How to implement modbus protocol using uart
SivaHari
Newbie level 3
I want to manipulate the data using Modbus protocol over UART and i decided to use PIC24 series microcontroller to implement this process. I studied little bit about MODBUS protocol, but in that their using MTCP gateway as a intermediator. but still i did't get that how to implement this protocol over UART.
There also two interfaces
1. RS232/485
2. Ethernet (TCP/IP)
Two transmission modes
1. ASCII mode
2. RTU mode
I planned to use via RS232. but i can't to decide which Transmission mode is convenient. please kindly some one give idea about this process.
RTU is commonly used. For the implementation details, study the documents available at Modbus.org
There are also various code examples on the internet.
1. RS232/485
I'd say three:
1. RS232
2. RS485
3. Ethernet (TCP/IP)
1. RS232/485
In terms of MODBUS specification, they are different transport protocols, not only interfaces
1. MODBUS over serial
2. MODBUS over TCP
Anyway, I do not recomend to use 232.
485 much more relable.
Basicaly, we can use any phisical layer for MODBUS. But I think, CAN fit better. It has many h/w realized things like confirmation and CRC checking.
No reason to use such old interfaces in out century.
Objection! Apparently there are many reasons to use it today. You'll find that most HMI devices support as a standard protocol, multi-protocol converters like the HMS Anybus devices have MODBUS as a common protocol, etc., etc.
RS232 layer isn't suitable for actual bus (multi-drop) topologies, in so far MODBUS over serial mostly uses RS485.
