[SOLVED] drf1101 or cc1101 problem
fakourm
Newbie level 3
hi every body
i am working in drf1101 that it uses cc1101 for transiver . i can read and write its registers. but sometime the registers dont set currectly and i have confused.
also i cant send or recieve any data.
i use a board that design it by myself.
this is my code for transfer side
 * transiver mega2560-cc1101-test.c
 * Created: 10/01/2016 04:05:24 ب.ظ
 * Author : Ramin
#define F_CPU 16000000UL
#include <avr/io.h>
#include <util/delay.h>
#define SCK_PORT		PB1			// PORTB1
#define MISO_PIN    	PINB3		// PINB3
#define MOSI_PORT		PB2			// PORTB2
#define SS_PORT			PB5			// PORTB5
#define GDO0_PIN		PINB7		// PINB7
#define GDO2_PIN		PINB6		// PINB6
//***************************************CC1101 define**************************************************//
// CC1101 CONFIG REGSITER
#define CC1101_IOCFG2       0x00        // GDO2 output pin configuration
#define CC1101_IOCFG1       0x01        // GDO1 output pin configuration
#define CC1101_IOCFG0       0x02        // GDO0 output pin configuration
#define CC1101_FIFOTHR      0x03        // RX FIFO and TX FIFO thresholds
#define CC1101_SYNC1        0x04        // Sync word, high INT8U
#define CC1101_SYNC0        0x05        // Sync word, low INT8U
#define CC1101_PKTLEN       0x06        // Packet length
#define CC1101_PKTCTRL1     0x07        // Packet automation control
#define CC1101_PKTCTRL0     0x08        // Packet automation control
#define CC1101_ADDR         0x09        // Device address
#define CC1101_CHANNR       0x0A        // Channel number
#define CC1101_FSCTRL1      0x0B        // Frequency synthesizer control
#define CC1101_FSCTRL0      0x0C        // Frequency synthesizer control
#define CC1101_FREQ2        0x0D        // Frequency control word, high INT8U
#define CC1101_FREQ1        0x0E        // Frequency control word, middle INT8U
#define CC1101_FREQ0        0x0F        // Frequency control word, low INT8U
#define CC1101_MDMCFG4      0x10        // Modem configuration
#define CC1101_MDMCFG3      0x11        // Modem configuration
#define CC1101_MDMCFG2      0x12        // Modem configuration
#define CC1101_MDMCFG1      0x13        // Modem configuration
#define CC1101_MDMCFG0      0x14        // Modem configuration
#define CC1101_DEVIATN      0x15        // Modem deviation setting
#define CC1101_MCSM2        0x16        // Main Radio Control State Machine configuration
#define CC1101_MCSM1        0x17        // Main Radio Control State Machine configuration
#define CC1101_MCSM0        0x18        // Main Radio Control State Machine configuration
#define CC1101_FOCCFG       0x19        // Frequency Offset Compensation configuration
#define CC1101_BSCFG        0x1A        // Bit Synchronization configuration
#define CC1101_AGCCTRL2     0x1B        // AGC control
#define CC1101_AGCCTRL1     0x1C        // AGC control
#define CC1101_AGCCTRL0     0x1D        // AGC control
#define CC1101_WOREVT1      0x1E        // High INT8U Event 0 timeout
#define CC1101_WOREVT0      0x1F        // Low INT8U Event 0 timeout
#define CC1101_WORCTRL      0x20        // Wake On Radio control
#define CC1101_FREND1       0x21        // Front end RX configuration
#define CC1101_FREND0       0x22        // Front end TX configuration
#define CC1101_FSCAL3       0x23        // Frequency synthesizer calibration
#define CC1101_FSCAL2       0x24        // Frequency synthesizer calibration
#define CC1101_FSCAL1       0x25        // Frequency synthesizer calibration
#define CC1101_FSCAL0       0x26        // Frequency synthesizer calibration
#define CC1101_RCCTRL1      0x27        // RC oscillator configuration
#define CC1101_RCCTRL0      0x28        // RC oscillator configuration
#define CC1101_FSTEST       0x29        // Frequency synthesizer calibration control
#define CC1101_PTEST        0x2A        // Production test
#define CC1101_AGCTEST      0x2B        // AGC test
#define CC1101_TEST2        0x2C        // Various test settings
#define CC1101_TEST1        0x2D        // Various test settings
#define CC1101_TEST0        0x2E        // Various test settings
#define 	WRITE_BURST     	0x40		//
#define 	READ_SINGLE     	0x80		//     IN CC1101
#define 	READ_BURST      	0xC0		//
#define 	BYTES_IN_RXFIFO     0x7F 		//
//CC1101 Strobe commands
#define CC1101_SRES         0x30        // Reset chip.
