+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 3
    Points: 173, Level: 2
    Join Date
    Oct 2016
    Posts
    Points
    173
    Level
    Can I use sine wave transformer to square wave inverter kit board
    Hello
    I was made a sine wave base inverter transformer. now i want to use it to a square wave inverter kit board. can i do it?
    •   Alt18th October 2016, 10:03
      advertising
  2. #2
    Full Member level 4
    Points: 2,578, Level: 11
    Achievements:
    7 years registered
    Join Date
    Feb 2009
    Kolkata
    Posts
    193
    Points
    2,578
    Level
    11
    Re: Can I use sine wave transformer to square wave inverter kit board
    You may notice that the transformer of sine wave inverter has 0V - 8V primary to 0V - 220V/240V secondary winding. But for a square wave inverter kit, you require a transformer of 12V - 0V - 12V (Bifiler winding) primary to 0V - 230V secondary winding with a tap at 160/170V (for CCCV SCR/TRIAC charging). So normally it is not possible to use the transformer with square wave inverter kit. I am writing from my practical experience.
    •   Alt18th October 2016, 12:06
      advertising
  3. #3
    Full Member level 6
    Points: 2,845, Level: 12
    Join Date
    Sep 2013
    Posts
    331
    Points
    2,845
    Level
    12
    Yes
    Generally, sign wave transformer will handle the same power in square wave too
    While designing a transformer, sign or squire is an insignificant design parameter.
    According to area product method, sign wave transformer sizes are 10% less than square wave transformer.
