Results 1 to 4 of 4
    Banned
    Points: 727, Level: 5
    Nov 2016
    161
    727
    What is this in CRT Vacuum tube?
    what is this in TV vacuum tube?
    the top wire lock in tube hole?
    black thick wire with cap..
ID:	134101Click image for larger version.
    Points: 14,943, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,483
    14,943
    29
    Re: What is this in CRT Vacuum tube?
    The high voltage supply, anything between 25 to 35 kV
    Advanced Member level 2
    Points: 3,760, Level: 14
    May 2012
    504
    3,760
    14
    Stick your finger in the hole, it will make you jump and maybe fatal, the tube can store a high voltage charge that could be present for a very long time after the power has been removed.
    Apr 2013
    2,483
    14,943
    29
    Indeed, a shocking and unforgettable experience.
    For an electronics student, it was a rite of passage getting shocked by a CRT's high voltage.
    You would become a real engineer afterwards, learning both respect for electricity and that one should always double check everything before testing a circuit.