#define CC1101_SFSTXON      0x31        // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL=1).
// If in RX/TX: Go to a wait state where only the synthesizer is
// running (for quick RX / TX turnaround).
#define CC1101_SXOFF        0x32        // Turn off crystal oscillator.
#define CC1101_SCAL         0x33        // Calibrate frequency synthesizer and turn it off
// (enables quick start).
#define CC1101_SRX          0x34        // Enable RX. Perform calibration first if coming from IDLE and
// MCSM0.FS_AUTOCAL=1.
#define CC1101_STX          0x35        // In IDLE state: Enable TX. Perform calibration first if
// MCSM0.FS_AUTOCAL=1. If in RX state and CCA is enabled:
// Only go to TX if channel is clear.
#define CC1101_SIDLE        0x36        // Exit RX / TX, turn off frequency synthesizer and exit
// Wake-On-Radio mode if applicable.
#define CC1101_SAFC         0x37        // Perform AFC adjustment of the frequency synthesizer
#define CC1101_SWOR         0x38        // Start automatic RX polling sequence (Wake-on-Radio)
#define CC1101_SPWD         0x39        // Enter power down mode when CSn goes high.
#define CC1101_SFRX         0x3A        // Flush the RX FIFO buffer.
#define CC1101_SFTX         0x3B        // Flush the TX FIFO buffer.
#define CC1101_SWORRST      0x3C        // Reset real time clock.
#define CC1101_SNOP         0x3D        // No operation. May be used to pad strobe commands to two
// INT8Us for simpler software.
//CC1101 STATUS REGSITER
#define CC1101_PARTNUM      0x30
#define CC1101_VERSION      0x31
#define CC1101_FREQEST      0x32
#define CC1101_LQI          0x33
#define CC1101_RSSI         0x34
#define CC1101_MARCSTATE    0x35
#define CC1101_WORTIME1     0x36
#define CC1101_WORTIME0     0x37
#define CC1101_PKTSTATUS    0x38
#define CC1101_VCO_VC_DAC   0x39
#define CC1101_TXBYTES      0x3A
#define CC1101_RXBYTES      0x3B
//CC1101 PATABLE,TXFIFO,RXFIFO
#define CC1101_PATABLE      0x3E
#define CC1101_TXFIFO       0x3F
#define CC1101_RXFIFO       0x3F
unsigned char  txBuffer[] = {0x04,0x5b,0x25,4,5};
unsigned char  rxBuffer[61];    // Length unsigned char  + 2 status unsigned chars are not stored in this buffer
unsigned char in1=0,in2=0,in3=0,in4,in5,in6,in7,in8,in9,in10,in11aMARCSTATE,in12,in13,in14,timout,size1,d1,d2,i;  // FOR TESTING
void SpiInit(void)
{        //            SCK        MOSI      MISO       CS       GDO2       GDO0
	DDRB = (1<<DDB0)|(1<<DDB1)|(1<<DDB2)|(0<<DDB3)|(1<<DDB5)|(0<<DDB6)|(0<<DDB7);
	//Enable SPI master mode
	SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR0);
unsigned char SpiTransfer(unsigned char Data)
	SPDR = Data;
	while(!(SPSR & (1<<SPIF)));
	return SPDR;
void reset_CC1101(void)
	PORTB &= ~(1<<SS_PORT);
	_delay_ms(1);
	PORTB |= 1<<SS_PORT;
	_delay_ms(1);
	while (PINB & (1<< MISO_PIN));
	SpiTransfer(CC1101_SRES);         // Reset chip.
