Bjtpower
Full Member level 5
Dear Friends
I want to use the PNP Transistors as a switch which can be CONTROLLED from a uControllers of 3.3V/0V.
I am applying a +12v at the Emitter..
i want to use the Pull up resistor at the base.
I am confused for
1)If High Signal(3.3v) From uCONTROLLERS then what will be the output..??
2) If 0v from uCONTROLLERS what will be the output?
Driving a load at the collector to Gnd..
Pls help with the base resistor calculations as pull up resistor calculation for 500mA OF CURRENT thru the bjt
I am confused for
