JJFORTY
Member level 1
modelsim 211
Hi everybody .
I have modelsim 5.8 that is called from HDL designer for simulation (FPGA 6.3).
the probleme is that when i execut the command : "add wave *" or "add
wave name" in modelsim it disappear completly (modelsim exit) and in
the HDL log window it say :
Reading C:/FPGAdv63LSPS/Modeltech/tcl/vsim/pref.tcl
Reading C:/FPGAdv63LSPS/Hds/resources/downstream/modelsim/hdsInit.tc_
Connected to HDS
# Attempting stack trace sig 11
# Signal caught: signo [11]
# vsim_stacktrace.vstf written
# Current time Wed Apr 13 13:42:01 2005
# ModelSim Stack Trace
# Program = vsim
# Id = "5.8c"
# Version = "2004.03"
# Date = "Mar 25 2004"
# Platform = win32
# 0 0x005add42: '<unknown (@0x5add42)> + 0xf1002'
# 1 0x005add7c: '<unknown (@0x5add7c)> + 0xf103c'
# Corrupt Call Stack
** Fatal: (SIGSEGV) Bad pointer access. Closing vsim.
** Fatal: vsim is exiting with code 211.
(Exit codes are defined in the ModelSim messages appendix
of the ModelSim User's Manual.)
in the modelsim manual its indicated that the code 211 means :
segmentation violation.
I dont know what to do to correcte the probleme, i'v tryed to delet
the modelsim.ini file, also to reinstal modelsim, its doesnt hepl....
So please can you tel me whats can i do to solve this problem.
Thanks for answering.
Hi everybody .
Connected to HDS
# Program = vsim
# Id = "5.8c"
# Platform = win32