void Init(void)
	SpiInit();
	PORTB = 1<<SS_PORT;
	PORTB = 1<<SCK_PORT;
	PORTB = 0<<MOSI_PORT;
	reset_CC1101();
void SpiWriteReg(unsigned char addr, unsigned char data)
	SpiTransfer(addr);
	SpiTransfer(data);
void SpiWriteBurstReg(unsigned char addr,unsigned char *buffer, unsigned char size)
	unsigned char i, temp;
	temp = addr | WRITE_BURST;
	SpiTransfer(temp);
	for(i=0;i<size;i++)
		SpiTransfer(buffer[i]);
void SpiStrobe(unsigned char strobe)
	SpiTransfer(strobe);
unsigned char SpiReadReg(unsigned char addr)
	unsigned char temp, data;
	//	changed status_register
	temp = addr|READ_SINGLE;
	SpiTransfer(temp);
	data = SpiTransfer(0);
	return data;
void SpiReadBurstReg(unsigned char addr, unsigned char *buffer, unsigned char size)
	temp = addr|READ_BURST;
	SpiTransfer(temp);
	for(i=0;i<size;i++)
		buffer[i] = SpiTransfer(0);
unsigned char SpiReadStatus(unsigned char addr)
	unsigned char data, temp;
	SpiTransfer(temp);
	return data;
void SendData(unsigned char *txBuffer, unsigned char size)
	SpiWriteReg(CC1101_TXFIFO,size);
	SpiWriteBurstReg(CC1101_TXFIFO,txBuffer,size);
	SpiStrobe(CC1101_STX);
	while(!(PINB & (1<< GDO0_PIN)));
	while(PINB & (1<< GDO0_PIN));
	SpiStrobe(CC1101_SFTX);
unsigned char ReceiveData(unsigned char *rxBuffer)
	unsigned char size, status[2];
			SpiStrobe(CC1101_SRX);
	if(SpiReadStatus(CC1101_RXBYTES) & BYTES_IN_RXFIFO)
		size = SpiReadReg(CC1101_RXFIFO);
		SpiReadBurstReg(CC1101_RXFIFO,rxBuffer,size);
		SpiReadBurstReg(CC1101_RXFIFO,status,2);
						SpiStrobe(CC1101_SIDLE);
		SpiStrobe(CC1101_SFRX);
		return size;
	else
		return 0;
void RegConfigSettings1(void)
	SpiWriteReg(CC1101_FSCTRL1,0x0C);
	SpiWriteReg(CC1101_FSCTRL0,0x00);
	SpiWriteReg(CC1101_FREQ2,0x10);
	SpiWriteReg(CC1101_FREQ1,0xA7);
	SpiWriteReg(CC1101_FREQ0,0x62);
	SpiWriteReg(CC1101_MDMCFG4,0x2D);
	SpiWriteReg(CC1101_MDMCFG3,0x3B);
	SpiWriteReg(CC1101_MDMCFG2,0x13);
	SpiWriteReg(CC1101_MDMCFG1,0x22);
	SpiWriteReg(CC1101_MDMCFG0,0xF8);
	SpiWriteReg(CC1101_CHANNR,0x00);
	SpiWriteReg(CC1101_DEVIATN,0x62);
	SpiWriteReg(CC1101_FREND1,   0xB6);
	SpiWriteReg(CC1101_FREND0,   0x10);
	SpiWriteReg(CC1101_MCSM0 ,   0x18);
	SpiWriteReg(CC1101_FIFOTHR ,  0x07);
	SpiWriteReg(CC1101_FOCCFG,   0x1D);
	SpiWriteReg(CC1101_BSCFG,    0x1C);
	SpiWriteReg(CC1101_AGCCTRL2, 0xC7);
	SpiWriteReg(CC1101_AGCCTRL1, 0x00);
	SpiWriteReg(CC1101_AGCCTRL0, 0xB0);
	SpiWriteReg(CC1101_FSCAL3,   0xEA);
	SpiWriteReg(CC1101_FSCAL2,   0x2A);
	SpiWriteReg(CC1101_FSCAL1,   0x00);
	SpiWriteReg(CC1101_FSCAL0,   0x1F);
	SpiWriteReg(CC1101_FSTEST,   0x59);
	SpiWriteReg(CC1101_TEST2,    0x88);
	SpiWriteReg(CC1101_TEST1,    0x31);
	SpiWriteReg(CC1101_TEST0,    0x09);
	SpiWriteReg(CC1101_IOCFG2,   0x29); 	//serial clock.synchronous to the data in synchronous serial mode
	SpiWriteReg(CC1101_IOCFG0,   0x06);  	//asserts when sync word has been sent/received, and de-asserts at the end of the packet
	SpiWriteReg(CC1101_PKTCTRL1, 0x04);		//two status unsigned chars will be appended to the payload of the packet,including RSSI LQI and CRC OK
	//No address check
	SpiWriteReg(CC1101_PKTCTRL0, 0x05);		//whitening off;CRC Enable£»variable length packets, packet length configured by the first unsigned char after sync word
	SpiWriteReg(CC1101_ADDR,0x00);		//address used for packet filtration.
