UltraGreen
Junior Member level 3
I am using Vivado 2016.2 , and virtex ultrascale.
My design is successfully implemented, now I want to increase the frequency of the design by modifying mmcm out clock from 50 MHz to 75 MHz, or if I need to add some false path or multicycle path constraint in the the implemented design, then in these cases can I force up to date the design and avoid rerunning the implementation run and only rerun the "report timing summary " ?
will I get updated timing summary ?
