+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 2
    Points: 1,216, Level: 7
    Join Date
    Nov 2014
    Posts
    127
    Points
    1,216
    Level
    7
    Lo voltage CMOS ciruits
    Can anyone tell me the use of low voltage power supply? the motivation for using low VDD in analog circuits especially OTAs? In many research articles I have read that its mentioned low voltage low power circuits. I can understand about low power but why low voltage what advantages we get other then low power consumption?
    •   AltAdvertisment
  2. #2
    Super Moderator
    Points: 50,445, Level: 54
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    12,407
    Points
    50,445
    Level
    54
    Re: Lo voltage CMOS ciruits
    Lower voltage allows use of fewer batteries, and/or longer use from them.
    Also increased miniaturization.
    Also less heat production.
    Electrolytic capacitors with lower voltage ratings are smaller and cheaper.
    •   AltAdvertisment
  3. #3
    Advanced Member level 5
    Points: 38,224, Level: 47
    Join Date
    Mar 2008
    USA
    Posts
    6,181
    Points
    38,224
    Level
    47
    For analog blocks low voltage is "what you do because
    you must", not "what you want to do for analog quality".
    Ability to integrate trumps ultimate performance. Of
    course running off one cell or less, for a very long time
    has value in things like hearing aids, low-maintenance
    remote devices (IoT) and so on. Nobody wants a +/-15V,
    10mA op amp in their Apple Watch. But more to the point
    they could not embed it inside their cost-crushed, mondo
    volume Far East vanilla CMOS foundry process.
    Functional (digital) density drives lithography drives device
    working voltage, and your analog functions are just along
    for the ride if you go by percentage of content. And then
    the cost position and the declining voltage of surrounding
    circuitry drags support parts (ADCs, DACs, signal conditioning)
    along with it, at some lag.
