+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 5
    Points: 999, Level: 7
    Join Date
    Oct 2014
    Posts
    85
    Points
    999
    Level
    7
    Problems synthesizing AES code
    Hello All,
    I am trying to synthesize AES encryption algorithm in vivado which was uploaded on open cores as shown in the link below
    http://opencores.org/project,aes-128...ned_encryption
    When I synthesize it, i get the following errors
    [Place 30-415] IO Placement failed due to overutilization. This design contains 258 I/O ports
    while the target device: 7z020 package: clg400, contains only 255 available user I/O. The target device has 255 usable I/O pins of which 0 are already occupied by user-locked I/Os.
    To rectify this issue:
    1. Ensure you are targeting the correct device and package. Select a larger device or different package if necessary.
    2. Check the top-level ports of the design to ensure the correct number of ports are specified.
    3. Consider design changes to reduce the number of I/Os necessary.
    [Place 30-68] Instance clk_IBUF_BUFG_inst (BUFG) is not placed
    [Place 30-99] Placer failed with error: 'IO Clock Placer failed'
    Please review all ERROR, CRITICAL WARNING, and WARNING messages during placement to understand the cause for failure.
    Can someone tell me how to rectify these errors?
  2. #2
    Points: 8,117, Level: 21
    Achievements:
    7 years registered Created Blog entry
    dpaul's Avatar
    Join Date
    Jan 2008
    Germany
    Posts
    1,207
    Points
    8,117
    Level
    21
    Blog Entries
    Re: Problems synthesizing AES code
    Without going into the design details (AES encryption details)...
    What can be done is already mentioned in simple English #1 to #3.
    If you cannot use a larger device (#1) then go to #3.
    I am assuming you have specified the correct no. of top-level ports (#2), else re-check.
    If #1 is not feasible then #3 is your only option. Reduce the encrypt key size and data.
    I see in the module Top_PipelinedCipher,
    parameter DATA_W = 128, //data width
    parameter KEY_L = 128, //key length
    So use 64bits or 96bits or some other value as per your project requirements. I will not look into the RTL details, but the fact that the data & key are parameterized suggests that changes might be easily done at the top-level.
    FPGA enthusiast!
    •   AltAdvertisment
  3. #3
    Advanced Member level 5
    Points: 37,347, Level: 47
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,792
    Points
    37,347
    Level
    47
    Even when you have compiled it, what do you intend to do with it?
    This core is not intended as a top level design, it's an IP block for you to put into your design.
    You could easily write a top level wrapper around the core to make it fit and not completly remove all the logic. If you were using Quartus you could use virtual pins to avoid IO limitations, but as it's xilinx you get no such option.
    1 members found this post helpful.
    •   AltAdvertisment
  4. #4
    Achievements:
    dpaul's Avatar
    Join Date
    Jan 2008
    Germany
    Posts
    1,207
    Points
    8,117
    Level
    21
    Blog Entries
    Correct! If implemented as a non top-level module then this is no problem.
    Probably the OP has such an intention, and is currently analyzing the implementation ability of the free core. Might have inadvertently used it as a top-module.
    FPGA enthusiast!
    •   AltAdvertisment
  5. #5
    Super Moderator
    Points: 30,238, Level: 42
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,969
    Points
    30,238
    Level
    42
    Quote Originally Posted by TrickyDicky View Post
    Tell the synthesis tool to not insert I/O, Vivado allows you to make dcp files with no I/O, but as I recall that will require you disable logic removal during place and route (inflating the resource utilization).
    The other option is to add a shift register for all inputs and all outputs that don't go to pins and tie the SDO/SDI pins of the shift register to pins, compile that to get a resource estimation and to see if it will meet your clock frequency constraints. That way you'll restrict the number of pins used to clock, reset, in_sdo, in_sdi, out_sdo, out_sdi, out_en (used to select between the output of the UUT and the shifting data). The whole idea here is to have a non-functional design for resource estimation.
    If you need to test the design add Vivado debug cores to the design to drive the I/Os of the UUT with the VIOs and capture outputs with ILAs.
  6. #6
    Member level 5
    Join Date
    Oct 2014
    Posts
    85
    Points
    999
    Level
    7
    Hello ads-ee, i have to connect this AES IP core to AXI module and make an internal IP out of it with no I/O's going external of the FPGA. All the I/O's of the AES IP core have to be converted into internal nets. How am i supposed to do it? Do you have any example or document which explains this procedure?
  7. #7
    Achievements:
    dpaul's Avatar
    Join Date
    Jan 2008
    Germany
    Posts
    1,207
    Points
    8,117
    Level
    21
    Blog Entries
    Put the AES IP core and the AXI module in a new top-level and then it is ready to be used as an internal IP. Defining the input and outputs ports of the new top-level module and port-mapping them to the AES IP core and the AXI module is all you need to do.
    FPGA enthusiast!
  8. #8
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,969
    Points
    30,238
    Level
    42
    Quote Originally Posted by Sunayana Chakradhar View Post
    Huh? It's a IP core it shouldn't have any IO primitives in it. You should be able to instantiate it in a top-level module and create signals/wires to connect to it and your other AXI module(s).
    If you need tutorials on instantiating modules in other modules, then you really need to learn the language basics before tackling a project like this.
    •   AltAdvertisment
  9. #9
    Points: 7,803, Level: 21
    Join Date
    Apr 2016
    Posts
    1,642
    Points
    7,803
    Level
    21
    this type of thing can even be done with the graphical interface in vivado. I don't understand what is the struggle here.
