David_
Advanced Member level 2
Hello.
First I will explain what situation this is regarding and it might not be of any interest for some, so if you don't want to read all that scroll down until a Bold statement comes, after that it is the electronic stuff.
I don't know how many of you are smokers/nicotine addicts, not that you have to be that to know what "vaping" is.
But for anyone who don't know about vaping, it's the use of technologies to evaporate a mixture of nicotine diluted in PG and/or VG.
PG = Propylene Glycol also called propane-1,2-diol or α-propylene glycol(an organic compound with chemical formula C3H8O2, amongst other uses it is used in food processing as the E-number E1520, farmers are known to dilute the cattles water supply with Propylene Glycol during winters to keep it from freezing)
VG = Vegetable Glycerin or propane-1,2,3-triol(is used in a lot of food and cosmetic products as well as soaps and god knows what else)
Also you add flavor additives and then you "vape" it in a atomizer, there have been real academic research done about this quite extensively and it has been proven to be at least 95% less harmful than smoking tobacco, so I have switched all my tobacco usage to vaping instead and it's great.
The devices used to vaporize the liquid comes in many forms and I use the more serious so called MOD which is a device containing often extra batteries as opposed to e-cigarettes which has very weak batteries, but also have more firmware to control the wattage, temperature and other things. And the way I do it you have to wind your own coils to be used as the heat element(this is done with Kanthal, Stainless-steel, Nichrome or other metals), which is all a fun hobby, but enough about this.
Li-Ion Safety
Currently I have a setup on a device that is using 2 18650 Li-Ion 2100mA/h batteries in series and I generally use the device at a setting of 40W, in any case I have two use cases. One is drawing 17,7A and the other is drawing 14,7A, and with a battery with 2100mA/h I then get about 7 or 8,5 minutes of usage before the battery is drained.
I am using 2 Sony VTC4 IMR 18650 High Drain Flat top 2100mA/h batteries in series, if I am draining 17,7A how long will it last?
I am very unsure about how I got the following number but am I right that it should give me about 7 minutes?
I would like at least double that but the sites selling batteries for vaping MODs advices that only high quality batteries like these should be used.
What dangers could you see with using batteries from ebay with 6800mA/h (assuming there discharge rate is high enough)?
Just to say, when I use the device I am activating it first for 10seconds after which I activate it for 3 seconfs each inhale, if the coils have cooled down then I activate it for 10 seconds again and then continue with 3 second activations, so those 7 minutes is spread out over a few hours.
Li-Ion Safety
