richaphy
I have made a simple transmission gate with one input (for signal with sinusiodal voltage input V0), a control (logic 0/1 to make switch On /OFF, with dc voltgae) and an output across a resistor.
I want to do the noise analysis of this circuit.
1) Since it is not a differential circuit, how can i have positive and negative output nodes, for output noise? Can I use ground as one output node?
2) For input noise, Input voltage source should be the the input sin voltage V0. But software is neither selecting the vsin as source or any of its ports.
