RenesasT
Full Member level 2
Hello All,
Hope you all are doing well.
I have a little query. My query is below:
I have interfaced HC05 Bluetooth module(slave) with my micro controller. Also I have attached second HC05 Bluetooth module(master) with another micro controller. connection and data sending is working fine. To check connection is establish or not, at master end I am reading STATE pin of HC05. It is giving both connection and disconnection status at master end. But what I should do at slave (receiver) end. The state pin at receiver/slave end only gives 0.4V after connection and gives mV after disconnection.
Please suggest, how to identify disconnection notification at slave/ receiver end.
Awaiting for your reply.
