[SOLVED] SystemVerilog access members of multidimensional array of struct
logari84
Newbie level 6
Hi all,
I will try to explain what my question is. To make it more clear lets make an example. I have the struct:
typedef struct packed{
logic[`PR_ADDRESS_WIDTH-1:0] address;
logic[`ADC_CODE_WIDTH-1:0] adc0_code;
logic[`ADC_CODE_WIDTH-1:0] adc1_code;
logic[`ADC_CODE_WIDTH-1:0] adc2_code;
logic[`ADC_CODE_WIDTH-1:0] adc3_code;
} T_ENCODED_ADDR_ADC;
In one of my modules I use as input an array of T_ENCODED_ADDR_ADC:
input T_ENCODED_ADDR_ADC [`NUM_OF_REGIONS-1:0] data_in;
Then I need to pass each adc_code to a shifting unit, so I have:
shifter32b shifting_unit[0:3][`NUM_OF_REGIONS-1:0](port mapping here)
where in parenthesis I should map the ports.
I need [0:3] shifting units for each REGION because I have 4 adc_codes:
Nth adc0_code -> 0 index of Nth REGION
Nth adc1_code -> 1 index of Nth REGION
Nth adc2_code -> 2 index of Nth REGION
Nth adc3_code -> 3 index of Nth REGION
The question is: How can I easily map only the adc_codes and not the address of T_ENCODED_ADDR_ADC?
Hope my question is clear enough. If not ask anything.
Thank you in advance!
Anyway. I was looking for a "smart" fast way. In the end I used generate to make the instances of my module.
