Fixed_point
Newbie level 3
Has anyone come up with a good way of describing a state machine in requirements without access to the state signals, e.g. so it is directly testable?
For instance
1) The state machine shall change state from state A to state B when Z = 1.
2) When in state B, output C shall be set to 1
When writing a test for these requirements you would have a test procedure like:
1) Reset
2) Set Z = 0
3) Check C is 0
4) Set Z = 1
5) Check C is 1
This only implies that you are in state B, but does not directly test it, as C=1 could also be set in some other state (not described above). Is there a better way of writing the requirements so that you can test them without giving the test module access to the state machine state signals?
For instance
1) Reset
2) Set Z = 0
3) Check C is 0
4) Set Z = 1
5) Check C is 1
