+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 2
    Points: 595, Level: 5
    Join Date
    Oct 2015
    United Kingdom
    Posts
    21
    Points
    595
    Level
    Selection of op-amp to sense nA current.
    Hi all,
    I want to measure ultra low current (couple of nano ampere). Is there any special technique to measure such low currents or differntial voltage measurement across a series resistor (Rsense) will do ?
    Suggestions to select appropriate operational amplifier for low current measurment are required. Thank you in advance.
    Regards,
    Moeed
    I want to measure AC current. Maximum frequency is few hundred hertz.
    •   AltAdvertisment
  2. #2
    Super Moderator
    Points: 251,591, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    43,812
    Points
    251,591
    Level
    100
    Re: Selection of op-amp to sense nA current.
    Couple of nA isn't particularly low. Good "electrometer" OPs like OP129 have < 100 fA input current. Measurement "across a series resistor" involves a differential amplifier and respective common mode errors. Better to use a ground referred I/V converter OP (transimpedance amplifier) circuit, if ever possible.
    Leakage currents can be a problem, so high quality isolator (e.g. Teflon) and shielding/guarding is strongly suggested.
    1 members found this post helpful.
    •   AltAdvertisment
  3. #3
    Advanced Member level 5
    Points: 12,273, Level: 26
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,866
    Points
    12,273
    Level
    26
    for such low level measurement , better to use standard meters available.
    one such is keithley instruments (part of tektronix now)
    •   AltAdvertisment
  4. #4
    Super Moderator
    Points: 69,659, Level: 64
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    14,229
    Points
    69,659
    Level
    64
    I agree with FvM.
    Ive used the transimpedance amplifier and ADC solution to safely detect signals with 30pA threshold for an XRAY dosemeter.
    Careful desgin, well desgined amplifer circuit, well selected amplifiers, clean power supply, shielding (maybe guarding, more important at DC signals), proper PCB layout.....is essential.
    Especially for the transimpedance amplifier oyu need careful selection of OPAMP according current noise and voltage noise.
    Current noise is more important. But high frequency voltage noise is amplified because of (stray) capacitance of your input signal.
    Shielding of input signal wires adds capacitance..Here a series resistor at the input can be used to act as a low pass filter.
    Klaus
  5. #5
    Join Date
    Oct 2015
    United Kingdom
    Posts
    21
    Points
    595
    Level
    Thank you all for suggestions. I would go for TIA. I have LMP7721 in stock. Soon i will update about the progress.
    Cheers !
    Moeed
