[moved] rfid reader 125khz in vhdl
o-man
Newbie level 5
how to program the rfid reader in vhdl .. i use FPGA kit
Get the spec for the rfid reader, a book on VHDL and write a FSM to communicate with the rfid reader using whatever protocol that is defined in the devices spec is how you program the rfid reader using VHDL.
For a more specific answer about a specific problem, ask a specific question, instead of a generic, "Help me, I don't know what to do."
i mean the steps ..
i have read uart code but i dont have any idea about the next step what i have to do
If the RFID reader uses a UART communication protocol, then determine what is required to program it to function the way you want and then write an FSM to send those bytes to the UART to perform the writes and reads of the RFID registers.
Reactions: o-man
    o-man
can yuo help me to detect the error
when i connect the rfid reader with kit doesn't give me the condition i want
>>>>code >>>>>
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
--RFID TOP-LEVEL DESIGN
library IEEE;
use IEEE.std_logic_1164.all;
ENTITY RFID IS
--I/O PINS
PORT (
    CLK, RESET,R_X : IN STD_LOGIC;
     A_o: out std_logic_vector (4 downto 0);
     FLAG_o: OUT STD_LOGIC
END ENTITY;
ARCHITECTURE CKT OF RFID IS
--COMPARE COMPONENT
COMPONENT compare is
generic(W: integer := 8);
port(
clk, reset: in std_logic;
clr_flag, set_flag: in std_logic;
din: in std_logic_vector(w-1 downto 0);
a: out std_logic_vector (4 downto 0);
flag: out std_logic
END COMPONENT;
--BAUD RATE GENERATOR COMPONENT
COMPONENT mod_326 is
generic(
N: integer := 9;
M: integer := 326
port(
max_tick: out std_logic;
q: out std_logic_vector(N-1 downto 0)
end COMPONENT;
--SERIAL RECIEVER COMPONENT
COMPONENT UART_1 is
generic(
DBIT: integer := 8;
SB_TICK: integer := 16
port(
rx: in std_logic;
s_tick: in std_logic;
rx_done_tick: out std_logic;
dout: out std_logic_vector(7 downto 0)
end COMPONENT;
--signals
signal rx_d: std_LOGIC;
signal dout_m:std_logic_vector(7 downto 0);
signal s_tick_m:std_LOGIC;
signal q_out: std_logic_vector(8 downto 0);
BEGIN
gene: mod_326 port map (clk,reset,s_tick_m,q_out);
UART_2: UART_1 port map (clk,reset,R_x,s_tick_m ,rx_d,dout_m);
comp_1: compare port map (clk,reset,'0',rx_d,dout_m,A_o,flag_o);
end ckt;
What condition do you want?
Why not post the problems and ask questions.
we do that
if the tag is right three leds in the kit will light
if not only one led
I wonder if you
- tested the individual VHDL components and complete design in a test bench
- tested the FPGA design with a terminal as test data source
- verified that the RFID reader actually outputs the expected UART data
If you want others to check your code, your surely need to post the complete design. But preferably you'll test the design function yourself using standard verification methods.
this is uart code ....
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity UART_1 is
generic(
DBIT: integer := 8;
port(
rx: in std_logic;
end UART_1;
architecture arch of UART_1 is
type state_type is (idle, start, data, stop);
signal state_reg, state_next: state_type;
signal s_reg, s_next: unsigned(3 downto 0);
signal n_reg, n_next: unsigned(2 downto 0);
signal b_reg, b_next: std_logic_vector(7 downto 0);
begin
process(clk, reset) -- FSMD state and data regs.
begin
if (reset = '1') then
state_reg <= idle;
s_reg <= (others => '0');
n_reg <= (others => '0');
b_reg <= (others => '0');
elsif (clk'event and clk='1') then
state_reg <= state_next;
s_reg <= s_next;
n_reg <= n_next;
b_reg <= b_next;
end if;
end process;
-- next state logic
process (state_reg, s_reg, n_reg, b_reg, s_tick, rx)
begin
state_next <= state_reg;
s_next <= s_reg;
n_next <= n_reg;
b_next <= b_reg;
rx_done_tick <= '0';
case state_reg is
when idle =>
if (rx = '0') then
state_next <= start;
s_next <= (others => '0');
end if;
when start =>
if (s_tick = '1') then
if (s_reg = 7) then
state_next <= data;
n_next <= (others => '0');
else
s_next <= s_reg + 1;
end if;
end if;
when data =>
if (s_reg = 15) then
b_next <= rx & b_reg(7 downto 1);
if (n_reg = (DBIT - 1)) then
state_next <= stop;
else
n_next <= n_reg + 1;
end if;
else
end if;
end if;
when stop =>
if (s_reg = (SB_TICK-1)) then
state_next <= idle;
rx_done_tick <= '1';
else
end if;
end if;
end case;
end process;
dout <= b_reg;
end arch;
this is compare code ...
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
library ieee;
entity compare is
port(
a: out std_logic_vector (4 downto 0):="00000" ;
flag: out std_logic
end entity;
architecture arch of compare is
signal dout: std_logic_vector(39 downto 0);
signal buf_reg, buf_next: std_logic_vector(W-1 downto 0);
signal flag_reg, flag_next: std_logic;
begin
process(clk, reset)
begin
buf_reg <= (others =>'0');
flag_reg <= '0';
buf_reg <= buf_next;
flag_reg <= flag_next;
end if;
end process;
process (buf_reg, flag_reg, set_flag, clr_flag, din)
variable count: integer:=0;
begin
buf_next <= buf_reg;
flag_next <= flag_reg;
if (set_flag = '1') then
buf_next <= din;
flag_next <= '1';
elsif (clr_flag = '1') then
flag_next <= '0';
end if;
case count is
when 0 =>
dout(39 downto 32)<= buf_reg;
count := count + 1;
when 1 =>
dout(31 downto 24)<= buf_reg;
count := count + 1;
when 2=>
dout(23 downto 16)<= buf_reg;
count := count + 1;
when 3 =>
dout(15 downto 8)<= buf_reg;
count := count + 1;
when 4 =>
dout(7 downto 0)<= buf_reg;
 IF dout="0000000001111110100010101110011100010011" then
a<="00111";
else
a<="00000";
end if;
count := 0;
when others =>
count := 0;
end case;
end process;
-- output logic
flag <= flag_reg;
end arch;
this is code for clock divider
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
library ieee;
entity mod_326 is
generic(
N: integer := 9;
M: integer := 326
port(
end entity;
architecture arch of mod_326 is
signal r_reg: unsigned(N-1 downto 0);
signal r_next: unsigned(N-1 downto 0);
begin
process(clk, reset)
begin
r_reg <= (others => '0');
r_reg <= r_next;
end if;
end process;
-- next state logic
r_next <= (others => '0') when r_reg=(M-1) else
r_reg + 1;
-- output logic
q <= std_logic_vector(r_reg);
max_tick <= '1' when r_reg=(M-1) else '0';
end arch;
Tricky and FvM made it pretty clear that you should run verification simulations on the blocks and on the entire design. Then ask specific questions when you get stuck.
Just posting your code and requesting someone verify it for you (or maybe expecting someone to write a testbench?) is not going to happen. If that is what you want done, then start a thread in the EDA jobs section and expect to pay a consultant to do this for you.
