Garurumon
LM385 datasheet: https://www.ti.com/lit/ds/symlink/lm158-n.pdf
My setup: https://obrazki.elektroda.pl/2925856800_1477180471.png
Hi again.
I need a bit of help.
"In the Linear Mode the Input Common-Mode Voltage Range Includes Ground and the Output voltage Can Also Swing to Ground, even though Operated from Only a Single Power Supply Voltage."
Does this means that I could get away with my circuit? I mean, does that mean that I will get 0V at op amp output for V+=0V, and that I'll get a constant increase in op amp output voltage/transistor current when I turn the potentiometer knob? Or does op amp has some other fancy property just waiting to ruin someone's day. :razz:
Quick circuit description: It's a dummy load. POT sets the voltage on V+ from 0-2V, V- = V+, so the op amp does it's thingy on the output to make the inputs equal, so it makes the inputs equal by letting the current through the transistors.
Note: It's still in progress, 7805 will actually be 7812, and few of the values are missing.
Also, if my idea is faulty in any other way, I'd like to know
Hi again.
