Non isolated dc- dc converter
Bjtpower
Full Member level 5
I am looking to design a Non-isolated DC-DC Converter with POWER Integration Tool.
Input specs:90-270VAC
Output:12v-500mA (Max)
The design should be transformeless.. can include only inductors cos it is Non-isolated converter.
I have gone thru Linkswitch in PI-Expert, But i am not getting the Non isolated design options.
Kindly Help with weblinks
Marx
Using a flyback converter with small transformer will give much better efficiency than a single inductor buck converter, whether you want an isolated design or not. Because the switched power of a buck converter is input current * output current, resulting in respective switching losses. A Vin/Vout ratio above 20 isn't suitable for a buck converter.
Marx
If you cannot use transformers... and keep high efficiency maybe you have to employ interleaved bucks.
As FvM says... i think it's not a good idea to use buck converter...but here it is a simple calculator to design it fastly:
https://www.daycounter.com/Calculators/Switching-Converter-Calculator.phtml
