karg3
Newbie level 3
Hi All,
I have a circuit powered by AAA battery of 1.5 V,1A. I wanted to measure the current consumption in the board. The AAA battery assembly will be not be accessible to measure, so another AAA 1.5V battery in connected in parallel and current is measured across the wire using clamp meter.
I understand when the batteries are connected in parallel, the voltage will remain same but the current will be doubled. The connection is as shown below..
Can anyone clarify if this is the right way to measure the current across. I am doubtful since the current is doubled,will the measurement be accurate?
