30
    Join Date
    Nov 2012
    Posts
    2,993
    Points
    16,347
    Level
    30
    There are two distinct unbalance conditions: The three phases have unequal peak voltages AND/OR the phase relations between the phases are not equal.
    In general, we expect the load too be symmetric on the three phases. This condition is often not fulfilled. The effect depends on the source impedance.
    Your load is not the only load on the system; other large loads on the same circuit can affect the phase and amplitude. If the line voltages are 220/440V, then 5V on the neutral due to unbalanced current is rather small and nothing to worry.
    If the voltage gets over 10% of the line voltage, you need to redistribute the other loads so that some symmetry is attained.
    •   AltAdvertisement
  6. #6
    Points: 13,005, Level: 27
    Join Date
    May 2015
    Melbourne, Australia
    Posts
    2,213
    Points
    13,005
    Level
    27
    Harmonic distortion can easily be several percent.
    So even if the rms voltages are identical, the zero point can be moving around quite a lot at harmonic frequencies.
    Cheers, Tony.
