design compiler symbol library
hamidmoallemi
Full Member level 2
Hi
I am using Synopsys design compiler as synthesize tool , I have PDK from a vendor that doesn't have symbol library then I can't do synthesize in design vision.
is this library needed if I don't use gui and don't need to se schematics ?
and is there any way to synthesize without this library ?
do you have any suggestion for this
thanks in advance
Hamid
The symbol library (*.sdb) can not affect to the synthesis of Design Compiler tool. Can you show the TCL script to synthesize your design?
Maybe, you setup the values of link_library or search_path variables incorrect!!!
thank you for the response,
I checked setup parameters there is no problem with that
maybe this is because I use GUI , in this mode *.sdb is mandatory
I should check dc_shell
