any connector between this kind of wire (SMA connectors to UFL connector)
shanmei
Advanced Member level 1
USA
any connector between this kind of wire( SMA connector to UFL connector)
As the above figure shows, a SMA connector to a UFL connector.
I need to add some additional wire between it, as shown in the bellowing figure.
So I have to cut off the wires, and find the conductor inside the wire, and then connect the additional wire to the connector.
Whether there is any ready-made product that I do not have to cut off the wire, and I can directly connect the additional wire into it easily. ??
Thanks.
Re: any connector between this kind of wire( SMA connector to UFL connector)
Splicing the coaxial cable is not the correct solution. It's just not feasible to do it without ruining its effectiveness. Instead find a second cable with SMA at both ends (male and female) and use that to extend the length.
Thanks, you are right that we can extend wire by adding another SMA connector.
Here I don't need to extend the wire. The only aim there is how to add the additional wire(red) to the original wire, and the added wire has its specific function during its application.
The problem is that as you said, how to add the additional wire without hurting the performance of the wire conducting. Is there any connector allow me to do that?
Sounds confused. You can't keep the cable performance without maintaining the transmission line geometry, using an inner and outer conductor with specific diameter ratio. Connecting only an "additional wire" is not possible.
You can possibly design a transition to a different transmission line geometry, but you need to keep the characteristic impedance.