	SpiWriteReg(CC1101_PKTLEN,   0xFF); 	//61 unsigned chars max length
void RegConfigSettings2(void)
	SpiWriteReg(CC1101_FSCTRL1,0x08);
	SpiWriteReg(CC1101_MDMCFG4,0x5B);
	SpiWriteReg(CC1101_MDMCFG3,0xF8);
	SpiWriteReg(CC1101_MDMCFG2,0x03);
	SpiWriteReg(CC1101_DEVIATN,0x47);
	SpiWriteReg(CC1101_AGCCTRL0, 0xB2);
	SpiWriteReg(CC1101_FSCAL0,   0x11);
	SpiWriteReg(CC1101_TEST2,    0x81);
	SpiWriteReg(CC1101_TEST1,    0x35);
	SpiWriteReg(CC1101_IOCFG2,   0x0B); 	//serial clock.synchronous to the data in synchronous serial mode
	//No address check
	SpiWriteReg(CC1101_PKTLEN,   0x3D); 	//61 unsigned chars max length
void RegConfigSettings3(void)
	SpiWriteReg(CC1101_IOCFG0  ,0x06);
	SpiWriteReg(CC1101_FIFOTHR ,0x47);
	SpiWriteReg(CC1101_PKTCTRL0,0x05);
	SpiWriteReg(CC1101_FSCTRL1 ,0x06);
	SpiWriteReg(CC1101_FREQ2   ,0x10);
	SpiWriteReg(CC1101_FREQ1   ,0xB1);
	SpiWriteReg(CC1101_FREQ0   ,0x3B);
	SpiWriteReg(CC1101_MDMCFG4 ,0xFE);
	SpiWriteReg(CC1101_MDMCFG3 ,0x43);
	SpiWriteReg(CC1101_MDMCFG2 ,0x1B);
	SpiWriteReg(CC1101_DEVIATN ,0x15);
	SpiWriteReg(CC1101_MCSM0   ,0x18);
	SpiWriteReg(CC1101_FOCCFG  ,0x16);
	SpiWriteReg(CC1101_WORCTRL ,0xFB);
	SpiWriteReg(CC1101_FSCAL3  ,0xEA);
	SpiWriteReg(CC1101_FSCAL2  ,0x2A);
	SpiWriteReg(CC1101_FSCAL1  ,0x00);
	SpiWriteReg(CC1101_FSCAL0  ,0x1F);
	SpiWriteReg(CC1101_TEST2   ,0x81);
	SpiWriteReg(CC1101_TEST1   ,0x35);
	SpiWriteReg(CC1101_TEST0   ,0x09);
void RegConfigSettings4(void)
	SpiWriteReg(CC1101_IOCFG2,0x29); 	//serial clock.synchronous to the data in synchronous serial mode
	SpiWriteReg(CC1101_IOCFG1,0x2e);
	SpiWriteReg(CC1101_IOCFG0,0x06);  	//asserts when sync word has been sent/received, and de-asserts at the end of the packet
	SpiWriteReg(CC1101_FIFOTHR,0x47);
	SpiWriteReg(CC1101_SYNC1,0xd3);
	SpiWriteReg(CC1101_SYNC0,0x91);
	//no address check
	SpiWriteReg(CC1101_FSCTRL1,0x06);
	SpiWriteReg(CC1101_FREQ1,0xb1);
	SpiWriteReg(CC1101_FREQ0,0x3a);
	SpiWriteReg(CC1101_MDMCFG4,0xf5);
	SpiWriteReg(CC1101_MDMCFG3,0x83);
	SpiWriteReg(CC1101_DEVIATN,0x15);
	SpiWriteReg(CC1101_MCSM2 ,   0x07);
	SpiWriteReg(CC1101_MCSM1 ,   0x3f);
	SpiWriteReg(CC1101_FOCCFG,   0x16);
	SpiWriteReg(CC1101_WOREVT1,   0x87);
	SpiWriteReg(CC1101_WOREVT0,   0x6b);
	SpiWriteReg(CC1101_WORCTRL,   0xfb);
	SpiWriteReg(CC1101_FSCAL3,   0xE9);
	SpiWriteReg(CC1101_FSCAL0,   0x1f);
