Like: Where can I use a motor with 3000 Rpm?
Usually you have an application or a problem and you try to find a solution, than the other way round.
The next is that a filter is not specified only with the frequencies: Maybe you have a filter for an RF receiver in your hand, but it can't be used for 230V AC mains applications.
