ro0ter
Junior Member level 3
- Joined
- Jan 14, 2012
- Messages
- 26
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Cluj, Romania
- Activity points
- 1,656
Hello everyone,
It's been a while since I visited this forum, yet my bench PSU is now toasted but I do not know for what reason (last time it worked like a charm, but baby came and I did not turned it on at all in the past 6m).
It is a switching bench power supply able to provide 30v and 10a (never went above 5~6a). Indeed, it is a cheap PSU, but I'd rather repair it than replace it.
The PSU won't even start normally, its LCD backlight and digits are dimply flickering and a light click can be heard (although there are no relays inside). After I turn it off, the flickering is more rapid until it dies. The power on switch breaks both live and null.
I inspected thoroughly the PCB and found no swollen caps and no visible damage, but only a resistor which seemed very heated (couldn't distinguish the colors) but after desiring and measuring it I could tell it's 226k +/-1%, and the "browned" colors could be red-red-blue-orange-brown, indeed. This resistor sits next to the TNY277PN ic, at the enable / under voltage pin (will try to draw a schematic and upload it later on).
However, since the resistor seems functional, I'm not sure if I am wrong or not by suspecting it. It has a voltage drop off 265v while the device is on. I have not measured the 5v rail, but I suppose this is the problem; I would say the TNY277PN and the small-to-medium inductor next to it (plus passives, optocouplers) are producing the 5v required by the control circuitry. Will measure it later on today if the little one allows me .
If anyone had any advice or different assumption, I am open to follow it.
Thank you all!
Thank you all!
