eyeow
Junior Member level 1
Hi all,
I have a oscilloscope Lecroy Wave Ace 2014 (100MHz max input volt 400Vpk Cat I) with Lecroy PP016 probe (300MHz 10:1 10Mohm 12pF 600V(DC+pk.AC) Cat II rating)
The scope itself has the probe setting range from 1x to 1000x. So it should be able to view 5V - 5kV/div in the screen.
I wonder whether I could use my existing scope and probe on voltage after bridge rectifier where the Vpeak value is range 280 ~ 336V as shown in the diagram below without damaging my scope and probe?
Or do I need to get a probe that has 100:1 attenuation feature and with higher max input voltage rating? Or I need to upgrade to High Voltage Passive Probe?
a) MULTI-CONTACT 68.9838-120-23 Oscilloscope Probe, 300 MHz, High-Voltage Passive Probe, 1 kV, 100:1 (cheap cost)
b) TEKTRONIX P5122 Oscilloscope Probe, 200 MHz, High-Voltage Passive Probe, 1 kV, 100:1 (moderate cost)
c) LeCroy HVP120 Oscilloscope Probe 400MHz (expensive)
Thanks...Hope can get some advises..