	SpiWriteReg(CC1101_RCCTRL1, 0x41);
	SpiWriteReg(CC1101_RCCTRL0, 0x00);
	SpiWriteReg(CC1101_PTEST,   0x7f);
	SpiWriteReg(CC1101_AGCTEST,   0x3f);
	SpiWriteReg(CC1101_PATABLE,   0xc8);
int main(void)
		DDRE = 1<<DDE0;
		PORTE |=1<<PE1;
	 Init();
	 RegConfigSettings4();  // setting
	while (1)
  in1 = SpiReadReg(CC1101_IOCFG0); // 06
  in2 = SpiReadReg(CC1101_PKTLEN);  // 3d
  in3 = SpiReadReg(CC1101_MDMCFG4);//f5
  in4 = SpiReadReg(CC1101_FSCAL2); //2a
  in5 = SpiReadReg(CC1101_MDMCFG2); //13
  in6 = SpiReadReg(CC1101_FREQ1); //b1
  in7 = SpiReadReg(CC1101_DEVIATN); //15
  in8 = SpiReadReg(CC1101_AGCCTRL2);  //c7                       //these codes are for testing
  in9 = SpiReadReg(CC1101_FREQ2);  //10
  in10 = SpiReadReg(CC1101_AGCCTRL0); //b0
  in11aMARCSTATE = SpiReadStatus(CC1101_MARCSTATE);
  in12 = SpiReadReg(CC1101_TEST1); //35
  in13 = SpiReadReg(CC1101_TEST2); //81
  in14 = SpiReadReg(CC1101_FSCAL0); //1f
  timout = SpiReadReg(CC1101_MCSM2); //07
d1=SpiReadStatus(CC1101_TXBYTES);
         if (!(PINE & (1<< PINE1)))
	         _delay_ms(30);
		     in3=SpiReadStatus(CC1101_TXBYTES);   // txbytes is 6 bytes
	         if (!(PINE & (1<< PINE1)) && in3 ==6 )
	    			     _delay_ms(1500);
					    PORTE |= 1<< PE0;
  				        _delay_ms(1500);
	  	 			    PORTE &= ~(1<<PE0);
	  		           while(!(PINB & (1<< GDO0_PIN)));  // for sync bytes
	  		           while(PINB & (1<< GDO0_PIN));      // for data that it is sent
				       while(!(PINE & (1<< PINE1)));	// for button
				         in11aMARCSTATE=SpiReadStatus(CC1101_MARCSTATE);
	   	  	 	         in2=SpiReadStatus(CC1101_TXBYTES); // length of tx buffer
		if ((in11aMARCSTATE==0x13||in11aMARCSTATE==0x0D)&& in2==6 )
			for (i==0;i<=50;i++)
		        _delay_ms(80);
			     PORTE |= 1<< PE0;
  			    _delay_ms(80);
	  	 	     PORTE &= ~(1<<PE0);
help me please:sad:
thank friends.
now i can send data and check it with marcstate byte in cc1101, but when i use SRX command(receive mode),marcstate byte sometime shows 0x0d(receive mode) and sometime show 0xf1. why? i use Atmel_ICE debugger.
I solved my friends :))))))
first i chacked hardware after that write codes.
my problems were in board,incurrect register and false ctrystal for atmega8a in 3.3v.
for programing, u can use TI's examples for cc1101 with 8051.
