+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 3
    Points: 3,572, Level: 14
    Join Date
    Dec 2004
    Posts
    154
    Points
    3,572
    Level
    14
    CTS question about create_clock
    There are two clock made constraint as create_clock.
    If I don't set false_path about these two clock.
    After CTS, are these two path balance ?
    What action does CTS handle false_path constraint ?
    For CTS, these two clocks are treat as independent and have not balance ??
    Thanks.
    •   AltAdvertisement
  2. #2
    Full Member level 5
    Points: 1,575, Level: 9
    Join Date
    Oct 2015
    Posts
    247
    Points
    1,575
    Level
    9
    Re: CTS question about create_clock
    Which tool set do you use ?
    For Synopsys ICC, 2 primary clocks ( created by create_clock command ) are not balanced in their latencies or say, they are indenpendent in latency.
    The same CTS for the case of 2 clocks which have false path relationship.
  3. #3
    Advanced Member level 5
    Points: 8,111, Level: 21
    Join Date
    Apr 2016
    Posts
    1,707
    Points
    8,111
    Level
    21
    Quote Originally Posted by nemolee View Post
    Thanks.
    I think what you are asking is if you can assume any relationship between independent clocks. The answer for that is no. But I am not sure I understood your question, really convoluted English there.
    •   AltAdvertisement
  4. #4
    Super Moderator
    Points: 30,595, Level: 42
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    7,038
    Points
    30,595
    Level
    42
    This is only conjecture...
    Maybe the situation is two synchronous clocks (created externally) are coming into their ASIC and they want them to be usable as synchronous clocks internal to the ASIC, therefore they want the clock trees to be balanced.
  5. #5
    Full Member level 3
    Join Date
    Dec 2004
    Posts
    154
    Points
    3,572
    Level
    14
    My senior colleague in company replied me.
    False path is just timing constraint, not effect CTS and won’t be see.
    CTS is just balance leaf pins of its create clock.
    Each “create_clock” won’t balance to each “create_clock”.
    Eg. A clock may 1ns latency.
    B clock may 5ns latency.
    •   AltAdvertisement
  6. #6
    Join Date
    Apr 2016
    Posts
    1,707
    Points
    8,111
    Level
    21
    wrong. false path affects the CTS if it isn't set properly. remember that CTS tries to balance skew, and might waste resources to balance the two flops in this false path if it happens to be a critical path.
  7. #7
    Newbie level 5
    Points: 906, Level: 6
    Join Date
    Jul 2013
    Posts
    8
    Points
    906
    Level
    false_path constraint won't be affected in CTS interclock balance.
    And ICC doesn't adjust interclock skew balance by default.
    In icc, You would be set another commands.
    "set_inter_clock_delay_options -balance_group "$need_to_balance_clocks" -balance_group_name balance_grp1 -target_delay_clock $longest_delay_clock
    and perform shown below in mega command.
    "clock_opt -inter_clock_balance"
  8. #8
    Join Date
    Apr 2016
    Posts
    1,707
    Points
    8,111
    Level
    21
    Quote Originally Posted by hyun5226 View Post
    This is not correct.
    You are assuming CTS targets skew only. it doesn't. not anymore.
    Think of CTS as a retiming engine. It needs proper false paths to be defined.
