Want to understand following specification terms for Home Theater 2.1
shroff_rushi
Need to know exact definition of following terms..
PMPO output, Source input, Frequency response, S/N ratio, Distortion, Output Power, Separation, Input sensitive, Hum-noise output, Satellite impedance, Subwoofer impedance, Power consumption, Power supply SMPS Type, Satellite Dimension, Subwoofer Dimension
Those are very basic English words.
1) Learn the English language.
2) Look at the definition of the words in a dictionary.
3) Look at the words in Google.
peak music power output
the dependence on signal frequency of the output–input ratio of an amplifier or other device.
Signal-to-noise ratio (abbreviated SNR or S/N) is a measure used in science and engineering that compares the level of a desired signal to the level of background noise. It is defined as the ratio of signal power to the noise power, often expressed in decibels.
what are you doing ?
