+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Newbie level 2
    Points: 24, Level: 1
    Join Date
    Jan 2017
    Posts
    Points
    24
    Level
    Help Idenitifying RF IC
    Hi
    I'm trying to identify an SMD IC that is used in the front end of the Futaba R3006SB radio control receiver. I think that it is most likely a PIN diode attenuator working in the 2.4 GHz region, but it could also be an RF preamp.
    Any help gratefully appreciated.
    Thanks
    Andrew
    rfengfpv.wordpress.com
    •   AltAdvertisment
  2. #2
    Newbie level 2
    Join Date
    Jan 2017
    Posts
    Points
    24
    Level
    Re: Help Idenitifying RF IC
    On second thoughts, I think it's more likely an RF preamp (LNA). I've attached an image showing the associated components.
    Click image for larger version.
Name:	Mystery Rx IC_DxO.jpg
    The signal input is at pin 4 (top left in the image) and output at pin 1 (bottom right). A bias voltage is fed in to pins 1 and 3 via decoupling caps, and an additional RF choke in the case of pin 1, which is also the output.
    The package size is approx. 1.5mm x 1mm excluding the leads.
    Thanks
    Andrew
